https://wiki.electrolab.fr/api.php?action=feedcontributions&user=Eric&feedformat=atomElectrolab - User contributions [en]2024-03-29T02:28:43ZUser contributionsMediaWiki 1.22.4https://wiki.electrolab.fr/Projets:Perso:2018:KAPEX_KS120_DadoCutFunctionEnhancementProjets:Perso:2018:KAPEX KS120 DadoCutFunctionEnhancement2021-05-10T08:53:38Z<p>Eric: </p>
<hr />
<div><br />
{{Project<br />
|name=: Modify / enhance the dado cut adjustment span of the FESTOOL Kapex KS120 miter saw<br />
|author= Eric<br />
|proposal_date=August 2018<br />
|abstract1=Mod for FESTOOL KAPEX KS120 MITER SAW <br />
|abstract3=Augmentation de la plage de réglage de la fonction de découpe de rainure de la scie à onglet FESTOOL KAPEX KS120<br />
|tags=FESTOOL KAPEX KS120,dado cut,rainure,modding,enhancement<br />
|where=<br />
|for_who=my Kapex<br />
|official_electrolab_project=<br />
|elecrolab_project_manager= N/A<br />
|budget= 15€<br />
|number_of_members= N/A<br />
|estimated_time= 1/2 day<br />
}}<br />
<br />
<br />
=Dado cuts height adjustement feature=<br />
<br />
The Kapex KS120 height adjustement for dado cuts is limited to about 40 mm, which avoids using this feature for high workpieces.<br />
This limitation [http://festoolownersgroup.com/festool-how-to/kapex-ks-120-cutting-depth-limiter-limitation-of-cutting-higher-workpieces/ seems to annoy other Kapex users.]<br />
<br />
[[File:FESTOOL_KAPEX_dado_cut_mod_50411.JPG|800px|thumb|center|Dado cuts are limited to about 40 mm]]<br />
<br />
<br />
Ron Paulk recorded a [https://www.youtube.com/watch?v=YynWuNeGuQY small video] to show how to perform dado cuts using the Kapex KS120. Many thanks to him !<br />
<br />
=User's manuals=<br />
The cutting depth limit lever is referenced at position "1.4" on page 4 of the [https://www.festoolusa.com/-/media/tts/fcp/festool-usa/downloads/manuals/472068_005_ks_120_usa.pdf#page=4 PDF user manual.]<br />
<br />
The cutting depth limit lever is referenced at position "U" on page 7 of this [https://www.manualsdir.com/manuals/103754/festool-kapex-ks-120.html?page=7&original=1 very nice official Kapex KS120 supplemental user's manual.] <br />
<br />
=Enhancement=<br />
<br />
I updated my Kapex KS120 to allow a cutting depth limit adustement from 0 to ...93 mm<br />
<br />
==How to ?==<br />
Replace the existing cutting depth limiter lever with a custom made part.<br />
<br />
To unmount the existing 1.4 lever, remove the mains cable strain relief and the machine back panel/plate.<br />
<br />
As shown in the picture below, the cutting depth limiter lever is of easy access.<br />
[[File:FESTOOL KAPEX dado cut mod 50412 ann.jpg|800px|thumb|center|The cutting depth limiter lever is easy to replace]]<br />
<br />
<br />
<br />
On a lathe, process a [https://www.rcm-machines.com/fr/c45k-poli-/acier-c45k-rectifi-h6-rond-poli--6-mm-x-300-mm/rcstp06 6 mm silver steel rod] or similar to make a modified copy of the lever 1.4 using the dimensions shown in the picture below (scale = mm). The shape of the thinner side of the rod does not need to match exactly with the original part.<br />
<br />
[[File:FESTOOL KAPEX dado cut mod 50409 ann.jpg|800px|thumb|center|Original and custom made cutting depth limiter levers]]<br />
<br />
<br />
<br />
Use an M6 x 1 mm (right hand) HSS die to machine the thread.<br />
<br />
e.g ref. SDEMM06B [http://www.tap-die.com/contents/en-uk/p637_6x1mm_dies_1od.html here.]<br />
<br />
<br />
The total lenght of the new custom lever should not exceed 11,5 cm, as shown in the picture above.<br />
<br />
Use an angle grinder to create the two flats on the opposite side of the thread.<br />
<br />
<br />
<br />
Mount the barrel nut on the threaded side of your custom made lever<br />
<br />
As you can observe on the original part, the lowest possible position of the barrel nut is 12 mm.<br />
<br />
On your custom made lever, use a small chisel to break the thread at 3 or 4 locations in order to limit the barrel nut lowest position to 12 mm (same value as on the original Festool part).<br />
<br />
[[File:FESTOOL_KAPEX_dado_cut_mod_50417.JPG|800px|thumb|center|Limit the barrel nut lowest position to 12 mm. The broken thread is visible just at the right side of the barrel nut]]<br />
<br />
<br />
Replace the original lever with your custom made lever.<br />
<br />
Once mounted in your miter saw, check if your custom made lever has enough room to move near the motor enclosure.<br />
<br />
[[File:FESTOOL_KAPEX_dado_cut_mod_50420.JPG|800px|thumb|center|Take care of the motor enclosure]]<br />
<br />
==Mounting hints==<br />
<br />
Keep a look on the tall miter latch parts to be sure they are in their correct position.<br />
[[File:FESTOOL_KAPEX_dado_cut_mod_50421.JPG|800px|thumb|center|Tall miter latch parts mounting]]<br />
<br />
<br />
While positionning the plastic back panel, take care to put the tall miter locking lever spring into it's groove.<br />
[[File:FESTOOL KAPEX dado cut mod 50424 ann.jpg|800px|thumb|center|Spring and groove for the tall miter feature]]<br />
<br />
==Results==<br />
With this modding, we now obtain a gorgeous adjustement span from 0 to 93 mm.<br />
The dado cut feature of the Kapex becomes now far more versatile.<br />
[[File:FESTOOL_KAPEX_dado_cut_mod_50435.JPG|800px|thumb|center|Great! We now have more than twice the span of the unmodified machine]]<br />
<br />
=Other hints and limitations=<br />
==Barrel nut==<br />
You may use the M6 x 1 barrel nut from the existing lever assembly or buy a [https://www.fastenright.com/general-fixings/cross-dowel-barrel-nut/ff04 new part] <br />
The original part has a 10 mm diameter and 14 mm lenght.<br />
<br />
==The height adjustment lever has now 3 positions==<br />
Once upgraded with your custom part, setting the depth position is slighly different.<br />
<br />
For adjustement limit above 50 mm, the 1.4 lever has to be set into an intermediate position.<br />
<br />
[[File:FESTOOL_KAPEX_dado_cut_mod_50436.JPG|300px|thumb|left|Depth limit lever in engaged position for dado cuts from 0 to 40 mm]]<br />
[[File:FESTOOL_KAPEX_dado_cut_mod_50442.JPG|300px|thumb|right|Depth limit lever in disengaged position]][[File:FESTOOL_KAPEX_dado_cut_mod_50428.JPG|300px|thumb|center|Lever in intermediate position for dado cuts from 40 to 93 mm]]<br />
<br />
<br />
<br />
==Cutting witdh==<br />
Another limitation (that already exists on an unmodified Kapex saw) : you won't be able to perform the dado cut in one pass on the full nominal machine width of 305 mm, but 220 mm seems to be reachable. To process wider dado cuts, you need to reverse your workpiece.</div>Erichttps://wiki.electrolab.fr/Projets:Perso:2018:KAPEX_KS120_DadoCutFunctionEnhancementProjets:Perso:2018:KAPEX KS120 DadoCutFunctionEnhancement2021-05-10T08:49:00Z<p>Eric: </p>
<hr />
<div><br />
{{Project<br />
|author= Eric<br />
|where=<br />
|budget= 15€<br />
}}<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
=Enhancement=<br />
<br />
<br />
==How to ?==<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
Use an angle grinder to create the flats on the opposite side of the rod.<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
==Results==<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
Another limitation (that already exists on an unmodified Kapex saw) : you won't be able to perform the dado cut in one pass on the full nominal machine width of 305 mm, but 220 mm seems to be reachable. To process wider dado cuts, you need to reverse your workpiece.</div>Erichttps://wiki.electrolab.fr/RessourcesRessources2021-01-20T19:51:59Z<p>Eric: /* Notions de base en électricité, électronique et schéma */</p>
<hr />
<div>= Les formations =<br />
<br />
== Trainings vidéo réalisés à l'Electrolab ==<br />
http://downloads.electrolab.fr/training/<br />
<br />
<br />
== Howto publiés par le lab ==<br />
Ces how-to sont surtout des penses-bête destinés à recueillir l'information.<br />
*[[Cnc-howto|CNC howto]]<br />
*[[CAO_howto|CAO howto]]<br />
*[[3D_printing|3D printing]]<br />
*[[PrintedCircuitBoard|Fabrication de circuits imprimés]]<br />
*[[Recommandations_chimie|Chimie au Lab : recommandations en vrac]]<br />
*[[Affut/forets|Affutage manuel des forets]]<br />
*[[Mortier|Comment faire un mortier]]<br />
*[[Alimentations_à_decoupage|Les topologies d'alimentation à découpage]]<br />
<br />
== Articles sympa & ressources diverses ==<br />
=== Sites web ===<br />
==== sciences ====<br />
*[https://leblob.fr leblob] la chaîne de vulgarisation généraliste d'Universcience (cité des sciences, palais de la découverte)<br />
==== informatique & électronique ====<br />
*[https://interstices.info/ interstices] site de vulgarisation principalement autour des technologies de l'informatique/logique<br />
*[[RaspberryPi]] Page du wiki qui regroupe les infos et liens sympa sur la Raspberry Pi (raspi pour les intimes).<br />
*[[Robotique:Equipement]] Page du wiki qui regroupe les infos et liens sur la robotique.<br />
==== usinage, mécanique, fonderie ====<br />
*[http://lcamtuf.coredump.cx/gcnc/ Guerrilla guide to CNC machining, mold making, and resin casting]<br />
*[https://docs.google.com/folderview?id=0B_lQIis3mN_XMURkbzdKcFJSZnlpSG1YSVRqb09wUQ Archive regroupant des écrits sur les armes historiques et la métallurgie (forge, soudure, moulage)]<br />
*[http://www.thatlazymachinist.com thatlazymachinist.com] attention le site pique les yeux mais pas mal de vidéos (en québecois) sur l'usinage<br />
<br />
=== podcasts ===<br />
*[https://www.franceculture.fr/emissions/les-cours-du-college-de-france les cours du Collège de France] par France culture<br />
*[https://www.franceculture.fr/emissions/la-methode-scientifique la methode scientifique] émission d'actualité scientifique de France culture (54mn)<br />
*[https://www.franceinter.fr/emissions/les-savanturiers les savanturiers] émission d'actualité scientifique de France inter (4mn)<br />
*[https://www.franceinter.fr/emissions/la-tete-au-carre la tête au carre] émission d'actualité scientifique de France inter (54mn)<br />
=== Chaînes vidéo ===<br />
*[https://www.youtube.com/user/epenser1 e-penser], chaîne de vulgarisation scientifique généraliste<br />
==== zététique (raisonement, logique et biais cognitifs) ====<br />
*[https://www.youtube.com/user/TroncheEnBiais TroncheEnBiais]<br />
*[https://www.youtube.com/user/fauxsceptique fauxsceptique]<br />
==== Math ====<br />
*[https://www.youtube.com/user/Micmaths Micmaths] vulgarisation mathématique<br />
<br />
=== Conférences ===<br />
*[http://www.cite-sciences.fr/fr/ressources/conferences-en-ligne/ les conférences de la cité des sciences] (grand public)<br />
*[http://www.college-de-france.fr/site/audio-video/index.htm conférences du Collège de France], plus de 10000 conférences sur la science en cours (cible: grand public avec quelques bases). Malheureusement leur système de navigation est une merde infâme ( [https://salamandre.college-de-france.fr/audiovisuel-search-form.html recherche ici])disponible sous forme de podcast dans la section podcast<br />
<br />
=== Livres ===<br />
'''Tous les livres de Randall Munroe''' (what if, xkcd): what if (vf Et si... ?),How To (e-book), Thing explainer<br />
<br />
'''How science works''' (en anglais) isbn:978-0-2412-8727-9 livre généraliste de vulgarisation à destination d'un grand public curieux, bourré de graphisme pour expliquer simplement des concepts avancé (chimie, optique, énergie, biologie,...)<br />
<br />
'''Physique minute''' isbn:978-2-84933-314-3 vulgarisation petit format mais dense. Un texte et un schémas par concept. toutes les bases de la physique moderne y sont.<br />
<br />
'''La physique à ma portée''' (et les autres livres scientifiques des édition cepaduès par Raymond Vetter et Guy Taïeb) isbn: 978-2-85428-995-4 La on pars dans du plus costaud. Il faut de bonnes bases pour pouvoir suivre. Parfait pour des sujets que vous connaissez déjà pas mal et que vous voulez approfondir. Les bouquins sont pas très épais mais on relis plusieurs fois les pages :-p<br />
<br />
[https://www.victoires.com/fr/Lumiere__le_Spectre_visible_et_au_dela.html '''Lumière'''] (et autres livres de la collection: atomes, molécules, réactions,...) isbn: 978-2-8099-1437-5 une belle série de livres faisant la part belle à de magnifiques photos pleine page. Pour découvrir ces sujets sans se prendre la tête.<br />
<br />
'''L'intelligence artificielle''' (Nicolas Spatola) isbn:978-2-84516-808-4 tout petit format qui permet de découvrir le sujet rapidement.<br />
<br />
=== Blog BD ===<br />
*[https://www.xkcd.com/ xkcd], une référence des blogs bd scientifiques et humoristique (en anglais). Il faut souvent un peu de baggages.[https://xkcd.lapin.org/ Traductions fr], mais on y perd un peu<br />
*[https://what-if.xkcd.com/ what if]: même auteur que le précédent des réponses scientifiques à des questions absurdes (en anglais)<br />
*[https://www.smbc-comics.com/ saturday morning breakfast cereal]: sciences, philo et absurde (vf de certaines planches [https://cereales.lapin.org/ ici])<br />
*Le site [https://lapin.org/tous-les-webcomics/ lapin.org] traduit et liste pas mal de blogs BD scientifiques (ou pas) dont certains au dessus<br />
<br />
== Howto (externes) ==<br />
*[https://docs.google.com/file/d/0B1Q2XTPf2Q8xRjNiU3hGeVhER0E/view?pli=1&sle=true soudure de CMS]<br />
*[http://mightyohm.com/files/soldercomic/translations/Souder%20c%27est%20facile_FR.pdf soudure composant traversant]<br />
*[http://www.pinrepair.com/connect/ Pour la connection des connecteur à sertir[EN]]<br />
Projets:Lab:Système d'éclairage circulaire pour broche CNC<br />
<br />
<br />
===Notions de base en électricité, électronique et schéma ===<br />
*[http://fr.wikipedia.org/wiki/Courant_%C3%A9lectrique Le courant électrique]<br />
*[http://fr.wikipedia.org/wiki/Symbole_%C3%A9lectronique Symboles électroniques pour schémas]<br />
*[http://fr.wikipedia.org/wiki/Lois_de_Kirchhoff Loi des mailles, loi des noeuds (lois de Kirchoff)]<br />
*[http://fr.wikipedia.org/wiki/Source_de_tension Source de tension] <br />
*[http://en.wikipedia.org/wiki/Current_source Source de courant]<br />
*[http://www.unige.ch/sciences/physique/tp/tpe/PDF/E1.pdf Source de tension et de courant (expériences)]<br />
*[http://fr.wikipedia.org/wiki/Th%C3%A9or%C3%A8me_de_Th%C3%A9venin Théorème de Thévenin]<br />
*[http://fr.wikipedia.org/wiki/Th%C3%A9or%C3%A8me_de_Norton Théormème de Norton]<br />
*[http://jredoutey.free.fr/Puissance/Technologie_composants.pdf Technologie des composants électroniques]<br />
*[http://dessoudeurs-ex.lebonforum.com/t98-cours-electronique-m07-alimentations Transformateurs, redressement et filtrage]<br />
*[http://fr.wikipedia.org/wiki/R%C3%A9gulateur_de_tension Régulateurs de tension]<br />
*[http://fr.wikipedia.org/wiki/R%C3%A9gulateur_lin%C3%A9aire Régulateurs linéaires]<br />
*[http://home.cogeco.ca/~rpaisley4/xCurrentReg.html Régulateurs de courant]<br />
*[http://www.sonelec-musique.com/electronique_realisations_alim_led.html Alimentation de leds]<br />
*[http://www.free-track.net/fichiers/doc_led.pdf Principes de raccordement de leds]<br />
*[http://www.sonelec-musique.com/electronique_bases_transistor.html Utilisation du transistor]<br />
*[https://www.campbellsci.fr/blog/ins-outs-rf-connectors Principaux connecteurs RF]<br />
<br />
==Réflexions==<br />
*[[Volta|Notre voiture électrique : la Volta !]]<br />
*[[Working_with_SMD|Le matériel de nos rêves pour souder/réparer des cartes à CMS]]<br />
*[[Electronical_CAD_software_choice|Choix d'un outil de CAO électronique pour le Lab]]<br />
*[[Workbench_tools|Que mettre dans les tiroirs de nos paillasses]]<br />
*[[Logos|Propositions de Logos]]<br />
<br />
==Bon Plans==<br />
*[[DecoupeLaser|Comment faire de la découpe/gravure laser par l'intermédiaire du lab]]<br />
*[[Liste_Fournisseurs|Une liste de fournisseurs]], le bon endroit pour indiquer vos dealers habituels - ou en trouver de nouveaux.</div>Erichttps://wiki.electrolab.fr/Projets:Perso:2020:TEKTRONIX_2467B_Add_HeatsinkToU800Projets:Perso:2020:TEKTRONIX 2467B Add HeatsinkToU8002020-11-20T18:32:22Z<p>Eric: /* Add a heatsink to 2467B U800 horizontal output stage IC */</p>
<hr />
<div>{{Project<br />
|name=: TEKTRONIX 2465B - 2467B : add a heatsink to U800 horizontal output stage IC (TEK '155-0241-02') <br />
|author= Eric<br />
|proposal_date=Nov 2020<br />
|abstract1=Mod for 2465/2466/2467 TEKTRONIX scope series<br />
|abstract3=Ajout d'un radiateur sur le composant U800 (étage de sortie horizontal) sur oscilloscope TEKTRONIX 2467B<br />
|tags=TEKTRONIX 2467B,U800,'155-0241-02',heatsink<br />
|where=<br />
|for_who=my 2467B<br />
|budget= 0 €<br />
|estimated_time= 1,5 hour<br />
}}<br />
<br />
<br />
=Context=<br />
My [https://www.us-instrument.com/content/images/thumbs/0009638_tektronix-2467b-400-mhz-4-channel-oscilloscope_550.jpeg TEK 2467B oscilloscope] recently released some magic smoke : failure came from the mains filter C14 socket. Replacing the mains filter-socket needs some time (2-3 hours) because gaining access to the defective part requires the whole power supply assembly to be removed :(<br />
<br />
=Add a heatsink to 2467B U800 [http://w140.com/tekwiki/wiki/155-0241-02 horizontal output stage IC]= <br />
As the scope was open (and it's mains filter-socket sucessfully replaced), I choose to make use of the opportunity to add a small heatsink to the [https://www.youtube.com/watch?v=WtacH4FGmR0 rather fragile Tektronix "155-0241-02" U800 horizontal output stage] with is difficult to find as spare part. A design that duplicates the parts functionality can be [https://www.davmar.org/TE/Tek2465/lafay.html found here]<br />
[[File:TEKTRONIX_2467B_U800_Without_Heatsink_404.JPG|400px|thumb|center|The famous U800 '155-0241-02' originally branded 'TEK' in his heasinked DIP-24 package (one side steel tab); some units might also be branded 'MAXIM']]<br />
<br />
<br />
I could find a small heatsink in my junk drawer.<br />
<br />
Lenght : 110 mm<br />
<br />
Width : 16 mm<br />
<br />
Height : 12 mm <br />
<br />
Luckilly, its bottom is already coated with a kind of yellow thermally conductive foam/compound.<br />
[[File:TEKTRONIX_2467B_U800_Junk_Heatsink_400.JPG|400px|thumb|center|A small heatsink found in my junk drawer (pen is for size comparison)]]<br />
<br />
==How to proceed ?==<br />
Shorten the heasink to a lenght between 45 and 60 mm : there's actually enough room on the tab side of the IC so that the heasink can be slighly longer than U800.<br />
<br />
Remove the fins where the hole(s) have to be placed.<br />
<br />
Bore diameter : 3 mm<br />
<br />
Distance between the two mounting holes : 36,9 mm<br />
[[File:TEKTRONIX_2467B_U800_Machined_Heatsink_401.JPG|400px|thumb|center|Two fins removed, two 3 mm holes added]]<br />
<br />
<br />
Installation on top of U800 is rather straightforward by using an additional nut and washer, as shown on the picture below.<br />
[[File:TEKTRONIX_2467B_U800_With_Heatsink_409.JPG|400px|thumb|center|Done ! The nut on the left is the orignal one; the nut on the right is an additionnal one : it is good practice to keep the original right nut tighten onto the IC's steel tab]]<br />
<br />
==Additionnal information==<br />
The same kind of improvement on a 2465B can be seen at 1:24 on [https://www.youtube.com/watch?v=nizLA1hUG80 this video] made by Philippe Demerliac.</div>Erichttps://wiki.electrolab.fr/Projets:Perso:2020:TEKTRONIX_2467B_Add_HeatsinkToU800Projets:Perso:2020:TEKTRONIX 2467B Add HeatsinkToU8002020-11-20T18:31:51Z<p>Eric: /* Context */</p>
<hr />
|author= Eric<br />
|where=<br />
|budget= 0 €<br />
}}<br />
<br />
<br />
=Context=<br />
<br />
As the scope was open (and it's mains filter sucesfully replaced), I choose to make use of the opportunity to add a small heatsink to the [https://www.youtube.com/watch?v=WtacH4FGmR0 rather fragile Tektronix "155-0241-02" U800 horizontal output stage] with is difficult to find as spare part. A design that duplicates the parts functionality can be [https://www.davmar.org/TE/Tek2465/lafay.html found here]<br />
<br />
<br />
<br />
<br />
Width : 16 mm<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
The same kind of improvement on a 2465B can be seen at 1:24 on [https://www.youtube.com/watch?v=nizLA1hUG80 this video] made by Philippe Demerliac.</div>Erichttps://wiki.electrolab.fr/Projets:Perso:2020:TEKTRONIX_2467B_Add_HeatsinkToU800Projets:Perso:2020:TEKTRONIX 2467B Add HeatsinkToU8002020-11-17T17:14:29Z<p>Eric: /* How to proceed ? */</p>
<hr />
|author= Eric<br />
|where=<br />
|budget= 0 €<br />
}}<br />
<br />
<br />
=Context=<br />
My [https://www.us-instrument.com/content/images/thumbs/0009638_tektronix-2467b-400-mhz-4-channel-oscilloscope_550.jpeg TEK 2467B oscilloscope] recently released some magic smoke : failure came from the mains filter C14 socket. Replacing the mains socket-filter needs some time (2-3 hours) because gaining access to the defective part requires the whole power supply assembly to be removed :(<br />
<br />
<br />
<br />
<br />
<br />
Width : 16 mm<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
The same kind of improvement on a 2465B can be seen at 1:24 on [https://www.youtube.com/watch?v=nizLA1hUG80 this video] made by Philippe Demerliac.</div>Erichttps://wiki.electrolab.fr/Projets:Perso:2020:TEKTRONIX_2467B_Add_HeatsinkToU800Projets:Perso:2020:TEKTRONIX 2467B Add HeatsinkToU8002020-11-17T15:52:24Z<p>Eric: /* Additionnal information */</p>
<hr />
|author= Eric<br />
|where=<br />
|budget= 0 €<br />
}}<br />
<br />
<br />
=Context=<br />
<br />
<br />
<br />
<br />
<br />
Width : 16 mm<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
[[File:TEKTRONIX_2467B_U800_With_Heatsink_409.JPG|400px|thumb|center|Done !]]<br />
<br />
The same kind of improvement on a 2465B can be seen at 1:24 on [https://www.youtube.com/watch?v=nizLA1hUG80 this video] made by Philippe Demerliac.</div>Erichttps://wiki.electrolab.fr/Projets:Perso:2020:TEKTRONIX_2467B_Add_HeatsinkToU800Projets:Perso:2020:TEKTRONIX 2467B Add HeatsinkToU8002020-11-17T15:43:17Z<p>Eric: /* Context */</p>
<hr />
|author= Eric<br />
|where=<br />
|budget= 0 €<br />
}}<br />
<br />
<br />
=Context=<br />
<br />
<br />
<br />
<br />
<br />
Width : 16 mm<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
The same kind of improvement can be seen at 1:24 on [https://www.youtube.com/watch?v=nizLA1hUG80 this video] made by Philippe Demerliac on a 2465B.</div>Erichttps://wiki.electrolab.fr/Projets:Perso:2020:TEKTRONIX_2467B_Add_HeatsinkToU800Projets:Perso:2020:TEKTRONIX 2467B Add HeatsinkToU8002020-11-17T15:42:47Z<p>Eric: </p>
<hr />
|author= Eric<br />
|where=<br />
|budget= 0 €<br />
}}<br />
<br />
<br />
=Context=<br />
My [https://www.us-instrument.com/content/images/thumbs/0009638_tektronix-2467b-400-mhz-4-channel-oscilloscope_550.jpeg TEK 2467B oscilloscope] recently released some magic smoke : failure came form the mains filter C14 socket. Replacing the mains socket-filter needs some time (2-3 hours) because gaining access to the defective part requires the whole power supply assembly to be removed :(<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
Width : 16 mm<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
The same kind of improvement can be seen at 1:24 on [https://www.youtube.com/watch?v=nizLA1hUG80 this video] made by Philippe Demerliac on a 2465B.</div>Erichttps://wiki.electrolab.fr/Projets:Perso:2020:TEKTRONIX_2467B_Add_HeatsinkToU800Projets:Perso:2020:TEKTRONIX 2467B Add HeatsinkToU8002020-11-17T15:30:24Z<p>Eric: </p>
<hr />
|author= Eric<br />
|where=<br />
|budget= 0 €<br />
}}<br />
<br />
<br />
=Context=<br />
My [https://www.us-instrument.com/content/images/thumbs/0009638_tektronix-2467b-400-mhz-4-channel-oscilloscope_550.jpeg] recently released some magic smoke : failure came form the mains filter C14 socket. Replacing the mains socket-filter needs some time (2-3 hours) because gaining access to the defective part requires the whole power supply assembly to be removed :(<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
Width : 16 mm<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
The same kind of improvement can be seen at 1:24 on [https://www.youtube.com/watch?v=nizLA1hUG80 this video] made by Philippe Demerliac on a 2465B.</div>Erichttps://wiki.electrolab.fr/Projets:ArchivesProjets:Archives2020-11-17T15:28:37Z<p>Eric: /* Projets personnels achevés - Completed members projects */</p>
<hr />
<div>Sur cette page sont récapitulés l'ensemble des projets achevés, qu'ils soient personnels ou du lab.<br />
<br />
==Projets du lab achevés - Completed Electrolab projects==<br />
<br />
{|class="wikitable sortable" width=100%<br />
|-<br />
! Catégorie !! class="unsortable"| Projet !! Auteur !! Etat<br />
|-<br />
| Récursive || [[Construire le Lab|DIY - Construire son Electrolab (version 1.0 (2011-2013)]] || Anybody || Terminé en mars 2013<br />
|-<br />
| Projet|| [[Projets:Lab:2014:SMA Thumb-Wrench|Bouton moleté pour SMA avec limiteur de couple]] || Vincent|| {{Avancement|100||border: solid 1px gray;background-color: lightgray;width: 50px;margin-right:10px;margin-top:-5px;display:inline-block;}}<br />
|-<br />
| RepRap || [[Projets:Perso:2011:RepRap:Mendel_n1|Réalisation d'une Reprap Mendel]] || Collectif || {{Avancement|100||border: solid 1px gray;background-color: lightgray;width: 50px;margin-right:10px;margin-top:-5px;display:inline-block;}}<br />
|-<br />
| Equipement du Lab || [[Projets:RFID|Système d'accès RFID]] || [[User:Gradator|Gradator]] || Terminé<br />
|-<br />
| Robotique || [[Projets:Lab:2011:Couperobotique2013|Coupe de France de robotique 2013]] || Collectif || Terminé<br />
|-<br />
| Robotique || [[Projets:Lab:2013:Couperobotique2014|Coupe de France de robotique 2014]] || Collectif || Terminé<br />
|-<br />
| SDR|| [[Projets:Lab:2011:SDR_Widget|Processeur de signal SDR à large dynamique]] || f6itu|| {{Avancement|100||border: solid 1px gray;background-color: lightgray;width: 50px;margin-right:10px;margin-top:-5px;display:inline-block;}}<br />
|-<br />
| SDR|| [[Projets:Lab:2011:GHPSDR3-Alex|Serveur de streaming de SDR (DVB-T, Softrock, USRP...)]] || f6itu|| {{Avancement|100||border: solid 1px gray;background-color: lightgray;width: 50px;margin-right:10px;margin-top:-5px;display:inline-block;}}<br />
|-<br />
| SDR|| [[Projets:Lab:2011:TVHeadend|Serveur de streaming TV (SDR clefs DVB-T)]] || f6itu|| {{Avancement|100||border: solid 1px gray;background-color: lightgray;width: 50px;margin-right:10px;margin-top:-5px;display:inline-block;}}<br />
|-<br />
| SDR|| [[Projets:Lab:2011:Softrock|Howto introductif sur les SDR simples]] || f6itu|| {{Avancement|100||border: solid 1px gray;background-color: lightgray;width: 50px;margin-right:10px;margin-top:-5px;display:inline-block;}}<br />
|-<br />
| Kit|| [[Projets:Lab:2015:SolderStation:Manuel]]|| Collectif || {{Avancement|100||border: solid 1px gray;background-color: lightgray;width: 50px;margin-right:10px;margin-top:-5px;display:inline-block;}} Work done<br />
|-<br />
| Presse 50 tonnes || [[Projets:Lab:2015:Presse]]||Pitrak, David et Mael C, Francis, Arnaud, Guillaume, Louis, Denis|| {{Avancement|100||border: solid 1px gray;background-color: lightgray;width: 50px;margin-right:10px;margin-top:-5px;display:inline-block;}} <br />
|-<br />
| Bourse aux objets || [[Projets:Bourse_aux_objets]]||||Terminé <br />
|-<br />
|-class="sortbottom"<br />
! !! !! !!<br />
|}<br />
<br />
<br />
==Projets personnels achevés - Completed members projects==<br />
|-<br />
|-<br />
| Projet || [[Projets:Lab:2011:DominouxCMS|Dominoux CMS : Dominos lumineux]] || Destynova || {{Avancement|100||border: solid 1px gray;background-color: lightgray;width: 50px;margin-right:10px;margin-top:-5px;display:inline-block;}} 800 kits dominoux en stock<br />
|-<br />
| Mécanique|| [[Projets:Perso:2012:BequilleAtelierMoto|Béquille d'atelier moto]] || Clmnt || {{Avancement|100||border: solid 1px gray;background-color: lightgray;width: 50px;margin-right:10px;margin-top:-5px;display:inline-block;}} <br />
|-<br />
| Robotique || [[Projets:Perso:2011:RobotCup|Conception d'un robot pour la coupe de robotique 2011]] || [http://beach-bot.p1.fr/ Beachbot Team] || {{Avancement|100||border: solid 1px gray;background-color: lightgray;width: 50px;margin-right:10px;margin-top:-5px;display:inline-block;}} <br />
|-<br />
| Electronique/Radio || [[Projets:Perso:2012:Upconverter|convertisseur pour clefs radio USB à base de chipset Realtek]] || F6ITU|| {{Avancement|100||border: solid 1px gray;background-color: lightgray;width: 50px;margin-right:10px;margin-top:-5px;display:inline-block;}}<br />
|-<br />
| Electronique/Radio || [[Projets:Perso:2012:ArduiKeyer| Shield manipulateur morse electronique avec arduino]] || F6ITU||{{Avancement|100||border: solid 1px gray;background-color: lightgray;width: 50px;margin-right:10px;margin-top:-5px;display:inline-block;}}<br />
|-<br />
| Electricité|| [[Projets: panneaux solaires |Création d'une alimentation autonome photovoltaïque]] || pitrak|| {{Avancement|100||border: solid 1px gray;background-color: lightgray;width: 50px;margin-right:10px;margin-top:-5px;display:inline-block;}} <br />
|-<br />
| Electronique|| [[Projets: Alim +-5V |Création d'une alimentation symétrique +5 -5V avec limitation de courant réglable]] || pitrak||{{Avancement|100||border: solid 1px gray;background-color: lightgray;width: 50px;margin-right:10px;margin-top:-5px;display:inline-block;}} <br />
|-<br />
| Electronique|| [[Projets: chauffage électrique à céramique |Création d'un chauffage céramique panneaux solaires 24V autorégulé avec ventilateur de PC]] || pitrak|| {{Avancement|100||border: solid 1px gray;background-color: lightgray;width: 50px;margin-right:10px;margin-top:-5px;display:inline-block;}} <br />
|-<br />
| Couture|| [[Projets: Tricotin |Création d'un tricotin suffisement grand pour faire de grandes écharpes et bonets]] || pitrak|| {{Avancement|100||border: solid 1px gray;background-color: lightgray;width: 50px;margin-right:10px;margin-top:-5px;display:inline-block;}} <br />
|-<br />
| Electronique || [[Projets:Perso:2013:RaspEink| E-Paper display driver for Raspberry Pi]] || [[User:Mrpozor|MrPozor]]||{{Avancement|100||border: solid 1px gray;background-color: lightgray;width: 50px;margin-right:10px;margin-top:-5px;display:inline-block;}} Finished<br />
|-<br />
| Electronique || [[Projets:Perso:2013:RaspEink FHEM| E-Paper display for displaying FHEM data]] || [[User:Mrpozor|MrPozor]]||{{Avancement|100||border: solid 1px gray;background-color: lightgray;width: 50px;margin-right:10px;margin-top:-5px;display:inline-block;}} Finished<br />
|-<br />
| Soft || [[Projets:Perso:2014:PyResistorColorCode|PyResistorColorCode est un petit logiciel écrit en Python qui permet de décoder par inférence les codes couleurs des résistances (IEC 60062).]] || Fabrice || {{Avancement|100||border: solid 1px gray;background-color: lightgray;width: 50px;margin-right:10px;margin-top:-5px;display:inline-block;}} <br />
|-<br />
| Projet || [[Projets:Perso:2014:BuzzButton |Boutons communiquants style 'Questions pour un champion' ]] || Guillaume|| {{Avancement|100||border: solid 1px gray;background-color: lightgray;width: 50px;margin-right:10px;margin-top:-5px;display:inline-block;}} 3 unités réalisées<br />
|-<br />
| Biotech|| [[Projets:Perso:2014:PS-PCR|Thermocycleur PCR open source]] || Damip || {{Avancement|100||border: solid 1px gray;background-color: lightgray;width: 50px;margin-right:10px;margin-top:-5px;display:inline-block;}} Terminé.<br />
|-<br />
| Ameublement || [[Projets:Perso:2015:Presentoir_Metallique_Pour_Gaines_Thermoretractables| Présentoir métallique pour gaines thermorétractables]] || Eric|| {{Avancement|100||border: solid 1px gray;background-color: lightgray;width: 50px;margin-right:10px;margin-top:-5px;display:inline-block;}} Présentoir réalisé<br />
|-<br />
| Electronique || [[Projets:Perso:2016:Lepton Websocket|Streaming web pour module caméra thermique FLIR Lepton depuis Raspberry Pi]] || Damip || {{Avancement|100||border: solid 1px gray;background-color: lightgray;width: 50px;margin-right:10px;margin-top:-5px;display:inline-block;}} Terminé.<br />
|-<br />
| Electronique || [[Projets:Perso:2015:LedTube|Led Tube]] || Laurent(C) || {{Avancement|100||border: solid 1px gray;background-color: lightgray;width: 50px;margin-right:10px;margin-top:-5px;display:inline-block;}} <br />
|-<br />
| Mécanique|| [[Projets:Perso:2016:SupportSacocheIStep|Pièce imprimée 3D pour réparation support sacoche arrière vélo i-step]] || Laurent(C)|| {{Avancement|100||border: solid 1px gray;background-color: lightgray;width: 50px;margin-right:10px;margin-top:-5px;display:inline-block;}} <br />
|-<br />
| Spatial || [[Projets:Perso:2013:AlphaRocket|Fusée expérimentale Alpha Rocket]] || [[User:THe MaN|tHe_MaN]] || {{Avancement|100||border: solid 1px gray;background-color: lightgray;width: 50px;margin-right:10px;margin-top:-5px;display:inline-block;}}<br />
|-<br />
| Electronique || [[Hoverboard_SKATE_6.5_repair|Hoverboard_SKATE_6.5_repair]] || Eric || {{Avancement|100||border: solid 1px gray;background-color: lightgray;width: 50px;margin-right:10px;margin-top:-5px;display:inline-block;}} <br />
|-<br />
| Outllage/tool|| [[Projets:Perso:2018:KAPEX_KS120_DadoCutFunctionEnhancement| Augmentation de la plage de réglage de la fonction de découpe de rainure de la scie à onglet FESTOOL KAPEX KS120 / Enhance the dado cut adjustment span of the FESTOOL Kapex KS120 miter saw ]] || Eric || {{Avancement|100||border: solid 1px gray;background-color: lightgray;width: 50px;margin-right:10px;margin-top:-5px;display:inline-block;}} <br />
|-<br />
| Test & mesure|| [[Projets:Perso:2020:TEKTRONIX_2467B_Add_HeatsinkToU800| Ajout d'un radiateur sur le composant U800 (étage de sortie horizontal) sur oscilloscope TEKTRONIX 2467B / TEKTRONIX 2465B - 2467B : add a heatsink to U800 horizontal output stage IC (TEK '155-0241-02')]] || Eric || {{Avancement|100||border: solid 1px gray;background-color: lightgray;width: 50px;margin-right:10px;margin-top:-5px;display:inline-block;}} <br />
|-<br />
|}</div>Erichttps://wiki.electrolab.fr/Projets:Perso:2020:TEKTRONIX_2467B_Add_HeatsinkToU800Projets:Perso:2020:TEKTRONIX 2467B Add HeatsinkToU8002020-11-17T15:22:58Z<p>Eric: Created page with "{{Project |name=: TEKTRONIX 2465B - 2467B : add a heatsink to U800 horizontal output stage IC (TEK '155-0241-02') |author= Eric |proposal_date=Nov 2020 |abstract1=Mod for 246..."</p>
<hr />
|author= Eric<br />
|where=<br />
|budget= 0 €<br />
}}<br />
<br />
<br />
=Context=<br />
My [https://www.us-instrument.com/content/images/thumbs/0009638_tektronix-2467b-400-mhz-4-channel-oscilloscope_550.jpegTek 2467B oscilloscope] recently released some magic smoke : failure came form the mains filter C14 socket. Replacing the mains socket-filter needs some time (2-3 hours) because gaining access to the defective part requires the whole power supply assembly to be removed :(<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
Width : 16 mm<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
The same kind of improvement can be seen at 1:24 on [https://www.youtube.com/watch?v=nizLA1hUG80 this video] made by Philippe Demerliac on a 2465B.</div>Erichttps://wiki.electrolab.fr/File:TEKTRONIX_2467B_U800_Machined_Heasink_401.JPGFile:TEKTRONIX 2467B U800 Machined Heasink 401.JPG2020-11-17T14:45:09Z<p>Eric: Eric moved page File:TEKTRONIX 2467B U800 Machined Heasink 401.JPG to File:TEKTRONIX 2467B U800 Machined Heatsink 401.JPG: typo</p>
<hr />
<div>#REDIRECT [[File:TEKTRONIX 2467B U800 Machined Heatsink 401.JPG]]</div>Erichttps://wiki.electrolab.fr/File:TEKTRONIX_2467B_U800_Machined_Heatsink_401.JPGFile:TEKTRONIX 2467B U800 Machined Heatsink 401.JPG2020-11-17T14:45:08Z<p>Eric: Eric moved page File:TEKTRONIX 2467B U800 Machined Heasink 401.JPG to File:TEKTRONIX 2467B U800 Machined Heatsink 401.JPG: typo</p>
<hr />
<div></div>Erichttps://wiki.electrolab.fr/File:TEKTRONIX_2467B_U800_Without_Heasink_404.JPGFile:TEKTRONIX 2467B U800 Without Heasink 404.JPG2020-11-17T14:44:31Z<p>Eric: Eric moved page File:TEKTRONIX 2467B U800 Without Heasink 404.JPG to File:TEKTRONIX 2467B U800 Without Heatsink 404.JPG: typo</p>
<hr />
<div>#REDIRECT [[File:TEKTRONIX 2467B U800 Without Heatsink 404.JPG]]</div>Erichttps://wiki.electrolab.fr/File:TEKTRONIX_2467B_U800_Without_Heatsink_404.JPGFile:TEKTRONIX 2467B U800 Without Heatsink 404.JPG2020-11-17T14:44:30Z<p>Eric: Eric moved page File:TEKTRONIX 2467B U800 Without Heasink 404.JPG to File:TEKTRONIX 2467B U800 Without Heatsink 404.JPG: typo</p>
<hr />
<div></div>Erichttps://wiki.electrolab.fr/File:TEKTRONIX_2467B_U800_With_Heatsink_409.JPGFile:TEKTRONIX 2467B U800 With Heatsink 409.JPG2020-11-17T14:42:27Z<p>Eric: Eric moved page File:TEKTRONIX 2467B U800 With Heasink 400.JPG to File:TEKTRONIX 2467B U800 With Heatsink 409.JPG: wrong ID + typo</p>
<hr />
<div>#REDIRECT [[File:TEKTRONIX 2467B U800 With Heasink 409.JPG]]</div>Erichttps://wiki.electrolab.fr/File:TEKTRONIX_2467B_U800_With_Heasink_400.JPGFile:TEKTRONIX 2467B U800 With Heasink 400.JPG2020-11-17T14:42:27Z<p>Eric: Eric moved page File:TEKTRONIX 2467B U800 With Heasink 400.JPG to File:TEKTRONIX 2467B U800 With Heatsink 409.JPG: wrong ID + typo</p>
<hr />
<div>#REDIRECT [[File:TEKTRONIX 2467B U800 With Heatsink 409.JPG]]</div>Erichttps://wiki.electrolab.fr/File:TEKTRONIX_2467B_U800_With_Heasink_409.JPGFile:TEKTRONIX 2467B U800 With Heasink 409.JPG2020-11-17T14:41:36Z<p>Eric: Eric moved page File:TEKTRONIX 2467B U800 With Heasink 400.JPG to File:TEKTRONIX 2467B U800 With Heasink 409.JPG</p>
<hr />
<div></div>Erichttps://wiki.electrolab.fr/File:TEKTRONIX_2467B_U800_With_Heatsink_409.JPGFile:TEKTRONIX 2467B U800 With Heatsink 409.JPG2020-11-17T14:41:36Z<p>Eric: Eric moved page File:TEKTRONIX 2467B U800 With Heasink 400.JPG to File:TEKTRONIX 2467B U800 With Heasink 409.JPG</p>
<hr />
<div>#REDIRECT [[File:TEKTRONIX 2467B U800 With Heasink 409.JPG]]</div>Erichttps://wiki.electrolab.fr/File:TEKTRONIX_2467B_U800_Without_Heasink_400.JPG_404.JPGFile:TEKTRONIX 2467B U800 Without Heasink 400.JPG 404.JPG2020-11-17T14:41:02Z<p>Eric: Eric moved page File:TEKTRONIX 2467B U800 Without Heasink 400.JPG 404.JPG to File:TEKTRONIX 2467B U800 Without Heasink 404.JPG: double extension</p>
<hr />
<div>#REDIRECT [[File:TEKTRONIX 2467B U800 Without Heasink 404.JPG]]</div>Erichttps://wiki.electrolab.fr/File:TEKTRONIX_2467B_U800_Without_Heatsink_404.JPGFile:TEKTRONIX 2467B U800 Without Heatsink 404.JPG2020-11-17T14:41:01Z<p>Eric: Eric moved page File:TEKTRONIX 2467B U800 Without Heasink 400.JPG 404.JPG to File:TEKTRONIX 2467B U800 Without Heasink 404.JPG: double extension</p>
<hr />
<div></div>Erichttps://wiki.electrolab.fr/File:TEKTRONIX_2467B_U800_Machined_Heatsink_401.JPGFile:TEKTRONIX 2467B U800 Machined Heatsink 401.JPG2020-11-17T14:39:19Z<p>Eric: Eric moved page File:TEKTRONIX 2467B U800 Machined Heasink 400.JPG 404.JPG to File:TEKTRONIX 2467B U800 Machined Heasink 401.JPG: double extension</p>
<hr />
<div></div>Erichttps://wiki.electrolab.fr/File:TEKTRONIX_2467B_U800_Machined_Heasink_400.JPG_404.JPGFile:TEKTRONIX 2467B U800 Machined Heasink 400.JPG 404.JPG2020-11-17T14:39:19Z<p>Eric: Eric moved page File:TEKTRONIX 2467B U800 Machined Heasink 400.JPG 404.JPG to File:TEKTRONIX 2467B U800 Machined Heasink 401.JPG: double extension</p>
<hr />
<div>#REDIRECT [[File:TEKTRONIX 2467B U800 Machined Heasink 401.JPG]]</div>Erichttps://wiki.electrolab.fr/File:TEKTRONIX_2467B_U800_With_Heasink_409.JPGFile:TEKTRONIX 2467B U800 With Heasink 409.JPG2020-11-17T14:34:32Z<p>Eric: </p>
<hr />
<div></div>Erichttps://wiki.electrolab.fr/File:TEKTRONIX_2467B_U800_Machined_Heatsink_401.JPGFile:TEKTRONIX 2467B U800 Machined Heatsink 401.JPG2020-11-17T14:33:57Z<p>Eric: </p>
<hr />
<div></div>Erichttps://wiki.electrolab.fr/File:TEKTRONIX_2467B_U800_Without_Heatsink_404.JPGFile:TEKTRONIX 2467B U800 Without Heatsink 404.JPG2020-11-17T14:33:14Z<p>Eric: </p>
<hr />
<div></div>Erichttps://wiki.electrolab.fr/File:TEKTRONIX_2467B_U800_Junk_Heatsink_400.JPGFile:TEKTRONIX 2467B U800 Junk Heatsink 400.JPG2020-11-17T14:32:15Z<p>Eric: </p>
<hr />
<div></div>Erichttps://wiki.electrolab.fr/Projets:Commande_groupeeProjets:Commande groupee2020-06-06T11:26:34Z<p>Eric: /* Mouser Electronics */</p>
<hr />
<div>=Commandes groupées=<br />
<br />
== Principe ==<br />
Tout projet a régulièrement besoin de matières premières, composants, fournitures diverses, etc. Le lab a en stock une quantité importante de fournitures plus ou moins courantes, mais cela ne peut remplacer des commandes régulières.<br />
<br />
Histoire de mutualiser les bons plans & regrouper les frais de port, profiter de divers price breaks, etc, cette page a été créee pour organiser des commandes groupées.<br />
<br />
== Glossaire ==<br />
===Demandeur===<br />
Celui qui a besoin d'un article<br />
<br />
===Acheteur===<br />
Celui qui passe effectivement la commande chez le Fournisseur. L'Acheteur peut être le lab ou une personne privée.<br />
Dans le cas du lab indiquer dans la colonne "acheteur" lab_<nom/pseudo membres> exemple : lab_peewee<br />
Sauf avis contraire, le paiement est à effectuer sur le compte paypal du lab.<br />
<br />
Dans le cas d'une personne privée, indiquer dans la colonne "acheteur", son nom ou pseudo.<br />
L'Acheteur définit lui même les moyens de paiement à utiliser par les <demandeurs>.<br />
<br />
<br />
===Distributeur===<br />
Fournisseur ou fabricant chez qui l'<acheteur> passe commande.<br />
Chaque <distributeur> dispose d'une rubrique propre.<br />
<br />
Il est bien entendu possible d'ajouter des <distributeurs> supplémentaires (notez qu'ils sont triés par '''ordre alphabétique''').<br />
<br />
== Règles du jeu ==<br />
<br />
En général, lorsque l'on s'occupe d'un "group buy", on fait un premier tour de<br />
table pour savoir qui est partant, on annonce ensuite le prix de l'addition<br />
générale (TTC et frais d'expé avec ou sans assurance, éventuels frais de<br />
dédouanement) divisée par le nombre de participants (au prorata des volumes<br />
de commande : celui qui achète 2 items paye 2 parts de frais de port par<br />
exemple).<br />
<br />
Ceci fait, on attend qu'une "masse critique" soit atteinte lorsque l'on vise<br />
certains "price break" (décollonage en jargon de vendeur), puis on lance<br />
l'appel aux fonds avec une date butoir. Passé la date butoir, la commande<br />
est passée, en ignorant ceux qui n'ont pas répondu a temps, puisque le<br />
responsable de group buy n'a pas la trésorerie correspondant à l'achat en<br />
question.<br />
Les histoires genre "le chèque est au courrier" ne marchent pas avec des<br />
virements Paypal... le patron des achats sait exactement combien il a en<br />
caisse au moment de la commande.<br />
<br />
En cas de perte de colis, le responsable de "group buy" n'est pas<br />
redevable. C'est à chaque participant d'estimer s'il prend le risque ou non<br />
de faire confiance aux entreprises assurant l'acheminement des colis.<br />
C'est simple, et si c'est précisé, aucun conflit n'est à redouter, aucun lot<br />
ne reste sur les bras de l'<acheteur>.<br />
<br />
Pour le paiement par avance, celui-ci peut se faire au lab, mais c'est TTC et AVEC les frais de port et de douane, le cas échéant.<br />
<br />
Si un <demandeur> commande la mauvise référence, c'est pour sa pomme.<br />
<br />
Dans la mesure du possible, les <demandeur> doivent faciliter au maximum le travail des <acheteur> en indiquant des références d'articles et de désignation claires.<br />
<br />
==Mode opératoire lorsqu'on passe une commande chez l'un des distributeurs ==<br />
Les tableaux ci-après (un tableau par <distributeur> disposent des colonnes nécessaires à la synchronisation des commandes article par article.<br />
<br />
De même, chaque rubrique dispose d'un en-tete d'information qui a la structure suivante :<br />
<br />
La prochaine commande a pour référence interne : YY_xxx<br />
Prochaine date de commande : <non défini><br />
Commande passée en attente de livraison :[aucune]<br />
Commande livrée en cours de distribution : [aucune]<br />
Anciennes commandes <nom du distributeur> archivées [[Projets:Commande_groupee:archives|ici]]<br />
< informations complémentaires notamment en ce qui concerne les conditions de livraison, etc>''<br />
<br />
YY est un code fixe, unique pour chaque founisseur.<br />
<br />
xxx un le n° de commande pour ce distributeur. Il commence à 001 et s'incrémente à chaque commande.<br />
<br />
<br />
===Les différentes étapes de la commande ===<br />
<br />
====Prise en charge d'un commande par un <acheteur>==== <br />
La personne qui souhaite prendre en charge une commande chez un <distributeur> envoie un mail sur la ML pour informer tout le monde de cette action.<br />
Dans l'entête d'information du <distributeur> concerné, l'<acheteur> effectue les modifications suivantes :<br />
*mise à jour de la ligne ''Prochaine date de commande'' : valorisé à la date à laquelle il envisage de passer la commande auprès du <distributeur>. <br />
<br />
À ce moment, l'ensemble des <demandeurs> concernés se met en relation avec l'<acheteur> pour lui payer d'avance les articles commandés. Pour ces articles, l'<acheteur> fait les modifications suivantes dans le tableau des articles :<br />
*''Payé d'avance (O/N)'' : valorisé à "O" (Oui)<br />
<br />
<br />
====Passage effective de la commande par l'<acheteur>==== <br />
<br />
Celui qui passe la commande ( = <acheteur>) sélectionne les articles qu'il commande effectivement (= ceux pour lesquels il a reçu le paiement en avance). Il peut aussi inclure dans la commande des articles de <demandeurs> pour leuquel il est certain d'être payé au moment de la distribution.<br />
<br />
L'<acheteur> passe la commande auprès du distributeur (par internet, mail, téléphone, télécopie, signaux de fumée, déplacement sur place...) et effectue le paiement à l'aide d'un moyen de paiement à sa convenance. Il est judicieux de priviléger des moyens de paiement fournissant la traçabilité de la transaction.<br />
<br />
Pour les articles effectivement COMMANDÉS l'<acheteur> fait les modifications suivantes dans le tableau des articles :<br />
*'' Acheteur'' : valorisé par son nom/pseudo <br />
*''Commandé (O/N)'' : valorisé à "O" (Oui)<br />
<br />
Pour les articles qui n'ont pas déja été concernés par une commande précédente et que l'<acheteur> ne COMMANDE PAS (par exemple par ce que le <demandeur> ne s'est pas manifesté auprès de lui), il fait les modifications suivantes dans le tableau des articles :<br />
*''N° de commande'' : est incrémenté d'une unité afin que cet article non commandé soit inclus dans la prochaine commande.<br />
<br />
<br />
*mise à jour de la ligne ''Prochaine date de commande'' : valorisé à <non défini><br />
*mise à jour de la ligne ''La prochaine commande a pour référence interne'' : valorisé au numéro de commande interne actuel +1 <br />
*mise à jour de la ligne ''Commande passée en attente de livraison'': valorisé au n° de commande actuel<br />
<br />
====Réception de la commande par l'<acheteur>==== <br />
<br />
<br />
Au moment de la réception du colis, l'<acheteur> vérifie si la livraison est complète et négocie avec le <distributeur> en cas de problème. Il peut aussi informer le <demandeur> concerné par le ou les article(s) en litige ou manquants.<br />
<br />
====Distribution des articles aux <demandeurs>====<br />
Lorsque la distribution peut commencer l'<acheteur> effectue les modifications suivantes dans l'entête d'information du <distributeur> concerné :<br />
*mise à jour de la ligne : '' Commande passée en attente de livraison'' à [aucune]<br />
*mise à jour de la ligne : '' Commande livrée en cours de distribution '' avec la référence interne de la commande.<br />
<br />
L'<acheteur> informe via la ML les <demandeurs> du début de la distribution de la commande <référence interne de commande>.<br />
Chaque <demandeur> convient d'un RDV avec l'<acheteur> pour récupérer les articles (en principe cela se passe au lab) et payer son dû à l'<acheteur>, si ce n'est déja fait.<br />
<br />
Pour chaque article l'<acheteur> fait les modifications suivantes dans le tableau des articles :<br />
*'' Distribué (O/N)'' : valorisé à "O" (Oui) <br />
*''Remboursé/Archivé (O/N)'' : valorisé à "O" (Oui)<br />
<br />
====Ditribution des articles terminée====<br />
<br />
Une fois l'ensemble des pièces distribuées et payées, dans l'entête d'information du <distributeur> concerné, l'<acheteur> effectue les modifications suivantes :<br />
*mise à jour de la ligne ''Commande livrée en cours de distribution'' : valorisé à [aucune]<br />
<br />
<br />
===En conclusion ===<br />
<br />
Si les tableaux des commandes et les en-tête d'information sont gérés avec soin, il n'y a quasiment aucun risque de double commande et n'importe quel membre sait où on en est et peut à tout moment prendre la main sur l'un des tableaux d'achats pour commander un article ou organiser une commande en tant qu'<acheteur>. La bonne application de ces quelques recommandation bénéficie à l'ensemble des participants de ce système de commandes groupées.<br />
<br />
Sauf besoin urgent de pièces, il est bénéfique que ce soit de préférence les mêmes <acheteurs> qui officient auprès des mêmes <distributeurs>. Ainsi, vu de ces derniers, l'<acheteur> est très vite identifié comme "client important" (car en réalité il commande pour 5-10 personnes, voire plus) et peut bénéficier de conditions particulières (frais de port gratuit, -15% sur la prochaine commande, etc).<br />
<br />
Enfin, à tout moment en tant que <demandeur>, soyez diligent envers l'<acheteur> dont la gestion d'une commande de parfois plusieurs dizaines d'articles requert un investissement en temps non négligeable.<br />
<br />
== Commandes groupées passées (archives) ==<br />
<br />
Afin d'améliorer la lisibilité nous avons regroupé les commandes passées sur cette page: [[Projets:Commande_groupee:archives]]<br />
<br />
== Commandes groupées en cours ==<br />
<br />
=== BHV ===<br />
<br />
La prochaine commande a pour référence interne : BH_003<br />
<br />
<br />
<br />
Commande livrée en cours de distribution : [aucune] <br />
<br />
Anciennes commandes BHV archivées [[Projets:Commande_groupee:archives#BHV|ici]]<br />
<br />
achat sur place<br />
<br />
{|class="wikitable sortable" style="font-size:85%"<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref BHV!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
<!-- Pour ajouter une ligne, copier les 2 lignes suivantes (celles qui commencent par | ) à la suite du tableau et remplacer le contenu des colonnes par ce qui semblera adéquat<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||<Acheteur>|| DI_XXX || N || N || N || N<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| Lab|| Réglet métallique 30cm || - || 3 || 5.90€||Eric|| BH_001 || N || O || O || O<br />
|-<br />
|-<br />
| Lab|| Scie a métaux FACOM 603E || - || 1 || env. 36€||Eric|| BH_002 || N || O || 0 || O<br />
|-<br />
! !! !! !! !! !! !! !! !! !! !!<br />
|}<br />
<br />
=== [http://www.visseriefixations.fr/ Cergy-Vis] ===<br />
<br />
<br />
La prochaine commande a pour référence interne : CV_002<br />
<br />
<br />
<br />
<br />
Anciennes commandes Cergy-Vis archivées [[Projets:Commande_groupee:archives|ici]] <br />
<br />
Retrait gratuit sur place<br />
CERGY-VIS<br />
<br />
17, Rue du Périgord<br />
<br />
ZI des Béthunes<br />
<br />
95310 SAINT OUEN L’AUMONE<br />
<br />
<br />
Horaires pour les enlèvements: Du Lundi au Vendredi, de 7h30 à 12h00 et de 13h30 à 17h30.<br />
<br />
<br />
Livraison<br />
Colissimo Régional (0.05kg / France) 5,75 €<br />
<br />
Colissimo Régional (0.2888kg / France) 6,54 €<br />
<br />
Colissimo Régional (2.87kg / France) 9,25 €<br />
<br />
Colissimo Régional (12.8948kg / France) 16,50 €<br />
<br />
Anciennes commandes Cergy-Vis archivées [[Projets:Commande_groupee:archives#Cergy-Vis|ici]]<br />
<br />
<br />
|-<br />
!Demandeur !! class="unsortable"| Description !! Référence!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-<br />
||Eric|| TRCC M5X30 INOX A2 DIN 603|| ||50||0.17EURTTC||<acheteur>||CV_001||N||O||O||N (attends remb. trop versé)<br />
|-<br />
||Eric|| ECROU HU M12 PAS 100 Z.BLANC DIN 934|| ||20||0.39EURTTC||<acheteur>||CV_001||N||O||O||N (attends remb. trop versé)<br />
|-<br />
||Eric||Vis TCHC M5X22 INOX A2 EF DIN 912||TCHC05/022A2EF||15||0.12EURTTC||<acheteur>||CV_002||N||N||N||N<br />
|-<br />
||Eric||Vis STHC PLAT M6X12 INOX A2 DIN 913||STHCPLA06/012A2||30||0.06EURTTC||<acheteur>||CV_002||N||N||N||N<br />
|-<br />
||Eric||Vis TH M6X12 INOX A2 EF DIN 933||TH06/012A2EF||30||0.09EURTTC||<acheteur>||CV_002||N||N||N||N<br />
|-<br />
|}<br />
<br />
=== [http://www.conradpro.fr Conrad Electronique France] ===<br />
<br />
<br />
La prochaine commande aura pour référence interne : CO_017<br />
<br />
Prochaine date de commande :<br />
<br />
Commande passée en attente de livraison : NEANT<br />
<br />
Commande livrée en cours de distribution : NEANT<br />
<br />
Anciennes commandes Conrad Electronique France archivées [[Projets:Commande_groupee:archives#Conrad Electronique France|ici]]<br />
<br />
{| class="wikitable sortable" style="font-size:85%"<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Conrad!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€ ||<Acheteur>|| CO_XXX || N || N || N || N<br />
|-<br />
--><br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/822746/Fil-de-soudure-pour-PVC-rigide-Steinel-073114-26-pcs Fil de soudure pour PVC rigide Steinel 073114 26 pcs]</s>||<s>822746 - 62 </s>||<s> 1 </s>||<s> € 5.99 TTC</s>||<s><acheteur> </s>||<s> CO_014 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/492161/Soudure-plastique-225-mm-4-mm-polythylne-LDPE-nature-Bosch-1609201811 Soudure plastique, 225 mm, 4 mm, polyéthylène (LDPE) nature Bosch 1609201811]</s>||<s>492161 - 62 </s>||<s> 1 </s>||<s> € 15.99 TTC</s>||<s> <acheteur> </s>||<s> CO_014 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/121588/Solution-de-conservation-pour-electrodes-de-mesure-pH-HI-70300M Solution de conservation pour électrodes de mesure pH HI 70300M]</s>||<s>121588 - 62 </s>||<s> 1 </s>||<s> € 15.12 TTC</s>||<s> <acheteur> </s>||<s> CO_014 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/121586/Solution-de-nettoyage-pour-electrodes-pH-HI-7061M Solution de nettoyage pour électrodes pH HI 7061M]</s>||<s>121586 - 62 </s>||<s> 1 </s>||<s> € 15.12 TTC</s>||<s> <acheteur> </s>||<s> CO_014 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|Eric||[http://www.conrad.fr/ce/fr/product/121164/Sol-de-conduct-12880-S-HI-70030-P Sol. de conduct. 12880 µS HI 70030 P]||121164 - 62 || 1 || € 38.30 TTC|| <Pat> || CO_014 || N || O || O || O<br />
|-<br />
|Eric||[http://www.conradpro.fr/ce/fr/product/822188/Knipex-Pinces-pour-circlips-pour-colliers-dtranglement-darbre-46-11-G0-140-mm?ref=searchDetail Pince KNIPEX 46 11 G0]||822188 - 62 || 1 || € 20.13 HT|| <Pat> || CO_014 || N || O || O || O<br />
|-<br />
|Eric||[http://www.conradpro.fr/ce/fr/product/822189/Knipex-Pinces-pour-circlips-pour-colliers-dtranglement-darbre-46-11-G1-140-mm?ref=searchDetail Pince KNIPEX 46 11 G1]||822189 - 62 || 1 || € 13.02 HT|| <Pat> || CO_014 || N || O || O || O<br />
|-<br />
|MrPozor||[http://www.conrad.fr/ce/fr/product/702246/Interrupteur-de-porte-Panasonic-AZC11113HJ-250-VAC-5-A-poussoir-momentan-IP40-1-pcs?ref=searchDetail Interrupteur de porte Panasonic AZC11113HJ]||702246 - 62 || 1 || € 10.99 TTC|| <Pat> || CO_014 || N || O || N || N<br />
|-<br />
| papy F1CHF || 74HC390 SOIC || 1115010-62 || 10 || 1.06€ ||<Pat>|| CO_014 || O || O || O || O<br />
|-<br />
| Pat|| Condo moteur 5uF 450V || 441527-62 || 1 || 6.33€ H.T. ||<Pat>|| CO_014 || O || O || N || N<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/731484/Adaptateur-avec-fiche-dor-32-A-rouge-MultiContact-240160-22 Adaptateur avec fiche doré 32 A rouge MultiContact Ref. 24.0160-22]|| 731484 - 62 || 2 || 3.00 € H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/731559/Disque-de-marquage-couleur-MultiContact-145010-vert-jaune-1-pcs Disque de marquage couleur MultiContact Ref. 14.5010 vert-jaune 1 pc(s)]|| 31559 - 62 || 3 || 0.75 € H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/106109/Pointe-de-touche-de-scurit-MultiContact-XMA-7L-enfichable-4-mm-CAT-IV-1000-V-bleu Pointe de touche de sécurité MultiContact XMA-7L enfichable 4 mm CAT IV 1000 V bleu Ref. MC 66.9509-23]|| 106109 - 62 || 1 || 15.96 € H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/106108/Pointe-de-touche-de-scurit-MultiContact-XMA-7L-enfichable-4-mm-CAT-IV-1000-V-rouge Pointe de touche de sécurité MultiContact XMA-7L enfichable 4 mm CAT IV 1000 V rouge Ref. MC 66.9509-22]|| 106108 - 62 || 1 || 15.96 € H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/106107/Pointe-de-touche-de-scurit-MultiContact-XMA-7L-enfichable-4-mm-CAT-IV-1000-V-noir Pointe de touche de sécurité MultiContact XMA-7L enfichable 4 mm CAT IV 1000 V noir Ref. MC 66.9509-21]|| 106107 - 62 || 1 || 15.96 € H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/1385649/Pince-crocodile-4-mm-GRIP-FMA-MultiContact-669435-21 Pince crocodile 4 mm GRIP-FMA MultiContact Ref. 66.9435-21]|| 1385649 - 62 || 1 || 30.00€ H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Damien H || MOSFET RFD14N05L || 512-RFD14N05L || 5 || 0,695 € ||?|| CO_015 || N || O || O || O<br />
|-<br />
| Damien H || Zener BZX79C2V4 || 512-BZX79C2V4 || 5 || 0,11 € ||?|| CO_015 || N || O || O || O<br />
|-<br />
|Pierre G|| Câble audio SpeaKa 1m mf||986736 - 62 || 2||6,66 ht || ? || CO_015 || N || O || O || O<br />
|-<br />
|Pierre G|| Câble audio SpeaKa 0,50m mf||986735 - 62 || 1||5.92 ht || ? || CO_015 || N || O || O || O<br />
|-<br />
|Pierre G|| Lentille Dialight OPC-11SPOT transparent 10 ° 1 pc(s)||1127266 - 62 || 1||3 ht || ? || CO_016 || N || O || O || O<br />
|-<br />
|Pierre G|| LED High Power Barthelme 61003528 blanc chaud||1503528 - 62 || 1||3,50 ht || ? || CO_016 || N || O || O || O<br />
|-<br />
|FredericD|| [http://www.conrad.fr/ce/fr/product/574223/Transformateur-electronique-Standard-10-a-60-W Transformateur électronique "Standard" 10 à 60 W]||574223 - 62 || 1||15,49 '''TTC''' || <acheteur> || CO_017 || N || N || N || N<br />
|-<br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/542044/?insert=32&insertNoDeeplink&productname=Gaine-thermoretractable-pour-batteries-sans-colle-21-Conrad-Components-542044-transparent-avant-retreint-44-mm-1-pc Gaine thermorétractable 2:1 transparente pour accus longueur 100 cm largeur 44mm]</s>||<s>542044 - 32</s>||<s>3</s>||<s>2,70€TTC</s>||<s> <acheteur> </s>||<s> CO_017 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/100297/Solution-conductrice-1413-S-HI-70031-P?ref=list Solution conductrice 1413 µS HI 70031 P]</s>||<s>100297 - 62 </s>||<s> 1 </s>||<s> € 33,60 TTC</s>||<s> <acheteur> </s>||<s> CO_017 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|<s>Eric</s>||<s>[http://www.conradpro.fr/ce/fr/product/1305022/Diode-Zener-PanJit-1N4740A-G-DO-41G-Tension-Zener-10-V-1-pcs?ref=searchDetail Diode Zener PanJit 1N4740A-G DO-41G Tension Zener: 10 V]</s>||<s>1305022 - 62 </s>||<s> 10 </s>||<s> € 0,15 TTC</s>||<s> <acheteur> </s>||<s> CO_017 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/812811/tain-de-soudure-teneur-en-plomb-Stannol-HS-10-Sn60Pb39Cu1-bobine-100-g-10-mm?queryFromSuggest=true étain 100g 1mm STANNOL]|| 812811 - 62 || 2 || 7,55 € H.T. ||<acheteur>|| CO_017 || N || N || N || N<br />
|-<br />
|Eric||[http://www.conrad.fr/ce/fr/product/651105/XLR-Bride-mle-contacts-couds-Neutrik-NC3MAAH-Nombre-de-ples-3-noir-1-pcs?queryFromSuggest=true Connecteur XLR mâle plastique pour chassis soudage pour CI 3 broches coudé + blindage, NEUTRIK NC3MA(A)H ]||651105 - 62|| 2 || 1,20€TTC ||<acheteur>||CO_017||N||N||N||N <br />
|-<br />
|}<br />
<br />
Anciennes commandes Conrad archivées [[Projets:Commande_groupee:archives#Conrad_Electronique_France|ici]]<br />
<br />
=== [http://www.damencnc.com/fr DamenCNC] ===<br />
<br />
Accessoires pour machines CNC [http://www.damencnc.com]<br />
<br />
La prochaine commande a pour référence interne : DC_002<br />
<br />
Prochaine date de commande : ?? (probablement en octobre 2014)<br />
<br />
<br />
<br />
Livraison : depuis les Pays-Bas par UPS : estimation : 20€ pour un colis de 1.5kg<br />
<br />
ATTENTION : Prix HT.<br />
<br />
Anciennes commandes DamenCNC archivées [[Projets:Commande_groupee:archives#DamenCNC|ici]]<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref DamenCNC!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||<Acheteur>|| OT_XXX || N || N || N || N<br />
|-<br />
--><br />
|-<br />
|Goldo|| HIWIN HGR Profile Rail L=200mm || HG15R || 2 || 21,60€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|Goldo|| HIWIN Carriage HGH "Compact type" || HGH-15CA || 2 || 33.99€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|Goldo|| Mini Mill 2 flutes 0.20mm || ? || 1 || 11.99€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|Goldo|| Mini Mill 2 flutes 0.30mm || ? || 1 || 11.99€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|Goldo|| Mini Mill 2 flutes 0.50mm || ? || 1 || 9.99€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|Goldo|| Kress Collet + Clamp Nut 1/8inch || ? || 1 || 19.99€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|F1CHF|| Mini Mill 2 flutes 0.50mm || ? || 2 || 9.99€HT || Goldo || DC_001 || N || O || O || O<br />
|-<br />
|F1CHF|| Mini Mill 2 flutes 0.70mm || ? || 2 || 9.99€HT || Goldo || DC_001 || N || O || O || O<br />
|-<br />
|Eric||IPS_Cable_Assembly M12_Straight_Female/OPENEND_3meter || ? || 2 || 4.99€HT || <acheteur>|| DC_002 || N || N || N || N<br />
<br />
|}<br />
<br />
===[http://www.detandt.com/fr Detandt-Simon]===<br />
<br />
La prochaine commande aura pour référence interne : DET_001 <br />
<br />
Prochaine date de commande : Mardi 2/2/2016<br />
<br />
<br />
Commande livrée en cours de distribution : [nada] <br />
<br />
Anciennes commandes Detandt archivées [nope]<br />
<br />
Frais de livraisons: inconnu<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Taille !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!!Remboursé/Archive (O/N)<br />
|-<br />
<!-- Pour ajouter une ligne, copier les 2 lignes suivantes (celles qui commencent par | ) à la suite du tableau et remplacer le contenu des colonnes par ce qui semblera adéquat--><br />
| Steve|| Modèle haut Bleu et gris || Taille 44 || 1|| 15€ HT||Steve|| DET_001 || N || N || N || N<br />
|-<br />
| Steve|| Modèle haut Bleu et gris || Taille 45 || 1|| 15€ HT||Steve|| DET_001 || N || N || N || N<br />
|-<br />
| Laurent d. Lo^2 || Modèle haut orange et noir || Taille 44 || 1|| 15€ HT||Laurent|| DET_001 || N || N || N || N<br />
|-<br />
| Laurent d. Lo^2 || Modèle cuir noir || Taille 44 || 1|| 15€ HT||Laurent|| DET_001 || N || N || N || N<br />
|-<br />
| Beatrice/LK999 || Modèle cuir noir ou bas || Taille 45|| 1|| 15€ HT||XXX|| DET_001 || N || N || N || N<br />
|-<br />
| Le Xav || Modèle noir & orange haut || Taille 45|| 1|| 15€ HT||XXX|| DET_001 || N || N || N || N<br />
|-<br />
| Patrick|| 10m gaine VMC alu D80 M0|| HALUM0 82|| 2|| 13,78€ HT||XXX|| DET_002 || N || N || N || N<br />
|-<br />
| Patrick|| 10m gaine VMC alu D125 M0|| HALUM0 127|| 1|| 15,96€ HT||XXX|| DET_002 || N || N || N || N<br />
|-<br />
|}<br />
<br />
===[http://www.digikey.com/ Digikey Corporation]===<br />
<br />
La prochaine commande aura pour référence interne : DI_006<br />
<br />
<br />
Commande passée en attente de livraison : DI_005 <br />
<br />
Commande livrée en cours de distribution : NEANT <br />
<br />
Anciennes commandes Digikey Corporation archivées [[Projets:Commande_groupee:archives#Digikey Corporation|ici]]<br />
<br />
"PAS DE FRAIS POSTAUX sur toutes commandes avec une valeur de 65 Euro et plus.mais la DOUANE + frais"<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Digikey !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!!Remboursé/Archive (O/N)<br />
|-<br />
| Laurent(C) || Capa 470uF || 493-1493-ND || 24 || 0,229€||Laurent(C)|| DI_005 || || O || N || N<br />
|-<br />
| Laurent(C) || Carte NUCLEO-F303K8 || 497-15981-ND || 1|| 9,92€||Laurent(C)|| DI_005 || || O || N || N<br />
|-<br />
| Laurent(C) || Capa tantale 10uF || 478-8959-1-ND || 5|| 0.8€||Laurent(C)|| DI_005 || || O || N || N<br />
|-<br />
| Laurent(C) || PMIC 4V || MCP1702T-4002E/CBCT-ND|| 5|| 0.43€||Laurent(C)|| DI_005 || || O || N || N<br />
|-<br />
| Eric||[http://www.digikey.fr/product-search/fr?vendor=0&keywords=LT1677CS8%23PBF-ND LT1677 OPAMP S8 Package]|| LT1677CS8#PBF-ND || 4|| 3.95€||Laurent(C)|| DI_005 || O || O || N || N<br />
|-<br />
| Eric|| [http://www.digikey.com/product-detail/en/4664-6001/MPK64K-ND/138341 connecteur HE10 64 broches autodénudant mâle] || MPK64K-ND || 1|| 12.59€||Laurent(C)|| DI_005 || O || O || O || O<br />
|-<br />
| Eric|| [http://www.digikey.fr/product-detail/fr/DS2740U%2B/DS2740U%2B-ND/1197488 MAXIM coulombmetric counter DS2740U+ SMD]|| DS2740U+-ND || 1|| 3.90€||Laurent(C)|| DI_005 || O || O || O || O<br />
|-<br />
| Eric|| C190 case ||614-1102-ND||1||199,99USD||Laurent(C)|| DI_005 || O || N(export restriction!) || N || O<br />
|-<br />
| papy F1CHF || NB3N502 || NB3N502DGOS-ND ||4||2.99€||Laurent(C)|| DI_005 || N || O || O || O<br />
|-<br />
| Eric|| [http://www.digikey.com/product-detail/en/linear-technology/LT1763CS8-TRPBF/LT1763CS8-TRPBFCT-ND/4247570 LT1763CS8#TRPBF LT micropower low noise LDO ADJ regulator 500MA SO8]|| LT1763CS8#TRPBFCT-ND || 1|| 4.78USD||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| Eric|| [http://www.digikey.com/product-detail/en/linear-technology/LT1763CS8-3.3-TRPBF/LT1763CS8-3.3-TRPBFCT-ND/4247566 LT1763CS8-3.3#TRPBF LT micropower low noise LDO 3.3V regulator 500MA SO8]|| LT1763CS8-3.3#TRPBFCT-ND|| 2|| 4.78USD||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| Eric|| [http://www.digikey.fr/products/fr?keywords=BA5406 BA5406 Amplifier IC 2-Channel (Stereo) Class AB 12-SIP-M] ||BA5406-ND || 1|| 3.85 EUR||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| Eric|| [https://www.digikey.fr/products/fr?keywords=HR1732-ND HIROSE CONN PLUG 5POS W/PIN INSERT ref "RM12BPE-5PH(71)"] ||HR1732-ND || 1|| 11.19 EUR||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| Eric|| [https://www.digikey.fr/product-detail/fr/infineon-technologies/IRS2453DPBF/IRS2453DPBF-ND/1189713 INFINEON IC DRIVER FULL SELF OSC 14-DIP IRS2453DPBF] ||IRS2453DPBF-ND || 1|| 3.09 EUR||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| 3dsman|| US5881LUA Digital Switch Unipolar Switch Open Drain Hall Effect TO-92UA ||US5881LUA-AAA-000-BU-ND || 5|| 1.10 EUR||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| Debutant|| [https://www.digikey.fr/product-detail/fr/jst-sales-america-inc/SYF-001T-P0.6-LF-SN/455-2652-1-ND/2796952 JST Sales America Inc. SYF-001T-P0.6(LF)(SN) ] || 455-2652-1-ND || 100|| 0.05460 EUR|| Debutant || DI_006 || N || N || N || N<br />
|-<br />
| Lo2|| [https://www.digikey.fr/product-detail/en/molex-llc/0755860006/WM22014CT-ND/9095459 Molex Connecteur 50POS SMD] || WM22014CT-ND || 3|| 8.47 EUR|| Lo2 || DI_006 || N || N || N || N<br />
|-<br />
<br />
|}<br />
<br />
=== [http://www.doga.fr Doga] ===<br />
<br />
La prochaine commande aura pour référence interne : DO_004<br />
<br />
Prochaine date de commande : [inconnu]<br />
<br />
Commande passée en attente de livraison : [aucune]<br />
<br />
<br />
<br />
Minimum de commande : 50€ HT<br />
Franco : 100€ HT<br />
<br />
Merci de préciser le catalogue dans lequel se trouve l'article pour le retrouver plus aisément. <br />
<br />
Les principaux catalogues sont :<br />
* http://www.doga.fr/catalogue_pdf/ugv.pdf<br />
* http://www.doga.fr/catalogue_pdf/ugv-alliage-leger.pdf<br />
* [https://shop.precitool.de/bk/WKZ_2018-2019/#page_0.1 Precitool (catalogue 'Outillage')]<br />
<br />
Anciennes commandes Doga archivées [[Projets:Commande_groupee:archives#Doga|ici]]<br />
<br />
<br />
|-<br />
!Demandeur !! class="unsortable"| Description !!class="unsortable"| Ref Doga !! class="unsortable"| Catalogue !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!!Remboursé/Archive (O/N)<br />
<br />
<br />
|-<br />
| Eric||[http://shop.precitool.de/bk/HKL_2016-2017/#page_870 Ø 8mm Zylinderbürste mit Öse, Messingdraht gewellt marque : LESSMANN]|| 481772 || Precitool || 1 || 7 EURHT || <acheteur> || DO_002 || N || O || O || O<br />
|-<br />
| <s>Eric</s>||<s>[http://shop.precitool.de/bk/HKL_2015-2016/#page_1044 Kompakt-Bolzenscheider KNIPEX Mit Mehrkomponenten-Hülle, Öffnungsfeder, 20° abgewinkelt]</s>||<s> 559026</s> ||<s> Precitool </s>||<s> 1 </s>||<s> 40.45EURHT</s> ||<s> <acheteur> </s>||<s> DO_002 </s>||<s>N</s> ||<s>N</s>||<s> N </s>||<s> N</s><br />
|-<br />
| Eric||[http://shop.precitool.de/bk/HKL_2016-2017/#page_924 Strinlochschlüssel-Satz marque AMF]|| 506050|| Precitool || 1 || 31.05EURHT || <acheteur> || DO_002 || N || O || O || O<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1116 KNIPEX Montagezange Typ 4521 für Sprengringe auf Wellen (KNIPEX Ref 45 21 200)]||554175 /4521|| Precitool || 1 || 30,75EURHT || <acheteur> || DO_002 || N || O || O || O<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2016-2017/#page_1242 Schneidoel 500ml]||924055|| Precitool || 1 || 14,35EURHT || <acheteur> || DO_002 || N || O || O || O<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2016-2017/#page_1254 Luftweiche 3 Fach (4 x G3/8) Typ 0304]||925805/0304|| Precitool || 2 || 7.05EURHT || <acheteur> || DO_002 || N || O || O || O<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_35 Spiralbohrer HSS-Co Precitool D1897 INOX Dn 2,1mm]||100670/2,10|| Precitool || 5 || 1.91 EURHT || Lab || DO_003 || N || O || O (livré en 2.3mm, puis relivré gratuitement en 2,1mm) || O<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_815 Düsenlehre 0.45-1.5mm (0.05mm steigung)]||389850/20|| Precitool || 1 || 12.65 EURHT || Lab || DO_003 || N || O || O || O<br />
|-<br />
|Steve||[http://shop.precitool.de/bk/HKL_2017-2018/#page_987 Gelenk-Hakenschlüssel]||506350/22-35|| Precitool || 1 || 13.55 EURHT || Lab || DO_003 || N || N || N || N<br />
|-<br />
|Steve||[http://shop.precitool.de/bk/HKL_2017-2018/#page_987 Gelenk-Hakenschlüssel]||506350/35-60|| Precitool || 1 || 14.90 EURHT || Lab || DO_003 || N || N || N || N<br />
|-<br />
|Steve||[http://shop.precitool.de/bk/HKL_2017-2018/#page_987 Gelenk-Hakenschlüssel]||506350/60-90|| Precitool || 1 || 17.70 EURHT || Lab || DO_003 || N || N || N || N<br />
|-<br />
|Lab||[http://shop.precitool.de/bk/HKL_2017-2018/#page_985 Hakenschlüssel aus spezial Stahl Gehärtet und im Brunierton angelassen, pour Ø 95-100 mm, pour écrous DIN 1804 et DIN 981]||506200 95/100|| Precitool || 1 || 10,80 EURHT || Lab|| DO_003 || N || O || O (erreur de reference de commande) || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_985 Hakenschlüssel aus spezial Stahl Gehärtet und im Brunierton angelassen, pour Ø 95-100 mm, pour écrous DIN 1804 et DIN 981]||506200 95/100|| Precitool || 1 || 10,80 EURHT || Lab || DO_003 || N || O || O (erreur de reference de commande) || O<br />
<br />
|-<br />
|Lab||[http://shop.precitool.de/bk/HKL_2017-2018/#page_1153 Jeu de chasse-goupilles - Splintentreiber]|| 561110/6M || Precitool || 1 || 18.05 EURHT || Lab || DO_003 || N || N || N || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Linksausdreher Grosse 1 (für M3-M6)]||590950/1|| Precitool || 3 || 1,35 EURHT || Lab || DO_003 || N || O || O || O<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Linksausdreher Grosse 2 (für M6-M8)]||590950/2|| Precitool || 2 || 1,35 EURHT || Lab || DO_003 || N || O || O || O<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Linksausdreher Grosse 3 (für M8-M11)]||590950/3|| Precitool || 2 || 1,54 EURHT || Lab|| DO_003 || N || O || O || O<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Schaubenausdreher/Linksausdreher "Super Traktion" Grosse T1 (pour Ø 4-5 mm, perçage 2.1 mm)]||590970/T1|| Precitool || 3 || 4.47 EURHT || Lab || DO_003 || N || O || O || O<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Schaubenausdreher/Linksausdreher "Super Traktion" Grosse T2 (pour Ø 5-7 mm, perçage 3.2 mm )]||590970/T2|| Precitool || 3 || 4.58 EURHT || Lab || DO_003 || N || O || O || O<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Schaubenausdreher/Linksausdreher "Super Traktion" Grosse T3 (pour Ø 8-12 mm, perçage 4.5 mm )]||590970/T3|| Precitool || 3 || 5.70 EURHT || Lab || DO_003 || N || O || O || O<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/WKZ_2018-2019/#page_35 Spiralbohrer HSS-Co Precitool D1897 INOX Dn 8,6mm]||100670/8,60|| Precitool || 2 || 7.14 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/WKZ_2018-2019/#page_35 Spiralbohrer HSS-Co Precitool D1897 INOX Dn 8,7mm]||100670/8,70|| Precitool || 2 || 7.14 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/WKZ_2018-2019/#page_35 Spiralbohrer HSS-Co Precitool D1897 INOX Dn 6,4mm]||100670/6,40|| Precitool || 2 || 5,17 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/WKZ_2018-2019/#page_35 Spiralbohrer HSS-Co Precitool D1897 INOX Dn 9,8mm]||100670/9,80|| Precitool || 2 || 9.65 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/WKZ_2018-2019/#page_930 Gelenk-Hakenschlüssel verstellbar, mit Nase, gehärtet und im Brünierton angelassen; für AuBen Ø (Mutter) 20-35 mm]||506300/20-35|| Precitool || 1 || 11.55 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/WKZ_2018-2019/#page_930 Gelenk-Hakenschlüssel verstellbar, mit Nase, gehärtet und im Brünierton angelassen; für AuBen Ø (Mutter) 35-60 mm]||506300/35-60|| Precitool || 1 || 12.35 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/WKZ_2018-2019/#page_930 Gelenk-Hakenschlüssel verstellbar, mit Nase, gehärtet und im Brünierton angelassen; für AuBen Ø (Mutter) 60-90 mm]||506300/60-90|| Precitool || 1 || 16.05 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2018-2019/#page_1155 Schaubenausdreher/Linksausdreher "Super Traktion" Grosse T4 (pour Ø 12-14 mm, perçage 6.5 mm )]||590970/T4|| Precitool || 3 || 6.89 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2018-2019/#page_1155 Schaubenausdreher/Linksausdreher "Super Traktion" Grosse T5 (pour Ø 16-20 mm, perçage 8.5 mm )]||590970/T5|| Precitool || 3 || 9.00 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/WKZ_2018-2019/#page_761 Düsenlehre 1.5-3,0mm (0.1mm Steigung)]||389850/16|| Precitool || 1 || 13.55 EURHT || <acheteur>|| DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/WKZ_2018-2019/#page_940 Verlängerung 1/4" Typ 870 Marke : HAZET ]||511186|| Precitool || 1 || 20.50 EURHT || <acheteur>|| DO_004 || N || N || N || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2018-2019/#page_895 Einmaulschlüssel DIN894 SW : 13 mm ]||500602/13|| Precitool || 1 || 1.27 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|}<br />
<br />
=== [http://fr.farnell.com Farnell] ===<br />
<br />
Livraison gratuite au dessus de 30€ HT<br />
<br />
La prochaine commande aura pour référence interne : FA_017<br />
<br />
<br />
Prochaine date de commande : <à définir><br />
<br />
Commande passée en attente de livraison : <aucune><br />
<br />
Anciennes commandes Farnell archivées [[Projets:Commande_groupee:archives#Farnell|ici]]<br />
<br />
|-<br />
| Demandeur || class="unsortable"| Description || Ref Farnell || class="unsortable"| Quantité || class="unsortable"| Prix unitaire || Acheteur || Commande<br/>n° || Payé<br/>d'avance<br/>(O/N)|| Commandé<br/>(O/N)|| Distribué<br/>(O/N)|| Remboursé/<br/>Archive<br/>(O/N)<br />
|-<br />
|-<br />
|-<br />
| Claire Poisson || CD4011BM96 || 2114002 || 15 || 0,313 TTC || 3dsman ||FA_015 ||N ||O ||N ||N<br />
|-<br />
|-<br />
| 3dsman || Câble multiconducteur blindé || 2425036 || 10 || 0,85 TTC || 3dsman ||FA_015 ||N ||O ||N ||N<br />
|-<br />
|-<br />
| Steve (Pour lab/smoothie) || NXP LPC 1769 || 2072199 || 1 || 8,68 TTC || 3dsman ||FA_015 ||N ||O ||O ||N<br />
|-<br />
|-<br />
| Dom (Rude ULM) || Connecteur d'alimentation DC, Mâle, 2 A, 9.5 mm, Montage sur câble, 1.7 mm || 1737255 || 2 || 2.87 TTC || 3dsman ||FA_015 ||N ||O ||N ||N<br />
|-<br />
|-<br />
| Steve || MCP1702T-5002E/MB - Régulateur LDO 5V SOT89-3 || 1605559 || 3 || 0.593 || 3dsman ||FA_015 ||N ||O ||O ||N<br />
|-<br />
|-<br />
| Steve || RELAY, SPDT, 250VAC, 12A || 1714771 || 2 || 2.27E|| 3dsman ||FA_015 ||N ||O ||O ||N<br />
|-<br />
|-<br />
|-<br />
| Steve (Pour lab/smoothie) || LDO LM1117 3.3V || 2323580 || 5 || 0.907 || Ph. Gras||FA_016 ||N ||O ||O ||N<br />
|-<br />
| Eric ||[http://fr.farnell.com/amphenol-sine-tuchel/t-3424-501/fiche-libre-6-voies/dp/1123507 Connecteur 6 broches Amphénol avec serrage baillionnette ref T 3424 501] || 1123507 || 1 || 5,12 || Ph. Gras ||FA_016 ||N ||O ||O ||N<br />
|-<br />
| Eric ||[http://fr.farnell.com/nkk-switches/b18jp/switch-toggle-spdt-0-1a-28vac/dp/2374722?ost=2374722&ddkey=http%3Afr-FR%2FElement14_France%2Fsearch Commutateur 3 positions miniature SPDT, 0.1A, 28VAC On-Off-On NKK Switch ref B18JP ] || 2374722|| 2 || 3,98 EUR || Ph. Gras ||FA_016 ||N ||O ||O ||N<br />
|-<br />
| Ph. Gras||[http://fr.farnell.com/jst-japan-solderless-terminals/phr-2/boitier-2-voies-2mm/dp/3616186 Boîtier de connecteur, Série PH, Embase, 2 Voies, 2 mm, Contacts à sertir Série BPH et SPH ] || 3616186|| 100 || 0,0324 EUR || Ph. Gras||FA_016 ||N ||O ||O ||O<br />
|-<br />
| Ph. Gras||[http://fr.farnell.com/jst-japan-solderless-terminals/sph-002t-p0-5s/contact-0-05-0-22mm-cut-reel/dp/1671245?st=SPH-002T-P0.5S Contact, Série PH, Femelle, Sertissage, 24 AWG, Contacts plaqués étain, Connecteurs PH ] || 1671245|| 250|| 0,0208 EUR || Ph. Gras ||FA_016 ||N ||O ||O ||O<br />
|-<br />
| Ph. Gras||[http://fr.farnell.com/on-semiconductor/lm317ahvt/regulateur-ldo-ajustable-1-5a/dp/1564497?st=lm317LM317AHVT Régulateur de tension positive ajustable 1.2V à 37V, 1.5A en boîtier TO-220-3 ] || 1564497|| 10|| 0,727 EUR || Ph. Gras ||FA_016 ||N ||O ||O ||O<br />
|-<br />
|-<br />
|-<br />
| <demandeur> ||[http://wiki.electrolab.fr/Projets:Commande_groupee#Glossaire <article>] || <fa_cde_nb> || <quantité> || <prix> || <acheteur> ||FA_017 ||N ||N ||N ||N<br />
|-<br />
|-<br />
|}<br />
<br />
=== [http://www.gotronic.fr Gotronic] ===<br />
<br />
la prochaine commande a la référence interne GO_003<br />
<br />
<br />
Commande passée en attente de livraison :GO_002 le 31/05/2017 par Ellyan<br />
<br />
<br />
Anciennes commandes Gotronic archivées [[Projets:Commande_groupee:archives#Gotronic|ici]]<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref gotronic!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||<Acheteur>|| GO_XXX || N || N || N || N<br />
|-<br />
--><br />
| Damien H || Solénoïde 12 Vcc || LS1110BD || 1 || 7,00€||Ellyan|| GO_002 || N || O || N || N<br />
|}<br />
<br />
=== HighVoltageShop ===<br />
<br />
La prochaine commande a pour référence interne : HV_002<br />
<br />
5 euros de réduction sur la prochaine commande<br />
<br />
Prochaine date de commande : Aucune<br />
<br />
Commande passée en attente de livraison : Aucune<br />
* frais de port 20 euros<br />
* Livraison mardi 7 janvier 2014 au lab<br />
<br />
Commande livrée en cours de distribution : HV_001 (08/12/2013) <br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref ebay!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||David|| DI_XXX || N || N || N || N<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| Thomas || Cable HV 120 kV || 271261265516 || 1 || 8,69€||David|| HV_001 || O || O || O || N<br />
|-<br />
|David||-30kV HV-Generator Modul 12VDC||281162933827||1||34,99€||David||HV_001||O||O||O||N<br />
|-<br />
|David||5 Stk. Zeilentrafo - Flyback Transformer - Zeilentrafos||281024817841||1||24,99€||David||HV_001||O||O||O||N<br />
|-<br />
|David||+30kV HV-Generator Modul 12VDC||281162933829||1|| 34,99€||David||HV_001||O||O||O||N<br />
|-<br />
|CitronVert||-30kV HV-Generator Modul 12VDC||281162933827||2||34,99€||David||HV_001||N||O||O||N<br />
|-<br />
| Goldo || Regelbares Hochspannungsnetzteil 50kV Strombegrenzung || 280941865340 || 1 || 119,99€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || +30kV HV-Generator Modul 12VDC || 281162933829 || 1 || 34,99€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Zenos || +30kV HV-Generator Modul 12VDC || 281162933829 || 1 || 34,99€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || Cable HV 120 kV || 271261265516 || 1 || 8,69€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || Hochspannungskabel 40kV 1m || 271261265512 || 1 || 4,61€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || Hochspannungswiderstand 20kV 1 GigaOhm Messwiderstand || 280941865344 || 1 || 6,34€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || Hochspannungswiderstand 20kV 100 MegaOhm || 271106455991 || 1 || 6,34€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || Hochspannungswiderstand 20kV 1 MegaOhm || 281026497192 || 1 || 6,34€||David|| HV_001 || O || O || O || N<br />
|}<br />
<br />
=== [http://www.limpulsion.fr/web/index.php L'impulsion] ===<br />
<br />
[http://v1.limpulsion.fr/docpdf/2008_cat/bpoa_a.pdf Catalogue "accessoires de test"]<br />
<br />
La prochaine commande a la référence interne LI_002<br />
<br />
Prochaine date de commande : [à définir]<br />
<br />
<br />
Commande livrée en cours de distribution :[aucune]<br />
<br />
Anciennes commandes Limpulsion archivées [[Projets:Commande_groupee:archives|ici]]<br />
<br />
<br />
{|class="wikitable sortable" style="font-size:80%"<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref L'impulsion!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-<br />
|Lab||ADAPTATEUR D'AXE HM8001-2 HAMEG||760000500||1||2.30HT||Yannick||IL_001||N||N (plus livrable)||N||O<br />
|-<br />
|Lab||TRESSE A DESSOUDER NO CLEAN 2.8mm/3m||730.14||10||1.56HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||Entretoise plastique grise de montage en saillie marque "Electro-PJP" pour douilles 4mm type 3265, ref EPJP : 3282||<pas au catalogue: demander si livrable> ||16||? ||Yannick||IL_001||N||N (apparement pas dispo)||N||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou NOIR, ref3265-I-0 ||326500||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou MARRON, ref3265-I-1 ||326501||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou ROUGE, ref3265-I-2 ||326502||3||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou BLEU, ref3265-I-6 ||326506||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou VIOLET, ref3265-I-7 ||326507||3||1.48HT||Yannick||IL_001||O||O||N||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou GRIS, ref3265-I-8 ||326508||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou BLANC, ref3265-I-9 ||326509||3||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou JAUNE/VERT, ref 3265-I-J/V||326510||1||1.74HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||[http://v1.limpulsion.fr/docpdf/2008_cat/bpoe_a.pdf#page=9 Passe fil classique intérieur :12mm, Perçage: 18mm, Epaisseur :10mm (lot de 10pcs)]||252.162||1||1,95EURHT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||Entretoise plastique grise de montage en saillie marque "Electro-PJP" pour douilles 4mm type 3265, ref EPJP : 3282||<pas au catalogue: demander si livrable> ||16||? ||Yannick||IL_001||N||N(apparement pas dispo)||N||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou NOIR, ref3265-I-0 ||326500||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou MARRON, ref3265-I-1 ||326501||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou ROUGE, ref3265-I-2 ||326502||3||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou BLEU, ref3265-I-6 ||326506||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou VIOLET, ref3265-I-7 ||326507||3||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou GRIS, ref3265-I-8 ||326508||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou BLANC, ref3265-I-9 ||32650||3||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou JAUNE/VERT, ref 3265-I-J/V||326510||2||1.74HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||CLE EXTERNE POUR DOUILLE DE SECURITE||3299||1||13.51HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||TRANSFO FERRITE POUR THT HM1005 HAMEG (plus livrable) ||THTHM1005||1||16.77HT||Yannick||IL_001||N||N (plus livable)||N||O<br />
|-<br />
|Eric||Lot de 100 douilles pour C.I diam4 Long 10mm à souder Electro-PJP ref 20054||20054||1||7,95 EUR HT||Yannick||LI_001||N||O||O||O<br />
|-<br />
<br />
|Eric||CI SN75492 (7 segm DRIVER) TEXAS DIP14||75492||13||1.29HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||CI 74LS164 TEXAS DIL||74LS164||2||0.76HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||IPROBER520||IPROBER520||1||594HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|-class="sortbottom"<br />
|}<br />
<br />
=== [https://shop.mchobby.be/ MCHobby] ===<br />
<br />
La prochaine commande a pour référence interne : MCH_001<br />
<br />
Prochaine date de commande : <Mardi 20 ou mercredi 21 au plus tard ><br />
<br />
Livraison gratuite en Mondial Relay à partir de 75 euros.<br />
<br />
<br />
<br />
Anciennes commandes MCHobby archivées [[Projets:Commande_groupee:archives#MCHobby|ici]]<br />
<br />
Site WEB de MCHobby : https://shop.mchobby.be/<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Mon Droguiste !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||<Acheteur>|| MC_XXX || N || N || N || N<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| LienRag|| Divers ||Divers || ++|| 75€||<acheteur>|| MHC_001 || N|| N || N || N<br />
|}<br />
<br />
<br />
=== [http://217.34.103.131/homepage/homepage.html Mini-Circuits] ===<br />
<br />
La prochaine commande a pour référence interne : MC_001<br />
<br />
<br />
<br />
<br />
Anciennes commandes Mini-Circuits archivées [[Projets:Commande_groupee:archives#Mini-Circuits|ici]]<br />
<br />
Site WEB de minicircuits : http://www.minicircuits.com/homepage/homepage.html<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Mini-circuits !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| F1CHF || ERA-3 || AMPL || 20 || 1.43€||F1CHF|| MC_001 || N || N || N || N<br />
|-<br />
|-<br />
| F1CHF || ADCH-80+ || coil || 20 || 2.88€||F1CHF|| MC_001 || N || N || N || N<br />
|-<br />
|}<br />
<br />
=== [http://www.mon-droguiste.com/index.cfm Mon Droguiste] ===<br />
<br />
La prochaine commande a pour référence interne : MD_001<br />
<br />
<br />
<br />
<br />
Anciennes commandes Mon Droguiste archivées [[Projets:Commande_groupee:archives#Mon-droguiste|ici]]<br />
<br />
Site WEB de Mon Droguiste : http://www.mon-droguiste.com/index.cfm<br />
<br />
|-<br />
|-l<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| Eric|| Ethylene Diamino Tetraacetic Acide 500g ||Ethylene Diamino Tetraacetic Acide Sac 500g || 1|| 16.95€||<acheteur>|| MD_001 || N|| N || N || N<br />
|}<br />
<br />
=== [http://www.mouser.fr Mouser Electronics]===<br />
<br />
La prochaine commande aura pour référence interne MO_014<br />
<br />
Prochaine date de commande : ?<br />
<br />
<br />
Commande livrée en cours de distribution : MO_013 le 31/05/2017 par Ellyan<br />
<br />
Anciennes commandes Mouser Electronics archivées [[Projets:Commande_groupee:archives#Mouser Electronics|ici]]<br />
<br />
Livraison gratuite (FedEx ou UPS) au delà de 50€ de commande<br />
<br />
<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Mouser !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
|-<br />
--><br />
<br />
|-<br />
|Frederic.D.||[http://www.mouser.fr/ProductDetail/TE-Connectivity/1-826632-0/ Headers & Wire Housings 2X10P DUAL ROW]||571-1-826632-0 ||3 ||1.95 |||| MO_013||O ||O ||O ||N<br />
|-<br />
|Frederic.D.||[http://www.mouser.fr/ProductDetail/Bourns/3306P-1-103/ Trimmer Resistors - Through Hole 10K 25% 6mm Single Turn]||652-3306P-1-103 ||3 ||0.407 |||| MO_013||O ||O ||O ||N<br />
|-<br />
|Frederic.D.||[http://www.mouser.fr/ProductDetail/Schurter/13019302/?qs=%2fha2pyFadugAVCtehZ6ro0we%252bFlHwInvMJ3iEORyekx9pnGrLimsvA%3d%3d Pushbutton Switches SHORT TRAVEL SWITCH 6X6, 5.0MM]||693-1301.9302 ||9 ||0.251 |||| MO_013||O ||O ||O ||N<br />
|-<br />
|Frederic.D.||[http://www.mouser.fr/ProductDetail/Bourns/MF-USMF075-2/ Resettable Fuses - PPTC 0.75A 6V 0.18ohm Hold .75A Trip 1.5A]||652-MF-USMF075-2 ||3 ||0.275 |||| MO_013 ||O ||O||O ||N<br />
|-<br />
|Frederic.D.||[http://www.mouser.fr/ProductDetail/STMicroelectronics/SMA6J50A-TR/?qs=%2fha2pyFadujqXhcCRI4%2fO5BEn9p7pkr6EX0dAQtUlws3JpN%2fE2p9DQ%3d%3d TVS Diodes - Transient Voltage Suppressors HJ Temp Transil]||511-SMA6J5.0A-TR ||3 ||0.38 |||| MO_013 ||O||O||O ||N<br />
|-<br />
|-<br />
|Sylvain V.||[http://www.mouser.fr/ProductDetail/Cirrus-Logic/CS4398-CZZ/?qs=sGAEpiMZZMv%252bLKsN4bqzyhXScoHWAp%252boAQFEBwyfAGo%3d DAC Cirrus Logic]||777-CS4398-CZZ ||1 || 10.46 || Sylvain V. || MO_013 ||O||O||O ||N<br />
|-<br />
|Eric||[https://eu.mouser.com/ProductDetail/Amphenol-Tuchel/T-3427-100?qs=%2fha2pyFaduhPv3s%2fjYa9sAYm3fflPgRKEDSdRTPyUvP7YbNcd%2fVs5g%3d%3d Circular DIN Connectors FEMALE RECEPTACLE 6 WAY, Amphenol series C091B]|| 523-T3427-100 ||1 || 10.29|| <<acheteur>> || MO_014 ||N||N||N ||N<br />
|-<br />
|Eric||[https://www.mouser.fr/ProductDetail/EPCOS-TDK/B32926A4685M?qs=sGAEpiMZZMv1cc3ydrPrF3kXVSi%252b9fyL4PImBI83UxcgTMvwb1977w== Condensateurs à film 6.8uF 20% 350Vac LS 37.5MM Fabricant : EPCOS /TDK ref : B32926A4685M ]|| 871-B32926A4685M ||1 || 10.67|| <<acheteur>> || MO_014 ||N||N||N ||N<br />
|-<br />
|Eric||[https://www.mouser.fr/ProductDetail/Texas-Instruments/OPA2227U-2K5?qs=sGAEpiMZZMtCHixnSjNA6Mrdwin7F8A2DB4TJmgUI0w%3d OPA2227U SOIC8 dual opamp low noise Texas ]|| 595-OPA2227U/2K5 ||2 || 8.07|| <<acheteur>> || MO_014 ||N||N||N ||N<br />
|-<br />
|Eric||[https://eu.mouser.com/ProductDetail/Molex/53253-0570?qs=sGAEpiMZZMvlX3nhDDO4AD1CBCqS4WJ3BaSa47NubxE%3d Shrouded header 5 pins 2mm male through hole board connnector vertical mounting Molex ref. 53253-0570 Cross ref to JST PH "B5B-PH-K-S"]|| 538-53253-0570||20 || 0,164 €|| <<acheteur>> || MO_014 ||N||N||N ||N<br />
|-<br />
|Eric||[https://eu.mouser.com/ProductDetail/Central-Semiconductor/TIP42B?qs=sGAEpiMZZMshyDBzk1%2fWi0MKeUdJDRlz1TXFEdLineJjytqjBdqtHg%3d%3d Bipolar Transistor PNP 10A 80V TIP42B]|| 610-TIP42B ||2 || 0,969 €|| <<acheteur>> || MO_014 ||N||N||N ||N<br />
|-<br />
| Eric|| [https://www.mouser.fr/ProductDetail/Hirose-Connector/RM12BPE-5PH71?qs=sGAEpiMZZMvG94qpybaIZaiKjo18NgShhh8FQGCnH4c%3d HIROSE CONN PLUG Cbl Mount 5 Terminals ref "RM12BPE-5PH(71)"] (aussi dispos chez Digikey ref [https://www.digikey.fr/products/fr?keywords=HR1732-ND 'HR1732-ND')] ||798-RM12BPE-5PH71 || 1|| 11.47 EUR||<acheteur>|| MO_014 || N || N || N || N<br />
|-<br />
| Eric|| [https://www.mouser.fr/ProductDetail/Mueller-Electr/BU-75K?qs=sGAEpiMZZMs4AFwHyzhTm%2f3wHG8LpAJAx37I4fl4y%2fU%3d Kelvin clip 10A Mueller Electric ref. BU-75K] (aussi dispo chez Digikey [https://www.digikey.fr/products/fr?keywords=BU-75K ref '314-1128-ND')] ||548-BU-75K|| 4|| 10.20 EUR||<acheteur>|| MO_014 || N || N || N || N<br />
<br />
|-<br />
|}<br />
<br />
<br />
=== [http://www.motedis.fr/shop/ Motedis France] ===<br />
<br />
<br />
La prochaine commande aura pour référence interne : MS_001<br />
<br />
<br />
<br />
<br />
Anciennes commandes Motedis France archivées [[Projets:Commande_groupee:archives#Motedis France|ici]]<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Motedis!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-<br />
|Eric||Plaquette aluminium 15mm d'épaisseur Largeur: 100mm ||<ref motedis>||L:1000mm|| 24.15EURHT || <acheteur> || MS_001 || N|| N || N || N<br />
|-<br />
|<demandeur>||<description>||<ref motedis>|| <quantité> || <prix>|| <acheteur> || MS_001 || N|| N || N || N<br />
|-<br />
|}<br />
<br />
<br />
===[http://www.nouvelleplastique.it/f/setf.html Nouvelle Plastique]===<br />
La prochaine commande a pour référence interne : NP_001<br />
<br />
Prochaine date de commande : Q3/2014<br />
<br />
<br />
<br />
Anciennes commandes Nouvelle Plastique archivées [[Projets:Commande_groupee:archives#Nouvelle Plastique|ici]]<br />
<br />
La société "[http://www.nouvelleplastique.it/f/setf.html Nouvelle Plastique]" fabrique des systèmes de rangements portables et modulaires en plastique.<br />
Les produits sont souvent bien pensés (parfois mieux que RAACO ou Stanley) et de bonne solidité.<br />
<br />
Malheureusement, ses produits ne sont que rarement distribués par les circuits classiques et pour le moment aucun revendeur de détail en France n'a été identifié. De même, on ne connait pas les prix des produits.<br />
La démarche envisagée est de collecter via le tableau ci-dessous une liste de souhaits afin de pouvoir demander un devis global directement au fabricant d'ici quelques mois (probablement en Q3/2014). En fonction de ses proposition de prix, chacun pourra finalement accepter ou refuser que ses souhaits soient inclus dans la commande définitive. Le coût du port sera partagé au prorata du prix des marchandises achetées (plus il y a de demaneurs, plus le coût individuel du port sera faible).<br />
Pour chaque article, il y a indication d'une UDV (Unité De Vente), c'est à dire de lot indivisible.<br />
Au terme des sélections de vos besoins, il faudra que le nombre de pièces commandées pour chaque article soit un multiple de son UDV.<br />
Le tableau ci-dessous dispose d'une structure adaptée à la gestion des souhaits des demandeurs, du nombre d'article et des UDV.<br />
Tous les demandeurs intéressés par un même article s'inscrivent dans une seule ligne (ce qui conduit au fait qu'il y ait une ligne par référence d'article).<br />
Le champ "PUHT" sera complété une fois le devis obtenu.<br />
<br />
====Légende du tableau ====<br />
<br />
UDV = correspond au nombre d'articles par UDV. = nombre d'articles dans un lot indivisible, cette information est indiquée par le fabricant dans son catalogue. <br />
Reste à affecter = mod(Nombre d'UDV; Nombre d'articles) <br />
<br />
<br />
Si vous éditez une ligne existante pour vous inclure comme demandeur de l'article considéré, modifiez les champs suivants :<br />
*''UDV' *''Nombre d'UDV'' (valeur cumulée d'UDV entre tous les demandeurs) <br />
*''Quantités (nombre d'articles)'' (valeur cumulées en nombre d'articles individuels entre tous les demandeurs) <br />
*''Reste à affecter'' (valeur calculée globalement pour tout les demandeurs) <br />
*''Liste de demandeurs avec (unités)'' Unités = nombre d'articles demandéz<br />
<br />
<br />
{|class="wikitable sortable" style="font-size:99%"<br />
|-<br />
! Ref article!! class="unsortable"| Désignation!! UDV (= nombre d'articles dans un lot indivisible) !! class="unsortable"| Nombre d'UDV!! class="unsortable"| Quantité souhaitée(nombre d'articles) !! Reste à affecter!! PUHT !! Liste de demandeurs avec (unités) !! N° de commande <br />
|-l<br />
|00366|| Tyger maxi double|| 6 || 1 ||6 ||0|| <PU> || Eric (6) || NP_001 <br />
|-<br />
|00361|| Tyger maxi|| 12 || 1 ||6 ||6|| <PU> || Eric (6) || NP_001 <br />
|-<br />
<br />
|}<br />
<br />
=== [https://www.olimex.com/ Olimex]===<br />
<br />
La prochaine commande a pour référence interne : OL_001<br />
<br />
<br />
<br />
<br />
Anciennes commandes Olimex archivées [[Projets:Commande_groupee:archives#Olimex|ici]]<br />
<br />
<br />
Achat par l'intermédiaire de leur site internet: https://www.olimex.com/<br />
<br />
Produits identifiés comme potentiellement intéressants:<br />
* https://www.olimex.com/Products/ARM/TI/TMS570-CAN/ un pti devkit pour un micro bien patator, prévu au départ pour des applications safety mais qui a des périphériques & capacités pas dégueulasses...<br />
* https://www.olimex.com/Products/Modules/Adapters/ pour utiliser leurs modules d'extension avec un launchpad ou un rpi<br />
* https://www.olimex.com/Products/Modules/LCD/ (divers modules LCD)<br />
* https://www.olimex.com/Products/Modules/LCD/MOD-LCD4.3%27%27/ module LCD "complet" avec pti micro sympatoche intégré<br />
* https://www.olimex.com/Products/OLinuXino/ gamme de nanocomputers intégrés & pas chers (type rpi mais en open)<br />
* https://www.olimex.com/Products/Components/Misc/TC-K-TYPE/ thermocouple K <br />
etc...<br />
<br />
<br />
Commande prévue courant mars 2013 par Clem.<br />
Attention, prix HT a priori, et prévoir également frais de port "importants" (environ 20€) à répartir entre les participants à la CG.<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Olimex!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||<Acheteur>|| OL_XXX || N || N || N || N<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| XXX|| XXX || - || - || XXX€||XXX|| OL_001 || N || N || N || N<br />
|-<br />
|-<br />
|}<br />
<br />
=== [http://www.otelo.fr/fr/index.html Otelo] ===<br />
<br />
Outillage bois-métal <br />
<br />
Ports gratuits au delà de 230 € H.T. ou code promo<br />
<br />
La prochaine commande a pour référence interne : OT_004<br />
<br />
Prochaine date de commande : < non définie ><br />
<br />
Commande passée en attente de livraison [AUCUNE]<br />
<br />
<br />
Anciennes commandes Otelo archivées [[Projets:Commande_groupee:archives#Otelo|ici]]<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Otelo!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
|-<br />
--><br />
|-<br />
|lab||TARAUD à main diamètre 14X200 Acier/alu||14104142N1||1|| 14,51€ HT|| <Patrick> || OT_002|| N || O|| O || O<br />
|-<br />
|lab||100 rondelles plates diamètre 8X16 ||36211008||5|| 3,23€ HT|| <Patrick> || OT_002|| N || O|| O || O<br />
|-<br />
|Patrick||Disque à poncer bombé axe 22mm D125 grain 80||54426280||2|| 3,42€ HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|Patrick||boites de rangement 18 sep 375X310X60||PY 69720030||3|| 9,55€ HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|Patrick||jeu d'outils ébavurage||PY 58500009||1|| 7,35€ HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|Patrick||BOMBE GALVA FLASH||PY 73006003||1|| 8,40€ HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|Eric||Tablier de soudeur 90 x 60 cm||PW 75 150 001||1|| 10,90€HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|MAZ24||meule blanche touret||5473014F||1|| 11,40€HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|MAZ24||Meule verte de touret||54571150||1|| 42,40€HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|MAZ24||Bagues adaptation||54703320||4|| 1,09€HT|| <Patrick> || OT_002|| O || O|| O|| O<br />
|-<br />
|Patrick||Mandrin à clef 3-16mm CM2/B18||30140413||1|| 27,25€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Mandrin à clef 1-13mm CM2/B16||30140409||1|| 23,20€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Arbre pour mandrin CM2/B16||30199116||1|| 6,80€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Arbre pour mandrin CM2/B18||30199118||1|| 7,00€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Ecouvillon manche bois 15mm||57169015||1|| 7,70€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Ecouvillon manche bois 25mm||57169025||1|| 8,15€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Ecouvillon à fil 6mm||57169006||1|| 5,24€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Ecouvillon à fil 25mm||57151025||1|| 6,38€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Sylvia||Support articulé ||43130110||1|| 23,77€ HT|| <Patrick> || OT_003|| N || O|| O|| O<br />
|-<br />
|}<br />
<br />
===[http://www.outiz.fr/ Outiz]===<br />
<br />
<br />
Comptoir Guilleraies (Nanterre)<br />
<br />
Du lundi au vendredi 7h - 17h Samedi 8h - 12h<br />
<br />
Téléphone : 01 40 35 77 77<br />
<br />
La prochaine commande aura pour référence interne : OU_001 <br />
<br />
Prochaine date de commande : <non définie><br />
<br />
Commande passée en attente de livraison :[aucune]<br />
<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Outiz!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!!Remboursé/Archive (O/N)<br />
|-<br />
| Eric ||[http://www.outiz.fr/sferaco-vanne-a-sphere-laiton-pn25-batiment-ff-3-4-poignee-acier-plate-rouge-580005/p/3806984/ Vanne à poignée plate rouge Genre : FF Ø : 3/4" ] ||3806984 || 1|| 4,54 €HT||<acheteur>|| OU_001 || N || N || N || N<br />
|-<br />
|}<br />
<br />
=== [http://fr.rs-online.com/web/ Radiospares (RS Composants)] ===<br />
<br />
La prochaine commande aura pour référénce interne : RS_012<br />
<br />
<br />
<br />
Commande livrée en cours de distribution : <aucune><br />
<br />
Anciennes commandes Radiospares archivées [[Projets:Commande_groupee:archives#Radiospares|ici]]<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref RS!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||Acheteur|| DI_XXX || N || N || N || N<br />
--><br />
|-<br />
| papy F1CHF||régulateur || 686-9007 || 10 || 0,27€|| <>|| RS_012 || N || N || N || N<br />
|FredericD||[http://fr.rs-online.com/web/p/ldr/9146710/ Silonex, NSL-19M51, CdS, Traversant, TO-18, 20 kΩ → 100 kΩ]||914-6710|| 10 || 1.074€HT ||<>||RS_012||N||N||N||N <br />
|-<br />
|FredericD||[http://fr.rs-online.com/web/p/relais-reed/2562055/ Relais Reed 1NO 12V dc 1 A]||256-2055|| 1 || 5.17€HT ||<>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[http://fr.rs-online.com/web/p/refrigerants/1115853/ Réfrigérant aérosol Cramolin Aérosol 400 ml, -50°C]||111-5853|| 2 || 11.12€HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/accessoires-pour-capteur-de-temperature/0286771/ Presse-étoupe pour Thermocouple]||286-771|| 2 || 9,68€HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|<s>Eric</s>||<s>[https://fr.rs-online.com/web/p/pinces-kelvin/7148263/ Pince Kelvin BU-75K, 10A, noir, fabricant : Mueller]</s>||<s>714-8263</s>||<s> 2</s> ||<s> 19,61€HT</s> ||<s><acheteur></s>||<s>RS_012</s>||<s>N</s>||<s>N</s>||<s>N</s>||<s>N</s> <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/condensateurs-aluminium/8396258 Condensateur électrolytique aluminium radial 10µF, -20%, 50V dc, Traversant, +105°C, WURTH série WCAP-AT1H, 5 (Dia.) x 11mm 5000h 97mA Référence fabricant : 860240672002]||839-6258|| 25 (1 sachet) || 3,90 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/condensateurs-aluminium/8399011 Condensateur électrolytique aluminium radial 47µF, -20%, 63V dc, Traversant, +105°C, WURTH série WCAP-ATUL, 8 (Dia.) x 11.5mm 7000h 360mA ESR: 0.66 Ohms Référence fabricant : 860040774002]||839-9011|| 20 (2 paquets) || 3,12 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/condensateurs-aluminium/8399033 Condensateur électrolytique aluminium 120µF, -20%, 63V dc, Traversant, +105°C, série WCAP-ATUL, 10 (Dia.) x 16mm 7000h 760mA ESR: 0.3 Ohms Référence fabricant : 860040775008]||839-9033|| 20 (4 paquets) || 3,43 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/connecteur-xlr/7259543/ Connecteur XLR femelle plastique pour chassis soudage pour CI 3 broches coudé + blindage avec louet métal, NEUTRIK NC3FAH2]||725-9543|| 2 || 1,97 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/connecteur-xlr/7259549 Connecteur XLR mâle plastique pour chassis soudage pour CI 3 broches coudé + blindage, NEUTRIK NC3MAH ]||725-9549|| 2 || 1,43 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/fusibles-cms-rearmables/5177054/ Fusible CMS réarmable, Littelfuse, 2.2A - 1.1A Référence fabricant : SMD100F-2 MK : 100F]|| 517-7054|| 10 || 0,497 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|<s>Eric</s>||<s>[https://fr.rs-online.com/web/p/roulettes-sur-platine/0819567/ Roulette Pivotante Acier 50mm, Bas profil, 270kg Fabricant : Revvo]</s>|| <s>819-567</s> || <s>4</s>|| <s>34.91 €HT</s> ||<s><acheteur></s>||<s>RS_012</s>||<s>N</s>||<s>N</s>||<s>N</s>||<s>N</s> <br />
|-<br />
|3ds||[https://fr.rs-online.com/web/p/potentiometres/0387896/ Potentiomètre carbone série 23 montage panneau 4K7 B avec interrupteur DPST, axe 6,35mm TE Connectivity ref 23ESB472MMF50AF]||387-896|| 1 || 4,14€HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Louis||[https://fr.rs-online.com/web/p/passe-fils/1366806/ Passe-fils,SES en PVC, Diamètre maximum de câble 3mm Noir ref 01070005010 ]||136-6806|| 1 sachet de 100|| 5,38€HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|}<br />
<br />
<br />
<br />
=== [http://www.stquentin-radio.com/ Saint Quentin radio]===<br />
<br />
La prochaine commande a pour référence interne SQ_002<br />
<br />
Prochaine date de commande : <non défini><br />
<br />
<br />
<br />
Anciennes commandes Saint Quentin Radio archivées [[Projets:Commande_groupee: Saint Quentin radio|ici]]<br />
<br />
Paiement cash par avance à l'acheteur : payez le montant exact, car il n'y a pas de frais annexes<br />
<br />
Frais de port : 0€ (sauf objets lourds) Gare du Nord<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref St Quentin!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
|-<br />
--><br />
|Lab||DOUILLE DE SECURITE 4mm ECROU BLANC, ref3265-I-9 ||326509 ||3||1.80€||<Patrick>||SQ_001||N||O||O||O<br />
|-<br />
|Lab||Fiche DIN 5BR MALE PLASTIQUE 360°||I076||2||1.00€||<acheteur>||SQ_002||N||N||N||N<br />
|-<br />
|Lab||Fiche DIN 5BR CHASSIS METAL 360°||I088||1||1.20€||<acheteur>||SQ_002||N||N||N||N<br />
|}<br />
<br />
=== [http://www.selectronic.fr Selectronic] ===<br />
<br />
La prochaine commande a pour référence interne : SE_010 <br />
<br />
<br />
<br />
Commande livrée en cours de distribution : [aucune] <br />
<br />
Anciennes commandes Sélectronic archivées [[Projets:Commande_groupee:archives#Selectronic|ici]]<br />
<br />
Frais de port : 0€ (sauf objets lourds)<br />
<br />
Certains produits sont pas en stock à Paris et requièrent d'être livrés de Lille d'où un délai de quelques jours. Le mieux est d'aller au mag à Nation le mardi pour passer la commande et dans ce cas c'est en principe dispo jeudi sur place.<br />
<br />
<br />
<br />
{|class="wikitable sortable" style="font-size:85%"<br />
|-<br />
! Demandeur !! class="unsortable"| Description || Ref Sélectronic!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-<br />
|Eric||Résistance CTN 10kOhms 10% format goutte traversant||5277|| 1 || 0.95€TTC|| Eric|| SE_008 || O || O || O || O<br />
|- <br />
|lab||Résistance CTN 10kOhms 10% format goutte traversant||5277|| 1 || 0.95€TTC|| Zenos|| SE_009 || N || O || O || N<br />
|-<br />
|Zenos||triac BT139-600||4024|| 3 || 1,90€TTC|| Zenos|| SE_009 || O || O || O || O<br />
|-<br />
|Lab||TIC106D Thyristor||4018|||1||1,52||<acheteur>|| SE_009 || N || O || N (pas dispo) || N <br />
|-<br />
|Eric||IR IRF9540 MOS canal P -100V -19A||08015|||1||2,50EUR||Zenos|| SE_009 || O || O || O || O<br />
|- <br />
|Eric||Mosfet N IRF640N TO220 200V 0.150Ω - 18A||HD75-940|||2||1,94||<acheteur>|| SE_010 || N || N || N || N<br />
|-<br />
|Marc f6itu||pointes de scope||2447|||4||1,02||<acheteur>|| SE_010 || N || N || N || N<br />
|-<br />
|Lab (Eric)||[http://www.selectronic.fr/joints-adhesif-pour-enceintes.html bande mousse autocollante de largeur 5mm, hauteur 2mm]||2300|||2||5.50||<acheteur>|| SE_010 || N || N || N || N<br />
|-<br />
! !! !! !! !! !! !! !! !! !! !!<br />
|}<br />
<br />
=== [http://www.sparkfun.com/ SparkFun Electronics]===<br />
<br />
La prochaine commande a pour référence interne SF_002<br />
<br />
Prochaine date de commande : N/A<br />
<br />
<br />
Commande livrée en cours de distribution : SF_001<br />
<br />
<br />
TVA, frais de port et droits de douane + frais pour dossier de dédouanement : selon taille totale de la commande finale, seront ventilés au pro-rata du montant commandé par chacun.<br />
<br />
Anciennes commandes SparkFun Electronics archivées [[Projets:Commande_groupee:archives#SparkFun Electronics|ici]]<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref SparkFun!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
<!-- Pour ajouter une ligne, copier les 2 lignes suivantes (celles qui commencent par | ) à la suite du tableau et remplacer le contenu des colonnes par ce qui semblera adéquat<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||<Acheteur>|| DI_XXX || N || N || N || N<br />
|-<br />
--><br />
|Damien H||Spark Gap Igniter - 4.8V||COM-11218||3||$14,95||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Pilou||MIDI Shield||DEV-09595||1||$19,90||<Damien H>||SF_001||N||O||O||O<br />
|-<br />
|Pilou||OpenServo||ROB-09014||2||$14,95||<Damien H>||SF_001||N||O||O||O<br />
|-<br />
|Pilou||Breakout Board for PCF8575 I2C Expander||BOB-08130||1||$11,95||<Damien H>||SF_001||N||O||O||O<br />
|-<br />
|MAZ24||wire stripper||TOL-08696||1||$4,95||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|MAZ24||flush cutter||TOL-11952||1||$6,95||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Eric||Optical Dust Sensor - GP2Y1010AU0F||COM-09689||1||$11,95||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Eric||Mating Connector Housing for Dust Sensor (JST ref#: ZHR-6)||PRT-09690||2||$0,35||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Eric||Crimp Pins for Dust Sensor Connector (JST ref#: SZH-002T-P0.5)||PRT-09728||16||$0,09||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Eric||Copper Tape - 2" (50ft)||PRT-11081||1||$14,95||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Olga||RaspiRobot Board||KIT-11561||1||$29,95||<Damien H>||SF_001||N||O||N||O<br />
|-<br />
|Dom||Copper Tape - 2" (50ft)||PRT-11081||1||$14,95||||SF_002||N||N||N||N<br />
|-<br />
|Jean-Marc (PdM) || Polymer Lithium Ion Battery - 400mAh || PRT-10718 || 1 || $6.95 || || SF_002 || N || N || N ||N<br />
|-<br />
|Jean-Marc (PdM) || SparkFun USB LiPoly Charger - Single Cell || PRT-12711 || 1 || $14.95 || || SF_002 || N || N || N ||N<br />
|-<br />
|Jean-Marc (PdM) || Precision Disc Wheel - 5" (Yellow, 2 Pack) || ROB-12469 || 1 || $6.29 || || SF_002 || N || N || N ||N<br />
|-<br />
|Jean-Marc (PdM) || Set Screw Hub - 3mm Bore || ROB-12512 || 2 || $4.99 || || SF_002 || N || N || N ||N<br />
|-<br />
|Jean-Marc (PdM) || ProtoBoard - Square 2" || PRT-08811 || 1 || $2.95 || || SF_002 || N || N || N ||N<br />
|-<br />
|Jean-Marc (PdM) || Micro Gearmotor - 90 RPM (6-12V) || ROB-12285 || 2 || $12.95 || || SF_002 || N || N || N ||N<br />
|- <br />
|Jean-Marc (PdM) || SparkFun Solderable Breadboard - Mini || PRT-12702 || 1 || $2.95 || || SF_002 || N || N || N ||N<br />
|- <br />
|}<br />
<br />
=== Subtel.fr ===<br />
<br />
Pas de frais de port, prix TVA comprise<br />
<br />
<br />
<br />
<br />
Anciennes commandes Subtel.fr archivées [[Projets:Commande_groupee:archives|ici]]<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Subtel!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Archive (O/N)<br />
|-l<br />
|-<br />
|}<br />
<br />
=== raspberry-pi-zero ===<br />
Une opportunité dégotée par Francis: une version du raspberry-pi, un peu spartiate, pour 5 euros!<br />
https://www.raspberrypi.org/blog/raspberry-pi-zero/<br />
<br />
On peut également acheter le kit: http://swag.raspberrypi.org/collections/pi-kits/products/pi-zero-cables<br />
C'est le cordon midi-hdmi/hdmi, PLUSSE la barrette gpio.<br />
<br />
Cette entrée est mise en place alors que tout n'est pas défini pour cet achat: ni le fournisseur (fournisseur initial en rupture de stock), ni le prix.<br />
Mais ce sera le support pour rassembler les commandes. Je tiendrai ce paragraphe à jour selon les infos.<br />
<br />
Le kit comprend l'adaptateur micro-hdmi/hdmi (1 cordon + 1 petit adaptateur?), et la barette 2x20, à souder, pour les gpio. Le raspberry n'est pas dans le kit!<br />
<br />
Le prix: 5 euros le kit, idem le raspberry, et quelques pourcent pour les frais de transport. <br />
<br />
(ce soir: site http://swag.raspberrypi.org/ down; ??)<br />
<br />
<br />
On peut aussi attendre 3 semaines le temps que cela soit livré directement chez vous et avoir<br />
<br />
- l'adaptateur micro hdmi mâle- hdmi femelle : http://www.banggood.com/Gold-Plated-Micro-HDMI-Type-D-Male-To-HDMI-Female-Adapter-p-974265.html<br />
<br />
- un adaptateur micro-hdmi vers VGA femelle sans le son : http://www.banggood.com/1080P-HDMI-Male-To-VGA-Female-Adapter-Video-Converter-Cable-p-937626.html<br />
<br />
- un adaptateur micro-hdmi vers VGA femelle avec le son : http://www.banggood.com/Sin-Hon-SH-MH2V02-Micro-HDMI-to-VGA-Cable-Adapter-with-Audio-p-907524.html<br />
<br />
- un adaptateur micro usb coudé(pratique pour ranger sur le côté : http://www.banggood.com/Micro-USB-Host-OTG-Cable-For-Samsung-HTC-p-79909.html<br />
<br />
- pour se faire une prise alim micro usb, on déboîte le capot et on soude : http://www.banggood.com/USB-2_0-Micro-B-Male-to-Mini-B-Female-5-Pins-Adapter-p-956044.html<br />
<br />
- toutes sortes d'alim : http://www.banggood.com/search/usb-2a-charger.html<br />
<br />
- de quoi s'amuser avec les GPIO : http://www.banggood.com/search/gpio-raspberry/1091-0-0-0-0-0-0-price-0-0_p-1.html<br />
<br />
Et si vous avez le temps de chercher c'est encore moins cher sur http://fr.aliexpress.com/<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| raspberry ou kit !! class="unsortable"| Quantité !! class="unsortable"| Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Archive (O/N)<br />
|-l<br />
|-<br />
!Pierre Grommit !!raspb !! 2 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!Pierre Grommit !!kit !! 1 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!Francis Roussel !!rasp !! 2 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!papy F1CHF !!kit !! 4 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!PDA !!rasp !! 3 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!yvs Accard !!rasp !! 3 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!yvs Accard !!Kit !! 1 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!Malek H. !!3 rasp + 2 vga son + 1 gpio + 1 otg !! 1 !! 1 !! n!! n !!n !! n!!<br />
<br />
<br />
|}<br />
<br />
<br />
=== Starterkit FPGA Altera Max10 ===<br />
'''COMMANDE CLOSE'''<br />
<br />
[https://www.arrow.com/en/products/bemicromax10/arrow-development-tools#page-1 Carte de démarrage FPGA] qui sera parfait pour les [[Formations#Initiation_.C3.A9lectronique_num.C3.A9rique_et_FPGA|formation initiation à venir]].<br />
<br />
Cette carte utilise un FPGA entrée de gamme MAX 10 de chez Altera. Elle contient tout un tas de périphériques sympa pour débuter.<br />
<br />
A noter que la board intègre une sonde JTAG Altera Blaster II (>200€ dans le commerce, 20€ pour un clone).<br />
<br />
Le prix: $30 le kit, disons donc 30€ (à réajuster à la baisse post commande). <br />
<br />
Date butoir pour la commande: mercredi 6 avril 2016<br />
<br />
Chip principal: MAX® 10 FPGA (10M08DAF484C8G):<br />
* 8,000 LEs (largement de quoi mettre le soft core 32bit Altera & des périphériques confortables)<br />
* 414 Kbit (Kb) M9K memory<br />
* 256 Kbit (Kb) user flash memory<br />
* 2 phase locked loops (PLLs)<br />
* 24 18x18-bit multipliers<br />
* 1 ADC block – 1 MSa/sec, 12-bit, 18-channels<br />
* 17 analog inputs<br />
* 1 temperature sense diode<br />
* 250 general purpose input/output (GPIO)<br />
* Non-volatile self-configuration with dual-boot support<br />
* Clocking circuitry: 50 MHz oscillator and 24 MHz oscillator<br />
* achetable à l'unité (moins cher de la gamme: 3€, celui ci, 30€)<br />
<br />
External peripherals<br />
* 8MB SDRAM (4Mb x 16) (ISSI IS42S16400)<br />
* Accelerometer, 3-Axis, SPI interface (Analog Devices ADXL362)<br />
* DAC, 12-bit, SPI interface (Analog Devices AD5681)<br />
* Temperature sensor, I2C interface (Analog Devices ADT7420)<br />
* Thermal resistor<br />
* Photo resistor<br />
* 8 user LEDs<br />
* 2 user Pushbuttons<br />
<br />
Prototyping<br />
* Two 6-pin PMOD expansion headers<br />
* Two 40-pin prototyping headers which provide access to 64 digital I/O<br />
* 6 analog inputs<br />
* One 80-pin BeMicro card edge connector<br />
<br />
<br />
Merci d'ajouter votre nom et votre rapport à l'éventualité de formations au lab:<br />
* débutant, intermédiaire, expert: sous entendu je veux assister à une formation & j'ai ce niveau<br />
* formateur: je suis volontaire pour participer à l'élaboration de formations<br />
* pas intéressé: ni en participant ni en formateur<br />
<br />
Merci d'indiquer:<br />
* combien vous en achetez à titre perso (30€ pièce, à revoir selon le change & port)<br />
* si vous voulez en prendre une à offrir aux formations du lab (vous payez 20€, moi 10€ ; il nous faut 10 cartes)<br />
<br />
<br />
'''MISE A JOUR RECEPTION'''<br />
Prix total 40€/carte. 25€ par carte offerte au lab. Merci de vous mettre à jour, et venez récupérer vos cartes auprès de Coline :)<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Formation? !! class="unsortable"| Quantité !! class="unsortable"| cadeau au lab !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Archive (O/N)<br />
|-l<br />
|-<br />
|-<br />
!flax !!formateur!! 1 !! non !! O!! n !!n !! n!!<br />
|-<br />
!flax !!formateur!! 1 !! oui !! O!! n !!n !! n!!<br />
|-<br />
!Clem !!formateur!! 1 !! N/A !! O!! n !!n !! n!!<br />
|-<br />
!3dsman!!débutant !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
!3dsman!!débutant !! 1 !! oui !! n!! n !!n !! n!!<br />
|-<br />
!Yann D!!débutant !! 2 !! non !! n!! n !!n !! n!!<br />
|-<br />
!Yannick A.!!formateur !! 1 !! oui !! n!! n !!n !! n!!<br />
|-<br />
!Yannick A.!!formateur !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
!F1HSU!!débutant !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
!Roul!!formateur? !! 1 !! oui !! n!! n !!n !! n!!<br />
|-<br />
!Roul!!formateur? !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
!Jojo du VoLAB !!intermédiaire !! 2 !! non !! n!! n !!n !! n!!<br />
|-<br />
!Jojo du VoLAB !!intermédiaire !! 1 !! oui !! n!! n !!n !! n!!<br />
|-<br />
!MrPozor !!débutant !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
!Julien Len!!débutant !! 1 !! oui? !! n!! n !!n !! n!!<br />
|-<br />
!Julien Len!!débutant !! 1 !! non!! n!! n !!n !! n!!<br />
|-<br />
!Jérôme Loï!! débutant !! 1? !! oui !! O(payé 30)!! n !!n !! n!!<br />
|-<br />
!Jérôme Loï!! débutant !! 1 !! non!! O!! n !!n !! n!!<br />
|-<br />
!Moala!!débutant !! 1 !! non !! O!! n !!n !! n!!<br />
|-<br />
!Desty!!debutant !! 1 !! oui !! n!! n !!n !! n!!<br />
|-<br />
!Desty!!debutant !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
<br />
!Votre nom!!type !! nombre !! oui/non !! n!! n !!n !! n!!<br />
<br />
<br />
<br />
|}<br />
Nombre de cartes total: 23 dont lab: 8 (total à mettre à jour !)</div>Erichttps://wiki.electrolab.fr/Projets:Commande_groupeeProjets:Commande groupee2020-06-06T11:23:23Z<p>Eric: /* Mouser Electronics */</p>
<hr />
<div>=Commandes groupées=<br />
<br />
== Principe ==<br />
Tout projet a régulièrement besoin de matières premières, composants, fournitures diverses, etc. Le lab a en stock une quantité importante de fournitures plus ou moins courantes, mais cela ne peut remplacer des commandes régulières.<br />
<br />
Histoire de mutualiser les bons plans & regrouper les frais de port, profiter de divers price breaks, etc, cette page a été créee pour organiser des commandes groupées.<br />
<br />
== Glossaire ==<br />
===Demandeur===<br />
Celui qui a besoin d'un article<br />
<br />
===Acheteur===<br />
Celui qui passe effectivement la commande chez le Fournisseur. L'Acheteur peut être le lab ou une personne privée.<br />
Dans le cas du lab indiquer dans la colonne "acheteur" lab_<nom/pseudo membres> exemple : lab_peewee<br />
Sauf avis contraire, le paiement est à effectuer sur le compte paypal du lab.<br />
<br />
Dans le cas d'une personne privée, indiquer dans la colonne "acheteur", son nom ou pseudo.<br />
L'Acheteur définit lui même les moyens de paiement à utiliser par les <demandeurs>.<br />
<br />
<br />
===Distributeur===<br />
Fournisseur ou fabricant chez qui l'<acheteur> passe commande.<br />
Chaque <distributeur> dispose d'une rubrique propre.<br />
<br />
Il est bien entendu possible d'ajouter des <distributeurs> supplémentaires (notez qu'ils sont triés par '''ordre alphabétique''').<br />
<br />
== Règles du jeu ==<br />
<br />
En général, lorsque l'on s'occupe d'un "group buy", on fait un premier tour de<br />
table pour savoir qui est partant, on annonce ensuite le prix de l'addition<br />
générale (TTC et frais d'expé avec ou sans assurance, éventuels frais de<br />
dédouanement) divisée par le nombre de participants (au prorata des volumes<br />
de commande : celui qui achète 2 items paye 2 parts de frais de port par<br />
exemple).<br />
<br />
Ceci fait, on attend qu'une "masse critique" soit atteinte lorsque l'on vise<br />
certains "price break" (décollonage en jargon de vendeur), puis on lance<br />
l'appel aux fonds avec une date butoir. Passé la date butoir, la commande<br />
est passée, en ignorant ceux qui n'ont pas répondu a temps, puisque le<br />
responsable de group buy n'a pas la trésorerie correspondant à l'achat en<br />
question.<br />
Les histoires genre "le chèque est au courrier" ne marchent pas avec des<br />
virements Paypal... le patron des achats sait exactement combien il a en<br />
caisse au moment de la commande.<br />
<br />
En cas de perte de colis, le responsable de "group buy" n'est pas<br />
redevable. C'est à chaque participant d'estimer s'il prend le risque ou non<br />
de faire confiance aux entreprises assurant l'acheminement des colis.<br />
C'est simple, et si c'est précisé, aucun conflit n'est à redouter, aucun lot<br />
ne reste sur les bras de l'<acheteur>.<br />
<br />
Pour le paiement par avance, celui-ci peut se faire au lab, mais c'est TTC et AVEC les frais de port et de douane, le cas échéant.<br />
<br />
Si un <demandeur> commande la mauvise référence, c'est pour sa pomme.<br />
<br />
Dans la mesure du possible, les <demandeur> doivent faciliter au maximum le travail des <acheteur> en indiquant des références d'articles et de désignation claires.<br />
<br />
==Mode opératoire lorsqu'on passe une commande chez l'un des distributeurs ==<br />
Les tableaux ci-après (un tableau par <distributeur> disposent des colonnes nécessaires à la synchronisation des commandes article par article.<br />
<br />
De même, chaque rubrique dispose d'un en-tete d'information qui a la structure suivante :<br />
<br />
La prochaine commande a pour référence interne : YY_xxx<br />
Commande livrée en cours de distribution : [aucune]<br />
Anciennes commandes <nom du distributeur> archivées [[Projets:Commande_groupee:archives|ici]]<br />
< informations complémentaires notamment en ce qui concerne les conditions de livraison, etc>''<br />
<br />
YY est un code fixe, unique pour chaque founisseur.<br />
<br />
xxx un le n° de commande pour ce distributeur. Il commence à 001 et s'incrémente à chaque commande.<br />
<br />
<br />
===Les différentes étapes de la commande ===<br />
<br />
====Prise en charge d'un commande par un <acheteur>==== <br />
La personne qui souhaite prendre en charge une commande chez un <distributeur> envoie un mail sur la ML pour informer tout le monde de cette action.<br />
Dans l'entête d'information du <distributeur> concerné, l'<acheteur> effectue les modifications suivantes :<br />
*mise à jour de la ligne ''Prochaine date de commande'' : valorisé à la date à laquelle il envisage de passer la commande auprès du <distributeur>. <br />
<br />
À ce moment, l'ensemble des <demandeurs> concernés se met en relation avec l'<acheteur> pour lui payer d'avance les articles commandés. Pour ces articles, l'<acheteur> fait les modifications suivantes dans le tableau des articles :<br />
*''Payé d'avance (O/N)'' : valorisé à "O" (Oui)<br />
<br />
<br />
====Passage effective de la commande par l'<acheteur>==== <br />
<br />
Celui qui passe la commande ( = <acheteur>) sélectionne les articles qu'il commande effectivement (= ceux pour lesquels il a reçu le paiement en avance). Il peut aussi inclure dans la commande des articles de <demandeurs> pour leuquel il est certain d'être payé au moment de la distribution.<br />
<br />
L'<acheteur> passe la commande auprès du distributeur (par internet, mail, téléphone, télécopie, signaux de fumée, déplacement sur place...) et effectue le paiement à l'aide d'un moyen de paiement à sa convenance. Il est judicieux de priviléger des moyens de paiement fournissant la traçabilité de la transaction.<br />
<br />
Pour les articles effectivement COMMANDÉS l'<acheteur> fait les modifications suivantes dans le tableau des articles :<br />
*'' Acheteur'' : valorisé par son nom/pseudo <br />
*''Commandé (O/N)'' : valorisé à "O" (Oui)<br />
<br />
Pour les articles qui n'ont pas déja été concernés par une commande précédente et que l'<acheteur> ne COMMANDE PAS (par exemple par ce que le <demandeur> ne s'est pas manifesté auprès de lui), il fait les modifications suivantes dans le tableau des articles :<br />
*''N° de commande'' : est incrémenté d'une unité afin que cet article non commandé soit inclus dans la prochaine commande.<br />
<br />
<br />
*mise à jour de la ligne ''Prochaine date de commande'' : valorisé à <non défini><br />
*mise à jour de la ligne ''La prochaine commande a pour référence interne'' : valorisé au numéro de commande interne actuel +1 <br />
*mise à jour de la ligne ''Commande passée en attente de livraison'': valorisé au n° de commande actuel<br />
<br />
====Réception de la commande par l'<acheteur>==== <br />
<br />
<br />
Au moment de la réception du colis, l'<acheteur> vérifie si la livraison est complète et négocie avec le <distributeur> en cas de problème. Il peut aussi informer le <demandeur> concerné par le ou les article(s) en litige ou manquants.<br />
<br />
====Distribution des articles aux <demandeurs>====<br />
Lorsque la distribution peut commencer l'<acheteur> effectue les modifications suivantes dans l'entête d'information du <distributeur> concerné :<br />
*mise à jour de la ligne : '' Commande passée en attente de livraison'' à [aucune]<br />
*mise à jour de la ligne : '' Commande livrée en cours de distribution '' avec la référence interne de la commande.<br />
<br />
L'<acheteur> informe via la ML les <demandeurs> du début de la distribution de la commande <référence interne de commande>.<br />
Chaque <demandeur> convient d'un RDV avec l'<acheteur> pour récupérer les articles (en principe cela se passe au lab) et payer son dû à l'<acheteur>, si ce n'est déja fait.<br />
<br />
Pour chaque article l'<acheteur> fait les modifications suivantes dans le tableau des articles :<br />
*'' Distribué (O/N)'' : valorisé à "O" (Oui) <br />
*''Remboursé/Archivé (O/N)'' : valorisé à "O" (Oui)<br />
<br />
====Ditribution des articles terminée====<br />
<br />
Une fois l'ensemble des pièces distribuées et payées, dans l'entête d'information du <distributeur> concerné, l'<acheteur> effectue les modifications suivantes :<br />
*mise à jour de la ligne ''Commande livrée en cours de distribution'' : valorisé à [aucune]<br />
<br />
<br />
===En conclusion ===<br />
<br />
Si les tableaux des commandes et les en-tête d'information sont gérés avec soin, il n'y a quasiment aucun risque de double commande et n'importe quel membre sait où on en est et peut à tout moment prendre la main sur l'un des tableaux d'achats pour commander un article ou organiser une commande en tant qu'<acheteur>. La bonne application de ces quelques recommandation bénéficie à l'ensemble des participants de ce système de commandes groupées.<br />
<br />
Sauf besoin urgent de pièces, il est bénéfique que ce soit de préférence les mêmes <acheteurs> qui officient auprès des mêmes <distributeurs>. Ainsi, vu de ces derniers, l'<acheteur> est très vite identifié comme "client important" (car en réalité il commande pour 5-10 personnes, voire plus) et peut bénéficier de conditions particulières (frais de port gratuit, -15% sur la prochaine commande, etc).<br />
<br />
Enfin, à tout moment en tant que <demandeur>, soyez diligent envers l'<acheteur> dont la gestion d'une commande de parfois plusieurs dizaines d'articles requert un investissement en temps non négligeable.<br />
<br />
== Commandes groupées passées (archives) ==<br />
<br />
Afin d'améliorer la lisibilité nous avons regroupé les commandes passées sur cette page: [[Projets:Commande_groupee:archives]]<br />
<br />
== Commandes groupées en cours ==<br />
<br />
=== BHV ===<br />
<br />
La prochaine commande a pour référence interne : BH_003<br />
<br />
<br />
<br />
<br />
Anciennes commandes BHV archivées [[Projets:Commande_groupee:archives#BHV|ici]]<br />
<br />
achat sur place<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref BHV!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| Lab|| Réglet métallique 30cm || - || 3 || 5.90€||Eric|| BH_001 || N || O || O || O<br />
|-<br />
|-<br />
| Lab|| Scie a métaux FACOM 603E || - || 1 || env. 36€||Eric|| BH_002 || N || O || 0 || O<br />
|-<br />
|}<br />
<br />
=== [http://www.visseriefixations.fr/ Cergy-Vis] ===<br />
<br />
<br />
La prochaine commande a pour référence interne : CV_002<br />
<br />
<br />
<br />
<br />
Anciennes commandes Cergy-Vis archivées [[Projets:Commande_groupee:archives|ici]] <br />
<br />
Retrait gratuit sur place<br />
CERGY-VIS<br />
<br />
17, Rue du Périgord<br />
<br />
ZI des Béthunes<br />
<br />
95310 SAINT OUEN L’AUMONE<br />
<br />
<br />
Horaires pour les enlèvements: Du Lundi au Vendredi, de 7h30 à 12h00 et de 13h30 à 17h30.<br />
<br />
<br />
Livraison<br />
Colissimo Régional (0.05kg / France) 5,75 €<br />
<br />
Colissimo Régional (0.2888kg / France) 6,54 €<br />
<br />
Colissimo Régional (2.87kg / France) 9,25 €<br />
<br />
Colissimo Régional (12.8948kg / France) 16,50 €<br />
<br />
Anciennes commandes Cergy-Vis archivées [[Projets:Commande_groupee:archives#Cergy-Vis|ici]]<br />
<br />
<br />
|-<br />
!Demandeur !! class="unsortable"| Description !! Référence!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-<br />
||Eric|| TRCC M5X30 INOX A2 DIN 603|| ||50||0.17EURTTC||<acheteur>||CV_001||N||O||O||N (attends remb. trop versé)<br />
|-<br />
||Eric|| ECROU HU M12 PAS 100 Z.BLANC DIN 934|| ||20||0.39EURTTC||<acheteur>||CV_001||N||O||O||N (attends remb. trop versé)<br />
|-<br />
||Eric||Vis TCHC M5X22 INOX A2 EF DIN 912||TCHC05/022A2EF||15||0.12EURTTC||<acheteur>||CV_002||N||N||N||N<br />
|-<br />
||Eric||Vis STHC PLAT M6X12 INOX A2 DIN 913||STHCPLA06/012A2||30||0.06EURTTC||<acheteur>||CV_002||N||N||N||N<br />
|-<br />
||Eric||Vis TH M6X12 INOX A2 EF DIN 933||TH06/012A2EF||30||0.09EURTTC||<acheteur>||CV_002||N||N||N||N<br />
|-<br />
|}<br />
<br />
=== [http://www.conradpro.fr Conrad Electronique France] ===<br />
<br />
<br />
La prochaine commande aura pour référence interne : CO_017<br />
<br />
Prochaine date de commande :<br />
<br />
Commande passée en attente de livraison : NEANT<br />
<br />
Commande livrée en cours de distribution : NEANT<br />
<br />
Anciennes commandes Conrad Electronique France archivées [[Projets:Commande_groupee:archives#Conrad Electronique France|ici]]<br />
<br />
{| class="wikitable sortable" style="font-size:85%"<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Conrad!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€ ||<Acheteur>|| CO_XXX || N || N || N || N<br />
|-<br />
--><br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/822746/Fil-de-soudure-pour-PVC-rigide-Steinel-073114-26-pcs Fil de soudure pour PVC rigide Steinel 073114 26 pcs]</s>||<s>822746 - 62 </s>||<s> 1 </s>||<s> € 5.99 TTC</s>||<s><acheteur> </s>||<s> CO_014 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/492161/Soudure-plastique-225-mm-4-mm-polythylne-LDPE-nature-Bosch-1609201811 Soudure plastique, 225 mm, 4 mm, polyéthylène (LDPE) nature Bosch 1609201811]</s>||<s>492161 - 62 </s>||<s> 1 </s>||<s> € 15.99 TTC</s>||<s> <acheteur> </s>||<s> CO_014 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/121588/Solution-de-conservation-pour-electrodes-de-mesure-pH-HI-70300M Solution de conservation pour électrodes de mesure pH HI 70300M]</s>||<s>121588 - 62 </s>||<s> 1 </s>||<s> € 15.12 TTC</s>||<s> <acheteur> </s>||<s> CO_014 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/121586/Solution-de-nettoyage-pour-electrodes-pH-HI-7061M Solution de nettoyage pour électrodes pH HI 7061M]</s>||<s>121586 - 62 </s>||<s> 1 </s>||<s> € 15.12 TTC</s>||<s> <acheteur> </s>||<s> CO_014 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|Eric||[http://www.conrad.fr/ce/fr/product/121164/Sol-de-conduct-12880-S-HI-70030-P Sol. de conduct. 12880 µS HI 70030 P]||121164 - 62 || 1 || € 38.30 TTC|| <Pat> || CO_014 || N || O || O || O<br />
|-<br />
|Eric||[http://www.conradpro.fr/ce/fr/product/822188/Knipex-Pinces-pour-circlips-pour-colliers-dtranglement-darbre-46-11-G0-140-mm?ref=searchDetail Pince KNIPEX 46 11 G0]||822188 - 62 || 1 || € 20.13 HT|| <Pat> || CO_014 || N || O || O || O<br />
|-<br />
|Eric||[http://www.conradpro.fr/ce/fr/product/822189/Knipex-Pinces-pour-circlips-pour-colliers-dtranglement-darbre-46-11-G1-140-mm?ref=searchDetail Pince KNIPEX 46 11 G1]||822189 - 62 || 1 || € 13.02 HT|| <Pat> || CO_014 || N || O || O || O<br />
|-<br />
|MrPozor||[http://www.conrad.fr/ce/fr/product/702246/Interrupteur-de-porte-Panasonic-AZC11113HJ-250-VAC-5-A-poussoir-momentan-IP40-1-pcs?ref=searchDetail Interrupteur de porte Panasonic AZC11113HJ]||702246 - 62 || 1 || € 10.99 TTC|| <Pat> || CO_014 || N || O || N || N<br />
|-<br />
| papy F1CHF || 74HC390 SOIC || 1115010-62 || 10 || 1.06€ ||<Pat>|| CO_014 || O || O || O || O<br />
|-<br />
| Pat|| Condo moteur 5uF 450V || 441527-62 || 1 || 6.33€ H.T. ||<Pat>|| CO_014 || O || O || N || N<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/731484/Adaptateur-avec-fiche-dor-32-A-rouge-MultiContact-240160-22 Adaptateur avec fiche doré 32 A rouge MultiContact Ref. 24.0160-22]|| 731484 - 62 || 2 || 3.00 € H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/731559/Disque-de-marquage-couleur-MultiContact-145010-vert-jaune-1-pcs Disque de marquage couleur MultiContact Ref. 14.5010 vert-jaune 1 pc(s)]|| 31559 - 62 || 3 || 0.75 € H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/106109/Pointe-de-touche-de-scurit-MultiContact-XMA-7L-enfichable-4-mm-CAT-IV-1000-V-bleu Pointe de touche de sécurité MultiContact XMA-7L enfichable 4 mm CAT IV 1000 V bleu Ref. MC 66.9509-23]|| 106109 - 62 || 1 || 15.96 € H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/106108/Pointe-de-touche-de-scurit-MultiContact-XMA-7L-enfichable-4-mm-CAT-IV-1000-V-rouge Pointe de touche de sécurité MultiContact XMA-7L enfichable 4 mm CAT IV 1000 V rouge Ref. MC 66.9509-22]|| 106108 - 62 || 1 || 15.96 € H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/106107/Pointe-de-touche-de-scurit-MultiContact-XMA-7L-enfichable-4-mm-CAT-IV-1000-V-noir Pointe de touche de sécurité MultiContact XMA-7L enfichable 4 mm CAT IV 1000 V noir Ref. MC 66.9509-21]|| 106107 - 62 || 1 || 15.96 € H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/1385649/Pince-crocodile-4-mm-GRIP-FMA-MultiContact-669435-21 Pince crocodile 4 mm GRIP-FMA MultiContact Ref. 66.9435-21]|| 1385649 - 62 || 1 || 30.00€ H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Damien H || MOSFET RFD14N05L || 512-RFD14N05L || 5 || 0,695 € ||?|| CO_015 || N || O || O || O<br />
|-<br />
| Damien H || Zener BZX79C2V4 || 512-BZX79C2V4 || 5 || 0,11 € ||?|| CO_015 || N || O || O || O<br />
|-<br />
|Pierre G|| Câble audio SpeaKa 1m mf||986736 - 62 || 2||6,66 ht || ? || CO_015 || N || O || O || O<br />
|-<br />
|Pierre G|| Câble audio SpeaKa 0,50m mf||986735 - 62 || 1||5.92 ht || ? || CO_015 || N || O || O || O<br />
|-<br />
|Pierre G|| Lentille Dialight OPC-11SPOT transparent 10 ° 1 pc(s)||1127266 - 62 || 1||3 ht || ? || CO_016 || N || O || O || O<br />
|-<br />
|Pierre G|| LED High Power Barthelme 61003528 blanc chaud||1503528 - 62 || 1||3,50 ht || ? || CO_016 || N || O || O || O<br />
|-<br />
|FredericD|| [http://www.conrad.fr/ce/fr/product/574223/Transformateur-electronique-Standard-10-a-60-W Transformateur électronique "Standard" 10 à 60 W]||574223 - 62 || 1||15,49 '''TTC''' || <acheteur> || CO_017 || N || N || N || N<br />
|-<br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/542044/?insert=32&insertNoDeeplink&productname=Gaine-thermoretractable-pour-batteries-sans-colle-21-Conrad-Components-542044-transparent-avant-retreint-44-mm-1-pc Gaine thermorétractable 2:1 transparente pour accus longueur 100 cm largeur 44mm]</s>||<s>542044 - 32</s>||<s>3</s>||<s>2,70€TTC</s>||<s> <acheteur> </s>||<s> CO_017 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/100297/Solution-conductrice-1413-S-HI-70031-P?ref=list Solution conductrice 1413 µS HI 70031 P]</s>||<s>100297 - 62 </s>||<s> 1 </s>||<s> € 33,60 TTC</s>||<s> <acheteur> </s>||<s> CO_017 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|<s>Eric</s>||<s>[http://www.conradpro.fr/ce/fr/product/1305022/Diode-Zener-PanJit-1N4740A-G-DO-41G-Tension-Zener-10-V-1-pcs?ref=searchDetail Diode Zener PanJit 1N4740A-G DO-41G Tension Zener: 10 V]</s>||<s>1305022 - 62 </s>||<s> 10 </s>||<s> € 0,15 TTC</s>||<s> <acheteur> </s>||<s> CO_017 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/812811/tain-de-soudure-teneur-en-plomb-Stannol-HS-10-Sn60Pb39Cu1-bobine-100-g-10-mm?queryFromSuggest=true étain 100g 1mm STANNOL]|| 812811 - 62 || 2 || 7,55 € H.T. ||<acheteur>|| CO_017 || N || N || N || N<br />
|-<br />
|Eric||[http://www.conrad.fr/ce/fr/product/651105/XLR-Bride-mle-contacts-couds-Neutrik-NC3MAAH-Nombre-de-ples-3-noir-1-pcs?queryFromSuggest=true Connecteur XLR mâle plastique pour chassis soudage pour CI 3 broches coudé + blindage, NEUTRIK NC3MA(A)H ]||651105 - 62|| 2 || 1,20€TTC ||<acheteur>||CO_017||N||N||N||N <br />
|-<br />
|}<br />
<br />
Anciennes commandes Conrad archivées [[Projets:Commande_groupee:archives#Conrad_Electronique_France|ici]]<br />
<br />
=== [http://www.damencnc.com/fr DamenCNC] ===<br />
<br />
Accessoires pour machines CNC [http://www.damencnc.com]<br />
<br />
La prochaine commande a pour référence interne : DC_002<br />
<br />
Prochaine date de commande : ?? (probablement en octobre 2014)<br />
<br />
<br />
<br />
Livraison : depuis les Pays-Bas par UPS : estimation : 20€ pour un colis de 1.5kg<br />
<br />
ATTENTION : Prix HT.<br />
<br />
Anciennes commandes DamenCNC archivées [[Projets:Commande_groupee:archives#DamenCNC|ici]]<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref DamenCNC!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||<Acheteur>|| OT_XXX || N || N || N || N<br />
|-<br />
--><br />
|-<br />
|Goldo|| HIWIN HGR Profile Rail L=200mm || HG15R || 2 || 21,60€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|Goldo|| HIWIN Carriage HGH "Compact type" || HGH-15CA || 2 || 33.99€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|Goldo|| Mini Mill 2 flutes 0.20mm || ? || 1 || 11.99€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|Goldo|| Mini Mill 2 flutes 0.30mm || ? || 1 || 11.99€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|Goldo|| Mini Mill 2 flutes 0.50mm || ? || 1 || 9.99€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|Goldo|| Kress Collet + Clamp Nut 1/8inch || ? || 1 || 19.99€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|F1CHF|| Mini Mill 2 flutes 0.50mm || ? || 2 || 9.99€HT || Goldo || DC_001 || N || O || O || O<br />
|-<br />
|F1CHF|| Mini Mill 2 flutes 0.70mm || ? || 2 || 9.99€HT || Goldo || DC_001 || N || O || O || O<br />
|-<br />
|Eric||IPS_Cable_Assembly M12_Straight_Female/OPENEND_3meter || ? || 2 || 4.99€HT || <acheteur>|| DC_002 || N || N || N || N<br />
<br />
|}<br />
<br />
===[http://www.detandt.com/fr Detandt-Simon]===<br />
<br />
La prochaine commande aura pour référence interne : DET_001 <br />
<br />
Prochaine date de commande : Mardi 2/2/2016<br />
<br />
<br />
Commande livrée en cours de distribution : [nada] <br />
<br />
Anciennes commandes Detandt archivées [nope]<br />
<br />
Frais de livraisons: inconnu<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Taille !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!!Remboursé/Archive (O/N)<br />
|-<br />
<!-- Pour ajouter une ligne, copier les 2 lignes suivantes (celles qui commencent par | ) à la suite du tableau et remplacer le contenu des colonnes par ce qui semblera adéquat--><br />
| Steve|| Modèle haut Bleu et gris || Taille 44 || 1|| 15€ HT||Steve|| DET_001 || N || N || N || N<br />
|-<br />
| Steve|| Modèle haut Bleu et gris || Taille 45 || 1|| 15€ HT||Steve|| DET_001 || N || N || N || N<br />
|-<br />
| Laurent d. Lo^2 || Modèle haut orange et noir || Taille 44 || 1|| 15€ HT||Laurent|| DET_001 || N || N || N || N<br />
|-<br />
| Laurent d. Lo^2 || Modèle cuir noir || Taille 44 || 1|| 15€ HT||Laurent|| DET_001 || N || N || N || N<br />
|-<br />
| Beatrice/LK999 || Modèle cuir noir ou bas || Taille 45|| 1|| 15€ HT||XXX|| DET_001 || N || N || N || N<br />
|-<br />
| Le Xav || Modèle noir & orange haut || Taille 45|| 1|| 15€ HT||XXX|| DET_001 || N || N || N || N<br />
|-<br />
| Patrick|| 10m gaine VMC alu D80 M0|| HALUM0 82|| 2|| 13,78€ HT||XXX|| DET_002 || N || N || N || N<br />
|-<br />
| Patrick|| 10m gaine VMC alu D125 M0|| HALUM0 127|| 1|| 15,96€ HT||XXX|| DET_002 || N || N || N || N<br />
|-<br />
|}<br />
<br />
===[http://www.digikey.com/ Digikey Corporation]===<br />
<br />
La prochaine commande aura pour référence interne : DI_006<br />
<br />
<br />
Commande passée en attente de livraison : DI_005 <br />
<br />
Commande livrée en cours de distribution : NEANT <br />
<br />
Anciennes commandes Digikey Corporation archivées [[Projets:Commande_groupee:archives#Digikey Corporation|ici]]<br />
<br />
"PAS DE FRAIS POSTAUX sur toutes commandes avec une valeur de 65 Euro et plus.mais la DOUANE + frais"<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Digikey !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!!Remboursé/Archive (O/N)<br />
|-<br />
| Laurent(C) || Capa 470uF || 493-1493-ND || 24 || 0,229€||Laurent(C)|| DI_005 || || O || N || N<br />
|-<br />
| Laurent(C) || Carte NUCLEO-F303K8 || 497-15981-ND || 1|| 9,92€||Laurent(C)|| DI_005 || || O || N || N<br />
|-<br />
| Laurent(C) || Capa tantale 10uF || 478-8959-1-ND || 5|| 0.8€||Laurent(C)|| DI_005 || || O || N || N<br />
|-<br />
| Laurent(C) || PMIC 4V || MCP1702T-4002E/CBCT-ND|| 5|| 0.43€||Laurent(C)|| DI_005 || || O || N || N<br />
|-<br />
| Eric||[http://www.digikey.fr/product-search/fr?vendor=0&keywords=LT1677CS8%23PBF-ND LT1677 OPAMP S8 Package]|| LT1677CS8#PBF-ND || 4|| 3.95€||Laurent(C)|| DI_005 || O || O || N || N<br />
|-<br />
| Eric|| [http://www.digikey.com/product-detail/en/4664-6001/MPK64K-ND/138341 connecteur HE10 64 broches autodénudant mâle] || MPK64K-ND || 1|| 12.59€||Laurent(C)|| DI_005 || O || O || O || O<br />
|-<br />
| Eric|| [http://www.digikey.fr/product-detail/fr/DS2740U%2B/DS2740U%2B-ND/1197488 MAXIM coulombmetric counter DS2740U+ SMD]|| DS2740U+-ND || 1|| 3.90€||Laurent(C)|| DI_005 || O || O || O || O<br />
|-<br />
| Eric|| C190 case ||614-1102-ND||1||199,99USD||Laurent(C)|| DI_005 || O || N(export restriction!) || N || O<br />
|-<br />
| papy F1CHF || NB3N502 || NB3N502DGOS-ND ||4||2.99€||Laurent(C)|| DI_005 || N || O || O || O<br />
|-<br />
| Eric|| [http://www.digikey.com/product-detail/en/linear-technology/LT1763CS8-TRPBF/LT1763CS8-TRPBFCT-ND/4247570 LT1763CS8#TRPBF LT micropower low noise LDO ADJ regulator 500MA SO8]|| LT1763CS8#TRPBFCT-ND || 1|| 4.78USD||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| Eric|| [http://www.digikey.com/product-detail/en/linear-technology/LT1763CS8-3.3-TRPBF/LT1763CS8-3.3-TRPBFCT-ND/4247566 LT1763CS8-3.3#TRPBF LT micropower low noise LDO 3.3V regulator 500MA SO8]|| LT1763CS8-3.3#TRPBFCT-ND|| 2|| 4.78USD||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| Eric|| [http://www.digikey.fr/products/fr?keywords=BA5406 BA5406 Amplifier IC 2-Channel (Stereo) Class AB 12-SIP-M] ||BA5406-ND || 1|| 3.85 EUR||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| Eric|| [https://www.digikey.fr/products/fr?keywords=HR1732-ND HIROSE CONN PLUG 5POS W/PIN INSERT ref "RM12BPE-5PH(71)"] ||HR1732-ND || 1|| 11.19 EUR||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| Eric|| [https://www.digikey.fr/product-detail/fr/infineon-technologies/IRS2453DPBF/IRS2453DPBF-ND/1189713 INFINEON IC DRIVER FULL SELF OSC 14-DIP IRS2453DPBF] ||IRS2453DPBF-ND || 1|| 3.09 EUR||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| 3dsman|| US5881LUA Digital Switch Unipolar Switch Open Drain Hall Effect TO-92UA ||US5881LUA-AAA-000-BU-ND || 5|| 1.10 EUR||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| Debutant|| [https://www.digikey.fr/product-detail/fr/jst-sales-america-inc/SYF-001T-P0.6-LF-SN/455-2652-1-ND/2796952 JST Sales America Inc. SYF-001T-P0.6(LF)(SN) ] || 455-2652-1-ND || 100|| 0.05460 EUR|| Debutant || DI_006 || N || N || N || N<br />
|-<br />
| Lo2|| [https://www.digikey.fr/product-detail/en/molex-llc/0755860006/WM22014CT-ND/9095459 Molex Connecteur 50POS SMD] || WM22014CT-ND || 3|| 8.47 EUR|| Lo2 || DI_006 || N || N || N || N<br />
|-<br />
<br />
|}<br />
<br />
=== [http://www.doga.fr Doga] ===<br />
<br />
La prochaine commande aura pour référence interne : DO_004<br />
<br />
Prochaine date de commande : [inconnu]<br />
<br />
Commande passée en attente de livraison : [aucune]<br />
<br />
<br />
<br />
Minimum de commande : 50€ HT<br />
Franco : 100€ HT<br />
<br />
Merci de préciser le catalogue dans lequel se trouve l'article pour le retrouver plus aisément. <br />
<br />
Les principaux catalogues sont :<br />
* http://www.doga.fr/catalogue_pdf/ugv.pdf<br />
* http://www.doga.fr/catalogue_pdf/ugv-alliage-leger.pdf<br />
* [https://shop.precitool.de/bk/WKZ_2018-2019/#page_0.1 Precitool (catalogue 'Outillage')]<br />
<br />
Anciennes commandes Doga archivées [[Projets:Commande_groupee:archives#Doga|ici]]<br />
<br />
<br />
|-<br />
!Demandeur !! class="unsortable"| Description !!class="unsortable"| Ref Doga !! class="unsortable"| Catalogue !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!!Remboursé/Archive (O/N)<br />
<br />
<br />
|-<br />
| Eric||[http://shop.precitool.de/bk/HKL_2016-2017/#page_870 Ø 8mm Zylinderbürste mit Öse, Messingdraht gewellt marque : LESSMANN]|| 481772 || Precitool || 1 || 7 EURHT || <acheteur> || DO_002 || N || O || O || O<br />
|-<br />
| <s>Eric</s>||<s>[http://shop.precitool.de/bk/HKL_2015-2016/#page_1044 Kompakt-Bolzenscheider KNIPEX Mit Mehrkomponenten-Hülle, Öffnungsfeder, 20° abgewinkelt]</s>||<s> 559026</s> ||<s> Precitool </s>||<s> 1 </s>||<s> 40.45EURHT</s> ||<s> <acheteur> </s>||<s> DO_002 </s>||<s>N</s> ||<s>N</s>||<s> N </s>||<s> N</s><br />
|-<br />
| Eric||[http://shop.precitool.de/bk/HKL_2016-2017/#page_924 Strinlochschlüssel-Satz marque AMF]|| 506050|| Precitool || 1 || 31.05EURHT || <acheteur> || DO_002 || N || O || O || O<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1116 KNIPEX Montagezange Typ 4521 für Sprengringe auf Wellen (KNIPEX Ref 45 21 200)]||554175 /4521|| Precitool || 1 || 30,75EURHT || <acheteur> || DO_002 || N || O || O || O<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2016-2017/#page_1242 Schneidoel 500ml]||924055|| Precitool || 1 || 14,35EURHT || <acheteur> || DO_002 || N || O || O || O<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2016-2017/#page_1254 Luftweiche 3 Fach (4 x G3/8) Typ 0304]||925805/0304|| Precitool || 2 || 7.05EURHT || <acheteur> || DO_002 || N || O || O || O<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_35 Spiralbohrer HSS-Co Precitool D1897 INOX Dn 2,1mm]||100670/2,10|| Precitool || 5 || 1.91 EURHT || Lab || DO_003 || N || O || O (livré en 2.3mm, puis relivré gratuitement en 2,1mm) || O<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_815 Düsenlehre 0.45-1.5mm (0.05mm steigung)]||389850/20|| Precitool || 1 || 12.65 EURHT || Lab || DO_003 || N || O || O || O<br />
|-<br />
|Steve||[http://shop.precitool.de/bk/HKL_2017-2018/#page_987 Gelenk-Hakenschlüssel]||506350/22-35|| Precitool || 1 || 13.55 EURHT || Lab || DO_003 || N || N || N || N<br />
|-<br />
|Steve||[http://shop.precitool.de/bk/HKL_2017-2018/#page_987 Gelenk-Hakenschlüssel]||506350/35-60|| Precitool || 1 || 14.90 EURHT || Lab || DO_003 || N || N || N || N<br />
|-<br />
|Steve||[http://shop.precitool.de/bk/HKL_2017-2018/#page_987 Gelenk-Hakenschlüssel]||506350/60-90|| Precitool || 1 || 17.70 EURHT || Lab || DO_003 || N || N || N || N<br />
|-<br />
|Lab||[http://shop.precitool.de/bk/HKL_2017-2018/#page_985 Hakenschlüssel aus spezial Stahl Gehärtet und im Brunierton angelassen, pour Ø 95-100 mm, pour écrous DIN 1804 et DIN 981]||506200 95/100|| Precitool || 1 || 10,80 EURHT || Lab|| DO_003 || N || O || O (erreur de reference de commande) || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_985 Hakenschlüssel aus spezial Stahl Gehärtet und im Brunierton angelassen, pour Ø 95-100 mm, pour écrous DIN 1804 et DIN 981]||506200 95/100|| Precitool || 1 || 10,80 EURHT || Lab || DO_003 || N || O || O (erreur de reference de commande) || O<br />
<br />
|-<br />
|Lab||[http://shop.precitool.de/bk/HKL_2017-2018/#page_1153 Jeu de chasse-goupilles - Splintentreiber]|| 561110/6M || Precitool || 1 || 18.05 EURHT || Lab || DO_003 || N || N || N || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Linksausdreher Grosse 1 (für M3-M6)]||590950/1|| Precitool || 3 || 1,35 EURHT || Lab || DO_003 || N || O || O || O<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Linksausdreher Grosse 2 (für M6-M8)]||590950/2|| Precitool || 2 || 1,35 EURHT || Lab || DO_003 || N || O || O || O<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Linksausdreher Grosse 3 (für M8-M11)]||590950/3|| Precitool || 2 || 1,54 EURHT || Lab|| DO_003 || N || O || O || O<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Schaubenausdreher/Linksausdreher "Super Traktion" Grosse T1 (pour Ø 4-5 mm, perçage 2.1 mm)]||590970/T1|| Precitool || 3 || 4.47 EURHT || Lab || DO_003 || N || O || O || O<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Schaubenausdreher/Linksausdreher "Super Traktion" Grosse T2 (pour Ø 5-7 mm, perçage 3.2 mm )]||590970/T2|| Precitool || 3 || 4.58 EURHT || Lab || DO_003 || N || O || O || O<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Schaubenausdreher/Linksausdreher "Super Traktion" Grosse T3 (pour Ø 8-12 mm, perçage 4.5 mm )]||590970/T3|| Precitool || 3 || 5.70 EURHT || Lab || DO_003 || N || O || O || O<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/WKZ_2018-2019/#page_35 Spiralbohrer HSS-Co Precitool D1897 INOX Dn 8,6mm]||100670/8,60|| Precitool || 2 || 7.14 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/WKZ_2018-2019/#page_35 Spiralbohrer HSS-Co Precitool D1897 INOX Dn 8,7mm]||100670/8,70|| Precitool || 2 || 7.14 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/WKZ_2018-2019/#page_35 Spiralbohrer HSS-Co Precitool D1897 INOX Dn 6,4mm]||100670/6,40|| Precitool || 2 || 5,17 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/WKZ_2018-2019/#page_35 Spiralbohrer HSS-Co Precitool D1897 INOX Dn 9,8mm]||100670/9,80|| Precitool || 2 || 9.65 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/WKZ_2018-2019/#page_930 Gelenk-Hakenschlüssel verstellbar, mit Nase, gehärtet und im Brünierton angelassen; für AuBen Ø (Mutter) 20-35 mm]||506300/20-35|| Precitool || 1 || 11.55 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/WKZ_2018-2019/#page_930 Gelenk-Hakenschlüssel verstellbar, mit Nase, gehärtet und im Brünierton angelassen; für AuBen Ø (Mutter) 35-60 mm]||506300/35-60|| Precitool || 1 || 12.35 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/WKZ_2018-2019/#page_930 Gelenk-Hakenschlüssel verstellbar, mit Nase, gehärtet und im Brünierton angelassen; für AuBen Ø (Mutter) 60-90 mm]||506300/60-90|| Precitool || 1 || 16.05 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-class="sortbottom"<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2018-2019/#page_1155 Schaubenausdreher/Linksausdreher "Super Traktion" Grosse T4 (pour Ø 12-14 mm, perçage 6.5 mm )]||590970/T4|| Precitool || 3 || 6.89 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2018-2019/#page_1155 Schaubenausdreher/Linksausdreher "Super Traktion" Grosse T5 (pour Ø 16-20 mm, perçage 8.5 mm )]||590970/T5|| Precitool || 3 || 9.00 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/WKZ_2018-2019/#page_761 Düsenlehre 1.5-3,0mm (0.1mm Steigung)]||389850/16|| Precitool || 1 || 13.55 EURHT || <acheteur>|| DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/WKZ_2018-2019/#page_940 Verlängerung 1/4" Typ 870 Marke : HAZET ]||511186|| Precitool || 1 || 20.50 EURHT || <acheteur>|| DO_004 || N || N || N || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2018-2019/#page_895 Einmaulschlüssel DIN894 SW : 13 mm ]||500602/13|| Precitool || 1 || 1.27 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|}<br />
<br />
=== [http://fr.farnell.com Farnell] ===<br />
<br />
Livraison gratuite au dessus de 30€ HT<br />
<br />
La prochaine commande aura pour référence interne : FA_017<br />
<br />
<br />
Prochaine date de commande : <à définir><br />
<br />
Commande passée en attente de livraison : <aucune><br />
<br />
Anciennes commandes Farnell archivées [[Projets:Commande_groupee:archives#Farnell|ici]]<br />
<br />
|-<br />
| Demandeur || class="unsortable"| Description || Ref Farnell || class="unsortable"| Quantité || class="unsortable"| Prix unitaire || Acheteur || Commande<br/>n° || Payé<br/>d'avance<br/>(O/N)|| Commandé<br/>(O/N)|| Distribué<br/>(O/N)|| Remboursé/<br/>Archive<br/>(O/N)<br />
|-<br />
|-<br />
|-<br />
| Claire Poisson || CD4011BM96 || 2114002 || 15 || 0,313 TTC || 3dsman ||FA_015 ||N ||O ||N ||N<br />
|-<br />
|-<br />
| 3dsman || Câble multiconducteur blindé || 2425036 || 10 || 0,85 TTC || 3dsman ||FA_015 ||N ||O ||N ||N<br />
|-<br />
|-<br />
| Steve (Pour lab/smoothie) || NXP LPC 1769 || 2072199 || 1 || 8,68 TTC || 3dsman ||FA_015 ||N ||O ||O ||N<br />
|-<br />
|-<br />
| Dom (Rude ULM) || Connecteur d'alimentation DC, Mâle, 2 A, 9.5 mm, Montage sur câble, 1.7 mm || 1737255 || 2 || 2.87 TTC || 3dsman ||FA_015 ||N ||O ||N ||N<br />
|-<br />
|-<br />
| Steve || MCP1702T-5002E/MB - Régulateur LDO 5V SOT89-3 || 1605559 || 3 || 0.593 || 3dsman ||FA_015 ||N ||O ||O ||N<br />
|-<br />
|-<br />
| Steve || RELAY, SPDT, 250VAC, 12A || 1714771 || 2 || 2.27E|| 3dsman ||FA_015 ||N ||O ||O ||N<br />
|-<br />
|-<br />
|-<br />
| Steve (Pour lab/smoothie) || LDO LM1117 3.3V || 2323580 || 5 || 0.907 || Ph. Gras||FA_016 ||N ||O ||O ||N<br />
|-<br />
| Eric ||[http://fr.farnell.com/amphenol-sine-tuchel/t-3424-501/fiche-libre-6-voies/dp/1123507 Connecteur 6 broches Amphénol avec serrage baillionnette ref T 3424 501] || 1123507 || 1 || 5,12 || Ph. Gras ||FA_016 ||N ||O ||O ||N<br />
|-<br />
| Eric ||[http://fr.farnell.com/nkk-switches/b18jp/switch-toggle-spdt-0-1a-28vac/dp/2374722?ost=2374722&ddkey=http%3Afr-FR%2FElement14_France%2Fsearch Commutateur 3 positions miniature SPDT, 0.1A, 28VAC On-Off-On NKK Switch ref B18JP ] || 2374722|| 2 || 3,98 EUR || Ph. Gras ||FA_016 ||N ||O ||O ||N<br />
|-<br />
| Ph. Gras||[http://fr.farnell.com/jst-japan-solderless-terminals/phr-2/boitier-2-voies-2mm/dp/3616186 Boîtier de connecteur, Série PH, Embase, 2 Voies, 2 mm, Contacts à sertir Série BPH et SPH ] || 3616186|| 100 || 0,0324 EUR || Ph. Gras||FA_016 ||N ||O ||O ||O<br />
|-<br />
| Ph. Gras||[http://fr.farnell.com/jst-japan-solderless-terminals/sph-002t-p0-5s/contact-0-05-0-22mm-cut-reel/dp/1671245?st=SPH-002T-P0.5S Contact, Série PH, Femelle, Sertissage, 24 AWG, Contacts plaqués étain, Connecteurs PH ] || 1671245|| 250|| 0,0208 EUR || Ph. Gras ||FA_016 ||N ||O ||O ||O<br />
|-<br />
| Ph. Gras||[http://fr.farnell.com/on-semiconductor/lm317ahvt/regulateur-ldo-ajustable-1-5a/dp/1564497?st=lm317LM317AHVT Régulateur de tension positive ajustable 1.2V à 37V, 1.5A en boîtier TO-220-3 ] || 1564497|| 10|| 0,727 EUR || Ph. Gras ||FA_016 ||N ||O ||O ||O<br />
|-<br />
|-<br />
|-<br />
| <demandeur> ||[http://wiki.electrolab.fr/Projets:Commande_groupee#Glossaire <article>] || <fa_cde_nb> || <quantité> || <prix> || <acheteur> ||FA_017 ||N ||N ||N ||N<br />
|-<br />
|-<br />
|}<br />
<br />
=== [http://www.gotronic.fr Gotronic] ===<br />
<br />
la prochaine commande a la référence interne GO_003<br />
<br />
<br />
Commande passée en attente de livraison :GO_002 le 31/05/2017 par Ellyan<br />
<br />
<br />
Anciennes commandes Gotronic archivées [[Projets:Commande_groupee:archives#Gotronic|ici]]<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref gotronic!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||<Acheteur>|| GO_XXX || N || N || N || N<br />
|-<br />
--><br />
| Damien H || Solénoïde 12 Vcc || LS1110BD || 1 || 7,00€||Ellyan|| GO_002 || N || O || N || N<br />
|}<br />
<br />
=== HighVoltageShop ===<br />
<br />
La prochaine commande a pour référence interne : HV_002<br />
<br />
5 euros de réduction sur la prochaine commande<br />
<br />
Prochaine date de commande : Aucune<br />
<br />
Commande passée en attente de livraison : Aucune<br />
* frais de port 20 euros<br />
* Livraison mardi 7 janvier 2014 au lab<br />
<br />
Commande livrée en cours de distribution : HV_001 (08/12/2013) <br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref ebay!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||David|| DI_XXX || N || N || N || N<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| Thomas || Cable HV 120 kV || 271261265516 || 1 || 8,69€||David|| HV_001 || O || O || O || N<br />
|-<br />
|David||-30kV HV-Generator Modul 12VDC||281162933827||1||34,99€||David||HV_001||O||O||O||N<br />
|-<br />
|David||5 Stk. Zeilentrafo - Flyback Transformer - Zeilentrafos||281024817841||1||24,99€||David||HV_001||O||O||O||N<br />
|-<br />
|David||+30kV HV-Generator Modul 12VDC||281162933829||1|| 34,99€||David||HV_001||O||O||O||N<br />
|-<br />
|CitronVert||-30kV HV-Generator Modul 12VDC||281162933827||2||34,99€||David||HV_001||N||O||O||N<br />
|-<br />
| Goldo || Regelbares Hochspannungsnetzteil 50kV Strombegrenzung || 280941865340 || 1 || 119,99€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || +30kV HV-Generator Modul 12VDC || 281162933829 || 1 || 34,99€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Zenos || +30kV HV-Generator Modul 12VDC || 281162933829 || 1 || 34,99€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || Cable HV 120 kV || 271261265516 || 1 || 8,69€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || Hochspannungskabel 40kV 1m || 271261265512 || 1 || 4,61€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || Hochspannungswiderstand 20kV 1 GigaOhm Messwiderstand || 280941865344 || 1 || 6,34€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || Hochspannungswiderstand 20kV 100 MegaOhm || 271106455991 || 1 || 6,34€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || Hochspannungswiderstand 20kV 1 MegaOhm || 281026497192 || 1 || 6,34€||David|| HV_001 || O || O || O || N<br />
|}<br />
<br />
=== [http://www.limpulsion.fr/web/index.php L'impulsion] ===<br />
<br />
[http://v1.limpulsion.fr/docpdf/2008_cat/bpoa_a.pdf Catalogue "accessoires de test"]<br />
<br />
La prochaine commande a la référence interne LI_002<br />
<br />
Prochaine date de commande : [à définir]<br />
<br />
<br />
Commande livrée en cours de distribution :[aucune]<br />
<br />
Anciennes commandes Limpulsion archivées [[Projets:Commande_groupee:archives|ici]]<br />
<br />
<br />
{|class="wikitable sortable" style="font-size:80%"<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref L'impulsion!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-<br />
|Lab||ADAPTATEUR D'AXE HM8001-2 HAMEG||760000500||1||2.30HT||Yannick||IL_001||N||N (plus livrable)||N||O<br />
|-<br />
|Lab||TRESSE A DESSOUDER NO CLEAN 2.8mm/3m||730.14||10||1.56HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||Entretoise plastique grise de montage en saillie marque "Electro-PJP" pour douilles 4mm type 3265, ref EPJP : 3282||<pas au catalogue: demander si livrable> ||16||? ||Yannick||IL_001||N||N (apparement pas dispo)||N||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou NOIR, ref3265-I-0 ||326500||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou MARRON, ref3265-I-1 ||326501||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou ROUGE, ref3265-I-2 ||326502||3||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou BLEU, ref3265-I-6 ||326506||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou VIOLET, ref3265-I-7 ||326507||3||1.48HT||Yannick||IL_001||O||O||N||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou GRIS, ref3265-I-8 ||326508||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou BLANC, ref3265-I-9 ||326509||3||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou JAUNE/VERT, ref 3265-I-J/V||326510||1||1.74HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||[http://v1.limpulsion.fr/docpdf/2008_cat/bpoe_a.pdf#page=9 Passe fil classique intérieur :12mm, Perçage: 18mm, Epaisseur :10mm (lot de 10pcs)]||252.162||1||1,95EURHT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||Entretoise plastique grise de montage en saillie marque "Electro-PJP" pour douilles 4mm type 3265, ref EPJP : 3282||<pas au catalogue: demander si livrable> ||16||? ||Yannick||IL_001||N||N(apparement pas dispo)||N||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou NOIR, ref3265-I-0 ||326500||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou MARRON, ref3265-I-1 ||326501||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou ROUGE, ref3265-I-2 ||326502||3||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou BLEU, ref3265-I-6 ||326506||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou VIOLET, ref3265-I-7 ||326507||3||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou GRIS, ref3265-I-8 ||326508||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou BLANC, ref3265-I-9 ||32650||3||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou JAUNE/VERT, ref 3265-I-J/V||326510||2||1.74HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||CLE EXTERNE POUR DOUILLE DE SECURITE||3299||1||13.51HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||TRANSFO FERRITE POUR THT HM1005 HAMEG (plus livrable) ||THTHM1005||1||16.77HT||Yannick||IL_001||N||N (plus livable)||N||O<br />
|-<br />
|Eric||Lot de 100 douilles pour C.I diam4 Long 10mm à souder Electro-PJP ref 20054||20054||1||7,95 EUR HT||Yannick||LI_001||N||O||O||O<br />
|-<br />
<br />
|Eric||CI SN75492 (7 segm DRIVER) TEXAS DIP14||75492||13||1.29HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||CI 74LS164 TEXAS DIL||74LS164||2||0.76HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||IPROBER520||IPROBER520||1||594HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|}<br />
<br />
=== [https://shop.mchobby.be/ MCHobby] ===<br />
<br />
La prochaine commande a pour référence interne : MCH_001<br />
<br />
Prochaine date de commande : <Mardi 20 ou mercredi 21 au plus tard ><br />
<br />
Livraison gratuite en Mondial Relay à partir de 75 euros.<br />
<br />
Commande passée en attente de livraison :[aucune]<br />
<br />
Commande livrée en cours de distribution : [aucune] <br />
<br />
Anciennes commandes MCHobby archivées [[Projets:Commande_groupee:archives#MCHobby|ici]]<br />
<br />
Site WEB de MCHobby : https://shop.mchobby.be/<br />
<br />
{|class="wikitable sortable" style="font-size:85%"<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Mon Droguiste !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||<Acheteur>|| MC_XXX || N || N || N || N<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| LienRag|| Divers ||Divers || ++|| 75€||<acheteur>|| MHC_001 || N|| N || N || N<br />
|}<br />
<br />
<br />
=== [http://217.34.103.131/homepage/homepage.html Mini-Circuits] ===<br />
<br />
La prochaine commande a pour référence interne : MC_001<br />
<br />
Prochaine date de commande : <non défini><br />
<br />
<br />
<br />
Anciennes commandes Mini-Circuits archivées [[Projets:Commande_groupee:archives#Mini-Circuits|ici]]<br />
<br />
Site WEB de minicircuits : http://www.minicircuits.com/homepage/homepage.html<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Mini-circuits !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| F1CHF || ERA-3 || AMPL || 20 || 1.43€||F1CHF|| MC_001 || N || N || N || N<br />
|-<br />
|-<br />
| F1CHF || ADCH-80+ || coil || 20 || 2.88€||F1CHF|| MC_001 || N || N || N || N<br />
|-<br />
! !! !! !! !! !! !! !! !! !! !!<br />
|}<br />
<br />
=== [http://www.mon-droguiste.com/index.cfm Mon Droguiste] ===<br />
<br />
La prochaine commande a pour référence interne : MD_001<br />
<br />
<br />
<br />
<br />
Anciennes commandes Mon Droguiste archivées [[Projets:Commande_groupee:archives#Mon-droguiste|ici]]<br />
<br />
Site WEB de Mon Droguiste : http://www.mon-droguiste.com/index.cfm<br />
<br />
|-<br />
|-l<br />
<!-- Pour ajouter une ligne, copier les 2 lignes suivantes (celles qui commencent par | ) à la suite du tableau et remplacer le contenu des colonnes par ce qui semblera adéquat<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| Eric|| Ethylene Diamino Tetraacetic Acide 500g ||Ethylene Diamino Tetraacetic Acide Sac 500g || 1|| 16.95€||<acheteur>|| MD_001 || N|| N || N || N<br />
|}<br />
<br />
=== [http://www.mouser.fr Mouser Electronics]===<br />
<br />
La prochaine commande aura pour référence interne MO_014<br />
<br />
Prochaine date de commande : ?<br />
<br />
<br />
Commande livrée en cours de distribution : MO_013 le 31/05/2017 par Ellyan<br />
<br />
Anciennes commandes Mouser Electronics archivées [[Projets:Commande_groupee:archives#Mouser Electronics|ici]]<br />
<br />
Livraison gratuite (FedEx ou UPS) au delà de 50€ de commande<br />
<br />
<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Mouser !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||<Acheteur>|| DI_XXX || N || N || N || N<br />
|-<br />
--><br />
<br />
|-<br />
|Frederic.D.||[http://www.mouser.fr/ProductDetail/TE-Connectivity/1-826632-0/ Headers & Wire Housings 2X10P DUAL ROW]||571-1-826632-0 ||3 ||1.95 |||| MO_013||O ||O ||O ||N<br />
|-<br />
|Frederic.D.||[http://www.mouser.fr/ProductDetail/Bourns/3306P-1-103/ Trimmer Resistors - Through Hole 10K 25% 6mm Single Turn]||652-3306P-1-103 ||3 ||0.407 |||| MO_013||O ||O ||O ||N<br />
|-<br />
|Frederic.D.||[http://www.mouser.fr/ProductDetail/Schurter/13019302/?qs=%2fha2pyFadugAVCtehZ6ro0we%252bFlHwInvMJ3iEORyekx9pnGrLimsvA%3d%3d Pushbutton Switches SHORT TRAVEL SWITCH 6X6, 5.0MM]||693-1301.9302 ||9 ||0.251 |||| MO_013||O ||O ||O ||N<br />
|-<br />
|Frederic.D.||[http://www.mouser.fr/ProductDetail/Bourns/MF-USMF075-2/ Resettable Fuses - PPTC 0.75A 6V 0.18ohm Hold .75A Trip 1.5A]||652-MF-USMF075-2 ||3 ||0.275 |||| MO_013 ||O ||O||O ||N<br />
|-<br />
|Frederic.D.||[http://www.mouser.fr/ProductDetail/STMicroelectronics/SMA6J50A-TR/?qs=%2fha2pyFadujqXhcCRI4%2fO5BEn9p7pkr6EX0dAQtUlws3JpN%2fE2p9DQ%3d%3d TVS Diodes - Transient Voltage Suppressors HJ Temp Transil]||511-SMA6J5.0A-TR ||3 ||0.38 |||| MO_013 ||O||O||O ||N<br />
|-<br />
|-<br />
|Sylvain V.||[http://www.mouser.fr/ProductDetail/Cirrus-Logic/CS4398-CZZ/?qs=sGAEpiMZZMv%252bLKsN4bqzyhXScoHWAp%252boAQFEBwyfAGo%3d DAC Cirrus Logic]||777-CS4398-CZZ ||1 || 10.46 || Sylvain V. || MO_013 ||O||O||O ||N<br />
|-<br />
|Eric||[https://eu.mouser.com/ProductDetail/Amphenol-Tuchel/T-3427-100?qs=%2fha2pyFaduhPv3s%2fjYa9sAYm3fflPgRKEDSdRTPyUvP7YbNcd%2fVs5g%3d%3d Circular DIN Connectors FEMALE RECEPTACLE 6 WAY, Amphenol series C091B]|| 523-T3427-100 ||1 || 10.29|| <<acheteur>> || MO_014 ||N||N||N ||N<br />
|-<br />
|Eric||[https://www.mouser.fr/ProductDetail/EPCOS-TDK/B32926A4685M?qs=sGAEpiMZZMv1cc3ydrPrF3kXVSi%252b9fyL4PImBI83UxcgTMvwb1977w== Condensateurs à film 6.8uF 20% 350Vac LS 37.5MM Fabricant : EPCOS /TDK ref : B32926A4685M ]|| 871-B32926A4685M ||1 || 10.67|| <<acheteur>> || MO_014 ||N||N||N ||N<br />
|-<br />
|Eric||[https://www.mouser.fr/ProductDetail/Texas-Instruments/OPA2227U-2K5?qs=sGAEpiMZZMtCHixnSjNA6Mrdwin7F8A2DB4TJmgUI0w%3d OPA2227U SOIC8 dual opamp low noise Texas ]|| 595-OPA2227U/2K5 ||2 || 8.07|| <<acheteur>> || MO_014 ||N||N||N ||N<br />
|-<br />
|Eric||[https://eu.mouser.com/ProductDetail/Molex/53253-0570?qs=sGAEpiMZZMvlX3nhDDO4AD1CBCqS4WJ3BaSa47NubxE%3d Shrouded header 5 pins 2mm male through hole board connnector vertical mounting Molex ref. 53253-0570 Cross ref to JST PH "B5B-PH-K-S"]|| 538-53253-0570||20 || 0,164 €|| <<acheteur>> || MO_014 ||N||N||N ||N<br />
|-<br />
|Eric||[https://eu.mouser.com/ProductDetail/Central-Semiconductor/TIP42B?qs=sGAEpiMZZMshyDBzk1%2fWi0MKeUdJDRlz1TXFEdLineJjytqjBdqtHg%3d%3d Bipolar Transistor PNP 10A 80V TIP42B]|| 610-TIP42B ||2 || 0,969 €|| <<acheteur>> || MO_014 ||N||N||N ||N<br />
|-<br />
| Eric|| [https://www.mouser.fr/ProductDetail/Hirose-Connector/RM12BPE-5PH71?qs=sGAEpiMZZMvG94qpybaIZaiKjo18NgShhh8FQGCnH4c%3d HIROSE CONN PLUG Cbl Mount 5 Terminals ref "RM12BPE-5PH(71)"] (aussi dispos chez Digikey ref [https://www.digikey.fr/products/fr?keywords=HR1732-ND 'HR1732-ND')] ||798-RM12BPE-5PH71 || 1|| 11.47 EUR||<acheteur>|| MO_014 || N || N || N || N<br />
|-<br />
| Eric|| [https://www.mouser.fr/ProductDetail/Mueller-Electr/BU-75K?qs=sGAEpiMZZMs4AFwHyzhTm%2f3wHG8LpAJAx37I4fl4y%2fU%3d Kelvin clip 10A Mueller Electric ref. BU-75K] ||548-BU-75K|| 4|| 10.20 EUR||<acheteur>|| MO_014 || N || N || N || N<br />
<br />
|-<br />
|}<br />
<br />
<br />
=== [http://www.motedis.fr/shop/ Motedis France] ===<br />
<br />
<br />
La prochaine commande aura pour référence interne : MS_001<br />
<br />
<br />
<br />
<br />
Anciennes commandes Motedis France archivées [[Projets:Commande_groupee:archives#Motedis France|ici]]<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Motedis!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-<br />
|Eric||Plaquette aluminium 15mm d'épaisseur Largeur: 100mm ||<ref motedis>||L:1000mm|| 24.15EURHT || <acheteur> || MS_001 || N|| N || N || N<br />
|-<br />
|<demandeur>||<description>||<ref motedis>|| <quantité> || <prix>|| <acheteur> || MS_001 || N|| N || N || N<br />
|-<br />
|}<br />
<br />
<br />
===[http://www.nouvelleplastique.it/f/setf.html Nouvelle Plastique]===<br />
La prochaine commande a pour référence interne : NP_001<br />
<br />
Prochaine date de commande : Q3/2014<br />
<br />
<br />
<br />
Anciennes commandes Nouvelle Plastique archivées [[Projets:Commande_groupee:archives#Nouvelle Plastique|ici]]<br />
<br />
La société "[http://www.nouvelleplastique.it/f/setf.html Nouvelle Plastique]" fabrique des systèmes de rangements portables et modulaires en plastique.<br />
Les produits sont souvent bien pensés (parfois mieux que RAACO ou Stanley) et de bonne solidité.<br />
<br />
Malheureusement, ses produits ne sont que rarement distribués par les circuits classiques et pour le moment aucun revendeur de détail en France n'a été identifié. De même, on ne connait pas les prix des produits.<br />
La démarche envisagée est de collecter via le tableau ci-dessous une liste de souhaits afin de pouvoir demander un devis global directement au fabricant d'ici quelques mois (probablement en Q3/2014). En fonction de ses proposition de prix, chacun pourra finalement accepter ou refuser que ses souhaits soient inclus dans la commande définitive. Le coût du port sera partagé au prorata du prix des marchandises achetées (plus il y a de demaneurs, plus le coût individuel du port sera faible).<br />
Pour chaque article, il y a indication d'une UDV (Unité De Vente), c'est à dire de lot indivisible.<br />
Au terme des sélections de vos besoins, il faudra que le nombre de pièces commandées pour chaque article soit un multiple de son UDV.<br />
Le tableau ci-dessous dispose d'une structure adaptée à la gestion des souhaits des demandeurs, du nombre d'article et des UDV.<br />
Tous les demandeurs intéressés par un même article s'inscrivent dans une seule ligne (ce qui conduit au fait qu'il y ait une ligne par référence d'article).<br />
Le champ "PUHT" sera complété une fois le devis obtenu.<br />
<br />
====Légende du tableau ====<br />
<br />
UDV = correspond au nombre d'articles par UDV. = nombre d'articles dans un lot indivisible, cette information est indiquée par le fabricant dans son catalogue. <br />
Reste à affecter = mod(Nombre d'UDV; Nombre d'articles) <br />
<br />
<br />
Si vous éditez une ligne existante pour vous inclure comme demandeur de l'article considéré, modifiez les champs suivants :<br />
*''UDV' *''Nombre d'UDV'' (valeur cumulée d'UDV entre tous les demandeurs) <br />
*''Quantités (nombre d'articles)'' (valeur cumulées en nombre d'articles individuels entre tous les demandeurs) <br />
*''Reste à affecter'' (valeur calculée globalement pour tout les demandeurs) <br />
*''Liste de demandeurs avec (unités)'' Unités = nombre d'articles demandéz<br />
<br />
<br />
{|class="wikitable sortable" style="font-size:99%"<br />
|-<br />
! Ref article!! class="unsortable"| Désignation!! UDV (= nombre d'articles dans un lot indivisible) !! class="unsortable"| Nombre d'UDV!! class="unsortable"| Quantité souhaitée(nombre d'articles) !! Reste à affecter!! PUHT !! Liste de demandeurs avec (unités) !! N° de commande <br />
|-l<br />
|00366|| Tyger maxi double|| 6 || 1 ||6 ||0|| <PU> || Eric (6) || NP_001 <br />
|-<br />
|00361|| Tyger maxi|| 12 || 1 ||6 ||6|| <PU> || Eric (6) || NP_001 <br />
|-<br />
<br />
|}<br />
<br />
=== [https://www.olimex.com/ Olimex]===<br />
<br />
La prochaine commande a pour référence interne : OL_001<br />
<br />
<br />
<br />
<br />
Anciennes commandes Olimex archivées [[Projets:Commande_groupee:archives#Olimex|ici]]<br />
<br />
<br />
Achat par l'intermédiaire de leur site internet: https://www.olimex.com/<br />
<br />
Produits identifiés comme potentiellement intéressants:<br />
* https://www.olimex.com/Products/ARM/TI/TMS570-CAN/ un pti devkit pour un micro bien patator, prévu au départ pour des applications safety mais qui a des périphériques & capacités pas dégueulasses...<br />
* https://www.olimex.com/Products/Modules/Adapters/ pour utiliser leurs modules d'extension avec un launchpad ou un rpi<br />
* https://www.olimex.com/Products/Modules/LCD/ (divers modules LCD)<br />
* https://www.olimex.com/Products/Modules/LCD/MOD-LCD4.3%27%27/ module LCD "complet" avec pti micro sympatoche intégré<br />
* https://www.olimex.com/Products/OLinuXino/ gamme de nanocomputers intégrés & pas chers (type rpi mais en open)<br />
* https://www.olimex.com/Products/Components/Misc/TC-K-TYPE/ thermocouple K <br />
etc...<br />
<br />
<br />
Commande prévue courant mars 2013 par Clem.<br />
Attention, prix HT a priori, et prévoir également frais de port "importants" (environ 20€) à répartir entre les participants à la CG.<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Olimex!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||<Acheteur>|| OL_XXX || N || N || N || N<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| XXX|| XXX || - || - || XXX€||XXX|| OL_001 || N || N || N || N<br />
|-<br />
|-<br />
|}<br />
<br />
=== [http://www.otelo.fr/fr/index.html Otelo] ===<br />
<br />
Outillage bois-métal <br />
<br />
Ports gratuits au delà de 230 € H.T. ou code promo<br />
<br />
La prochaine commande a pour référence interne : OT_004<br />
<br />
Prochaine date de commande : < non définie ><br />
<br />
Commande passée en attente de livraison [AUCUNE]<br />
<br />
<br />
Anciennes commandes Otelo archivées [[Projets:Commande_groupee:archives#Otelo|ici]]<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Otelo!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
|-<br />
--><br />
|-<br />
|lab||TARAUD à main diamètre 14X200 Acier/alu||14104142N1||1|| 14,51€ HT|| <Patrick> || OT_002|| N || O|| O || O<br />
|-<br />
|lab||100 rondelles plates diamètre 8X16 ||36211008||5|| 3,23€ HT|| <Patrick> || OT_002|| N || O|| O || O<br />
|-<br />
|Patrick||Disque à poncer bombé axe 22mm D125 grain 80||54426280||2|| 3,42€ HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|Patrick||boites de rangement 18 sep 375X310X60||PY 69720030||3|| 9,55€ HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|Patrick||jeu d'outils ébavurage||PY 58500009||1|| 7,35€ HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|Patrick||BOMBE GALVA FLASH||PY 73006003||1|| 8,40€ HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|Eric||Tablier de soudeur 90 x 60 cm||PW 75 150 001||1|| 10,90€HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|MAZ24||meule blanche touret||5473014F||1|| 11,40€HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|MAZ24||Meule verte de touret||54571150||1|| 42,40€HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|MAZ24||Bagues adaptation||54703320||4|| 1,09€HT|| <Patrick> || OT_002|| O || O|| O|| O<br />
|-<br />
|Patrick||Mandrin à clef 3-16mm CM2/B18||30140413||1|| 27,25€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Mandrin à clef 1-13mm CM2/B16||30140409||1|| 23,20€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Arbre pour mandrin CM2/B16||30199116||1|| 6,80€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Arbre pour mandrin CM2/B18||30199118||1|| 7,00€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Ecouvillon manche bois 15mm||57169015||1|| 7,70€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Ecouvillon manche bois 25mm||57169025||1|| 8,15€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Ecouvillon à fil 6mm||57169006||1|| 5,24€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Ecouvillon à fil 25mm||57151025||1|| 6,38€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Sylvia||Support articulé ||43130110||1|| 23,77€ HT|| <Patrick> || OT_003|| N || O|| O|| O<br />
|-<br />
|}<br />
<br />
===[http://www.outiz.fr/ Outiz]===<br />
<br />
<br />
Comptoir Guilleraies (Nanterre)<br />
<br />
Du lundi au vendredi 7h - 17h Samedi 8h - 12h<br />
<br />
Téléphone : 01 40 35 77 77<br />
<br />
La prochaine commande aura pour référence interne : OU_001 <br />
<br />
Prochaine date de commande : <non définie><br />
<br />
<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Outiz!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!!Remboursé/Archive (O/N)<br />
|-<br />
| Eric ||[http://www.outiz.fr/sferaco-vanne-a-sphere-laiton-pn25-batiment-ff-3-4-poignee-acier-plate-rouge-580005/p/3806984/ Vanne à poignée plate rouge Genre : FF Ø : 3/4" ] ||3806984 || 1|| 4,54 €HT||<acheteur>|| OU_001 || N || N || N || N<br />
|-<br />
|}<br />
<br />
=== [http://fr.rs-online.com/web/ Radiospares (RS Composants)] ===<br />
<br />
La prochaine commande aura pour référénce interne : RS_012<br />
<br />
<br />
<br />
Commande livrée en cours de distribution : <aucune><br />
<br />
Anciennes commandes Radiospares archivées [[Projets:Commande_groupee:archives#Radiospares|ici]]<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref RS!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||Acheteur|| DI_XXX || N || N || N || N<br />
--><br />
|-<br />
| papy F1CHF||régulateur || 686-9007 || 10 || 0,27€|| <>|| RS_012 || N || N || N || N<br />
|FredericD||[http://fr.rs-online.com/web/p/ldr/9146710/ Silonex, NSL-19M51, CdS, Traversant, TO-18, 20 kΩ → 100 kΩ]||914-6710|| 10 || 1.074€HT ||<>||RS_012||N||N||N||N <br />
|-<br />
|FredericD||[http://fr.rs-online.com/web/p/relais-reed/2562055/ Relais Reed 1NO 12V dc 1 A]||256-2055|| 1 || 5.17€HT ||<>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[http://fr.rs-online.com/web/p/refrigerants/1115853/ Réfrigérant aérosol Cramolin Aérosol 400 ml, -50°C]||111-5853|| 2 || 11.12€HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/accessoires-pour-capteur-de-temperature/0286771/ Presse-étoupe pour Thermocouple]||286-771|| 2 || 9,68€HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|<s>Eric</s>||<s>[https://fr.rs-online.com/web/p/pinces-kelvin/7148263/ Pince Kelvin BU-75K, 10A, noir, fabricant : Mueller]</s>||<s>714-8263</s>||<s> 2</s> ||<s> 19,61€HT</s> ||<s><acheteur></s>||<s>RS_012</s>||<s>N</s>||<s>N</s>||<s>N</s>||<s>N</s> <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/condensateurs-aluminium/8396258 Condensateur électrolytique aluminium radial 10µF, -20%, 50V dc, Traversant, +105°C, WURTH série WCAP-AT1H, 5 (Dia.) x 11mm 5000h 97mA Référence fabricant : 860240672002]||839-6258|| 25 (1 sachet) || 3,90 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/condensateurs-aluminium/8399011 Condensateur électrolytique aluminium radial 47µF, -20%, 63V dc, Traversant, +105°C, WURTH série WCAP-ATUL, 8 (Dia.) x 11.5mm 7000h 360mA ESR: 0.66 Ohms Référence fabricant : 860040774002]||839-9011|| 20 (2 paquets) || 3,12 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/condensateurs-aluminium/8399033 Condensateur électrolytique aluminium 120µF, -20%, 63V dc, Traversant, +105°C, série WCAP-ATUL, 10 (Dia.) x 16mm 7000h 760mA ESR: 0.3 Ohms Référence fabricant : 860040775008]||839-9033|| 20 (4 paquets) || 3,43 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/connecteur-xlr/7259543/ Connecteur XLR femelle plastique pour chassis soudage pour CI 3 broches coudé + blindage avec louet métal, NEUTRIK NC3FAH2]||725-9543|| 2 || 1,97 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/connecteur-xlr/7259549 Connecteur XLR mâle plastique pour chassis soudage pour CI 3 broches coudé + blindage, NEUTRIK NC3MAH ]||725-9549|| 2 || 1,43 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/fusibles-cms-rearmables/5177054/ Fusible CMS réarmable, Littelfuse, 2.2A - 1.1A Référence fabricant : SMD100F-2 MK : 100F]|| 517-7054|| 10 || 0,497 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|<s>Eric</s>||<s>[https://fr.rs-online.com/web/p/roulettes-sur-platine/0819567/ Roulette Pivotante Acier 50mm, Bas profil, 270kg Fabricant : Revvo]</s>|| <s>819-567</s> || <s>4</s>|| <s>34.91 €HT</s> ||<s><acheteur></s>||<s>RS_012</s>||<s>N</s>||<s>N</s>||<s>N</s>||<s>N</s> <br />
|-<br />
|3ds||[https://fr.rs-online.com/web/p/potentiometres/0387896/ Potentiomètre carbone série 23 montage panneau 4K7 B avec interrupteur DPST, axe 6,35mm TE Connectivity ref 23ESB472MMF50AF]||387-896|| 1 || 4,14€HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Louis||[https://fr.rs-online.com/web/p/passe-fils/1366806/ Passe-fils,SES en PVC, Diamètre maximum de câble 3mm Noir ref 01070005010 ]||136-6806|| 1 sachet de 100|| 5,38€HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|}<br />
<br />
<br />
<br />
=== [http://www.stquentin-radio.com/ Saint Quentin radio]===<br />
<br />
La prochaine commande a pour référence interne SQ_002<br />
<br />
<br />
<br />
<br />
Anciennes commandes Saint Quentin Radio archivées [[Projets:Commande_groupee: Saint Quentin radio|ici]]<br />
<br />
Paiement cash par avance à l'acheteur : payez le montant exact, car il n'y a pas de frais annexes<br />
<br />
Frais de port : 0€ (sauf objets lourds) Gare du Nord<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref St Quentin!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
|-<br />
--><br />
|Lab||DOUILLE DE SECURITE 4mm ECROU BLANC, ref3265-I-9 ||326509 ||3||1.80€||<Patrick>||SQ_001||N||O||O||O<br />
|-<br />
|Lab||Fiche DIN 5BR MALE PLASTIQUE 360°||I076||2||1.00€||<acheteur>||SQ_002||N||N||N||N<br />
|-<br />
|Lab||Fiche DIN 5BR CHASSIS METAL 360°||I088||1||1.20€||<acheteur>||SQ_002||N||N||N||N<br />
|}<br />
<br />
=== [http://www.selectronic.fr Selectronic] ===<br />
<br />
La prochaine commande a pour référence interne : SE_010 <br />
<br />
<br />
<br />
<br />
Anciennes commandes Sélectronic archivées [[Projets:Commande_groupee:archives#Selectronic|ici]]<br />
<br />
Frais de port : 0€ (sauf objets lourds)<br />
<br />
Certains produits sont pas en stock à Paris et requièrent d'être livrés de Lille d'où un délai de quelques jours. Le mieux est d'aller au mag à Nation le mardi pour passer la commande et dans ce cas c'est en principe dispo jeudi sur place.<br />
<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description || Ref Sélectronic!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-<br />
|Eric||Résistance CTN 10kOhms 10% format goutte traversant||5277|| 1 || 0.95€TTC|| Eric|| SE_008 || O || O || O || O<br />
|- <br />
|lab||Résistance CTN 10kOhms 10% format goutte traversant||5277|| 1 || 0.95€TTC|| Zenos|| SE_009 || N || O || O || N<br />
|-<br />
|Zenos||triac BT139-600||4024|| 3 || 1,90€TTC|| Zenos|| SE_009 || O || O || O || O<br />
|-<br />
|Lab||TIC106D Thyristor||4018|||1||1,52||<acheteur>|| SE_009 || N || O || N (pas dispo) || N <br />
|-<br />
|Eric||IR IRF9540 MOS canal P -100V -19A||08015|||1||2,50EUR||Zenos|| SE_009 || O || O || O || O<br />
|- <br />
|Eric||Mosfet N IRF640N TO220 200V 0.150Ω - 18A||HD75-940|||2||1,94||<acheteur>|| SE_010 || N || N || N || N<br />
|-<br />
|Marc f6itu||pointes de scope||2447|||4||1,02||<acheteur>|| SE_010 || N || N || N || N<br />
|-<br />
|Lab (Eric)||[http://www.selectronic.fr/joints-adhesif-pour-enceintes.html bande mousse autocollante de largeur 5mm, hauteur 2mm]||2300|||2||5.50||<acheteur>|| SE_010 || N || N || N || N<br />
|-<br />
|}<br />
<br />
=== [http://www.sparkfun.com/ SparkFun Electronics]===<br />
<br />
La prochaine commande a pour référence interne SF_002<br />
<br />
Prochaine date de commande : N/A<br />
<br />
<br />
Commande livrée en cours de distribution : SF_001<br />
<br />
<br />
TVA, frais de port et droits de douane + frais pour dossier de dédouanement : selon taille totale de la commande finale, seront ventilés au pro-rata du montant commandé par chacun.<br />
<br />
Anciennes commandes SparkFun Electronics archivées [[Projets:Commande_groupee:archives#SparkFun Electronics|ici]]<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref SparkFun!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
|-<br />
--><br />
|Damien H||Spark Gap Igniter - 4.8V||COM-11218||3||$14,95||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Pilou||MIDI Shield||DEV-09595||1||$19,90||<Damien H>||SF_001||N||O||O||O<br />
|-<br />
|Pilou||OpenServo||ROB-09014||2||$14,95||<Damien H>||SF_001||N||O||O||O<br />
|-<br />
|Pilou||Breakout Board for PCF8575 I2C Expander||BOB-08130||1||$11,95||<Damien H>||SF_001||N||O||O||O<br />
|-<br />
|MAZ24||wire stripper||TOL-08696||1||$4,95||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|MAZ24||flush cutter||TOL-11952||1||$6,95||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Eric||Optical Dust Sensor - GP2Y1010AU0F||COM-09689||1||$11,95||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Eric||Mating Connector Housing for Dust Sensor (JST ref#: ZHR-6)||PRT-09690||2||$0,35||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Eric||Crimp Pins for Dust Sensor Connector (JST ref#: SZH-002T-P0.5)||PRT-09728||16||$0,09||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Eric||Copper Tape - 2" (50ft)||PRT-11081||1||$14,95||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Olga||RaspiRobot Board||KIT-11561||1||$29,95||<Damien H>||SF_001||N||O||N||O<br />
|-<br />
|Dom||Copper Tape - 2" (50ft)||PRT-11081||1||$14,95||||SF_002||N||N||N||N<br />
|-<br />
|Jean-Marc (PdM) || Polymer Lithium Ion Battery - 400mAh || PRT-10718 || 1 || $6.95 || || SF_002 || N || N || N ||N<br />
|-<br />
|Jean-Marc (PdM) || SparkFun USB LiPoly Charger - Single Cell || PRT-12711 || 1 || $14.95 || || SF_002 || N || N || N ||N<br />
|-<br />
|Jean-Marc (PdM) || Precision Disc Wheel - 5" (Yellow, 2 Pack) || ROB-12469 || 1 || $6.29 || || SF_002 || N || N || N ||N<br />
|-<br />
|Jean-Marc (PdM) || Set Screw Hub - 3mm Bore || ROB-12512 || 2 || $4.99 || || SF_002 || N || N || N ||N<br />
|-<br />
|Jean-Marc (PdM) || ProtoBoard - Square 2" || PRT-08811 || 1 || $2.95 || || SF_002 || N || N || N ||N<br />
|-<br />
|Jean-Marc (PdM) || Micro Gearmotor - 90 RPM (6-12V) || ROB-12285 || 2 || $12.95 || || SF_002 || N || N || N ||N<br />
|- <br />
|Jean-Marc (PdM) || SparkFun Solderable Breadboard - Mini || PRT-12702 || 1 || $2.95 || || SF_002 || N || N || N ||N<br />
|- <br />
|}<br />
<br />
=== Subtel.fr ===<br />
<br />
Pas de frais de port, prix TVA comprise<br />
<br />
<br />
<br />
<br />
Anciennes commandes Subtel.fr archivées [[Projets:Commande_groupee:archives|ici]]<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Subtel!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Archive (O/N)<br />
|-l<br />
|-<br />
|}<br />
<br />
=== raspberry-pi-zero ===<br />
Une opportunité dégotée par Francis: une version du raspberry-pi, un peu spartiate, pour 5 euros!<br />
https://www.raspberrypi.org/blog/raspberry-pi-zero/<br />
<br />
On peut également acheter le kit: http://swag.raspberrypi.org/collections/pi-kits/products/pi-zero-cables<br />
C'est le cordon midi-hdmi/hdmi, PLUSSE la barrette gpio.<br />
<br />
Cette entrée est mise en place alors que tout n'est pas défini pour cet achat: ni le fournisseur (fournisseur initial en rupture de stock), ni le prix.<br />
Mais ce sera le support pour rassembler les commandes. Je tiendrai ce paragraphe à jour selon les infos.<br />
<br />
Le kit comprend l'adaptateur micro-hdmi/hdmi (1 cordon + 1 petit adaptateur?), et la barette 2x20, à souder, pour les gpio. Le raspberry n'est pas dans le kit!<br />
<br />
Le prix: 5 euros le kit, idem le raspberry, et quelques pourcent pour les frais de transport. <br />
<br />
(ce soir: site http://swag.raspberrypi.org/ down; ??)<br />
<br />
<br />
On peut aussi attendre 3 semaines le temps que cela soit livré directement chez vous et avoir<br />
<br />
- l'adaptateur micro hdmi mâle- hdmi femelle : http://www.banggood.com/Gold-Plated-Micro-HDMI-Type-D-Male-To-HDMI-Female-Adapter-p-974265.html<br />
<br />
- un adaptateur micro-hdmi vers VGA femelle sans le son : http://www.banggood.com/1080P-HDMI-Male-To-VGA-Female-Adapter-Video-Converter-Cable-p-937626.html<br />
<br />
- un adaptateur micro-hdmi vers VGA femelle avec le son : http://www.banggood.com/Sin-Hon-SH-MH2V02-Micro-HDMI-to-VGA-Cable-Adapter-with-Audio-p-907524.html<br />
<br />
- un adaptateur micro usb coudé(pratique pour ranger sur le côté : http://www.banggood.com/Micro-USB-Host-OTG-Cable-For-Samsung-HTC-p-79909.html<br />
<br />
- pour se faire une prise alim micro usb, on déboîte le capot et on soude : http://www.banggood.com/USB-2_0-Micro-B-Male-to-Mini-B-Female-5-Pins-Adapter-p-956044.html<br />
<br />
- toutes sortes d'alim : http://www.banggood.com/search/usb-2a-charger.html<br />
<br />
- de quoi s'amuser avec les GPIO : http://www.banggood.com/search/gpio-raspberry/1091-0-0-0-0-0-0-price-0-0_p-1.html<br />
<br />
Et si vous avez le temps de chercher c'est encore moins cher sur http://fr.aliexpress.com/<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| raspberry ou kit !! class="unsortable"| Quantité !! class="unsortable"| Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Archive (O/N)<br />
|-l<br />
|-<br />
!Pierre Grommit !!raspb !! 2 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!Pierre Grommit !!kit !! 1 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!Francis Roussel !!rasp !! 2 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!papy F1CHF !!kit !! 4 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!PDA !!rasp !! 3 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!yvs Accard !!rasp !! 3 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!yvs Accard !!Kit !! 1 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!Malek H. !!3 rasp + 2 vga son + 1 gpio + 1 otg !! 1 !! 1 !! n!! n !!n !! n!!<br />
<br />
<br />
|}<br />
<br />
<br />
=== Starterkit FPGA Altera Max10 ===<br />
'''COMMANDE CLOSE'''<br />
<br />
[https://www.arrow.com/en/products/bemicromax10/arrow-development-tools#page-1 Carte de démarrage FPGA] qui sera parfait pour les [[Formations#Initiation_.C3.A9lectronique_num.C3.A9rique_et_FPGA|formation initiation à venir]].<br />
<br />
Cette carte utilise un FPGA entrée de gamme MAX 10 de chez Altera. Elle contient tout un tas de périphériques sympa pour débuter.<br />
<br />
A noter que la board intègre une sonde JTAG Altera Blaster II (>200€ dans le commerce, 20€ pour un clone).<br />
<br />
Le prix: $30 le kit, disons donc 30€ (à réajuster à la baisse post commande). <br />
<br />
Date butoir pour la commande: mercredi 6 avril 2016<br />
<br />
Chip principal: MAX® 10 FPGA (10M08DAF484C8G):<br />
* 8,000 LEs (largement de quoi mettre le soft core 32bit Altera & des périphériques confortables)<br />
* 414 Kbit (Kb) M9K memory<br />
* 256 Kbit (Kb) user flash memory<br />
* 2 phase locked loops (PLLs)<br />
* 24 18x18-bit multipliers<br />
* 1 ADC block – 1 MSa/sec, 12-bit, 18-channels<br />
* 17 analog inputs<br />
* 1 temperature sense diode<br />
* 250 general purpose input/output (GPIO)<br />
* Non-volatile self-configuration with dual-boot support<br />
* Clocking circuitry: 50 MHz oscillator and 24 MHz oscillator<br />
* achetable à l'unité (moins cher de la gamme: 3€, celui ci, 30€)<br />
<br />
External peripherals<br />
* 8MB SDRAM (4Mb x 16) (ISSI IS42S16400)<br />
* Accelerometer, 3-Axis, SPI interface (Analog Devices ADXL362)<br />
* DAC, 12-bit, SPI interface (Analog Devices AD5681)<br />
* Temperature sensor, I2C interface (Analog Devices ADT7420)<br />
* Thermal resistor<br />
* Photo resistor<br />
* 8 user LEDs<br />
* 2 user Pushbuttons<br />
<br />
Prototyping<br />
* Two 6-pin PMOD expansion headers<br />
* Two 40-pin prototyping headers which provide access to 64 digital I/O<br />
* 6 analog inputs<br />
* One 80-pin BeMicro card edge connector<br />
<br />
<br />
Merci d'ajouter votre nom et votre rapport à l'éventualité de formations au lab:<br />
* débutant, intermédiaire, expert: sous entendu je veux assister à une formation & j'ai ce niveau<br />
* formateur: je suis volontaire pour participer à l'élaboration de formations<br />
* pas intéressé: ni en participant ni en formateur<br />
<br />
Merci d'indiquer:<br />
* combien vous en achetez à titre perso (30€ pièce, à revoir selon le change & port)<br />
* si vous voulez en prendre une à offrir aux formations du lab (vous payez 20€, moi 10€ ; il nous faut 10 cartes)<br />
<br />
<br />
'''MISE A JOUR RECEPTION'''<br />
Prix total 40€/carte. 25€ par carte offerte au lab. Merci de vous mettre à jour, et venez récupérer vos cartes auprès de Coline :)<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Formation? !! class="unsortable"| Quantité !! class="unsortable"| cadeau au lab !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Archive (O/N)<br />
|-l<br />
|-<br />
|-<br />
!flax !!formateur!! 1 !! non !! O!! n !!n !! n!!<br />
|-<br />
!flax !!formateur!! 1 !! oui !! O!! n !!n !! n!!<br />
|-<br />
!Clem !!formateur!! 1 !! N/A !! O!! n !!n !! n!!<br />
|-<br />
!3dsman!!débutant !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
!3dsman!!débutant !! 1 !! oui !! n!! n !!n !! n!!<br />
|-<br />
!Yann D!!débutant !! 2 !! non !! n!! n !!n !! n!!<br />
|-<br />
!Yannick A.!!formateur !! 1 !! oui !! n!! n !!n !! n!!<br />
|-<br />
!Yannick A.!!formateur !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
!F1HSU!!débutant !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
!Roul!!formateur? !! 1 !! oui !! n!! n !!n !! n!!<br />
|-<br />
!Roul!!formateur? !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
!Jojo du VoLAB !!intermédiaire !! 2 !! non !! n!! n !!n !! n!!<br />
|-<br />
!Jojo du VoLAB !!intermédiaire !! 1 !! oui !! n!! n !!n !! n!!<br />
|-<br />
!MrPozor !!débutant !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
!Julien Len!!débutant !! 1 !! oui? !! n!! n !!n !! n!!<br />
|-<br />
!Julien Len!!débutant !! 1 !! non!! n!! n !!n !! n!!<br />
|-<br />
!Jérôme Loï!! débutant !! 1? !! oui !! O(payé 30)!! n !!n !! n!!<br />
|-<br />
!Jérôme Loï!! débutant !! 1 !! non!! O!! n !!n !! n!!<br />
|-<br />
!Moala!!débutant !! 1 !! non !! O!! n !!n !! n!!<br />
|-<br />
!Desty!!debutant !! 1 !! oui !! n!! n !!n !! n!!<br />
|-<br />
!Desty!!debutant !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
<br />
!Votre nom!!type !! nombre !! oui/non !! n!! n !!n !! n!!<br />
<br />
<br />
<br />
|}<br />
Nombre de cartes total: 23 dont lab: 8 (total à mettre à jour !)</div>Erichttps://wiki.electrolab.fr/Projets:Perso:2018:KAPEX_KS120_DadoCutFunctionEnhancementProjets:Perso:2018:KAPEX KS120 DadoCutFunctionEnhancement2019-12-01T10:39:04Z<p>Eric: /* How to ? */</p>
<hr />
<div><br />
{{Project<br />
|name=: Modify / enhance the dado cut adjustment span of the FESTOOL Kapex KS120 miter saw<br />
|author= Eric<br />
|proposal_date=August 2018<br />
|abstract1=Mod for FESTOOL KAPEX KS120 MITER SAW <br />
|abstract3=Augmentation de la plage de réglage de la fonction de découpe de rainure de la scie à onglet FESTOOL KAPEX KS120<br />
|tags=FESTOOL KAPEX KS120,dado cut,rainure,modding,enhancement<br />
|where=<br />
|for_who=my Kapex<br />
|official_electrolab_project=<br />
|elecrolab_project_manager= N/A<br />
|budget= 15€<br />
|number_of_members= N/A<br />
|estimated_time= 1/2 day<br />
}}<br />
<br />
<br />
=Dado cuts height adjustement feature=<br />
<br />
The Kapex KS120 height adjustement for dado cuts is limited to about 40 mm, which avoids using this feature for high workpieces.<br />
This limitation [http://festoolownersgroup.com/festool-how-to/kapex-ks-120-cutting-depth-limiter-limitation-of-cutting-higher-workpieces/ seems to annoy other Kapex users.]<br />
<br />
[[File:FESTOOL_KAPEX_dado_cut_mod_50411.JPG|800px|thumb|center|Dado cuts are limited to about 40 mm]]<br />
<br />
<br />
Ron Paulk recorded a [https://www.youtube.com/watch?v=YynWuNeGuQY small video] to show how to perform dado cuts using the Kapex KS120. Many thanks to him !<br />
<br />
=User's manuals=<br />
The cutting depth limit lever is referenced at position "1.4" on page 4 of the [https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=2ahUKEwj4ycjQi_TcAhVInRoKHQw1DRAQFjABegQIBhAC&url=https%3A%2F%2Fwww.festoolusa.com%2F-%2Fmedia%2Ftts%2Ffestool%2Ffestool-usa%2Fdownloads%2Fmanuals%2F472068_005_ks_120_usa.pdf PDF user manual.]<br />
<br />
The cutting depth limit lever is referenced at position "U" on page 7 of this [https://service.festoolusa.com/media/pdf/Kapex-KS120-Supplemental-Manual.pdf very nice official Kapex KS120 supplemental user's manual.] <br />
<br />
=Enhancement=<br />
<br />
I updated my Kapex KS120 to allow a cutting depth limit adustement from 0 to ...93 mm<br />
<br />
==How to ?==<br />
Replace the existing cutting depth limiter lever with a custom made part.<br />
<br />
To unmount the existing 1.4 lever, remove the mains cable strain relief and the machine back panel/plate.<br />
<br />
As shown in the picture below, the cutting depth limiter lever is of easy access.<br />
[[File:FESTOOL KAPEX dado cut mod 50412 ann.jpg|800px|thumb|center|The cutting depth limiter lever is easy to replace]]<br />
<br />
<br />
<br />
On a lathe, process a [https://www.rcm-machines.com/fr/c45k-poli-/acier-c45k-rectifi-h6-rond-poli--6-mm-x-300-mm/rcstp06 6 mm silver steel rod] or similar to make a modified copy of the lever 1.4 using the dimensions shown in the picture below (scale = mm). The shape of the thinner side of the rod does not need to match exactly with the original part.<br />
<br />
[[File:FESTOOL KAPEX dado cut mod 50409 ann.jpg|800px|thumb|center|Original and custom made cutting depth limiter levers]]<br />
<br />
<br />
<br />
Use an M6 x 1 mm (right hand) HSS die to machine the thread.<br />
<br />
e.g ref. SDEMM06B [http://www.tap-die.com/contents/en-uk/p637_6x1mm_dies_1od.html here.]<br />
<br />
<br />
<br />
Use an angle grinder to create the flats on the opposite side of the rod.<br />
<br />
<br />
<br />
Mount the barrel nut on the threaded side of your custom made lever<br />
<br />
As you can observe on the original part, the lowest possible position of the barrel nut is 12 mm.<br />
<br />
On your custom made lever, use a small chisel to break the thread at 3 or 4 locations in order to limit the barrel nut lowest position to 12 mm (same value as on the original Festool part).<br />
<br />
[[File:FESTOOL_KAPEX_dado_cut_mod_50417.JPG|800px|thumb|center|Limit the barrel nut lowest position to 12 mm. The broken thread is visible just at the right side of the barrel nut]]<br />
<br />
<br />
Replace the original lever with your custom made lever.<br />
<br />
Once mounted in your miter saw, check if your custom made lever has enough room to move near the motor enclosure.<br />
<br />
[[File:FESTOOL_KAPEX_dado_cut_mod_50420.JPG|800px|thumb|center|Take care of the motor enclosure]]<br />
<br />
==Mounting hints==<br />
<br />
Keep a look on the tall miter latch parts to be sure they are in their correct position.<br />
[[File:FESTOOL_KAPEX_dado_cut_mod_50421.JPG|800px|thumb|center|Tall miter latch parts mounting]]<br />
<br />
<br />
While positionning the plastic back panel, take care to put the tall miter locking lever spring into it's groove.<br />
[[File:FESTOOL KAPEX dado cut mod 50424 ann.jpg|800px|thumb|center|Spring and groove for the tall miter feature]]<br />
<br />
==Results==<br />
With this modding, we now obtain a gorgeous adjustement span from 0 to 93 mm.<br />
The dado cut feature of the Kapex becomes now far more versatile.<br />
[[File:FESTOOL_KAPEX_dado_cut_mod_50435.JPG|800px|thumb|center|Great! We now have more than twice the span of the unmodified machine]]<br />
<br />
=Other hints and limitations=<br />
==Barrel nut==<br />
You may use the M6 x 1 barrel nut from the existing lever assembly or buy a [https://www.fastenright.com/general-fixings/cross-dowel-barrel-nut/ff04 new part] <br />
The original part has a 10 mm diameter and 14 mm lenght.<br />
<br />
==The height adjustment lever has now 3 positions==<br />
Once upgraded with your custom part, setting the depth position is slighly different.<br />
<br />
For adjustement limit above 50 mm, the 1.4 lever has to be set into an intermediate position.<br />
<br />
[[File:FESTOOL_KAPEX_dado_cut_mod_50436.JPG|300px|thumb|left|Depth limit lever in engaged position for dado cuts from 0 to 40 mm]]<br />
[[File:FESTOOL_KAPEX_dado_cut_mod_50442.JPG|300px|thumb|right|Depth limit lever in disengaged position]][[File:FESTOOL_KAPEX_dado_cut_mod_50428.JPG|300px|thumb|center|Lever in intermediate position for dado cuts from 40 to 93 mm]]<br />
<br />
<br />
<br />
==Cutting witdh==<br />
Another limitation (that already exists on an unmodified Kapex saw) : you won't be able to perform the dado cut in one pass on the full nominal machine width of 305 mm, but 220 mm seems to be reachable. To process wider dado cuts, you need to reverse your workpiece.</div>Erichttps://wiki.electrolab.fr/Projets:Perso:2018:KAPEX_KS120_DadoCutFunctionEnhancementProjets:Perso:2018:KAPEX KS120 DadoCutFunctionEnhancement2019-12-01T10:34:44Z<p>Eric: /* How to ? */</p>
<hr />
<div><br />
{{Project<br />
|author= Eric<br />
|where=<br />
|budget= 15€<br />
}}<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
=Enhancement=<br />
<br />
<br />
==How to ?==<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
[[File:FESTOOL_KAPEX_dado_cut_mod_50417.JPG|800px|thumb|center|Limit the barrel nut lowest position to 12 mm]]<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
==Results==<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
Another limitation (that already exists on an unmodified Kapex saw) : you won't be able to perform the dado cut in one pass on the full nominal machine width of 305 mm, but 220 mm seems to be reachable. To process wider dado cuts, you need to reverse your workpiece.</div>Erichttps://wiki.electrolab.fr/Projets:Perso:2018:KAPEX_KS120_DadoCutFunctionEnhancementProjets:Perso:2018:KAPEX KS120 DadoCutFunctionEnhancement2019-11-25T18:21:40Z<p>Eric: </p>
<hr />
<div><br />
{{Project<br />
|author= Eric<br />
|where=<br />
|budget= 15€<br />
}}<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
=Enhancement=<br />
<br />
<br />
==How to ?==<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
==Results==<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
Another limitation (that already exists on an unmodified Kapex saw) : you won't be able to perform the dado cut in one pass on the full nominal machine width of 305 mm, but 220 mm seems to be reachable. To process wider dado cuts, you need to reverse your workpiece.</div>Erichttps://wiki.electrolab.fr/Projets:Perso:2018:KAPEX_KS120_DadoCutFunctionEnhancementProjets:Perso:2018:KAPEX KS120 DadoCutFunctionEnhancement2019-11-25T18:20:59Z<p>Eric: </p>
<hr />
<div><br />
{{Project<br />
|author= Eric<br />
|where=<br />
|budget= 15€<br />
}}<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
=Enhancement=<br />
<br />
<br />
==How to ?==<br />
<br />
<br />
<br />
<br />
On a lathe, mac hinea [https://www.rcm-machines.com/fr/c45k-poli-/acier-c45k-rectifi-h6-rond-poli--6-mm-x-300-mm/rcstp06 6 mm silver steel rod] or similar to make a modified copy of the lever 1.4 using the dimensions shown in the picture below (scale = mm). The shape of the thinner side of the rod does not need to match exactly with the original part.<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
==Results==<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
Another limitation (that already exists on an unmodified Kapex saw) : you won't be able to perform the dado cut in one pass on the full nominal machine width of 305 mm, but 220 mm seems to be reachable. To process wider dado cuts, you need to reverse your workpiece.</div>Erichttps://wiki.electrolab.fr/Projets:Perso:2018:KAPEX_KS120_DadoCutFunctionEnhancementProjets:Perso:2018:KAPEX KS120 DadoCutFunctionEnhancement2019-11-25T18:14:20Z<p>Eric: </p>
<hr />
<div><br />
{{Project<br />
|author= Eric<br />
|where=<br />
|budget= 15€<br />
}}<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
=Enhancement=<br />
<br />
<br />
==How to ?==<br />
<br />
<br />
<br />
<br />
On a lathe, process a [https://www.rc-machines.com/en/materials/silver-steel/silversteel/silver-steel-o-6-mm-length-330-mm?action_ms=1 6 mm silver steel rod] to make a modified copy of the lever 1.4 using the dimensions shown in the picture below (scale = mm). The shape of the thinner side of the rod does not need to match exactly with the original part.<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
==Results==<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
Another limitation (that already exists on an unmodified Kapex saw) : you won't be able to perform the dado cut in one pass on the full nominal machine width of 305 mm, but 220 mm seems to be reachable. To process wider dado cuts, you need to reverse your workpiece.</div>Erichttps://wiki.electrolab.fr/Projets:Commande_groupeeProjets:Commande groupee2019-09-25T12:59:27Z<p>Eric: /* Doga */</p>
<hr />
<div>=Commandes groupées=<br />
<br />
== Principe ==<br />
Tout projet a régulièrement besoin de matières premières, composants, fournitures diverses, etc. Le lab a en stock une quantité importante de fournitures plus ou moins courantes, mais cela ne peut remplacer des commandes régulières.<br />
<br />
Histoire de mutualiser les bons plans & regrouper les frais de port, profiter de divers price breaks, etc, cette page a été créee pour organiser des commandes groupées.<br />
<br />
== Glossaire ==<br />
===Demandeur===<br />
Celui qui a besoin d'un article<br />
<br />
===Acheteur===<br />
Celui qui passe effectivement la commande chez le Fournisseur. L'Acheteur peut être le lab ou une personne privée.<br />
Dans le cas du lab indiquer dans la colonne "acheteur" lab_<nom/pseudo membres> exemple : lab_peewee<br />
Sauf avis contraire, le paiement est à effectuer sur le compte paypal du lab.<br />
<br />
Dans le cas d'une personne privée, indiquer dans la colonne "acheteur", son nom ou pseudo.<br />
L'Acheteur définit lui même les moyens de paiement à utiliser par les <demandeurs>.<br />
<br />
<br />
===Distributeur===<br />
Fournisseur ou fabricant chez qui l'<acheteur> passe commande.<br />
Chaque <distributeur> dispose d'une rubrique propre.<br />
<br />
Il est bien entendu possible d'ajouter des <distributeurs> supplémentaires (notez qu'ils sont triés par '''ordre alphabétique''').<br />
<br />
== Règles du jeu ==<br />
<br />
En général, lorsque l'on s'occupe d'un "group buy", on fait un premier tour de<br />
table pour savoir qui est partant, on annonce ensuite le prix de l'addition<br />
générale (TTC et frais d'expé avec ou sans assurance, éventuels frais de<br />
dédouanement) divisée par le nombre de participants (au prorata des volumes<br />
de commande : celui qui achète 2 items paye 2 parts de frais de port par<br />
exemple).<br />
<br />
Ceci fait, on attend qu'une "masse critique" soit atteinte lorsque l'on vise<br />
certains "price break" (décollonage en jargon de vendeur), puis on lance<br />
l'appel aux fonds avec une date butoir. Passé la date butoir, la commande<br />
est passée, en ignorant ceux qui n'ont pas répondu a temps, puisque le<br />
responsable de group buy n'a pas la trésorerie correspondant à l'achat en<br />
question.<br />
Les histoires genre "le chèque est au courrier" ne marchent pas avec des<br />
virements Paypal... le patron des achats sait exactement combien il a en<br />
caisse au moment de la commande.<br />
<br />
En cas de perte de colis, le responsable de "group buy" n'est pas<br />
redevable. C'est à chaque participant d'estimer s'il prend le risque ou non<br />
de faire confiance aux entreprises assurant l'acheminement des colis.<br />
C'est simple, et si c'est précisé, aucun conflit n'est à redouter, aucun lot<br />
ne reste sur les bras de l'<acheteur>.<br />
<br />
Pour le paiement par avance, celui-ci peut se faire au lab, mais c'est TTC et AVEC les frais de port et de douane, le cas échéant.<br />
<br />
Si un <demandeur> commande la mauvise référence, c'est pour sa pomme.<br />
<br />
Dans la mesure du possible, les <demandeur> doivent faciliter au maximum le travail des <acheteur> en indiquant des références d'articles et de désignation claires.<br />
<br />
==Mode opératoire lorsqu'on passe une commande chez l'un des distributeurs ==<br />
Les tableaux ci-après (un tableau par <distributeur> disposent des colonnes nécessaires à la synchronisation des commandes article par article.<br />
<br />
De même, chaque rubrique dispose d'un en-tete d'information qui a la structure suivante :<br />
<br />
La prochaine commande a pour référence interne : YY_xxx<br />
Commande livrée en cours de distribution : [aucune]<br />
Anciennes commandes <nom du distributeur> archivées [[Projets:Commande_groupee:archives|ici]]<br />
< informations complémentaires notamment en ce qui concerne les conditions de livraison, etc>''<br />
<br />
YY est un code fixe, unique pour chaque founisseur.<br />
<br />
xxx un le n° de commande pour ce distributeur. Il commence à 001 et s'incrémente à chaque commande.<br />
<br />
<br />
===Les différentes étapes de la commande ===<br />
<br />
====Prise en charge d'un commande par un <acheteur>==== <br />
La personne qui souhaite prendre en charge une commande chez un <distributeur> envoie un mail sur la ML pour informer tout le monde de cette action.<br />
Dans l'entête d'information du <distributeur> concerné, l'<acheteur> effectue les modifications suivantes :<br />
*mise à jour de la ligne ''Prochaine date de commande'' : valorisé à la date à laquelle il envisage de passer la commande auprès du <distributeur>. <br />
<br />
À ce moment, l'ensemble des <demandeurs> concernés se met en relation avec l'<acheteur> pour lui payer d'avance les articles commandés. Pour ces articles, l'<acheteur> fait les modifications suivantes dans le tableau des articles :<br />
*''Payé d'avance (O/N)'' : valorisé à "O" (Oui)<br />
<br />
<br />
====Passage effective de la commande par l'<acheteur>==== <br />
<br />
Celui qui passe la commande ( = <acheteur>) sélectionne les articles qu'il commande effectivement (= ceux pour lesquels il a reçu le paiement en avance). Il peut aussi inclure dans la commande des articles de <demandeurs> pour leuquel il est certain d'être payé au moment de la distribution.<br />
<br />
L'<acheteur> passe la commande auprès du distributeur (par internet, mail, téléphone, télécopie, signaux de fumée, déplacement sur place...) et effectue le paiement à l'aide d'un moyen de paiement à sa convenance. Il est judicieux de priviléger des moyens de paiement fournissant la traçabilité de la transaction.<br />
<br />
Pour les articles effectivement COMMANDÉS l'<acheteur> fait les modifications suivantes dans le tableau des articles :<br />
*'' Acheteur'' : valorisé par son nom/pseudo <br />
*''Commandé (O/N)'' : valorisé à "O" (Oui)<br />
<br />
Pour les articles qui n'ont pas déja été concernés par une commande précédente et que l'<acheteur> ne COMMANDE PAS (par exemple par ce que le <demandeur> ne s'est pas manifesté auprès de lui), il fait les modifications suivantes dans le tableau des articles :<br />
*''N° de commande'' : est incrémenté d'une unité afin que cet article non commandé soit inclus dans la prochaine commande.<br />
<br />
<br />
*mise à jour de la ligne ''Prochaine date de commande'' : valorisé à <non défini><br />
*mise à jour de la ligne ''La prochaine commande a pour référence interne'' : valorisé au numéro de commande interne actuel +1 <br />
*mise à jour de la ligne ''Commande passée en attente de livraison'': valorisé au n° de commande actuel<br />
<br />
====Réception de la commande par l'<acheteur>==== <br />
<br />
<br />
Au moment de la réception du colis, l'<acheteur> vérifie si la livraison est complète et négocie avec le <distributeur> en cas de problème. Il peut aussi informer le <demandeur> concerné par le ou les article(s) en litige ou manquants.<br />
<br />
====Distribution des articles aux <demandeurs>====<br />
Lorsque la distribution peut commencer l'<acheteur> effectue les modifications suivantes dans l'entête d'information du <distributeur> concerné :<br />
*mise à jour de la ligne : '' Commande passée en attente de livraison'' à [aucune]<br />
*mise à jour de la ligne : '' Commande livrée en cours de distribution '' avec la référence interne de la commande.<br />
<br />
L'<acheteur> informe via la ML les <demandeurs> du début de la distribution de la commande <référence interne de commande>.<br />
Chaque <demandeur> convient d'un RDV avec l'<acheteur> pour récupérer les articles (en principe cela se passe au lab) et payer son dû à l'<acheteur>, si ce n'est déja fait.<br />
<br />
Pour chaque article l'<acheteur> fait les modifications suivantes dans le tableau des articles :<br />
*'' Distribué (O/N)'' : valorisé à "O" (Oui) <br />
*''Remboursé/Archivé (O/N)'' : valorisé à "O" (Oui)<br />
<br />
====Ditribution des articles terminée====<br />
<br />
Une fois l'ensemble des pièces distribuées et payées, dans l'entête d'information du <distributeur> concerné, l'<acheteur> effectue les modifications suivantes :<br />
*mise à jour de la ligne ''Commande livrée en cours de distribution'' : valorisé à [aucune]<br />
<br />
<br />
===En conclusion ===<br />
<br />
Si les tableaux des commandes et les en-tête d'information sont gérés avec soin, il n'y a quasiment aucun risque de double commande et n'importe quel membre sait où on en est et peut à tout moment prendre la main sur l'un des tableaux d'achats pour commander un article ou organiser une commande en tant qu'<acheteur>. La bonne application de ces quelques recommandation bénéficie à l'ensemble des participants de ce système de commandes groupées.<br />
<br />
Sauf besoin urgent de pièces, il est bénéfique que ce soit de préférence les mêmes <acheteurs> qui officient auprès des mêmes <distributeurs>. Ainsi, vu de ces derniers, l'<acheteur> est très vite identifié comme "client important" (car en réalité il commande pour 5-10 personnes, voire plus) et peut bénéficier de conditions particulières (frais de port gratuit, -15% sur la prochaine commande, etc).<br />
<br />
Enfin, à tout moment en tant que <demandeur>, soyez diligent envers l'<acheteur> dont la gestion d'une commande de parfois plusieurs dizaines d'articles requert un investissement en temps non négligeable.<br />
<br />
== Commandes groupées passées (archives) ==<br />
<br />
Afin d'améliorer la lisibilité nous avons regroupé les commandes passées sur cette page: [[Projets:Commande_groupee:archives]]<br />
<br />
== Commandes groupées en cours ==<br />
<br />
=== BHV ===<br />
<br />
La prochaine commande a pour référence interne : BH_003<br />
<br />
<br />
<br />
<br />
Anciennes commandes BHV archivées [[Projets:Commande_groupee:archives#BHV|ici]]<br />
<br />
achat sur place<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref BHV!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| Lab|| Réglet métallique 30cm || - || 3 || 5.90€||Eric|| BH_001 || N || O || O || O<br />
|-<br />
|-<br />
| Lab|| Scie a métaux FACOM 603E || - || 1 || env. 36€||Eric|| BH_002 || N || O || 0 || O<br />
|-<br />
|-class="sortbottom"<br />
|}<br />
<br />
=== [http://www.visseriefixations.fr/ Cergy-Vis] ===<br />
<br />
<br />
La prochaine commande a pour référence interne : CV_002<br />
<br />
<br />
<br />
<br />
Anciennes commandes Cergy-Vis archivées [[Projets:Commande_groupee:archives|ici]] <br />
<br />
Retrait gratuit sur place<br />
CERGY-VIS<br />
<br />
17, Rue du Périgord<br />
<br />
ZI des Béthunes<br />
<br />
95310 SAINT OUEN L’AUMONE<br />
<br />
<br />
Horaires pour les enlèvements: Du Lundi au Vendredi, de 7h30 à 12h00 et de 13h30 à 17h30.<br />
<br />
<br />
Livraison<br />
Colissimo Régional (0.05kg / France) 5,75 €<br />
<br />
Colissimo Régional (0.2888kg / France) 6,54 €<br />
<br />
Colissimo Régional (2.87kg / France) 9,25 €<br />
<br />
Colissimo Régional (12.8948kg / France) 16,50 €<br />
<br />
Anciennes commandes Cergy-Vis archivées [[Projets:Commande_groupee:archives#Cergy-Vis|ici]]<br />
<br />
<br />
|-<br />
!Demandeur !! class="unsortable"| Description !! Référence!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-<br />
||Eric|| TRCC M5X30 INOX A2 DIN 603|| ||50||0.17EURTTC||<acheteur>||CV_001||N||O||O||N (attends remb. trop versé)<br />
|-<br />
||Eric|| ECROU HU M12 PAS 100 Z.BLANC DIN 934|| ||20||0.39EURTTC||<acheteur>||CV_001||N||O||O||N (attends remb. trop versé)<br />
|-<br />
||Eric||Vis TCHC M5X22 INOX A2 EF DIN 912||TCHC05/022A2EF||15||0.12EURTTC||<acheteur>||CV_002||N||N||N||N<br />
|-<br />
||Eric||Vis STHC PLAT M6X12 INOX A2 DIN 913||STHCPLA06/012A2||30||0.06EURTTC||<acheteur>||CV_002||N||N||N||N<br />
|-<br />
||Eric||Vis TH M6X12 INOX A2 EF DIN 933||TH06/012A2EF||30||0.09EURTTC||<acheteur>||CV_002||N||N||N||N<br />
|-<br />
|}<br />
<br />
=== [http://www.conradpro.fr Conrad Electronique France] ===<br />
<br />
<br />
La prochaine commande aura pour référence interne : CO_017<br />
<br />
Prochaine date de commande :<br />
<br />
Commande passée en attente de livraison : NEANT<br />
<br />
Commande livrée en cours de distribution : NEANT<br />
<br />
Anciennes commandes Conrad Electronique France archivées [[Projets:Commande_groupee:archives#Conrad Electronique France|ici]]<br />
<br />
{| class="wikitable sortable" style="font-size:85%"<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Conrad!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€ ||<Acheteur>|| CO_XXX || N || N || N || N<br />
|-<br />
--><br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/822746/Fil-de-soudure-pour-PVC-rigide-Steinel-073114-26-pcs Fil de soudure pour PVC rigide Steinel 073114 26 pcs]</s>||<s>822746 - 62 </s>||<s> 1 </s>||<s> € 5.99 TTC</s>||<s><acheteur> </s>||<s> CO_014 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/492161/Soudure-plastique-225-mm-4-mm-polythylne-LDPE-nature-Bosch-1609201811 Soudure plastique, 225 mm, 4 mm, polyéthylène (LDPE) nature Bosch 1609201811]</s>||<s>492161 - 62 </s>||<s> 1 </s>||<s> € 15.99 TTC</s>||<s> <acheteur> </s>||<s> CO_014 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/121588/Solution-de-conservation-pour-electrodes-de-mesure-pH-HI-70300M Solution de conservation pour électrodes de mesure pH HI 70300M]</s>||<s>121588 - 62 </s>||<s> 1 </s>||<s> € 15.12 TTC</s>||<s> <acheteur> </s>||<s> CO_014 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/121586/Solution-de-nettoyage-pour-electrodes-pH-HI-7061M Solution de nettoyage pour électrodes pH HI 7061M]</s>||<s>121586 - 62 </s>||<s> 1 </s>||<s> € 15.12 TTC</s>||<s> <acheteur> </s>||<s> CO_014 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|Eric||[http://www.conrad.fr/ce/fr/product/121164/Sol-de-conduct-12880-S-HI-70030-P Sol. de conduct. 12880 µS HI 70030 P]||121164 - 62 || 1 || € 38.30 TTC|| <Pat> || CO_014 || N || O || O || O<br />
|-<br />
|Eric||[http://www.conradpro.fr/ce/fr/product/822188/Knipex-Pinces-pour-circlips-pour-colliers-dtranglement-darbre-46-11-G0-140-mm?ref=searchDetail Pince KNIPEX 46 11 G0]||822188 - 62 || 1 || € 20.13 HT|| <Pat> || CO_014 || N || O || O || O<br />
|-<br />
|Eric||[http://www.conradpro.fr/ce/fr/product/822189/Knipex-Pinces-pour-circlips-pour-colliers-dtranglement-darbre-46-11-G1-140-mm?ref=searchDetail Pince KNIPEX 46 11 G1]||822189 - 62 || 1 || € 13.02 HT|| <Pat> || CO_014 || N || O || O || O<br />
|-<br />
|MrPozor||[http://www.conrad.fr/ce/fr/product/702246/Interrupteur-de-porte-Panasonic-AZC11113HJ-250-VAC-5-A-poussoir-momentan-IP40-1-pcs?ref=searchDetail Interrupteur de porte Panasonic AZC11113HJ]||702246 - 62 || 1 || € 10.99 TTC|| <Pat> || CO_014 || N || O || N || N<br />
|-<br />
| papy F1CHF || 74HC390 SOIC || 1115010-62 || 10 || 1.06€ ||<Pat>|| CO_014 || O || O || O || O<br />
|-<br />
| Pat|| Condo moteur 5uF 450V || 441527-62 || 1 || 6.33€ H.T. ||<Pat>|| CO_014 || O || O || N || N<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/731484/Adaptateur-avec-fiche-dor-32-A-rouge-MultiContact-240160-22 Adaptateur avec fiche doré 32 A rouge MultiContact Ref. 24.0160-22]|| 731484 - 62 || 2 || 3.00 € H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/731559/Disque-de-marquage-couleur-MultiContact-145010-vert-jaune-1-pcs Disque de marquage couleur MultiContact Ref. 14.5010 vert-jaune 1 pc(s)]|| 31559 - 62 || 3 || 0.75 € H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/106109/Pointe-de-touche-de-scurit-MultiContact-XMA-7L-enfichable-4-mm-CAT-IV-1000-V-bleu Pointe de touche de sécurité MultiContact XMA-7L enfichable 4 mm CAT IV 1000 V bleu Ref. MC 66.9509-23]|| 106109 - 62 || 1 || 15.96 € H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/106108/Pointe-de-touche-de-scurit-MultiContact-XMA-7L-enfichable-4-mm-CAT-IV-1000-V-rouge Pointe de touche de sécurité MultiContact XMA-7L enfichable 4 mm CAT IV 1000 V rouge Ref. MC 66.9509-22]|| 106108 - 62 || 1 || 15.96 € H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/106107/Pointe-de-touche-de-scurit-MultiContact-XMA-7L-enfichable-4-mm-CAT-IV-1000-V-noir Pointe de touche de sécurité MultiContact XMA-7L enfichable 4 mm CAT IV 1000 V noir Ref. MC 66.9509-21]|| 106107 - 62 || 1 || 15.96 € H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/1385649/Pince-crocodile-4-mm-GRIP-FMA-MultiContact-669435-21 Pince crocodile 4 mm GRIP-FMA MultiContact Ref. 66.9435-21]|| 1385649 - 62 || 1 || 30.00€ H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Damien H || MOSFET RFD14N05L || 512-RFD14N05L || 5 || 0,695 € ||?|| CO_015 || N || O || O || O<br />
|-<br />
| Damien H || Zener BZX79C2V4 || 512-BZX79C2V4 || 5 || 0,11 € ||?|| CO_015 || N || O || O || O<br />
|-<br />
|Pierre G|| Câble audio SpeaKa 1m mf||986736 - 62 || 2||6,66 ht || ? || CO_015 || N || O || O || O<br />
|-<br />
|Pierre G|| Câble audio SpeaKa 0,50m mf||986735 - 62 || 1||5.92 ht || ? || CO_015 || N || O || O || O<br />
|-<br />
|Pierre G|| Lentille Dialight OPC-11SPOT transparent 10 ° 1 pc(s)||1127266 - 62 || 1||3 ht || ? || CO_016 || N || O || O || O<br />
|-<br />
|Pierre G|| LED High Power Barthelme 61003528 blanc chaud||1503528 - 62 || 1||3,50 ht || ? || CO_016 || N || O || O || O<br />
|-<br />
|FredericD|| [http://www.conrad.fr/ce/fr/product/574223/Transformateur-electronique-Standard-10-a-60-W Transformateur électronique "Standard" 10 à 60 W]||574223 - 62 || 1||15,49 '''TTC''' || <acheteur> || CO_017 || N || N || N || N<br />
|-<br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/542044/?insert=32&insertNoDeeplink&productname=Gaine-thermoretractable-pour-batteries-sans-colle-21-Conrad-Components-542044-transparent-avant-retreint-44-mm-1-pc Gaine thermorétractable 2:1 transparente pour accus longueur 100 cm largeur 44mm]</s>||<s>542044 - 32</s>||<s>3</s>||<s>2,70€TTC</s>||<s> <acheteur> </s>||<s> CO_017 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/100297/Solution-conductrice-1413-S-HI-70031-P?ref=list Solution conductrice 1413 µS HI 70031 P]</s>||<s>100297 - 62 </s>||<s> 1 </s>||<s> € 33,60 TTC</s>||<s> <acheteur> </s>||<s> CO_017 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|<s>Eric</s>||<s>[http://www.conradpro.fr/ce/fr/product/1305022/Diode-Zener-PanJit-1N4740A-G-DO-41G-Tension-Zener-10-V-1-pcs?ref=searchDetail Diode Zener PanJit 1N4740A-G DO-41G Tension Zener: 10 V]</s>||<s>1305022 - 62 </s>||<s> 10 </s>||<s> € 0,15 TTC</s>||<s> <acheteur> </s>||<s> CO_017 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/812811/tain-de-soudure-teneur-en-plomb-Stannol-HS-10-Sn60Pb39Cu1-bobine-100-g-10-mm?queryFromSuggest=true étain 100g 1mm STANNOL]|| 812811 - 62 || 2 || 7,55 € H.T. ||<acheteur>|| CO_017 || N || N || N || N<br />
|-<br />
|Eric||[http://www.conrad.fr/ce/fr/product/651105/XLR-Bride-mle-contacts-couds-Neutrik-NC3MAAH-Nombre-de-ples-3-noir-1-pcs?queryFromSuggest=true Connecteur XLR mâle plastique pour chassis soudage pour CI 3 broches coudé + blindage, NEUTRIK NC3MA(A)H ]||651105 - 62|| 2 || 1,20€TTC ||<acheteur>||CO_017||N||N||N||N <br />
|-<br />
|}<br />
<br />
Anciennes commandes Conrad archivées [[Projets:Commande_groupee:archives#Conrad_Electronique_France|ici]]<br />
<br />
=== [http://www.damencnc.com/fr DamenCNC] ===<br />
<br />
Accessoires pour machines CNC [http://www.damencnc.com]<br />
<br />
La prochaine commande a pour référence interne : DC_002<br />
<br />
Prochaine date de commande : ?? (probablement en octobre 2014)<br />
<br />
Commande passée en attente de livraison :[aucune]<br />
<br />
Commande livrée en cours de distribution : [aucune] <br />
<br />
Livraison : depuis les Pays-Bas par UPS : estimation : 20€ pour un colis de 1.5kg<br />
<br />
ATTENTION : Prix HT.<br />
<br />
Anciennes commandes DamenCNC archivées [[Projets:Commande_groupee:archives#DamenCNC|ici]]<br />
<br />
{|class="wikitable sortable" style="font-size:85%"<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref DamenCNC!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
<!-- Pour ajouter une ligne, copier les 2 lignes suivantes (celles qui commencent par | ) à la suite du tableau et remplacer le contenu des colonnes par ce qui semblera adéquat<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||<Acheteur>|| OT_XXX || N || N || N || N<br />
|-<br />
--><br />
|-<br />
|Goldo|| HIWIN HGR Profile Rail L=200mm || HG15R || 2 || 21,60€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|Goldo|| HIWIN Carriage HGH "Compact type" || HGH-15CA || 2 || 33.99€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|Goldo|| Mini Mill 2 flutes 0.20mm || ? || 1 || 11.99€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|Goldo|| Mini Mill 2 flutes 0.30mm || ? || 1 || 11.99€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|Goldo|| Mini Mill 2 flutes 0.50mm || ? || 1 || 9.99€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|Goldo|| Kress Collet + Clamp Nut 1/8inch || ? || 1 || 19.99€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|F1CHF|| Mini Mill 2 flutes 0.50mm || ? || 2 || 9.99€HT || Goldo || DC_001 || N || O || O || O<br />
|-<br />
|F1CHF|| Mini Mill 2 flutes 0.70mm || ? || 2 || 9.99€HT || Goldo || DC_001 || N || O || O || O<br />
|-<br />
|Eric||IPS_Cable_Assembly M12_Straight_Female/OPENEND_3meter || ? || 2 || 4.99€HT || <acheteur>|| DC_002 || N || N || N || N<br />
<br />
! !! !! !! !! !! !! !! !! !! !!<br />
|}<br />
<br />
===[http://www.detandt.com/fr Detandt-Simon]===<br />
<br />
La prochaine commande aura pour référence interne : DET_001 <br />
<br />
Prochaine date de commande : Mardi 2/2/2016<br />
<br />
<br />
Commande livrée en cours de distribution : [nada] <br />
<br />
Anciennes commandes Detandt archivées [nope]<br />
<br />
Frais de livraisons: inconnu<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Taille !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!!Remboursé/Archive (O/N)<br />
|-<br />
<!-- Pour ajouter une ligne, copier les 2 lignes suivantes (celles qui commencent par | ) à la suite du tableau et remplacer le contenu des colonnes par ce qui semblera adéquat--><br />
| Steve|| Modèle haut Bleu et gris || Taille 44 || 1|| 15€ HT||Steve|| DET_001 || N || N || N || N<br />
|-<br />
| Steve|| Modèle haut Bleu et gris || Taille 45 || 1|| 15€ HT||Steve|| DET_001 || N || N || N || N<br />
|-<br />
| Laurent d. Lo^2 || Modèle haut orange et noir || Taille 44 || 1|| 15€ HT||Laurent|| DET_001 || N || N || N || N<br />
|-<br />
| Laurent d. Lo^2 || Modèle cuir noir || Taille 44 || 1|| 15€ HT||Laurent|| DET_001 || N || N || N || N<br />
|-<br />
| Beatrice/LK999 || Modèle cuir noir ou bas || Taille 45|| 1|| 15€ HT||XXX|| DET_001 || N || N || N || N<br />
|-<br />
| Le Xav || Modèle noir & orange haut || Taille 45|| 1|| 15€ HT||XXX|| DET_001 || N || N || N || N<br />
|-<br />
| Patrick|| 10m gaine VMC alu D80 M0|| HALUM0 82|| 2|| 13,78€ HT||XXX|| DET_002 || N || N || N || N<br />
|-<br />
| Patrick|| 10m gaine VMC alu D125 M0|| HALUM0 127|| 1|| 15,96€ HT||XXX|| DET_002 || N || N || N || N<br />
|-<br />
|}<br />
<br />
===[http://www.digikey.com/ Digikey Corporation]===<br />
<br />
La prochaine commande aura pour référence interne : DI_006<br />
<br />
Prochaine date de commande : <non défini><br />
<br />
Commande passée en attente de livraison : DI_005 <br />
<br />
Commande livrée en cours de distribution : NEANT <br />
<br />
Anciennes commandes Digikey Corporation archivées [[Projets:Commande_groupee:archives#Digikey Corporation|ici]]<br />
<br />
"PAS DE FRAIS POSTAUX sur toutes commandes avec une valeur de 65 Euro et plus.mais la DOUANE + frais"<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Digikey !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!!Remboursé/Archive (O/N)<br />
|-<br />
| Laurent(C) || Capa 470uF || 493-1493-ND || 24 || 0,229€||Laurent(C)|| DI_005 || || O || N || N<br />
|-<br />
| Laurent(C) || Carte NUCLEO-F303K8 || 497-15981-ND || 1|| 9,92€||Laurent(C)|| DI_005 || || O || N || N<br />
|-<br />
| Laurent(C) || Capa tantale 10uF || 478-8959-1-ND || 5|| 0.8€||Laurent(C)|| DI_005 || || O || N || N<br />
|-<br />
| Laurent(C) || PMIC 4V || MCP1702T-4002E/CBCT-ND|| 5|| 0.43€||Laurent(C)|| DI_005 || || O || N || N<br />
|-<br />
| Eric||[http://www.digikey.fr/product-search/fr?vendor=0&keywords=LT1677CS8%23PBF-ND LT1677 OPAMP S8 Package]|| LT1677CS8#PBF-ND || 4|| 3.95€||Laurent(C)|| DI_005 || O || O || N || N<br />
|-<br />
| Eric|| [http://www.digikey.com/product-detail/en/4664-6001/MPK64K-ND/138341 connecteur HE10 64 broches autodénudant mâle] || MPK64K-ND || 1|| 12.59€||Laurent(C)|| DI_005 || O || O || O || O<br />
|-<br />
| Eric|| [http://www.digikey.fr/product-detail/fr/DS2740U%2B/DS2740U%2B-ND/1197488 MAXIM coulombmetric counter DS2740U+ SMD]|| DS2740U+-ND || 1|| 3.90€||Laurent(C)|| DI_005 || O || O || O || O<br />
|-<br />
| Eric|| C190 case ||614-1102-ND||1||199,99USD||Laurent(C)|| DI_005 || O || N(export restriction!) || N || O<br />
|-<br />
| papy F1CHF || NB3N502 || NB3N502DGOS-ND ||4||2.99€||Laurent(C)|| DI_005 || N || O || O || O<br />
|-<br />
| Eric|| [http://www.digikey.com/product-detail/en/linear-technology/LT1763CS8-TRPBF/LT1763CS8-TRPBFCT-ND/4247570 LT1763CS8#TRPBF LT micropower low noise LDO ADJ regulator 500MA SO8]|| LT1763CS8#TRPBFCT-ND || 1|| 4.78USD||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| Eric|| [http://www.digikey.com/product-detail/en/linear-technology/LT1763CS8-3.3-TRPBF/LT1763CS8-3.3-TRPBFCT-ND/4247566 LT1763CS8-3.3#TRPBF LT micropower low noise LDO 3.3V regulator 500MA SO8]|| LT1763CS8-3.3#TRPBFCT-ND|| 2|| 4.78USD||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| Eric|| [http://www.digikey.fr/products/fr?keywords=BA5406 BA5406 Amplifier IC 2-Channel (Stereo) Class AB 12-SIP-M] ||BA5406-ND || 1|| 3.85 EUR||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| Eric|| [https://www.digikey.fr/products/fr?keywords=HR1732-ND HIROSE CONN PLUG 5POS W/PIN INSERT ref "RM12BPE-5PH(71)"] ||HR1732-ND || 1|| 11.19 EUR||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| Eric|| [https://www.digikey.fr/product-detail/fr/infineon-technologies/IRS2453DPBF/IRS2453DPBF-ND/1189713 INFINEON IC DRIVER FULL SELF OSC 14-DIP IRS2453DPBF] ||IRS2453DPBF-ND || 1|| 3.09 EUR||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| 3dsman|| US5881LUA Digital Switch Unipolar Switch Open Drain Hall Effect TO-92UA ||US5881LUA-AAA-000-BU-ND || 5|| 1.10 EUR||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| Debutant|| [https://www.digikey.fr/product-detail/fr/jst-sales-america-inc/SYF-001T-P0.6-LF-SN/455-2652-1-ND/2796952 JST Sales America Inc. SYF-001T-P0.6(LF)(SN) ] || 455-2652-1-ND || 100|| 0.05460 EUR|| Debutant || DI_006 || N || N || N || N<br />
|-<br />
| Lo2|| [https://www.digikey.fr/product-detail/en/molex-llc/0755860006/WM22014CT-ND/9095459 Molex Connecteur 50POS SMD] || WM22014CT-ND || 3|| 8.47 EUR|| Lo2 || DI_006 || N || N || N || N<br />
|-<br />
<br />
|}<br />
<br />
=== [http://www.doga.fr Doga] ===<br />
<br />
La prochaine commande aura pour référence interne : DO_004<br />
<br />
Prochaine date de commande : [inconnu]<br />
<br />
Commande passée en attente de livraison : [aucune]<br />
<br />
<br />
<br />
Minimum de commande : 50€ HT<br />
Franco : 100€ HT<br />
<br />
Merci de préciser le catalogue dans lequel se trouve l'article pour le retrouver plus aisément. <br />
<br />
Les principaux catalogues sont :<br />
* http://www.doga.fr/catalogue_pdf/ugv.pdf<br />
* http://www.doga.fr/catalogue_pdf/ugv-alliage-leger.pdf<br />
* [https://shop.precitool.de/bk/WKZ_2018-2019/#page_0.1 Precitool (catalogue 'Outillage')]<br />
<br />
Anciennes commandes Doga archivées [[Projets:Commande_groupee:archives#Doga|ici]]<br />
<br />
<br />
|-<br />
!Demandeur !! class="unsortable"| Description !!class="unsortable"| Ref Doga !! class="unsortable"| Catalogue !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!!Remboursé/Archive (O/N)<br />
<br />
<br />
|-<br />
| Eric||[http://shop.precitool.de/bk/HKL_2016-2017/#page_870 Ø 8mm Zylinderbürste mit Öse, Messingdraht gewellt marque : LESSMANN]|| 481772 || Precitool || 1 || 7 EURHT || <acheteur> || DO_002 || N || O || O || O<br />
|-<br />
| <s>Eric</s>||<s>[http://shop.precitool.de/bk/HKL_2015-2016/#page_1044 Kompakt-Bolzenscheider KNIPEX Mit Mehrkomponenten-Hülle, Öffnungsfeder, 20° abgewinkelt]</s>||<s> 559026</s> ||<s> Precitool </s>||<s> 1 </s>||<s> 40.45EURHT</s> ||<s> <acheteur> </s>||<s> DO_002 </s>||<s>N</s> ||<s>N</s>||<s> N </s>||<s> N</s><br />
|-<br />
| Eric||[http://shop.precitool.de/bk/HKL_2016-2017/#page_924 Strinlochschlüssel-Satz marque AMF]|| 506050|| Precitool || 1 || 31.05EURHT || <acheteur> || DO_002 || N || O || O || O<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1116 KNIPEX Montagezange Typ 4521 für Sprengringe auf Wellen (KNIPEX Ref 45 21 200)]||554175 /4521|| Precitool || 1 || 30,75EURHT || <acheteur> || DO_002 || N || O || O || O<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2016-2017/#page_1242 Schneidoel 500ml]||924055|| Precitool || 1 || 14,35EURHT || <acheteur> || DO_002 || N || O || O || O<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2016-2017/#page_1254 Luftweiche 3 Fach (4 x G3/8) Typ 0304]||925805/0304|| Precitool || 2 || 7.05EURHT || <acheteur> || DO_002 || N || O || O || O<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_35 Spiralbohrer HSS-Co Precitool D1897 INOX Dn 2,1mm]||100670/2,10|| Precitool || 5 || 1.91 EURHT || Lab || DO_003 || N || O || O (livré en 2.3mm, puis relivré gratuitement en 2,1mm) || O<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_815 Düsenlehre 0.45-1.5mm (0.05mm steigung)]||389850/20|| Precitool || 1 || 12.65 EURHT || Lab || DO_003 || N || O || O || O<br />
|-<br />
|Steve||[http://shop.precitool.de/bk/HKL_2017-2018/#page_987 Gelenk-Hakenschlüssel]||506350/22-35|| Precitool || 1 || 13.55 EURHT || Lab || DO_003 || N || N || N || N<br />
|-<br />
|Steve||[http://shop.precitool.de/bk/HKL_2017-2018/#page_987 Gelenk-Hakenschlüssel]||506350/35-60|| Precitool || 1 || 14.90 EURHT || Lab || DO_003 || N || N || N || N<br />
|-<br />
|Steve||[http://shop.precitool.de/bk/HKL_2017-2018/#page_987 Gelenk-Hakenschlüssel]||506350/60-90|| Precitool || 1 || 17.70 EURHT || Lab || DO_003 || N || N || N || N<br />
|-<br />
|Lab||[http://shop.precitool.de/bk/HKL_2017-2018/#page_985 Hakenschlüssel aus spezial Stahl Gehärtet und im Brunierton angelassen, pour Ø 95-100 mm, pour écrous DIN 1804 et DIN 981]||506200 95/100|| Precitool || 1 || 10,80 EURHT || Lab|| DO_003 || N || O || O (erreur de reference de commande) || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_985 Hakenschlüssel aus spezial Stahl Gehärtet und im Brunierton angelassen, pour Ø 95-100 mm, pour écrous DIN 1804 et DIN 981]||506200 95/100|| Precitool || 1 || 10,80 EURHT || Lab || DO_003 || N || O || O (erreur de reference de commande) || O<br />
<br />
|-<br />
|Lab||[http://shop.precitool.de/bk/HKL_2017-2018/#page_1153 Jeu de chasse-goupilles - Splintentreiber]|| 561110/6M || Precitool || 1 || 18.05 EURHT || Lab || DO_003 || N || N || N || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Linksausdreher Grosse 1 (für M3-M6)]||590950/1|| Precitool || 3 || 1,35 EURHT || Lab || DO_003 || N || O || O || O<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Linksausdreher Grosse 2 (für M6-M8)]||590950/2|| Precitool || 2 || 1,35 EURHT || Lab || DO_003 || N || O || O || O<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Linksausdreher Grosse 3 (für M8-M11)]||590950/3|| Precitool || 2 || 1,54 EURHT || Lab|| DO_003 || N || O || O || O<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Schaubenausdreher/Linksausdreher "Super Traktion" Grosse T1 (pour Ø 4-5 mm, perçage 2.1 mm)]||590970/T1|| Precitool || 3 || 4.47 EURHT || Lab || DO_003 || N || O || O || O<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Schaubenausdreher/Linksausdreher "Super Traktion" Grosse T2 (pour Ø 5-7 mm, perçage 3.2 mm )]||590970/T2|| Precitool || 3 || 4.58 EURHT || Lab || DO_003 || N || O || O || O<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Schaubenausdreher/Linksausdreher "Super Traktion" Grosse T3 (pour Ø 8-12 mm, perçage 4.5 mm )]||590970/T3|| Precitool || 3 || 5.70 EURHT || Lab || DO_003 || N || O || O || O<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/WKZ_2018-2019/#page_35 Spiralbohrer HSS-Co Precitool D1897 INOX Dn 8,6mm]||100670/8,60|| Precitool || 2 || 7.14 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/WKZ_2018-2019/#page_35 Spiralbohrer HSS-Co Precitool D1897 INOX Dn 8,7mm]||100670/8,70|| Precitool || 2 || 7.14 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/WKZ_2018-2019/#page_35 Spiralbohrer HSS-Co Precitool D1897 INOX Dn 6,4mm]||100670/6,40|| Precitool || 2 || 5,17 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/WKZ_2018-2019/#page_35 Spiralbohrer HSS-Co Precitool D1897 INOX Dn 9,8mm]||100670/9,80|| Precitool || 2 || 9.65 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/WKZ_2018-2019/#page_930 Gelenk-Hakenschlüssel verstellbar, mit Nase, gehärtet und im Brünierton angelassen; für AuBen Ø (Mutter) 20-35 mm]||506300/20-35|| Precitool || 1 || 11.55 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/WKZ_2018-2019/#page_930 Gelenk-Hakenschlüssel verstellbar, mit Nase, gehärtet und im Brünierton angelassen; für AuBen Ø (Mutter) 35-60 mm]||506300/35-60|| Precitool || 1 || 12.35 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/WKZ_2018-2019/#page_930 Gelenk-Hakenschlüssel verstellbar, mit Nase, gehärtet und im Brünierton angelassen; für AuBen Ø (Mutter) 60-90 mm]||506300/60-90|| Precitool || 1 || 16.05 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2018-2019/#page_1155 Schaubenausdreher/Linksausdreher "Super Traktion" Grosse T4 (pour Ø 12-14 mm, perçage 6.5 mm )]||590970/T4|| Precitool || 3 || 6.89 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2018-2019/#page_1155 Schaubenausdreher/Linksausdreher "Super Traktion" Grosse T5 (pour Ø 16-20 mm, perçage 8.5 mm )]||590970/T5|| Precitool || 3 || 9.00 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/WKZ_2018-2019/#page_761 Düsenlehre 1.5-3,0mm (0.1mm Steigung)]||389850/16|| Precitool || 1 || 13.55 EURHT || <acheteur>|| DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/WKZ_2018-2019/#page_940 Verlängerung 1/4" Typ 870 Marke : HAZET ]||511186|| Precitool || 1 || 20.50 EURHT || <acheteur>|| DO_004 || N || N || N || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2018-2019/#page_895 Einmaulschlüssel DIN894 SW : 13 mm ]||500602/13|| Precitool || 1 || 1.27 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|}<br />
<br />
=== [http://fr.farnell.com Farnell] ===<br />
<br />
Livraison gratuite au dessus de 30€ HT<br />
<br />
La prochaine commande aura pour référence interne : FA_017<br />
<br />
<br />
Prochaine date de commande : <à définir><br />
<br />
Commande passée en attente de livraison : <aucune><br />
<br />
Anciennes commandes Farnell archivées [[Projets:Commande_groupee:archives#Farnell|ici]]<br />
<br />
|-<br />
| Demandeur || class="unsortable"| Description || Ref Farnell || class="unsortable"| Quantité || class="unsortable"| Prix unitaire || Acheteur || Commande<br/>n° || Payé<br/>d'avance<br/>(O/N)|| Commandé<br/>(O/N)|| Distribué<br/>(O/N)|| Remboursé/<br/>Archive<br/>(O/N)<br />
|-<br />
|-<br />
|-<br />
| Claire Poisson || CD4011BM96 || 2114002 || 15 || 0,313 TTC || 3dsman ||FA_015 ||N ||O ||N ||N<br />
|-<br />
|-<br />
| 3dsman || Câble multiconducteur blindé || 2425036 || 10 || 0,85 TTC || 3dsman ||FA_015 ||N ||O ||N ||N<br />
|-<br />
|-<br />
| Steve (Pour lab/smoothie) || NXP LPC 1769 || 2072199 || 1 || 8,68 TTC || 3dsman ||FA_015 ||N ||O ||O ||N<br />
|-<br />
|-<br />
| Dom (Rude ULM) || Connecteur d'alimentation DC, Mâle, 2 A, 9.5 mm, Montage sur câble, 1.7 mm || 1737255 || 2 || 2.87 TTC || 3dsman ||FA_015 ||N ||O ||N ||N<br />
|-<br />
|-<br />
| Steve || MCP1702T-5002E/MB - Régulateur LDO 5V SOT89-3 || 1605559 || 3 || 0.593 || 3dsman ||FA_015 ||N ||O ||O ||N<br />
|-<br />
|-<br />
| Steve || RELAY, SPDT, 250VAC, 12A || 1714771 || 2 || 2.27E|| 3dsman ||FA_015 ||N ||O ||O ||N<br />
|-<br />
|-<br />
|-<br />
| Steve (Pour lab/smoothie) || LDO LM1117 3.3V || 2323580 || 5 || 0.907 || Ph. Gras||FA_016 ||N ||O ||O ||N<br />
|-<br />
| Eric ||[http://fr.farnell.com/amphenol-sine-tuchel/t-3424-501/fiche-libre-6-voies/dp/1123507 Connecteur 6 broches Amphénol avec serrage baillionnette ref T 3424 501] || 1123507 || 1 || 5,12 || Ph. Gras ||FA_016 ||N ||O ||O ||N<br />
|-<br />
| Eric ||[http://fr.farnell.com/nkk-switches/b18jp/switch-toggle-spdt-0-1a-28vac/dp/2374722?ost=2374722&ddkey=http%3Afr-FR%2FElement14_France%2Fsearch Commutateur 3 positions miniature SPDT, 0.1A, 28VAC On-Off-On NKK Switch ref B18JP ] || 2374722|| 2 || 3,98 EUR || Ph. Gras ||FA_016 ||N ||O ||O ||N<br />
|-<br />
| Ph. Gras||[http://fr.farnell.com/jst-japan-solderless-terminals/phr-2/boitier-2-voies-2mm/dp/3616186 Boîtier de connecteur, Série PH, Embase, 2 Voies, 2 mm, Contacts à sertir Série BPH et SPH ] || 3616186|| 100 || 0,0324 EUR || Ph. Gras||FA_016 ||N ||O ||O ||O<br />
|-<br />
| Ph. Gras||[http://fr.farnell.com/jst-japan-solderless-terminals/sph-002t-p0-5s/contact-0-05-0-22mm-cut-reel/dp/1671245?st=SPH-002T-P0.5S Contact, Série PH, Femelle, Sertissage, 24 AWG, Contacts plaqués étain, Connecteurs PH ] || 1671245|| 250|| 0,0208 EUR || Ph. Gras ||FA_016 ||N ||O ||O ||O<br />
|-<br />
| Ph. Gras||[http://fr.farnell.com/on-semiconductor/lm317ahvt/regulateur-ldo-ajustable-1-5a/dp/1564497?st=lm317LM317AHVT Régulateur de tension positive ajustable 1.2V à 37V, 1.5A en boîtier TO-220-3 ] || 1564497|| 10|| 0,727 EUR || Ph. Gras ||FA_016 ||N ||O ||O ||O<br />
|-<br />
|-<br />
|-<br />
| <demandeur> ||[http://wiki.electrolab.fr/Projets:Commande_groupee#Glossaire <article>] || <fa_cde_nb> || <quantité> || <prix> || <acheteur> ||FA_017 ||N ||N ||N ||N<br />
|-<br />
|-<br />
|}<br />
<br />
=== [http://www.gotronic.fr Gotronic] ===<br />
<br />
la prochaine commande a la référence interne GO_003<br />
<br />
<br />
Commande passée en attente de livraison :GO_002 le 31/05/2017 par Ellyan<br />
<br />
<br />
Anciennes commandes Gotronic archivées [[Projets:Commande_groupee:archives#Gotronic|ici]]<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref gotronic!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||<Acheteur>|| GO_XXX || N || N || N || N<br />
|-<br />
--><br />
| Damien H || Solénoïde 12 Vcc || LS1110BD || 1 || 7,00€||Ellyan|| GO_002 || N || O || N || N<br />
|}<br />
<br />
=== HighVoltageShop ===<br />
<br />
La prochaine commande a pour référence interne : HV_002<br />
<br />
5 euros de réduction sur la prochaine commande<br />
<br />
Prochaine date de commande : Aucune<br />
<br />
Commande passée en attente de livraison : Aucune<br />
* frais de port 20 euros<br />
* Livraison mardi 7 janvier 2014 au lab<br />
<br />
Commande livrée en cours de distribution : HV_001 (08/12/2013) <br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref ebay!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||David|| DI_XXX || N || N || N || N<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| Thomas || Cable HV 120 kV || 271261265516 || 1 || 8,69€||David|| HV_001 || O || O || O || N<br />
|-<br />
|David||-30kV HV-Generator Modul 12VDC||281162933827||1||34,99€||David||HV_001||O||O||O||N<br />
|-<br />
|David||5 Stk. Zeilentrafo - Flyback Transformer - Zeilentrafos||281024817841||1||24,99€||David||HV_001||O||O||O||N<br />
|-<br />
|David||+30kV HV-Generator Modul 12VDC||281162933829||1|| 34,99€||David||HV_001||O||O||O||N<br />
|-<br />
|CitronVert||-30kV HV-Generator Modul 12VDC||281162933827||2||34,99€||David||HV_001||N||O||O||N<br />
|-<br />
| Goldo || Regelbares Hochspannungsnetzteil 50kV Strombegrenzung || 280941865340 || 1 || 119,99€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || +30kV HV-Generator Modul 12VDC || 281162933829 || 1 || 34,99€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Zenos || +30kV HV-Generator Modul 12VDC || 281162933829 || 1 || 34,99€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || Cable HV 120 kV || 271261265516 || 1 || 8,69€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || Hochspannungskabel 40kV 1m || 271261265512 || 1 || 4,61€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || Hochspannungswiderstand 20kV 1 GigaOhm Messwiderstand || 280941865344 || 1 || 6,34€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || Hochspannungswiderstand 20kV 100 MegaOhm || 271106455991 || 1 || 6,34€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || Hochspannungswiderstand 20kV 1 MegaOhm || 281026497192 || 1 || 6,34€||David|| HV_001 || O || O || O || N<br />
|}<br />
<br />
=== [http://www.limpulsion.fr/web/index.php L'impulsion] ===<br />
<br />
[http://v1.limpulsion.fr/docpdf/2008_cat/bpoa_a.pdf Catalogue "accessoires de test"]<br />
<br />
La prochaine commande a la référence interne LI_002<br />
<br />
Prochaine date de commande : [à définir]<br />
<br />
<br />
Commande livrée en cours de distribution :[aucune]<br />
<br />
Anciennes commandes Limpulsion archivées [[Projets:Commande_groupee:archives|ici]]<br />
<br />
<br />
{|class="wikitable sortable" style="font-size:80%"<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref L'impulsion!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-<br />
|Lab||ADAPTATEUR D'AXE HM8001-2 HAMEG||760000500||1||2.30HT||Yannick||IL_001||N||N (plus livrable)||N||O<br />
|-<br />
|Lab||TRESSE A DESSOUDER NO CLEAN 2.8mm/3m||730.14||10||1.56HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||Entretoise plastique grise de montage en saillie marque "Electro-PJP" pour douilles 4mm type 3265, ref EPJP : 3282||<pas au catalogue: demander si livrable> ||16||? ||Yannick||IL_001||N||N (apparement pas dispo)||N||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou NOIR, ref3265-I-0 ||326500||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou MARRON, ref3265-I-1 ||326501||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou ROUGE, ref3265-I-2 ||326502||3||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou BLEU, ref3265-I-6 ||326506||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou VIOLET, ref3265-I-7 ||326507||3||1.48HT||Yannick||IL_001||O||O||N||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou GRIS, ref3265-I-8 ||326508||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou BLANC, ref3265-I-9 ||326509||3||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou JAUNE/VERT, ref 3265-I-J/V||326510||1||1.74HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||[http://v1.limpulsion.fr/docpdf/2008_cat/bpoe_a.pdf#page=9 Passe fil classique intérieur :12mm, Perçage: 18mm, Epaisseur :10mm (lot de 10pcs)]||252.162||1||1,95EURHT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||Entretoise plastique grise de montage en saillie marque "Electro-PJP" pour douilles 4mm type 3265, ref EPJP : 3282||<pas au catalogue: demander si livrable> ||16||? ||Yannick||IL_001||N||N(apparement pas dispo)||N||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou NOIR, ref3265-I-0 ||326500||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou MARRON, ref3265-I-1 ||326501||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou ROUGE, ref3265-I-2 ||326502||3||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou BLEU, ref3265-I-6 ||326506||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou VIOLET, ref3265-I-7 ||326507||3||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou GRIS, ref3265-I-8 ||326508||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou BLANC, ref3265-I-9 ||32650||3||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou JAUNE/VERT, ref 3265-I-J/V||326510||2||1.74HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||CLE EXTERNE POUR DOUILLE DE SECURITE||3299||1||13.51HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||TRANSFO FERRITE POUR THT HM1005 HAMEG (plus livrable) ||THTHM1005||1||16.77HT||Yannick||IL_001||N||N (plus livable)||N||O<br />
|-<br />
|Eric||Lot de 100 douilles pour C.I diam4 Long 10mm à souder Electro-PJP ref 20054||20054||1||7,95 EUR HT||Yannick||LI_001||N||O||O||O<br />
|-<br />
<br />
|Eric||CI SN75492 (7 segm DRIVER) TEXAS DIP14||75492||13||1.29HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||CI 74LS164 TEXAS DIL||74LS164||2||0.76HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||IPROBER520||IPROBER520||1||594HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|}<br />
<br />
=== [https://shop.mchobby.be/ MCHobby] ===<br />
<br />
La prochaine commande a pour référence interne : MCH_001<br />
<br />
Prochaine date de commande : <Mardi 20 ou mercredi 21 au plus tard ><br />
<br />
Livraison gratuite en Mondial Relay à partir de 75 euros.<br />
<br />
<br />
<br />
Anciennes commandes MCHobby archivées [[Projets:Commande_groupee:archives#MCHobby|ici]]<br />
<br />
Site WEB de MCHobby : https://shop.mchobby.be/<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Mon Droguiste !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||<Acheteur>|| MC_XXX || N || N || N || N<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| LienRag|| Divers ||Divers || ++|| 75€||<acheteur>|| MHC_001 || N|| N || N || N<br />
|}<br />
<br />
<br />
=== [http://217.34.103.131/homepage/homepage.html Mini-Circuits] ===<br />
<br />
La prochaine commande a pour référence interne : MC_001<br />
<br />
<br />
<br />
<br />
Anciennes commandes Mini-Circuits archivées [[Projets:Commande_groupee:archives#Mini-Circuits|ici]]<br />
<br />
Site WEB de minicircuits : http://www.minicircuits.com/homepage/homepage.html<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Mini-circuits !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| F1CHF || ERA-3 || AMPL || 20 || 1.43€||F1CHF|| MC_001 || N || N || N || N<br />
|-<br />
|-<br />
| F1CHF || ADCH-80+ || coil || 20 || 2.88€||F1CHF|| MC_001 || N || N || N || N<br />
|-<br />
|}<br />
<br />
=== [http://www.mon-droguiste.com/index.cfm Mon Droguiste] ===<br />
<br />
La prochaine commande a pour référence interne : MD_001<br />
<br />
<br />
<br />
<br />
Anciennes commandes Mon Droguiste archivées [[Projets:Commande_groupee:archives#Mon-droguiste|ici]]<br />
<br />
Site WEB de Mon Droguiste : http://www.mon-droguiste.com/index.cfm<br />
<br />
|-<br />
|-l<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| Eric|| Ethylene Diamino Tetraacetic Acide 500g ||Ethylene Diamino Tetraacetic Acide Sac 500g || 1|| 16.95€||<acheteur>|| MD_001 || N|| N || N || N<br />
|}<br />
<br />
=== [http://www.mouser.fr Mouser Electronics]===<br />
<br />
La prochaine commande aura pour référence interne MO_014<br />
<br />
Prochaine date de commande : ?<br />
<br />
<br />
Commande livrée en cours de distribution : MO_013 le 31/05/2017 par Ellyan<br />
<br />
Anciennes commandes Mouser Electronics archivées [[Projets:Commande_groupee:archives#Mouser Electronics|ici]]<br />
<br />
Livraison gratuite (FedEx ou UPS) au delà de 50€ de commande<br />
<br />
<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Mouser !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||<Acheteur>|| DI_XXX || N || N || N || N<br />
|-<br />
--><br />
<br />
|-<br />
|Frederic.D.||[http://www.mouser.fr/ProductDetail/TE-Connectivity/1-826632-0/ Headers & Wire Housings 2X10P DUAL ROW]||571-1-826632-0 ||3 ||1.95 |||| MO_013||O ||O ||O ||N<br />
|-<br />
|Frederic.D.||[http://www.mouser.fr/ProductDetail/Bourns/3306P-1-103/ Trimmer Resistors - Through Hole 10K 25% 6mm Single Turn]||652-3306P-1-103 ||3 ||0.407 |||| MO_013||O ||O ||O ||N<br />
|-<br />
|Frederic.D.||[http://www.mouser.fr/ProductDetail/Schurter/13019302/?qs=%2fha2pyFadugAVCtehZ6ro0we%252bFlHwInvMJ3iEORyekx9pnGrLimsvA%3d%3d Pushbutton Switches SHORT TRAVEL SWITCH 6X6, 5.0MM]||693-1301.9302 ||9 ||0.251 |||| MO_013||O ||O ||O ||N<br />
|-<br />
|Frederic.D.||[http://www.mouser.fr/ProductDetail/Bourns/MF-USMF075-2/ Resettable Fuses - PPTC 0.75A 6V 0.18ohm Hold .75A Trip 1.5A]||652-MF-USMF075-2 ||3 ||0.275 |||| MO_013 ||O ||O||O ||N<br />
|-<br />
|Frederic.D.||[http://www.mouser.fr/ProductDetail/STMicroelectronics/SMA6J50A-TR/?qs=%2fha2pyFadujqXhcCRI4%2fO5BEn9p7pkr6EX0dAQtUlws3JpN%2fE2p9DQ%3d%3d TVS Diodes - Transient Voltage Suppressors HJ Temp Transil]||511-SMA6J5.0A-TR ||3 ||0.38 |||| MO_013 ||O||O||O ||N<br />
|-<br />
|-<br />
|Sylvain V.||[http://www.mouser.fr/ProductDetail/Cirrus-Logic/CS4398-CZZ/?qs=sGAEpiMZZMv%252bLKsN4bqzyhXScoHWAp%252boAQFEBwyfAGo%3d DAC Cirrus Logic]||777-CS4398-CZZ ||1 || 10.46 || Sylvain V. || MO_013 ||O||O||O ||N<br />
|-<br />
|Eric||[https://eu.mouser.com/ProductDetail/Amphenol-Tuchel/T-3427-100?qs=%2fha2pyFaduhPv3s%2fjYa9sAYm3fflPgRKEDSdRTPyUvP7YbNcd%2fVs5g%3d%3d Circular DIN Connectors FEMALE RECEPTACLE 6 WAY, Amphenol series C091B]|| 523-T3427-100 ||1 || 10.29|| <<acheteur>> || MO_014 ||N||N||N ||N<br />
|-<br />
|Eric||[https://www.mouser.fr/ProductDetail/EPCOS-TDK/B32926A4685M?qs=sGAEpiMZZMv1cc3ydrPrF3kXVSi%252b9fyL4PImBI83UxcgTMvwb1977w== Condensateurs à film 6.8uF 20% 350Vac LS 37.5MM Fabricant : EPCOS /TDK ref : B32926A4685M ]|| 871-B32926A4685M ||1 || 10.67|| <<acheteur>> || MO_014 ||N||N||N ||N<br />
|-<br />
|Eric||[https://www.mouser.fr/ProductDetail/Texas-Instruments/OPA2227U-2K5?qs=sGAEpiMZZMtCHixnSjNA6Mrdwin7F8A2DB4TJmgUI0w%3d OPA2227U SOIC8 dual opamp low noise Texas ]|| 595-OPA2227U/2K5 ||2 || 8.07|| <<acheteur>> || MO_014 ||N||N||N ||N<br />
|-<br />
|Eric||[https://eu.mouser.com/ProductDetail/Molex/53253-0570?qs=sGAEpiMZZMvlX3nhDDO4AD1CBCqS4WJ3BaSa47NubxE%3d Shrouded header 5 pins 2mm male through hole board connnector vertical mounting Molex ref. 53253-0570 Cross ref to JST PH "B5B-PH-K-S"]|| 538-53253-0570||20 || 0,164 €|| <<acheteur>> || MO_014 ||N||N||N ||N<br />
|-<br />
|Eric||[https://eu.mouser.com/ProductDetail/Central-Semiconductor/TIP42B?qs=sGAEpiMZZMshyDBzk1%2fWi0MKeUdJDRlz1TXFEdLineJjytqjBdqtHg%3d%3d Bipolar Transistor PNP 10A 80V TIP42B]|| 610-TIP42B ||2 || 0,969 €|| <<acheteur>> || MO_014 ||N||N||N ||N<br />
|-<br />
| Eric|| [https://www.mouser.fr/ProductDetail/Hirose-Connector/RM12BPE-5PH71?qs=sGAEpiMZZMvG94qpybaIZaiKjo18NgShhh8FQGCnH4c%3d HIROSE CONN PLUG Cbl Mount 5 Terminals ref "RM12BPE-5PH(71)"] ||798-RM12BPE-5PH71 || 1|| 11.47 EUR||<acheteur>|| MO_014 || N || N || N || N<br />
|-<br />
| Eric|| [https://www.mouser.fr/ProductDetail/Mueller-Electr/BU-75K?qs=sGAEpiMZZMs4AFwHyzhTm%2f3wHG8LpAJAx37I4fl4y%2fU%3d Kelvin clip 10A Mueller Electric ref. BU-75K] ||548-BU-75K|| 4|| 10.20 EUR||<acheteur>|| MO_014 || N || N || N || N<br />
<br />
|-<br />
|}<br />
<br />
<br />
=== [http://www.motedis.fr/shop/ Motedis France] ===<br />
<br />
<br />
La prochaine commande aura pour référence interne : MS_001<br />
<br />
<br />
<br />
<br />
Anciennes commandes Motedis France archivées [[Projets:Commande_groupee:archives#Motedis France|ici]]<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Motedis!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-<br />
|Eric||Plaquette aluminium 15mm d'épaisseur Largeur: 100mm ||<ref motedis>||L:1000mm|| 24.15EURHT || <acheteur> || MS_001 || N|| N || N || N<br />
|-<br />
|<demandeur>||<description>||<ref motedis>|| <quantité> || <prix>|| <acheteur> || MS_001 || N|| N || N || N<br />
|-<br />
|}<br />
<br />
<br />
===[http://www.nouvelleplastique.it/f/setf.html Nouvelle Plastique]===<br />
La prochaine commande a pour référence interne : NP_001<br />
<br />
Prochaine date de commande : Q3/2014<br />
<br />
<br />
<br />
Anciennes commandes Nouvelle Plastique archivées [[Projets:Commande_groupee:archives#Nouvelle Plastique|ici]]<br />
<br />
La société "[http://www.nouvelleplastique.it/f/setf.html Nouvelle Plastique]" fabrique des systèmes de rangements portables et modulaires en plastique.<br />
Les produits sont souvent bien pensés (parfois mieux que RAACO ou Stanley) et de bonne solidité.<br />
<br />
Malheureusement, ses produits ne sont que rarement distribués par les circuits classiques et pour le moment aucun revendeur de détail en France n'a été identifié. De même, on ne connait pas les prix des produits.<br />
La démarche envisagée est de collecter via le tableau ci-dessous une liste de souhaits afin de pouvoir demander un devis global directement au fabricant d'ici quelques mois (probablement en Q3/2014). En fonction de ses proposition de prix, chacun pourra finalement accepter ou refuser que ses souhaits soient inclus dans la commande définitive. Le coût du port sera partagé au prorata du prix des marchandises achetées (plus il y a de demaneurs, plus le coût individuel du port sera faible).<br />
Pour chaque article, il y a indication d'une UDV (Unité De Vente), c'est à dire de lot indivisible.<br />
Au terme des sélections de vos besoins, il faudra que le nombre de pièces commandées pour chaque article soit un multiple de son UDV.<br />
Le tableau ci-dessous dispose d'une structure adaptée à la gestion des souhaits des demandeurs, du nombre d'article et des UDV.<br />
Tous les demandeurs intéressés par un même article s'inscrivent dans une seule ligne (ce qui conduit au fait qu'il y ait une ligne par référence d'article).<br />
Le champ "PUHT" sera complété une fois le devis obtenu.<br />
<br />
====Légende du tableau ====<br />
<br />
UDV = correspond au nombre d'articles par UDV. = nombre d'articles dans un lot indivisible, cette information est indiquée par le fabricant dans son catalogue. <br />
Reste à affecter = mod(Nombre d'UDV; Nombre d'articles) <br />
<br />
<br />
Si vous éditez une ligne existante pour vous inclure comme demandeur de l'article considéré, modifiez les champs suivants :<br />
*''UDV' *''Nombre d'UDV'' (valeur cumulée d'UDV entre tous les demandeurs) <br />
*''Quantités (nombre d'articles)'' (valeur cumulées en nombre d'articles individuels entre tous les demandeurs) <br />
*''Reste à affecter'' (valeur calculée globalement pour tout les demandeurs) <br />
*''Liste de demandeurs avec (unités)'' Unités = nombre d'articles demandéz<br />
<br />
<br />
{|class="wikitable sortable" style="font-size:99%"<br />
|-<br />
! Ref article!! class="unsortable"| Désignation!! UDV (= nombre d'articles dans un lot indivisible) !! class="unsortable"| Nombre d'UDV!! class="unsortable"| Quantité souhaitée(nombre d'articles) !! Reste à affecter!! PUHT !! Liste de demandeurs avec (unités) !! N° de commande <br />
|-l<br />
|00366|| Tyger maxi double|| 6 || 1 ||6 ||0|| <PU> || Eric (6) || NP_001 <br />
|-<br />
|00361|| Tyger maxi|| 12 || 1 ||6 ||6|| <PU> || Eric (6) || NP_001 <br />
|-<br />
<br />
|}<br />
<br />
=== [https://www.olimex.com/ Olimex]===<br />
<br />
La prochaine commande a pour référence interne : OL_001<br />
<br />
<br />
<br />
<br />
Anciennes commandes Olimex archivées [[Projets:Commande_groupee:archives#Olimex|ici]]<br />
<br />
<br />
Achat par l'intermédiaire de leur site internet: https://www.olimex.com/<br />
<br />
Produits identifiés comme potentiellement intéressants:<br />
* https://www.olimex.com/Products/ARM/TI/TMS570-CAN/ un pti devkit pour un micro bien patator, prévu au départ pour des applications safety mais qui a des périphériques & capacités pas dégueulasses...<br />
* https://www.olimex.com/Products/Modules/Adapters/ pour utiliser leurs modules d'extension avec un launchpad ou un rpi<br />
* https://www.olimex.com/Products/Modules/LCD/ (divers modules LCD)<br />
* https://www.olimex.com/Products/Modules/LCD/MOD-LCD4.3%27%27/ module LCD "complet" avec pti micro sympatoche intégré<br />
* https://www.olimex.com/Products/OLinuXino/ gamme de nanocomputers intégrés & pas chers (type rpi mais en open)<br />
* https://www.olimex.com/Products/Components/Misc/TC-K-TYPE/ thermocouple K <br />
etc...<br />
<br />
<br />
Commande prévue courant mars 2013 par Clem.<br />
Attention, prix HT a priori, et prévoir également frais de port "importants" (environ 20€) à répartir entre les participants à la CG.<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Olimex!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||<Acheteur>|| OL_XXX || N || N || N || N<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| XXX|| XXX || - || - || XXX€||XXX|| OL_001 || N || N || N || N<br />
|-<br />
|-<br />
|}<br />
<br />
=== [http://www.otelo.fr/fr/index.html Otelo] ===<br />
<br />
Outillage bois-métal <br />
<br />
Ports gratuits au delà de 230 € H.T. ou code promo<br />
<br />
La prochaine commande a pour référence interne : OT_004<br />
<br />
Prochaine date de commande : < non définie ><br />
<br />
Commande passée en attente de livraison [AUCUNE]<br />
<br />
<br />
Anciennes commandes Otelo archivées [[Projets:Commande_groupee:archives#Otelo|ici]]<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Otelo!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
|-<br />
--><br />
|-<br />
|lab||TARAUD à main diamètre 14X200 Acier/alu||14104142N1||1|| 14,51€ HT|| <Patrick> || OT_002|| N || O|| O || O<br />
|-<br />
|lab||100 rondelles plates diamètre 8X16 ||36211008||5|| 3,23€ HT|| <Patrick> || OT_002|| N || O|| O || O<br />
|-<br />
|Patrick||Disque à poncer bombé axe 22mm D125 grain 80||54426280||2|| 3,42€ HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|Patrick||boites de rangement 18 sep 375X310X60||PY 69720030||3|| 9,55€ HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|Patrick||jeu d'outils ébavurage||PY 58500009||1|| 7,35€ HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|Patrick||BOMBE GALVA FLASH||PY 73006003||1|| 8,40€ HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|Eric||Tablier de soudeur 90 x 60 cm||PW 75 150 001||1|| 10,90€HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|MAZ24||meule blanche touret||5473014F||1|| 11,40€HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|MAZ24||Meule verte de touret||54571150||1|| 42,40€HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|MAZ24||Bagues adaptation||54703320||4|| 1,09€HT|| <Patrick> || OT_002|| O || O|| O|| O<br />
|-<br />
|Patrick||Mandrin à clef 3-16mm CM2/B18||30140413||1|| 27,25€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Mandrin à clef 1-13mm CM2/B16||30140409||1|| 23,20€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Arbre pour mandrin CM2/B16||30199116||1|| 6,80€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Arbre pour mandrin CM2/B18||30199118||1|| 7,00€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Ecouvillon manche bois 15mm||57169015||1|| 7,70€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Ecouvillon manche bois 25mm||57169025||1|| 8,15€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Ecouvillon à fil 6mm||57169006||1|| 5,24€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Ecouvillon à fil 25mm||57151025||1|| 6,38€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Sylvia||Support articulé ||43130110||1|| 23,77€ HT|| <Patrick> || OT_003|| N || O|| O|| O<br />
|-<br />
|}<br />
<br />
===[http://www.outiz.fr/ Outiz]===<br />
<br />
<br />
Comptoir Guilleraies (Nanterre)<br />
<br />
Du lundi au vendredi 7h - 17h Samedi 8h - 12h<br />
<br />
Téléphone : 01 40 35 77 77<br />
<br />
La prochaine commande aura pour référence interne : OU_001 <br />
<br />
Prochaine date de commande : <non définie><br />
<br />
<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Outiz!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!!Remboursé/Archive (O/N)<br />
|-<br />
| Eric ||[http://www.outiz.fr/sferaco-vanne-a-sphere-laiton-pn25-batiment-ff-3-4-poignee-acier-plate-rouge-580005/p/3806984/ Vanne à poignée plate rouge Genre : FF Ø : 3/4" ] ||3806984 || 1|| 4,54 €HT||<acheteur>|| OU_001 || N || N || N || N<br />
|-<br />
|}<br />
<br />
=== [http://fr.rs-online.com/web/ Radiospares (RS Composants)] ===<br />
<br />
La prochaine commande aura pour référénce interne : RS_012<br />
<br />
<br />
<br />
Commande livrée en cours de distribution : <aucune><br />
<br />
Anciennes commandes Radiospares archivées [[Projets:Commande_groupee:archives#Radiospares|ici]]<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref RS!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||Acheteur|| DI_XXX || N || N || N || N<br />
--><br />
|-<br />
| papy F1CHF||régulateur || 686-9007 || 10 || 0,27€|| <>|| RS_012 || N || N || N || N<br />
|FredericD||[http://fr.rs-online.com/web/p/ldr/9146710/ Silonex, NSL-19M51, CdS, Traversant, TO-18, 20 kΩ → 100 kΩ]||914-6710|| 10 || 1.074€HT ||<>||RS_012||N||N||N||N <br />
|-<br />
|FredericD||[http://fr.rs-online.com/web/p/relais-reed/2562055/ Relais Reed 1NO 12V dc 1 A]||256-2055|| 1 || 5.17€HT ||<>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[http://fr.rs-online.com/web/p/refrigerants/1115853/ Réfrigérant aérosol Cramolin Aérosol 400 ml, -50°C]||111-5853|| 2 || 11.12€HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/accessoires-pour-capteur-de-temperature/0286771/ Presse-étoupe pour Thermocouple]||286-771|| 2 || 9,68€HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|<s>Eric</s>||<s>[https://fr.rs-online.com/web/p/pinces-kelvin/7148263/ Pince Kelvin BU-75K, 10A, noir, fabricant : Mueller]</s>||<s>714-8263</s>||<s> 2</s> ||<s> 19,61€HT</s> ||<s><acheteur></s>||<s>RS_012</s>||<s>N</s>||<s>N</s>||<s>N</s>||<s>N</s> <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/condensateurs-aluminium/8396258 Condensateur électrolytique aluminium radial 10µF, -20%, 50V dc, Traversant, +105°C, WURTH série WCAP-AT1H, 5 (Dia.) x 11mm 5000h 97mA Référence fabricant : 860240672002]||839-6258|| 25 (1 sachet) || 3,90 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/condensateurs-aluminium/8399011 Condensateur électrolytique aluminium radial 47µF, -20%, 63V dc, Traversant, +105°C, WURTH série WCAP-ATUL, 8 (Dia.) x 11.5mm 7000h 360mA ESR: 0.66 Ohms Référence fabricant : 860040774002]||839-9011|| 20 (2 paquets) || 3,12 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/condensateurs-aluminium/8399033 Condensateur électrolytique aluminium 120µF, -20%, 63V dc, Traversant, +105°C, série WCAP-ATUL, 10 (Dia.) x 16mm 7000h 760mA ESR: 0.3 Ohms Référence fabricant : 860040775008]||839-9033|| 20 (4 paquets) || 3,43 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/connecteur-xlr/7259543/ Connecteur XLR femelle plastique pour chassis soudage pour CI 3 broches coudé + blindage avec louet métal, NEUTRIK NC3FAH2]||725-9543|| 2 || 1,97 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/connecteur-xlr/7259549 Connecteur XLR mâle plastique pour chassis soudage pour CI 3 broches coudé + blindage, NEUTRIK NC3MAH ]||725-9549|| 2 || 1,43 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/fusibles-cms-rearmables/5177054/ Fusible CMS réarmable, Littelfuse, 2.2A - 1.1A Référence fabricant : SMD100F-2 MK : 100F]|| 517-7054|| 10 || 0,497 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|<s>Eric</s>||<s>[https://fr.rs-online.com/web/p/roulettes-sur-platine/0819567/ Roulette Pivotante Acier 50mm, Bas profil, 270kg Fabricant : Revvo]</s>|| <s>819-567</s> || <s>4</s>|| <s>34.91 €HT</s> ||<s><acheteur></s>||<s>RS_012</s>||<s>N</s>||<s>N</s>||<s>N</s>||<s>N</s> <br />
|-<br />
|3ds||[https://fr.rs-online.com/web/p/potentiometres/0387896/ Potentiomètre carbone série 23 montage panneau 4K7 B avec interrupteur DPST, axe 6,35mm TE Connectivity ref 23ESB472MMF50AF]||387-896|| 1 || 4,14€HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Louis||[https://fr.rs-online.com/web/p/passe-fils/1366806/ Passe-fils,SES en PVC, Diamètre maximum de câble 3mm Noir ref 01070005010 ]||136-6806|| 1 sachet de 100|| 5,38€HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|}<br />
<br />
<br />
<br />
=== [http://www.stquentin-radio.com/ Saint Quentin radio]===<br />
<br />
La prochaine commande a pour référence interne SQ_002<br />
<br />
<br />
<br />
<br />
Anciennes commandes Saint Quentin Radio archivées [[Projets:Commande_groupee: Saint Quentin radio|ici]]<br />
<br />
Paiement cash par avance à l'acheteur : payez le montant exact, car il n'y a pas de frais annexes<br />
<br />
Frais de port : 0€ (sauf objets lourds) Gare du Nord<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref St Quentin!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
|-<br />
--><br />
|Lab||DOUILLE DE SECURITE 4mm ECROU BLANC, ref3265-I-9 ||326509 ||3||1.80€||<Patrick>||SQ_001||N||O||O||O<br />
|-<br />
|Lab||Fiche DIN 5BR MALE PLASTIQUE 360°||I076||2||1.00€||<acheteur>||SQ_002||N||N||N||N<br />
|-<br />
|Lab||Fiche DIN 5BR CHASSIS METAL 360°||I088||1||1.20€||<acheteur>||SQ_002||N||N||N||N<br />
|}<br />
<br />
=== [http://www.selectronic.fr Selectronic] ===<br />
<br />
La prochaine commande a pour référence interne : SE_010 <br />
<br />
<br />
<br />
<br />
Anciennes commandes Sélectronic archivées [[Projets:Commande_groupee:archives#Selectronic|ici]]<br />
<br />
Frais de port : 0€ (sauf objets lourds)<br />
<br />
Certains produits sont pas en stock à Paris et requièrent d'être livrés de Lille d'où un délai de quelques jours. Le mieux est d'aller au mag à Nation le mardi pour passer la commande et dans ce cas c'est en principe dispo jeudi sur place.<br />
<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description || Ref Sélectronic!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-<br />
|Eric||Résistance CTN 10kOhms 10% format goutte traversant||5277|| 1 || 0.95€TTC|| Eric|| SE_008 || O || O || O || O<br />
|- <br />
|lab||Résistance CTN 10kOhms 10% format goutte traversant||5277|| 1 || 0.95€TTC|| Zenos|| SE_009 || N || O || O || N<br />
|-<br />
|Zenos||triac BT139-600||4024|| 3 || 1,90€TTC|| Zenos|| SE_009 || O || O || O || O<br />
|-<br />
|Lab||TIC106D Thyristor||4018|||1||1,52||<acheteur>|| SE_009 || N || O || N (pas dispo) || N <br />
|-<br />
|Eric||IR IRF9540 MOS canal P -100V -19A||08015|||1||2,50EUR||Zenos|| SE_009 || O || O || O || O<br />
|- <br />
|Eric||Mosfet N IRF640N TO220 200V 0.150Ω - 18A||HD75-940|||2||1,94||<acheteur>|| SE_010 || N || N || N || N<br />
|-<br />
|Marc f6itu||pointes de scope||2447|||4||1,02||<acheteur>|| SE_010 || N || N || N || N<br />
|-<br />
|Lab (Eric)||[http://www.selectronic.fr/joints-adhesif-pour-enceintes.html bande mousse autocollante de largeur 5mm, hauteur 2mm]||2300|||2||5.50||<acheteur>|| SE_010 || N || N || N || N<br />
|-<br />
|-class="sortbottom"<br />
|}<br />
<br />
=== [http://www.sparkfun.com/ SparkFun Electronics]===<br />
<br />
La prochaine commande a pour référence interne SF_002<br />
<br />
Prochaine date de commande : N/A<br />
<br />
<br />
Commande livrée en cours de distribution : SF_001<br />
<br />
<br />
TVA, frais de port et droits de douane + frais pour dossier de dédouanement : selon taille totale de la commande finale, seront ventilés au pro-rata du montant commandé par chacun.<br />
<br />
Anciennes commandes SparkFun Electronics archivées [[Projets:Commande_groupee:archives#SparkFun Electronics|ici]]<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref SparkFun!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
|-<br />
--><br />
|Damien H||Spark Gap Igniter - 4.8V||COM-11218||3||$14,95||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Pilou||MIDI Shield||DEV-09595||1||$19,90||<Damien H>||SF_001||N||O||O||O<br />
|-<br />
|Pilou||OpenServo||ROB-09014||2||$14,95||<Damien H>||SF_001||N||O||O||O<br />
|-<br />
|Pilou||Breakout Board for PCF8575 I2C Expander||BOB-08130||1||$11,95||<Damien H>||SF_001||N||O||O||O<br />
|-<br />
|MAZ24||wire stripper||TOL-08696||1||$4,95||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|MAZ24||flush cutter||TOL-11952||1||$6,95||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Eric||Optical Dust Sensor - GP2Y1010AU0F||COM-09689||1||$11,95||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Eric||Mating Connector Housing for Dust Sensor (JST ref#: ZHR-6)||PRT-09690||2||$0,35||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Eric||Crimp Pins for Dust Sensor Connector (JST ref#: SZH-002T-P0.5)||PRT-09728||16||$0,09||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Eric||Copper Tape - 2" (50ft)||PRT-11081||1||$14,95||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Olga||RaspiRobot Board||KIT-11561||1||$29,95||<Damien H>||SF_001||N||O||N||O<br />
|-<br />
|Dom||Copper Tape - 2" (50ft)||PRT-11081||1||$14,95||||SF_002||N||N||N||N<br />
|-<br />
|Jean-Marc (PdM) || Polymer Lithium Ion Battery - 400mAh || PRT-10718 || 1 || $6.95 || || SF_002 || N || N || N ||N<br />
|-<br />
|Jean-Marc (PdM) || SparkFun USB LiPoly Charger - Single Cell || PRT-12711 || 1 || $14.95 || || SF_002 || N || N || N ||N<br />
|-<br />
|Jean-Marc (PdM) || Precision Disc Wheel - 5" (Yellow, 2 Pack) || ROB-12469 || 1 || $6.29 || || SF_002 || N || N || N ||N<br />
|-<br />
|Jean-Marc (PdM) || Set Screw Hub - 3mm Bore || ROB-12512 || 2 || $4.99 || || SF_002 || N || N || N ||N<br />
|-<br />
|Jean-Marc (PdM) || ProtoBoard - Square 2" || PRT-08811 || 1 || $2.95 || || SF_002 || N || N || N ||N<br />
|-<br />
|Jean-Marc (PdM) || Micro Gearmotor - 90 RPM (6-12V) || ROB-12285 || 2 || $12.95 || || SF_002 || N || N || N ||N<br />
|- <br />
|Jean-Marc (PdM) || SparkFun Solderable Breadboard - Mini || PRT-12702 || 1 || $2.95 || || SF_002 || N || N || N ||N<br />
|- <br />
|}<br />
<br />
=== Subtel.fr ===<br />
<br />
Pas de frais de port, prix TVA comprise<br />
<br />
<br />
<br />
<br />
Anciennes commandes Subtel.fr archivées [[Projets:Commande_groupee:archives|ici]]<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Subtel!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Archive (O/N)<br />
|-l<br />
|-<br />
|}<br />
<br />
=== raspberry-pi-zero ===<br />
Une opportunité dégotée par Francis: une version du raspberry-pi, un peu spartiate, pour 5 euros!<br />
https://www.raspberrypi.org/blog/raspberry-pi-zero/<br />
<br />
On peut également acheter le kit: http://swag.raspberrypi.org/collections/pi-kits/products/pi-zero-cables<br />
C'est le cordon midi-hdmi/hdmi, PLUSSE la barrette gpio.<br />
<br />
Cette entrée est mise en place alors que tout n'est pas défini pour cet achat: ni le fournisseur (fournisseur initial en rupture de stock), ni le prix.<br />
Mais ce sera le support pour rassembler les commandes. Je tiendrai ce paragraphe à jour selon les infos.<br />
<br />
Le kit comprend l'adaptateur micro-hdmi/hdmi (1 cordon + 1 petit adaptateur?), et la barette 2x20, à souder, pour les gpio. Le raspberry n'est pas dans le kit!<br />
<br />
Le prix: 5 euros le kit, idem le raspberry, et quelques pourcent pour les frais de transport. <br />
<br />
(ce soir: site http://swag.raspberrypi.org/ down; ??)<br />
<br />
<br />
On peut aussi attendre 3 semaines le temps que cela soit livré directement chez vous et avoir<br />
<br />
- l'adaptateur micro hdmi mâle- hdmi femelle : http://www.banggood.com/Gold-Plated-Micro-HDMI-Type-D-Male-To-HDMI-Female-Adapter-p-974265.html<br />
<br />
- un adaptateur micro-hdmi vers VGA femelle sans le son : http://www.banggood.com/1080P-HDMI-Male-To-VGA-Female-Adapter-Video-Converter-Cable-p-937626.html<br />
<br />
- un adaptateur micro-hdmi vers VGA femelle avec le son : http://www.banggood.com/Sin-Hon-SH-MH2V02-Micro-HDMI-to-VGA-Cable-Adapter-with-Audio-p-907524.html<br />
<br />
- un adaptateur micro usb coudé(pratique pour ranger sur le côté : http://www.banggood.com/Micro-USB-Host-OTG-Cable-For-Samsung-HTC-p-79909.html<br />
<br />
- pour se faire une prise alim micro usb, on déboîte le capot et on soude : http://www.banggood.com/USB-2_0-Micro-B-Male-to-Mini-B-Female-5-Pins-Adapter-p-956044.html<br />
<br />
- toutes sortes d'alim : http://www.banggood.com/search/usb-2a-charger.html<br />
<br />
- de quoi s'amuser avec les GPIO : http://www.banggood.com/search/gpio-raspberry/1091-0-0-0-0-0-0-price-0-0_p-1.html<br />
<br />
Et si vous avez le temps de chercher c'est encore moins cher sur http://fr.aliexpress.com/<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| raspberry ou kit !! class="unsortable"| Quantité !! class="unsortable"| Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Archive (O/N)<br />
|-l<br />
|-<br />
!Pierre Grommit !!raspb !! 2 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!Pierre Grommit !!kit !! 1 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!Francis Roussel !!rasp !! 2 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!papy F1CHF !!kit !! 4 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!PDA !!rasp !! 3 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!yvs Accard !!rasp !! 3 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!yvs Accard !!Kit !! 1 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!Malek H. !!3 rasp + 2 vga son + 1 gpio + 1 otg !! 1 !! 1 !! n!! n !!n !! n!!<br />
<br />
<br />
|}<br />
<br />
<br />
=== Starterkit FPGA Altera Max10 ===<br />
'''COMMANDE CLOSE'''<br />
<br />
[https://www.arrow.com/en/products/bemicromax10/arrow-development-tools#page-1 Carte de démarrage FPGA] qui sera parfait pour les [[Formations#Initiation_.C3.A9lectronique_num.C3.A9rique_et_FPGA|formation initiation à venir]].<br />
<br />
Cette carte utilise un FPGA entrée de gamme MAX 10 de chez Altera. Elle contient tout un tas de périphériques sympa pour débuter.<br />
<br />
A noter que la board intègre une sonde JTAG Altera Blaster II (>200€ dans le commerce, 20€ pour un clone).<br />
<br />
Le prix: $30 le kit, disons donc 30€ (à réajuster à la baisse post commande). <br />
<br />
Date butoir pour la commande: mercredi 6 avril 2016<br />
<br />
Chip principal: MAX® 10 FPGA (10M08DAF484C8G):<br />
* 8,000 LEs (largement de quoi mettre le soft core 32bit Altera & des périphériques confortables)<br />
* 414 Kbit (Kb) M9K memory<br />
* 256 Kbit (Kb) user flash memory<br />
* 2 phase locked loops (PLLs)<br />
* 24 18x18-bit multipliers<br />
* 1 ADC block – 1 MSa/sec, 12-bit, 18-channels<br />
* 17 analog inputs<br />
* 1 temperature sense diode<br />
* 250 general purpose input/output (GPIO)<br />
* Non-volatile self-configuration with dual-boot support<br />
* Clocking circuitry: 50 MHz oscillator and 24 MHz oscillator<br />
* achetable à l'unité (moins cher de la gamme: 3€, celui ci, 30€)<br />
<br />
External peripherals<br />
* 8MB SDRAM (4Mb x 16) (ISSI IS42S16400)<br />
* Accelerometer, 3-Axis, SPI interface (Analog Devices ADXL362)<br />
* DAC, 12-bit, SPI interface (Analog Devices AD5681)<br />
* Temperature sensor, I2C interface (Analog Devices ADT7420)<br />
* Thermal resistor<br />
* Photo resistor<br />
* 8 user LEDs<br />
* 2 user Pushbuttons<br />
<br />
Prototyping<br />
* Two 6-pin PMOD expansion headers<br />
* Two 40-pin prototyping headers which provide access to 64 digital I/O<br />
* 6 analog inputs<br />
* One 80-pin BeMicro card edge connector<br />
<br />
<br />
Merci d'ajouter votre nom et votre rapport à l'éventualité de formations au lab:<br />
* débutant, intermédiaire, expert: sous entendu je veux assister à une formation & j'ai ce niveau<br />
* formateur: je suis volontaire pour participer à l'élaboration de formations<br />
* pas intéressé: ni en participant ni en formateur<br />
<br />
Merci d'indiquer:<br />
* combien vous en achetez à titre perso (30€ pièce, à revoir selon le change & port)<br />
* si vous voulez en prendre une à offrir aux formations du lab (vous payez 20€, moi 10€ ; il nous faut 10 cartes)<br />
<br />
<br />
'''MISE A JOUR RECEPTION'''<br />
Prix total 40€/carte. 25€ par carte offerte au lab. Merci de vous mettre à jour, et venez récupérer vos cartes auprès de Coline :)<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Formation? !! class="unsortable"| Quantité !! class="unsortable"| cadeau au lab !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Archive (O/N)<br />
|-l<br />
|-<br />
|-<br />
!flax !!formateur!! 1 !! non !! O!! n !!n !! n!!<br />
|-<br />
!flax !!formateur!! 1 !! oui !! O!! n !!n !! n!!<br />
|-<br />
!Clem !!formateur!! 1 !! N/A !! O!! n !!n !! n!!<br />
|-<br />
!3dsman!!débutant !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
!3dsman!!débutant !! 1 !! oui !! n!! n !!n !! n!!<br />
|-<br />
!Yann D!!débutant !! 2 !! non !! n!! n !!n !! n!!<br />
|-<br />
!Yannick A.!!formateur !! 1 !! oui !! n!! n !!n !! n!!<br />
|-<br />
!Yannick A.!!formateur !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
!F1HSU!!débutant !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
!Roul!!formateur? !! 1 !! oui !! n!! n !!n !! n!!<br />
|-<br />
!Roul!!formateur? !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
!Jojo du VoLAB !!intermédiaire !! 2 !! non !! n!! n !!n !! n!!<br />
|-<br />
!Jojo du VoLAB !!intermédiaire !! 1 !! oui !! n!! n !!n !! n!!<br />
|-<br />
!MrPozor !!débutant !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
!Julien Len!!débutant !! 1 !! oui? !! n!! n !!n !! n!!<br />
|-<br />
!Julien Len!!débutant !! 1 !! non!! n!! n !!n !! n!!<br />
|-<br />
!Jérôme Loï!! débutant !! 1? !! oui !! O(payé 30)!! n !!n !! n!!<br />
|-<br />
!Jérôme Loï!! débutant !! 1 !! non!! O!! n !!n !! n!!<br />
|-<br />
!Moala!!débutant !! 1 !! non !! O!! n !!n !! n!!<br />
|-<br />
!Desty!!debutant !! 1 !! oui !! n!! n !!n !! n!!<br />
|-<br />
!Desty!!debutant !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
<br />
!Votre nom!!type !! nombre !! oui/non !! n!! n !!n !! n!!<br />
<br />
<br />
<br />
|}<br />
Nombre de cartes total: 23 dont lab: 8 (total à mettre à jour !)</div>Erichttps://wiki.electrolab.fr/Projets:Commande_groupeeProjets:Commande groupee2019-08-28T11:53:10Z<p>Eric: /* Doga */</p>
<hr />
<div>=Commandes groupées=<br />
<br />
== Principe ==<br />
Tout projet a régulièrement besoin de matières premières, composants, fournitures diverses, etc. Le lab a en stock une quantité importante de fournitures plus ou moins courantes, mais cela ne peut remplacer des commandes régulières.<br />
<br />
Histoire de mutualiser les bons plans & regrouper les frais de port, profiter de divers price breaks, etc, cette page a été créee pour organiser des commandes groupées.<br />
<br />
== Glossaire ==<br />
===Demandeur===<br />
Celui qui a besoin d'un article<br />
<br />
===Acheteur===<br />
Celui qui passe effectivement la commande chez le Fournisseur. L'Acheteur peut être le lab ou une personne privée.<br />
Dans le cas du lab indiquer dans la colonne "acheteur" lab_<nom/pseudo membres> exemple : lab_peewee<br />
Sauf avis contraire, le paiement est à effectuer sur le compte paypal du lab.<br />
<br />
Dans le cas d'une personne privée, indiquer dans la colonne "acheteur", son nom ou pseudo.<br />
L'Acheteur définit lui même les moyens de paiement à utiliser par les <demandeurs>.<br />
<br />
<br />
===Distributeur===<br />
Fournisseur ou fabricant chez qui l'<acheteur> passe commande.<br />
Chaque <distributeur> dispose d'une rubrique propre.<br />
<br />
Il est bien entendu possible d'ajouter des <distributeurs> supplémentaires (notez qu'ils sont triés par '''ordre alphabétique''').<br />
<br />
== Règles du jeu ==<br />
<br />
En général, lorsque l'on s'occupe d'un "group buy", on fait un premier tour de<br />
table pour savoir qui est partant, on annonce ensuite le prix de l'addition<br />
générale (TTC et frais d'expé avec ou sans assurance, éventuels frais de<br />
dédouanement) divisée par le nombre de participants (au prorata des volumes<br />
de commande : celui qui achète 2 items paye 2 parts de frais de port par<br />
exemple).<br />
<br />
Ceci fait, on attend qu'une "masse critique" soit atteinte lorsque l'on vise<br />
certains "price break" (décollonage en jargon de vendeur), puis on lance<br />
l'appel aux fonds avec une date butoir. Passé la date butoir, la commande<br />
est passée, en ignorant ceux qui n'ont pas répondu a temps, puisque le<br />
responsable de group buy n'a pas la trésorerie correspondant à l'achat en<br />
question.<br />
Les histoires genre "le chèque est au courrier" ne marchent pas avec des<br />
virements Paypal... le patron des achats sait exactement combien il a en<br />
caisse au moment de la commande.<br />
<br />
En cas de perte de colis, le responsable de "group buy" n'est pas<br />
redevable. C'est à chaque participant d'estimer s'il prend le risque ou non<br />
de faire confiance aux entreprises assurant l'acheminement des colis.<br />
C'est simple, et si c'est précisé, aucun conflit n'est à redouter, aucun lot<br />
ne reste sur les bras de l'<acheteur>.<br />
<br />
Pour le paiement par avance, celui-ci peut se faire au lab, mais c'est TTC et AVEC les frais de port et de douane, le cas échéant.<br />
<br />
Si un <demandeur> commande la mauvise référence, c'est pour sa pomme.<br />
<br />
Dans la mesure du possible, les <demandeur> doivent faciliter au maximum le travail des <acheteur> en indiquant des références d'articles et de désignation claires.<br />
<br />
==Mode opératoire lorsqu'on passe une commande chez l'un des distributeurs ==<br />
Les tableaux ci-après (un tableau par <distributeur> disposent des colonnes nécessaires à la synchronisation des commandes article par article.<br />
<br />
De même, chaque rubrique dispose d'un en-tete d'information qui a la structure suivante :<br />
<br />
La prochaine commande a pour référence interne : YY_xxx<br />
Prochaine date de commande : <non défini><br />
Commande passée en attente de livraison :[aucune]<br />
Commande livrée en cours de distribution : [aucune]<br />
Anciennes commandes <nom du distributeur> archivées [[Projets:Commande_groupee:archives|ici]]<br />
< informations complémentaires notamment en ce qui concerne les conditions de livraison, etc>''<br />
<br />
YY est un code fixe, unique pour chaque founisseur.<br />
<br />
xxx un le n° de commande pour ce distributeur. Il commence à 001 et s'incrémente à chaque commande.<br />
<br />
<br />
===Les différentes étapes de la commande ===<br />
<br />
====Prise en charge d'un commande par un <acheteur>==== <br />
La personne qui souhaite prendre en charge une commande chez un <distributeur> envoie un mail sur la ML pour informer tout le monde de cette action.<br />
Dans l'entête d'information du <distributeur> concerné, l'<acheteur> effectue les modifications suivantes :<br />
*mise à jour de la ligne ''Prochaine date de commande'' : valorisé à la date à laquelle il envisage de passer la commande auprès du <distributeur>. <br />
<br />
À ce moment, l'ensemble des <demandeurs> concernés se met en relation avec l'<acheteur> pour lui payer d'avance les articles commandés. Pour ces articles, l'<acheteur> fait les modifications suivantes dans le tableau des articles :<br />
*''Payé d'avance (O/N)'' : valorisé à "O" (Oui)<br />
<br />
<br />
====Passage effective de la commande par l'<acheteur>==== <br />
<br />
Celui qui passe la commande ( = <acheteur>) sélectionne les articles qu'il commande effectivement (= ceux pour lesquels il a reçu le paiement en avance). Il peut aussi inclure dans la commande des articles de <demandeurs> pour leuquel il est certain d'être payé au moment de la distribution.<br />
<br />
L'<acheteur> passe la commande auprès du distributeur (par internet, mail, téléphone, télécopie, signaux de fumée, déplacement sur place...) et effectue le paiement à l'aide d'un moyen de paiement à sa convenance. Il est judicieux de priviléger des moyens de paiement fournissant la traçabilité de la transaction.<br />
<br />
Pour les articles effectivement COMMANDÉS l'<acheteur> fait les modifications suivantes dans le tableau des articles :<br />
*'' Acheteur'' : valorisé par son nom/pseudo <br />
*''Commandé (O/N)'' : valorisé à "O" (Oui)<br />
<br />
Pour les articles qui n'ont pas déja été concernés par une commande précédente et que l'<acheteur> ne COMMANDE PAS (par exemple par ce que le <demandeur> ne s'est pas manifesté auprès de lui), il fait les modifications suivantes dans le tableau des articles :<br />
*''N° de commande'' : est incrémenté d'une unité afin que cet article non commandé soit inclus dans la prochaine commande.<br />
<br />
<br />
*mise à jour de la ligne ''Prochaine date de commande'' : valorisé à <non défini><br />
*mise à jour de la ligne ''La prochaine commande a pour référence interne'' : valorisé au numéro de commande interne actuel +1 <br />
*mise à jour de la ligne ''Commande passée en attente de livraison'': valorisé au n° de commande actuel<br />
<br />
====Réception de la commande par l'<acheteur>==== <br />
<br />
<br />
Au moment de la réception du colis, l'<acheteur> vérifie si la livraison est complète et négocie avec le <distributeur> en cas de problème. Il peut aussi informer le <demandeur> concerné par le ou les article(s) en litige ou manquants.<br />
<br />
====Distribution des articles aux <demandeurs>====<br />
Lorsque la distribution peut commencer l'<acheteur> effectue les modifications suivantes dans l'entête d'information du <distributeur> concerné :<br />
*mise à jour de la ligne : '' Commande passée en attente de livraison'' à [aucune]<br />
*mise à jour de la ligne : '' Commande livrée en cours de distribution '' avec la référence interne de la commande.<br />
<br />
L'<acheteur> informe via la ML les <demandeurs> du début de la distribution de la commande <référence interne de commande>.<br />
Chaque <demandeur> convient d'un RDV avec l'<acheteur> pour récupérer les articles (en principe cela se passe au lab) et payer son dû à l'<acheteur>, si ce n'est déja fait.<br />
<br />
Pour chaque article l'<acheteur> fait les modifications suivantes dans le tableau des articles :<br />
*'' Distribué (O/N)'' : valorisé à "O" (Oui) <br />
*''Remboursé/Archivé (O/N)'' : valorisé à "O" (Oui)<br />
<br />
====Ditribution des articles terminée====<br />
<br />
Une fois l'ensemble des pièces distribuées et payées, dans l'entête d'information du <distributeur> concerné, l'<acheteur> effectue les modifications suivantes :<br />
*mise à jour de la ligne ''Commande livrée en cours de distribution'' : valorisé à [aucune]<br />
<br />
<br />
===En conclusion ===<br />
<br />
Si les tableaux des commandes et les en-tête d'information sont gérés avec soin, il n'y a quasiment aucun risque de double commande et n'importe quel membre sait où on en est et peut à tout moment prendre la main sur l'un des tableaux d'achats pour commander un article ou organiser une commande en tant qu'<acheteur>. La bonne application de ces quelques recommandation bénéficie à l'ensemble des participants de ce système de commandes groupées.<br />
<br />
Sauf besoin urgent de pièces, il est bénéfique que ce soit de préférence les mêmes <acheteurs> qui officient auprès des mêmes <distributeurs>. Ainsi, vu de ces derniers, l'<acheteur> est très vite identifié comme "client important" (car en réalité il commande pour 5-10 personnes, voire plus) et peut bénéficier de conditions particulières (frais de port gratuit, -15% sur la prochaine commande, etc).<br />
<br />
Enfin, à tout moment en tant que <demandeur>, soyez diligent envers l'<acheteur> dont la gestion d'une commande de parfois plusieurs dizaines d'articles requert un investissement en temps non négligeable.<br />
<br />
== Commandes groupées passées (archives) ==<br />
<br />
Afin d'améliorer la lisibilité nous avons regroupé les commandes passées sur cette page: [[Projets:Commande_groupee:archives]]<br />
<br />
== Commandes groupées en cours ==<br />
<br />
=== BHV ===<br />
<br />
La prochaine commande a pour référence interne : BH_003<br />
<br />
<br />
<br />
Commande livrée en cours de distribution : [aucune] <br />
<br />
Anciennes commandes BHV archivées [[Projets:Commande_groupee:archives#BHV|ici]]<br />
<br />
achat sur place<br />
<br />
{|class="wikitable sortable" style="font-size:85%"<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref BHV!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
<!-- Pour ajouter une ligne, copier les 2 lignes suivantes (celles qui commencent par | ) à la suite du tableau et remplacer le contenu des colonnes par ce qui semblera adéquat<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| Lab|| Réglet métallique 30cm || - || 3 || 5.90€||Eric|| BH_001 || N || O || O || O<br />
|-<br />
|-<br />
| Lab|| Scie a métaux FACOM 603E || - || 1 || env. 36€||Eric|| BH_002 || N || O || 0 || O<br />
|-<br />
! !! !! !! !! !! !! !! !! !! !!<br />
|}<br />
<br />
=== [http://www.visseriefixations.fr/ Cergy-Vis] ===<br />
<br />
<br />
La prochaine commande a pour référence interne : CV_002<br />
<br />
<br />
<br />
<br />
Anciennes commandes Cergy-Vis archivées [[Projets:Commande_groupee:archives|ici]] <br />
<br />
Retrait gratuit sur place<br />
CERGY-VIS<br />
<br />
17, Rue du Périgord<br />
<br />
ZI des Béthunes<br />
<br />
95310 SAINT OUEN L’AUMONE<br />
<br />
<br />
Horaires pour les enlèvements: Du Lundi au Vendredi, de 7h30 à 12h00 et de 13h30 à 17h30.<br />
<br />
<br />
Livraison<br />
Colissimo Régional (0.05kg / France) 5,75 €<br />
<br />
Colissimo Régional (0.2888kg / France) 6,54 €<br />
<br />
Colissimo Régional (2.87kg / France) 9,25 €<br />
<br />
Colissimo Régional (12.8948kg / France) 16,50 €<br />
<br />
Anciennes commandes Cergy-Vis archivées [[Projets:Commande_groupee:archives#Cergy-Vis|ici]]<br />
<br />
<br />
|-<br />
!Demandeur !! class="unsortable"| Description !! Référence!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-<br />
||Eric|| TRCC M5X30 INOX A2 DIN 603|| ||50||0.17EURTTC||<acheteur>||CV_001||N||O||O||N (attends remb. trop versé)<br />
|-<br />
||Eric|| ECROU HU M12 PAS 100 Z.BLANC DIN 934|| ||20||0.39EURTTC||<acheteur>||CV_001||N||O||O||N (attends remb. trop versé)<br />
|-<br />
||Eric||Vis TCHC M5X22 INOX A2 EF DIN 912||TCHC05/022A2EF||15||0.12EURTTC||<acheteur>||CV_002||N||N||N||N<br />
|-<br />
||Eric||Vis STHC PLAT M6X12 INOX A2 DIN 913||STHCPLA06/012A2||30||0.06EURTTC||<acheteur>||CV_002||N||N||N||N<br />
|-<br />
||Eric||Vis TH M6X12 INOX A2 EF DIN 933||TH06/012A2EF||30||0.09EURTTC||<acheteur>||CV_002||N||N||N||N<br />
|-<br />
|}<br />
<br />
=== [http://www.conradpro.fr Conrad Electronique France] ===<br />
<br />
<br />
La prochaine commande aura pour référence interne : CO_017<br />
<br />
Prochaine date de commande :<br />
<br />
Commande passée en attente de livraison : NEANT<br />
<br />
Commande livrée en cours de distribution : NEANT<br />
<br />
Anciennes commandes Conrad Electronique France archivées [[Projets:Commande_groupee:archives#Conrad Electronique France|ici]]<br />
<br />
{| class="wikitable sortable" style="font-size:85%"<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Conrad!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€ ||<Acheteur>|| CO_XXX || N || N || N || N<br />
|-<br />
--><br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/822746/Fil-de-soudure-pour-PVC-rigide-Steinel-073114-26-pcs Fil de soudure pour PVC rigide Steinel 073114 26 pcs]</s>||<s>822746 - 62 </s>||<s> 1 </s>||<s> € 5.99 TTC</s>||<s><acheteur> </s>||<s> CO_014 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/492161/Soudure-plastique-225-mm-4-mm-polythylne-LDPE-nature-Bosch-1609201811 Soudure plastique, 225 mm, 4 mm, polyéthylène (LDPE) nature Bosch 1609201811]</s>||<s>492161 - 62 </s>||<s> 1 </s>||<s> € 15.99 TTC</s>||<s> <acheteur> </s>||<s> CO_014 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/121588/Solution-de-conservation-pour-electrodes-de-mesure-pH-HI-70300M Solution de conservation pour électrodes de mesure pH HI 70300M]</s>||<s>121588 - 62 </s>||<s> 1 </s>||<s> € 15.12 TTC</s>||<s> <acheteur> </s>||<s> CO_014 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/121586/Solution-de-nettoyage-pour-electrodes-pH-HI-7061M Solution de nettoyage pour électrodes pH HI 7061M]</s>||<s>121586 - 62 </s>||<s> 1 </s>||<s> € 15.12 TTC</s>||<s> <acheteur> </s>||<s> CO_014 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|Eric||[http://www.conrad.fr/ce/fr/product/121164/Sol-de-conduct-12880-S-HI-70030-P Sol. de conduct. 12880 µS HI 70030 P]||121164 - 62 || 1 || € 38.30 TTC|| <Pat> || CO_014 || N || O || O || O<br />
|-<br />
|Eric||[http://www.conradpro.fr/ce/fr/product/822188/Knipex-Pinces-pour-circlips-pour-colliers-dtranglement-darbre-46-11-G0-140-mm?ref=searchDetail Pince KNIPEX 46 11 G0]||822188 - 62 || 1 || € 20.13 HT|| <Pat> || CO_014 || N || O || O || O<br />
|-<br />
|Eric||[http://www.conradpro.fr/ce/fr/product/822189/Knipex-Pinces-pour-circlips-pour-colliers-dtranglement-darbre-46-11-G1-140-mm?ref=searchDetail Pince KNIPEX 46 11 G1]||822189 - 62 || 1 || € 13.02 HT|| <Pat> || CO_014 || N || O || O || O<br />
|-<br />
|MrPozor||[http://www.conrad.fr/ce/fr/product/702246/Interrupteur-de-porte-Panasonic-AZC11113HJ-250-VAC-5-A-poussoir-momentan-IP40-1-pcs?ref=searchDetail Interrupteur de porte Panasonic AZC11113HJ]||702246 - 62 || 1 || € 10.99 TTC|| <Pat> || CO_014 || N || O || N || N<br />
|-<br />
| papy F1CHF || 74HC390 SOIC || 1115010-62 || 10 || 1.06€ ||<Pat>|| CO_014 || O || O || O || O<br />
|-<br />
| Pat|| Condo moteur 5uF 450V || 441527-62 || 1 || 6.33€ H.T. ||<Pat>|| CO_014 || O || O || N || N<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/731484/Adaptateur-avec-fiche-dor-32-A-rouge-MultiContact-240160-22 Adaptateur avec fiche doré 32 A rouge MultiContact Ref. 24.0160-22]|| 731484 - 62 || 2 || 3.00 € H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/731559/Disque-de-marquage-couleur-MultiContact-145010-vert-jaune-1-pcs Disque de marquage couleur MultiContact Ref. 14.5010 vert-jaune 1 pc(s)]|| 31559 - 62 || 3 || 0.75 € H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/106109/Pointe-de-touche-de-scurit-MultiContact-XMA-7L-enfichable-4-mm-CAT-IV-1000-V-bleu Pointe de touche de sécurité MultiContact XMA-7L enfichable 4 mm CAT IV 1000 V bleu Ref. MC 66.9509-23]|| 106109 - 62 || 1 || 15.96 € H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/106108/Pointe-de-touche-de-scurit-MultiContact-XMA-7L-enfichable-4-mm-CAT-IV-1000-V-rouge Pointe de touche de sécurité MultiContact XMA-7L enfichable 4 mm CAT IV 1000 V rouge Ref. MC 66.9509-22]|| 106108 - 62 || 1 || 15.96 € H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/106107/Pointe-de-touche-de-scurit-MultiContact-XMA-7L-enfichable-4-mm-CAT-IV-1000-V-noir Pointe de touche de sécurité MultiContact XMA-7L enfichable 4 mm CAT IV 1000 V noir Ref. MC 66.9509-21]|| 106107 - 62 || 1 || 15.96 € H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/1385649/Pince-crocodile-4-mm-GRIP-FMA-MultiContact-669435-21 Pince crocodile 4 mm GRIP-FMA MultiContact Ref. 66.9435-21]|| 1385649 - 62 || 1 || 30.00€ H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Damien H || MOSFET RFD14N05L || 512-RFD14N05L || 5 || 0,695 € ||?|| CO_015 || N || O || O || O<br />
|-<br />
| Damien H || Zener BZX79C2V4 || 512-BZX79C2V4 || 5 || 0,11 € ||?|| CO_015 || N || O || O || O<br />
|-<br />
|Pierre G|| Câble audio SpeaKa 1m mf||986736 - 62 || 2||6,66 ht || ? || CO_015 || N || O || O || O<br />
|-<br />
|Pierre G|| Câble audio SpeaKa 0,50m mf||986735 - 62 || 1||5.92 ht || ? || CO_015 || N || O || O || O<br />
|-<br />
|Pierre G|| Lentille Dialight OPC-11SPOT transparent 10 ° 1 pc(s)||1127266 - 62 || 1||3 ht || ? || CO_016 || N || O || O || O<br />
|-<br />
|Pierre G|| LED High Power Barthelme 61003528 blanc chaud||1503528 - 62 || 1||3,50 ht || ? || CO_016 || N || O || O || O<br />
|-<br />
|FredericD|| [http://www.conrad.fr/ce/fr/product/574223/Transformateur-electronique-Standard-10-a-60-W Transformateur électronique "Standard" 10 à 60 W]||574223 - 62 || 1||15,49 '''TTC''' || <acheteur> || CO_017 || N || N || N || N<br />
|-<br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/542044/?insert=32&insertNoDeeplink&productname=Gaine-thermoretractable-pour-batteries-sans-colle-21-Conrad-Components-542044-transparent-avant-retreint-44-mm-1-pc Gaine thermorétractable 2:1 transparente pour accus longueur 100 cm largeur 44mm]</s>||<s>542044 - 32</s>||<s>3</s>||<s>2,70€TTC</s>||<s> <acheteur> </s>||<s> CO_017 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/100297/Solution-conductrice-1413-S-HI-70031-P?ref=list Solution conductrice 1413 µS HI 70031 P]</s>||<s>100297 - 62 </s>||<s> 1 </s>||<s> € 33,60 TTC</s>||<s> <acheteur> </s>||<s> CO_017 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|<s>Eric</s>||<s>[http://www.conradpro.fr/ce/fr/product/1305022/Diode-Zener-PanJit-1N4740A-G-DO-41G-Tension-Zener-10-V-1-pcs?ref=searchDetail Diode Zener PanJit 1N4740A-G DO-41G Tension Zener: 10 V]</s>||<s>1305022 - 62 </s>||<s> 10 </s>||<s> € 0,15 TTC</s>||<s> <acheteur> </s>||<s> CO_017 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/812811/tain-de-soudure-teneur-en-plomb-Stannol-HS-10-Sn60Pb39Cu1-bobine-100-g-10-mm?queryFromSuggest=true étain 100g 1mm STANNOL]|| 812811 - 62 || 2 || 7,55 € H.T. ||<acheteur>|| CO_017 || N || N || N || N<br />
|-<br />
|Eric||[http://www.conrad.fr/ce/fr/product/651105/XLR-Bride-mle-contacts-couds-Neutrik-NC3MAAH-Nombre-de-ples-3-noir-1-pcs?queryFromSuggest=true Connecteur XLR mâle plastique pour chassis soudage pour CI 3 broches coudé + blindage, NEUTRIK NC3MA(A)H ]||651105 - 62|| 2 || 1,20€TTC ||<acheteur>||CO_017||N||N||N||N <br />
|-<br />
|}<br />
<br />
Anciennes commandes Conrad archivées [[Projets:Commande_groupee:archives#Conrad_Electronique_France|ici]]<br />
<br />
=== [http://www.damencnc.com/fr DamenCNC] ===<br />
<br />
Accessoires pour machines CNC [http://www.damencnc.com]<br />
<br />
La prochaine commande a pour référence interne : DC_002<br />
<br />
Prochaine date de commande : ?? (probablement en octobre 2014)<br />
<br />
<br />
<br />
Livraison : depuis les Pays-Bas par UPS : estimation : 20€ pour un colis de 1.5kg<br />
<br />
ATTENTION : Prix HT.<br />
<br />
Anciennes commandes DamenCNC archivées [[Projets:Commande_groupee:archives#DamenCNC|ici]]<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref DamenCNC!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||<Acheteur>|| OT_XXX || N || N || N || N<br />
|-<br />
--><br />
|-<br />
|Goldo|| HIWIN HGR Profile Rail L=200mm || HG15R || 2 || 21,60€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|Goldo|| HIWIN Carriage HGH "Compact type" || HGH-15CA || 2 || 33.99€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|Goldo|| Mini Mill 2 flutes 0.20mm || ? || 1 || 11.99€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|Goldo|| Mini Mill 2 flutes 0.30mm || ? || 1 || 11.99€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|Goldo|| Mini Mill 2 flutes 0.50mm || ? || 1 || 9.99€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|Goldo|| Kress Collet + Clamp Nut 1/8inch || ? || 1 || 19.99€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|F1CHF|| Mini Mill 2 flutes 0.50mm || ? || 2 || 9.99€HT || Goldo || DC_001 || N || O || O || O<br />
|-<br />
|F1CHF|| Mini Mill 2 flutes 0.70mm || ? || 2 || 9.99€HT || Goldo || DC_001 || N || O || O || O<br />
|-<br />
|Eric||IPS_Cable_Assembly M12_Straight_Female/OPENEND_3meter || ? || 2 || 4.99€HT || <acheteur>|| DC_002 || N || N || N || N<br />
<br />
|}<br />
<br />
===[http://www.detandt.com/fr Detandt-Simon]===<br />
<br />
La prochaine commande aura pour référence interne : DET_001 <br />
<br />
Prochaine date de commande : Mardi 2/2/2016<br />
<br />
<br />
Commande livrée en cours de distribution : [nada] <br />
<br />
Anciennes commandes Detandt archivées [nope]<br />
<br />
Frais de livraisons: inconnu<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Taille !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!!Remboursé/Archive (O/N)<br />
|-<br />
<!-- Pour ajouter une ligne, copier les 2 lignes suivantes (celles qui commencent par | ) à la suite du tableau et remplacer le contenu des colonnes par ce qui semblera adéquat--><br />
| Steve|| Modèle haut Bleu et gris || Taille 44 || 1|| 15€ HT||Steve|| DET_001 || N || N || N || N<br />
|-<br />
| Steve|| Modèle haut Bleu et gris || Taille 45 || 1|| 15€ HT||Steve|| DET_001 || N || N || N || N<br />
|-<br />
| Laurent d. Lo^2 || Modèle haut orange et noir || Taille 44 || 1|| 15€ HT||Laurent|| DET_001 || N || N || N || N<br />
|-<br />
| Laurent d. Lo^2 || Modèle cuir noir || Taille 44 || 1|| 15€ HT||Laurent|| DET_001 || N || N || N || N<br />
|-<br />
| Beatrice/LK999 || Modèle cuir noir ou bas || Taille 45|| 1|| 15€ HT||XXX|| DET_001 || N || N || N || N<br />
|-<br />
| Le Xav || Modèle noir & orange haut || Taille 45|| 1|| 15€ HT||XXX|| DET_001 || N || N || N || N<br />
|-<br />
| Patrick|| 10m gaine VMC alu D80 M0|| HALUM0 82|| 2|| 13,78€ HT||XXX|| DET_002 || N || N || N || N<br />
|-<br />
| Patrick|| 10m gaine VMC alu D125 M0|| HALUM0 127|| 1|| 15,96€ HT||XXX|| DET_002 || N || N || N || N<br />
|-<br />
|}<br />
<br />
===[http://www.digikey.com/ Digikey Corporation]===<br />
<br />
La prochaine commande aura pour référence interne : DI_006<br />
<br />
<br />
Commande passée en attente de livraison : DI_005 <br />
<br />
Commande livrée en cours de distribution : NEANT <br />
<br />
Anciennes commandes Digikey Corporation archivées [[Projets:Commande_groupee:archives#Digikey Corporation|ici]]<br />
<br />
"PAS DE FRAIS POSTAUX sur toutes commandes avec une valeur de 65 Euro et plus.mais la DOUANE + frais"<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Digikey !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!!Remboursé/Archive (O/N)<br />
|-<br />
| Laurent(C) || Capa 470uF || 493-1493-ND || 24 || 0,229€||Laurent(C)|| DI_005 || || O || N || N<br />
|-<br />
| Laurent(C) || Carte NUCLEO-F303K8 || 497-15981-ND || 1|| 9,92€||Laurent(C)|| DI_005 || || O || N || N<br />
|-<br />
| Laurent(C) || Capa tantale 10uF || 478-8959-1-ND || 5|| 0.8€||Laurent(C)|| DI_005 || || O || N || N<br />
|-<br />
| Laurent(C) || PMIC 4V || MCP1702T-4002E/CBCT-ND|| 5|| 0.43€||Laurent(C)|| DI_005 || || O || N || N<br />
|-<br />
| Eric||[http://www.digikey.fr/product-search/fr?vendor=0&keywords=LT1677CS8%23PBF-ND LT1677 OPAMP S8 Package]|| LT1677CS8#PBF-ND || 4|| 3.95€||Laurent(C)|| DI_005 || O || O || N || N<br />
|-<br />
| Eric|| [http://www.digikey.com/product-detail/en/4664-6001/MPK64K-ND/138341 connecteur HE10 64 broches autodénudant mâle] || MPK64K-ND || 1|| 12.59€||Laurent(C)|| DI_005 || O || O || O || O<br />
|-<br />
| Eric|| [http://www.digikey.fr/product-detail/fr/DS2740U%2B/DS2740U%2B-ND/1197488 MAXIM coulombmetric counter DS2740U+ SMD]|| DS2740U+-ND || 1|| 3.90€||Laurent(C)|| DI_005 || O || O || O || O<br />
|-<br />
| Eric|| C190 case ||614-1102-ND||1||199,99USD||Laurent(C)|| DI_005 || O || N(export restriction!) || N || O<br />
|-<br />
| papy F1CHF || NB3N502 || NB3N502DGOS-ND ||4||2.99€||Laurent(C)|| DI_005 || N || O || O || O<br />
|-<br />
| Eric|| [http://www.digikey.com/product-detail/en/linear-technology/LT1763CS8-TRPBF/LT1763CS8-TRPBFCT-ND/4247570 LT1763CS8#TRPBF LT micropower low noise LDO ADJ regulator 500MA SO8]|| LT1763CS8#TRPBFCT-ND || 1|| 4.78USD||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| Eric|| [http://www.digikey.com/product-detail/en/linear-technology/LT1763CS8-3.3-TRPBF/LT1763CS8-3.3-TRPBFCT-ND/4247566 LT1763CS8-3.3#TRPBF LT micropower low noise LDO 3.3V regulator 500MA SO8]|| LT1763CS8-3.3#TRPBFCT-ND|| 2|| 4.78USD||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| Eric|| [http://www.digikey.fr/products/fr?keywords=BA5406 BA5406 Amplifier IC 2-Channel (Stereo) Class AB 12-SIP-M] ||BA5406-ND || 1|| 3.85 EUR||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| Eric|| [https://www.digikey.fr/products/fr?keywords=HR1732-ND HIROSE CONN PLUG 5POS W/PIN INSERT ref "RM12BPE-5PH(71)"] ||HR1732-ND || 1|| 11.19 EUR||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| Eric|| [https://www.digikey.fr/product-detail/fr/infineon-technologies/IRS2453DPBF/IRS2453DPBF-ND/1189713 INFINEON IC DRIVER FULL SELF OSC 14-DIP IRS2453DPBF] ||IRS2453DPBF-ND || 1|| 3.09 EUR||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| 3dsman|| US5881LUA Digital Switch Unipolar Switch Open Drain Hall Effect TO-92UA ||US5881LUA-AAA-000-BU-ND || 5|| 1.10 EUR||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| Debutant|| [https://www.digikey.fr/product-detail/fr/jst-sales-america-inc/SYF-001T-P0.6-LF-SN/455-2652-1-ND/2796952 JST Sales America Inc. SYF-001T-P0.6(LF)(SN) ] || 455-2652-1-ND || 100|| 0.05460 EUR|| Debutant || DI_006 || N || N || N || N<br />
|-<br />
| Lo2|| [https://www.digikey.fr/product-detail/en/molex-llc/0755860006/WM22014CT-ND/9095459 Molex Connecteur 50POS SMD] || WM22014CT-ND || 3|| 8.47 EUR|| Lo2 || DI_006 || N || N || N || N<br />
|-<br />
<br />
|}<br />
<br />
=== [http://www.doga.fr Doga] ===<br />
<br />
La prochaine commande aura pour référence interne : DO_004<br />
<br />
Prochaine date de commande : [inconnu]<br />
<br />
Commande passée en attente de livraison : [aucune]<br />
<br />
Commande livrée en cours de distribution : DO_003<br />
<br />
<br />
Minimum de commande : 50€ HT<br />
Franco : 100€ HT<br />
<br />
Merci de préciser le catalogue dans lequel se trouve l'article pour le retrouver plus aisément. <br />
<br />
Les principaux catalogues sont :<br />
* http://www.doga.fr/catalogue_pdf/ugv.pdf<br />
* http://www.doga.fr/catalogue_pdf/ugv-alliage-leger.pdf<br />
* [https://shop.precitool.de/bk/WKZ_2017-2018/#page_0.1 Precitool]<br />
<br />
Anciennes commandes Doga archivées [[Projets:Commande_groupee:archives#Doga|ici]]<br />
<br />
<br />
|-<br />
!Demandeur !! class="unsortable"| Description !!class="unsortable"| Ref Doga !! class="unsortable"| Catalogue !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!!Remboursé/Archive (O/N)<br />
<br />
<br />
|-<br />
| Eric||[http://shop.precitool.de/bk/HKL_2016-2017/#page_870 Ø 8mm Zylinderbürste mit Öse, Messingdraht gewellt marque : LESSMANN]|| 481772 || Precitool || 1 || 7 EURHT || <acheteur> || DO_002 || N || O || O || O<br />
|-<br />
| <s>Eric</s>||<s>[http://shop.precitool.de/bk/HKL_2015-2016/#page_1044 Kompakt-Bolzenscheider KNIPEX Mit Mehrkomponenten-Hülle, Öffnungsfeder, 20° abgewinkelt]</s>||<s> 559026</s> ||<s> Precitool </s>||<s> 1 </s>||<s> 40.45EURHT</s> ||<s> <acheteur> </s>||<s> DO_002 </s>||<s>N</s> ||<s>N</s>||<s> N </s>||<s> N</s><br />
|-<br />
| Eric||[http://shop.precitool.de/bk/HKL_2016-2017/#page_924 Strinlochschlüssel-Satz marque AMF]|| 506050|| Precitool || 1 || 31.05EURHT || <acheteur> || DO_002 || N || O || O || O<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1116 KNIPEX Montagezange Typ 4521 für Sprengringe auf Wellen (KNIPEX Ref 45 21 200)]||554175 /4521|| Precitool || 1 || 30,75EURHT || <acheteur> || DO_002 || N || O || O || O<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2016-2017/#page_1242 Schneidoel 500ml]||924055|| Precitool || 1 || 14,35EURHT || <acheteur> || DO_002 || N || O || O || O<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2016-2017/#page_1254 Luftweiche 3 Fach (4 x G3/8) Typ 0304]||925805/0304|| Precitool || 2 || 7.05EURHT || <acheteur> || DO_002 || N || O || O || O<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_35 Spiralbohrer HSS-Co Precitool D1897 INOX Dn 2,1mm]||100670/2,10|| Precitool || 5 || 1.91 EURHT || Lab || DO_003 || N || O || O (livré en 2.3mm, puis relivré gratuitement en 2,1mm) || O<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_815 Düsenlehre 0.45-1.5mm (0.05mm steigung)]||389850/20|| Precitool || 1 || 12.65 EURHT || Lab || DO_003 || N || O || O || O<br />
|-<br />
|Steve||[http://shop.precitool.de/bk/HKL_2017-2018/#page_987 Gelenk-Hakenschlüssel]||506350/22-35|| Precitool || 1 || 13.55 EURHT || Lab || DO_003 || N || N || N || N<br />
|-<br />
|Steve||[http://shop.precitool.de/bk/HKL_2017-2018/#page_987 Gelenk-Hakenschlüssel]||506350/35-60|| Precitool || 1 || 14.90 EURHT || Lab || DO_003 || N || N || N || N<br />
|-<br />
|Steve||[http://shop.precitool.de/bk/HKL_2017-2018/#page_987 Gelenk-Hakenschlüssel]||506350/60-90|| Precitool || 1 || 17.70 EURHT || Lab || DO_003 || N || N || N || N<br />
|-<br />
|Lab||[http://shop.precitool.de/bk/HKL_2017-2018/#page_985 Hakenschlüssel aus spezial Stahl Gehärtet und im Brunierton angelassen, pour Ø 95-100 mm, pour écrous DIN 1804 et DIN 981]||506200 95/100|| Precitool || 1 || 10,80 EURHT || Lab|| DO_003 || N || O || O (erreur de reference de commande) || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_985 Hakenschlüssel aus spezial Stahl Gehärtet und im Brunierton angelassen, pour Ø 95-100 mm, pour écrous DIN 1804 et DIN 981]||506200 95/100|| Precitool || 1 || 10,80 EURHT || Lab || DO_003 || N || O || O (erreur de reference de commande) || O<br />
<br />
|-<br />
|Lab||[http://shop.precitool.de/bk/HKL_2017-2018/#page_1153 Jeu de chasse-goupilles - Splintentreiber]|| 561110/6M || Precitool || 1 || 18.05 EURHT || Lab || DO_003 || N || N || N || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Linksausdreher Grosse 1 (für M3-M6)]||590950/1|| Precitool || 3 || 1,35 EURHT || Lab || DO_003 || N || O || O || O<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Linksausdreher Grosse 2 (für M6-M8)]||590950/2|| Precitool || 2 || 1,35 EURHT || Lab || DO_003 || N || O || O || O<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Linksausdreher Grosse 3 (für M8-M11)]||590950/3|| Precitool || 2 || 1,54 EURHT || Lab|| DO_003 || N || O || O || O<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Schaubenausdreher/Linksausdreher "Super Traktion" Grosse T1 (pour Ø 4-5 mm, perçage 2.1 mm)]||590970/T1|| Precitool || 3 || 4.47 EURHT || Lab || DO_003 || N || O || O || O<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Schaubenausdreher/Linksausdreher "Super Traktion" Grosse T2 (pour Ø 5-7 mm, perçage 3.2 mm )]||590970/T2|| Precitool || 3 || 4.58 EURHT || Lab || DO_003 || N || O || O || O<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Schaubenausdreher/Linksausdreher "Super Traktion" Grosse T3 (pour Ø 8-12 mm, perçage 4.5 mm )]||590970/T3|| Precitool || 3 || 5.70 EURHT || Lab || DO_003 || N || O || O || O<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/WKZ_2018-2019/#page_35 Spiralbohrer HSS-Co Precitool D1897 INOX Dn 8,6mm]||100670/8,60|| Precitool || 2 || 7.14 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/WKZ_2018-2019/#page_35 Spiralbohrer HSS-Co Precitool D1897 INOX Dn 8,7mm]||100670/8,70|| Precitool || 2 || 7.14 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/WKZ_2018-2019/#page_35 Spiralbohrer HSS-Co Precitool D1897 INOX Dn 6,4mm]||100670/6,40|| Precitool || 2 || 5,17 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/WKZ_2018-2019/#page_35 Spiralbohrer HSS-Co Precitool D1897 INOX Dn 9,8mm]||100670/9,80|| Precitool || 2 || 9.65 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/WKZ_2018-2019/#page_930 Gelenk-Hakenschlüssel verstellbar, mit Nase, gehärtet und im Brünierton angelassen; für AuBen Ø (Mutter) 20-35 mm]||506300/20-35|| Precitool || 1 || 11.55 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/WKZ_2018-2019/#page_930 Gelenk-Hakenschlüssel verstellbar, mit Nase, gehärtet und im Brünierton angelassen; für AuBen Ø (Mutter) 35-60 mm]||506300/35-60|| Precitool || 1 || 12.35 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/WKZ_2018-2019/#page_930 Gelenk-Hakenschlüssel verstellbar, mit Nase, gehärtet und im Brünierton angelassen; für AuBen Ø (Mutter) 60-90 mm]||506300/60-90|| Precitool || 1 || 16.05 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2018-2019/#page_1155 Schaubenausdreher/Linksausdreher "Super Traktion" Grosse T4 (pour Ø 12-14 mm, perçage 6.5 mm )]||590970/T4|| Precitool || 3 || 6.89 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2018-2019/#page_1155 Schaubenausdreher/Linksausdreher "Super Traktion" Grosse T5 (pour Ø 16-20 mm, perçage 8.5 mm )]||590970/T5|| Precitool || 3 || 9.00 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/WKZ_2018-2019/#page_761 Düsenlehre 1.5-3,0mm (0.1mm Steigung)]||389850/16|| Precitool || 1 || 13.55 EURHT || <acheteur>|| DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/WKZ_2018-2019/#page_940 Verlängerung 1/4" Typ 870 Marke : HAZET ]||511186|| Precitool || 1 || 20.50 EURHT || <acheteur>|| DO_004 || N || N || N || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2018-2019/#page_895 Einmaulschlüssel DIN894 SW : 13 mm ]||500602/13|| Precitool || 1 || 1.27 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|}<br />
<br />
=== [http://fr.farnell.com Farnell] ===<br />
<br />
Livraison gratuite au dessus de 30€ HT<br />
<br />
La prochaine commande aura pour référence interne : FA_017<br />
<br />
<br />
Prochaine date de commande : <à définir><br />
<br />
Commande passée en attente de livraison : <aucune><br />
<br />
Anciennes commandes Farnell archivées [[Projets:Commande_groupee:archives#Farnell|ici]]<br />
<br />
|-<br />
| Demandeur || class="unsortable"| Description || Ref Farnell || class="unsortable"| Quantité || class="unsortable"| Prix unitaire || Acheteur || Commande<br/>n° || Payé<br/>d'avance<br/>(O/N)|| Commandé<br/>(O/N)|| Distribué<br/>(O/N)|| Remboursé/<br/>Archive<br/>(O/N)<br />
|-<br />
|-<br />
|-<br />
| Claire Poisson || CD4011BM96 || 2114002 || 15 || 0,313 TTC || 3dsman ||FA_015 ||N ||O ||N ||N<br />
|-<br />
|-<br />
| 3dsman || Câble multiconducteur blindé || 2425036 || 10 || 0,85 TTC || 3dsman ||FA_015 ||N ||O ||N ||N<br />
|-<br />
|-<br />
| Steve (Pour lab/smoothie) || NXP LPC 1769 || 2072199 || 1 || 8,68 TTC || 3dsman ||FA_015 ||N ||O ||O ||N<br />
|-<br />
|-<br />
| Dom (Rude ULM) || Connecteur d'alimentation DC, Mâle, 2 A, 9.5 mm, Montage sur câble, 1.7 mm || 1737255 || 2 || 2.87 TTC || 3dsman ||FA_015 ||N ||O ||N ||N<br />
|-<br />
|-<br />
| Steve || MCP1702T-5002E/MB - Régulateur LDO 5V SOT89-3 || 1605559 || 3 || 0.593 || 3dsman ||FA_015 ||N ||O ||O ||N<br />
|-<br />
|-<br />
| Steve || RELAY, SPDT, 250VAC, 12A || 1714771 || 2 || 2.27E|| 3dsman ||FA_015 ||N ||O ||O ||N<br />
|-<br />
|-<br />
|-<br />
| Steve (Pour lab/smoothie) || LDO LM1117 3.3V || 2323580 || 5 || 0.907 || Ph. Gras||FA_016 ||N ||O ||O ||N<br />
|-<br />
| Eric ||[http://fr.farnell.com/amphenol-sine-tuchel/t-3424-501/fiche-libre-6-voies/dp/1123507 Connecteur 6 broches Amphénol avec serrage baillionnette ref T 3424 501] || 1123507 || 1 || 5,12 || Ph. Gras ||FA_016 ||N ||O ||O ||N<br />
|-<br />
| Eric ||[http://fr.farnell.com/nkk-switches/b18jp/switch-toggle-spdt-0-1a-28vac/dp/2374722?ost=2374722&ddkey=http%3Afr-FR%2FElement14_France%2Fsearch Commutateur 3 positions miniature SPDT, 0.1A, 28VAC On-Off-On NKK Switch ref B18JP ] || 2374722|| 2 || 3,98 EUR || Ph. Gras ||FA_016 ||N ||O ||O ||N<br />
|-<br />
| Ph. Gras||[http://fr.farnell.com/jst-japan-solderless-terminals/phr-2/boitier-2-voies-2mm/dp/3616186 Boîtier de connecteur, Série PH, Embase, 2 Voies, 2 mm, Contacts à sertir Série BPH et SPH ] || 3616186|| 100 || 0,0324 EUR || Ph. Gras||FA_016 ||N ||O ||O ||O<br />
|-<br />
| Ph. Gras||[http://fr.farnell.com/jst-japan-solderless-terminals/sph-002t-p0-5s/contact-0-05-0-22mm-cut-reel/dp/1671245?st=SPH-002T-P0.5S Contact, Série PH, Femelle, Sertissage, 24 AWG, Contacts plaqués étain, Connecteurs PH ] || 1671245|| 250|| 0,0208 EUR || Ph. Gras ||FA_016 ||N ||O ||O ||O<br />
|-<br />
| Ph. Gras||[http://fr.farnell.com/on-semiconductor/lm317ahvt/regulateur-ldo-ajustable-1-5a/dp/1564497?st=lm317LM317AHVT Régulateur de tension positive ajustable 1.2V à 37V, 1.5A en boîtier TO-220-3 ] || 1564497|| 10|| 0,727 EUR || Ph. Gras ||FA_016 ||N ||O ||O ||O<br />
|-<br />
|-<br />
|-<br />
| <demandeur> ||[http://wiki.electrolab.fr/Projets:Commande_groupee#Glossaire <article>] || <fa_cde_nb> || <quantité> || <prix> || <acheteur> ||FA_017 ||N ||N ||N ||N<br />
|-<br />
|-<br />
|}<br />
<br />
=== [http://www.gotronic.fr Gotronic] ===<br />
<br />
la prochaine commande a la référence interne GO_003<br />
<br />
<br />
Commande passée en attente de livraison :GO_002 le 31/05/2017 par Ellyan<br />
<br />
<br />
Anciennes commandes Gotronic archivées [[Projets:Commande_groupee:archives#Gotronic|ici]]<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref gotronic!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||<Acheteur>|| GO_XXX || N || N || N || N<br />
|-<br />
--><br />
| Damien H || Solénoïde 12 Vcc || LS1110BD || 1 || 7,00€||Ellyan|| GO_002 || N || O || N || N<br />
|}<br />
<br />
=== HighVoltageShop ===<br />
<br />
La prochaine commande a pour référence interne : HV_002<br />
<br />
5 euros de réduction sur la prochaine commande<br />
<br />
Prochaine date de commande : Aucune<br />
<br />
Commande passée en attente de livraison : Aucune<br />
* frais de port 20 euros<br />
* Livraison mardi 7 janvier 2014 au lab<br />
<br />
Commande livrée en cours de distribution : HV_001 (08/12/2013) <br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref ebay!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||David|| DI_XXX || N || N || N || N<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| Thomas || Cable HV 120 kV || 271261265516 || 1 || 8,69€||David|| HV_001 || O || O || O || N<br />
|-<br />
|David||-30kV HV-Generator Modul 12VDC||281162933827||1||34,99€||David||HV_001||O||O||O||N<br />
|-<br />
|David||5 Stk. Zeilentrafo - Flyback Transformer - Zeilentrafos||281024817841||1||24,99€||David||HV_001||O||O||O||N<br />
|-<br />
|David||+30kV HV-Generator Modul 12VDC||281162933829||1|| 34,99€||David||HV_001||O||O||O||N<br />
|-<br />
|CitronVert||-30kV HV-Generator Modul 12VDC||281162933827||2||34,99€||David||HV_001||N||O||O||N<br />
|-<br />
| Goldo || Regelbares Hochspannungsnetzteil 50kV Strombegrenzung || 280941865340 || 1 || 119,99€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || +30kV HV-Generator Modul 12VDC || 281162933829 || 1 || 34,99€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Zenos || +30kV HV-Generator Modul 12VDC || 281162933829 || 1 || 34,99€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || Cable HV 120 kV || 271261265516 || 1 || 8,69€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || Hochspannungskabel 40kV 1m || 271261265512 || 1 || 4,61€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || Hochspannungswiderstand 20kV 1 GigaOhm Messwiderstand || 280941865344 || 1 || 6,34€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || Hochspannungswiderstand 20kV 100 MegaOhm || 271106455991 || 1 || 6,34€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || Hochspannungswiderstand 20kV 1 MegaOhm || 281026497192 || 1 || 6,34€||David|| HV_001 || O || O || O || N<br />
|}<br />
<br />
=== [http://www.limpulsion.fr/web/index.php L'impulsion] ===<br />
<br />
[http://v1.limpulsion.fr/docpdf/2008_cat/bpoa_a.pdf Catalogue "accessoires de test"]<br />
<br />
La prochaine commande a la référence interne LI_002<br />
<br />
Prochaine date de commande : [à définir]<br />
<br />
<br />
Commande livrée en cours de distribution :[aucune]<br />
<br />
Anciennes commandes Limpulsion archivées [[Projets:Commande_groupee:archives|ici]]<br />
<br />
<br />
{|class="wikitable sortable" style="font-size:80%"<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref L'impulsion!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-<br />
|Lab||ADAPTATEUR D'AXE HM8001-2 HAMEG||760000500||1||2.30HT||Yannick||IL_001||N||N (plus livrable)||N||O<br />
|-<br />
|Lab||TRESSE A DESSOUDER NO CLEAN 2.8mm/3m||730.14||10||1.56HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||Entretoise plastique grise de montage en saillie marque "Electro-PJP" pour douilles 4mm type 3265, ref EPJP : 3282||<pas au catalogue: demander si livrable> ||16||? ||Yannick||IL_001||N||N (apparement pas dispo)||N||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou NOIR, ref3265-I-0 ||326500||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou MARRON, ref3265-I-1 ||326501||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou ROUGE, ref3265-I-2 ||326502||3||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou BLEU, ref3265-I-6 ||326506||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou VIOLET, ref3265-I-7 ||326507||3||1.48HT||Yannick||IL_001||O||O||N||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou GRIS, ref3265-I-8 ||326508||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou BLANC, ref3265-I-9 ||326509||3||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou JAUNE/VERT, ref 3265-I-J/V||326510||1||1.74HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||[http://v1.limpulsion.fr/docpdf/2008_cat/bpoe_a.pdf#page=9 Passe fil classique intérieur :12mm, Perçage: 18mm, Epaisseur :10mm (lot de 10pcs)]||252.162||1||1,95EURHT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||Entretoise plastique grise de montage en saillie marque "Electro-PJP" pour douilles 4mm type 3265, ref EPJP : 3282||<pas au catalogue: demander si livrable> ||16||? ||Yannick||IL_001||N||N(apparement pas dispo)||N||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou NOIR, ref3265-I-0 ||326500||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou MARRON, ref3265-I-1 ||326501||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou ROUGE, ref3265-I-2 ||326502||3||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou BLEU, ref3265-I-6 ||326506||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou VIOLET, ref3265-I-7 ||326507||3||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou GRIS, ref3265-I-8 ||326508||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou BLANC, ref3265-I-9 ||32650||3||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou JAUNE/VERT, ref 3265-I-J/V||326510||2||1.74HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||CLE EXTERNE POUR DOUILLE DE SECURITE||3299||1||13.51HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||TRANSFO FERRITE POUR THT HM1005 HAMEG (plus livrable) ||THTHM1005||1||16.77HT||Yannick||IL_001||N||N (plus livable)||N||O<br />
|-<br />
|Eric||Lot de 100 douilles pour C.I diam4 Long 10mm à souder Electro-PJP ref 20054||20054||1||7,95 EUR HT||Yannick||LI_001||N||O||O||O<br />
|-<br />
<br />
|Eric||CI SN75492 (7 segm DRIVER) TEXAS DIP14||75492||13||1.29HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||CI 74LS164 TEXAS DIL||74LS164||2||0.76HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||IPROBER520||IPROBER520||1||594HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|}<br />
<br />
=== [https://shop.mchobby.be/ MCHobby] ===<br />
<br />
La prochaine commande a pour référence interne : MCH_001<br />
<br />
Prochaine date de commande : <Mardi 20 ou mercredi 21 au plus tard ><br />
<br />
Livraison gratuite en Mondial Relay à partir de 75 euros.<br />
<br />
<br />
<br />
Anciennes commandes MCHobby archivées [[Projets:Commande_groupee:archives#MCHobby|ici]]<br />
<br />
Site WEB de MCHobby : https://shop.mchobby.be/<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Mon Droguiste !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||<Acheteur>|| MC_XXX || N || N || N || N<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| LienRag|| Divers ||Divers || ++|| 75€||<acheteur>|| MHC_001 || N|| N || N || N<br />
|}<br />
<br />
<br />
=== [http://217.34.103.131/homepage/homepage.html Mini-Circuits] ===<br />
<br />
La prochaine commande a pour référence interne : MC_001<br />
<br />
<br />
<br />
<br />
Anciennes commandes Mini-Circuits archivées [[Projets:Commande_groupee:archives#Mini-Circuits|ici]]<br />
<br />
Site WEB de minicircuits : http://www.minicircuits.com/homepage/homepage.html<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Mini-circuits !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| F1CHF || ERA-3 || AMPL || 20 || 1.43€||F1CHF|| MC_001 || N || N || N || N<br />
|-<br />
|-<br />
| F1CHF || ADCH-80+ || coil || 20 || 2.88€||F1CHF|| MC_001 || N || N || N || N<br />
|-<br />
|-class="sortbottom"<br />
|}<br />
<br />
=== [http://www.mon-droguiste.com/index.cfm Mon Droguiste] ===<br />
<br />
La prochaine commande a pour référence interne : MD_001<br />
<br />
<br />
<br />
<br />
Anciennes commandes Mon Droguiste archivées [[Projets:Commande_groupee:archives#Mon-droguiste|ici]]<br />
<br />
Site WEB de Mon Droguiste : http://www.mon-droguiste.com/index.cfm<br />
<br />
|-<br />
|-l<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| Eric|| Ethylene Diamino Tetraacetic Acide 500g ||Ethylene Diamino Tetraacetic Acide Sac 500g || 1|| 16.95€||<acheteur>|| MD_001 || N|| N || N || N<br />
|}<br />
<br />
=== [http://www.mouser.fr Mouser Electronics]===<br />
<br />
La prochaine commande aura pour référence interne MO_014<br />
<br />
Prochaine date de commande : ?<br />
<br />
<br />
Commande livrée en cours de distribution : MO_013 le 31/05/2017 par Ellyan<br />
<br />
Anciennes commandes Mouser Electronics archivées [[Projets:Commande_groupee:archives#Mouser Electronics|ici]]<br />
<br />
Livraison gratuite (FedEx ou UPS) au delà de 50€ de commande<br />
<br />
<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Mouser !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||<Acheteur>|| DI_XXX || N || N || N || N<br />
|-<br />
--><br />
<br />
|-<br />
|Frederic.D.||[http://www.mouser.fr/ProductDetail/TE-Connectivity/1-826632-0/ Headers & Wire Housings 2X10P DUAL ROW]||571-1-826632-0 ||3 ||1.95 |||| MO_013||O ||O ||O ||N<br />
|-<br />
|Frederic.D.||[http://www.mouser.fr/ProductDetail/Bourns/3306P-1-103/ Trimmer Resistors - Through Hole 10K 25% 6mm Single Turn]||652-3306P-1-103 ||3 ||0.407 |||| MO_013||O ||O ||O ||N<br />
|-<br />
|Frederic.D.||[http://www.mouser.fr/ProductDetail/Schurter/13019302/?qs=%2fha2pyFadugAVCtehZ6ro0we%252bFlHwInvMJ3iEORyekx9pnGrLimsvA%3d%3d Pushbutton Switches SHORT TRAVEL SWITCH 6X6, 5.0MM]||693-1301.9302 ||9 ||0.251 |||| MO_013||O ||O ||O ||N<br />
|-<br />
|Frederic.D.||[http://www.mouser.fr/ProductDetail/Bourns/MF-USMF075-2/ Resettable Fuses - PPTC 0.75A 6V 0.18ohm Hold .75A Trip 1.5A]||652-MF-USMF075-2 ||3 ||0.275 |||| MO_013 ||O ||O||O ||N<br />
|-<br />
|Frederic.D.||[http://www.mouser.fr/ProductDetail/STMicroelectronics/SMA6J50A-TR/?qs=%2fha2pyFadujqXhcCRI4%2fO5BEn9p7pkr6EX0dAQtUlws3JpN%2fE2p9DQ%3d%3d TVS Diodes - Transient Voltage Suppressors HJ Temp Transil]||511-SMA6J5.0A-TR ||3 ||0.38 |||| MO_013 ||O||O||O ||N<br />
|-<br />
|-<br />
|Sylvain V.||[http://www.mouser.fr/ProductDetail/Cirrus-Logic/CS4398-CZZ/?qs=sGAEpiMZZMv%252bLKsN4bqzyhXScoHWAp%252boAQFEBwyfAGo%3d DAC Cirrus Logic]||777-CS4398-CZZ ||1 || 10.46 || Sylvain V. || MO_013 ||O||O||O ||N<br />
|-<br />
|Eric||[https://eu.mouser.com/ProductDetail/Amphenol-Tuchel/T-3427-100?qs=%2fha2pyFaduhPv3s%2fjYa9sAYm3fflPgRKEDSdRTPyUvP7YbNcd%2fVs5g%3d%3d Circular DIN Connectors FEMALE RECEPTACLE 6 WAY, Amphenol series C091B]|| 523-T3427-100 ||1 || 10.29|| <<acheteur>> || MO_014 ||N||N||N ||N<br />
|-<br />
|Eric||[https://www.mouser.fr/ProductDetail/EPCOS-TDK/B32926A4685M?qs=sGAEpiMZZMv1cc3ydrPrF3kXVSi%252b9fyL4PImBI83UxcgTMvwb1977w== Condensateurs à film 6.8uF 20% 350Vac LS 37.5MM Fabricant : EPCOS /TDK ref : B32926A4685M ]|| 871-B32926A4685M ||1 || 10.67|| <<acheteur>> || MO_014 ||N||N||N ||N<br />
|-<br />
|Eric||[https://www.mouser.fr/ProductDetail/Texas-Instruments/OPA2227U-2K5?qs=sGAEpiMZZMtCHixnSjNA6Mrdwin7F8A2DB4TJmgUI0w%3d OPA2227U SOIC8 dual opamp low noise Texas ]|| 595-OPA2227U/2K5 ||2 || 8.07|| <<acheteur>> || MO_014 ||N||N||N ||N<br />
|-<br />
|Eric||[https://eu.mouser.com/ProductDetail/Molex/53253-0570?qs=sGAEpiMZZMvlX3nhDDO4AD1CBCqS4WJ3BaSa47NubxE%3d Shrouded header 5 pins 2mm male through hole board connnector vertical mounting Molex ref. 53253-0570 Cross ref to JST PH "B5B-PH-K-S"]|| 538-53253-0570||20 || 0,164 €|| <<acheteur>> || MO_014 ||N||N||N ||N<br />
|-<br />
|Eric||[https://eu.mouser.com/ProductDetail/Central-Semiconductor/TIP42B?qs=sGAEpiMZZMshyDBzk1%2fWi0MKeUdJDRlz1TXFEdLineJjytqjBdqtHg%3d%3d Bipolar Transistor PNP 10A 80V TIP42B]|| 610-TIP42B ||2 || 0,969 €|| <<acheteur>> || MO_014 ||N||N||N ||N<br />
|-<br />
| Eric|| [https://www.mouser.fr/ProductDetail/Hirose-Connector/RM12BPE-5PH71?qs=sGAEpiMZZMvG94qpybaIZaiKjo18NgShhh8FQGCnH4c%3d HIROSE CONN PLUG Cbl Mount 5 Terminals ref "RM12BPE-5PH(71)"] ||798-RM12BPE-5PH71 || 1|| 11.47 EUR||<acheteur>|| MO_014 || N || N || N || N<br />
|-<br />
| Eric|| [https://www.mouser.fr/ProductDetail/Mueller-Electr/BU-75K?qs=sGAEpiMZZMs4AFwHyzhTm%2f3wHG8LpAJAx37I4fl4y%2fU%3d Kelvin clip 10A Mueller Electric ref. BU-75K] ||548-BU-75K|| 4|| 10.20 EUR||<acheteur>|| MO_014 || N || N || N || N<br />
<br />
|-<br />
|}<br />
<br />
<br />
=== [http://www.motedis.fr/shop/ Motedis France] ===<br />
<br />
<br />
La prochaine commande aura pour référence interne : MS_001<br />
<br />
<br />
<br />
<br />
Anciennes commandes Motedis France archivées [[Projets:Commande_groupee:archives#Motedis France|ici]]<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Motedis!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-<br />
|Eric||Plaquette aluminium 15mm d'épaisseur Largeur: 100mm ||<ref motedis>||L:1000mm|| 24.15EURHT || <acheteur> || MS_001 || N|| N || N || N<br />
|-<br />
|<demandeur>||<description>||<ref motedis>|| <quantité> || <prix>|| <acheteur> || MS_001 || N|| N || N || N<br />
|-<br />
|}<br />
<br />
<br />
===[http://www.nouvelleplastique.it/f/setf.html Nouvelle Plastique]===<br />
La prochaine commande a pour référence interne : NP_001<br />
<br />
Prochaine date de commande : Q3/2014<br />
<br />
<br />
<br />
Anciennes commandes Nouvelle Plastique archivées [[Projets:Commande_groupee:archives#Nouvelle Plastique|ici]]<br />
<br />
La société "[http://www.nouvelleplastique.it/f/setf.html Nouvelle Plastique]" fabrique des systèmes de rangements portables et modulaires en plastique.<br />
Les produits sont souvent bien pensés (parfois mieux que RAACO ou Stanley) et de bonne solidité.<br />
<br />
Malheureusement, ses produits ne sont que rarement distribués par les circuits classiques et pour le moment aucun revendeur de détail en France n'a été identifié. De même, on ne connait pas les prix des produits.<br />
La démarche envisagée est de collecter via le tableau ci-dessous une liste de souhaits afin de pouvoir demander un devis global directement au fabricant d'ici quelques mois (probablement en Q3/2014). En fonction de ses proposition de prix, chacun pourra finalement accepter ou refuser que ses souhaits soient inclus dans la commande définitive. Le coût du port sera partagé au prorata du prix des marchandises achetées (plus il y a de demaneurs, plus le coût individuel du port sera faible).<br />
Pour chaque article, il y a indication d'une UDV (Unité De Vente), c'est à dire de lot indivisible.<br />
Au terme des sélections de vos besoins, il faudra que le nombre de pièces commandées pour chaque article soit un multiple de son UDV.<br />
Le tableau ci-dessous dispose d'une structure adaptée à la gestion des souhaits des demandeurs, du nombre d'article et des UDV.<br />
Tous les demandeurs intéressés par un même article s'inscrivent dans une seule ligne (ce qui conduit au fait qu'il y ait une ligne par référence d'article).<br />
Le champ "PUHT" sera complété une fois le devis obtenu.<br />
<br />
====Légende du tableau ====<br />
<br />
UDV = correspond au nombre d'articles par UDV. = nombre d'articles dans un lot indivisible, cette information est indiquée par le fabricant dans son catalogue. <br />
Reste à affecter = mod(Nombre d'UDV; Nombre d'articles) <br />
<br />
<br />
Si vous éditez une ligne existante pour vous inclure comme demandeur de l'article considéré, modifiez les champs suivants :<br />
*''UDV' *''Nombre d'UDV'' (valeur cumulée d'UDV entre tous les demandeurs) <br />
*''Quantités (nombre d'articles)'' (valeur cumulées en nombre d'articles individuels entre tous les demandeurs) <br />
*''Reste à affecter'' (valeur calculée globalement pour tout les demandeurs) <br />
*''Liste de demandeurs avec (unités)'' Unités = nombre d'articles demandéz<br />
<br />
<br />
{|class="wikitable sortable" style="font-size:99%"<br />
|-<br />
! Ref article!! class="unsortable"| Désignation!! UDV (= nombre d'articles dans un lot indivisible) !! class="unsortable"| Nombre d'UDV!! class="unsortable"| Quantité souhaitée(nombre d'articles) !! Reste à affecter!! PUHT !! Liste de demandeurs avec (unités) !! N° de commande <br />
|-l<br />
|00366|| Tyger maxi double|| 6 || 1 ||6 ||0|| <PU> || Eric (6) || NP_001 <br />
|-<br />
|00361|| Tyger maxi|| 12 || 1 ||6 ||6|| <PU> || Eric (6) || NP_001 <br />
|-<br />
<br />
|}<br />
<br />
=== [https://www.olimex.com/ Olimex]===<br />
<br />
La prochaine commande a pour référence interne : OL_001<br />
<br />
<br />
<br />
<br />
Anciennes commandes Olimex archivées [[Projets:Commande_groupee:archives#Olimex|ici]]<br />
<br />
<br />
Achat par l'intermédiaire de leur site internet: https://www.olimex.com/<br />
<br />
Produits identifiés comme potentiellement intéressants:<br />
* https://www.olimex.com/Products/ARM/TI/TMS570-CAN/ un pti devkit pour un micro bien patator, prévu au départ pour des applications safety mais qui a des périphériques & capacités pas dégueulasses...<br />
* https://www.olimex.com/Products/Modules/Adapters/ pour utiliser leurs modules d'extension avec un launchpad ou un rpi<br />
* https://www.olimex.com/Products/Modules/LCD/ (divers modules LCD)<br />
* https://www.olimex.com/Products/Modules/LCD/MOD-LCD4.3%27%27/ module LCD "complet" avec pti micro sympatoche intégré<br />
* https://www.olimex.com/Products/OLinuXino/ gamme de nanocomputers intégrés & pas chers (type rpi mais en open)<br />
* https://www.olimex.com/Products/Components/Misc/TC-K-TYPE/ thermocouple K <br />
etc...<br />
<br />
<br />
Commande prévue courant mars 2013 par Clem.<br />
Attention, prix HT a priori, et prévoir également frais de port "importants" (environ 20€) à répartir entre les participants à la CG.<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Olimex!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||<Acheteur>|| OL_XXX || N || N || N || N<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| XXX|| XXX || - || - || XXX€||XXX|| OL_001 || N || N || N || N<br />
|-<br />
|-<br />
|}<br />
<br />
=== [http://www.otelo.fr/fr/index.html Otelo] ===<br />
<br />
Outillage bois-métal <br />
<br />
Ports gratuits au delà de 230 € H.T. ou code promo<br />
<br />
La prochaine commande a pour référence interne : OT_004<br />
<br />
Prochaine date de commande : < non définie ><br />
<br />
Commande passée en attente de livraison [AUCUNE]<br />
<br />
<br />
Anciennes commandes Otelo archivées [[Projets:Commande_groupee:archives#Otelo|ici]]<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Otelo!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
|-<br />
--><br />
|-<br />
|lab||TARAUD à main diamètre 14X200 Acier/alu||14104142N1||1|| 14,51€ HT|| <Patrick> || OT_002|| N || O|| O || O<br />
|-<br />
|lab||100 rondelles plates diamètre 8X16 ||36211008||5|| 3,23€ HT|| <Patrick> || OT_002|| N || O|| O || O<br />
|-<br />
|Patrick||Disque à poncer bombé axe 22mm D125 grain 80||54426280||2|| 3,42€ HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|Patrick||boites de rangement 18 sep 375X310X60||PY 69720030||3|| 9,55€ HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|Patrick||jeu d'outils ébavurage||PY 58500009||1|| 7,35€ HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|Patrick||BOMBE GALVA FLASH||PY 73006003||1|| 8,40€ HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|Eric||Tablier de soudeur 90 x 60 cm||PW 75 150 001||1|| 10,90€HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|MAZ24||meule blanche touret||5473014F||1|| 11,40€HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|MAZ24||Meule verte de touret||54571150||1|| 42,40€HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|MAZ24||Bagues adaptation||54703320||4|| 1,09€HT|| <Patrick> || OT_002|| O || O|| O|| O<br />
|-<br />
|Patrick||Mandrin à clef 3-16mm CM2/B18||30140413||1|| 27,25€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Mandrin à clef 1-13mm CM2/B16||30140409||1|| 23,20€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Arbre pour mandrin CM2/B16||30199116||1|| 6,80€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Arbre pour mandrin CM2/B18||30199118||1|| 7,00€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Ecouvillon manche bois 15mm||57169015||1|| 7,70€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Ecouvillon manche bois 25mm||57169025||1|| 8,15€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Ecouvillon à fil 6mm||57169006||1|| 5,24€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Ecouvillon à fil 25mm||57151025||1|| 6,38€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Sylvia||Support articulé ||43130110||1|| 23,77€ HT|| <Patrick> || OT_003|| N || O|| O|| O<br />
|-<br />
|}<br />
<br />
===[http://www.outiz.fr/ Outiz]===<br />
<br />
<br />
Comptoir Guilleraies (Nanterre)<br />
<br />
Du lundi au vendredi 7h - 17h Samedi 8h - 12h<br />
<br />
Téléphone : 01 40 35 77 77<br />
<br />
La prochaine commande aura pour référence interne : OU_001 <br />
<br />
Prochaine date de commande : <non définie><br />
<br />
<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Outiz!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!!Remboursé/Archive (O/N)<br />
|-<br />
| Eric ||[http://www.outiz.fr/sferaco-vanne-a-sphere-laiton-pn25-batiment-ff-3-4-poignee-acier-plate-rouge-580005/p/3806984/ Vanne à poignée plate rouge Genre : FF Ø : 3/4" ] ||3806984 || 1|| 4,54 €HT||<acheteur>|| OU_001 || N || N || N || N<br />
|-<br />
|}<br />
<br />
=== [http://fr.rs-online.com/web/ Radiospares (RS Composants)] ===<br />
<br />
La prochaine commande aura pour référénce interne : RS_012<br />
<br />
<br />
<br />
Commande livrée en cours de distribution : <aucune><br />
<br />
Anciennes commandes Radiospares archivées [[Projets:Commande_groupee:archives#Radiospares|ici]]<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref RS!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||Acheteur|| DI_XXX || N || N || N || N<br />
--><br />
|-<br />
| papy F1CHF||régulateur || 686-9007 || 10 || 0,27€|| <>|| RS_012 || N || N || N || N<br />
|FredericD||[http://fr.rs-online.com/web/p/ldr/9146710/ Silonex, NSL-19M51, CdS, Traversant, TO-18, 20 kΩ → 100 kΩ]||914-6710|| 10 || 1.074€HT ||<>||RS_012||N||N||N||N <br />
|-<br />
|FredericD||[http://fr.rs-online.com/web/p/relais-reed/2562055/ Relais Reed 1NO 12V dc 1 A]||256-2055|| 1 || 5.17€HT ||<>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[http://fr.rs-online.com/web/p/refrigerants/1115853/ Réfrigérant aérosol Cramolin Aérosol 400 ml, -50°C]||111-5853|| 2 || 11.12€HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/accessoires-pour-capteur-de-temperature/0286771/ Presse-étoupe pour Thermocouple]||286-771|| 2 || 9,68€HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|<s>Eric</s>||<s>[https://fr.rs-online.com/web/p/pinces-kelvin/7148263/ Pince Kelvin BU-75K, 10A, noir, fabricant : Mueller]</s>||<s>714-8263</s>||<s> 2</s> ||<s> 19,61€HT</s> ||<s><acheteur></s>||<s>RS_012</s>||<s>N</s>||<s>N</s>||<s>N</s>||<s>N</s> <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/condensateurs-aluminium/8396258 Condensateur électrolytique aluminium radial 10µF, -20%, 50V dc, Traversant, +105°C, WURTH série WCAP-AT1H, 5 (Dia.) x 11mm 5000h 97mA Référence fabricant : 860240672002]||839-6258|| 25 (1 sachet) || 3,90 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/condensateurs-aluminium/8399011 Condensateur électrolytique aluminium radial 47µF, -20%, 63V dc, Traversant, +105°C, WURTH série WCAP-ATUL, 8 (Dia.) x 11.5mm 7000h 360mA ESR: 0.66 Ohms Référence fabricant : 860040774002]||839-9011|| 20 (2 paquets) || 3,12 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/condensateurs-aluminium/8399033 Condensateur électrolytique aluminium 120µF, -20%, 63V dc, Traversant, +105°C, série WCAP-ATUL, 10 (Dia.) x 16mm 7000h 760mA ESR: 0.3 Ohms Référence fabricant : 860040775008]||839-9033|| 20 (4 paquets) || 3,43 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/connecteur-xlr/7259543/ Connecteur XLR femelle plastique pour chassis soudage pour CI 3 broches coudé + blindage avec louet métal, NEUTRIK NC3FAH2]||725-9543|| 2 || 1,97 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/connecteur-xlr/7259549 Connecteur XLR mâle plastique pour chassis soudage pour CI 3 broches coudé + blindage, NEUTRIK NC3MAH ]||725-9549|| 2 || 1,43 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/fusibles-cms-rearmables/5177054/ Fusible CMS réarmable, Littelfuse, 2.2A - 1.1A Référence fabricant : SMD100F-2 MK : 100F]|| 517-7054|| 10 || 0,497 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|<s>Eric</s>||<s>[https://fr.rs-online.com/web/p/roulettes-sur-platine/0819567/ Roulette Pivotante Acier 50mm, Bas profil, 270kg Fabricant : Revvo]</s>|| <s>819-567</s> || <s>4</s>|| <s>34.91 €HT</s> ||<s><acheteur></s>||<s>RS_012</s>||<s>N</s>||<s>N</s>||<s>N</s>||<s>N</s> <br />
|-<br />
|3ds||[https://fr.rs-online.com/web/p/potentiometres/0387896/ Potentiomètre carbone série 23 montage panneau 4K7 B avec interrupteur DPST, axe 6,35mm TE Connectivity ref 23ESB472MMF50AF]||387-896|| 1 || 4,14€HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Louis||[https://fr.rs-online.com/web/p/passe-fils/1366806/ Passe-fils,SES en PVC, Diamètre maximum de câble 3mm Noir ref 01070005010 ]||136-6806|| 1 sachet de 100|| 5,38€HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|}<br />
<br />
<br />
<br />
=== [http://www.stquentin-radio.com/ Saint Quentin radio]===<br />
<br />
La prochaine commande a pour référence interne SQ_002<br />
<br />
Prochaine date de commande : <non défini><br />
<br />
Commande passée en attente de livraison :[aucune]<br />
<br />
<br />
Anciennes commandes Saint Quentin Radio archivées [[Projets:Commande_groupee: Saint Quentin radio|ici]]<br />
<br />
Paiement cash par avance à l'acheteur : payez le montant exact, car il n'y a pas de frais annexes<br />
<br />
Frais de port : 0€ (sauf objets lourds) Gare du Nord<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref St Quentin!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
|-<br />
--><br />
|Lab||DOUILLE DE SECURITE 4mm ECROU BLANC, ref3265-I-9 ||326509 ||3||1.80€||<Patrick>||SQ_001||N||O||O||O<br />
|-<br />
|Lab||Fiche DIN 5BR MALE PLASTIQUE 360°||I076||2||1.00€||<acheteur>||SQ_002||N||N||N||N<br />
|-<br />
|Lab||Fiche DIN 5BR CHASSIS METAL 360°||I088||1||1.20€||<acheteur>||SQ_002||N||N||N||N<br />
|}<br />
<br />
=== [http://www.selectronic.fr Selectronic] ===<br />
<br />
La prochaine commande a pour référence interne : SE_010 <br />
<br />
<br />
<br />
<br />
Anciennes commandes Sélectronic archivées [[Projets:Commande_groupee:archives#Selectronic|ici]]<br />
<br />
Frais de port : 0€ (sauf objets lourds)<br />
<br />
Certains produits sont pas en stock à Paris et requièrent d'être livrés de Lille d'où un délai de quelques jours. Le mieux est d'aller au mag à Nation le mardi pour passer la commande et dans ce cas c'est en principe dispo jeudi sur place.<br />
<br />
<br />
<br />
{|class="wikitable sortable" style="font-size:85%"<br />
|-<br />
! Demandeur !! class="unsortable"| Description || Ref Sélectronic!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-<br />
|Eric||Résistance CTN 10kOhms 10% format goutte traversant||5277|| 1 || 0.95€TTC|| Eric|| SE_008 || O || O || O || O<br />
|- <br />
|lab||Résistance CTN 10kOhms 10% format goutte traversant||5277|| 1 || 0.95€TTC|| Zenos|| SE_009 || N || O || O || N<br />
|-<br />
|Zenos||triac BT139-600||4024|| 3 || 1,90€TTC|| Zenos|| SE_009 || O || O || O || O<br />
|-<br />
|Lab||TIC106D Thyristor||4018|||1||1,52||<acheteur>|| SE_009 || N || O || N (pas dispo) || N <br />
|-<br />
|Eric||IR IRF9540 MOS canal P -100V -19A||08015|||1||2,50EUR||Zenos|| SE_009 || O || O || O || O<br />
|- <br />
|Eric||Mosfet N IRF640N TO220 200V 0.150Ω - 18A||HD75-940|||2||1,94||<acheteur>|| SE_010 || N || N || N || N<br />
|-<br />
|Marc f6itu||pointes de scope||2447|||4||1,02||<acheteur>|| SE_010 || N || N || N || N<br />
|-<br />
|Lab (Eric)||[http://www.selectronic.fr/joints-adhesif-pour-enceintes.html bande mousse autocollante de largeur 5mm, hauteur 2mm]||2300|||2||5.50||<acheteur>|| SE_010 || N || N || N || N<br />
|-<br />
! !! !! !! !! !! !! !! !! !! !!<br />
|}<br />
<br />
=== [http://www.sparkfun.com/ SparkFun Electronics]===<br />
<br />
La prochaine commande a pour référence interne SF_002<br />
<br />
Prochaine date de commande : N/A<br />
<br />
<br />
Commande livrée en cours de distribution : SF_001<br />
<br />
<br />
TVA, frais de port et droits de douane + frais pour dossier de dédouanement : selon taille totale de la commande finale, seront ventilés au pro-rata du montant commandé par chacun.<br />
<br />
Anciennes commandes SparkFun Electronics archivées [[Projets:Commande_groupee:archives#SparkFun Electronics|ici]]<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref SparkFun!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
<!-- Pour ajouter une ligne, copier les 2 lignes suivantes (celles qui commencent par | ) à la suite du tableau et remplacer le contenu des colonnes par ce qui semblera adéquat<br />
|-<br />
--><br />
|Damien H||Spark Gap Igniter - 4.8V||COM-11218||3||$14,95||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Pilou||MIDI Shield||DEV-09595||1||$19,90||<Damien H>||SF_001||N||O||O||O<br />
|-<br />
|Pilou||OpenServo||ROB-09014||2||$14,95||<Damien H>||SF_001||N||O||O||O<br />
|-<br />
|Pilou||Breakout Board for PCF8575 I2C Expander||BOB-08130||1||$11,95||<Damien H>||SF_001||N||O||O||O<br />
|-<br />
|MAZ24||wire stripper||TOL-08696||1||$4,95||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|MAZ24||flush cutter||TOL-11952||1||$6,95||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Eric||Optical Dust Sensor - GP2Y1010AU0F||COM-09689||1||$11,95||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Eric||Mating Connector Housing for Dust Sensor (JST ref#: ZHR-6)||PRT-09690||2||$0,35||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Eric||Crimp Pins for Dust Sensor Connector (JST ref#: SZH-002T-P0.5)||PRT-09728||16||$0,09||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Eric||Copper Tape - 2" (50ft)||PRT-11081||1||$14,95||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Olga||RaspiRobot Board||KIT-11561||1||$29,95||<Damien H>||SF_001||N||O||N||O<br />
|-<br />
|Dom||Copper Tape - 2" (50ft)||PRT-11081||1||$14,95||||SF_002||N||N||N||N<br />
|-<br />
|Jean-Marc (PdM) || Polymer Lithium Ion Battery - 400mAh || PRT-10718 || 1 || $6.95 || || SF_002 || N || N || N ||N<br />
|-<br />
|Jean-Marc (PdM) || SparkFun USB LiPoly Charger - Single Cell || PRT-12711 || 1 || $14.95 || || SF_002 || N || N || N ||N<br />
|-<br />
|Jean-Marc (PdM) || Precision Disc Wheel - 5" (Yellow, 2 Pack) || ROB-12469 || 1 || $6.29 || || SF_002 || N || N || N ||N<br />
|-<br />
|Jean-Marc (PdM) || Set Screw Hub - 3mm Bore || ROB-12512 || 2 || $4.99 || || SF_002 || N || N || N ||N<br />
|-<br />
|Jean-Marc (PdM) || ProtoBoard - Square 2" || PRT-08811 || 1 || $2.95 || || SF_002 || N || N || N ||N<br />
|-<br />
|Jean-Marc (PdM) || Micro Gearmotor - 90 RPM (6-12V) || ROB-12285 || 2 || $12.95 || || SF_002 || N || N || N ||N<br />
|- <br />
|Jean-Marc (PdM) || SparkFun Solderable Breadboard - Mini || PRT-12702 || 1 || $2.95 || || SF_002 || N || N || N ||N<br />
|- <br />
|}<br />
<br />
=== Subtel.fr ===<br />
<br />
Pas de frais de port, prix TVA comprise<br />
<br />
<br />
<br />
Commande livrée en cours de distribution : [aucune] <br />
<br />
Anciennes commandes Subtel.fr archivées [[Projets:Commande_groupee:archives|ici]]<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Subtel!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Archive (O/N)<br />
|-l<br />
|-<br />
|}<br />
<br />
=== raspberry-pi-zero ===<br />
Une opportunité dégotée par Francis: une version du raspberry-pi, un peu spartiate, pour 5 euros!<br />
https://www.raspberrypi.org/blog/raspberry-pi-zero/<br />
<br />
On peut également acheter le kit: http://swag.raspberrypi.org/collections/pi-kits/products/pi-zero-cables<br />
C'est le cordon midi-hdmi/hdmi, PLUSSE la barrette gpio.<br />
<br />
Cette entrée est mise en place alors que tout n'est pas défini pour cet achat: ni le fournisseur (fournisseur initial en rupture de stock), ni le prix.<br />
Mais ce sera le support pour rassembler les commandes. Je tiendrai ce paragraphe à jour selon les infos.<br />
<br />
Le kit comprend l'adaptateur micro-hdmi/hdmi (1 cordon + 1 petit adaptateur?), et la barette 2x20, à souder, pour les gpio. Le raspberry n'est pas dans le kit!<br />
<br />
Le prix: 5 euros le kit, idem le raspberry, et quelques pourcent pour les frais de transport. <br />
<br />
(ce soir: site http://swag.raspberrypi.org/ down; ??)<br />
<br />
<br />
On peut aussi attendre 3 semaines le temps que cela soit livré directement chez vous et avoir<br />
<br />
- l'adaptateur micro hdmi mâle- hdmi femelle : http://www.banggood.com/Gold-Plated-Micro-HDMI-Type-D-Male-To-HDMI-Female-Adapter-p-974265.html<br />
<br />
- un adaptateur micro-hdmi vers VGA femelle sans le son : http://www.banggood.com/1080P-HDMI-Male-To-VGA-Female-Adapter-Video-Converter-Cable-p-937626.html<br />
<br />
- un adaptateur micro-hdmi vers VGA femelle avec le son : http://www.banggood.com/Sin-Hon-SH-MH2V02-Micro-HDMI-to-VGA-Cable-Adapter-with-Audio-p-907524.html<br />
<br />
- un adaptateur micro usb coudé(pratique pour ranger sur le côté : http://www.banggood.com/Micro-USB-Host-OTG-Cable-For-Samsung-HTC-p-79909.html<br />
<br />
- pour se faire une prise alim micro usb, on déboîte le capot et on soude : http://www.banggood.com/USB-2_0-Micro-B-Male-to-Mini-B-Female-5-Pins-Adapter-p-956044.html<br />
<br />
- toutes sortes d'alim : http://www.banggood.com/search/usb-2a-charger.html<br />
<br />
- de quoi s'amuser avec les GPIO : http://www.banggood.com/search/gpio-raspberry/1091-0-0-0-0-0-0-price-0-0_p-1.html<br />
<br />
Et si vous avez le temps de chercher c'est encore moins cher sur http://fr.aliexpress.com/<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| raspberry ou kit !! class="unsortable"| Quantité !! class="unsortable"| Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Archive (O/N)<br />
|-l<br />
|-<br />
!Pierre Grommit !!raspb !! 2 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!Pierre Grommit !!kit !! 1 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!Francis Roussel !!rasp !! 2 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!papy F1CHF !!kit !! 4 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!PDA !!rasp !! 3 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!yvs Accard !!rasp !! 3 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!yvs Accard !!Kit !! 1 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!Malek H. !!3 rasp + 2 vga son + 1 gpio + 1 otg !! 1 !! 1 !! n!! n !!n !! n!!<br />
<br />
<br />
|}<br />
<br />
<br />
=== Starterkit FPGA Altera Max10 ===<br />
'''COMMANDE CLOSE'''<br />
<br />
[https://www.arrow.com/en/products/bemicromax10/arrow-development-tools#page-1 Carte de démarrage FPGA] qui sera parfait pour les [[Formations#Initiation_.C3.A9lectronique_num.C3.A9rique_et_FPGA|formation initiation à venir]].<br />
<br />
Cette carte utilise un FPGA entrée de gamme MAX 10 de chez Altera. Elle contient tout un tas de périphériques sympa pour débuter.<br />
<br />
A noter que la board intègre une sonde JTAG Altera Blaster II (>200€ dans le commerce, 20€ pour un clone).<br />
<br />
Le prix: $30 le kit, disons donc 30€ (à réajuster à la baisse post commande). <br />
<br />
Date butoir pour la commande: mercredi 6 avril 2016<br />
<br />
Chip principal: MAX® 10 FPGA (10M08DAF484C8G):<br />
* 8,000 LEs (largement de quoi mettre le soft core 32bit Altera & des périphériques confortables)<br />
* 414 Kbit (Kb) M9K memory<br />
* 256 Kbit (Kb) user flash memory<br />
* 2 phase locked loops (PLLs)<br />
* 24 18x18-bit multipliers<br />
* 1 ADC block – 1 MSa/sec, 12-bit, 18-channels<br />
* 17 analog inputs<br />
* 1 temperature sense diode<br />
* 250 general purpose input/output (GPIO)<br />
* Non-volatile self-configuration with dual-boot support<br />
* Clocking circuitry: 50 MHz oscillator and 24 MHz oscillator<br />
* achetable à l'unité (moins cher de la gamme: 3€, celui ci, 30€)<br />
<br />
External peripherals<br />
* 8MB SDRAM (4Mb x 16) (ISSI IS42S16400)<br />
* Accelerometer, 3-Axis, SPI interface (Analog Devices ADXL362)<br />
* DAC, 12-bit, SPI interface (Analog Devices AD5681)<br />
* Temperature sensor, I2C interface (Analog Devices ADT7420)<br />
* Thermal resistor<br />
* Photo resistor<br />
* 8 user LEDs<br />
* 2 user Pushbuttons<br />
<br />
Prototyping<br />
* Two 6-pin PMOD expansion headers<br />
* Two 40-pin prototyping headers which provide access to 64 digital I/O<br />
* 6 analog inputs<br />
* One 80-pin BeMicro card edge connector<br />
<br />
<br />
Merci d'ajouter votre nom et votre rapport à l'éventualité de formations au lab:<br />
* débutant, intermédiaire, expert: sous entendu je veux assister à une formation & j'ai ce niveau<br />
* formateur: je suis volontaire pour participer à l'élaboration de formations<br />
* pas intéressé: ni en participant ni en formateur<br />
<br />
Merci d'indiquer:<br />
* combien vous en achetez à titre perso (30€ pièce, à revoir selon le change & port)<br />
* si vous voulez en prendre une à offrir aux formations du lab (vous payez 20€, moi 10€ ; il nous faut 10 cartes)<br />
<br />
<br />
'''MISE A JOUR RECEPTION'''<br />
Prix total 40€/carte. 25€ par carte offerte au lab. Merci de vous mettre à jour, et venez récupérer vos cartes auprès de Coline :)<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Formation? !! class="unsortable"| Quantité !! class="unsortable"| cadeau au lab !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Archive (O/N)<br />
|-l<br />
|-<br />
|-<br />
!flax !!formateur!! 1 !! non !! O!! n !!n !! n!!<br />
|-<br />
!flax !!formateur!! 1 !! oui !! O!! n !!n !! n!!<br />
|-<br />
!Clem !!formateur!! 1 !! N/A !! O!! n !!n !! n!!<br />
|-<br />
!3dsman!!débutant !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
!3dsman!!débutant !! 1 !! oui !! n!! n !!n !! n!!<br />
|-<br />
!Yann D!!débutant !! 2 !! non !! n!! n !!n !! n!!<br />
|-<br />
!Yannick A.!!formateur !! 1 !! oui !! n!! n !!n !! n!!<br />
|-<br />
!Yannick A.!!formateur !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
!F1HSU!!débutant !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
!Roul!!formateur? !! 1 !! oui !! n!! n !!n !! n!!<br />
|-<br />
!Roul!!formateur? !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
!Jojo du VoLAB !!intermédiaire !! 2 !! non !! n!! n !!n !! n!!<br />
|-<br />
!Jojo du VoLAB !!intermédiaire !! 1 !! oui !! n!! n !!n !! n!!<br />
|-<br />
!MrPozor !!débutant !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
!Julien Len!!débutant !! 1 !! oui? !! n!! n !!n !! n!!<br />
|-<br />
!Julien Len!!débutant !! 1 !! non!! n!! n !!n !! n!!<br />
|-<br />
!Jérôme Loï!! débutant !! 1? !! oui !! O(payé 30)!! n !!n !! n!!<br />
|-<br />
!Jérôme Loï!! débutant !! 1 !! non!! O!! n !!n !! n!!<br />
|-<br />
!Moala!!débutant !! 1 !! non !! O!! n !!n !! n!!<br />
|-<br />
!Desty!!debutant !! 1 !! oui !! n!! n !!n !! n!!<br />
|-<br />
!Desty!!debutant !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
<br />
!Votre nom!!type !! nombre !! oui/non !! n!! n !!n !! n!!<br />
<br />
<br />
<br />
|}<br />
Nombre de cartes total: 23 dont lab: 8 (total à mettre à jour !)</div>Erichttps://wiki.electrolab.fr/Projets:Commande_groupeeProjets:Commande groupee2018-12-03T16:43:24Z<p>Eric: /* Radiospares (RS Composants) */</p>
<hr />
<div>=Commandes groupées=<br />
<br />
== Principe ==<br />
Tout projet a régulièrement besoin de matières premières, composants, fournitures diverses, etc. Le lab a en stock une quantité importante de fournitures plus ou moins courantes, mais cela ne peut remplacer des commandes régulières.<br />
<br />
Histoire de mutualiser les bons plans & regrouper les frais de port, profiter de divers price breaks, etc, cette page a été créee pour organiser des commandes groupées.<br />
<br />
== Glossaire ==<br />
===Demandeur===<br />
Celui qui a besoin d'un article<br />
<br />
===Acheteur===<br />
Celui qui passe effectivement la commande chez le Fournisseur. L'Acheteur peut être le lab ou une personne privée.<br />
Dans le cas du lab indiquer dans la colonne "acheteur" lab_<nom/pseudo membres> exemple : lab_peewee<br />
Sauf avis contraire, le paiement est à effectuer sur le compte paypal du lab.<br />
<br />
Dans le cas d'une personne privée, indiquer dans la colonne "acheteur", son nom ou pseudo.<br />
L'Acheteur définit lui même les moyens de paiement à utiliser par les <demandeurs>.<br />
<br />
<br />
===Distributeur===<br />
Fournisseur ou fabricant chez qui l'<acheteur> passe commande.<br />
Chaque <distributeur> dispose d'une rubrique propre.<br />
<br />
Il est bien entendu possible d'ajouter des <distributeurs> supplémentaires (notez qu'ils sont triés par '''ordre alphabétique''').<br />
<br />
== Règles du jeu ==<br />
<br />
En général, lorsque l'on s'occupe d'un "group buy", on fait un premier tour de<br />
table pour savoir qui est partant, on annonce ensuite le prix de l'addition<br />
générale (TTC et frais d'expé avec ou sans assurance, éventuels frais de<br />
dédouanement) divisée par le nombre de participants (au prorata des volumes<br />
de commande : celui qui achète 2 items paye 2 parts de frais de port par<br />
exemple).<br />
<br />
Ceci fait, on attend qu'une "masse critique" soit atteinte lorsque l'on vise<br />
certains "price break" (décollonage en jargon de vendeur), puis on lance<br />
l'appel aux fonds avec une date butoir. Passé la date butoir, la commande<br />
est passée, en ignorant ceux qui n'ont pas répondu a temps, puisque le<br />
responsable de group buy n'a pas la trésorerie correspondant à l'achat en<br />
question.<br />
Les histoires genre "le chèque est au courrier" ne marchent pas avec des<br />
virements Paypal... le patron des achats sait exactement combien il a en<br />
caisse au moment de la commande.<br />
<br />
En cas de perte de colis, le responsable de "group buy" n'est pas<br />
redevable. C'est à chaque participant d'estimer s'il prend le risque ou non<br />
de faire confiance aux entreprises assurant l'acheminement des colis.<br />
C'est simple, et si c'est précisé, aucun conflit n'est à redouter, aucun lot<br />
ne reste sur les bras de l'<acheteur>.<br />
<br />
Pour le paiement par avance, celui-ci peut se faire au lab, mais c'est TTC et AVEC les frais de port et de douane, le cas échéant.<br />
<br />
Si un <demandeur> commande la mauvise référence, c'est pour sa pomme.<br />
<br />
Dans la mesure du possible, les <demandeur> doivent faciliter au maximum le travail des <acheteur> en indiquant des références d'articles et de désignation claires.<br />
<br />
==Mode opératoire lorsqu'on passe une commande chez l'un des distributeurs ==<br />
Les tableaux ci-après (un tableau par <distributeur> disposent des colonnes nécessaires à la synchronisation des commandes article par article.<br />
<br />
De même, chaque rubrique dispose d'un en-tete d'information qui a la structure suivante :<br />
<br />
La prochaine commande a pour référence interne : YY_xxx<br />
Commande livrée en cours de distribution : [aucune]<br />
Anciennes commandes <nom du distributeur> archivées [[Projets:Commande_groupee:archives|ici]]<br />
< informations complémentaires notamment en ce qui concerne les conditions de livraison, etc>''<br />
<br />
YY est un code fixe, unique pour chaque founisseur.<br />
<br />
xxx un le n° de commande pour ce distributeur. Il commence à 001 et s'incrémente à chaque commande.<br />
<br />
<br />
===Les différentes étapes de la commande ===<br />
<br />
====Prise en charge d'un commande par un <acheteur>==== <br />
La personne qui souhaite prendre en charge une commande chez un <distributeur> envoie un mail sur la ML pour informer tout le monde de cette action.<br />
Dans l'entête d'information du <distributeur> concerné, l'<acheteur> effectue les modifications suivantes :<br />
*mise à jour de la ligne ''Prochaine date de commande'' : valorisé à la date à laquelle il envisage de passer la commande auprès du <distributeur>. <br />
<br />
À ce moment, l'ensemble des <demandeurs> concernés se met en relation avec l'<acheteur> pour lui payer d'avance les articles commandés. Pour ces articles, l'<acheteur> fait les modifications suivantes dans le tableau des articles :<br />
*''Payé d'avance (O/N)'' : valorisé à "O" (Oui)<br />
<br />
<br />
====Passage effective de la commande par l'<acheteur>==== <br />
<br />
Celui qui passe la commande ( = <acheteur>) sélectionne les articles qu'il commande effectivement (= ceux pour lesquels il a reçu le paiement en avance). Il peut aussi inclure dans la commande des articles de <demandeurs> pour leuquel il est certain d'être payé au moment de la distribution.<br />
<br />
L'<acheteur> passe la commande auprès du distributeur (par internet, mail, téléphone, télécopie, signaux de fumée, déplacement sur place...) et effectue le paiement à l'aide d'un moyen de paiement à sa convenance. Il est judicieux de priviléger des moyens de paiement fournissant la traçabilité de la transaction.<br />
<br />
Pour les articles effectivement COMMANDÉS l'<acheteur> fait les modifications suivantes dans le tableau des articles :<br />
*'' Acheteur'' : valorisé par son nom/pseudo <br />
*''Commandé (O/N)'' : valorisé à "O" (Oui)<br />
<br />
Pour les articles qui n'ont pas déja été concernés par une commande précédente et que l'<acheteur> ne COMMANDE PAS (par exemple par ce que le <demandeur> ne s'est pas manifesté auprès de lui), il fait les modifications suivantes dans le tableau des articles :<br />
*''N° de commande'' : est incrémenté d'une unité afin que cet article non commandé soit inclus dans la prochaine commande.<br />
<br />
<br />
*mise à jour de la ligne ''Prochaine date de commande'' : valorisé à <non défini><br />
*mise à jour de la ligne ''La prochaine commande a pour référence interne'' : valorisé au numéro de commande interne actuel +1 <br />
*mise à jour de la ligne ''Commande passée en attente de livraison'': valorisé au n° de commande actuel<br />
<br />
====Réception de la commande par l'<acheteur>==== <br />
<br />
<br />
Au moment de la réception du colis, l'<acheteur> vérifie si la livraison est complète et négocie avec le <distributeur> en cas de problème. Il peut aussi informer le <demandeur> concerné par le ou les article(s) en litige ou manquants.<br />
<br />
====Distribution des articles aux <demandeurs>====<br />
Lorsque la distribution peut commencer l'<acheteur> effectue les modifications suivantes dans l'entête d'information du <distributeur> concerné :<br />
*mise à jour de la ligne : '' Commande passée en attente de livraison'' à [aucune]<br />
*mise à jour de la ligne : '' Commande livrée en cours de distribution '' avec la référence interne de la commande.<br />
<br />
L'<acheteur> informe via la ML les <demandeurs> du début de la distribution de la commande <référence interne de commande>.<br />
Chaque <demandeur> convient d'un RDV avec l'<acheteur> pour récupérer les articles (en principe cela se passe au lab) et payer son dû à l'<acheteur>, si ce n'est déja fait.<br />
<br />
Pour chaque article l'<acheteur> fait les modifications suivantes dans le tableau des articles :<br />
*'' Distribué (O/N)'' : valorisé à "O" (Oui) <br />
*''Remboursé/Archivé (O/N)'' : valorisé à "O" (Oui)<br />
<br />
====Ditribution des articles terminée====<br />
<br />
Une fois l'ensemble des pièces distribuées et payées, dans l'entête d'information du <distributeur> concerné, l'<acheteur> effectue les modifications suivantes :<br />
*mise à jour de la ligne ''Commande livrée en cours de distribution'' : valorisé à [aucune]<br />
<br />
<br />
===En conclusion ===<br />
<br />
Si les tableaux des commandes et les en-tête d'information sont gérés avec soin, il n'y a quasiment aucun risque de double commande et n'importe quel membre sait où on en est et peut à tout moment prendre la main sur l'un des tableaux d'achats pour commander un article ou organiser une commande en tant qu'<acheteur>. La bonne application de ces quelques recommandation bénéficie à l'ensemble des participants de ce système de commandes groupées.<br />
<br />
Sauf besoin urgent de pièces, il est bénéfique que ce soit de préférence les mêmes <acheteurs> qui officient auprès des mêmes <distributeurs>. Ainsi, vu de ces derniers, l'<acheteur> est très vite identifié comme "client important" (car en réalité il commande pour 5-10 personnes, voire plus) et peut bénéficier de conditions particulières (frais de port gratuit, -15% sur la prochaine commande, etc).<br />
<br />
Enfin, à tout moment en tant que <demandeur>, soyez diligent envers l'<acheteur> dont la gestion d'une commande de parfois plusieurs dizaines d'articles requert un investissement en temps non négligeable.<br />
<br />
== Commandes groupées passées (archives) ==<br />
<br />
Afin d'améliorer la lisibilité nous avons regroupé les commandes passées sur cette page: [[Projets:Commande_groupee:archives]]<br />
<br />
== Commandes groupées en cours ==<br />
<br />
=== BHV ===<br />
<br />
La prochaine commande a pour référence interne : BH_003<br />
<br />
<br />
<br />
<br />
Anciennes commandes BHV archivées [[Projets:Commande_groupee:archives#BHV|ici]]<br />
<br />
achat sur place<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref BHV!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| Lab|| Réglet métallique 30cm || - || 3 || 5.90€||Eric|| BH_001 || N || O || O || O<br />
|-<br />
|-<br />
| Lab|| Scie a métaux FACOM 603E || - || 1 || env. 36€||Eric|| BH_002 || N || O || 0 || O<br />
|-<br />
|}<br />
<br />
=== [http://www.visseriefixations.fr/ Cergy-Vis] ===<br />
<br />
<br />
La prochaine commande a pour référence interne : CV_002<br />
<br />
<br />
<br />
<br />
Anciennes commandes Cergy-Vis archivées [[Projets:Commande_groupee:archives|ici]] <br />
<br />
Retrait gratuit sur place<br />
CERGY-VIS<br />
<br />
17, Rue du Périgord<br />
<br />
ZI des Béthunes<br />
<br />
95310 SAINT OUEN L’AUMONE<br />
<br />
<br />
Horaires pour les enlèvements: Du Lundi au Vendredi, de 7h30 à 12h00 et de 13h30 à 17h30.<br />
<br />
<br />
Livraison<br />
Colissimo Régional (0.05kg / France) 5,75 €<br />
<br />
Colissimo Régional (0.2888kg / France) 6,54 €<br />
<br />
Colissimo Régional (2.87kg / France) 9,25 €<br />
<br />
Colissimo Régional (12.8948kg / France) 16,50 €<br />
<br />
Anciennes commandes Cergy-Vis archivées [[Projets:Commande_groupee:archives#Cergy-Vis|ici]]<br />
<br />
<br />
|-<br />
!Demandeur !! class="unsortable"| Description !! Référence!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-<br />
||Eric|| TRCC M5X30 INOX A2 DIN 603|| ||50||0.17EURTTC||<acheteur>||CV_001||N||O||O||N (attends remb. trop versé)<br />
|-<br />
||Eric|| ECROU HU M12 PAS 100 Z.BLANC DIN 934|| ||20||0.39EURTTC||<acheteur>||CV_001||N||O||O||N (attends remb. trop versé)<br />
|-<br />
||Eric||Vis TCHC M5X22 INOX A2 EF DIN 912||TCHC05/022A2EF||15||0.12EURTTC||<acheteur>||CV_002||N||N||N||N<br />
|-<br />
||Eric||Vis STHC PLAT M6X12 INOX A2 DIN 913||STHCPLA06/012A2||30||0.06EURTTC||<acheteur>||CV_002||N||N||N||N<br />
|-<br />
||Eric||Vis TH M6X12 INOX A2 EF DIN 933||TH06/012A2EF||30||0.09EURTTC||<acheteur>||CV_002||N||N||N||N<br />
|-<br />
|}<br />
<br />
=== [http://www.conradpro.fr Conrad Electronique France] ===<br />
<br />
<br />
La prochaine commande aura pour référence interne : CO_017<br />
<br />
Prochaine date de commande :<br />
<br />
Commande passée en attente de livraison : NEANT<br />
<br />
Commande livrée en cours de distribution : NEANT<br />
<br />
Anciennes commandes Conrad Electronique France archivées [[Projets:Commande_groupee:archives#Conrad Electronique France|ici]]<br />
<br />
{| class="wikitable sortable" style="font-size:85%"<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Conrad!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€ ||<Acheteur>|| CO_XXX || N || N || N || N<br />
|-<br />
--><br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/822746/Fil-de-soudure-pour-PVC-rigide-Steinel-073114-26-pcs Fil de soudure pour PVC rigide Steinel 073114 26 pcs]</s>||<s>822746 - 62 </s>||<s> 1 </s>||<s> € 5.99 TTC</s>||<s><acheteur> </s>||<s> CO_014 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/492161/Soudure-plastique-225-mm-4-mm-polythylne-LDPE-nature-Bosch-1609201811 Soudure plastique, 225 mm, 4 mm, polyéthylène (LDPE) nature Bosch 1609201811]</s>||<s>492161 - 62 </s>||<s> 1 </s>||<s> € 15.99 TTC</s>||<s> <acheteur> </s>||<s> CO_014 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/121588/Solution-de-conservation-pour-electrodes-de-mesure-pH-HI-70300M Solution de conservation pour électrodes de mesure pH HI 70300M]</s>||<s>121588 - 62 </s>||<s> 1 </s>||<s> € 15.12 TTC</s>||<s> <acheteur> </s>||<s> CO_014 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/121586/Solution-de-nettoyage-pour-electrodes-pH-HI-7061M Solution de nettoyage pour électrodes pH HI 7061M]</s>||<s>121586 - 62 </s>||<s> 1 </s>||<s> € 15.12 TTC</s>||<s> <acheteur> </s>||<s> CO_014 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|Eric||[http://www.conrad.fr/ce/fr/product/121164/Sol-de-conduct-12880-S-HI-70030-P Sol. de conduct. 12880 µS HI 70030 P]||121164 - 62 || 1 || € 38.30 TTC|| <Pat> || CO_014 || N || O || O || O<br />
|-<br />
|Eric||[http://www.conradpro.fr/ce/fr/product/822188/Knipex-Pinces-pour-circlips-pour-colliers-dtranglement-darbre-46-11-G0-140-mm?ref=searchDetail Pince KNIPEX 46 11 G0]||822188 - 62 || 1 || € 20.13 HT|| <Pat> || CO_014 || N || O || O || O<br />
|-<br />
|Eric||[http://www.conradpro.fr/ce/fr/product/822189/Knipex-Pinces-pour-circlips-pour-colliers-dtranglement-darbre-46-11-G1-140-mm?ref=searchDetail Pince KNIPEX 46 11 G1]||822189 - 62 || 1 || € 13.02 HT|| <Pat> || CO_014 || N || O || O || O<br />
|-<br />
|MrPozor||[http://www.conrad.fr/ce/fr/product/702246/Interrupteur-de-porte-Panasonic-AZC11113HJ-250-VAC-5-A-poussoir-momentan-IP40-1-pcs?ref=searchDetail Interrupteur de porte Panasonic AZC11113HJ]||702246 - 62 || 1 || € 10.99 TTC|| <Pat> || CO_014 || N || O || N || N<br />
|-<br />
| papy F1CHF || 74HC390 SOIC || 1115010-62 || 10 || 1.06€ ||<Pat>|| CO_014 || O || O || O || O<br />
|-<br />
| Pat|| Condo moteur 5uF 450V || 441527-62 || 1 || 6.33€ H.T. ||<Pat>|| CO_014 || O || O || N || N<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/731484/Adaptateur-avec-fiche-dor-32-A-rouge-MultiContact-240160-22 Adaptateur avec fiche doré 32 A rouge MultiContact Ref. 24.0160-22]|| 731484 - 62 || 2 || 3.00 € H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/731559/Disque-de-marquage-couleur-MultiContact-145010-vert-jaune-1-pcs Disque de marquage couleur MultiContact Ref. 14.5010 vert-jaune 1 pc(s)]|| 31559 - 62 || 3 || 0.75 € H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/106109/Pointe-de-touche-de-scurit-MultiContact-XMA-7L-enfichable-4-mm-CAT-IV-1000-V-bleu Pointe de touche de sécurité MultiContact XMA-7L enfichable 4 mm CAT IV 1000 V bleu Ref. MC 66.9509-23]|| 106109 - 62 || 1 || 15.96 € H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/106108/Pointe-de-touche-de-scurit-MultiContact-XMA-7L-enfichable-4-mm-CAT-IV-1000-V-rouge Pointe de touche de sécurité MultiContact XMA-7L enfichable 4 mm CAT IV 1000 V rouge Ref. MC 66.9509-22]|| 106108 - 62 || 1 || 15.96 € H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/106107/Pointe-de-touche-de-scurit-MultiContact-XMA-7L-enfichable-4-mm-CAT-IV-1000-V-noir Pointe de touche de sécurité MultiContact XMA-7L enfichable 4 mm CAT IV 1000 V noir Ref. MC 66.9509-21]|| 106107 - 62 || 1 || 15.96 € H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/1385649/Pince-crocodile-4-mm-GRIP-FMA-MultiContact-669435-21 Pince crocodile 4 mm GRIP-FMA MultiContact Ref. 66.9435-21]|| 1385649 - 62 || 1 || 30.00€ H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Damien H || MOSFET RFD14N05L || 512-RFD14N05L || 5 || 0,695 € ||?|| CO_015 || N || O || O || O<br />
|-<br />
| Damien H || Zener BZX79C2V4 || 512-BZX79C2V4 || 5 || 0,11 € ||?|| CO_015 || N || O || O || O<br />
|-<br />
|Pierre G|| Câble audio SpeaKa 1m mf||986736 - 62 || 2||6,66 ht || ? || CO_015 || N || O || O || O<br />
|-<br />
|Pierre G|| Câble audio SpeaKa 0,50m mf||986735 - 62 || 1||5.92 ht || ? || CO_015 || N || O || O || O<br />
|-<br />
|Pierre G|| Lentille Dialight OPC-11SPOT transparent 10 ° 1 pc(s)||1127266 - 62 || 1||3 ht || ? || CO_016 || N || O || O || O<br />
|-<br />
|Pierre G|| LED High Power Barthelme 61003528 blanc chaud||1503528 - 62 || 1||3,50 ht || ? || CO_016 || N || O || O || O<br />
|-<br />
|FredericD|| [http://www.conrad.fr/ce/fr/product/574223/Transformateur-electronique-Standard-10-a-60-W Transformateur électronique "Standard" 10 à 60 W]||574223 - 62 || 1||15,49 '''TTC''' || <acheteur> || CO_017 || N || N || N || N<br />
|-<br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/542044/?insert=32&insertNoDeeplink&productname=Gaine-thermoretractable-pour-batteries-sans-colle-21-Conrad-Components-542044-transparent-avant-retreint-44-mm-1-pc Gaine thermorétractable 2:1 transparente pour accus longueur 100 cm largeur 44mm]</s>||<s>542044 - 32</s>||<s>3</s>||<s>2,70€TTC</s>||<s> <acheteur> </s>||<s> CO_017 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/100297/Solution-conductrice-1413-S-HI-70031-P?ref=list Solution conductrice 1413 µS HI 70031 P]</s>||<s>100297 - 62 </s>||<s> 1 </s>||<s> € 33,60 TTC</s>||<s> <acheteur> </s>||<s> CO_017 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|<s>Eric</s>||<s>[http://www.conradpro.fr/ce/fr/product/1305022/Diode-Zener-PanJit-1N4740A-G-DO-41G-Tension-Zener-10-V-1-pcs?ref=searchDetail Diode Zener PanJit 1N4740A-G DO-41G Tension Zener: 10 V]</s>||<s>1305022 - 62 </s>||<s> 10 </s>||<s> € 0,15 TTC</s>||<s> <acheteur> </s>||<s> CO_017 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/812811/tain-de-soudure-teneur-en-plomb-Stannol-HS-10-Sn60Pb39Cu1-bobine-100-g-10-mm?queryFromSuggest=true étain 100g 1mm STANNOL]|| 812811 - 62 || 2 || 7,55 € H.T. ||<acheteur>|| CO_017 || N || N || N || N<br />
|-<br />
|Eric||[http://www.conrad.fr/ce/fr/product/651105/XLR-Bride-mle-contacts-couds-Neutrik-NC3MAAH-Nombre-de-ples-3-noir-1-pcs?queryFromSuggest=true Connecteur XLR mâle plastique pour chassis soudage pour CI 3 broches coudé + blindage, NEUTRIK NC3MA(A)H ]||651105 - 62|| 2 || 1,20€TTC ||<acheteur>||CO_017||N||N||N||N <br />
|-<br />
|}<br />
<br />
Anciennes commandes Conrad archivées [[Projets:Commande_groupee:archives#Conrad_Electronique_France|ici]]<br />
<br />
=== [http://www.damencnc.com/fr DamenCNC] ===<br />
<br />
Accessoires pour machines CNC [http://www.damencnc.com]<br />
<br />
La prochaine commande a pour référence interne : DC_002<br />
<br />
Prochaine date de commande : ?? (probablement en octobre 2014)<br />
<br />
<br />
<br />
Livraison : depuis les Pays-Bas par UPS : estimation : 20€ pour un colis de 1.5kg<br />
<br />
ATTENTION : Prix HT.<br />
<br />
Anciennes commandes DamenCNC archivées [[Projets:Commande_groupee:archives#DamenCNC|ici]]<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref DamenCNC!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||<Acheteur>|| OT_XXX || N || N || N || N<br />
|-<br />
--><br />
|-<br />
|Goldo|| HIWIN HGR Profile Rail L=200mm || HG15R || 2 || 21,60€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|Goldo|| HIWIN Carriage HGH "Compact type" || HGH-15CA || 2 || 33.99€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|Goldo|| Mini Mill 2 flutes 0.20mm || ? || 1 || 11.99€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|Goldo|| Mini Mill 2 flutes 0.30mm || ? || 1 || 11.99€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|Goldo|| Mini Mill 2 flutes 0.50mm || ? || 1 || 9.99€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|Goldo|| Kress Collet + Clamp Nut 1/8inch || ? || 1 || 19.99€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|F1CHF|| Mini Mill 2 flutes 0.50mm || ? || 2 || 9.99€HT || Goldo || DC_001 || N || O || O || O<br />
|-<br />
|F1CHF|| Mini Mill 2 flutes 0.70mm || ? || 2 || 9.99€HT || Goldo || DC_001 || N || O || O || O<br />
|-<br />
|Eric||IPS_Cable_Assembly M12_Straight_Female/OPENEND_3meter || ? || 2 || 4.99€HT || <acheteur>|| DC_002 || N || N || N || N<br />
<br />
|}<br />
<br />
===[http://www.detandt.com/fr Detandt-Simon]===<br />
<br />
La prochaine commande aura pour référence interne : DET_001 <br />
<br />
Prochaine date de commande : Mardi 2/2/2016<br />
<br />
<br />
Commande livrée en cours de distribution : [nada] <br />
<br />
Anciennes commandes Detandt archivées [nope]<br />
<br />
Frais de livraisons: inconnu<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Taille !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!!Remboursé/Archive (O/N)<br />
|-<br />
<!-- Pour ajouter une ligne, copier les 2 lignes suivantes (celles qui commencent par | ) à la suite du tableau et remplacer le contenu des colonnes par ce qui semblera adéquat--><br />
| Steve|| Modèle haut Bleu et gris || Taille 44 || 1|| 15€ HT||Steve|| DET_001 || N || N || N || N<br />
|-<br />
| Steve|| Modèle haut Bleu et gris || Taille 45 || 1|| 15€ HT||Steve|| DET_001 || N || N || N || N<br />
|-<br />
| Laurent d. Lo^2 || Modèle haut orange et noir || Taille 44 || 1|| 15€ HT||Laurent|| DET_001 || N || N || N || N<br />
|-<br />
| Laurent d. Lo^2 || Modèle cuir noir || Taille 44 || 1|| 15€ HT||Laurent|| DET_001 || N || N || N || N<br />
|-<br />
| Beatrice/LK999 || Modèle cuir noir ou bas || Taille 45|| 1|| 15€ HT||XXX|| DET_001 || N || N || N || N<br />
|-<br />
| Le Xav || Modèle noir & orange haut || Taille 45|| 1|| 15€ HT||XXX|| DET_001 || N || N || N || N<br />
|-<br />
| Patrick|| 10m gaine VMC alu D80 M0|| HALUM0 82|| 2|| 13,78€ HT||XXX|| DET_002 || N || N || N || N<br />
|-<br />
| Patrick|| 10m gaine VMC alu D125 M0|| HALUM0 127|| 1|| 15,96€ HT||XXX|| DET_002 || N || N || N || N<br />
|-<br />
|}<br />
<br />
===[http://www.digikey.com/ Digikey Corporation]===<br />
<br />
La prochaine commande aura pour référence interne : DI_006<br />
<br />
<br />
Commande passée en attente de livraison : DI_005 <br />
<br />
Commande livrée en cours de distribution : NEANT <br />
<br />
Anciennes commandes Digikey Corporation archivées [[Projets:Commande_groupee:archives#Digikey Corporation|ici]]<br />
<br />
"PAS DE FRAIS POSTAUX sur toutes commandes avec une valeur de 65 Euro et plus.mais la DOUANE + frais"<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Digikey !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!!Remboursé/Archive (O/N)<br />
|-<br />
| Laurent(C) || Capa 470uF || 493-1493-ND || 24 || 0,229€||Laurent(C)|| DI_005 || || O || N || N<br />
|-<br />
| Laurent(C) || Carte NUCLEO-F303K8 || 497-15981-ND || 1|| 9,92€||Laurent(C)|| DI_005 || || O || N || N<br />
|-<br />
| Laurent(C) || Capa tantale 10uF || 478-8959-1-ND || 5|| 0.8€||Laurent(C)|| DI_005 || || O || N || N<br />
|-<br />
| Laurent(C) || PMIC 4V || MCP1702T-4002E/CBCT-ND|| 5|| 0.43€||Laurent(C)|| DI_005 || || O || N || N<br />
|-<br />
| Eric||[http://www.digikey.fr/product-search/fr?vendor=0&keywords=LT1677CS8%23PBF-ND LT1677 OPAMP S8 Package]|| LT1677CS8#PBF-ND || 4|| 3.95€||Laurent(C)|| DI_005 || O || O || N || N<br />
|-<br />
| Eric|| [http://www.digikey.com/product-detail/en/4664-6001/MPK64K-ND/138341 connecteur HE10 64 broches autodénudant mâle] || MPK64K-ND || 1|| 12.59€||Laurent(C)|| DI_005 || O || O || O || O<br />
|-<br />
| Eric|| [http://www.digikey.fr/product-detail/fr/DS2740U%2B/DS2740U%2B-ND/1197488 MAXIM coulombmetric counter DS2740U+ SMD]|| DS2740U+-ND || 1|| 3.90€||Laurent(C)|| DI_005 || O || O || O || O<br />
|-<br />
| Eric|| C190 case ||614-1102-ND||1||199,99USD||Laurent(C)|| DI_005 || O || N(export restriction!) || N || O<br />
|-<br />
| papy F1CHF || NB3N502 || NB3N502DGOS-ND ||4||2.99€||Laurent(C)|| DI_005 || N || O || O || O<br />
|-<br />
| Eric|| [http://www.digikey.com/product-detail/en/linear-technology/LT1763CS8-TRPBF/LT1763CS8-TRPBFCT-ND/4247570 LT1763CS8#TRPBF LT micropower low noise LDO ADJ regulator 500MA SO8]|| LT1763CS8#TRPBFCT-ND || 1|| 4.78USD||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| Eric|| [http://www.digikey.com/product-detail/en/linear-technology/LT1763CS8-3.3-TRPBF/LT1763CS8-3.3-TRPBFCT-ND/4247566 LT1763CS8-3.3#TRPBF LT micropower low noise LDO 3.3V regulator 500MA SO8]|| LT1763CS8-3.3#TRPBFCT-ND|| 2|| 4.78USD||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| Eric|| [http://www.digikey.fr/products/fr?keywords=BA5406 BA5406 Amplifier IC 2-Channel (Stereo) Class AB 12-SIP-M] ||BA5406-ND || 1|| 3.85 EUR||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| Eric|| [https://www.digikey.fr/products/fr?keywords=HR1732-ND HIROSE CONN PLUG 5POS W/PIN INSERT ref "RM12BPE-5PH(71)"] ||HR1732-ND || 1|| 11.19 EUR||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| Eric|| [https://www.digikey.fr/product-detail/fr/infineon-technologies/IRS2453DPBF/IRS2453DPBF-ND/1189713 INFINEON IC DRIVER FULL SELF OSC 14-DIP IRS2453DPBF] ||IRS2453DPBF-ND || 1|| 3.09 EUR||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| 3dsman|| US5881LUA Digital Switch Unipolar Switch Open Drain Hall Effect TO-92UA ||US5881LUA-AAA-000-BU-ND || 5|| 1.10 EUR||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| Debutant|| [https://www.digikey.fr/product-detail/fr/jst-sales-america-inc/SYF-001T-P0.6-LF-SN/455-2652-1-ND/2796952 JST Sales America Inc. SYF-001T-P0.6(LF)(SN) ] || 455-2652-1-ND || 100|| 0.05460 EUR|| Debutant || DI_006 || N || N || N || N<br />
|-<br />
| Lo2|| [https://www.digikey.fr/product-detail/en/molex-llc/0755860006/WM22014CT-ND/9095459 Molex Connecteur 50POS SMD] || WM22014CT-ND || 3|| 8.47 EUR|| Lo2 || DI_006 || N || N || N || N<br />
|-<br />
<br />
|}<br />
<br />
=== [http://www.doga.fr Doga] ===<br />
<br />
La prochaine commande aura pour référence interne : DO_004<br />
<br />
Prochaine date de commande : [inconnu]<br />
<br />
Commande passée en attente de livraison : [aucune]<br />
<br />
Commande livrée en cours de distribution : DO_003<br />
<br />
<br />
Minimum de commande : 50€ HT<br />
Franco : 100€ HT<br />
<br />
Merci de préciser le catalogue dans lequel se trouve l'article pour le retrouver plus aisément. <br />
<br />
Les principaux catalogues sont :<br />
* http://www.doga.fr/catalogue_pdf/ugv.pdf<br />
* http://www.doga.fr/catalogue_pdf/ugv-alliage-leger.pdf<br />
* [https://shop.precitool.de/bk/WKZ_2017-2018/#page_0.1 Precitool]<br />
<br />
Anciennes commandes Doga archivées [[Projets:Commande_groupee:archives#Doga|ici]]<br />
<br />
<br />
|-<br />
!Demandeur !! class="unsortable"| Description !!class="unsortable"| Ref Doga !! class="unsortable"| Catalogue !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!!Remboursé/Archive (O/N)<br />
<br />
<br />
|-<br />
| Eric||[http://shop.precitool.de/bk/HKL_2016-2017/#page_870 Ø 8mm Zylinderbürste mit Öse, Messingdraht gewellt marque : LESSMANN]|| 481772 || Precitool || 1 || 7 EURHT || <acheteur> || DO_002 || N || O || O || O<br />
|-<br />
| <s>Eric</s>||<s>[http://shop.precitool.de/bk/HKL_2015-2016/#page_1044 Kompakt-Bolzenscheider KNIPEX Mit Mehrkomponenten-Hülle, Öffnungsfeder, 20° abgewinkelt]</s>||<s> 559026</s> ||<s> Precitool </s>||<s> 1 </s>||<s> 40.45EURHT</s> ||<s> <acheteur> </s>||<s> DO_002 </s>||<s>N</s> ||<s>N</s>||<s> N </s>||<s> N</s><br />
|-<br />
| Eric||[http://shop.precitool.de/bk/HKL_2016-2017/#page_924 Strinlochschlüssel-Satz marque AMF]|| 506050|| Precitool || 1 || 31.05EURHT || <acheteur> || DO_002 || N || O || O || O<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1116 KNIPEX Montagezange Typ 4521 für Sprengringe auf Wellen (KNIPEX Ref 45 21 200)]||554175 /4521|| Precitool || 1 || 30,75EURHT || <acheteur> || DO_002 || N || O || O || O<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2016-2017/#page_1242 Schneidoel 500ml]||924055|| Precitool || 1 || 14,35EURHT || <acheteur> || DO_002 || N || O || O || O<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2016-2017/#page_1254 Luftweiche 3 Fach (4 x G3/8) Typ 0304]||925805/0304|| Precitool || 2 || 7.05EURHT || <acheteur> || DO_002 || N || O || O || O<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_35 Spiralbohrer HSS-Co Precitool D1897 INOX Dn 2,1mm]||100670/2,10|| Precitool || 5 || 1.91 EURHT || Lab || DO_003 || N || O || O (livré en 2.3mm, puis relivré gratuitement en 2,1mm) || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_815 Düsenlehre 0.45-1.5mm (0.05mm steigung)]||389850/20|| Precitool || 1 || 12.65 EURHT || Lab || DO_003 || N || O || O || N<br />
|-<br />
|Steve||[http://shop.precitool.de/bk/HKL_2017-2018/#page_987 Gelenk-Hakenschlüssel]||506350/22-35|| Precitool || 1 || 13.55 EURHT || Lab || DO_003 || N || N || N || N<br />
|-<br />
|Steve||[http://shop.precitool.de/bk/HKL_2017-2018/#page_987 Gelenk-Hakenschlüssel]||506350/35-60|| Precitool || 1 || 14.90 EURHT || Lab || DO_003 || N || N || N || N<br />
|-<br />
|Steve||[http://shop.precitool.de/bk/HKL_2017-2018/#page_987 Gelenk-Hakenschlüssel]||506350/60-90|| Precitool || 1 || 17.70 EURHT || Lab || DO_003 || N || N || N || N<br />
|-<br />
|Lab||[http://shop.precitool.de/bk/HKL_2017-2018/#page_985 Hakenschlüssel aus spezial Stahl Gehärtet und im Brunierton angelassen, pour Ø 95-100 mm, pour écrous DIN 1804 et DIN 981]||506200 95/100|| Precitool || 1 || 10,80 EURHT || Lab|| DO_003 || N || O || O (erreur de reference de commande) || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_985 Hakenschlüssel aus spezial Stahl Gehärtet und im Brunierton angelassen, pour Ø 95-100 mm, pour écrous DIN 1804 et DIN 981]||506200 95/100|| Precitool || 1 || 10,80 EURHT || Lab || DO_003 || N || O || O (erreur de reference de commande) || N<br />
<br />
|-<br />
|Lab||[http://shop.precitool.de/bk/HKL_2017-2018/#page_1153 Jeu de chasse-goupilles - Splintentreiber]|| 561110/6M || Precitool || 1 || 18.05 EURHT || Lab || DO_003 || N || N || N || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Linksausdreher Grosse 1 (für M3-M6)]||590950/1|| Precitool || 3 || 1,35 EURHT || Lab || DO_003 || N || O || O || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Linksausdreher Grosse 2 (für M6-M8)]||590950/2|| Precitool || 2 || 1,35 EURHT || Lab || DO_003 || N || O || O || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Linksausdreher Grosse 3 (für M8-M11)]||590950/3|| Precitool || 2 || 1,54 EURHT || Lab|| DO_003 || N || O || O || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Schaubenausdreher/Linksausdreher "Super Traktion" Grosse T1 (pour Ø 4-5 mm, perçage 2.1 mm)]||590970/T1|| Precitool || 3 || 4.47 EURHT || Lab || DO_003 || N || O || O || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Schaubenausdreher/Linksausdreher "Super Traktion" Grosse T2 (pour Ø 5-7 mm, perçage 3.2 mm )]||590970/T2|| Precitool || 3 || 4.58 EURHT || Lab || DO_003 || N || O || O || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Schaubenausdreher/Linksausdreher "Super Traktion" Grosse T3 (pour Ø 8-12 mm, perçage 4.5 mm )]||590970/T3|| Precitool || 3 || 5.70 EURHT || Lab || DO_003 || N || O || O || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_35 Spiralbohrer HSS-Co Precitool D1897 INOX Dn 8,6mm]||100670/8,60|| Precitool || 2 || 6.99 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_35 Spiralbohrer HSS-Co Precitool D1897 INOX Dn 8,7mm]||100670/8,70|| Precitool || 2 || 6.99 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_985 Gelenk-Hakenschlüssel verstellbar, mit Nase, gehärtet und im Brünierton angelassen; für AuBen Ø (Mutter) 20-35 mm]||506300/20-35|| Precitool || 1 || 11.10 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_985 Gelenk-Hakenschlüssel verstellbar, mit Nase, gehärtet und im Brünierton angelassen; für AuBen Ø (Mutter) 35-60 mm]||506300/35-60|| Precitool || 1 || 12.00 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_985 Gelenk-Hakenschlüssel verstellbar, mit Nase, gehärtet und im Brünierton angelassen; für AuBen Ø (Mutter) 60-90 mm]||506300/60-90|| Precitool || 1 || 15.55 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-class="sortbottom"<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Schaubenausdreher/Linksausdreher "Super Traktion" Grosse T4 (pour Ø 12-14 mm, perçage 6.5 mm )]||590970/T4|| Precitool || 3 || 6.59 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Schaubenausdreher/Linksausdreher "Super Traktion" Grosse T5 (pour Ø 16-20 mm, perçage 8.5 mm )]||590970/T5|| Precitool || 3 || 9.00 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|}<br />
<br />
=== [http://fr.farnell.com Farnell] ===<br />
<br />
Livraison gratuite au dessus de 30€ HT<br />
<br />
La prochaine commande aura pour référence interne : FA_017<br />
<br />
<br />
Prochaine date de commande : <à définir><br />
<br />
Commande passée en attente de livraison : <aucune><br />
<br />
Anciennes commandes Farnell archivées [[Projets:Commande_groupee:archives#Farnell|ici]]<br />
<br />
|-<br />
| Demandeur || class="unsortable"| Description || Ref Farnell || class="unsortable"| Quantité || class="unsortable"| Prix unitaire || Acheteur || Commande<br/>n° || Payé<br/>d'avance<br/>(O/N)|| Commandé<br/>(O/N)|| Distribué<br/>(O/N)|| Remboursé/<br/>Archive<br/>(O/N)<br />
|-<br />
|-<br />
|-<br />
| Claire Poisson || CD4011BM96 || 2114002 || 15 || 0,313 TTC || 3dsman ||FA_015 ||N ||O ||N ||N<br />
|-<br />
|-<br />
| 3dsman || Câble multiconducteur blindé || 2425036 || 10 || 0,85 TTC || 3dsman ||FA_015 ||N ||O ||N ||N<br />
|-<br />
|-<br />
| Steve (Pour lab/smoothie) || NXP LPC 1769 || 2072199 || 1 || 8,68 TTC || 3dsman ||FA_015 ||N ||O ||O ||N<br />
|-<br />
|-<br />
| Dom (Rude ULM) || Connecteur d'alimentation DC, Mâle, 2 A, 9.5 mm, Montage sur câble, 1.7 mm || 1737255 || 2 || 2.87 TTC || 3dsman ||FA_015 ||N ||O ||N ||N<br />
|-<br />
|-<br />
| Steve || MCP1702T-5002E/MB - Régulateur LDO 5V SOT89-3 || 1605559 || 3 || 0.593 || 3dsman ||FA_015 ||N ||O ||O ||N<br />
|-<br />
|-<br />
| Steve || RELAY, SPDT, 250VAC, 12A || 1714771 || 2 || 2.27E|| 3dsman ||FA_015 ||N ||O ||O ||N<br />
|-<br />
|-<br />
|-<br />
| Steve (Pour lab/smoothie) || LDO LM1117 3.3V || 2323580 || 5 || 0.907 || Ph. Gras||FA_016 ||N ||O ||O ||N<br />
|-<br />
| Eric ||[http://fr.farnell.com/amphenol-sine-tuchel/t-3424-501/fiche-libre-6-voies/dp/1123507 Connecteur 6 broches Amphénol avec serrage baillionnette ref T 3424 501] || 1123507 || 1 || 5,12 || Ph. Gras ||FA_016 ||N ||O ||O ||N<br />
|-<br />
| Eric ||[http://fr.farnell.com/nkk-switches/b18jp/switch-toggle-spdt-0-1a-28vac/dp/2374722?ost=2374722&ddkey=http%3Afr-FR%2FElement14_France%2Fsearch Commutateur 3 positions miniature SPDT, 0.1A, 28VAC On-Off-On NKK Switch ref B18JP ] || 2374722|| 2 || 3,98 EUR || Ph. Gras ||FA_016 ||N ||O ||O ||N<br />
|-<br />
| Ph. Gras||[http://fr.farnell.com/jst-japan-solderless-terminals/phr-2/boitier-2-voies-2mm/dp/3616186 Boîtier de connecteur, Série PH, Embase, 2 Voies, 2 mm, Contacts à sertir Série BPH et SPH ] || 3616186|| 100 || 0,0324 EUR || Ph. Gras||FA_016 ||N ||O ||O ||O<br />
|-<br />
| Ph. Gras||[http://fr.farnell.com/jst-japan-solderless-terminals/sph-002t-p0-5s/contact-0-05-0-22mm-cut-reel/dp/1671245?st=SPH-002T-P0.5S Contact, Série PH, Femelle, Sertissage, 24 AWG, Contacts plaqués étain, Connecteurs PH ] || 1671245|| 250|| 0,0208 EUR || Ph. Gras ||FA_016 ||N ||O ||O ||O<br />
|-<br />
| Ph. Gras||[http://fr.farnell.com/on-semiconductor/lm317ahvt/regulateur-ldo-ajustable-1-5a/dp/1564497?st=lm317LM317AHVT Régulateur de tension positive ajustable 1.2V à 37V, 1.5A en boîtier TO-220-3 ] || 1564497|| 10|| 0,727 EUR || Ph. Gras ||FA_016 ||N ||O ||O ||O<br />
|-<br />
|-<br />
|-<br />
| <demandeur> ||[http://wiki.electrolab.fr/Projets:Commande_groupee#Glossaire <article>] || <fa_cde_nb> || <quantité> || <prix> || <acheteur> ||FA_017 ||N ||N ||N ||N<br />
|-<br />
|-<br />
|}<br />
<br />
=== [http://www.gotronic.fr Gotronic] ===<br />
<br />
la prochaine commande a la référence interne GO_003<br />
<br />
<br />
Commande passée en attente de livraison :GO_002 le 31/05/2017 par Ellyan<br />
<br />
<br />
Anciennes commandes Gotronic archivées [[Projets:Commande_groupee:archives#Gotronic|ici]]<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref gotronic!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||<Acheteur>|| GO_XXX || N || N || N || N<br />
|-<br />
--><br />
| Damien H || Solénoïde 12 Vcc || LS1110BD || 1 || 7,00€||Ellyan|| GO_002 || N || O || N || N<br />
|}<br />
<br />
=== HighVoltageShop ===<br />
<br />
La prochaine commande a pour référence interne : HV_002<br />
<br />
5 euros de réduction sur la prochaine commande<br />
<br />
Prochaine date de commande : Aucune<br />
<br />
Commande passée en attente de livraison : Aucune<br />
* frais de port 20 euros<br />
* Livraison mardi 7 janvier 2014 au lab<br />
<br />
Commande livrée en cours de distribution : HV_001 (08/12/2013) <br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref ebay!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||David|| DI_XXX || N || N || N || N<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| Thomas || Cable HV 120 kV || 271261265516 || 1 || 8,69€||David|| HV_001 || O || O || O || N<br />
|-<br />
|David||-30kV HV-Generator Modul 12VDC||281162933827||1||34,99€||David||HV_001||O||O||O||N<br />
|-<br />
|David||5 Stk. Zeilentrafo - Flyback Transformer - Zeilentrafos||281024817841||1||24,99€||David||HV_001||O||O||O||N<br />
|-<br />
|David||+30kV HV-Generator Modul 12VDC||281162933829||1|| 34,99€||David||HV_001||O||O||O||N<br />
|-<br />
|CitronVert||-30kV HV-Generator Modul 12VDC||281162933827||2||34,99€||David||HV_001||N||O||O||N<br />
|-<br />
| Goldo || Regelbares Hochspannungsnetzteil 50kV Strombegrenzung || 280941865340 || 1 || 119,99€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || +30kV HV-Generator Modul 12VDC || 281162933829 || 1 || 34,99€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Zenos || +30kV HV-Generator Modul 12VDC || 281162933829 || 1 || 34,99€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || Cable HV 120 kV || 271261265516 || 1 || 8,69€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || Hochspannungskabel 40kV 1m || 271261265512 || 1 || 4,61€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || Hochspannungswiderstand 20kV 1 GigaOhm Messwiderstand || 280941865344 || 1 || 6,34€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || Hochspannungswiderstand 20kV 100 MegaOhm || 271106455991 || 1 || 6,34€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || Hochspannungswiderstand 20kV 1 MegaOhm || 281026497192 || 1 || 6,34€||David|| HV_001 || O || O || O || N<br />
|}<br />
<br />
=== [http://www.limpulsion.fr/web/index.php L'impulsion] ===<br />
<br />
[http://v1.limpulsion.fr/docpdf/2008_cat/bpoa_a.pdf Catalogue "accessoires de test"]<br />
<br />
La prochaine commande a la référence interne LI_002<br />
<br />
Prochaine date de commande : [à définir]<br />
<br />
<br />
Commande livrée en cours de distribution :[aucune]<br />
<br />
Anciennes commandes Limpulsion archivées [[Projets:Commande_groupee:archives|ici]]<br />
<br />
<br />
{|class="wikitable sortable" style="font-size:80%"<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref L'impulsion!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-<br />
|Lab||ADAPTATEUR D'AXE HM8001-2 HAMEG||760000500||1||2.30HT||Yannick||IL_001||N||N (plus livrable)||N||O<br />
|-<br />
|Lab||TRESSE A DESSOUDER NO CLEAN 2.8mm/3m||730.14||10||1.56HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||Entretoise plastique grise de montage en saillie marque "Electro-PJP" pour douilles 4mm type 3265, ref EPJP : 3282||<pas au catalogue: demander si livrable> ||16||? ||Yannick||IL_001||N||N (apparement pas dispo)||N||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou NOIR, ref3265-I-0 ||326500||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou MARRON, ref3265-I-1 ||326501||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou ROUGE, ref3265-I-2 ||326502||3||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou BLEU, ref3265-I-6 ||326506||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou VIOLET, ref3265-I-7 ||326507||3||1.48HT||Yannick||IL_001||O||O||N||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou GRIS, ref3265-I-8 ||326508||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou BLANC, ref3265-I-9 ||326509||3||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou JAUNE/VERT, ref 3265-I-J/V||326510||1||1.74HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||[http://v1.limpulsion.fr/docpdf/2008_cat/bpoe_a.pdf#page=9 Passe fil classique intérieur :12mm, Perçage: 18mm, Epaisseur :10mm (lot de 10pcs)]||252.162||1||1,95EURHT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||Entretoise plastique grise de montage en saillie marque "Electro-PJP" pour douilles 4mm type 3265, ref EPJP : 3282||<pas au catalogue: demander si livrable> ||16||? ||Yannick||IL_001||N||N(apparement pas dispo)||N||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou NOIR, ref3265-I-0 ||326500||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou MARRON, ref3265-I-1 ||326501||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou ROUGE, ref3265-I-2 ||326502||3||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou BLEU, ref3265-I-6 ||326506||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou VIOLET, ref3265-I-7 ||326507||3||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou GRIS, ref3265-I-8 ||326508||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou BLANC, ref3265-I-9 ||32650||3||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou JAUNE/VERT, ref 3265-I-J/V||326510||2||1.74HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||CLE EXTERNE POUR DOUILLE DE SECURITE||3299||1||13.51HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||TRANSFO FERRITE POUR THT HM1005 HAMEG (plus livrable) ||THTHM1005||1||16.77HT||Yannick||IL_001||N||N (plus livable)||N||O<br />
|-<br />
|Eric||Lot de 100 douilles pour C.I diam4 Long 10mm à souder Electro-PJP ref 20054||20054||1||7,95 EUR HT||Yannick||LI_001||N||O||O||O<br />
|-<br />
<br />
|Eric||CI SN75492 (7 segm DRIVER) TEXAS DIP14||75492||13||1.29HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||CI 74LS164 TEXAS DIL||74LS164||2||0.76HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||IPROBER520||IPROBER520||1||594HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|}<br />
<br />
=== [https://shop.mchobby.be/ MCHobby] ===<br />
<br />
La prochaine commande a pour référence interne : MCH_001<br />
<br />
Prochaine date de commande : <Mardi 20 ou mercredi 21 au plus tard ><br />
<br />
Livraison gratuite en Mondial Relay à partir de 75 euros.<br />
<br />
Commande passée en attente de livraison :[aucune]<br />
<br />
<br />
Anciennes commandes MCHobby archivées [[Projets:Commande_groupee:archives#MCHobby|ici]]<br />
<br />
Site WEB de MCHobby : https://shop.mchobby.be/<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Mon Droguiste !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||<Acheteur>|| MC_XXX || N || N || N || N<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| LienRag|| Divers ||Divers || ++|| 75€||<acheteur>|| MHC_001 || N|| N || N || N<br />
|}<br />
<br />
<br />
=== [http://217.34.103.131/homepage/homepage.html Mini-Circuits] ===<br />
<br />
La prochaine commande a pour référence interne : MC_001<br />
<br />
Prochaine date de commande : <non défini><br />
<br />
<br />
<br />
Anciennes commandes Mini-Circuits archivées [[Projets:Commande_groupee:archives#Mini-Circuits|ici]]<br />
<br />
Site WEB de minicircuits : http://www.minicircuits.com/homepage/homepage.html<br />
<br />
{|class="wikitable sortable" style="font-size:85%"<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Mini-circuits !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| F1CHF || ERA-3 || AMPL || 20 || 1.43€||F1CHF|| MC_001 || N || N || N || N<br />
|-<br />
|-<br />
| F1CHF || ADCH-80+ || coil || 20 || 2.88€||F1CHF|| MC_001 || N || N || N || N<br />
|-<br />
|}<br />
<br />
=== [http://www.mon-droguiste.com/index.cfm Mon Droguiste] ===<br />
<br />
La prochaine commande a pour référence interne : MD_001<br />
<br />
<br />
<br />
<br />
Anciennes commandes Mon Droguiste archivées [[Projets:Commande_groupee:archives#Mon-droguiste|ici]]<br />
<br />
Site WEB de Mon Droguiste : http://www.mon-droguiste.com/index.cfm<br />
<br />
|-<br />
|-l<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| Eric|| Ethylene Diamino Tetraacetic Acide 500g ||Ethylene Diamino Tetraacetic Acide Sac 500g || 1|| 16.95€||<acheteur>|| MD_001 || N|| N || N || N<br />
! !! !! !! !! !! !! !! !! !! !!<br />
|}<br />
<br />
=== [http://www.mouser.fr Mouser Electronics]===<br />
<br />
La prochaine commande aura pour référence interne MO_014<br />
<br />
Prochaine date de commande : ?<br />
<br />
<br />
Commande livrée en cours de distribution : MO_013 le 31/05/2017 par Ellyan<br />
<br />
Anciennes commandes Mouser Electronics archivées [[Projets:Commande_groupee:archives#Mouser Electronics|ici]]<br />
<br />
Livraison gratuite (FedEx ou UPS) au delà de 50€ de commande<br />
<br />
<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Mouser !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
<!-- Pour ajouter une ligne, copier les 2 lignes suivantes (celles qui commencent par | ) à la suite du tableau et remplacer le contenu des colonnes par ce qui semblera adéquat<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||<Acheteur>|| DI_XXX || N || N || N || N<br />
|-<br />
--><br />
<br />
|-<br />
|Frederic.D.||[http://www.mouser.fr/ProductDetail/TE-Connectivity/1-826632-0/ Headers & Wire Housings 2X10P DUAL ROW]||571-1-826632-0 ||3 ||1.95 |||| MO_013||O ||O ||O ||N<br />
|-<br />
|Frederic.D.||[http://www.mouser.fr/ProductDetail/Bourns/3306P-1-103/ Trimmer Resistors - Through Hole 10K 25% 6mm Single Turn]||652-3306P-1-103 ||3 ||0.407 |||| MO_013||O ||O ||O ||N<br />
|-<br />
|Frederic.D.||[http://www.mouser.fr/ProductDetail/Schurter/13019302/?qs=%2fha2pyFadugAVCtehZ6ro0we%252bFlHwInvMJ3iEORyekx9pnGrLimsvA%3d%3d Pushbutton Switches SHORT TRAVEL SWITCH 6X6, 5.0MM]||693-1301.9302 ||9 ||0.251 |||| MO_013||O ||O ||O ||N<br />
|-<br />
|Frederic.D.||[http://www.mouser.fr/ProductDetail/Bourns/MF-USMF075-2/ Resettable Fuses - PPTC 0.75A 6V 0.18ohm Hold .75A Trip 1.5A]||652-MF-USMF075-2 ||3 ||0.275 |||| MO_013 ||O ||O||O ||N<br />
|-<br />
|Frederic.D.||[http://www.mouser.fr/ProductDetail/STMicroelectronics/SMA6J50A-TR/?qs=%2fha2pyFadujqXhcCRI4%2fO5BEn9p7pkr6EX0dAQtUlws3JpN%2fE2p9DQ%3d%3d TVS Diodes - Transient Voltage Suppressors HJ Temp Transil]||511-SMA6J5.0A-TR ||3 ||0.38 |||| MO_013 ||O||O||O ||N<br />
|-<br />
|-<br />
|Sylvain V.||[http://www.mouser.fr/ProductDetail/Cirrus-Logic/CS4398-CZZ/?qs=sGAEpiMZZMv%252bLKsN4bqzyhXScoHWAp%252boAQFEBwyfAGo%3d DAC Cirrus Logic]||777-CS4398-CZZ ||1 || 10.46 || Sylvain V. || MO_013 ||O||O||O ||N<br />
|-<br />
|Eric||[https://eu.mouser.com/ProductDetail/Amphenol-Tuchel/T-3427-100?qs=%2fha2pyFaduhPv3s%2fjYa9sAYm3fflPgRKEDSdRTPyUvP7YbNcd%2fVs5g%3d%3d Circular DIN Connectors FEMALE RECEPTACLE 6 WAY, Amphenol series C091B]|| 523-T3427-100 ||1 || 10.29|| <<acheteur>> || MO_014 ||N||N||N ||N<br />
|-<br />
|Eric||[https://www.mouser.fr/ProductDetail/EPCOS-TDK/B32926A4685M?qs=sGAEpiMZZMv1cc3ydrPrF3kXVSi%252b9fyL4PImBI83UxcgTMvwb1977w== Condensateurs à film 6.8uF 20% 350Vac LS 37.5MM Fabricant : EPCOS /TDK ref : B32926A4685M ]|| 871-B32926A4685M ||1 || 10.67|| <<acheteur>> || MO_014 ||N||N||N ||N<br />
|-<br />
|Eric||[https://www.mouser.fr/ProductDetail/Texas-Instruments/OPA2227U-2K5?qs=sGAEpiMZZMtCHixnSjNA6Mrdwin7F8A2DB4TJmgUI0w%3d OPA2227U SOIC8 dual opamp low noise Texas ]|| 595-OPA2227U/2K5 ||2 || 8.07|| <<acheteur>> || MO_014 ||N||N||N ||N<br />
|-<br />
|Eric||[https://eu.mouser.com/ProductDetail/Molex/53253-0570?qs=sGAEpiMZZMvlX3nhDDO4AD1CBCqS4WJ3BaSa47NubxE%3d Shrouded header 5 pins 2mm male through hole board connnector vertical mounting Molex ref. 53253-0570 Cross ref to JST PH "B5B-PH-K-S"]|| 538-53253-0570||20 || 0,164 €|| <<acheteur>> || MO_014 ||N||N||N ||N<br />
|-<br />
|Eric||[https://eu.mouser.com/ProductDetail/Central-Semiconductor/TIP42B?qs=sGAEpiMZZMshyDBzk1%2fWi0MKeUdJDRlz1TXFEdLineJjytqjBdqtHg%3d%3d Bipolar Transistor PNP 10A 80V TIP42B]|| 610-TIP42B ||2 || 0,969 €|| <<acheteur>> || MO_014 ||N||N||N ||N<br />
|-<br />
| Eric|| [https://www.mouser.fr/ProductDetail/Hirose-Connector/RM12BPE-5PH71?qs=sGAEpiMZZMvG94qpybaIZaiKjo18NgShhh8FQGCnH4c%3d HIROSE CONN PLUG Cbl Mount 5 Terminals ref "RM12BPE-5PH(71)"] ||798-RM12BPE-5PH71 || 1|| 11.47 EUR||<acheteur>|| MO_014 || N || N || N || N<br />
|-<br />
| Eric|| [https://www.mouser.fr/ProductDetail/Mueller-Electr/BU-75K?qs=sGAEpiMZZMs4AFwHyzhTm%2f3wHG8LpAJAx37I4fl4y%2fU%3d Kelvin clip 10A Mueller Electric ref. BU-75K] ||548-BU-75K|| 4|| 10.20 EUR||<acheteur>|| MO_014 || N || N || N || N<br />
<br />
|-<br />
|}<br />
<br />
<br />
=== [http://www.motedis.fr/shop/ Motedis France] ===<br />
<br />
<br />
La prochaine commande aura pour référence interne : MS_001<br />
<br />
<br />
<br />
<br />
Anciennes commandes Motedis France archivées [[Projets:Commande_groupee:archives#Motedis France|ici]]<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Motedis!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-<br />
|Eric||Plaquette aluminium 15mm d'épaisseur Largeur: 100mm ||<ref motedis>||L:1000mm|| 24.15EURHT || <acheteur> || MS_001 || N|| N || N || N<br />
|-<br />
|<demandeur>||<description>||<ref motedis>|| <quantité> || <prix>|| <acheteur> || MS_001 || N|| N || N || N<br />
|-<br />
|}<br />
<br />
<br />
===[http://www.nouvelleplastique.it/f/setf.html Nouvelle Plastique]===<br />
La prochaine commande a pour référence interne : NP_001<br />
<br />
Prochaine date de commande : Q3/2014<br />
<br />
<br />
Commande livrée en cours de distribution : [aucune] <br />
<br />
Anciennes commandes Nouvelle Plastique archivées [[Projets:Commande_groupee:archives#Nouvelle Plastique|ici]]<br />
<br />
La société "[http://www.nouvelleplastique.it/f/setf.html Nouvelle Plastique]" fabrique des systèmes de rangements portables et modulaires en plastique.<br />
Les produits sont souvent bien pensés (parfois mieux que RAACO ou Stanley) et de bonne solidité.<br />
<br />
Malheureusement, ses produits ne sont que rarement distribués par les circuits classiques et pour le moment aucun revendeur de détail en France n'a été identifié. De même, on ne connait pas les prix des produits.<br />
La démarche envisagée est de collecter via le tableau ci-dessous une liste de souhaits afin de pouvoir demander un devis global directement au fabricant d'ici quelques mois (probablement en Q3/2014). En fonction de ses proposition de prix, chacun pourra finalement accepter ou refuser que ses souhaits soient inclus dans la commande définitive. Le coût du port sera partagé au prorata du prix des marchandises achetées (plus il y a de demaneurs, plus le coût individuel du port sera faible).<br />
Pour chaque article, il y a indication d'une UDV (Unité De Vente), c'est à dire de lot indivisible.<br />
Au terme des sélections de vos besoins, il faudra que le nombre de pièces commandées pour chaque article soit un multiple de son UDV.<br />
Le tableau ci-dessous dispose d'une structure adaptée à la gestion des souhaits des demandeurs, du nombre d'article et des UDV.<br />
Tous les demandeurs intéressés par un même article s'inscrivent dans une seule ligne (ce qui conduit au fait qu'il y ait une ligne par référence d'article).<br />
Le champ "PUHT" sera complété une fois le devis obtenu.<br />
<br />
====Légende du tableau ====<br />
<br />
UDV = correspond au nombre d'articles par UDV. = nombre d'articles dans un lot indivisible, cette information est indiquée par le fabricant dans son catalogue. <br />
Reste à affecter = mod(Nombre d'UDV; Nombre d'articles) <br />
<br />
<br />
Si vous éditez une ligne existante pour vous inclure comme demandeur de l'article considéré, modifiez les champs suivants :<br />
*''UDV' *''Nombre d'UDV'' (valeur cumulée d'UDV entre tous les demandeurs) <br />
*''Quantités (nombre d'articles)'' (valeur cumulées en nombre d'articles individuels entre tous les demandeurs) <br />
*''Reste à affecter'' (valeur calculée globalement pour tout les demandeurs) <br />
*''Liste de demandeurs avec (unités)'' Unités = nombre d'articles demandéz<br />
<br />
<br />
{|class="wikitable sortable" style="font-size:99%"<br />
|-<br />
! Ref article!! class="unsortable"| Désignation!! UDV (= nombre d'articles dans un lot indivisible) !! class="unsortable"| Nombre d'UDV!! class="unsortable"| Quantité souhaitée(nombre d'articles) !! Reste à affecter!! PUHT !! Liste de demandeurs avec (unités) !! N° de commande <br />
|-l<br />
|00366|| Tyger maxi double|| 6 || 1 ||6 ||0|| <PU> || Eric (6) || NP_001 <br />
|-<br />
|00361|| Tyger maxi|| 12 || 1 ||6 ||6|| <PU> || Eric (6) || NP_001 <br />
|-<br />
<br />
|}<br />
<br />
=== [https://www.olimex.com/ Olimex]===<br />
<br />
La prochaine commande a pour référence interne : OL_001<br />
<br />
<br />
<br />
<br />
Anciennes commandes Olimex archivées [[Projets:Commande_groupee:archives#Olimex|ici]]<br />
<br />
<br />
Achat par l'intermédiaire de leur site internet: https://www.olimex.com/<br />
<br />
Produits identifiés comme potentiellement intéressants:<br />
* https://www.olimex.com/Products/ARM/TI/TMS570-CAN/ un pti devkit pour un micro bien patator, prévu au départ pour des applications safety mais qui a des périphériques & capacités pas dégueulasses...<br />
* https://www.olimex.com/Products/Modules/Adapters/ pour utiliser leurs modules d'extension avec un launchpad ou un rpi<br />
* https://www.olimex.com/Products/Modules/LCD/ (divers modules LCD)<br />
* https://www.olimex.com/Products/Modules/LCD/MOD-LCD4.3%27%27/ module LCD "complet" avec pti micro sympatoche intégré<br />
* https://www.olimex.com/Products/OLinuXino/ gamme de nanocomputers intégrés & pas chers (type rpi mais en open)<br />
* https://www.olimex.com/Products/Components/Misc/TC-K-TYPE/ thermocouple K <br />
etc...<br />
<br />
<br />
Commande prévue courant mars 2013 par Clem.<br />
Attention, prix HT a priori, et prévoir également frais de port "importants" (environ 20€) à répartir entre les participants à la CG.<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Olimex!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||<Acheteur>|| OL_XXX || N || N || N || N<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| XXX|| XXX || - || - || XXX€||XXX|| OL_001 || N || N || N || N<br />
|-<br />
|-<br />
|}<br />
<br />
=== [http://www.otelo.fr/fr/index.html Otelo] ===<br />
<br />
Outillage bois-métal <br />
<br />
Ports gratuits au delà de 230 € H.T. ou code promo<br />
<br />
La prochaine commande a pour référence interne : OT_004<br />
<br />
Prochaine date de commande : < non définie ><br />
<br />
Commande passée en attente de livraison [AUCUNE]<br />
<br />
<br />
Anciennes commandes Otelo archivées [[Projets:Commande_groupee:archives#Otelo|ici]]<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Otelo!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
|-<br />
--><br />
|-<br />
|lab||TARAUD à main diamètre 14X200 Acier/alu||14104142N1||1|| 14,51€ HT|| <Patrick> || OT_002|| N || O|| O || O<br />
|-<br />
|lab||100 rondelles plates diamètre 8X16 ||36211008||5|| 3,23€ HT|| <Patrick> || OT_002|| N || O|| O || O<br />
|-<br />
|Patrick||Disque à poncer bombé axe 22mm D125 grain 80||54426280||2|| 3,42€ HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|Patrick||boites de rangement 18 sep 375X310X60||PY 69720030||3|| 9,55€ HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|Patrick||jeu d'outils ébavurage||PY 58500009||1|| 7,35€ HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|Patrick||BOMBE GALVA FLASH||PY 73006003||1|| 8,40€ HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|Eric||Tablier de soudeur 90 x 60 cm||PW 75 150 001||1|| 10,90€HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|MAZ24||meule blanche touret||5473014F||1|| 11,40€HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|MAZ24||Meule verte de touret||54571150||1|| 42,40€HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|MAZ24||Bagues adaptation||54703320||4|| 1,09€HT|| <Patrick> || OT_002|| O || O|| O|| O<br />
|-<br />
|Patrick||Mandrin à clef 3-16mm CM2/B18||30140413||1|| 27,25€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Mandrin à clef 1-13mm CM2/B16||30140409||1|| 23,20€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Arbre pour mandrin CM2/B16||30199116||1|| 6,80€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Arbre pour mandrin CM2/B18||30199118||1|| 7,00€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Ecouvillon manche bois 15mm||57169015||1|| 7,70€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Ecouvillon manche bois 25mm||57169025||1|| 8,15€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Ecouvillon à fil 6mm||57169006||1|| 5,24€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Ecouvillon à fil 25mm||57151025||1|| 6,38€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Sylvia||Support articulé ||43130110||1|| 23,77€ HT|| <Patrick> || OT_003|| N || O|| O|| O<br />
|-<br />
|}<br />
<br />
===[http://www.outiz.fr/ Outiz]===<br />
<br />
<br />
Comptoir Guilleraies (Nanterre)<br />
<br />
Du lundi au vendredi 7h - 17h Samedi 8h - 12h<br />
<br />
Téléphone : 01 40 35 77 77<br />
<br />
La prochaine commande aura pour référence interne : OU_001 <br />
<br />
Prochaine date de commande : <non définie><br />
<br />
<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Outiz!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!!Remboursé/Archive (O/N)<br />
|-<br />
| Eric ||[http://www.outiz.fr/sferaco-vanne-a-sphere-laiton-pn25-batiment-ff-3-4-poignee-acier-plate-rouge-580005/p/3806984/ Vanne à poignée plate rouge Genre : FF Ø : 3/4" ] ||3806984 || 1|| 4,54 €HT||<acheteur>|| OU_001 || N || N || N || N<br />
|-<br />
|}<br />
<br />
=== [http://fr.rs-online.com/web/ Radiospares (RS Composants)] ===<br />
<br />
La prochaine commande aura pour référénce interne : RS_012<br />
<br />
<br />
<br />
Commande livrée en cours de distribution : <aucune><br />
<br />
Anciennes commandes Radiospares archivées [[Projets:Commande_groupee:archives#Radiospares|ici]]<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref RS!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||Acheteur|| DI_XXX || N || N || N || N<br />
--><br />
|-<br />
| papy F1CHF||régulateur || 686-9007 || 10 || 0,27€|| <>|| RS_012 || N || N || N || N<br />
|FredericD||[http://fr.rs-online.com/web/p/ldr/9146710/ Silonex, NSL-19M51, CdS, Traversant, TO-18, 20 kΩ → 100 kΩ]||914-6710|| 10 || 1.074€HT ||<>||RS_012||N||N||N||N <br />
|-<br />
|FredericD||[http://fr.rs-online.com/web/p/relais-reed/2562055/ Relais Reed 1NO 12V dc 1 A]||256-2055|| 1 || 5.17€HT ||<>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[http://fr.rs-online.com/web/p/refrigerants/1115853/ Réfrigérant aérosol Cramolin Aérosol 400 ml, -50°C]||111-5853|| 2 || 11.12€HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/accessoires-pour-capteur-de-temperature/0286771/ Presse-étoupe pour Thermocouple]||286-771|| 2 || 9,68€HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|<s>Eric</s>||<s>[https://fr.rs-online.com/web/p/pinces-kelvin/7148263/ Pince Kelvin BU-75K, 10A, noir, fabricant : Mueller]</s>||<s>714-8263</s>||<s> 2</s> ||<s> 19,61€HT</s> ||<s><acheteur></s>||<s>RS_012</s>||<s>N</s>||<s>N</s>||<s>N</s>||<s>N</s> <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/condensateurs-aluminium/8396258 Condensateur électrolytique aluminium radial 10µF, -20%, 50V dc, Traversant, +105°C, WURTH série WCAP-AT1H, 5 (Dia.) x 11mm 5000h 97mA Référence fabricant : 860240672002]||839-6258|| 25 (1 sachet) || 3,90 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/condensateurs-aluminium/8399011 Condensateur électrolytique aluminium radial 47µF, -20%, 63V dc, Traversant, +105°C, WURTH série WCAP-ATUL, 8 (Dia.) x 11.5mm 7000h 360mA ESR: 0.66 Ohms Référence fabricant : 860040774002]||839-9011|| 20 (2 paquets) || 3,12 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/condensateurs-aluminium/8399033 Condensateur électrolytique aluminium 120µF, -20%, 63V dc, Traversant, +105°C, série WCAP-ATUL, 10 (Dia.) x 16mm 7000h 760mA ESR: 0.3 Ohms Référence fabricant : 860040775008]||839-9033|| 20 (4 paquets) || 3,43 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/connecteur-xlr/7259543/ Connecteur XLR femelle plastique pour chassis soudage pour CI 3 broches coudé + blindage avec louet métal, NEUTRIK NC3FAH2]||725-9543|| 2 || 1,97 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/connecteur-xlr/7259549 Connecteur XLR mâle plastique pour chassis soudage pour CI 3 broches coudé + blindage, NEUTRIK NC3MAH ]||725-9549|| 2 || 1,43 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/fusibles-cms-rearmables/5177054/ Fusible CMS réarmable, Littelfuse, 2.2A - 1.1A Référence fabricant : SMD100F-2 MK : 100F]|| 517-7054|| 10 || 0,497 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|<s>Eric</s>||<s>[https://fr.rs-online.com/web/p/roulettes-sur-platine/0819567/ Roulette Pivotante Acier 50mm, Bas profil, 270kg Fabricant : Revvo]</s>|| <s>819-567</s> || <s>4</s>|| <s>34.91 €HT</s> ||<s><acheteur></s>||<s>RS_012</s>||<s>N</s>||<s>N</s>||<s>N</s>||<s>N</s> <br />
|-<br />
|3ds||[https://fr.rs-online.com/web/p/potentiometres/0387896/ Potentiomètre carbone série 23 montage panneau 4K7 B avec interrupteur DPST, axe 6,35mm TE Connectivity ref 23ESB472MMF50AF]||387-896|| 1 || 4,14€HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Louis||[https://fr.rs-online.com/web/p/passe-fils/1366806/ Passe-fils,SES en PVC, Diamètre maximum de câble 3mm Noir ref 01070005010 ]||136-6806|| 1 sachet de 100|| 5,38€HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|}<br />
<br />
<br />
<br />
=== [http://www.stquentin-radio.com/ Saint Quentin radio]===<br />
<br />
La prochaine commande a pour référence interne SQ_002<br />
<br />
<br />
<br />
<br />
Anciennes commandes Saint Quentin Radio archivées [[Projets:Commande_groupee: Saint Quentin radio|ici]]<br />
<br />
Paiement cash par avance à l'acheteur : payez le montant exact, car il n'y a pas de frais annexes<br />
<br />
Frais de port : 0€ (sauf objets lourds) Gare du Nord<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref St Quentin!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
|-<br />
--><br />
|Lab||DOUILLE DE SECURITE 4mm ECROU BLANC, ref3265-I-9 ||326509 ||3||1.80€||<Patrick>||SQ_001||N||O||O||O<br />
|-<br />
|Lab||Fiche DIN 5BR MALE PLASTIQUE 360°||I076||2||1.00€||<acheteur>||SQ_002||N||N||N||N<br />
|-<br />
|Lab||Fiche DIN 5BR CHASSIS METAL 360°||I088||1||1.20€||<acheteur>||SQ_002||N||N||N||N<br />
|}<br />
<br />
=== [http://www.selectronic.fr Selectronic] ===<br />
<br />
La prochaine commande a pour référence interne : SE_010 <br />
<br />
<br />
<br />
<br />
Anciennes commandes Sélectronic archivées [[Projets:Commande_groupee:archives#Selectronic|ici]]<br />
<br />
Frais de port : 0€ (sauf objets lourds)<br />
<br />
Certains produits sont pas en stock à Paris et requièrent d'être livrés de Lille d'où un délai de quelques jours. Le mieux est d'aller au mag à Nation le mardi pour passer la commande et dans ce cas c'est en principe dispo jeudi sur place.<br />
<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description || Ref Sélectronic!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-<br />
|Eric||Résistance CTN 10kOhms 10% format goutte traversant||5277|| 1 || 0.95€TTC|| Eric|| SE_008 || O || O || O || O<br />
|- <br />
|lab||Résistance CTN 10kOhms 10% format goutte traversant||5277|| 1 || 0.95€TTC|| Zenos|| SE_009 || N || O || O || N<br />
|-<br />
|Zenos||triac BT139-600||4024|| 3 || 1,90€TTC|| Zenos|| SE_009 || O || O || O || O<br />
|-<br />
|Lab||TIC106D Thyristor||4018|||1||1,52||<acheteur>|| SE_009 || N || O || N (pas dispo) || N <br />
|-<br />
|Eric||IR IRF9540 MOS canal P -100V -19A||08015|||1||2,50EUR||Zenos|| SE_009 || O || O || O || O<br />
|- <br />
|Eric||Mosfet N IRF640N TO220 200V 0.150Ω - 18A||HD75-940|||2||1,94||<acheteur>|| SE_010 || N || N || N || N<br />
|-<br />
|Marc f6itu||pointes de scope||2447|||4||1,02||<acheteur>|| SE_010 || N || N || N || N<br />
|-<br />
|Lab (Eric)||[http://www.selectronic.fr/joints-adhesif-pour-enceintes.html bande mousse autocollante de largeur 5mm, hauteur 2mm]||2300|||2||5.50||<acheteur>|| SE_010 || N || N || N || N<br />
|-<br />
|}<br />
<br />
=== [http://www.sparkfun.com/ SparkFun Electronics]===<br />
<br />
La prochaine commande a pour référence interne SF_002<br />
<br />
Prochaine date de commande : N/A<br />
<br />
<br />
Commande livrée en cours de distribution : SF_001<br />
<br />
<br />
TVA, frais de port et droits de douane + frais pour dossier de dédouanement : selon taille totale de la commande finale, seront ventilés au pro-rata du montant commandé par chacun.<br />
<br />
Anciennes commandes SparkFun Electronics archivées [[Projets:Commande_groupee:archives#SparkFun Electronics|ici]]<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref SparkFun!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
|-<br />
--><br />
|Damien H||Spark Gap Igniter - 4.8V||COM-11218||3||$14,95||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Pilou||MIDI Shield||DEV-09595||1||$19,90||<Damien H>||SF_001||N||O||O||O<br />
|-<br />
|Pilou||OpenServo||ROB-09014||2||$14,95||<Damien H>||SF_001||N||O||O||O<br />
|-<br />
|Pilou||Breakout Board for PCF8575 I2C Expander||BOB-08130||1||$11,95||<Damien H>||SF_001||N||O||O||O<br />
|-<br />
|MAZ24||wire stripper||TOL-08696||1||$4,95||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|MAZ24||flush cutter||TOL-11952||1||$6,95||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Eric||Optical Dust Sensor - GP2Y1010AU0F||COM-09689||1||$11,95||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Eric||Mating Connector Housing for Dust Sensor (JST ref#: ZHR-6)||PRT-09690||2||$0,35||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Eric||Crimp Pins for Dust Sensor Connector (JST ref#: SZH-002T-P0.5)||PRT-09728||16||$0,09||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Eric||Copper Tape - 2" (50ft)||PRT-11081||1||$14,95||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Olga||RaspiRobot Board||KIT-11561||1||$29,95||<Damien H>||SF_001||N||O||N||O<br />
|-<br />
|Dom||Copper Tape - 2" (50ft)||PRT-11081||1||$14,95||||SF_002||N||N||N||N<br />
|-<br />
|Jean-Marc (PdM) || Polymer Lithium Ion Battery - 400mAh || PRT-10718 || 1 || $6.95 || || SF_002 || N || N || N ||N<br />
|-<br />
|Jean-Marc (PdM) || SparkFun USB LiPoly Charger - Single Cell || PRT-12711 || 1 || $14.95 || || SF_002 || N || N || N ||N<br />
|-<br />
|Jean-Marc (PdM) || Precision Disc Wheel - 5" (Yellow, 2 Pack) || ROB-12469 || 1 || $6.29 || || SF_002 || N || N || N ||N<br />
|-<br />
|Jean-Marc (PdM) || Set Screw Hub - 3mm Bore || ROB-12512 || 2 || $4.99 || || SF_002 || N || N || N ||N<br />
|-<br />
|Jean-Marc (PdM) || ProtoBoard - Square 2" || PRT-08811 || 1 || $2.95 || || SF_002 || N || N || N ||N<br />
|-<br />
|Jean-Marc (PdM) || Micro Gearmotor - 90 RPM (6-12V) || ROB-12285 || 2 || $12.95 || || SF_002 || N || N || N ||N<br />
|- <br />
|Jean-Marc (PdM) || SparkFun Solderable Breadboard - Mini || PRT-12702 || 1 || $2.95 || || SF_002 || N || N || N ||N<br />
|- <br />
|}<br />
<br />
=== Subtel.fr ===<br />
<br />
Pas de frais de port, prix TVA comprise<br />
<br />
<br />
<br />
<br />
Anciennes commandes Subtel.fr archivées [[Projets:Commande_groupee:archives|ici]]<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Subtel!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Archive (O/N)<br />
|-l<br />
|-<br />
|}<br />
<br />
=== raspberry-pi-zero ===<br />
Une opportunité dégotée par Francis: une version du raspberry-pi, un peu spartiate, pour 5 euros!<br />
https://www.raspberrypi.org/blog/raspberry-pi-zero/<br />
<br />
On peut également acheter le kit: http://swag.raspberrypi.org/collections/pi-kits/products/pi-zero-cables<br />
C'est le cordon midi-hdmi/hdmi, PLUSSE la barrette gpio.<br />
<br />
Cette entrée est mise en place alors que tout n'est pas défini pour cet achat: ni le fournisseur (fournisseur initial en rupture de stock), ni le prix.<br />
Mais ce sera le support pour rassembler les commandes. Je tiendrai ce paragraphe à jour selon les infos.<br />
<br />
Le kit comprend l'adaptateur micro-hdmi/hdmi (1 cordon + 1 petit adaptateur?), et la barette 2x20, à souder, pour les gpio. Le raspberry n'est pas dans le kit!<br />
<br />
Le prix: 5 euros le kit, idem le raspberry, et quelques pourcent pour les frais de transport. <br />
<br />
(ce soir: site http://swag.raspberrypi.org/ down; ??)<br />
<br />
<br />
On peut aussi attendre 3 semaines le temps que cela soit livré directement chez vous et avoir<br />
<br />
- l'adaptateur micro hdmi mâle- hdmi femelle : http://www.banggood.com/Gold-Plated-Micro-HDMI-Type-D-Male-To-HDMI-Female-Adapter-p-974265.html<br />
<br />
- un adaptateur micro-hdmi vers VGA femelle sans le son : http://www.banggood.com/1080P-HDMI-Male-To-VGA-Female-Adapter-Video-Converter-Cable-p-937626.html<br />
<br />
- un adaptateur micro-hdmi vers VGA femelle avec le son : http://www.banggood.com/Sin-Hon-SH-MH2V02-Micro-HDMI-to-VGA-Cable-Adapter-with-Audio-p-907524.html<br />
<br />
- un adaptateur micro usb coudé(pratique pour ranger sur le côté : http://www.banggood.com/Micro-USB-Host-OTG-Cable-For-Samsung-HTC-p-79909.html<br />
<br />
- pour se faire une prise alim micro usb, on déboîte le capot et on soude : http://www.banggood.com/USB-2_0-Micro-B-Male-to-Mini-B-Female-5-Pins-Adapter-p-956044.html<br />
<br />
- toutes sortes d'alim : http://www.banggood.com/search/usb-2a-charger.html<br />
<br />
- de quoi s'amuser avec les GPIO : http://www.banggood.com/search/gpio-raspberry/1091-0-0-0-0-0-0-price-0-0_p-1.html<br />
<br />
Et si vous avez le temps de chercher c'est encore moins cher sur http://fr.aliexpress.com/<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| raspberry ou kit !! class="unsortable"| Quantité !! class="unsortable"| Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Archive (O/N)<br />
|-l<br />
|-<br />
!Pierre Grommit !!raspb !! 2 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!Pierre Grommit !!kit !! 1 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!Francis Roussel !!rasp !! 2 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!papy F1CHF !!kit !! 4 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!PDA !!rasp !! 3 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!yvs Accard !!rasp !! 3 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!yvs Accard !!Kit !! 1 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!Malek H. !!3 rasp + 2 vga son + 1 gpio + 1 otg !! 1 !! 1 !! n!! n !!n !! n!!<br />
<br />
<br />
|}<br />
<br />
<br />
=== Starterkit FPGA Altera Max10 ===<br />
'''COMMANDE CLOSE'''<br />
<br />
[https://www.arrow.com/en/products/bemicromax10/arrow-development-tools#page-1 Carte de démarrage FPGA] qui sera parfait pour les [[Formations#Initiation_.C3.A9lectronique_num.C3.A9rique_et_FPGA|formation initiation à venir]].<br />
<br />
Cette carte utilise un FPGA entrée de gamme MAX 10 de chez Altera. Elle contient tout un tas de périphériques sympa pour débuter.<br />
<br />
A noter que la board intègre une sonde JTAG Altera Blaster II (>200€ dans le commerce, 20€ pour un clone).<br />
<br />
Le prix: $30 le kit, disons donc 30€ (à réajuster à la baisse post commande). <br />
<br />
Date butoir pour la commande: mercredi 6 avril 2016<br />
<br />
Chip principal: MAX® 10 FPGA (10M08DAF484C8G):<br />
* 8,000 LEs (largement de quoi mettre le soft core 32bit Altera & des périphériques confortables)<br />
* 414 Kbit (Kb) M9K memory<br />
* 256 Kbit (Kb) user flash memory<br />
* 2 phase locked loops (PLLs)<br />
* 24 18x18-bit multipliers<br />
* 1 ADC block – 1 MSa/sec, 12-bit, 18-channels<br />
* 17 analog inputs<br />
* 1 temperature sense diode<br />
* 250 general purpose input/output (GPIO)<br />
* Non-volatile self-configuration with dual-boot support<br />
* Clocking circuitry: 50 MHz oscillator and 24 MHz oscillator<br />
* achetable à l'unité (moins cher de la gamme: 3€, celui ci, 30€)<br />
<br />
External peripherals<br />
* 8MB SDRAM (4Mb x 16) (ISSI IS42S16400)<br />
* Accelerometer, 3-Axis, SPI interface (Analog Devices ADXL362)<br />
* DAC, 12-bit, SPI interface (Analog Devices AD5681)<br />
* Temperature sensor, I2C interface (Analog Devices ADT7420)<br />
* Thermal resistor<br />
* Photo resistor<br />
* 8 user LEDs<br />
* 2 user Pushbuttons<br />
<br />
Prototyping<br />
* Two 6-pin PMOD expansion headers<br />
* Two 40-pin prototyping headers which provide access to 64 digital I/O<br />
* 6 analog inputs<br />
* One 80-pin BeMicro card edge connector<br />
<br />
<br />
Merci d'ajouter votre nom et votre rapport à l'éventualité de formations au lab:<br />
* débutant, intermédiaire, expert: sous entendu je veux assister à une formation & j'ai ce niveau<br />
* formateur: je suis volontaire pour participer à l'élaboration de formations<br />
* pas intéressé: ni en participant ni en formateur<br />
<br />
Merci d'indiquer:<br />
* combien vous en achetez à titre perso (30€ pièce, à revoir selon le change & port)<br />
* si vous voulez en prendre une à offrir aux formations du lab (vous payez 20€, moi 10€ ; il nous faut 10 cartes)<br />
<br />
<br />
'''MISE A JOUR RECEPTION'''<br />
Prix total 40€/carte. 25€ par carte offerte au lab. Merci de vous mettre à jour, et venez récupérer vos cartes auprès de Coline :)<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Formation? !! class="unsortable"| Quantité !! class="unsortable"| cadeau au lab !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Archive (O/N)<br />
|-l<br />
|-<br />
|-<br />
!flax !!formateur!! 1 !! non !! O!! n !!n !! n!!<br />
|-<br />
!flax !!formateur!! 1 !! oui !! O!! n !!n !! n!!<br />
|-<br />
!Clem !!formateur!! 1 !! N/A !! O!! n !!n !! n!!<br />
|-<br />
!3dsman!!débutant !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
!3dsman!!débutant !! 1 !! oui !! n!! n !!n !! n!!<br />
|-<br />
!Yann D!!débutant !! 2 !! non !! n!! n !!n !! n!!<br />
|-<br />
!Yannick A.!!formateur !! 1 !! oui !! n!! n !!n !! n!!<br />
|-<br />
!Yannick A.!!formateur !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
!F1HSU!!débutant !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
!Roul!!formateur? !! 1 !! oui !! n!! n !!n !! n!!<br />
|-<br />
!Roul!!formateur? !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
!Jojo du VoLAB !!intermédiaire !! 2 !! non !! n!! n !!n !! n!!<br />
|-<br />
!Jojo du VoLAB !!intermédiaire !! 1 !! oui !! n!! n !!n !! n!!<br />
|-<br />
!MrPozor !!débutant !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
!Julien Len!!débutant !! 1 !! oui? !! n!! n !!n !! n!!<br />
|-<br />
!Julien Len!!débutant !! 1 !! non!! n!! n !!n !! n!!<br />
|-<br />
!Jérôme Loï!! débutant !! 1? !! oui !! O(payé 30)!! n !!n !! n!!<br />
|-<br />
!Jérôme Loï!! débutant !! 1 !! non!! O!! n !!n !! n!!<br />
|-<br />
!Moala!!débutant !! 1 !! non !! O!! n !!n !! n!!<br />
|-<br />
!Desty!!debutant !! 1 !! oui !! n!! n !!n !! n!!<br />
|-<br />
!Desty!!debutant !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
<br />
!Votre nom!!type !! nombre !! oui/non !! n!! n !!n !! n!!<br />
<br />
<br />
<br />
|}<br />
Nombre de cartes total: 23 dont lab: 8 (total à mettre à jour !)</div>Erichttps://wiki.electrolab.fr/Projets:Commande_groupeeProjets:Commande groupee2018-12-03T16:42:30Z<p>Eric: /* Radiospares (RS Composants) */</p>
<hr />
<div>=Commandes groupées=<br />
<br />
== Principe ==<br />
Tout projet a régulièrement besoin de matières premières, composants, fournitures diverses, etc. Le lab a en stock une quantité importante de fournitures plus ou moins courantes, mais cela ne peut remplacer des commandes régulières.<br />
<br />
Histoire de mutualiser les bons plans & regrouper les frais de port, profiter de divers price breaks, etc, cette page a été créee pour organiser des commandes groupées.<br />
<br />
== Glossaire ==<br />
===Demandeur===<br />
Celui qui a besoin d'un article<br />
<br />
===Acheteur===<br />
Celui qui passe effectivement la commande chez le Fournisseur. L'Acheteur peut être le lab ou une personne privée.<br />
Dans le cas du lab indiquer dans la colonne "acheteur" lab_<nom/pseudo membres> exemple : lab_peewee<br />
Sauf avis contraire, le paiement est à effectuer sur le compte paypal du lab.<br />
<br />
Dans le cas d'une personne privée, indiquer dans la colonne "acheteur", son nom ou pseudo.<br />
L'Acheteur définit lui même les moyens de paiement à utiliser par les <demandeurs>.<br />
<br />
<br />
===Distributeur===<br />
Fournisseur ou fabricant chez qui l'<acheteur> passe commande.<br />
Chaque <distributeur> dispose d'une rubrique propre.<br />
<br />
Il est bien entendu possible d'ajouter des <distributeurs> supplémentaires (notez qu'ils sont triés par '''ordre alphabétique''').<br />
<br />
== Règles du jeu ==<br />
<br />
En général, lorsque l'on s'occupe d'un "group buy", on fait un premier tour de<br />
table pour savoir qui est partant, on annonce ensuite le prix de l'addition<br />
générale (TTC et frais d'expé avec ou sans assurance, éventuels frais de<br />
dédouanement) divisée par le nombre de participants (au prorata des volumes<br />
de commande : celui qui achète 2 items paye 2 parts de frais de port par<br />
exemple).<br />
<br />
Ceci fait, on attend qu'une "masse critique" soit atteinte lorsque l'on vise<br />
certains "price break" (décollonage en jargon de vendeur), puis on lance<br />
l'appel aux fonds avec une date butoir. Passé la date butoir, la commande<br />
est passée, en ignorant ceux qui n'ont pas répondu a temps, puisque le<br />
responsable de group buy n'a pas la trésorerie correspondant à l'achat en<br />
question.<br />
Les histoires genre "le chèque est au courrier" ne marchent pas avec des<br />
virements Paypal... le patron des achats sait exactement combien il a en<br />
caisse au moment de la commande.<br />
<br />
En cas de perte de colis, le responsable de "group buy" n'est pas<br />
redevable. C'est à chaque participant d'estimer s'il prend le risque ou non<br />
de faire confiance aux entreprises assurant l'acheminement des colis.<br />
C'est simple, et si c'est précisé, aucun conflit n'est à redouter, aucun lot<br />
ne reste sur les bras de l'<acheteur>.<br />
<br />
Pour le paiement par avance, celui-ci peut se faire au lab, mais c'est TTC et AVEC les frais de port et de douane, le cas échéant.<br />
<br />
Si un <demandeur> commande la mauvise référence, c'est pour sa pomme.<br />
<br />
Dans la mesure du possible, les <demandeur> doivent faciliter au maximum le travail des <acheteur> en indiquant des références d'articles et de désignation claires.<br />
<br />
==Mode opératoire lorsqu'on passe une commande chez l'un des distributeurs ==<br />
Les tableaux ci-après (un tableau par <distributeur> disposent des colonnes nécessaires à la synchronisation des commandes article par article.<br />
<br />
De même, chaque rubrique dispose d'un en-tete d'information qui a la structure suivante :<br />
<br />
La prochaine commande a pour référence interne : YY_xxx<br />
Commande livrée en cours de distribution : [aucune]<br />
Anciennes commandes <nom du distributeur> archivées [[Projets:Commande_groupee:archives|ici]]<br />
< informations complémentaires notamment en ce qui concerne les conditions de livraison, etc>''<br />
<br />
YY est un code fixe, unique pour chaque founisseur.<br />
<br />
xxx un le n° de commande pour ce distributeur. Il commence à 001 et s'incrémente à chaque commande.<br />
<br />
<br />
===Les différentes étapes de la commande ===<br />
<br />
====Prise en charge d'un commande par un <acheteur>==== <br />
La personne qui souhaite prendre en charge une commande chez un <distributeur> envoie un mail sur la ML pour informer tout le monde de cette action.<br />
Dans l'entête d'information du <distributeur> concerné, l'<acheteur> effectue les modifications suivantes :<br />
*mise à jour de la ligne ''Prochaine date de commande'' : valorisé à la date à laquelle il envisage de passer la commande auprès du <distributeur>. <br />
<br />
À ce moment, l'ensemble des <demandeurs> concernés se met en relation avec l'<acheteur> pour lui payer d'avance les articles commandés. Pour ces articles, l'<acheteur> fait les modifications suivantes dans le tableau des articles :<br />
*''Payé d'avance (O/N)'' : valorisé à "O" (Oui)<br />
<br />
<br />
====Passage effective de la commande par l'<acheteur>==== <br />
<br />
Celui qui passe la commande ( = <acheteur>) sélectionne les articles qu'il commande effectivement (= ceux pour lesquels il a reçu le paiement en avance). Il peut aussi inclure dans la commande des articles de <demandeurs> pour leuquel il est certain d'être payé au moment de la distribution.<br />
<br />
L'<acheteur> passe la commande auprès du distributeur (par internet, mail, téléphone, télécopie, signaux de fumée, déplacement sur place...) et effectue le paiement à l'aide d'un moyen de paiement à sa convenance. Il est judicieux de priviléger des moyens de paiement fournissant la traçabilité de la transaction.<br />
<br />
Pour les articles effectivement COMMANDÉS l'<acheteur> fait les modifications suivantes dans le tableau des articles :<br />
*'' Acheteur'' : valorisé par son nom/pseudo <br />
*''Commandé (O/N)'' : valorisé à "O" (Oui)<br />
<br />
Pour les articles qui n'ont pas déja été concernés par une commande précédente et que l'<acheteur> ne COMMANDE PAS (par exemple par ce que le <demandeur> ne s'est pas manifesté auprès de lui), il fait les modifications suivantes dans le tableau des articles :<br />
*''N° de commande'' : est incrémenté d'une unité afin que cet article non commandé soit inclus dans la prochaine commande.<br />
<br />
<br />
*mise à jour de la ligne ''Prochaine date de commande'' : valorisé à <non défini><br />
*mise à jour de la ligne ''La prochaine commande a pour référence interne'' : valorisé au numéro de commande interne actuel +1 <br />
*mise à jour de la ligne ''Commande passée en attente de livraison'': valorisé au n° de commande actuel<br />
<br />
====Réception de la commande par l'<acheteur>==== <br />
<br />
<br />
Au moment de la réception du colis, l'<acheteur> vérifie si la livraison est complète et négocie avec le <distributeur> en cas de problème. Il peut aussi informer le <demandeur> concerné par le ou les article(s) en litige ou manquants.<br />
<br />
====Distribution des articles aux <demandeurs>====<br />
Lorsque la distribution peut commencer l'<acheteur> effectue les modifications suivantes dans l'entête d'information du <distributeur> concerné :<br />
*mise à jour de la ligne : '' Commande passée en attente de livraison'' à [aucune]<br />
*mise à jour de la ligne : '' Commande livrée en cours de distribution '' avec la référence interne de la commande.<br />
<br />
L'<acheteur> informe via la ML les <demandeurs> du début de la distribution de la commande <référence interne de commande>.<br />
Chaque <demandeur> convient d'un RDV avec l'<acheteur> pour récupérer les articles (en principe cela se passe au lab) et payer son dû à l'<acheteur>, si ce n'est déja fait.<br />
<br />
Pour chaque article l'<acheteur> fait les modifications suivantes dans le tableau des articles :<br />
*'' Distribué (O/N)'' : valorisé à "O" (Oui) <br />
*''Remboursé/Archivé (O/N)'' : valorisé à "O" (Oui)<br />
<br />
====Ditribution des articles terminée====<br />
<br />
Une fois l'ensemble des pièces distribuées et payées, dans l'entête d'information du <distributeur> concerné, l'<acheteur> effectue les modifications suivantes :<br />
*mise à jour de la ligne ''Commande livrée en cours de distribution'' : valorisé à [aucune]<br />
<br />
<br />
===En conclusion ===<br />
<br />
Si les tableaux des commandes et les en-tête d'information sont gérés avec soin, il n'y a quasiment aucun risque de double commande et n'importe quel membre sait où on en est et peut à tout moment prendre la main sur l'un des tableaux d'achats pour commander un article ou organiser une commande en tant qu'<acheteur>. La bonne application de ces quelques recommandation bénéficie à l'ensemble des participants de ce système de commandes groupées.<br />
<br />
Sauf besoin urgent de pièces, il est bénéfique que ce soit de préférence les mêmes <acheteurs> qui officient auprès des mêmes <distributeurs>. Ainsi, vu de ces derniers, l'<acheteur> est très vite identifié comme "client important" (car en réalité il commande pour 5-10 personnes, voire plus) et peut bénéficier de conditions particulières (frais de port gratuit, -15% sur la prochaine commande, etc).<br />
<br />
Enfin, à tout moment en tant que <demandeur>, soyez diligent envers l'<acheteur> dont la gestion d'une commande de parfois plusieurs dizaines d'articles requert un investissement en temps non négligeable.<br />
<br />
== Commandes groupées passées (archives) ==<br />
<br />
Afin d'améliorer la lisibilité nous avons regroupé les commandes passées sur cette page: [[Projets:Commande_groupee:archives]]<br />
<br />
== Commandes groupées en cours ==<br />
<br />
=== BHV ===<br />
<br />
La prochaine commande a pour référence interne : BH_003<br />
<br />
<br />
<br />
<br />
Anciennes commandes BHV archivées [[Projets:Commande_groupee:archives#BHV|ici]]<br />
<br />
achat sur place<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref BHV!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| Lab|| Réglet métallique 30cm || - || 3 || 5.90€||Eric|| BH_001 || N || O || O || O<br />
|-<br />
|-<br />
| Lab|| Scie a métaux FACOM 603E || - || 1 || env. 36€||Eric|| BH_002 || N || O || 0 || O<br />
|-<br />
|}<br />
<br />
=== [http://www.visseriefixations.fr/ Cergy-Vis] ===<br />
<br />
<br />
La prochaine commande a pour référence interne : CV_002<br />
<br />
<br />
<br />
<br />
Anciennes commandes Cergy-Vis archivées [[Projets:Commande_groupee:archives|ici]] <br />
<br />
Retrait gratuit sur place<br />
CERGY-VIS<br />
<br />
17, Rue du Périgord<br />
<br />
ZI des Béthunes<br />
<br />
95310 SAINT OUEN L’AUMONE<br />
<br />
<br />
Horaires pour les enlèvements: Du Lundi au Vendredi, de 7h30 à 12h00 et de 13h30 à 17h30.<br />
<br />
<br />
Livraison<br />
Colissimo Régional (0.05kg / France) 5,75 €<br />
<br />
Colissimo Régional (0.2888kg / France) 6,54 €<br />
<br />
Colissimo Régional (2.87kg / France) 9,25 €<br />
<br />
Colissimo Régional (12.8948kg / France) 16,50 €<br />
<br />
Anciennes commandes Cergy-Vis archivées [[Projets:Commande_groupee:archives#Cergy-Vis|ici]]<br />
<br />
<br />
|-<br />
!Demandeur !! class="unsortable"| Description !! Référence!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-<br />
||Eric|| TRCC M5X30 INOX A2 DIN 603|| ||50||0.17EURTTC||<acheteur>||CV_001||N||O||O||N (attends remb. trop versé)<br />
|-<br />
||Eric|| ECROU HU M12 PAS 100 Z.BLANC DIN 934|| ||20||0.39EURTTC||<acheteur>||CV_001||N||O||O||N (attends remb. trop versé)<br />
|-<br />
||Eric||Vis TCHC M5X22 INOX A2 EF DIN 912||TCHC05/022A2EF||15||0.12EURTTC||<acheteur>||CV_002||N||N||N||N<br />
|-<br />
||Eric||Vis STHC PLAT M6X12 INOX A2 DIN 913||STHCPLA06/012A2||30||0.06EURTTC||<acheteur>||CV_002||N||N||N||N<br />
|-<br />
||Eric||Vis TH M6X12 INOX A2 EF DIN 933||TH06/012A2EF||30||0.09EURTTC||<acheteur>||CV_002||N||N||N||N<br />
|-<br />
|}<br />
<br />
=== [http://www.conradpro.fr Conrad Electronique France] ===<br />
<br />
<br />
La prochaine commande aura pour référence interne : CO_017<br />
<br />
Prochaine date de commande :<br />
<br />
Commande passée en attente de livraison : NEANT<br />
<br />
Commande livrée en cours de distribution : NEANT<br />
<br />
Anciennes commandes Conrad Electronique France archivées [[Projets:Commande_groupee:archives#Conrad Electronique France|ici]]<br />
<br />
{| class="wikitable sortable" style="font-size:85%"<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Conrad!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€ ||<Acheteur>|| CO_XXX || N || N || N || N<br />
|-<br />
--><br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/822746/Fil-de-soudure-pour-PVC-rigide-Steinel-073114-26-pcs Fil de soudure pour PVC rigide Steinel 073114 26 pcs]</s>||<s>822746 - 62 </s>||<s> 1 </s>||<s> € 5.99 TTC</s>||<s><acheteur> </s>||<s> CO_014 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/492161/Soudure-plastique-225-mm-4-mm-polythylne-LDPE-nature-Bosch-1609201811 Soudure plastique, 225 mm, 4 mm, polyéthylène (LDPE) nature Bosch 1609201811]</s>||<s>492161 - 62 </s>||<s> 1 </s>||<s> € 15.99 TTC</s>||<s> <acheteur> </s>||<s> CO_014 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/121588/Solution-de-conservation-pour-electrodes-de-mesure-pH-HI-70300M Solution de conservation pour électrodes de mesure pH HI 70300M]</s>||<s>121588 - 62 </s>||<s> 1 </s>||<s> € 15.12 TTC</s>||<s> <acheteur> </s>||<s> CO_014 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/121586/Solution-de-nettoyage-pour-electrodes-pH-HI-7061M Solution de nettoyage pour électrodes pH HI 7061M]</s>||<s>121586 - 62 </s>||<s> 1 </s>||<s> € 15.12 TTC</s>||<s> <acheteur> </s>||<s> CO_014 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|Eric||[http://www.conrad.fr/ce/fr/product/121164/Sol-de-conduct-12880-S-HI-70030-P Sol. de conduct. 12880 µS HI 70030 P]||121164 - 62 || 1 || € 38.30 TTC|| <Pat> || CO_014 || N || O || O || O<br />
|-<br />
|Eric||[http://www.conradpro.fr/ce/fr/product/822188/Knipex-Pinces-pour-circlips-pour-colliers-dtranglement-darbre-46-11-G0-140-mm?ref=searchDetail Pince KNIPEX 46 11 G0]||822188 - 62 || 1 || € 20.13 HT|| <Pat> || CO_014 || N || O || O || O<br />
|-<br />
|Eric||[http://www.conradpro.fr/ce/fr/product/822189/Knipex-Pinces-pour-circlips-pour-colliers-dtranglement-darbre-46-11-G1-140-mm?ref=searchDetail Pince KNIPEX 46 11 G1]||822189 - 62 || 1 || € 13.02 HT|| <Pat> || CO_014 || N || O || O || O<br />
|-<br />
|MrPozor||[http://www.conrad.fr/ce/fr/product/702246/Interrupteur-de-porte-Panasonic-AZC11113HJ-250-VAC-5-A-poussoir-momentan-IP40-1-pcs?ref=searchDetail Interrupteur de porte Panasonic AZC11113HJ]||702246 - 62 || 1 || € 10.99 TTC|| <Pat> || CO_014 || N || O || N || N<br />
|-<br />
| papy F1CHF || 74HC390 SOIC || 1115010-62 || 10 || 1.06€ ||<Pat>|| CO_014 || O || O || O || O<br />
|-<br />
| Pat|| Condo moteur 5uF 450V || 441527-62 || 1 || 6.33€ H.T. ||<Pat>|| CO_014 || O || O || N || N<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/731484/Adaptateur-avec-fiche-dor-32-A-rouge-MultiContact-240160-22 Adaptateur avec fiche doré 32 A rouge MultiContact Ref. 24.0160-22]|| 731484 - 62 || 2 || 3.00 € H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/731559/Disque-de-marquage-couleur-MultiContact-145010-vert-jaune-1-pcs Disque de marquage couleur MultiContact Ref. 14.5010 vert-jaune 1 pc(s)]|| 31559 - 62 || 3 || 0.75 € H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/106109/Pointe-de-touche-de-scurit-MultiContact-XMA-7L-enfichable-4-mm-CAT-IV-1000-V-bleu Pointe de touche de sécurité MultiContact XMA-7L enfichable 4 mm CAT IV 1000 V bleu Ref. MC 66.9509-23]|| 106109 - 62 || 1 || 15.96 € H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/106108/Pointe-de-touche-de-scurit-MultiContact-XMA-7L-enfichable-4-mm-CAT-IV-1000-V-rouge Pointe de touche de sécurité MultiContact XMA-7L enfichable 4 mm CAT IV 1000 V rouge Ref. MC 66.9509-22]|| 106108 - 62 || 1 || 15.96 € H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/106107/Pointe-de-touche-de-scurit-MultiContact-XMA-7L-enfichable-4-mm-CAT-IV-1000-V-noir Pointe de touche de sécurité MultiContact XMA-7L enfichable 4 mm CAT IV 1000 V noir Ref. MC 66.9509-21]|| 106107 - 62 || 1 || 15.96 € H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/1385649/Pince-crocodile-4-mm-GRIP-FMA-MultiContact-669435-21 Pince crocodile 4 mm GRIP-FMA MultiContact Ref. 66.9435-21]|| 1385649 - 62 || 1 || 30.00€ H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Damien H || MOSFET RFD14N05L || 512-RFD14N05L || 5 || 0,695 € ||?|| CO_015 || N || O || O || O<br />
|-<br />
| Damien H || Zener BZX79C2V4 || 512-BZX79C2V4 || 5 || 0,11 € ||?|| CO_015 || N || O || O || O<br />
|-<br />
|Pierre G|| Câble audio SpeaKa 1m mf||986736 - 62 || 2||6,66 ht || ? || CO_015 || N || O || O || O<br />
|-<br />
|Pierre G|| Câble audio SpeaKa 0,50m mf||986735 - 62 || 1||5.92 ht || ? || CO_015 || N || O || O || O<br />
|-<br />
|Pierre G|| Lentille Dialight OPC-11SPOT transparent 10 ° 1 pc(s)||1127266 - 62 || 1||3 ht || ? || CO_016 || N || O || O || O<br />
|-<br />
|Pierre G|| LED High Power Barthelme 61003528 blanc chaud||1503528 - 62 || 1||3,50 ht || ? || CO_016 || N || O || O || O<br />
|-<br />
|FredericD|| [http://www.conrad.fr/ce/fr/product/574223/Transformateur-electronique-Standard-10-a-60-W Transformateur électronique "Standard" 10 à 60 W]||574223 - 62 || 1||15,49 '''TTC''' || <acheteur> || CO_017 || N || N || N || N<br />
|-<br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/542044/?insert=32&insertNoDeeplink&productname=Gaine-thermoretractable-pour-batteries-sans-colle-21-Conrad-Components-542044-transparent-avant-retreint-44-mm-1-pc Gaine thermorétractable 2:1 transparente pour accus longueur 100 cm largeur 44mm]</s>||<s>542044 - 32</s>||<s>3</s>||<s>2,70€TTC</s>||<s> <acheteur> </s>||<s> CO_017 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/100297/Solution-conductrice-1413-S-HI-70031-P?ref=list Solution conductrice 1413 µS HI 70031 P]</s>||<s>100297 - 62 </s>||<s> 1 </s>||<s> € 33,60 TTC</s>||<s> <acheteur> </s>||<s> CO_017 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|<s>Eric</s>||<s>[http://www.conradpro.fr/ce/fr/product/1305022/Diode-Zener-PanJit-1N4740A-G-DO-41G-Tension-Zener-10-V-1-pcs?ref=searchDetail Diode Zener PanJit 1N4740A-G DO-41G Tension Zener: 10 V]</s>||<s>1305022 - 62 </s>||<s> 10 </s>||<s> € 0,15 TTC</s>||<s> <acheteur> </s>||<s> CO_017 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/812811/tain-de-soudure-teneur-en-plomb-Stannol-HS-10-Sn60Pb39Cu1-bobine-100-g-10-mm?queryFromSuggest=true étain 100g 1mm STANNOL]|| 812811 - 62 || 2 || 7,55 € H.T. ||<acheteur>|| CO_017 || N || N || N || N<br />
|-<br />
|Eric||[http://www.conrad.fr/ce/fr/product/651105/XLR-Bride-mle-contacts-couds-Neutrik-NC3MAAH-Nombre-de-ples-3-noir-1-pcs?queryFromSuggest=true Connecteur XLR mâle plastique pour chassis soudage pour CI 3 broches coudé + blindage, NEUTRIK NC3MA(A)H ]||651105 - 62|| 2 || 1,20€TTC ||<acheteur>||CO_017||N||N||N||N <br />
|-<br />
|}<br />
<br />
Anciennes commandes Conrad archivées [[Projets:Commande_groupee:archives#Conrad_Electronique_France|ici]]<br />
<br />
=== [http://www.damencnc.com/fr DamenCNC] ===<br />
<br />
Accessoires pour machines CNC [http://www.damencnc.com]<br />
<br />
La prochaine commande a pour référence interne : DC_002<br />
<br />
Prochaine date de commande : ?? (probablement en octobre 2014)<br />
<br />
<br />
<br />
Livraison : depuis les Pays-Bas par UPS : estimation : 20€ pour un colis de 1.5kg<br />
<br />
ATTENTION : Prix HT.<br />
<br />
Anciennes commandes DamenCNC archivées [[Projets:Commande_groupee:archives#DamenCNC|ici]]<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref DamenCNC!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||<Acheteur>|| OT_XXX || N || N || N || N<br />
|-<br />
--><br />
|-<br />
|Goldo|| HIWIN HGR Profile Rail L=200mm || HG15R || 2 || 21,60€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|Goldo|| HIWIN Carriage HGH "Compact type" || HGH-15CA || 2 || 33.99€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|Goldo|| Mini Mill 2 flutes 0.20mm || ? || 1 || 11.99€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|Goldo|| Mini Mill 2 flutes 0.30mm || ? || 1 || 11.99€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|Goldo|| Mini Mill 2 flutes 0.50mm || ? || 1 || 9.99€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|Goldo|| Kress Collet + Clamp Nut 1/8inch || ? || 1 || 19.99€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|F1CHF|| Mini Mill 2 flutes 0.50mm || ? || 2 || 9.99€HT || Goldo || DC_001 || N || O || O || O<br />
|-<br />
|F1CHF|| Mini Mill 2 flutes 0.70mm || ? || 2 || 9.99€HT || Goldo || DC_001 || N || O || O || O<br />
|-<br />
|Eric||IPS_Cable_Assembly M12_Straight_Female/OPENEND_3meter || ? || 2 || 4.99€HT || <acheteur>|| DC_002 || N || N || N || N<br />
<br />
|-class="sortbottom"<br />
|}<br />
<br />
===[http://www.detandt.com/fr Detandt-Simon]===<br />
<br />
La prochaine commande aura pour référence interne : DET_001 <br />
<br />
Prochaine date de commande : Mardi 2/2/2016<br />
<br />
<br />
Commande livrée en cours de distribution : [nada] <br />
<br />
Anciennes commandes Detandt archivées [nope]<br />
<br />
Frais de livraisons: inconnu<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Taille !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!!Remboursé/Archive (O/N)<br />
|-<br />
<!-- Pour ajouter une ligne, copier les 2 lignes suivantes (celles qui commencent par | ) à la suite du tableau et remplacer le contenu des colonnes par ce qui semblera adéquat--><br />
| Steve|| Modèle haut Bleu et gris || Taille 44 || 1|| 15€ HT||Steve|| DET_001 || N || N || N || N<br />
|-<br />
| Steve|| Modèle haut Bleu et gris || Taille 45 || 1|| 15€ HT||Steve|| DET_001 || N || N || N || N<br />
|-<br />
| Laurent d. Lo^2 || Modèle haut orange et noir || Taille 44 || 1|| 15€ HT||Laurent|| DET_001 || N || N || N || N<br />
|-<br />
| Laurent d. Lo^2 || Modèle cuir noir || Taille 44 || 1|| 15€ HT||Laurent|| DET_001 || N || N || N || N<br />
|-<br />
| Beatrice/LK999 || Modèle cuir noir ou bas || Taille 45|| 1|| 15€ HT||XXX|| DET_001 || N || N || N || N<br />
|-<br />
| Le Xav || Modèle noir & orange haut || Taille 45|| 1|| 15€ HT||XXX|| DET_001 || N || N || N || N<br />
|-<br />
| Patrick|| 10m gaine VMC alu D80 M0|| HALUM0 82|| 2|| 13,78€ HT||XXX|| DET_002 || N || N || N || N<br />
|-<br />
| Patrick|| 10m gaine VMC alu D125 M0|| HALUM0 127|| 1|| 15,96€ HT||XXX|| DET_002 || N || N || N || N<br />
|-<br />
|}<br />
<br />
===[http://www.digikey.com/ Digikey Corporation]===<br />
<br />
La prochaine commande aura pour référence interne : DI_006<br />
<br />
<br />
Commande passée en attente de livraison : DI_005 <br />
<br />
Commande livrée en cours de distribution : NEANT <br />
<br />
Anciennes commandes Digikey Corporation archivées [[Projets:Commande_groupee:archives#Digikey Corporation|ici]]<br />
<br />
"PAS DE FRAIS POSTAUX sur toutes commandes avec une valeur de 65 Euro et plus.mais la DOUANE + frais"<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Digikey !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!!Remboursé/Archive (O/N)<br />
|-<br />
| Laurent(C) || Capa 470uF || 493-1493-ND || 24 || 0,229€||Laurent(C)|| DI_005 || || O || N || N<br />
|-<br />
| Laurent(C) || Carte NUCLEO-F303K8 || 497-15981-ND || 1|| 9,92€||Laurent(C)|| DI_005 || || O || N || N<br />
|-<br />
| Laurent(C) || Capa tantale 10uF || 478-8959-1-ND || 5|| 0.8€||Laurent(C)|| DI_005 || || O || N || N<br />
|-<br />
| Laurent(C) || PMIC 4V || MCP1702T-4002E/CBCT-ND|| 5|| 0.43€||Laurent(C)|| DI_005 || || O || N || N<br />
|-<br />
| Eric||[http://www.digikey.fr/product-search/fr?vendor=0&keywords=LT1677CS8%23PBF-ND LT1677 OPAMP S8 Package]|| LT1677CS8#PBF-ND || 4|| 3.95€||Laurent(C)|| DI_005 || O || O || N || N<br />
|-<br />
| Eric|| [http://www.digikey.com/product-detail/en/4664-6001/MPK64K-ND/138341 connecteur HE10 64 broches autodénudant mâle] || MPK64K-ND || 1|| 12.59€||Laurent(C)|| DI_005 || O || O || O || O<br />
|-<br />
| Eric|| [http://www.digikey.fr/product-detail/fr/DS2740U%2B/DS2740U%2B-ND/1197488 MAXIM coulombmetric counter DS2740U+ SMD]|| DS2740U+-ND || 1|| 3.90€||Laurent(C)|| DI_005 || O || O || O || O<br />
|-<br />
| Eric|| C190 case ||614-1102-ND||1||199,99USD||Laurent(C)|| DI_005 || O || N(export restriction!) || N || O<br />
|-<br />
| papy F1CHF || NB3N502 || NB3N502DGOS-ND ||4||2.99€||Laurent(C)|| DI_005 || N || O || O || O<br />
|-<br />
| Eric|| [http://www.digikey.com/product-detail/en/linear-technology/LT1763CS8-TRPBF/LT1763CS8-TRPBFCT-ND/4247570 LT1763CS8#TRPBF LT micropower low noise LDO ADJ regulator 500MA SO8]|| LT1763CS8#TRPBFCT-ND || 1|| 4.78USD||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| Eric|| [http://www.digikey.com/product-detail/en/linear-technology/LT1763CS8-3.3-TRPBF/LT1763CS8-3.3-TRPBFCT-ND/4247566 LT1763CS8-3.3#TRPBF LT micropower low noise LDO 3.3V regulator 500MA SO8]|| LT1763CS8-3.3#TRPBFCT-ND|| 2|| 4.78USD||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| Eric|| [http://www.digikey.fr/products/fr?keywords=BA5406 BA5406 Amplifier IC 2-Channel (Stereo) Class AB 12-SIP-M] ||BA5406-ND || 1|| 3.85 EUR||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| Eric|| [https://www.digikey.fr/products/fr?keywords=HR1732-ND HIROSE CONN PLUG 5POS W/PIN INSERT ref "RM12BPE-5PH(71)"] ||HR1732-ND || 1|| 11.19 EUR||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| Eric|| [https://www.digikey.fr/product-detail/fr/infineon-technologies/IRS2453DPBF/IRS2453DPBF-ND/1189713 INFINEON IC DRIVER FULL SELF OSC 14-DIP IRS2453DPBF] ||IRS2453DPBF-ND || 1|| 3.09 EUR||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| 3dsman|| US5881LUA Digital Switch Unipolar Switch Open Drain Hall Effect TO-92UA ||US5881LUA-AAA-000-BU-ND || 5|| 1.10 EUR||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| Debutant|| [https://www.digikey.fr/product-detail/fr/jst-sales-america-inc/SYF-001T-P0.6-LF-SN/455-2652-1-ND/2796952 JST Sales America Inc. SYF-001T-P0.6(LF)(SN) ] || 455-2652-1-ND || 100|| 0.05460 EUR|| Debutant || DI_006 || N || N || N || N<br />
|-<br />
| Lo2|| [https://www.digikey.fr/product-detail/en/molex-llc/0755860006/WM22014CT-ND/9095459 Molex Connecteur 50POS SMD] || WM22014CT-ND || 3|| 8.47 EUR|| Lo2 || DI_006 || N || N || N || N<br />
|-<br />
<br />
|}<br />
<br />
=== [http://www.doga.fr Doga] ===<br />
<br />
La prochaine commande aura pour référence interne : DO_004<br />
<br />
Prochaine date de commande : [inconnu]<br />
<br />
Commande passée en attente de livraison : [aucune]<br />
<br />
Commande livrée en cours de distribution : DO_003<br />
<br />
<br />
Minimum de commande : 50€ HT<br />
Franco : 100€ HT<br />
<br />
Merci de préciser le catalogue dans lequel se trouve l'article pour le retrouver plus aisément. <br />
<br />
Les principaux catalogues sont :<br />
* http://www.doga.fr/catalogue_pdf/ugv.pdf<br />
* http://www.doga.fr/catalogue_pdf/ugv-alliage-leger.pdf<br />
* [https://shop.precitool.de/bk/WKZ_2017-2018/#page_0.1 Precitool]<br />
<br />
Anciennes commandes Doga archivées [[Projets:Commande_groupee:archives#Doga|ici]]<br />
<br />
<br />
{|class="wikitable sortable" style="font-size:85%"<br />
|-<br />
!Demandeur !! class="unsortable"| Description !!class="unsortable"| Ref Doga !! class="unsortable"| Catalogue !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!!Remboursé/Archive (O/N)<br />
<br />
<br />
|-<br />
| Eric||[http://shop.precitool.de/bk/HKL_2016-2017/#page_870 Ø 8mm Zylinderbürste mit Öse, Messingdraht gewellt marque : LESSMANN]|| 481772 || Precitool || 1 || 7 EURHT || <acheteur> || DO_002 || N || O || O || O<br />
|-<br />
| <s>Eric</s>||<s>[http://shop.precitool.de/bk/HKL_2015-2016/#page_1044 Kompakt-Bolzenscheider KNIPEX Mit Mehrkomponenten-Hülle, Öffnungsfeder, 20° abgewinkelt]</s>||<s> 559026</s> ||<s> Precitool </s>||<s> 1 </s>||<s> 40.45EURHT</s> ||<s> <acheteur> </s>||<s> DO_002 </s>||<s>N</s> ||<s>N</s>||<s> N </s>||<s> N</s><br />
|-<br />
| Eric||[http://shop.precitool.de/bk/HKL_2016-2017/#page_924 Strinlochschlüssel-Satz marque AMF]|| 506050|| Precitool || 1 || 31.05EURHT || <acheteur> || DO_002 || N || O || O || O<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1116 KNIPEX Montagezange Typ 4521 für Sprengringe auf Wellen (KNIPEX Ref 45 21 200)]||554175 /4521|| Precitool || 1 || 30,75EURHT || <acheteur> || DO_002 || N || O || O || O<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2016-2017/#page_1242 Schneidoel 500ml]||924055|| Precitool || 1 || 14,35EURHT || <acheteur> || DO_002 || N || O || O || O<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2016-2017/#page_1254 Luftweiche 3 Fach (4 x G3/8) Typ 0304]||925805/0304|| Precitool || 2 || 7.05EURHT || <acheteur> || DO_002 || N || O || O || O<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_35 Spiralbohrer HSS-Co Precitool D1897 INOX Dn 2,1mm]||100670/2,10|| Precitool || 5 || 1.91 EURHT || Lab || DO_003 || N || O || O (livré en 2.3mm, puis relivré gratuitement en 2,1mm) || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_815 Düsenlehre 0.45-1.5mm (0.05mm steigung)]||389850/20|| Precitool || 1 || 12.65 EURHT || Lab || DO_003 || N || O || O || N<br />
|-<br />
|Steve||[http://shop.precitool.de/bk/HKL_2017-2018/#page_987 Gelenk-Hakenschlüssel]||506350/22-35|| Precitool || 1 || 13.55 EURHT || Lab || DO_003 || N || N || N || N<br />
|-<br />
|Steve||[http://shop.precitool.de/bk/HKL_2017-2018/#page_987 Gelenk-Hakenschlüssel]||506350/35-60|| Precitool || 1 || 14.90 EURHT || Lab || DO_003 || N || N || N || N<br />
|-<br />
|Steve||[http://shop.precitool.de/bk/HKL_2017-2018/#page_987 Gelenk-Hakenschlüssel]||506350/60-90|| Precitool || 1 || 17.70 EURHT || Lab || DO_003 || N || N || N || N<br />
|-<br />
|Lab||[http://shop.precitool.de/bk/HKL_2017-2018/#page_985 Hakenschlüssel aus spezial Stahl Gehärtet und im Brunierton angelassen, pour Ø 95-100 mm, pour écrous DIN 1804 et DIN 981]||506200 95/100|| Precitool || 1 || 10,80 EURHT || Lab|| DO_003 || N || O || O (erreur de reference de commande) || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_985 Hakenschlüssel aus spezial Stahl Gehärtet und im Brunierton angelassen, pour Ø 95-100 mm, pour écrous DIN 1804 et DIN 981]||506200 95/100|| Precitool || 1 || 10,80 EURHT || Lab || DO_003 || N || O || O (erreur de reference de commande) || N<br />
<br />
|-<br />
|Lab||[http://shop.precitool.de/bk/HKL_2017-2018/#page_1153 Jeu de chasse-goupilles - Splintentreiber]|| 561110/6M || Precitool || 1 || 18.05 EURHT || Lab || DO_003 || N || N || N || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Linksausdreher Grosse 1 (für M3-M6)]||590950/1|| Precitool || 3 || 1,35 EURHT || Lab || DO_003 || N || O || O || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Linksausdreher Grosse 2 (für M6-M8)]||590950/2|| Precitool || 2 || 1,35 EURHT || Lab || DO_003 || N || O || O || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Linksausdreher Grosse 3 (für M8-M11)]||590950/3|| Precitool || 2 || 1,54 EURHT || Lab|| DO_003 || N || O || O || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Schaubenausdreher/Linksausdreher "Super Traktion" Grosse T1 (pour Ø 4-5 mm, perçage 2.1 mm)]||590970/T1|| Precitool || 3 || 4.47 EURHT || Lab || DO_003 || N || O || O || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Schaubenausdreher/Linksausdreher "Super Traktion" Grosse T2 (pour Ø 5-7 mm, perçage 3.2 mm )]||590970/T2|| Precitool || 3 || 4.58 EURHT || Lab || DO_003 || N || O || O || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Schaubenausdreher/Linksausdreher "Super Traktion" Grosse T3 (pour Ø 8-12 mm, perçage 4.5 mm )]||590970/T3|| Precitool || 3 || 5.70 EURHT || Lab || DO_003 || N || O || O || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_35 Spiralbohrer HSS-Co Precitool D1897 INOX Dn 8,6mm]||100670/8,60|| Precitool || 2 || 6.99 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_35 Spiralbohrer HSS-Co Precitool D1897 INOX Dn 8,7mm]||100670/8,70|| Precitool || 2 || 6.99 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_985 Gelenk-Hakenschlüssel verstellbar, mit Nase, gehärtet und im Brünierton angelassen; für AuBen Ø (Mutter) 20-35 mm]||506300/20-35|| Precitool || 1 || 11.10 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_985 Gelenk-Hakenschlüssel verstellbar, mit Nase, gehärtet und im Brünierton angelassen; für AuBen Ø (Mutter) 35-60 mm]||506300/35-60|| Precitool || 1 || 12.00 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_985 Gelenk-Hakenschlüssel verstellbar, mit Nase, gehärtet und im Brünierton angelassen; für AuBen Ø (Mutter) 60-90 mm]||506300/60-90|| Precitool || 1 || 15.55 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Schaubenausdreher/Linksausdreher "Super Traktion" Grosse T4 (pour Ø 12-14 mm, perçage 6.5 mm )]||590970/T4|| Precitool || 3 || 6.59 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Schaubenausdreher/Linksausdreher "Super Traktion" Grosse T5 (pour Ø 16-20 mm, perçage 8.5 mm )]||590970/T5|| Precitool || 3 || 9.00 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|}<br />
<br />
=== [http://fr.farnell.com Farnell] ===<br />
<br />
Livraison gratuite au dessus de 30€ HT<br />
<br />
La prochaine commande aura pour référence interne : FA_017<br />
<br />
<br />
Prochaine date de commande : <à définir><br />
<br />
Commande passée en attente de livraison : <aucune><br />
<br />
Anciennes commandes Farnell archivées [[Projets:Commande_groupee:archives#Farnell|ici]]<br />
<br />
|-<br />
| Demandeur || class="unsortable"| Description || Ref Farnell || class="unsortable"| Quantité || class="unsortable"| Prix unitaire || Acheteur || Commande<br/>n° || Payé<br/>d'avance<br/>(O/N)|| Commandé<br/>(O/N)|| Distribué<br/>(O/N)|| Remboursé/<br/>Archive<br/>(O/N)<br />
|-<br />
! !! !! !! !! !! !! !! !! !! !!<br />
|-<br />
|-<br />
| Claire Poisson || CD4011BM96 || 2114002 || 15 || 0,313 TTC || 3dsman ||FA_015 ||N ||O ||N ||N<br />
|-<br />
|-<br />
| 3dsman || Câble multiconducteur blindé || 2425036 || 10 || 0,85 TTC || 3dsman ||FA_015 ||N ||O ||N ||N<br />
|-<br />
|-<br />
| Steve (Pour lab/smoothie) || NXP LPC 1769 || 2072199 || 1 || 8,68 TTC || 3dsman ||FA_015 ||N ||O ||O ||N<br />
|-<br />
|-<br />
| Dom (Rude ULM) || Connecteur d'alimentation DC, Mâle, 2 A, 9.5 mm, Montage sur câble, 1.7 mm || 1737255 || 2 || 2.87 TTC || 3dsman ||FA_015 ||N ||O ||N ||N<br />
|-<br />
|-<br />
| Steve || MCP1702T-5002E/MB - Régulateur LDO 5V SOT89-3 || 1605559 || 3 || 0.593 || 3dsman ||FA_015 ||N ||O ||O ||N<br />
|-<br />
|-<br />
| Steve || RELAY, SPDT, 250VAC, 12A || 1714771 || 2 || 2.27E|| 3dsman ||FA_015 ||N ||O ||O ||N<br />
|-<br />
|-<br />
|-<br />
| Steve (Pour lab/smoothie) || LDO LM1117 3.3V || 2323580 || 5 || 0.907 || Ph. Gras||FA_016 ||N ||O ||O ||N<br />
|-<br />
| Eric ||[http://fr.farnell.com/amphenol-sine-tuchel/t-3424-501/fiche-libre-6-voies/dp/1123507 Connecteur 6 broches Amphénol avec serrage baillionnette ref T 3424 501] || 1123507 || 1 || 5,12 || Ph. Gras ||FA_016 ||N ||O ||O ||N<br />
|-<br />
| Eric ||[http://fr.farnell.com/nkk-switches/b18jp/switch-toggle-spdt-0-1a-28vac/dp/2374722?ost=2374722&ddkey=http%3Afr-FR%2FElement14_France%2Fsearch Commutateur 3 positions miniature SPDT, 0.1A, 28VAC On-Off-On NKK Switch ref B18JP ] || 2374722|| 2 || 3,98 EUR || Ph. Gras ||FA_016 ||N ||O ||O ||N<br />
|-<br />
| Ph. Gras||[http://fr.farnell.com/jst-japan-solderless-terminals/phr-2/boitier-2-voies-2mm/dp/3616186 Boîtier de connecteur, Série PH, Embase, 2 Voies, 2 mm, Contacts à sertir Série BPH et SPH ] || 3616186|| 100 || 0,0324 EUR || Ph. Gras||FA_016 ||N ||O ||O ||O<br />
|-<br />
| Ph. Gras||[http://fr.farnell.com/jst-japan-solderless-terminals/sph-002t-p0-5s/contact-0-05-0-22mm-cut-reel/dp/1671245?st=SPH-002T-P0.5S Contact, Série PH, Femelle, Sertissage, 24 AWG, Contacts plaqués étain, Connecteurs PH ] || 1671245|| 250|| 0,0208 EUR || Ph. Gras ||FA_016 ||N ||O ||O ||O<br />
|-<br />
| Ph. Gras||[http://fr.farnell.com/on-semiconductor/lm317ahvt/regulateur-ldo-ajustable-1-5a/dp/1564497?st=lm317LM317AHVT Régulateur de tension positive ajustable 1.2V à 37V, 1.5A en boîtier TO-220-3 ] || 1564497|| 10|| 0,727 EUR || Ph. Gras ||FA_016 ||N ||O ||O ||O<br />
|-<br />
|-<br />
|-<br />
| <demandeur> ||[http://wiki.electrolab.fr/Projets:Commande_groupee#Glossaire <article>] || <fa_cde_nb> || <quantité> || <prix> || <acheteur> ||FA_017 ||N ||N ||N ||N<br />
|-<br />
|-<br />
|}<br />
<br />
=== [http://www.gotronic.fr Gotronic] ===<br />
<br />
la prochaine commande a la référence interne GO_003<br />
<br />
Prochaine date de commande : <non défini><br />
<br />
Commande passée en attente de livraison :GO_002 le 31/05/2017 par Ellyan<br />
<br />
Commande livrée en cours de distribution : [aucune] <br />
<br />
Anciennes commandes Gotronic archivées [[Projets:Commande_groupee:archives#Gotronic|ici]]<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref gotronic!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-<br />
<!-- Pour ajouter une ligne, copier les 2 lignes suivantes (celles qui commencent par | ) à la suite du tableau et remplacer le contenu des colonnes par ce qui semblera adéquat<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||<Acheteur>|| GO_XXX || N || N || N || N<br />
|-<br />
--><br />
| Damien H || Solénoïde 12 Vcc || LS1110BD || 1 || 7,00€||Ellyan|| GO_002 || N || O || N || N<br />
|}<br />
<br />
=== HighVoltageShop ===<br />
<br />
La prochaine commande a pour référence interne : HV_002<br />
<br />
5 euros de réduction sur la prochaine commande<br />
<br />
Prochaine date de commande : Aucune<br />
<br />
Commande passée en attente de livraison : Aucune<br />
* frais de port 20 euros<br />
* Livraison mardi 7 janvier 2014 au lab<br />
<br />
Commande livrée en cours de distribution : HV_001 (08/12/2013) <br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref ebay!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||David|| DI_XXX || N || N || N || N<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| Thomas || Cable HV 120 kV || 271261265516 || 1 || 8,69€||David|| HV_001 || O || O || O || N<br />
|-<br />
|David||-30kV HV-Generator Modul 12VDC||281162933827||1||34,99€||David||HV_001||O||O||O||N<br />
|-<br />
|David||5 Stk. Zeilentrafo - Flyback Transformer - Zeilentrafos||281024817841||1||24,99€||David||HV_001||O||O||O||N<br />
|-<br />
|David||+30kV HV-Generator Modul 12VDC||281162933829||1|| 34,99€||David||HV_001||O||O||O||N<br />
|-<br />
|CitronVert||-30kV HV-Generator Modul 12VDC||281162933827||2||34,99€||David||HV_001||N||O||O||N<br />
|-<br />
| Goldo || Regelbares Hochspannungsnetzteil 50kV Strombegrenzung || 280941865340 || 1 || 119,99€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || +30kV HV-Generator Modul 12VDC || 281162933829 || 1 || 34,99€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Zenos || +30kV HV-Generator Modul 12VDC || 281162933829 || 1 || 34,99€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || Cable HV 120 kV || 271261265516 || 1 || 8,69€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || Hochspannungskabel 40kV 1m || 271261265512 || 1 || 4,61€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || Hochspannungswiderstand 20kV 1 GigaOhm Messwiderstand || 280941865344 || 1 || 6,34€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || Hochspannungswiderstand 20kV 100 MegaOhm || 271106455991 || 1 || 6,34€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || Hochspannungswiderstand 20kV 1 MegaOhm || 281026497192 || 1 || 6,34€||David|| HV_001 || O || O || O || N<br />
|}<br />
<br />
=== [http://www.limpulsion.fr/web/index.php L'impulsion] ===<br />
<br />
[http://v1.limpulsion.fr/docpdf/2008_cat/bpoa_a.pdf Catalogue "accessoires de test"]<br />
<br />
La prochaine commande a la référence interne LI_002<br />
<br />
Prochaine date de commande : [à définir]<br />
<br />
<br />
Commande livrée en cours de distribution :[aucune]<br />
<br />
Anciennes commandes Limpulsion archivées [[Projets:Commande_groupee:archives|ici]]<br />
<br />
<br />
{|class="wikitable sortable" style="font-size:80%"<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref L'impulsion!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-<br />
|Lab||ADAPTATEUR D'AXE HM8001-2 HAMEG||760000500||1||2.30HT||Yannick||IL_001||N||N (plus livrable)||N||O<br />
|-<br />
|Lab||TRESSE A DESSOUDER NO CLEAN 2.8mm/3m||730.14||10||1.56HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||Entretoise plastique grise de montage en saillie marque "Electro-PJP" pour douilles 4mm type 3265, ref EPJP : 3282||<pas au catalogue: demander si livrable> ||16||? ||Yannick||IL_001||N||N (apparement pas dispo)||N||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou NOIR, ref3265-I-0 ||326500||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou MARRON, ref3265-I-1 ||326501||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou ROUGE, ref3265-I-2 ||326502||3||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou BLEU, ref3265-I-6 ||326506||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou VIOLET, ref3265-I-7 ||326507||3||1.48HT||Yannick||IL_001||O||O||N||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou GRIS, ref3265-I-8 ||326508||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou BLANC, ref3265-I-9 ||326509||3||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou JAUNE/VERT, ref 3265-I-J/V||326510||1||1.74HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||[http://v1.limpulsion.fr/docpdf/2008_cat/bpoe_a.pdf#page=9 Passe fil classique intérieur :12mm, Perçage: 18mm, Epaisseur :10mm (lot de 10pcs)]||252.162||1||1,95EURHT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||Entretoise plastique grise de montage en saillie marque "Electro-PJP" pour douilles 4mm type 3265, ref EPJP : 3282||<pas au catalogue: demander si livrable> ||16||? ||Yannick||IL_001||N||N(apparement pas dispo)||N||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou NOIR, ref3265-I-0 ||326500||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou MARRON, ref3265-I-1 ||326501||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou ROUGE, ref3265-I-2 ||326502||3||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou BLEU, ref3265-I-6 ||326506||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou VIOLET, ref3265-I-7 ||326507||3||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou GRIS, ref3265-I-8 ||326508||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou BLANC, ref3265-I-9 ||32650||3||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou JAUNE/VERT, ref 3265-I-J/V||326510||2||1.74HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||CLE EXTERNE POUR DOUILLE DE SECURITE||3299||1||13.51HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||TRANSFO FERRITE POUR THT HM1005 HAMEG (plus livrable) ||THTHM1005||1||16.77HT||Yannick||IL_001||N||N (plus livable)||N||O<br />
|-<br />
|Eric||Lot de 100 douilles pour C.I diam4 Long 10mm à souder Electro-PJP ref 20054||20054||1||7,95 EUR HT||Yannick||LI_001||N||O||O||O<br />
|-<br />
<br />
|Eric||CI SN75492 (7 segm DRIVER) TEXAS DIP14||75492||13||1.29HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||CI 74LS164 TEXAS DIL||74LS164||2||0.76HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||IPROBER520||IPROBER520||1||594HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|}<br />
<br />
=== [https://shop.mchobby.be/ MCHobby] ===<br />
<br />
La prochaine commande a pour référence interne : MCH_001<br />
<br />
Prochaine date de commande : <Mardi 20 ou mercredi 21 au plus tard ><br />
<br />
Livraison gratuite en Mondial Relay à partir de 75 euros.<br />
<br />
Commande passée en attente de livraison :[aucune]<br />
<br />
<br />
Anciennes commandes MCHobby archivées [[Projets:Commande_groupee:archives#MCHobby|ici]]<br />
<br />
Site WEB de MCHobby : https://shop.mchobby.be/<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Mon Droguiste !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||<Acheteur>|| MC_XXX || N || N || N || N<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| LienRag|| Divers ||Divers || ++|| 75€||<acheteur>|| MHC_001 || N|| N || N || N<br />
|}<br />
<br />
<br />
=== [http://217.34.103.131/homepage/homepage.html Mini-Circuits] ===<br />
<br />
La prochaine commande a pour référence interne : MC_001<br />
<br />
<br />
<br />
<br />
Anciennes commandes Mini-Circuits archivées [[Projets:Commande_groupee:archives#Mini-Circuits|ici]]<br />
<br />
Site WEB de minicircuits : http://www.minicircuits.com/homepage/homepage.html<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Mini-circuits !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| F1CHF || ERA-3 || AMPL || 20 || 1.43€||F1CHF|| MC_001 || N || N || N || N<br />
|-<br />
|-<br />
| F1CHF || ADCH-80+ || coil || 20 || 2.88€||F1CHF|| MC_001 || N || N || N || N<br />
|-<br />
|}<br />
<br />
=== [http://www.mon-droguiste.com/index.cfm Mon Droguiste] ===<br />
<br />
La prochaine commande a pour référence interne : MD_001<br />
<br />
<br />
<br />
<br />
Anciennes commandes Mon Droguiste archivées [[Projets:Commande_groupee:archives#Mon-droguiste|ici]]<br />
<br />
Site WEB de Mon Droguiste : http://www.mon-droguiste.com/index.cfm<br />
<br />
|-<br />
|-l<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| Eric|| Ethylene Diamino Tetraacetic Acide 500g ||Ethylene Diamino Tetraacetic Acide Sac 500g || 1|| 16.95€||<acheteur>|| MD_001 || N|| N || N || N<br />
|}<br />
<br />
=== [http://www.mouser.fr Mouser Electronics]===<br />
<br />
La prochaine commande aura pour référence interne MO_014<br />
<br />
Prochaine date de commande : ?<br />
<br />
<br />
Commande livrée en cours de distribution : MO_013 le 31/05/2017 par Ellyan<br />
<br />
Anciennes commandes Mouser Electronics archivées [[Projets:Commande_groupee:archives#Mouser Electronics|ici]]<br />
<br />
Livraison gratuite (FedEx ou UPS) au delà de 50€ de commande<br />
<br />
<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Mouser !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||<Acheteur>|| DI_XXX || N || N || N || N<br />
|-<br />
--><br />
<br />
|-<br />
|Frederic.D.||[http://www.mouser.fr/ProductDetail/TE-Connectivity/1-826632-0/ Headers & Wire Housings 2X10P DUAL ROW]||571-1-826632-0 ||3 ||1.95 |||| MO_013||O ||O ||O ||N<br />
|-<br />
|Frederic.D.||[http://www.mouser.fr/ProductDetail/Bourns/3306P-1-103/ Trimmer Resistors - Through Hole 10K 25% 6mm Single Turn]||652-3306P-1-103 ||3 ||0.407 |||| MO_013||O ||O ||O ||N<br />
|-<br />
|Frederic.D.||[http://www.mouser.fr/ProductDetail/Schurter/13019302/?qs=%2fha2pyFadugAVCtehZ6ro0we%252bFlHwInvMJ3iEORyekx9pnGrLimsvA%3d%3d Pushbutton Switches SHORT TRAVEL SWITCH 6X6, 5.0MM]||693-1301.9302 ||9 ||0.251 |||| MO_013||O ||O ||O ||N<br />
|-<br />
|Frederic.D.||[http://www.mouser.fr/ProductDetail/Bourns/MF-USMF075-2/ Resettable Fuses - PPTC 0.75A 6V 0.18ohm Hold .75A Trip 1.5A]||652-MF-USMF075-2 ||3 ||0.275 |||| MO_013 ||O ||O||O ||N<br />
|-<br />
|Frederic.D.||[http://www.mouser.fr/ProductDetail/STMicroelectronics/SMA6J50A-TR/?qs=%2fha2pyFadujqXhcCRI4%2fO5BEn9p7pkr6EX0dAQtUlws3JpN%2fE2p9DQ%3d%3d TVS Diodes - Transient Voltage Suppressors HJ Temp Transil]||511-SMA6J5.0A-TR ||3 ||0.38 |||| MO_013 ||O||O||O ||N<br />
|-<br />
|-<br />
|Sylvain V.||[http://www.mouser.fr/ProductDetail/Cirrus-Logic/CS4398-CZZ/?qs=sGAEpiMZZMv%252bLKsN4bqzyhXScoHWAp%252boAQFEBwyfAGo%3d DAC Cirrus Logic]||777-CS4398-CZZ ||1 || 10.46 || Sylvain V. || MO_013 ||O||O||O ||N<br />
|-<br />
|Eric||[https://eu.mouser.com/ProductDetail/Amphenol-Tuchel/T-3427-100?qs=%2fha2pyFaduhPv3s%2fjYa9sAYm3fflPgRKEDSdRTPyUvP7YbNcd%2fVs5g%3d%3d Circular DIN Connectors FEMALE RECEPTACLE 6 WAY, Amphenol series C091B]|| 523-T3427-100 ||1 || 10.29|| <<acheteur>> || MO_014 ||N||N||N ||N<br />
|-<br />
|Eric||[https://www.mouser.fr/ProductDetail/EPCOS-TDK/B32926A4685M?qs=sGAEpiMZZMv1cc3ydrPrF3kXVSi%252b9fyL4PImBI83UxcgTMvwb1977w== Condensateurs à film 6.8uF 20% 350Vac LS 37.5MM Fabricant : EPCOS /TDK ref : B32926A4685M ]|| 871-B32926A4685M ||1 || 10.67|| <<acheteur>> || MO_014 ||N||N||N ||N<br />
|-<br />
|Eric||[https://www.mouser.fr/ProductDetail/Texas-Instruments/OPA2227U-2K5?qs=sGAEpiMZZMtCHixnSjNA6Mrdwin7F8A2DB4TJmgUI0w%3d OPA2227U SOIC8 dual opamp low noise Texas ]|| 595-OPA2227U/2K5 ||2 || 8.07|| <<acheteur>> || MO_014 ||N||N||N ||N<br />
|-<br />
|Eric||[https://eu.mouser.com/ProductDetail/Molex/53253-0570?qs=sGAEpiMZZMvlX3nhDDO4AD1CBCqS4WJ3BaSa47NubxE%3d Shrouded header 5 pins 2mm male through hole board connnector vertical mounting Molex ref. 53253-0570 Cross ref to JST PH "B5B-PH-K-S"]|| 538-53253-0570||20 || 0,164 €|| <<acheteur>> || MO_014 ||N||N||N ||N<br />
|-<br />
|Eric||[https://eu.mouser.com/ProductDetail/Central-Semiconductor/TIP42B?qs=sGAEpiMZZMshyDBzk1%2fWi0MKeUdJDRlz1TXFEdLineJjytqjBdqtHg%3d%3d Bipolar Transistor PNP 10A 80V TIP42B]|| 610-TIP42B ||2 || 0,969 €|| <<acheteur>> || MO_014 ||N||N||N ||N<br />
|-<br />
| Eric|| [https://www.mouser.fr/ProductDetail/Hirose-Connector/RM12BPE-5PH71?qs=sGAEpiMZZMvG94qpybaIZaiKjo18NgShhh8FQGCnH4c%3d HIROSE CONN PLUG Cbl Mount 5 Terminals ref "RM12BPE-5PH(71)"] ||798-RM12BPE-5PH71 || 1|| 11.47 EUR||<acheteur>|| MO_014 || N || N || N || N<br />
|-<br />
| Eric|| [https://www.mouser.fr/ProductDetail/Mueller-Electr/BU-75K?qs=sGAEpiMZZMs4AFwHyzhTm%2f3wHG8LpAJAx37I4fl4y%2fU%3d Kelvin clip 10A Mueller Electric ref. BU-75K] ||548-BU-75K|| 4|| 10.20 EUR||<acheteur>|| MO_014 || N || N || N || N<br />
<br />
|-<br />
|}<br />
<br />
<br />
=== [http://www.motedis.fr/shop/ Motedis France] ===<br />
<br />
<br />
La prochaine commande aura pour référence interne : MS_001<br />
<br />
<br />
<br />
<br />
Anciennes commandes Motedis France archivées [[Projets:Commande_groupee:archives#Motedis France|ici]]<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Motedis!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-<br />
|Eric||Plaquette aluminium 15mm d'épaisseur Largeur: 100mm ||<ref motedis>||L:1000mm|| 24.15EURHT || <acheteur> || MS_001 || N|| N || N || N<br />
|-<br />
|<demandeur>||<description>||<ref motedis>|| <quantité> || <prix>|| <acheteur> || MS_001 || N|| N || N || N<br />
|-<br />
|}<br />
<br />
<br />
===[http://www.nouvelleplastique.it/f/setf.html Nouvelle Plastique]===<br />
La prochaine commande a pour référence interne : NP_001<br />
<br />
Prochaine date de commande : Q3/2014<br />
<br />
<br />
<br />
Anciennes commandes Nouvelle Plastique archivées [[Projets:Commande_groupee:archives#Nouvelle Plastique|ici]]<br />
<br />
La société "[http://www.nouvelleplastique.it/f/setf.html Nouvelle Plastique]" fabrique des systèmes de rangements portables et modulaires en plastique.<br />
Les produits sont souvent bien pensés (parfois mieux que RAACO ou Stanley) et de bonne solidité.<br />
<br />
Malheureusement, ses produits ne sont que rarement distribués par les circuits classiques et pour le moment aucun revendeur de détail en France n'a été identifié. De même, on ne connait pas les prix des produits.<br />
La démarche envisagée est de collecter via le tableau ci-dessous une liste de souhaits afin de pouvoir demander un devis global directement au fabricant d'ici quelques mois (probablement en Q3/2014). En fonction de ses proposition de prix, chacun pourra finalement accepter ou refuser que ses souhaits soient inclus dans la commande définitive. Le coût du port sera partagé au prorata du prix des marchandises achetées (plus il y a de demaneurs, plus le coût individuel du port sera faible).<br />
Pour chaque article, il y a indication d'une UDV (Unité De Vente), c'est à dire de lot indivisible.<br />
Au terme des sélections de vos besoins, il faudra que le nombre de pièces commandées pour chaque article soit un multiple de son UDV.<br />
Le tableau ci-dessous dispose d'une structure adaptée à la gestion des souhaits des demandeurs, du nombre d'article et des UDV.<br />
Tous les demandeurs intéressés par un même article s'inscrivent dans une seule ligne (ce qui conduit au fait qu'il y ait une ligne par référence d'article).<br />
Le champ "PUHT" sera complété une fois le devis obtenu.<br />
<br />
====Légende du tableau ====<br />
<br />
UDV = correspond au nombre d'articles par UDV. = nombre d'articles dans un lot indivisible, cette information est indiquée par le fabricant dans son catalogue. <br />
Reste à affecter = mod(Nombre d'UDV; Nombre d'articles) <br />
<br />
<br />
Si vous éditez une ligne existante pour vous inclure comme demandeur de l'article considéré, modifiez les champs suivants :<br />
*''UDV' *''Nombre d'UDV'' (valeur cumulée d'UDV entre tous les demandeurs) <br />
*''Quantités (nombre d'articles)'' (valeur cumulées en nombre d'articles individuels entre tous les demandeurs) <br />
*''Reste à affecter'' (valeur calculée globalement pour tout les demandeurs) <br />
*''Liste de demandeurs avec (unités)'' Unités = nombre d'articles demandéz<br />
<br />
<br />
{|class="wikitable sortable" style="font-size:99%"<br />
|-<br />
! Ref article!! class="unsortable"| Désignation!! UDV (= nombre d'articles dans un lot indivisible) !! class="unsortable"| Nombre d'UDV!! class="unsortable"| Quantité souhaitée(nombre d'articles) !! Reste à affecter!! PUHT !! Liste de demandeurs avec (unités) !! N° de commande <br />
|-l<br />
|00366|| Tyger maxi double|| 6 || 1 ||6 ||0|| <PU> || Eric (6) || NP_001 <br />
|-<br />
|00361|| Tyger maxi|| 12 || 1 ||6 ||6|| <PU> || Eric (6) || NP_001 <br />
|-<br />
<br />
|}<br />
<br />
=== [https://www.olimex.com/ Olimex]===<br />
<br />
La prochaine commande a pour référence interne : OL_001<br />
<br />
<br />
<br />
<br />
Anciennes commandes Olimex archivées [[Projets:Commande_groupee:archives#Olimex|ici]]<br />
<br />
<br />
Achat par l'intermédiaire de leur site internet: https://www.olimex.com/<br />
<br />
Produits identifiés comme potentiellement intéressants:<br />
* https://www.olimex.com/Products/ARM/TI/TMS570-CAN/ un pti devkit pour un micro bien patator, prévu au départ pour des applications safety mais qui a des périphériques & capacités pas dégueulasses...<br />
* https://www.olimex.com/Products/Modules/Adapters/ pour utiliser leurs modules d'extension avec un launchpad ou un rpi<br />
* https://www.olimex.com/Products/Modules/LCD/ (divers modules LCD)<br />
* https://www.olimex.com/Products/Modules/LCD/MOD-LCD4.3%27%27/ module LCD "complet" avec pti micro sympatoche intégré<br />
* https://www.olimex.com/Products/OLinuXino/ gamme de nanocomputers intégrés & pas chers (type rpi mais en open)<br />
* https://www.olimex.com/Products/Components/Misc/TC-K-TYPE/ thermocouple K <br />
etc...<br />
<br />
<br />
Commande prévue courant mars 2013 par Clem.<br />
Attention, prix HT a priori, et prévoir également frais de port "importants" (environ 20€) à répartir entre les participants à la CG.<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Olimex!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||<Acheteur>|| OL_XXX || N || N || N || N<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| XXX|| XXX || - || - || XXX€||XXX|| OL_001 || N || N || N || N<br />
|-<br />
|-<br />
|}<br />
<br />
=== [http://www.otelo.fr/fr/index.html Otelo] ===<br />
<br />
Outillage bois-métal <br />
<br />
Ports gratuits au delà de 230 € H.T. ou code promo<br />
<br />
La prochaine commande a pour référence interne : OT_004<br />
<br />
Prochaine date de commande : < non définie ><br />
<br />
Commande passée en attente de livraison [AUCUNE]<br />
<br />
<br />
Anciennes commandes Otelo archivées [[Projets:Commande_groupee:archives#Otelo|ici]]<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Otelo!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
|-<br />
--><br />
|-<br />
|lab||TARAUD à main diamètre 14X200 Acier/alu||14104142N1||1|| 14,51€ HT|| <Patrick> || OT_002|| N || O|| O || O<br />
|-<br />
|lab||100 rondelles plates diamètre 8X16 ||36211008||5|| 3,23€ HT|| <Patrick> || OT_002|| N || O|| O || O<br />
|-<br />
|Patrick||Disque à poncer bombé axe 22mm D125 grain 80||54426280||2|| 3,42€ HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|Patrick||boites de rangement 18 sep 375X310X60||PY 69720030||3|| 9,55€ HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|Patrick||jeu d'outils ébavurage||PY 58500009||1|| 7,35€ HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|Patrick||BOMBE GALVA FLASH||PY 73006003||1|| 8,40€ HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|Eric||Tablier de soudeur 90 x 60 cm||PW 75 150 001||1|| 10,90€HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|MAZ24||meule blanche touret||5473014F||1|| 11,40€HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|MAZ24||Meule verte de touret||54571150||1|| 42,40€HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|MAZ24||Bagues adaptation||54703320||4|| 1,09€HT|| <Patrick> || OT_002|| O || O|| O|| O<br />
|-<br />
|Patrick||Mandrin à clef 3-16mm CM2/B18||30140413||1|| 27,25€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Mandrin à clef 1-13mm CM2/B16||30140409||1|| 23,20€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Arbre pour mandrin CM2/B16||30199116||1|| 6,80€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Arbre pour mandrin CM2/B18||30199118||1|| 7,00€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Ecouvillon manche bois 15mm||57169015||1|| 7,70€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Ecouvillon manche bois 25mm||57169025||1|| 8,15€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Ecouvillon à fil 6mm||57169006||1|| 5,24€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Ecouvillon à fil 25mm||57151025||1|| 6,38€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Sylvia||Support articulé ||43130110||1|| 23,77€ HT|| <Patrick> || OT_003|| N || O|| O|| O<br />
|-<br />
|}<br />
<br />
===[http://www.outiz.fr/ Outiz]===<br />
<br />
<br />
Comptoir Guilleraies (Nanterre)<br />
<br />
Du lundi au vendredi 7h - 17h Samedi 8h - 12h<br />
<br />
Téléphone : 01 40 35 77 77<br />
<br />
La prochaine commande aura pour référence interne : OU_001 <br />
<br />
Prochaine date de commande : <non définie><br />
<br />
<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Outiz!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!!Remboursé/Archive (O/N)<br />
|-<br />
| Eric ||[http://www.outiz.fr/sferaco-vanne-a-sphere-laiton-pn25-batiment-ff-3-4-poignee-acier-plate-rouge-580005/p/3806984/ Vanne à poignée plate rouge Genre : FF Ø : 3/4" ] ||3806984 || 1|| 4,54 €HT||<acheteur>|| OU_001 || N || N || N || N<br />
|-<br />
|}<br />
<br />
=== [http://fr.rs-online.com/web/ Radiospares (RS Composants)] ===<br />
<br />
La prochaine commande aura pour référénce interne : RS_012<br />
<br />
<br />
<br />
Commande livrée en cours de distribution : <aucune><br />
<br />
Anciennes commandes Radiospares archivées [[Projets:Commande_groupee:archives#Radiospares|ici]]<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref RS!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||Acheteur|| DI_XXX || N || N || N || N<br />
--><br />
|-<br />
| papy F1CHF||régulateur || 686-9007 || 10 || 0,27€|| <>|| RS_012 || N || N || N || N<br />
|FredericD||[http://fr.rs-online.com/web/p/ldr/9146710/ Silonex, NSL-19M51, CdS, Traversant, TO-18, 20 kΩ → 100 kΩ]||914-6710|| 10 || 1.074€HT ||<>||RS_012||N||N||N||N <br />
|-<br />
|FredericD||[http://fr.rs-online.com/web/p/relais-reed/2562055/ Relais Reed 1NO 12V dc 1 A]||256-2055|| 1 || 5.17€HT ||<>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[http://fr.rs-online.com/web/p/refrigerants/1115853/ Réfrigérant aérosol Cramolin Aérosol 400 ml, -50°C]||111-5853|| 2 || 11.12€HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/accessoires-pour-capteur-de-temperature/0286771/ Presse-étoupe pour Thermocouple]||286-771|| 2 || 9,68€HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|<s>Eric</s>||[<s>https://fr.rs-online.com/web/p/pinces-kelvin/7148263/ Pince Kelvin BU-75K, 10A, noir, fabricant : Mueller]</s>||<s>714-8263</s>||<s> 2</s> ||<s> 19,61€HT</s> ||<s><acheteur></s>||<s>RS_012</s>||<s>N</s>||<s>N</s>||<s>N</s>||<s>N</s> <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/condensateurs-aluminium/8396258 Condensateur électrolytique aluminium radial 10µF, -20%, 50V dc, Traversant, +105°C, WURTH série WCAP-AT1H, 5 (Dia.) x 11mm 5000h 97mA Référence fabricant : 860240672002]||839-6258|| 25 (1 sachet) || 3,90 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/condensateurs-aluminium/8399011 Condensateur électrolytique aluminium radial 47µF, -20%, 63V dc, Traversant, +105°C, WURTH série WCAP-ATUL, 8 (Dia.) x 11.5mm 7000h 360mA ESR: 0.66 Ohms Référence fabricant : 860040774002]||839-9011|| 20 (2 paquets) || 3,12 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/condensateurs-aluminium/8399033 Condensateur électrolytique aluminium 120µF, -20%, 63V dc, Traversant, +105°C, série WCAP-ATUL, 10 (Dia.) x 16mm 7000h 760mA ESR: 0.3 Ohms Référence fabricant : 860040775008]||839-9033|| 20 (4 paquets) || 3,43 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/connecteur-xlr/7259543/ Connecteur XLR femelle plastique pour chassis soudage pour CI 3 broches coudé + blindage avec louet métal, NEUTRIK NC3FAH2]||725-9543|| 2 || 1,97 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/connecteur-xlr/7259549 Connecteur XLR mâle plastique pour chassis soudage pour CI 3 broches coudé + blindage, NEUTRIK NC3MAH ]||725-9549|| 2 || 1,43 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/fusibles-cms-rearmables/5177054/ Fusible CMS réarmable, Littelfuse, 2.2A - 1.1A Référence fabricant : SMD100F-2 MK : 100F]|| 517-7054|| 10 || 0,497 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|<s>Eric</s>||<s>[https://fr.rs-online.com/web/p/roulettes-sur-platine/0819567/ Roulette Pivotante Acier 50mm, Bas profil, 270kg Fabricant : Revvo]</s>|| <s>819-567</s> || <s>4</s>|| <s>34.91 €HT</s> ||<s><acheteur></s>||<s>RS_012</s>||<s>N</s>||<s>N</s>||<s>N</s>||<s>N</s> <br />
|-<br />
|3ds||[https://fr.rs-online.com/web/p/potentiometres/0387896/ Potentiomètre carbone série 23 montage panneau 4K7 B avec interrupteur DPST, axe 6,35mm TE Connectivity ref 23ESB472MMF50AF]||387-896|| 1 || 4,14€HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Louis||[https://fr.rs-online.com/web/p/passe-fils/1366806/ Passe-fils,SES en PVC, Diamètre maximum de câble 3mm Noir ref 01070005010 ]||136-6806|| 1 sachet de 100|| 5,38€HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|}<br />
<br />
<br />
<br />
=== [http://www.stquentin-radio.com/ Saint Quentin radio]===<br />
<br />
La prochaine commande a pour référence interne SQ_002<br />
<br />
<br />
<br />
<br />
Anciennes commandes Saint Quentin Radio archivées [[Projets:Commande_groupee: Saint Quentin radio|ici]]<br />
<br />
Paiement cash par avance à l'acheteur : payez le montant exact, car il n'y a pas de frais annexes<br />
<br />
Frais de port : 0€ (sauf objets lourds) Gare du Nord<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref St Quentin!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
|-<br />
--><br />
|Lab||DOUILLE DE SECURITE 4mm ECROU BLANC, ref3265-I-9 ||326509 ||3||1.80€||<Patrick>||SQ_001||N||O||O||O<br />
|-<br />
|Lab||Fiche DIN 5BR MALE PLASTIQUE 360°||I076||2||1.00€||<acheteur>||SQ_002||N||N||N||N<br />
|-<br />
|Lab||Fiche DIN 5BR CHASSIS METAL 360°||I088||1||1.20€||<acheteur>||SQ_002||N||N||N||N<br />
|}<br />
<br />
=== [http://www.selectronic.fr Selectronic] ===<br />
<br />
La prochaine commande a pour référence interne : SE_010 <br />
<br />
<br />
<br />
<br />
Anciennes commandes Sélectronic archivées [[Projets:Commande_groupee:archives#Selectronic|ici]]<br />
<br />
Frais de port : 0€ (sauf objets lourds)<br />
<br />
Certains produits sont pas en stock à Paris et requièrent d'être livrés de Lille d'où un délai de quelques jours. Le mieux est d'aller au mag à Nation le mardi pour passer la commande et dans ce cas c'est en principe dispo jeudi sur place.<br />
<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description || Ref Sélectronic!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-<br />
|Eric||Résistance CTN 10kOhms 10% format goutte traversant||5277|| 1 || 0.95€TTC|| Eric|| SE_008 || O || O || O || O<br />
|- <br />
|lab||Résistance CTN 10kOhms 10% format goutte traversant||5277|| 1 || 0.95€TTC|| Zenos|| SE_009 || N || O || O || N<br />
|-<br />
|Zenos||triac BT139-600||4024|| 3 || 1,90€TTC|| Zenos|| SE_009 || O || O || O || O<br />
|-<br />
|Lab||TIC106D Thyristor||4018|||1||1,52||<acheteur>|| SE_009 || N || O || N (pas dispo) || N <br />
|-<br />
|Eric||IR IRF9540 MOS canal P -100V -19A||08015|||1||2,50EUR||Zenos|| SE_009 || O || O || O || O<br />
|- <br />
|Eric||Mosfet N IRF640N TO220 200V 0.150Ω - 18A||HD75-940|||2||1,94||<acheteur>|| SE_010 || N || N || N || N<br />
|-<br />
|Marc f6itu||pointes de scope||2447|||4||1,02||<acheteur>|| SE_010 || N || N || N || N<br />
|-<br />
|Lab (Eric)||[http://www.selectronic.fr/joints-adhesif-pour-enceintes.html bande mousse autocollante de largeur 5mm, hauteur 2mm]||2300|||2||5.50||<acheteur>|| SE_010 || N || N || N || N<br />
|-<br />
|}<br />
<br />
=== [http://www.sparkfun.com/ SparkFun Electronics]===<br />
<br />
La prochaine commande a pour référence interne SF_002<br />
<br />
Prochaine date de commande : N/A<br />
<br />
<br />
Commande livrée en cours de distribution : SF_001<br />
<br />
<br />
TVA, frais de port et droits de douane + frais pour dossier de dédouanement : selon taille totale de la commande finale, seront ventilés au pro-rata du montant commandé par chacun.<br />
<br />
Anciennes commandes SparkFun Electronics archivées [[Projets:Commande_groupee:archives#SparkFun Electronics|ici]]<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref SparkFun!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
|-<br />
--><br />
|Damien H||Spark Gap Igniter - 4.8V||COM-11218||3||$14,95||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Pilou||MIDI Shield||DEV-09595||1||$19,90||<Damien H>||SF_001||N||O||O||O<br />
|-<br />
|Pilou||OpenServo||ROB-09014||2||$14,95||<Damien H>||SF_001||N||O||O||O<br />
|-<br />
|Pilou||Breakout Board for PCF8575 I2C Expander||BOB-08130||1||$11,95||<Damien H>||SF_001||N||O||O||O<br />
|-<br />
|MAZ24||wire stripper||TOL-08696||1||$4,95||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|MAZ24||flush cutter||TOL-11952||1||$6,95||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Eric||Optical Dust Sensor - GP2Y1010AU0F||COM-09689||1||$11,95||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Eric||Mating Connector Housing for Dust Sensor (JST ref#: ZHR-6)||PRT-09690||2||$0,35||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Eric||Crimp Pins for Dust Sensor Connector (JST ref#: SZH-002T-P0.5)||PRT-09728||16||$0,09||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Eric||Copper Tape - 2" (50ft)||PRT-11081||1||$14,95||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Olga||RaspiRobot Board||KIT-11561||1||$29,95||<Damien H>||SF_001||N||O||N||O<br />
|-<br />
|Dom||Copper Tape - 2" (50ft)||PRT-11081||1||$14,95||||SF_002||N||N||N||N<br />
|-<br />
|Jean-Marc (PdM) || Polymer Lithium Ion Battery - 400mAh || PRT-10718 || 1 || $6.95 || || SF_002 || N || N || N ||N<br />
|-<br />
|Jean-Marc (PdM) || SparkFun USB LiPoly Charger - Single Cell || PRT-12711 || 1 || $14.95 || || SF_002 || N || N || N ||N<br />
|-<br />
|Jean-Marc (PdM) || Precision Disc Wheel - 5" (Yellow, 2 Pack) || ROB-12469 || 1 || $6.29 || || SF_002 || N || N || N ||N<br />
|-<br />
|Jean-Marc (PdM) || Set Screw Hub - 3mm Bore || ROB-12512 || 2 || $4.99 || || SF_002 || N || N || N ||N<br />
|-<br />
|Jean-Marc (PdM) || ProtoBoard - Square 2" || PRT-08811 || 1 || $2.95 || || SF_002 || N || N || N ||N<br />
|-<br />
|Jean-Marc (PdM) || Micro Gearmotor - 90 RPM (6-12V) || ROB-12285 || 2 || $12.95 || || SF_002 || N || N || N ||N<br />
|- <br />
|Jean-Marc (PdM) || SparkFun Solderable Breadboard - Mini || PRT-12702 || 1 || $2.95 || || SF_002 || N || N || N ||N<br />
|- <br />
|}<br />
<br />
=== Subtel.fr ===<br />
<br />
Pas de frais de port, prix TVA comprise<br />
<br />
<br />
<br />
<br />
Anciennes commandes Subtel.fr archivées [[Projets:Commande_groupee:archives|ici]]<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Subtel!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Archive (O/N)<br />
|-l<br />
|-<br />
|}<br />
<br />
=== raspberry-pi-zero ===<br />
Une opportunité dégotée par Francis: une version du raspberry-pi, un peu spartiate, pour 5 euros!<br />
https://www.raspberrypi.org/blog/raspberry-pi-zero/<br />
<br />
On peut également acheter le kit: http://swag.raspberrypi.org/collections/pi-kits/products/pi-zero-cables<br />
C'est le cordon midi-hdmi/hdmi, PLUSSE la barrette gpio.<br />
<br />
Cette entrée est mise en place alors que tout n'est pas défini pour cet achat: ni le fournisseur (fournisseur initial en rupture de stock), ni le prix.<br />
Mais ce sera le support pour rassembler les commandes. Je tiendrai ce paragraphe à jour selon les infos.<br />
<br />
Le kit comprend l'adaptateur micro-hdmi/hdmi (1 cordon + 1 petit adaptateur?), et la barette 2x20, à souder, pour les gpio. Le raspberry n'est pas dans le kit!<br />
<br />
Le prix: 5 euros le kit, idem le raspberry, et quelques pourcent pour les frais de transport. <br />
<br />
(ce soir: site http://swag.raspberrypi.org/ down; ??)<br />
<br />
<br />
On peut aussi attendre 3 semaines le temps que cela soit livré directement chez vous et avoir<br />
<br />
- l'adaptateur micro hdmi mâle- hdmi femelle : http://www.banggood.com/Gold-Plated-Micro-HDMI-Type-D-Male-To-HDMI-Female-Adapter-p-974265.html<br />
<br />
- un adaptateur micro-hdmi vers VGA femelle sans le son : http://www.banggood.com/1080P-HDMI-Male-To-VGA-Female-Adapter-Video-Converter-Cable-p-937626.html<br />
<br />
- un adaptateur micro-hdmi vers VGA femelle avec le son : http://www.banggood.com/Sin-Hon-SH-MH2V02-Micro-HDMI-to-VGA-Cable-Adapter-with-Audio-p-907524.html<br />
<br />
- un adaptateur micro usb coudé(pratique pour ranger sur le côté : http://www.banggood.com/Micro-USB-Host-OTG-Cable-For-Samsung-HTC-p-79909.html<br />
<br />
- pour se faire une prise alim micro usb, on déboîte le capot et on soude : http://www.banggood.com/USB-2_0-Micro-B-Male-to-Mini-B-Female-5-Pins-Adapter-p-956044.html<br />
<br />
- toutes sortes d'alim : http://www.banggood.com/search/usb-2a-charger.html<br />
<br />
- de quoi s'amuser avec les GPIO : http://www.banggood.com/search/gpio-raspberry/1091-0-0-0-0-0-0-price-0-0_p-1.html<br />
<br />
Et si vous avez le temps de chercher c'est encore moins cher sur http://fr.aliexpress.com/<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| raspberry ou kit !! class="unsortable"| Quantité !! class="unsortable"| Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Archive (O/N)<br />
|-l<br />
|-<br />
!Pierre Grommit !!raspb !! 2 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!Pierre Grommit !!kit !! 1 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!Francis Roussel !!rasp !! 2 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!papy F1CHF !!kit !! 4 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!PDA !!rasp !! 3 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!yvs Accard !!rasp !! 3 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!yvs Accard !!Kit !! 1 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!Malek H. !!3 rasp + 2 vga son + 1 gpio + 1 otg !! 1 !! 1 !! n!! n !!n !! n!!<br />
<br />
<br />
|}<br />
<br />
<br />
=== Starterkit FPGA Altera Max10 ===<br />
'''COMMANDE CLOSE'''<br />
<br />
[https://www.arrow.com/en/products/bemicromax10/arrow-development-tools#page-1 Carte de démarrage FPGA] qui sera parfait pour les [[Formations#Initiation_.C3.A9lectronique_num.C3.A9rique_et_FPGA|formation initiation à venir]].<br />
<br />
Cette carte utilise un FPGA entrée de gamme MAX 10 de chez Altera. Elle contient tout un tas de périphériques sympa pour débuter.<br />
<br />
A noter que la board intègre une sonde JTAG Altera Blaster II (>200€ dans le commerce, 20€ pour un clone).<br />
<br />
Le prix: $30 le kit, disons donc 30€ (à réajuster à la baisse post commande). <br />
<br />
Date butoir pour la commande: mercredi 6 avril 2016<br />
<br />
Chip principal: MAX® 10 FPGA (10M08DAF484C8G):<br />
* 8,000 LEs (largement de quoi mettre le soft core 32bit Altera & des périphériques confortables)<br />
* 414 Kbit (Kb) M9K memory<br />
* 256 Kbit (Kb) user flash memory<br />
* 2 phase locked loops (PLLs)<br />
* 24 18x18-bit multipliers<br />
* 1 ADC block – 1 MSa/sec, 12-bit, 18-channels<br />
* 17 analog inputs<br />
* 1 temperature sense diode<br />
* 250 general purpose input/output (GPIO)<br />
* Non-volatile self-configuration with dual-boot support<br />
* Clocking circuitry: 50 MHz oscillator and 24 MHz oscillator<br />
* achetable à l'unité (moins cher de la gamme: 3€, celui ci, 30€)<br />
<br />
External peripherals<br />
* 8MB SDRAM (4Mb x 16) (ISSI IS42S16400)<br />
* Accelerometer, 3-Axis, SPI interface (Analog Devices ADXL362)<br />
* DAC, 12-bit, SPI interface (Analog Devices AD5681)<br />
* Temperature sensor, I2C interface (Analog Devices ADT7420)<br />
* Thermal resistor<br />
* Photo resistor<br />
* 8 user LEDs<br />
* 2 user Pushbuttons<br />
<br />
Prototyping<br />
* Two 6-pin PMOD expansion headers<br />
* Two 40-pin prototyping headers which provide access to 64 digital I/O<br />
* 6 analog inputs<br />
* One 80-pin BeMicro card edge connector<br />
<br />
<br />
Merci d'ajouter votre nom et votre rapport à l'éventualité de formations au lab:<br />
* débutant, intermédiaire, expert: sous entendu je veux assister à une formation & j'ai ce niveau<br />
* formateur: je suis volontaire pour participer à l'élaboration de formations<br />
* pas intéressé: ni en participant ni en formateur<br />
<br />
Merci d'indiquer:<br />
* combien vous en achetez à titre perso (30€ pièce, à revoir selon le change & port)<br />
* si vous voulez en prendre une à offrir aux formations du lab (vous payez 20€, moi 10€ ; il nous faut 10 cartes)<br />
<br />
<br />
'''MISE A JOUR RECEPTION'''<br />
Prix total 40€/carte. 25€ par carte offerte au lab. Merci de vous mettre à jour, et venez récupérer vos cartes auprès de Coline :)<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Formation? !! class="unsortable"| Quantité !! class="unsortable"| cadeau au lab !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Archive (O/N)<br />
|-l<br />
|-<br />
|-<br />
!flax !!formateur!! 1 !! non !! O!! n !!n !! n!!<br />
|-<br />
!flax !!formateur!! 1 !! oui !! O!! n !!n !! n!!<br />
|-<br />
!Clem !!formateur!! 1 !! N/A !! O!! n !!n !! n!!<br />
|-<br />
!3dsman!!débutant !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
!3dsman!!débutant !! 1 !! oui !! n!! n !!n !! n!!<br />
|-<br />
!Yann D!!débutant !! 2 !! non !! n!! n !!n !! n!!<br />
|-<br />
!Yannick A.!!formateur !! 1 !! oui !! n!! n !!n !! n!!<br />
|-<br />
!Yannick A.!!formateur !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
!F1HSU!!débutant !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
!Roul!!formateur? !! 1 !! oui !! n!! n !!n !! n!!<br />
|-<br />
!Roul!!formateur? !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
!Jojo du VoLAB !!intermédiaire !! 2 !! non !! n!! n !!n !! n!!<br />
|-<br />
!Jojo du VoLAB !!intermédiaire !! 1 !! oui !! n!! n !!n !! n!!<br />
|-<br />
!MrPozor !!débutant !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
!Julien Len!!débutant !! 1 !! oui? !! n!! n !!n !! n!!<br />
|-<br />
!Julien Len!!débutant !! 1 !! non!! n!! n !!n !! n!!<br />
|-<br />
!Jérôme Loï!! débutant !! 1? !! oui !! O(payé 30)!! n !!n !! n!!<br />
|-<br />
!Jérôme Loï!! débutant !! 1 !! non!! O!! n !!n !! n!!<br />
|-<br />
!Moala!!débutant !! 1 !! non !! O!! n !!n !! n!!<br />
|-<br />
!Desty!!debutant !! 1 !! oui !! n!! n !!n !! n!!<br />
|-<br />
!Desty!!debutant !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
<br />
!Votre nom!!type !! nombre !! oui/non !! n!! n !!n !! n!!<br />
<br />
<br />
<br />
|}<br />
Nombre de cartes total: 23 dont lab: 8 (total à mettre à jour !)</div>Erichttps://wiki.electrolab.fr/Projets:Commande_groupeeProjets:Commande groupee2018-09-17T10:22:42Z<p>Eric: /* Radiospares (RS Composants) */</p>
<hr />
<div>=Commandes groupées=<br />
<br />
== Principe ==<br />
Tout projet a régulièrement besoin de matières premières, composants, fournitures diverses, etc. Le lab a en stock une quantité importante de fournitures plus ou moins courantes, mais cela ne peut remplacer des commandes régulières.<br />
<br />
Histoire de mutualiser les bons plans & regrouper les frais de port, profiter de divers price breaks, etc, cette page a été créee pour organiser des commandes groupées.<br />
<br />
== Glossaire ==<br />
===Demandeur===<br />
Celui qui a besoin d'un article<br />
<br />
===Acheteur===<br />
Celui qui passe effectivement la commande chez le Fournisseur. L'Acheteur peut être le lab ou une personne privée.<br />
Dans le cas du lab indiquer dans la colonne "acheteur" lab_<nom/pseudo membres> exemple : lab_peewee<br />
Sauf avis contraire, le paiement est à effectuer sur le compte paypal du lab.<br />
<br />
Dans le cas d'une personne privée, indiquer dans la colonne "acheteur", son nom ou pseudo.<br />
L'Acheteur définit lui même les moyens de paiement à utiliser par les <demandeurs>.<br />
<br />
<br />
===Distributeur===<br />
Fournisseur ou fabricant chez qui l'<acheteur> passe commande.<br />
Chaque <distributeur> dispose d'une rubrique propre.<br />
<br />
Il est bien entendu possible d'ajouter des <distributeurs> supplémentaires (notez qu'ils sont triés par '''ordre alphabétique''').<br />
<br />
== Règles du jeu ==<br />
<br />
En général, lorsque l'on s'occupe d'un "group buy", on fait un premier tour de<br />
table pour savoir qui est partant, on annonce ensuite le prix de l'addition<br />
générale (TTC et frais d'expé avec ou sans assurance, éventuels frais de<br />
dédouanement) divisée par le nombre de participants (au prorata des volumes<br />
de commande : celui qui achète 2 items paye 2 parts de frais de port par<br />
exemple).<br />
<br />
Ceci fait, on attend qu'une "masse critique" soit atteinte lorsque l'on vise<br />
certains "price break" (décollonage en jargon de vendeur), puis on lance<br />
l'appel aux fonds avec une date butoir. Passé la date butoir, la commande<br />
est passée, en ignorant ceux qui n'ont pas répondu a temps, puisque le<br />
responsable de group buy n'a pas la trésorerie correspondant à l'achat en<br />
question.<br />
Les histoires genre "le chèque est au courrier" ne marchent pas avec des<br />
virements Paypal... le patron des achats sait exactement combien il a en<br />
caisse au moment de la commande.<br />
<br />
En cas de perte de colis, le responsable de "group buy" n'est pas<br />
redevable. C'est à chaque participant d'estimer s'il prend le risque ou non<br />
de faire confiance aux entreprises assurant l'acheminement des colis.<br />
C'est simple, et si c'est précisé, aucun conflit n'est à redouter, aucun lot<br />
ne reste sur les bras de l'<acheteur>.<br />
<br />
Pour le paiement par avance, celui-ci peut se faire au lab, mais c'est TTC et AVEC les frais de port et de douane, le cas échéant.<br />
<br />
Si un <demandeur> commande la mauvise référence, c'est pour sa pomme.<br />
<br />
Dans la mesure du possible, les <demandeur> doivent faciliter au maximum le travail des <acheteur> en indiquant des références d'articles et de désignation claires.<br />
<br />
==Mode opératoire lorsqu'on passe une commande chez l'un des distributeurs ==<br />
Les tableaux ci-après (un tableau par <distributeur> disposent des colonnes nécessaires à la synchronisation des commandes article par article.<br />
<br />
De même, chaque rubrique dispose d'un en-tete d'information qui a la structure suivante :<br />
<br />
La prochaine commande a pour référence interne : YY_xxx<br />
Commande livrée en cours de distribution : [aucune]<br />
Anciennes commandes <nom du distributeur> archivées [[Projets:Commande_groupee:archives|ici]]<br />
< informations complémentaires notamment en ce qui concerne les conditions de livraison, etc>''<br />
<br />
YY est un code fixe, unique pour chaque founisseur.<br />
<br />
xxx un le n° de commande pour ce distributeur. Il commence à 001 et s'incrémente à chaque commande.<br />
<br />
<br />
===Les différentes étapes de la commande ===<br />
<br />
====Prise en charge d'un commande par un <acheteur>==== <br />
La personne qui souhaite prendre en charge une commande chez un <distributeur> envoie un mail sur la ML pour informer tout le monde de cette action.<br />
Dans l'entête d'information du <distributeur> concerné, l'<acheteur> effectue les modifications suivantes :<br />
*mise à jour de la ligne ''Prochaine date de commande'' : valorisé à la date à laquelle il envisage de passer la commande auprès du <distributeur>. <br />
<br />
À ce moment, l'ensemble des <demandeurs> concernés se met en relation avec l'<acheteur> pour lui payer d'avance les articles commandés. Pour ces articles, l'<acheteur> fait les modifications suivantes dans le tableau des articles :<br />
*''Payé d'avance (O/N)'' : valorisé à "O" (Oui)<br />
<br />
<br />
====Passage effective de la commande par l'<acheteur>==== <br />
<br />
Celui qui passe la commande ( = <acheteur>) sélectionne les articles qu'il commande effectivement (= ceux pour lesquels il a reçu le paiement en avance). Il peut aussi inclure dans la commande des articles de <demandeurs> pour leuquel il est certain d'être payé au moment de la distribution.<br />
<br />
L'<acheteur> passe la commande auprès du distributeur (par internet, mail, téléphone, télécopie, signaux de fumée, déplacement sur place...) et effectue le paiement à l'aide d'un moyen de paiement à sa convenance. Il est judicieux de priviléger des moyens de paiement fournissant la traçabilité de la transaction.<br />
<br />
Pour les articles effectivement COMMANDÉS l'<acheteur> fait les modifications suivantes dans le tableau des articles :<br />
*'' Acheteur'' : valorisé par son nom/pseudo <br />
*''Commandé (O/N)'' : valorisé à "O" (Oui)<br />
<br />
Pour les articles qui n'ont pas déja été concernés par une commande précédente et que l'<acheteur> ne COMMANDE PAS (par exemple par ce que le <demandeur> ne s'est pas manifesté auprès de lui), il fait les modifications suivantes dans le tableau des articles :<br />
*''N° de commande'' : est incrémenté d'une unité afin que cet article non commandé soit inclus dans la prochaine commande.<br />
<br />
<br />
*mise à jour de la ligne ''Prochaine date de commande'' : valorisé à <non défini><br />
*mise à jour de la ligne ''La prochaine commande a pour référence interne'' : valorisé au numéro de commande interne actuel +1 <br />
*mise à jour de la ligne ''Commande passée en attente de livraison'': valorisé au n° de commande actuel<br />
<br />
====Réception de la commande par l'<acheteur>==== <br />
<br />
<br />
Au moment de la réception du colis, l'<acheteur> vérifie si la livraison est complète et négocie avec le <distributeur> en cas de problème. Il peut aussi informer le <demandeur> concerné par le ou les article(s) en litige ou manquants.<br />
<br />
====Distribution des articles aux <demandeurs>====<br />
Lorsque la distribution peut commencer l'<acheteur> effectue les modifications suivantes dans l'entête d'information du <distributeur> concerné :<br />
*mise à jour de la ligne : '' Commande passée en attente de livraison'' à [aucune]<br />
*mise à jour de la ligne : '' Commande livrée en cours de distribution '' avec la référence interne de la commande.<br />
<br />
L'<acheteur> informe via la ML les <demandeurs> du début de la distribution de la commande <référence interne de commande>.<br />
Chaque <demandeur> convient d'un RDV avec l'<acheteur> pour récupérer les articles (en principe cela se passe au lab) et payer son dû à l'<acheteur>, si ce n'est déja fait.<br />
<br />
Pour chaque article l'<acheteur> fait les modifications suivantes dans le tableau des articles :<br />
*'' Distribué (O/N)'' : valorisé à "O" (Oui) <br />
*''Remboursé/Archivé (O/N)'' : valorisé à "O" (Oui)<br />
<br />
====Ditribution des articles terminée====<br />
<br />
Une fois l'ensemble des pièces distribuées et payées, dans l'entête d'information du <distributeur> concerné, l'<acheteur> effectue les modifications suivantes :<br />
*mise à jour de la ligne ''Commande livrée en cours de distribution'' : valorisé à [aucune]<br />
<br />
<br />
===En conclusion ===<br />
<br />
Si les tableaux des commandes et les en-tête d'information sont gérés avec soin, il n'y a quasiment aucun risque de double commande et n'importe quel membre sait où on en est et peut à tout moment prendre la main sur l'un des tableaux d'achats pour commander un article ou organiser une commande en tant qu'<acheteur>. La bonne application de ces quelques recommandation bénéficie à l'ensemble des participants de ce système de commandes groupées.<br />
<br />
Sauf besoin urgent de pièces, il est bénéfique que ce soit de préférence les mêmes <acheteurs> qui officient auprès des mêmes <distributeurs>. Ainsi, vu de ces derniers, l'<acheteur> est très vite identifié comme "client important" (car en réalité il commande pour 5-10 personnes, voire plus) et peut bénéficier de conditions particulières (frais de port gratuit, -15% sur la prochaine commande, etc).<br />
<br />
Enfin, à tout moment en tant que <demandeur>, soyez diligent envers l'<acheteur> dont la gestion d'une commande de parfois plusieurs dizaines d'articles requert un investissement en temps non négligeable.<br />
<br />
== Commandes groupées passées (archives) ==<br />
<br />
Afin d'améliorer la lisibilité nous avons regroupé les commandes passées sur cette page: [[Projets:Commande_groupee:archives]]<br />
<br />
== Commandes groupées en cours ==<br />
<br />
=== BHV ===<br />
<br />
La prochaine commande a pour référence interne : BH_003<br />
<br />
<br />
<br />
<br />
Anciennes commandes BHV archivées [[Projets:Commande_groupee:archives#BHV|ici]]<br />
<br />
achat sur place<br />
<br />
{|class="wikitable sortable" style="font-size:85%"<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref BHV!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| Lab|| Réglet métallique 30cm || - || 3 || 5.90€||Eric|| BH_001 || N || O || O || O<br />
|-<br />
|-<br />
| Lab|| Scie a métaux FACOM 603E || - || 1 || env. 36€||Eric|| BH_002 || N || O || 0 || O<br />
|-<br />
|-class="sortbottom"<br />
|}<br />
<br />
=== [http://www.visseriefixations.fr/ Cergy-Vis] ===<br />
<br />
<br />
La prochaine commande a pour référence interne : CV_002<br />
<br />
<br />
<br />
<br />
Anciennes commandes Cergy-Vis archivées [[Projets:Commande_groupee:archives|ici]] <br />
<br />
Retrait gratuit sur place<br />
CERGY-VIS<br />
<br />
17, Rue du Périgord<br />
<br />
ZI des Béthunes<br />
<br />
95310 SAINT OUEN L’AUMONE<br />
<br />
<br />
Horaires pour les enlèvements: Du Lundi au Vendredi, de 7h30 à 12h00 et de 13h30 à 17h30.<br />
<br />
<br />
Livraison<br />
Colissimo Régional (0.05kg / France) 5,75 €<br />
<br />
Colissimo Régional (0.2888kg / France) 6,54 €<br />
<br />
Colissimo Régional (2.87kg / France) 9,25 €<br />
<br />
Colissimo Régional (12.8948kg / France) 16,50 €<br />
<br />
Anciennes commandes Cergy-Vis archivées [[Projets:Commande_groupee:archives#Cergy-Vis|ici]]<br />
<br />
<br />
|-<br />
!Demandeur !! class="unsortable"| Description !! Référence!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-<br />
||Eric|| TRCC M5X30 INOX A2 DIN 603|| ||50||0.17EURTTC||<acheteur>||CV_001||N||O||O||N (attends remb. trop versé)<br />
|-<br />
||Eric|| ECROU HU M12 PAS 100 Z.BLANC DIN 934|| ||20||0.39EURTTC||<acheteur>||CV_001||N||O||O||N (attends remb. trop versé)<br />
|-<br />
||Eric||Vis TCHC M5X22 INOX A2 EF DIN 912||TCHC05/022A2EF||15||0.12EURTTC||<acheteur>||CV_002||N||N||N||N<br />
|-<br />
||Eric||Vis STHC PLAT M6X12 INOX A2 DIN 913||STHCPLA06/012A2||30||0.06EURTTC||<acheteur>||CV_002||N||N||N||N<br />
|-<br />
||Eric||Vis TH M6X12 INOX A2 EF DIN 933||TH06/012A2EF||30||0.09EURTTC||<acheteur>||CV_002||N||N||N||N<br />
|-<br />
|}<br />
<br />
=== [http://www.conradpro.fr Conrad Electronique France] ===<br />
<br />
<br />
La prochaine commande aura pour référence interne : CO_017<br />
<br />
Prochaine date de commande :<br />
<br />
Commande passée en attente de livraison : NEANT<br />
<br />
Commande livrée en cours de distribution : NEANT<br />
<br />
Anciennes commandes Conrad Electronique France archivées [[Projets:Commande_groupee:archives#Conrad Electronique France|ici]]<br />
<br />
{| class="wikitable sortable" style="font-size:85%"<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Conrad!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€ ||<Acheteur>|| CO_XXX || N || N || N || N<br />
|-<br />
--><br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/822746/Fil-de-soudure-pour-PVC-rigide-Steinel-073114-26-pcs Fil de soudure pour PVC rigide Steinel 073114 26 pcs]</s>||<s>822746 - 62 </s>||<s> 1 </s>||<s> € 5.99 TTC</s>||<s><acheteur> </s>||<s> CO_014 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/492161/Soudure-plastique-225-mm-4-mm-polythylne-LDPE-nature-Bosch-1609201811 Soudure plastique, 225 mm, 4 mm, polyéthylène (LDPE) nature Bosch 1609201811]</s>||<s>492161 - 62 </s>||<s> 1 </s>||<s> € 15.99 TTC</s>||<s> <acheteur> </s>||<s> CO_014 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/121588/Solution-de-conservation-pour-electrodes-de-mesure-pH-HI-70300M Solution de conservation pour électrodes de mesure pH HI 70300M]</s>||<s>121588 - 62 </s>||<s> 1 </s>||<s> € 15.12 TTC</s>||<s> <acheteur> </s>||<s> CO_014 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/121586/Solution-de-nettoyage-pour-electrodes-pH-HI-7061M Solution de nettoyage pour électrodes pH HI 7061M]</s>||<s>121586 - 62 </s>||<s> 1 </s>||<s> € 15.12 TTC</s>||<s> <acheteur> </s>||<s> CO_014 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|Eric||[http://www.conrad.fr/ce/fr/product/121164/Sol-de-conduct-12880-S-HI-70030-P Sol. de conduct. 12880 µS HI 70030 P]||121164 - 62 || 1 || € 38.30 TTC|| <Pat> || CO_014 || N || O || O || O<br />
|-<br />
|Eric||[http://www.conradpro.fr/ce/fr/product/822188/Knipex-Pinces-pour-circlips-pour-colliers-dtranglement-darbre-46-11-G0-140-mm?ref=searchDetail Pince KNIPEX 46 11 G0]||822188 - 62 || 1 || € 20.13 HT|| <Pat> || CO_014 || N || O || O || O<br />
|-<br />
|Eric||[http://www.conradpro.fr/ce/fr/product/822189/Knipex-Pinces-pour-circlips-pour-colliers-dtranglement-darbre-46-11-G1-140-mm?ref=searchDetail Pince KNIPEX 46 11 G1]||822189 - 62 || 1 || € 13.02 HT|| <Pat> || CO_014 || N || O || O || O<br />
|-<br />
|MrPozor||[http://www.conrad.fr/ce/fr/product/702246/Interrupteur-de-porte-Panasonic-AZC11113HJ-250-VAC-5-A-poussoir-momentan-IP40-1-pcs?ref=searchDetail Interrupteur de porte Panasonic AZC11113HJ]||702246 - 62 || 1 || € 10.99 TTC|| <Pat> || CO_014 || N || O || N || N<br />
|-<br />
| papy F1CHF || 74HC390 SOIC || 1115010-62 || 10 || 1.06€ ||<Pat>|| CO_014 || O || O || O || O<br />
|-<br />
| Pat|| Condo moteur 5uF 450V || 441527-62 || 1 || 6.33€ H.T. ||<Pat>|| CO_014 || O || O || N || N<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/731484/Adaptateur-avec-fiche-dor-32-A-rouge-MultiContact-240160-22 Adaptateur avec fiche doré 32 A rouge MultiContact Ref. 24.0160-22]|| 731484 - 62 || 2 || 3.00 € H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/731559/Disque-de-marquage-couleur-MultiContact-145010-vert-jaune-1-pcs Disque de marquage couleur MultiContact Ref. 14.5010 vert-jaune 1 pc(s)]|| 31559 - 62 || 3 || 0.75 € H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/106109/Pointe-de-touche-de-scurit-MultiContact-XMA-7L-enfichable-4-mm-CAT-IV-1000-V-bleu Pointe de touche de sécurité MultiContact XMA-7L enfichable 4 mm CAT IV 1000 V bleu Ref. MC 66.9509-23]|| 106109 - 62 || 1 || 15.96 € H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/106108/Pointe-de-touche-de-scurit-MultiContact-XMA-7L-enfichable-4-mm-CAT-IV-1000-V-rouge Pointe de touche de sécurité MultiContact XMA-7L enfichable 4 mm CAT IV 1000 V rouge Ref. MC 66.9509-22]|| 106108 - 62 || 1 || 15.96 € H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/106107/Pointe-de-touche-de-scurit-MultiContact-XMA-7L-enfichable-4-mm-CAT-IV-1000-V-noir Pointe de touche de sécurité MultiContact XMA-7L enfichable 4 mm CAT IV 1000 V noir Ref. MC 66.9509-21]|| 106107 - 62 || 1 || 15.96 € H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/1385649/Pince-crocodile-4-mm-GRIP-FMA-MultiContact-669435-21 Pince crocodile 4 mm GRIP-FMA MultiContact Ref. 66.9435-21]|| 1385649 - 62 || 1 || 30.00€ H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Damien H || MOSFET RFD14N05L || 512-RFD14N05L || 5 || 0,695 € ||?|| CO_015 || N || O || O || O<br />
|-<br />
| Damien H || Zener BZX79C2V4 || 512-BZX79C2V4 || 5 || 0,11 € ||?|| CO_015 || N || O || O || O<br />
|-<br />
|Pierre G|| Câble audio SpeaKa 1m mf||986736 - 62 || 2||6,66 ht || ? || CO_015 || N || O || O || O<br />
|-<br />
|Pierre G|| Câble audio SpeaKa 0,50m mf||986735 - 62 || 1||5.92 ht || ? || CO_015 || N || O || O || O<br />
|-<br />
|Pierre G|| Lentille Dialight OPC-11SPOT transparent 10 ° 1 pc(s)||1127266 - 62 || 1||3 ht || ? || CO_016 || N || O || O || O<br />
|-<br />
|Pierre G|| LED High Power Barthelme 61003528 blanc chaud||1503528 - 62 || 1||3,50 ht || ? || CO_016 || N || O || O || O<br />
|-<br />
|FredericD|| [http://www.conrad.fr/ce/fr/product/574223/Transformateur-electronique-Standard-10-a-60-W Transformateur électronique "Standard" 10 à 60 W]||574223 - 62 || 1||15,49 '''TTC''' || <acheteur> || CO_017 || N || N || N || N<br />
|-<br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/542044/?insert=32&insertNoDeeplink&productname=Gaine-thermoretractable-pour-batteries-sans-colle-21-Conrad-Components-542044-transparent-avant-retreint-44-mm-1-pc Gaine thermorétractable 2:1 transparente pour accus longueur 100 cm largeur 44mm]</s>||<s>542044 - 32</s>||<s>3</s>||<s>2,70€TTC</s>||<s> <acheteur> </s>||<s> CO_017 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/100297/Solution-conductrice-1413-S-HI-70031-P?ref=list Solution conductrice 1413 µS HI 70031 P]</s>||<s>100297 - 62 </s>||<s> 1 </s>||<s> € 33,60 TTC</s>||<s> <acheteur> </s>||<s> CO_017 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|<s>Eric</s>||<s>[http://www.conradpro.fr/ce/fr/product/1305022/Diode-Zener-PanJit-1N4740A-G-DO-41G-Tension-Zener-10-V-1-pcs?ref=searchDetail Diode Zener PanJit 1N4740A-G DO-41G Tension Zener: 10 V]</s>||<s>1305022 - 62 </s>||<s> 10 </s>||<s> € 0,15 TTC</s>||<s> <acheteur> </s>||<s> CO_017 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/812811/tain-de-soudure-teneur-en-plomb-Stannol-HS-10-Sn60Pb39Cu1-bobine-100-g-10-mm?queryFromSuggest=true étain 100g 1mm STANNOL]|| 812811 - 62 || 2 || 7,55 € H.T. ||<acheteur>|| CO_017 || N || N || N || N<br />
|-<br />
|Eric||[http://www.conrad.fr/ce/fr/product/651105/XLR-Bride-mle-contacts-couds-Neutrik-NC3MAAH-Nombre-de-ples-3-noir-1-pcs?queryFromSuggest=true Connecteur XLR mâle plastique pour chassis soudage pour CI 3 broches coudé + blindage, NEUTRIK NC3MA(A)H ]||651105 - 62|| 2 || 1,20€TTC ||<acheteur>||CO_017||N||N||N||N <br />
|-<br />
|}<br />
<br />
Anciennes commandes Conrad archivées [[Projets:Commande_groupee:archives#Conrad_Electronique_France|ici]]<br />
<br />
=== [http://www.damencnc.com/fr DamenCNC] ===<br />
<br />
Accessoires pour machines CNC [http://www.damencnc.com]<br />
<br />
La prochaine commande a pour référence interne : DC_002<br />
<br />
Prochaine date de commande : ?? (probablement en octobre 2014)<br />
<br />
<br />
Commande livrée en cours de distribution : [aucune] <br />
<br />
Livraison : depuis les Pays-Bas par UPS : estimation : 20€ pour un colis de 1.5kg<br />
<br />
ATTENTION : Prix HT.<br />
<br />
Anciennes commandes DamenCNC archivées [[Projets:Commande_groupee:archives#DamenCNC|ici]]<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref DamenCNC!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
<!-- Pour ajouter une ligne, copier les 2 lignes suivantes (celles qui commencent par | ) à la suite du tableau et remplacer le contenu des colonnes par ce qui semblera adéquat<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||<Acheteur>|| OT_XXX || N || N || N || N<br />
|-<br />
--><br />
|-<br />
|Goldo|| HIWIN HGR Profile Rail L=200mm || HG15R || 2 || 21,60€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|Goldo|| HIWIN Carriage HGH "Compact type" || HGH-15CA || 2 || 33.99€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|Goldo|| Mini Mill 2 flutes 0.20mm || ? || 1 || 11.99€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|Goldo|| Mini Mill 2 flutes 0.30mm || ? || 1 || 11.99€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|Goldo|| Mini Mill 2 flutes 0.50mm || ? || 1 || 9.99€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|Goldo|| Kress Collet + Clamp Nut 1/8inch || ? || 1 || 19.99€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|F1CHF|| Mini Mill 2 flutes 0.50mm || ? || 2 || 9.99€HT || Goldo || DC_001 || N || O || O || O<br />
|-<br />
|F1CHF|| Mini Mill 2 flutes 0.70mm || ? || 2 || 9.99€HT || Goldo || DC_001 || N || O || O || O<br />
|-<br />
|Eric||IPS_Cable_Assembly M12_Straight_Female/OPENEND_3meter || ? || 2 || 4.99€HT || <acheteur>|| DC_002 || N || N || N || N<br />
<br />
! !! !! !! !! !! !! !! !! !! !!<br />
|}<br />
<br />
===[http://www.detandt.com/fr Detandt-Simon]===<br />
<br />
La prochaine commande aura pour référence interne : DET_001 <br />
<br />
Prochaine date de commande : Mardi 2/2/2016<br />
<br />
<br />
Commande livrée en cours de distribution : [nada] <br />
<br />
Anciennes commandes Detandt archivées [nope]<br />
<br />
Frais de livraisons: inconnu<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Taille !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!!Remboursé/Archive (O/N)<br />
|-<br />
<!-- Pour ajouter une ligne, copier les 2 lignes suivantes (celles qui commencent par | ) à la suite du tableau et remplacer le contenu des colonnes par ce qui semblera adéquat--><br />
| Steve|| Modèle haut Bleu et gris || Taille 44 || 1|| 15€ HT||Steve|| DET_001 || N || N || N || N<br />
|-<br />
| Steve|| Modèle haut Bleu et gris || Taille 45 || 1|| 15€ HT||Steve|| DET_001 || N || N || N || N<br />
|-<br />
| Laurent d. Lo^2 || Modèle haut orange et noir || Taille 44 || 1|| 15€ HT||Laurent|| DET_001 || N || N || N || N<br />
|-<br />
| Laurent d. Lo^2 || Modèle cuir noir || Taille 44 || 1|| 15€ HT||Laurent|| DET_001 || N || N || N || N<br />
|-<br />
| Beatrice/LK999 || Modèle cuir noir ou bas || Taille 45|| 1|| 15€ HT||XXX|| DET_001 || N || N || N || N<br />
|-<br />
| Le Xav || Modèle noir & orange haut || Taille 45|| 1|| 15€ HT||XXX|| DET_001 || N || N || N || N<br />
|-<br />
| Patrick|| 10m gaine VMC alu D80 M0|| HALUM0 82|| 2|| 13,78€ HT||XXX|| DET_002 || N || N || N || N<br />
|-<br />
| Patrick|| 10m gaine VMC alu D125 M0|| HALUM0 127|| 1|| 15,96€ HT||XXX|| DET_002 || N || N || N || N<br />
|-<br />
|}<br />
<br />
===[http://www.digikey.com/ Digikey Corporation]===<br />
<br />
La prochaine commande aura pour référence interne : DI_006<br />
<br />
Prochaine date de commande : <non défini><br />
<br />
Commande passée en attente de livraison : DI_005 <br />
<br />
Commande livrée en cours de distribution : NEANT <br />
<br />
Anciennes commandes Digikey Corporation archivées [[Projets:Commande_groupee:archives#Digikey Corporation|ici]]<br />
<br />
"PAS DE FRAIS POSTAUX sur toutes commandes avec une valeur de 65 Euro et plus.mais la DOUANE + frais"<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Digikey !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!!Remboursé/Archive (O/N)<br />
|-<br />
| Laurent(C) || Capa 470uF || 493-1493-ND || 24 || 0,229€||Laurent(C)|| DI_005 || || O || N || N<br />
|-<br />
| Laurent(C) || Carte NUCLEO-F303K8 || 497-15981-ND || 1|| 9,92€||Laurent(C)|| DI_005 || || O || N || N<br />
|-<br />
| Laurent(C) || Capa tantale 10uF || 478-8959-1-ND || 5|| 0.8€||Laurent(C)|| DI_005 || || O || N || N<br />
|-<br />
| Laurent(C) || PMIC 4V || MCP1702T-4002E/CBCT-ND|| 5|| 0.43€||Laurent(C)|| DI_005 || || O || N || N<br />
|-<br />
| Eric||[http://www.digikey.fr/product-search/fr?vendor=0&keywords=LT1677CS8%23PBF-ND LT1677 OPAMP S8 Package]|| LT1677CS8#PBF-ND || 4|| 3.95€||Laurent(C)|| DI_005 || O || O || N || N<br />
|-<br />
| Eric|| [http://www.digikey.com/product-detail/en/4664-6001/MPK64K-ND/138341 connecteur HE10 64 broches autodénudant mâle] || MPK64K-ND || 1|| 12.59€||Laurent(C)|| DI_005 || O || O || O || O<br />
|-<br />
| Eric|| [http://www.digikey.fr/product-detail/fr/DS2740U%2B/DS2740U%2B-ND/1197488 MAXIM coulombmetric counter DS2740U+ SMD]|| DS2740U+-ND || 1|| 3.90€||Laurent(C)|| DI_005 || O || O || O || O<br />
|-<br />
| Eric|| C190 case ||614-1102-ND||1||199,99USD||Laurent(C)|| DI_005 || O || N(export restriction!) || N || O<br />
|-<br />
| papy F1CHF || NB3N502 || NB3N502DGOS-ND ||4||2.99€||Laurent(C)|| DI_005 || N || O || O || O<br />
|-<br />
| Eric|| [http://www.digikey.com/product-detail/en/linear-technology/LT1763CS8-TRPBF/LT1763CS8-TRPBFCT-ND/4247570 LT1763CS8#TRPBF LT micropower low noise LDO ADJ regulator 500MA SO8]|| LT1763CS8#TRPBFCT-ND || 1|| 4.78USD||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| Eric|| [http://www.digikey.com/product-detail/en/linear-technology/LT1763CS8-3.3-TRPBF/LT1763CS8-3.3-TRPBFCT-ND/4247566 LT1763CS8-3.3#TRPBF LT micropower low noise LDO 3.3V regulator 500MA SO8]|| LT1763CS8-3.3#TRPBFCT-ND|| 2|| 4.78USD||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| Eric|| [http://www.digikey.fr/products/fr?keywords=BA5406 BA5406 Amplifier IC 2-Channel (Stereo) Class AB 12-SIP-M] ||BA5406-ND || 1|| 3.85 EUR||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| Eric|| [https://www.digikey.fr/products/fr?keywords=HR1732-ND HIROSE CONN PLUG 5POS W/PIN INSERT ref "RM12BPE-5PH(71)"] ||HR1732-ND || 1|| 11.19 EUR||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| Eric|| [https://www.digikey.fr/product-detail/fr/infineon-technologies/IRS2453DPBF/IRS2453DPBF-ND/1189713 INFINEON IC DRIVER FULL SELF OSC 14-DIP IRS2453DPBF] ||IRS2453DPBF-ND || 1|| 3.09 EUR||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| 3dsman|| US5881LUA Digital Switch Unipolar Switch Open Drain Hall Effect TO-92UA ||US5881LUA-AAA-000-BU-ND || 5|| 1.10 EUR||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| Debutant|| [https://www.digikey.fr/product-detail/fr/jst-sales-america-inc/SYF-001T-P0.6-LF-SN/455-2652-1-ND/2796952 JST Sales America Inc. SYF-001T-P0.6(LF)(SN) ] || 455-2652-1-ND || 100|| 0.05460 EUR|| Debutant || DI_006 || N || N || N || N<br />
|-<br />
| Lo2|| [https://www.digikey.fr/product-detail/en/molex-llc/0755860006/WM22014CT-ND/9095459 Molex Connecteur 50POS SMD] || WM22014CT-ND || 3|| 8.47 EUR|| Lo2 || DI_006 || N || N || N || N<br />
|-<br />
<br />
|}<br />
<br />
=== [http://www.doga.fr Doga] ===<br />
<br />
La prochaine commande aura pour référence interne : DO_004<br />
<br />
Prochaine date de commande : [inconnu]<br />
<br />
Commande passée en attente de livraison : [aucune]<br />
<br />
Commande livrée en cours de distribution : DO_003<br />
<br />
<br />
Minimum de commande : 50€ HT<br />
Franco : 100€ HT<br />
<br />
Merci de préciser le catalogue dans lequel se trouve l'article pour le retrouver plus aisément. <br />
<br />
Les principaux catalogues sont :<br />
* http://www.doga.fr/catalogue_pdf/ugv.pdf<br />
* http://www.doga.fr/catalogue_pdf/ugv-alliage-leger.pdf<br />
* [https://shop.precitool.de/bk/WKZ_2017-2018/#page_0.1 Precitool]<br />
<br />
Anciennes commandes Doga archivées [[Projets:Commande_groupee:archives#Doga|ici]]<br />
<br />
<br />
|-<br />
!Demandeur !! class="unsortable"| Description !!class="unsortable"| Ref Doga !! class="unsortable"| Catalogue !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!!Remboursé/Archive (O/N)<br />
<br />
<br />
|-<br />
| Eric||[http://shop.precitool.de/bk/HKL_2016-2017/#page_870 Ø 8mm Zylinderbürste mit Öse, Messingdraht gewellt marque : LESSMANN]|| 481772 || Precitool || 1 || 7 EURHT || <acheteur> || DO_002 || N || O || O || O<br />
|-<br />
| <s>Eric</s>||<s>[http://shop.precitool.de/bk/HKL_2015-2016/#page_1044 Kompakt-Bolzenscheider KNIPEX Mit Mehrkomponenten-Hülle, Öffnungsfeder, 20° abgewinkelt]</s>||<s> 559026</s> ||<s> Precitool </s>||<s> 1 </s>||<s> 40.45EURHT</s> ||<s> <acheteur> </s>||<s> DO_002 </s>||<s>N</s> ||<s>N</s>||<s> N </s>||<s> N</s><br />
|-<br />
| Eric||[http://shop.precitool.de/bk/HKL_2016-2017/#page_924 Strinlochschlüssel-Satz marque AMF]|| 506050|| Precitool || 1 || 31.05EURHT || <acheteur> || DO_002 || N || O || O || O<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1116 KNIPEX Montagezange Typ 4521 für Sprengringe auf Wellen (KNIPEX Ref 45 21 200)]||554175 /4521|| Precitool || 1 || 30,75EURHT || <acheteur> || DO_002 || N || O || O || O<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2016-2017/#page_1242 Schneidoel 500ml]||924055|| Precitool || 1 || 14,35EURHT || <acheteur> || DO_002 || N || O || O || O<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2016-2017/#page_1254 Luftweiche 3 Fach (4 x G3/8) Typ 0304]||925805/0304|| Precitool || 2 || 7.05EURHT || <acheteur> || DO_002 || N || O || O || O<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_35 Spiralbohrer HSS-Co Precitool D1897 INOX Dn 2,1mm]||100670/2,10|| Precitool || 5 || 1.91 EURHT || Lab || DO_003 || N || O || O (livré en 2.3mm, puis relivré gratuitement en 2,1mm) || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_815 Düsenlehre 0.45-1.5mm (0.05mm steigung)]||389850/20|| Precitool || 1 || 12.65 EURHT || Lab || DO_003 || N || O || O || N<br />
|-<br />
|Steve||[http://shop.precitool.de/bk/HKL_2017-2018/#page_987 Gelenk-Hakenschlüssel]||506350/22-35|| Precitool || 1 || 13.55 EURHT || Lab || DO_003 || N || N || N || N<br />
|-<br />
|Steve||[http://shop.precitool.de/bk/HKL_2017-2018/#page_987 Gelenk-Hakenschlüssel]||506350/35-60|| Precitool || 1 || 14.90 EURHT || Lab || DO_003 || N || N || N || N<br />
|-<br />
|Steve||[http://shop.precitool.de/bk/HKL_2017-2018/#page_987 Gelenk-Hakenschlüssel]||506350/60-90|| Precitool || 1 || 17.70 EURHT || Lab || DO_003 || N || N || N || N<br />
|-<br />
|Lab||[http://shop.precitool.de/bk/HKL_2017-2018/#page_985 Hakenschlüssel aus spezial Stahl Gehärtet und im Brunierton angelassen, pour Ø 95-100 mm, pour écrous DIN 1804 et DIN 981]||506200 95/100|| Precitool || 1 || 10,80 EURHT || Lab|| DO_003 || N || O || O (erreur de reference de commande) || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_985 Hakenschlüssel aus spezial Stahl Gehärtet und im Brunierton angelassen, pour Ø 95-100 mm, pour écrous DIN 1804 et DIN 981]||506200 95/100|| Precitool || 1 || 10,80 EURHT || Lab || DO_003 || N || O || O (erreur de reference de commande) || N<br />
<br />
|-<br />
|Lab||[http://shop.precitool.de/bk/HKL_2017-2018/#page_1153 Jeu de chasse-goupilles - Splintentreiber]|| 561110/6M || Precitool || 1 || 18.05 EURHT || Lab || DO_003 || N || N || N || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Linksausdreher Grosse 1 (für M3-M6)]||590950/1|| Precitool || 3 || 1,35 EURHT || Lab || DO_003 || N || O || O || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Linksausdreher Grosse 2 (für M6-M8)]||590950/2|| Precitool || 2 || 1,35 EURHT || Lab || DO_003 || N || O || O || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Linksausdreher Grosse 3 (für M8-M11)]||590950/3|| Precitool || 2 || 1,54 EURHT || Lab|| DO_003 || N || O || O || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Schaubenausdreher/Linksausdreher "Super Traktion" Grosse T1 (pour Ø 4-5 mm, perçage 2.1 mm)]||590970/T1|| Precitool || 3 || 4.47 EURHT || Lab || DO_003 || N || O || O || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Schaubenausdreher/Linksausdreher "Super Traktion" Grosse T2 (pour Ø 5-7 mm, perçage 3.2 mm )]||590970/T2|| Precitool || 3 || 4.58 EURHT || Lab || DO_003 || N || O || O || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Schaubenausdreher/Linksausdreher "Super Traktion" Grosse T3 (pour Ø 8-12 mm, perçage 4.5 mm )]||590970/T3|| Precitool || 3 || 5.70 EURHT || Lab || DO_003 || N || O || O || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_35 Spiralbohrer HSS-Co Precitool D1897 INOX Dn 8,6mm]||100670/8,60|| Precitool || 2 || 6.99 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_35 Spiralbohrer HSS-Co Precitool D1897 INOX Dn 8,7mm]||100670/8,70|| Precitool || 2 || 6.99 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_985 Gelenk-Hakenschlüssel verstellbar, mit Nase, gehärtet und im Brünierton angelassen; für AuBen Ø (Mutter) 20-35 mm]||506300/20-35|| Precitool || 1 || 11.10 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_985 Gelenk-Hakenschlüssel verstellbar, mit Nase, gehärtet und im Brünierton angelassen; für AuBen Ø (Mutter) 35-60 mm]||506300/35-60|| Precitool || 1 || 12.00 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_985 Gelenk-Hakenschlüssel verstellbar, mit Nase, gehärtet und im Brünierton angelassen; für AuBen Ø (Mutter) 60-90 mm]||506300/60-90|| Precitool || 1 || 15.55 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Schaubenausdreher/Linksausdreher "Super Traktion" Grosse T4 (pour Ø 12-14 mm, perçage 6.5 mm )]||590970/T4|| Precitool || 3 || 6.59 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Schaubenausdreher/Linksausdreher "Super Traktion" Grosse T5 (pour Ø 16-20 mm, perçage 8.5 mm )]||590970/T5|| Precitool || 3 || 9.00 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|}<br />
<br />
=== [http://fr.farnell.com Farnell] ===<br />
<br />
Livraison gratuite au dessus de 30€ HT<br />
<br />
La prochaine commande aura pour référence interne : FA_017<br />
<br />
<br />
Prochaine date de commande : <à définir><br />
<br />
Commande passée en attente de livraison : <aucune><br />
<br />
Anciennes commandes Farnell archivées [[Projets:Commande_groupee:archives#Farnell|ici]]<br />
<br />
|-<br />
| Demandeur || class="unsortable"| Description || Ref Farnell || class="unsortable"| Quantité || class="unsortable"| Prix unitaire || Acheteur || Commande<br/>n° || Payé<br/>d'avance<br/>(O/N)|| Commandé<br/>(O/N)|| Distribué<br/>(O/N)|| Remboursé/<br/>Archive<br/>(O/N)<br />
|-<br />
|-<br />
|-<br />
| Claire Poisson || CD4011BM96 || 2114002 || 15 || 0,313 TTC || 3dsman ||FA_015 ||N ||O ||N ||N<br />
|-<br />
|-<br />
| 3dsman || Câble multiconducteur blindé || 2425036 || 10 || 0,85 TTC || 3dsman ||FA_015 ||N ||O ||N ||N<br />
|-<br />
|-<br />
| Steve (Pour lab/smoothie) || NXP LPC 1769 || 2072199 || 1 || 8,68 TTC || 3dsman ||FA_015 ||N ||O ||O ||N<br />
|-<br />
|-<br />
| Dom (Rude ULM) || Connecteur d'alimentation DC, Mâle, 2 A, 9.5 mm, Montage sur câble, 1.7 mm || 1737255 || 2 || 2.87 TTC || 3dsman ||FA_015 ||N ||O ||N ||N<br />
|-<br />
|-<br />
| Steve || MCP1702T-5002E/MB - Régulateur LDO 5V SOT89-3 || 1605559 || 3 || 0.593 || 3dsman ||FA_015 ||N ||O ||O ||N<br />
|-<br />
|-<br />
| Steve || RELAY, SPDT, 250VAC, 12A || 1714771 || 2 || 2.27E|| 3dsman ||FA_015 ||N ||O ||O ||N<br />
|-<br />
|-<br />
|-<br />
| Steve (Pour lab/smoothie) || LDO LM1117 3.3V || 2323580 || 5 || 0.907 || Ph. Gras||FA_016 ||N ||O ||O ||N<br />
|-<br />
| Eric ||[http://fr.farnell.com/amphenol-sine-tuchel/t-3424-501/fiche-libre-6-voies/dp/1123507 Connecteur 6 broches Amphénol avec serrage baillionnette ref T 3424 501] || 1123507 || 1 || 5,12 || Ph. Gras ||FA_016 ||N ||O ||O ||N<br />
|-<br />
| Eric ||[http://fr.farnell.com/nkk-switches/b18jp/switch-toggle-spdt-0-1a-28vac/dp/2374722?ost=2374722&ddkey=http%3Afr-FR%2FElement14_France%2Fsearch Commutateur 3 positions miniature SPDT, 0.1A, 28VAC On-Off-On NKK Switch ref B18JP ] || 2374722|| 2 || 3,98 EUR || Ph. Gras ||FA_016 ||N ||O ||O ||N<br />
|-<br />
| Ph. Gras||[http://fr.farnell.com/jst-japan-solderless-terminals/phr-2/boitier-2-voies-2mm/dp/3616186 Boîtier de connecteur, Série PH, Embase, 2 Voies, 2 mm, Contacts à sertir Série BPH et SPH ] || 3616186|| 100 || 0,0324 EUR || Ph. Gras||FA_016 ||N ||O ||O ||O<br />
|-<br />
| Ph. Gras||[http://fr.farnell.com/jst-japan-solderless-terminals/sph-002t-p0-5s/contact-0-05-0-22mm-cut-reel/dp/1671245?st=SPH-002T-P0.5S Contact, Série PH, Femelle, Sertissage, 24 AWG, Contacts plaqués étain, Connecteurs PH ] || 1671245|| 250|| 0,0208 EUR || Ph. Gras ||FA_016 ||N ||O ||O ||O<br />
|-<br />
| Ph. Gras||[http://fr.farnell.com/on-semiconductor/lm317ahvt/regulateur-ldo-ajustable-1-5a/dp/1564497?st=lm317LM317AHVT Régulateur de tension positive ajustable 1.2V à 37V, 1.5A en boîtier TO-220-3 ] || 1564497|| 10|| 0,727 EUR || Ph. Gras ||FA_016 ||N ||O ||O ||O<br />
|-<br />
|-<br />
|-<br />
| <demandeur> ||[http://wiki.electrolab.fr/Projets:Commande_groupee#Glossaire <article>] || <fa_cde_nb> || <quantité> || <prix> || <acheteur> ||FA_017 ||N ||N ||N ||N<br />
|-<br />
|-<br />
|}<br />
<br />
=== [http://www.gotronic.fr Gotronic] ===<br />
<br />
la prochaine commande a la référence interne GO_003<br />
<br />
<br />
Commande passée en attente de livraison :GO_002 le 31/05/2017 par Ellyan<br />
<br />
<br />
Anciennes commandes Gotronic archivées [[Projets:Commande_groupee:archives#Gotronic|ici]]<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref gotronic!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||<Acheteur>|| GO_XXX || N || N || N || N<br />
|-<br />
--><br />
| Damien H || Solénoïde 12 Vcc || LS1110BD || 1 || 7,00€||Ellyan|| GO_002 || N || O || N || N<br />
|}<br />
<br />
=== HighVoltageShop ===<br />
<br />
La prochaine commande a pour référence interne : HV_002<br />
<br />
5 euros de réduction sur la prochaine commande<br />
<br />
Prochaine date de commande : Aucune<br />
<br />
Commande passée en attente de livraison : Aucune<br />
* frais de port 20 euros<br />
* Livraison mardi 7 janvier 2014 au lab<br />
<br />
Commande livrée en cours de distribution : HV_001 (08/12/2013) <br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref ebay!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||David|| DI_XXX || N || N || N || N<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| Thomas || Cable HV 120 kV || 271261265516 || 1 || 8,69€||David|| HV_001 || O || O || O || N<br />
|-<br />
|David||-30kV HV-Generator Modul 12VDC||281162933827||1||34,99€||David||HV_001||O||O||O||N<br />
|-<br />
|David||5 Stk. Zeilentrafo - Flyback Transformer - Zeilentrafos||281024817841||1||24,99€||David||HV_001||O||O||O||N<br />
|-<br />
|David||+30kV HV-Generator Modul 12VDC||281162933829||1|| 34,99€||David||HV_001||O||O||O||N<br />
|-<br />
|CitronVert||-30kV HV-Generator Modul 12VDC||281162933827||2||34,99€||David||HV_001||N||O||O||N<br />
|-<br />
| Goldo || Regelbares Hochspannungsnetzteil 50kV Strombegrenzung || 280941865340 || 1 || 119,99€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || +30kV HV-Generator Modul 12VDC || 281162933829 || 1 || 34,99€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Zenos || +30kV HV-Generator Modul 12VDC || 281162933829 || 1 || 34,99€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || Cable HV 120 kV || 271261265516 || 1 || 8,69€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || Hochspannungskabel 40kV 1m || 271261265512 || 1 || 4,61€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || Hochspannungswiderstand 20kV 1 GigaOhm Messwiderstand || 280941865344 || 1 || 6,34€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || Hochspannungswiderstand 20kV 100 MegaOhm || 271106455991 || 1 || 6,34€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || Hochspannungswiderstand 20kV 1 MegaOhm || 281026497192 || 1 || 6,34€||David|| HV_001 || O || O || O || N<br />
|}<br />
<br />
=== [http://www.limpulsion.fr/web/index.php L'impulsion] ===<br />
<br />
[http://v1.limpulsion.fr/docpdf/2008_cat/bpoa_a.pdf Catalogue "accessoires de test"]<br />
<br />
La prochaine commande a la référence interne LI_002<br />
<br />
Prochaine date de commande : [à définir]<br />
<br />
<br />
Commande livrée en cours de distribution :[aucune]<br />
<br />
Anciennes commandes Limpulsion archivées [[Projets:Commande_groupee:archives|ici]]<br />
<br />
<br />
{|class="wikitable sortable" style="font-size:80%"<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref L'impulsion!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-<br />
|Lab||ADAPTATEUR D'AXE HM8001-2 HAMEG||760000500||1||2.30HT||Yannick||IL_001||N||N (plus livrable)||N||O<br />
|-<br />
|Lab||TRESSE A DESSOUDER NO CLEAN 2.8mm/3m||730.14||10||1.56HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||Entretoise plastique grise de montage en saillie marque "Electro-PJP" pour douilles 4mm type 3265, ref EPJP : 3282||<pas au catalogue: demander si livrable> ||16||? ||Yannick||IL_001||N||N (apparement pas dispo)||N||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou NOIR, ref3265-I-0 ||326500||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou MARRON, ref3265-I-1 ||326501||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou ROUGE, ref3265-I-2 ||326502||3||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou BLEU, ref3265-I-6 ||326506||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou VIOLET, ref3265-I-7 ||326507||3||1.48HT||Yannick||IL_001||O||O||N||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou GRIS, ref3265-I-8 ||326508||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou BLANC, ref3265-I-9 ||326509||3||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou JAUNE/VERT, ref 3265-I-J/V||326510||1||1.74HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||[http://v1.limpulsion.fr/docpdf/2008_cat/bpoe_a.pdf#page=9 Passe fil classique intérieur :12mm, Perçage: 18mm, Epaisseur :10mm (lot de 10pcs)]||252.162||1||1,95EURHT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||Entretoise plastique grise de montage en saillie marque "Electro-PJP" pour douilles 4mm type 3265, ref EPJP : 3282||<pas au catalogue: demander si livrable> ||16||? ||Yannick||IL_001||N||N(apparement pas dispo)||N||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou NOIR, ref3265-I-0 ||326500||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou MARRON, ref3265-I-1 ||326501||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou ROUGE, ref3265-I-2 ||326502||3||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou BLEU, ref3265-I-6 ||326506||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou VIOLET, ref3265-I-7 ||326507||3||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou GRIS, ref3265-I-8 ||326508||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou BLANC, ref3265-I-9 ||32650||3||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou JAUNE/VERT, ref 3265-I-J/V||326510||2||1.74HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||CLE EXTERNE POUR DOUILLE DE SECURITE||3299||1||13.51HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||TRANSFO FERRITE POUR THT HM1005 HAMEG (plus livrable) ||THTHM1005||1||16.77HT||Yannick||IL_001||N||N (plus livable)||N||O<br />
|-<br />
|Eric||Lot de 100 douilles pour C.I diam4 Long 10mm à souder Electro-PJP ref 20054||20054||1||7,95 EUR HT||Yannick||LI_001||N||O||O||O<br />
|-<br />
<br />
|Eric||CI SN75492 (7 segm DRIVER) TEXAS DIP14||75492||13||1.29HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||CI 74LS164 TEXAS DIL||74LS164||2||0.76HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||IPROBER520||IPROBER520||1||594HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|}<br />
<br />
=== [https://shop.mchobby.be/ MCHobby] ===<br />
<br />
La prochaine commande a pour référence interne : MCH_001<br />
<br />
Prochaine date de commande : <Mardi 20 ou mercredi 21 au plus tard ><br />
<br />
Livraison gratuite en Mondial Relay à partir de 75 euros.<br />
<br />
Commande passée en attente de livraison :[aucune]<br />
<br />
<br />
Anciennes commandes MCHobby archivées [[Projets:Commande_groupee:archives#MCHobby|ici]]<br />
<br />
Site WEB de MCHobby : https://shop.mchobby.be/<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Mon Droguiste !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||<Acheteur>|| MC_XXX || N || N || N || N<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| LienRag|| Divers ||Divers || ++|| 75€||<acheteur>|| MHC_001 || N|| N || N || N<br />
|}<br />
<br />
<br />
=== [http://217.34.103.131/homepage/homepage.html Mini-Circuits] ===<br />
<br />
La prochaine commande a pour référence interne : MC_001<br />
<br />
<br />
<br />
<br />
Anciennes commandes Mini-Circuits archivées [[Projets:Commande_groupee:archives#Mini-Circuits|ici]]<br />
<br />
Site WEB de minicircuits : http://www.minicircuits.com/homepage/homepage.html<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Mini-circuits !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| F1CHF || ERA-3 || AMPL || 20 || 1.43€||F1CHF|| MC_001 || N || N || N || N<br />
|-<br />
|-<br />
| F1CHF || ADCH-80+ || coil || 20 || 2.88€||F1CHF|| MC_001 || N || N || N || N<br />
|-<br />
|}<br />
<br />
=== [http://www.mon-droguiste.com/index.cfm Mon Droguiste] ===<br />
<br />
La prochaine commande a pour référence interne : MD_001<br />
<br />
<br />
<br />
<br />
Anciennes commandes Mon Droguiste archivées [[Projets:Commande_groupee:archives#Mon-droguiste|ici]]<br />
<br />
Site WEB de Mon Droguiste : http://www.mon-droguiste.com/index.cfm<br />
<br />
|-<br />
|-l<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| Eric|| Ethylene Diamino Tetraacetic Acide 500g ||Ethylene Diamino Tetraacetic Acide Sac 500g || 1|| 16.95€||<acheteur>|| MD_001 || N|| N || N || N<br />
|}<br />
<br />
=== [http://www.mouser.fr Mouser Electronics]===<br />
<br />
La prochaine commande aura pour référence interne MO_014<br />
<br />
Prochaine date de commande : ?<br />
<br />
<br />
Commande livrée en cours de distribution : MO_013 le 31/05/2017 par Ellyan<br />
<br />
Anciennes commandes Mouser Electronics archivées [[Projets:Commande_groupee:archives#Mouser Electronics|ici]]<br />
<br />
Livraison gratuite (FedEx ou UPS) au delà de 50€ de commande<br />
<br />
<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Mouser !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||<Acheteur>|| DI_XXX || N || N || N || N<br />
|-<br />
--><br />
<br />
|-<br />
|Frederic.D.||[http://www.mouser.fr/ProductDetail/TE-Connectivity/1-826632-0/ Headers & Wire Housings 2X10P DUAL ROW]||571-1-826632-0 ||3 ||1.95 |||| MO_013||O ||O ||O ||N<br />
|-<br />
|Frederic.D.||[http://www.mouser.fr/ProductDetail/Bourns/3306P-1-103/ Trimmer Resistors - Through Hole 10K 25% 6mm Single Turn]||652-3306P-1-103 ||3 ||0.407 |||| MO_013||O ||O ||O ||N<br />
|-<br />
|Frederic.D.||[http://www.mouser.fr/ProductDetail/Schurter/13019302/?qs=%2fha2pyFadugAVCtehZ6ro0we%252bFlHwInvMJ3iEORyekx9pnGrLimsvA%3d%3d Pushbutton Switches SHORT TRAVEL SWITCH 6X6, 5.0MM]||693-1301.9302 ||9 ||0.251 |||| MO_013||O ||O ||O ||N<br />
|-<br />
|Frederic.D.||[http://www.mouser.fr/ProductDetail/Bourns/MF-USMF075-2/ Resettable Fuses - PPTC 0.75A 6V 0.18ohm Hold .75A Trip 1.5A]||652-MF-USMF075-2 ||3 ||0.275 |||| MO_013 ||O ||O||O ||N<br />
|-<br />
|Frederic.D.||[http://www.mouser.fr/ProductDetail/STMicroelectronics/SMA6J50A-TR/?qs=%2fha2pyFadujqXhcCRI4%2fO5BEn9p7pkr6EX0dAQtUlws3JpN%2fE2p9DQ%3d%3d TVS Diodes - Transient Voltage Suppressors HJ Temp Transil]||511-SMA6J5.0A-TR ||3 ||0.38 |||| MO_013 ||O||O||O ||N<br />
|-<br />
|-<br />
|Sylvain V.||[http://www.mouser.fr/ProductDetail/Cirrus-Logic/CS4398-CZZ/?qs=sGAEpiMZZMv%252bLKsN4bqzyhXScoHWAp%252boAQFEBwyfAGo%3d DAC Cirrus Logic]||777-CS4398-CZZ ||1 || 10.46 || Sylvain V. || MO_013 ||O||O||O ||N<br />
|-<br />
|Eric||[https://eu.mouser.com/ProductDetail/Amphenol-Tuchel/T-3427-100?qs=%2fha2pyFaduhPv3s%2fjYa9sAYm3fflPgRKEDSdRTPyUvP7YbNcd%2fVs5g%3d%3d Circular DIN Connectors FEMALE RECEPTACLE 6 WAY, Amphenol series C091B]|| 523-T3427-100 ||1 || 10.29|| <<acheteur>> || MO_014 ||N||N||N ||N<br />
|-<br />
|Eric||[https://www.mouser.fr/ProductDetail/EPCOS-TDK/B32926A4685M?qs=sGAEpiMZZMv1cc3ydrPrF3kXVSi%252b9fyL4PImBI83UxcgTMvwb1977w== Condensateurs à film 6.8uF 20% 350Vac LS 37.5MM Fabricant : EPCOS /TDK ref : B32926A4685M ]|| 871-B32926A4685M ||1 || 10.67|| <<acheteur>> || MO_014 ||N||N||N ||N<br />
|-<br />
|Eric||[https://www.mouser.fr/ProductDetail/Texas-Instruments/OPA2227U-2K5?qs=sGAEpiMZZMtCHixnSjNA6Mrdwin7F8A2DB4TJmgUI0w%3d OPA2227U SOIC8 dual opamp low noise Texas ]|| 595-OPA2227U/2K5 ||2 || 8.07|| <<acheteur>> || MO_014 ||N||N||N ||N<br />
|-<br />
|Eric||[https://eu.mouser.com/ProductDetail/Molex/53253-0570?qs=sGAEpiMZZMvlX3nhDDO4AD1CBCqS4WJ3BaSa47NubxE%3d Shrouded header 5 pins 2mm male through hole board connnector vertical mounting Molex ref. 53253-0570 Cross ref to JST PH "B5B-PH-K-S"]|| 538-53253-0570||20 || 0,164 €|| <<acheteur>> || MO_014 ||N||N||N ||N<br />
|-<br />
|Eric||[https://eu.mouser.com/ProductDetail/Central-Semiconductor/TIP42B?qs=sGAEpiMZZMshyDBzk1%2fWi0MKeUdJDRlz1TXFEdLineJjytqjBdqtHg%3d%3d Bipolar Transistor PNP 10A 80V TIP42B]|| 610-TIP42B ||2 || 0,969 €|| <<acheteur>> || MO_014 ||N||N||N ||N<br />
|-<br />
| Eric|| [https://www.mouser.fr/ProductDetail/Hirose-Connector/RM12BPE-5PH71?qs=sGAEpiMZZMvG94qpybaIZaiKjo18NgShhh8FQGCnH4c%3d HIROSE CONN PLUG Cbl Mount 5 Terminals ref "RM12BPE-5PH(71)"] ||798-RM12BPE-5PH71 || 1|| 11.47 EUR||<acheteur>|| MO_014 || N || N || N || N<br />
|-<br />
| Eric|| [https://www.mouser.fr/ProductDetail/Mueller-Electr/BU-75K?qs=sGAEpiMZZMs4AFwHyzhTm%2f3wHG8LpAJAx37I4fl4y%2fU%3d Kelvin clip 10A Mueller Electric ref. BU-75K] ||548-BU-75K|| 4|| 10.20 EUR||<acheteur>|| MO_014 || N || N || N || N<br />
|-<br />
| Marc|| [https://www.mouser.fr/ProductDetail/Laird/28B0570-000?qs=%2fha2pyFaduia8iLa7KZn%252b9ZwN9PPwsI6zauOY7uXjr3NGQmgjfyUfg%3d%3d Tores Laird] ||875-28B0570-000|| 25|| 0,139 €||<acheteur>|| MO_014 || N || N || N || N<br />
|-<br />
| Marc|| [https://www.mouser.fr/ProductDetail/Laird/28B0562-100?qs=%2fha2pyFadugPna2jpgDGpEerG08QF%2feuzZA0nW3WCHO2J%2fL24jvrtw%3d%3d Tube ferrite Laird] ||875-28B0562-100|| 25||0,236 €||<acheteur>|| MO_014 || N || N || N || N<br />
|-<br />
|}<br />
<br />
<br />
=== [http://www.motedis.fr/shop/ Motedis France] ===<br />
<br />
<br />
La prochaine commande aura pour référence interne : MS_001<br />
<br />
<br />
<br />
<br />
Anciennes commandes Motedis France archivées [[Projets:Commande_groupee:archives#Motedis France|ici]]<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Motedis!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-<br />
|Eric||Plaquette aluminium 15mm d'épaisseur Largeur: 100mm ||<ref motedis>||L:1000mm|| 24.15EURHT || <acheteur> || MS_001 || N|| N || N || N<br />
|-<br />
|<demandeur>||<description>||<ref motedis>|| <quantité> || <prix>|| <acheteur> || MS_001 || N|| N || N || N<br />
|-<br />
|}<br />
<br />
<br />
===[http://www.nouvelleplastique.it/f/setf.html Nouvelle Plastique]===<br />
La prochaine commande a pour référence interne : NP_001<br />
<br />
Prochaine date de commande : Q3/2014<br />
<br />
<br />
<br />
Anciennes commandes Nouvelle Plastique archivées [[Projets:Commande_groupee:archives#Nouvelle Plastique|ici]]<br />
<br />
La société "[http://www.nouvelleplastique.it/f/setf.html Nouvelle Plastique]" fabrique des systèmes de rangements portables et modulaires en plastique.<br />
Les produits sont souvent bien pensés (parfois mieux que RAACO ou Stanley) et de bonne solidité.<br />
<br />
Malheureusement, ses produits ne sont que rarement distribués par les circuits classiques et pour le moment aucun revendeur de détail en France n'a été identifié. De même, on ne connait pas les prix des produits.<br />
La démarche envisagée est de collecter via le tableau ci-dessous une liste de souhaits afin de pouvoir demander un devis global directement au fabricant d'ici quelques mois (probablement en Q3/2014). En fonction de ses proposition de prix, chacun pourra finalement accepter ou refuser que ses souhaits soient inclus dans la commande définitive. Le coût du port sera partagé au prorata du prix des marchandises achetées (plus il y a de demaneurs, plus le coût individuel du port sera faible).<br />
Pour chaque article, il y a indication d'une UDV (Unité De Vente), c'est à dire de lot indivisible.<br />
Au terme des sélections de vos besoins, il faudra que le nombre de pièces commandées pour chaque article soit un multiple de son UDV.<br />
Le tableau ci-dessous dispose d'une structure adaptée à la gestion des souhaits des demandeurs, du nombre d'article et des UDV.<br />
Tous les demandeurs intéressés par un même article s'inscrivent dans une seule ligne (ce qui conduit au fait qu'il y ait une ligne par référence d'article).<br />
Le champ "PUHT" sera complété une fois le devis obtenu.<br />
<br />
====Légende du tableau ====<br />
<br />
UDV = correspond au nombre d'articles par UDV. = nombre d'articles dans un lot indivisible, cette information est indiquée par le fabricant dans son catalogue. <br />
Reste à affecter = mod(Nombre d'UDV; Nombre d'articles) <br />
<br />
<br />
Si vous éditez une ligne existante pour vous inclure comme demandeur de l'article considéré, modifiez les champs suivants :<br />
*''UDV' *''Nombre d'UDV'' (valeur cumulée d'UDV entre tous les demandeurs) <br />
*''Quantités (nombre d'articles)'' (valeur cumulées en nombre d'articles individuels entre tous les demandeurs) <br />
*''Reste à affecter'' (valeur calculée globalement pour tout les demandeurs) <br />
*''Liste de demandeurs avec (unités)'' Unités = nombre d'articles demandéz<br />
<br />
<br />
{|class="wikitable sortable" style="font-size:99%"<br />
|-<br />
! Ref article!! class="unsortable"| Désignation!! UDV (= nombre d'articles dans un lot indivisible) !! class="unsortable"| Nombre d'UDV!! class="unsortable"| Quantité souhaitée(nombre d'articles) !! Reste à affecter!! PUHT !! Liste de demandeurs avec (unités) !! N° de commande <br />
|-l<br />
|00366|| Tyger maxi double|| 6 || 1 ||6 ||0|| <PU> || Eric (6) || NP_001 <br />
|-<br />
|00361|| Tyger maxi|| 12 || 1 ||6 ||6|| <PU> || Eric (6) || NP_001 <br />
|-<br />
<br />
|}<br />
<br />
=== [https://www.olimex.com/ Olimex]===<br />
<br />
La prochaine commande a pour référence interne : OL_001<br />
<br />
<br />
<br />
<br />
Anciennes commandes Olimex archivées [[Projets:Commande_groupee:archives#Olimex|ici]]<br />
<br />
<br />
Achat par l'intermédiaire de leur site internet: https://www.olimex.com/<br />
<br />
Produits identifiés comme potentiellement intéressants:<br />
* https://www.olimex.com/Products/ARM/TI/TMS570-CAN/ un pti devkit pour un micro bien patator, prévu au départ pour des applications safety mais qui a des périphériques & capacités pas dégueulasses...<br />
* https://www.olimex.com/Products/Modules/Adapters/ pour utiliser leurs modules d'extension avec un launchpad ou un rpi<br />
* https://www.olimex.com/Products/Modules/LCD/ (divers modules LCD)<br />
* https://www.olimex.com/Products/Modules/LCD/MOD-LCD4.3%27%27/ module LCD "complet" avec pti micro sympatoche intégré<br />
* https://www.olimex.com/Products/OLinuXino/ gamme de nanocomputers intégrés & pas chers (type rpi mais en open)<br />
* https://www.olimex.com/Products/Components/Misc/TC-K-TYPE/ thermocouple K <br />
etc...<br />
<br />
<br />
Commande prévue courant mars 2013 par Clem.<br />
Attention, prix HT a priori, et prévoir également frais de port "importants" (environ 20€) à répartir entre les participants à la CG.<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Olimex!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||<Acheteur>|| OL_XXX || N || N || N || N<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| XXX|| XXX || - || - || XXX€||XXX|| OL_001 || N || N || N || N<br />
|-<br />
|-<br />
|}<br />
<br />
=== [http://www.otelo.fr/fr/index.html Otelo] ===<br />
<br />
Outillage bois-métal <br />
<br />
Ports gratuits au delà de 230 € H.T. ou code promo<br />
<br />
La prochaine commande a pour référence interne : OT_004<br />
<br />
Prochaine date de commande : < non définie ><br />
<br />
Commande passée en attente de livraison [AUCUNE]<br />
<br />
<br />
Anciennes commandes Otelo archivées [[Projets:Commande_groupee:archives#Otelo|ici]]<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Otelo!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
|-<br />
--><br />
|-<br />
|lab||TARAUD à main diamètre 14X200 Acier/alu||14104142N1||1|| 14,51€ HT|| <Patrick> || OT_002|| N || O|| O || O<br />
|-<br />
|lab||100 rondelles plates diamètre 8X16 ||36211008||5|| 3,23€ HT|| <Patrick> || OT_002|| N || O|| O || O<br />
|-<br />
|Patrick||Disque à poncer bombé axe 22mm D125 grain 80||54426280||2|| 3,42€ HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|Patrick||boites de rangement 18 sep 375X310X60||PY 69720030||3|| 9,55€ HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|Patrick||jeu d'outils ébavurage||PY 58500009||1|| 7,35€ HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|Patrick||BOMBE GALVA FLASH||PY 73006003||1|| 8,40€ HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|Eric||Tablier de soudeur 90 x 60 cm||PW 75 150 001||1|| 10,90€HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|MAZ24||meule blanche touret||5473014F||1|| 11,40€HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|MAZ24||Meule verte de touret||54571150||1|| 42,40€HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|MAZ24||Bagues adaptation||54703320||4|| 1,09€HT|| <Patrick> || OT_002|| O || O|| O|| O<br />
|-<br />
|Patrick||Mandrin à clef 3-16mm CM2/B18||30140413||1|| 27,25€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Mandrin à clef 1-13mm CM2/B16||30140409||1|| 23,20€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Arbre pour mandrin CM2/B16||30199116||1|| 6,80€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Arbre pour mandrin CM2/B18||30199118||1|| 7,00€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Ecouvillon manche bois 15mm||57169015||1|| 7,70€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Ecouvillon manche bois 25mm||57169025||1|| 8,15€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Ecouvillon à fil 6mm||57169006||1|| 5,24€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Ecouvillon à fil 25mm||57151025||1|| 6,38€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Sylvia||Support articulé ||43130110||1|| 23,77€ HT|| <Patrick> || OT_003|| N || O|| O|| O<br />
|-<br />
|}<br />
<br />
===[http://www.outiz.fr/ Outiz]===<br />
<br />
<br />
Comptoir Guilleraies (Nanterre)<br />
<br />
Du lundi au vendredi 7h - 17h Samedi 8h - 12h<br />
<br />
Téléphone : 01 40 35 77 77<br />
<br />
La prochaine commande aura pour référence interne : OU_001 <br />
<br />
Prochaine date de commande : <non définie><br />
<br />
<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Outiz!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!!Remboursé/Archive (O/N)<br />
|-<br />
| Eric ||[http://www.outiz.fr/sferaco-vanne-a-sphere-laiton-pn25-batiment-ff-3-4-poignee-acier-plate-rouge-580005/p/3806984/ Vanne à poignée plate rouge Genre : FF Ø : 3/4" ] ||3806984 || 1|| 4,54 €HT||<acheteur>|| OU_001 || N || N || N || N<br />
|-<br />
|}<br />
<br />
=== [http://fr.rs-online.com/web/ Radiospares (RS Composants)] ===<br />
<br />
La prochaine commande aura pour référénce interne : RS_012<br />
<br />
<br />
<br />
Commande livrée en cours de distribution : <aucune><br />
<br />
Anciennes commandes Radiospares archivées [[Projets:Commande_groupee:archives#Radiospares|ici]]<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref RS!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||Acheteur|| DI_XXX || N || N || N || N<br />
--><br />
|-<br />
| papy F1CHF||régulateur || 686-9007 || 10 || 0,27€|| <>|| RS_012 || N || N || N || N<br />
|FredericD||[http://fr.rs-online.com/web/p/ldr/9146710/ Silonex, NSL-19M51, CdS, Traversant, TO-18, 20 kΩ → 100 kΩ]||914-6710|| 10 || 1.074€HT ||<>||RS_012||N||N||N||N <br />
|-<br />
|FredericD||[http://fr.rs-online.com/web/p/relais-reed/2562055/ Relais Reed 1NO 12V dc 1 A]||256-2055|| 1 || 5.17€HT ||<>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[http://fr.rs-online.com/web/p/refrigerants/1115853/ Réfrigérant aérosol Cramolin Aérosol 400 ml, -50°C]||111-5853|| 2 || 11.12€HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/accessoires-pour-capteur-de-temperature/0286771/ Presse-étoupe pour Thermocouple]||286-771|| 2 || 9,68€HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/pinces-kelvin/7148263/ Pince Kelvin BU-75K, 10A, noir, fabricant : Mueller]||714-8263|| 2 || 19,61€HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/condensateurs-aluminium/8396258 Condensateur électrolytique aluminium radial 10µF, -20%, 50V dc, Traversant, +105°C, WURTH série WCAP-AT1H, 5 (Dia.) x 11mm 5000h 97mA Référence fabricant : 860240672002]||839-6258|| 25 (1 sachet) || 3,90 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/condensateurs-aluminium/8399011 Condensateur électrolytique aluminium radial 47µF, -20%, 63V dc, Traversant, +105°C, WURTH série WCAP-ATUL, 8 (Dia.) x 11.5mm 7000h 360mA ESR: 0.66 Ohms Référence fabricant : 860040774002]||839-9011|| 20 (2 paquets) || 3,12 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/condensateurs-aluminium/8399033 Condensateur électrolytique aluminium 120µF, -20%, 63V dc, Traversant, +105°C, série WCAP-ATUL, 10 (Dia.) x 16mm 7000h 760mA ESR: 0.3 Ohms Référence fabricant : 860040775008]||839-9033|| 20 (4 paquets) || 3,43 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/connecteur-xlr/7259543/ Connecteur XLR femelle plastique pour chassis soudage pour CI 3 broches coudé + blindage avec louet métal, NEUTRIK NC3FAH2]||725-9543|| 2 || 1,97 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/connecteur-xlr/7259549 Connecteur XLR mâle plastique pour chassis soudage pour CI 3 broches coudé + blindage, NEUTRIK NC3MAH ]||725-9549|| 2 || 1,43 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/fusibles-cms-rearmables/5177054/ Fusible CMS réarmable, Littelfuse, 2.2A - 1.1A Référence fabricant : SMD100F-2 MK : 100F]|| 517-7054|| 10 || 0,497 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/roulettes-sur-platine/0819567/ Roulette Pivotante Acier 50mm, Bas profil, 270kg Fabricant : Revvo]|| 819-567 || 4|| 34.91 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|3ds||[https://fr.rs-online.com/web/p/potentiometres/0387896/ Potentiomètre carbone série 23 montage panneau 4K7 B avec interrupteur DPST, axe 6,35mm TE Connectivity ref 23ESB472MMF50AF]||387-896|| 1 || 4,14€HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Louis||[https://fr.rs-online.com/web/p/passe-fils/1366806/ Passe-fils,SES en PVC, Diamètre maximum de câble 3mm Noir ref 01070005010 ]||136-6806|| 1 sachet de 100|| 5,38€HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|}<br />
<br />
<br />
<br />
=== [http://www.stquentin-radio.com/ Saint Quentin radio]===<br />
<br />
La prochaine commande a pour référence interne SQ_002<br />
<br />
<br />
<br />
<br />
Anciennes commandes Saint Quentin Radio archivées [[Projets:Commande_groupee: Saint Quentin radio|ici]]<br />
<br />
Paiement cash par avance à l'acheteur : payez le montant exact, car il n'y a pas de frais annexes<br />
<br />
Frais de port : 0€ (sauf objets lourds) Gare du Nord<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref St Quentin!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
|-<br />
--><br />
|Lab||DOUILLE DE SECURITE 4mm ECROU BLANC, ref3265-I-9 ||326509 ||3||1.80€||<Patrick>||SQ_001||N||O||O||O<br />
|-<br />
|Lab||Fiche DIN 5BR MALE PLASTIQUE 360°||I076||2||1.00€||<acheteur>||SQ_002||N||N||N||N<br />
|-<br />
|Lab||Fiche DIN 5BR CHASSIS METAL 360°||I088||1||1.20€||<acheteur>||SQ_002||N||N||N||N<br />
|}<br />
<br />
=== [http://www.selectronic.fr Selectronic] ===<br />
<br />
La prochaine commande a pour référence interne : SE_010 <br />
<br />
<br />
<br />
<br />
Anciennes commandes Sélectronic archivées [[Projets:Commande_groupee:archives#Selectronic|ici]]<br />
<br />
Frais de port : 0€ (sauf objets lourds)<br />
<br />
Certains produits sont pas en stock à Paris et requièrent d'être livrés de Lille d'où un délai de quelques jours. Le mieux est d'aller au mag à Nation le mardi pour passer la commande et dans ce cas c'est en principe dispo jeudi sur place.<br />
<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description || Ref Sélectronic!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-<br />
|Eric||Résistance CTN 10kOhms 10% format goutte traversant||5277|| 1 || 0.95€TTC|| Eric|| SE_008 || O || O || O || O<br />
|- <br />
|lab||Résistance CTN 10kOhms 10% format goutte traversant||5277|| 1 || 0.95€TTC|| Zenos|| SE_009 || N || O || O || N<br />
|-<br />
|Zenos||triac BT139-600||4024|| 3 || 1,90€TTC|| Zenos|| SE_009 || O || O || O || O<br />
|-<br />
|Lab||TIC106D Thyristor||4018|||1||1,52||<acheteur>|| SE_009 || N || O || N (pas dispo) || N <br />
|-<br />
|Eric||IR IRF9540 MOS canal P -100V -19A||08015|||1||2,50EUR||Zenos|| SE_009 || O || O || O || O<br />
|- <br />
|Eric||Mosfet N IRF640N TO220 200V 0.150Ω - 18A||HD75-940|||2||1,94||<acheteur>|| SE_010 || N || N || N || N<br />
|-<br />
|Marc f6itu||pointes de scope||2447|||4||1,02||<acheteur>|| SE_010 || N || N || N || N<br />
|-<br />
|Lab (Eric)||[http://www.selectronic.fr/joints-adhesif-pour-enceintes.html bande mousse autocollante de largeur 5mm, hauteur 2mm]||2300|||2||5.50||<acheteur>|| SE_010 || N || N || N || N<br />
|-<br />
|-class="sortbottom"<br />
|}<br />
<br />
=== [http://www.sparkfun.com/ SparkFun Electronics]===<br />
<br />
La prochaine commande a pour référence interne SF_002<br />
<br />
Prochaine date de commande : N/A<br />
<br />
<br />
Commande livrée en cours de distribution : SF_001<br />
<br />
<br />
TVA, frais de port et droits de douane + frais pour dossier de dédouanement : selon taille totale de la commande finale, seront ventilés au pro-rata du montant commandé par chacun.<br />
<br />
Anciennes commandes SparkFun Electronics archivées [[Projets:Commande_groupee:archives#SparkFun Electronics|ici]]<br />
<br />
<br />
{|class="wikitable sortable" style="font-size:85%"<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref SparkFun!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
|-<br />
--><br />
|Damien H||Spark Gap Igniter - 4.8V||COM-11218||3||$14,95||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Pilou||MIDI Shield||DEV-09595||1||$19,90||<Damien H>||SF_001||N||O||O||O<br />
|-<br />
|Pilou||OpenServo||ROB-09014||2||$14,95||<Damien H>||SF_001||N||O||O||O<br />
|-<br />
|Pilou||Breakout Board for PCF8575 I2C Expander||BOB-08130||1||$11,95||<Damien H>||SF_001||N||O||O||O<br />
|-<br />
|MAZ24||wire stripper||TOL-08696||1||$4,95||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|MAZ24||flush cutter||TOL-11952||1||$6,95||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Eric||Optical Dust Sensor - GP2Y1010AU0F||COM-09689||1||$11,95||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Eric||Mating Connector Housing for Dust Sensor (JST ref#: ZHR-6)||PRT-09690||2||$0,35||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Eric||Crimp Pins for Dust Sensor Connector (JST ref#: SZH-002T-P0.5)||PRT-09728||16||$0,09||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Eric||Copper Tape - 2" (50ft)||PRT-11081||1||$14,95||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Olga||RaspiRobot Board||KIT-11561||1||$29,95||<Damien H>||SF_001||N||O||N||O<br />
|-<br />
|Dom||Copper Tape - 2" (50ft)||PRT-11081||1||$14,95||||SF_002||N||N||N||N<br />
|-<br />
|Jean-Marc (PdM) || Polymer Lithium Ion Battery - 400mAh || PRT-10718 || 1 || $6.95 || || SF_002 || N || N || N ||N<br />
|-<br />
|Jean-Marc (PdM) || SparkFun USB LiPoly Charger - Single Cell || PRT-12711 || 1 || $14.95 || || SF_002 || N || N || N ||N<br />
|-<br />
|Jean-Marc (PdM) || Precision Disc Wheel - 5" (Yellow, 2 Pack) || ROB-12469 || 1 || $6.29 || || SF_002 || N || N || N ||N<br />
|-<br />
|Jean-Marc (PdM) || Set Screw Hub - 3mm Bore || ROB-12512 || 2 || $4.99 || || SF_002 || N || N || N ||N<br />
|-<br />
|Jean-Marc (PdM) || ProtoBoard - Square 2" || PRT-08811 || 1 || $2.95 || || SF_002 || N || N || N ||N<br />
|-<br />
|Jean-Marc (PdM) || Micro Gearmotor - 90 RPM (6-12V) || ROB-12285 || 2 || $12.95 || || SF_002 || N || N || N ||N<br />
|- <br />
|Jean-Marc (PdM) || SparkFun Solderable Breadboard - Mini || PRT-12702 || 1 || $2.95 || || SF_002 || N || N || N ||N<br />
|- <br />
|}<br />
<br />
=== Subtel.fr ===<br />
<br />
Pas de frais de port, prix TVA comprise<br />
<br />
<br />
<br />
<br />
Anciennes commandes Subtel.fr archivées [[Projets:Commande_groupee:archives|ici]]<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Subtel!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Archive (O/N)<br />
|-l<br />
|-<br />
|}<br />
<br />
=== raspberry-pi-zero ===<br />
Une opportunité dégotée par Francis: une version du raspberry-pi, un peu spartiate, pour 5 euros!<br />
https://www.raspberrypi.org/blog/raspberry-pi-zero/<br />
<br />
On peut également acheter le kit: http://swag.raspberrypi.org/collections/pi-kits/products/pi-zero-cables<br />
C'est le cordon midi-hdmi/hdmi, PLUSSE la barrette gpio.<br />
<br />
Cette entrée est mise en place alors que tout n'est pas défini pour cet achat: ni le fournisseur (fournisseur initial en rupture de stock), ni le prix.<br />
Mais ce sera le support pour rassembler les commandes. Je tiendrai ce paragraphe à jour selon les infos.<br />
<br />
Le kit comprend l'adaptateur micro-hdmi/hdmi (1 cordon + 1 petit adaptateur?), et la barette 2x20, à souder, pour les gpio. Le raspberry n'est pas dans le kit!<br />
<br />
Le prix: 5 euros le kit, idem le raspberry, et quelques pourcent pour les frais de transport. <br />
<br />
(ce soir: site http://swag.raspberrypi.org/ down; ??)<br />
<br />
<br />
On peut aussi attendre 3 semaines le temps que cela soit livré directement chez vous et avoir<br />
<br />
- l'adaptateur micro hdmi mâle- hdmi femelle : http://www.banggood.com/Gold-Plated-Micro-HDMI-Type-D-Male-To-HDMI-Female-Adapter-p-974265.html<br />
<br />
- un adaptateur micro-hdmi vers VGA femelle sans le son : http://www.banggood.com/1080P-HDMI-Male-To-VGA-Female-Adapter-Video-Converter-Cable-p-937626.html<br />
<br />
- un adaptateur micro-hdmi vers VGA femelle avec le son : http://www.banggood.com/Sin-Hon-SH-MH2V02-Micro-HDMI-to-VGA-Cable-Adapter-with-Audio-p-907524.html<br />
<br />
- un adaptateur micro usb coudé(pratique pour ranger sur le côté : http://www.banggood.com/Micro-USB-Host-OTG-Cable-For-Samsung-HTC-p-79909.html<br />
<br />
- pour se faire une prise alim micro usb, on déboîte le capot et on soude : http://www.banggood.com/USB-2_0-Micro-B-Male-to-Mini-B-Female-5-Pins-Adapter-p-956044.html<br />
<br />
- toutes sortes d'alim : http://www.banggood.com/search/usb-2a-charger.html<br />
<br />
- de quoi s'amuser avec les GPIO : http://www.banggood.com/search/gpio-raspberry/1091-0-0-0-0-0-0-price-0-0_p-1.html<br />
<br />
Et si vous avez le temps de chercher c'est encore moins cher sur http://fr.aliexpress.com/<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| raspberry ou kit !! class="unsortable"| Quantité !! class="unsortable"| Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Archive (O/N)<br />
|-l<br />
|-<br />
!Pierre Grommit !!raspb !! 2 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!Pierre Grommit !!kit !! 1 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!Francis Roussel !!rasp !! 2 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!papy F1CHF !!kit !! 4 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!PDA !!rasp !! 3 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!yvs Accard !!rasp !! 3 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!yvs Accard !!Kit !! 1 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!Malek H. !!3 rasp + 2 vga son + 1 gpio + 1 otg !! 1 !! 1 !! n!! n !!n !! n!!<br />
<br />
<br />
|}<br />
<br />
<br />
=== Starterkit FPGA Altera Max10 ===<br />
'''COMMANDE CLOSE'''<br />
<br />
[https://www.arrow.com/en/products/bemicromax10/arrow-development-tools#page-1 Carte de démarrage FPGA] qui sera parfait pour les [[Formations#Initiation_.C3.A9lectronique_num.C3.A9rique_et_FPGA|formation initiation à venir]].<br />
<br />
Cette carte utilise un FPGA entrée de gamme MAX 10 de chez Altera. Elle contient tout un tas de périphériques sympa pour débuter.<br />
<br />
A noter que la board intègre une sonde JTAG Altera Blaster II (>200€ dans le commerce, 20€ pour un clone).<br />
<br />
Le prix: $30 le kit, disons donc 30€ (à réajuster à la baisse post commande). <br />
<br />
Date butoir pour la commande: mercredi 6 avril 2016<br />
<br />
Chip principal: MAX® 10 FPGA (10M08DAF484C8G):<br />
* 8,000 LEs (largement de quoi mettre le soft core 32bit Altera & des périphériques confortables)<br />
* 414 Kbit (Kb) M9K memory<br />
* 256 Kbit (Kb) user flash memory<br />
* 2 phase locked loops (PLLs)<br />
* 24 18x18-bit multipliers<br />
* 1 ADC block – 1 MSa/sec, 12-bit, 18-channels<br />
* 17 analog inputs<br />
* 1 temperature sense diode<br />
* 250 general purpose input/output (GPIO)<br />
* Non-volatile self-configuration with dual-boot support<br />
* Clocking circuitry: 50 MHz oscillator and 24 MHz oscillator<br />
* achetable à l'unité (moins cher de la gamme: 3€, celui ci, 30€)<br />
<br />
External peripherals<br />
* 8MB SDRAM (4Mb x 16) (ISSI IS42S16400)<br />
* Accelerometer, 3-Axis, SPI interface (Analog Devices ADXL362)<br />
* DAC, 12-bit, SPI interface (Analog Devices AD5681)<br />
* Temperature sensor, I2C interface (Analog Devices ADT7420)<br />
* Thermal resistor<br />
* Photo resistor<br />
* 8 user LEDs<br />
* 2 user Pushbuttons<br />
<br />
Prototyping<br />
* Two 6-pin PMOD expansion headers<br />
* Two 40-pin prototyping headers which provide access to 64 digital I/O<br />
* 6 analog inputs<br />
* One 80-pin BeMicro card edge connector<br />
<br />
<br />
Merci d'ajouter votre nom et votre rapport à l'éventualité de formations au lab:<br />
* débutant, intermédiaire, expert: sous entendu je veux assister à une formation & j'ai ce niveau<br />
* formateur: je suis volontaire pour participer à l'élaboration de formations<br />
* pas intéressé: ni en participant ni en formateur<br />
<br />
Merci d'indiquer:<br />
* combien vous en achetez à titre perso (30€ pièce, à revoir selon le change & port)<br />
* si vous voulez en prendre une à offrir aux formations du lab (vous payez 20€, moi 10€ ; il nous faut 10 cartes)<br />
<br />
<br />
'''MISE A JOUR RECEPTION'''<br />
Prix total 40€/carte. 25€ par carte offerte au lab. Merci de vous mettre à jour, et venez récupérer vos cartes auprès de Coline :)<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Formation? !! class="unsortable"| Quantité !! class="unsortable"| cadeau au lab !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Archive (O/N)<br />
|-l<br />
|-<br />
|-<br />
!flax !!formateur!! 1 !! non !! O!! n !!n !! n!!<br />
|-<br />
!flax !!formateur!! 1 !! oui !! O!! n !!n !! n!!<br />
|-<br />
!Clem !!formateur!! 1 !! N/A !! O!! n !!n !! n!!<br />
|-<br />
!3dsman!!débutant !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
!3dsman!!débutant !! 1 !! oui !! n!! n !!n !! n!!<br />
|-<br />
!Yann D!!débutant !! 2 !! non !! n!! n !!n !! n!!<br />
|-<br />
!Yannick A.!!formateur !! 1 !! oui !! n!! n !!n !! n!!<br />
|-<br />
!Yannick A.!!formateur !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
!F1HSU!!débutant !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
!Roul!!formateur? !! 1 !! oui !! n!! n !!n !! n!!<br />
|-<br />
!Roul!!formateur? !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
!Jojo du VoLAB !!intermédiaire !! 2 !! non !! n!! n !!n !! n!!<br />
|-<br />
!Jojo du VoLAB !!intermédiaire !! 1 !! oui !! n!! n !!n !! n!!<br />
|-<br />
!MrPozor !!débutant !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
!Julien Len!!débutant !! 1 !! oui? !! n!! n !!n !! n!!<br />
|-<br />
!Julien Len!!débutant !! 1 !! non!! n!! n !!n !! n!!<br />
|-<br />
!Jérôme Loï!! débutant !! 1? !! oui !! O(payé 30)!! n !!n !! n!!<br />
|-<br />
!Jérôme Loï!! débutant !! 1 !! non!! O!! n !!n !! n!!<br />
|-<br />
!Moala!!débutant !! 1 !! non !! O!! n !!n !! n!!<br />
|-<br />
!Desty!!debutant !! 1 !! oui !! n!! n !!n !! n!!<br />
|-<br />
!Desty!!debutant !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
<br />
!Votre nom!!type !! nombre !! oui/non !! n!! n !!n !! n!!<br />
<br />
<br />
<br />
|}<br />
Nombre de cartes total: 23 dont lab: 8 (total à mettre à jour !)</div>Erichttps://wiki.electrolab.fr/Projets:Commande_groupeeProjets:Commande groupee2018-09-17T09:53:55Z<p>Eric: /* Doga */</p>
<hr />
<div>=Commandes groupées=<br />
<br />
== Principe ==<br />
Tout projet a régulièrement besoin de matières premières, composants, fournitures diverses, etc. Le lab a en stock une quantité importante de fournitures plus ou moins courantes, mais cela ne peut remplacer des commandes régulières.<br />
<br />
Histoire de mutualiser les bons plans & regrouper les frais de port, profiter de divers price breaks, etc, cette page a été créee pour organiser des commandes groupées.<br />
<br />
== Glossaire ==<br />
===Demandeur===<br />
Celui qui a besoin d'un article<br />
<br />
===Acheteur===<br />
Celui qui passe effectivement la commande chez le Fournisseur. L'Acheteur peut être le lab ou une personne privée.<br />
Dans le cas du lab indiquer dans la colonne "acheteur" lab_<nom/pseudo membres> exemple : lab_peewee<br />
Sauf avis contraire, le paiement est à effectuer sur le compte paypal du lab.<br />
<br />
Dans le cas d'une personne privée, indiquer dans la colonne "acheteur", son nom ou pseudo.<br />
L'Acheteur définit lui même les moyens de paiement à utiliser par les <demandeurs>.<br />
<br />
<br />
===Distributeur===<br />
Fournisseur ou fabricant chez qui l'<acheteur> passe commande.<br />
Chaque <distributeur> dispose d'une rubrique propre.<br />
<br />
Il est bien entendu possible d'ajouter des <distributeurs> supplémentaires (notez qu'ils sont triés par '''ordre alphabétique''').<br />
<br />
== Règles du jeu ==<br />
<br />
En général, lorsque l'on s'occupe d'un "group buy", on fait un premier tour de<br />
table pour savoir qui est partant, on annonce ensuite le prix de l'addition<br />
générale (TTC et frais d'expé avec ou sans assurance, éventuels frais de<br />
dédouanement) divisée par le nombre de participants (au prorata des volumes<br />
de commande : celui qui achète 2 items paye 2 parts de frais de port par<br />
exemple).<br />
<br />
Ceci fait, on attend qu'une "masse critique" soit atteinte lorsque l'on vise<br />
certains "price break" (décollonage en jargon de vendeur), puis on lance<br />
l'appel aux fonds avec une date butoir. Passé la date butoir, la commande<br />
est passée, en ignorant ceux qui n'ont pas répondu a temps, puisque le<br />
responsable de group buy n'a pas la trésorerie correspondant à l'achat en<br />
question.<br />
Les histoires genre "le chèque est au courrier" ne marchent pas avec des<br />
virements Paypal... le patron des achats sait exactement combien il a en<br />
caisse au moment de la commande.<br />
<br />
En cas de perte de colis, le responsable de "group buy" n'est pas<br />
redevable. C'est à chaque participant d'estimer s'il prend le risque ou non<br />
de faire confiance aux entreprises assurant l'acheminement des colis.<br />
C'est simple, et si c'est précisé, aucun conflit n'est à redouter, aucun lot<br />
ne reste sur les bras de l'<acheteur>.<br />
<br />
Pour le paiement par avance, celui-ci peut se faire au lab, mais c'est TTC et AVEC les frais de port et de douane, le cas échéant.<br />
<br />
Si un <demandeur> commande la mauvise référence, c'est pour sa pomme.<br />
<br />
Dans la mesure du possible, les <demandeur> doivent faciliter au maximum le travail des <acheteur> en indiquant des références d'articles et de désignation claires.<br />
<br />
==Mode opératoire lorsqu'on passe une commande chez l'un des distributeurs ==<br />
Les tableaux ci-après (un tableau par <distributeur> disposent des colonnes nécessaires à la synchronisation des commandes article par article.<br />
<br />
De même, chaque rubrique dispose d'un en-tete d'information qui a la structure suivante :<br />
<br />
La prochaine commande a pour référence interne : YY_xxx<br />
Prochaine date de commande : <non défini><br />
Commande livrée en cours de distribution : [aucune]<br />
Anciennes commandes <nom du distributeur> archivées [[Projets:Commande_groupee:archives|ici]]<br />
< informations complémentaires notamment en ce qui concerne les conditions de livraison, etc>''<br />
<br />
YY est un code fixe, unique pour chaque founisseur.<br />
<br />
xxx un le n° de commande pour ce distributeur. Il commence à 001 et s'incrémente à chaque commande.<br />
<br />
<br />
===Les différentes étapes de la commande ===<br />
<br />
====Prise en charge d'un commande par un <acheteur>==== <br />
La personne qui souhaite prendre en charge une commande chez un <distributeur> envoie un mail sur la ML pour informer tout le monde de cette action.<br />
Dans l'entête d'information du <distributeur> concerné, l'<acheteur> effectue les modifications suivantes :<br />
*mise à jour de la ligne ''Prochaine date de commande'' : valorisé à la date à laquelle il envisage de passer la commande auprès du <distributeur>. <br />
<br />
À ce moment, l'ensemble des <demandeurs> concernés se met en relation avec l'<acheteur> pour lui payer d'avance les articles commandés. Pour ces articles, l'<acheteur> fait les modifications suivantes dans le tableau des articles :<br />
*''Payé d'avance (O/N)'' : valorisé à "O" (Oui)<br />
<br />
<br />
====Passage effective de la commande par l'<acheteur>==== <br />
<br />
Celui qui passe la commande ( = <acheteur>) sélectionne les articles qu'il commande effectivement (= ceux pour lesquels il a reçu le paiement en avance). Il peut aussi inclure dans la commande des articles de <demandeurs> pour leuquel il est certain d'être payé au moment de la distribution.<br />
<br />
L'<acheteur> passe la commande auprès du distributeur (par internet, mail, téléphone, télécopie, signaux de fumée, déplacement sur place...) et effectue le paiement à l'aide d'un moyen de paiement à sa convenance. Il est judicieux de priviléger des moyens de paiement fournissant la traçabilité de la transaction.<br />
<br />
Pour les articles effectivement COMMANDÉS l'<acheteur> fait les modifications suivantes dans le tableau des articles :<br />
*'' Acheteur'' : valorisé par son nom/pseudo <br />
*''Commandé (O/N)'' : valorisé à "O" (Oui)<br />
<br />
Pour les articles qui n'ont pas déja été concernés par une commande précédente et que l'<acheteur> ne COMMANDE PAS (par exemple par ce que le <demandeur> ne s'est pas manifesté auprès de lui), il fait les modifications suivantes dans le tableau des articles :<br />
*''N° de commande'' : est incrémenté d'une unité afin que cet article non commandé soit inclus dans la prochaine commande.<br />
<br />
<br />
*mise à jour de la ligne ''Prochaine date de commande'' : valorisé à <non défini><br />
*mise à jour de la ligne ''La prochaine commande a pour référence interne'' : valorisé au numéro de commande interne actuel +1 <br />
*mise à jour de la ligne ''Commande passée en attente de livraison'': valorisé au n° de commande actuel<br />
<br />
====Réception de la commande par l'<acheteur>==== <br />
<br />
<br />
Au moment de la réception du colis, l'<acheteur> vérifie si la livraison est complète et négocie avec le <distributeur> en cas de problème. Il peut aussi informer le <demandeur> concerné par le ou les article(s) en litige ou manquants.<br />
<br />
====Distribution des articles aux <demandeurs>====<br />
Lorsque la distribution peut commencer l'<acheteur> effectue les modifications suivantes dans l'entête d'information du <distributeur> concerné :<br />
*mise à jour de la ligne : '' Commande passée en attente de livraison'' à [aucune]<br />
*mise à jour de la ligne : '' Commande livrée en cours de distribution '' avec la référence interne de la commande.<br />
<br />
L'<acheteur> informe via la ML les <demandeurs> du début de la distribution de la commande <référence interne de commande>.<br />
Chaque <demandeur> convient d'un RDV avec l'<acheteur> pour récupérer les articles (en principe cela se passe au lab) et payer son dû à l'<acheteur>, si ce n'est déja fait.<br />
<br />
Pour chaque article l'<acheteur> fait les modifications suivantes dans le tableau des articles :<br />
*'' Distribué (O/N)'' : valorisé à "O" (Oui) <br />
*''Remboursé/Archivé (O/N)'' : valorisé à "O" (Oui)<br />
<br />
====Ditribution des articles terminée====<br />
<br />
Une fois l'ensemble des pièces distribuées et payées, dans l'entête d'information du <distributeur> concerné, l'<acheteur> effectue les modifications suivantes :<br />
*mise à jour de la ligne ''Commande livrée en cours de distribution'' : valorisé à [aucune]<br />
<br />
<br />
===En conclusion ===<br />
<br />
Si les tableaux des commandes et les en-tête d'information sont gérés avec soin, il n'y a quasiment aucun risque de double commande et n'importe quel membre sait où on en est et peut à tout moment prendre la main sur l'un des tableaux d'achats pour commander un article ou organiser une commande en tant qu'<acheteur>. La bonne application de ces quelques recommandation bénéficie à l'ensemble des participants de ce système de commandes groupées.<br />
<br />
Sauf besoin urgent de pièces, il est bénéfique que ce soit de préférence les mêmes <acheteurs> qui officient auprès des mêmes <distributeurs>. Ainsi, vu de ces derniers, l'<acheteur> est très vite identifié comme "client important" (car en réalité il commande pour 5-10 personnes, voire plus) et peut bénéficier de conditions particulières (frais de port gratuit, -15% sur la prochaine commande, etc).<br />
<br />
Enfin, à tout moment en tant que <demandeur>, soyez diligent envers l'<acheteur> dont la gestion d'une commande de parfois plusieurs dizaines d'articles requert un investissement en temps non négligeable.<br />
<br />
== Commandes groupées passées (archives) ==<br />
<br />
Afin d'améliorer la lisibilité nous avons regroupé les commandes passées sur cette page: [[Projets:Commande_groupee:archives]]<br />
<br />
== Commandes groupées en cours ==<br />
<br />
=== BHV ===<br />
<br />
La prochaine commande a pour référence interne : BH_003<br />
<br />
<br />
<br />
Commande livrée en cours de distribution : [aucune] <br />
<br />
Anciennes commandes BHV archivées [[Projets:Commande_groupee:archives#BHV|ici]]<br />
<br />
achat sur place<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref BHV!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
<!-- Pour ajouter une ligne, copier les 2 lignes suivantes (celles qui commencent par | ) à la suite du tableau et remplacer le contenu des colonnes par ce qui semblera adéquat<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| Lab|| Réglet métallique 30cm || - || 3 || 5.90€||Eric|| BH_001 || N || O || O || O<br />
|-<br />
|-<br />
| Lab|| Scie a métaux FACOM 603E || - || 1 || env. 36€||Eric|| BH_002 || N || O || 0 || O<br />
|-<br />
! !! !! !! !! !! !! !! !! !! !!<br />
|}<br />
<br />
=== [http://www.visseriefixations.fr/ Cergy-Vis] ===<br />
<br />
<br />
La prochaine commande a pour référence interne : CV_002<br />
<br />
<br />
<br />
<br />
Anciennes commandes Cergy-Vis archivées [[Projets:Commande_groupee:archives|ici]] <br />
<br />
Retrait gratuit sur place<br />
CERGY-VIS<br />
<br />
17, Rue du Périgord<br />
<br />
ZI des Béthunes<br />
<br />
95310 SAINT OUEN L’AUMONE<br />
<br />
<br />
Horaires pour les enlèvements: Du Lundi au Vendredi, de 7h30 à 12h00 et de 13h30 à 17h30.<br />
<br />
<br />
Livraison<br />
Colissimo Régional (0.05kg / France) 5,75 €<br />
<br />
Colissimo Régional (0.2888kg / France) 6,54 €<br />
<br />
Colissimo Régional (2.87kg / France) 9,25 €<br />
<br />
Colissimo Régional (12.8948kg / France) 16,50 €<br />
<br />
Anciennes commandes Cergy-Vis archivées [[Projets:Commande_groupee:archives#Cergy-Vis|ici]]<br />
<br />
<br />
|-<br />
!Demandeur !! class="unsortable"| Description !! Référence!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-<br />
||Eric|| TRCC M5X30 INOX A2 DIN 603|| ||50||0.17EURTTC||<acheteur>||CV_001||N||O||O||N (attends remb. trop versé)<br />
|-<br />
||Eric|| ECROU HU M12 PAS 100 Z.BLANC DIN 934|| ||20||0.39EURTTC||<acheteur>||CV_001||N||O||O||N (attends remb. trop versé)<br />
|-<br />
||Eric||Vis TCHC M5X22 INOX A2 EF DIN 912||TCHC05/022A2EF||15||0.12EURTTC||<acheteur>||CV_002||N||N||N||N<br />
|-<br />
||Eric||Vis STHC PLAT M6X12 INOX A2 DIN 913||STHCPLA06/012A2||30||0.06EURTTC||<acheteur>||CV_002||N||N||N||N<br />
|-<br />
||Eric||Vis TH M6X12 INOX A2 EF DIN 933||TH06/012A2EF||30||0.09EURTTC||<acheteur>||CV_002||N||N||N||N<br />
|-<br />
|}<br />
<br />
=== [http://www.conradpro.fr Conrad Electronique France] ===<br />
<br />
<br />
La prochaine commande aura pour référence interne : CO_017<br />
<br />
Prochaine date de commande :<br />
<br />
Commande passée en attente de livraison : NEANT<br />
<br />
Commande livrée en cours de distribution : NEANT<br />
<br />
Anciennes commandes Conrad Electronique France archivées [[Projets:Commande_groupee:archives#Conrad Electronique France|ici]]<br />
<br />
{| class="wikitable sortable" style="font-size:85%"<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Conrad!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€ ||<Acheteur>|| CO_XXX || N || N || N || N<br />
|-<br />
--><br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/822746/Fil-de-soudure-pour-PVC-rigide-Steinel-073114-26-pcs Fil de soudure pour PVC rigide Steinel 073114 26 pcs]</s>||<s>822746 - 62 </s>||<s> 1 </s>||<s> € 5.99 TTC</s>||<s><acheteur> </s>||<s> CO_014 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/492161/Soudure-plastique-225-mm-4-mm-polythylne-LDPE-nature-Bosch-1609201811 Soudure plastique, 225 mm, 4 mm, polyéthylène (LDPE) nature Bosch 1609201811]</s>||<s>492161 - 62 </s>||<s> 1 </s>||<s> € 15.99 TTC</s>||<s> <acheteur> </s>||<s> CO_014 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/121588/Solution-de-conservation-pour-electrodes-de-mesure-pH-HI-70300M Solution de conservation pour électrodes de mesure pH HI 70300M]</s>||<s>121588 - 62 </s>||<s> 1 </s>||<s> € 15.12 TTC</s>||<s> <acheteur> </s>||<s> CO_014 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/121586/Solution-de-nettoyage-pour-electrodes-pH-HI-7061M Solution de nettoyage pour électrodes pH HI 7061M]</s>||<s>121586 - 62 </s>||<s> 1 </s>||<s> € 15.12 TTC</s>||<s> <acheteur> </s>||<s> CO_014 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|Eric||[http://www.conrad.fr/ce/fr/product/121164/Sol-de-conduct-12880-S-HI-70030-P Sol. de conduct. 12880 µS HI 70030 P]||121164 - 62 || 1 || € 38.30 TTC|| <Pat> || CO_014 || N || O || O || O<br />
|-<br />
|Eric||[http://www.conradpro.fr/ce/fr/product/822188/Knipex-Pinces-pour-circlips-pour-colliers-dtranglement-darbre-46-11-G0-140-mm?ref=searchDetail Pince KNIPEX 46 11 G0]||822188 - 62 || 1 || € 20.13 HT|| <Pat> || CO_014 || N || O || O || O<br />
|-<br />
|Eric||[http://www.conradpro.fr/ce/fr/product/822189/Knipex-Pinces-pour-circlips-pour-colliers-dtranglement-darbre-46-11-G1-140-mm?ref=searchDetail Pince KNIPEX 46 11 G1]||822189 - 62 || 1 || € 13.02 HT|| <Pat> || CO_014 || N || O || O || O<br />
|-<br />
|MrPozor||[http://www.conrad.fr/ce/fr/product/702246/Interrupteur-de-porte-Panasonic-AZC11113HJ-250-VAC-5-A-poussoir-momentan-IP40-1-pcs?ref=searchDetail Interrupteur de porte Panasonic AZC11113HJ]||702246 - 62 || 1 || € 10.99 TTC|| <Pat> || CO_014 || N || O || N || N<br />
|-<br />
| papy F1CHF || 74HC390 SOIC || 1115010-62 || 10 || 1.06€ ||<Pat>|| CO_014 || O || O || O || O<br />
|-<br />
| Pat|| Condo moteur 5uF 450V || 441527-62 || 1 || 6.33€ H.T. ||<Pat>|| CO_014 || O || O || N || N<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/731484/Adaptateur-avec-fiche-dor-32-A-rouge-MultiContact-240160-22 Adaptateur avec fiche doré 32 A rouge MultiContact Ref. 24.0160-22]|| 731484 - 62 || 2 || 3.00 € H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/731559/Disque-de-marquage-couleur-MultiContact-145010-vert-jaune-1-pcs Disque de marquage couleur MultiContact Ref. 14.5010 vert-jaune 1 pc(s)]|| 31559 - 62 || 3 || 0.75 € H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/106109/Pointe-de-touche-de-scurit-MultiContact-XMA-7L-enfichable-4-mm-CAT-IV-1000-V-bleu Pointe de touche de sécurité MultiContact XMA-7L enfichable 4 mm CAT IV 1000 V bleu Ref. MC 66.9509-23]|| 106109 - 62 || 1 || 15.96 € H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/106108/Pointe-de-touche-de-scurit-MultiContact-XMA-7L-enfichable-4-mm-CAT-IV-1000-V-rouge Pointe de touche de sécurité MultiContact XMA-7L enfichable 4 mm CAT IV 1000 V rouge Ref. MC 66.9509-22]|| 106108 - 62 || 1 || 15.96 € H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/106107/Pointe-de-touche-de-scurit-MultiContact-XMA-7L-enfichable-4-mm-CAT-IV-1000-V-noir Pointe de touche de sécurité MultiContact XMA-7L enfichable 4 mm CAT IV 1000 V noir Ref. MC 66.9509-21]|| 106107 - 62 || 1 || 15.96 € H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/1385649/Pince-crocodile-4-mm-GRIP-FMA-MultiContact-669435-21 Pince crocodile 4 mm GRIP-FMA MultiContact Ref. 66.9435-21]|| 1385649 - 62 || 1 || 30.00€ H.T. ||<acheteur>|| CO_015 || N || O || O || O<br />
|-<br />
| Damien H || MOSFET RFD14N05L || 512-RFD14N05L || 5 || 0,695 € ||?|| CO_015 || N || O || O || O<br />
|-<br />
| Damien H || Zener BZX79C2V4 || 512-BZX79C2V4 || 5 || 0,11 € ||?|| CO_015 || N || O || O || O<br />
|-<br />
|Pierre G|| Câble audio SpeaKa 1m mf||986736 - 62 || 2||6,66 ht || ? || CO_015 || N || O || O || O<br />
|-<br />
|Pierre G|| Câble audio SpeaKa 0,50m mf||986735 - 62 || 1||5.92 ht || ? || CO_015 || N || O || O || O<br />
|-<br />
|Pierre G|| Lentille Dialight OPC-11SPOT transparent 10 ° 1 pc(s)||1127266 - 62 || 1||3 ht || ? || CO_016 || N || O || O || O<br />
|-<br />
|Pierre G|| LED High Power Barthelme 61003528 blanc chaud||1503528 - 62 || 1||3,50 ht || ? || CO_016 || N || O || O || O<br />
|-<br />
|FredericD|| [http://www.conrad.fr/ce/fr/product/574223/Transformateur-electronique-Standard-10-a-60-W Transformateur électronique "Standard" 10 à 60 W]||574223 - 62 || 1||15,49 '''TTC''' || <acheteur> || CO_017 || N || N || N || N<br />
|-<br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/542044/?insert=32&insertNoDeeplink&productname=Gaine-thermoretractable-pour-batteries-sans-colle-21-Conrad-Components-542044-transparent-avant-retreint-44-mm-1-pc Gaine thermorétractable 2:1 transparente pour accus longueur 100 cm largeur 44mm]</s>||<s>542044 - 32</s>||<s>3</s>||<s>2,70€TTC</s>||<s> <acheteur> </s>||<s> CO_017 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|<s>Eric</s>||<s>[http://www.conrad.fr/ce/fr/product/100297/Solution-conductrice-1413-S-HI-70031-P?ref=list Solution conductrice 1413 µS HI 70031 P]</s>||<s>100297 - 62 </s>||<s> 1 </s>||<s> € 33,60 TTC</s>||<s> <acheteur> </s>||<s> CO_017 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
|<s>Eric</s>||<s>[http://www.conradpro.fr/ce/fr/product/1305022/Diode-Zener-PanJit-1N4740A-G-DO-41G-Tension-Zener-10-V-1-pcs?ref=searchDetail Diode Zener PanJit 1N4740A-G DO-41G Tension Zener: 10 V]</s>||<s>1305022 - 62 </s>||<s> 10 </s>||<s> € 0,15 TTC</s>||<s> <acheteur> </s>||<s> CO_017 </s>||<s> N </s>||<s> N </s>||<s> N </s>||<s> N</s><br />
|-<br />
| Eric||[http://www.conradpro.fr/ce/fr/product/812811/tain-de-soudure-teneur-en-plomb-Stannol-HS-10-Sn60Pb39Cu1-bobine-100-g-10-mm?queryFromSuggest=true étain 100g 1mm STANNOL]|| 812811 - 62 || 2 || 7,55 € H.T. ||<acheteur>|| CO_017 || N || N || N || N<br />
|-<br />
|Eric||[http://www.conrad.fr/ce/fr/product/651105/XLR-Bride-mle-contacts-couds-Neutrik-NC3MAAH-Nombre-de-ples-3-noir-1-pcs?queryFromSuggest=true Connecteur XLR mâle plastique pour chassis soudage pour CI 3 broches coudé + blindage, NEUTRIK NC3MA(A)H ]||651105 - 62|| 2 || 1,20€TTC ||<acheteur>||CO_017||N||N||N||N <br />
|-<br />
|}<br />
<br />
Anciennes commandes Conrad archivées [[Projets:Commande_groupee:archives#Conrad_Electronique_France|ici]]<br />
<br />
=== [http://www.damencnc.com/fr DamenCNC] ===<br />
<br />
Accessoires pour machines CNC [http://www.damencnc.com]<br />
<br />
La prochaine commande a pour référence interne : DC_002<br />
<br />
Prochaine date de commande : ?? (probablement en octobre 2014)<br />
<br />
<br />
<br />
Livraison : depuis les Pays-Bas par UPS : estimation : 20€ pour un colis de 1.5kg<br />
<br />
ATTENTION : Prix HT.<br />
<br />
Anciennes commandes DamenCNC archivées [[Projets:Commande_groupee:archives#DamenCNC|ici]]<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref DamenCNC!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||<Acheteur>|| OT_XXX || N || N || N || N<br />
|-<br />
--><br />
|-<br />
|Goldo|| HIWIN HGR Profile Rail L=200mm || HG15R || 2 || 21,60€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|Goldo|| HIWIN Carriage HGH "Compact type" || HGH-15CA || 2 || 33.99€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|Goldo|| Mini Mill 2 flutes 0.20mm || ? || 1 || 11.99€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|Goldo|| Mini Mill 2 flutes 0.30mm || ? || 1 || 11.99€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|Goldo|| Mini Mill 2 flutes 0.50mm || ? || 1 || 9.99€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|Goldo|| Kress Collet + Clamp Nut 1/8inch || ? || 1 || 19.99€HT || Goldo || DC_001 || O || O || O || O<br />
|-<br />
|F1CHF|| Mini Mill 2 flutes 0.50mm || ? || 2 || 9.99€HT || Goldo || DC_001 || N || O || O || O<br />
|-<br />
|F1CHF|| Mini Mill 2 flutes 0.70mm || ? || 2 || 9.99€HT || Goldo || DC_001 || N || O || O || O<br />
|-<br />
|Eric||IPS_Cable_Assembly M12_Straight_Female/OPENEND_3meter || ? || 2 || 4.99€HT || <acheteur>|| DC_002 || N || N || N || N<br />
<br />
|}<br />
<br />
===[http://www.detandt.com/fr Detandt-Simon]===<br />
<br />
La prochaine commande aura pour référence interne : DET_001 <br />
<br />
Prochaine date de commande : Mardi 2/2/2016<br />
<br />
<br />
Commande livrée en cours de distribution : [nada] <br />
<br />
Anciennes commandes Detandt archivées [nope]<br />
<br />
Frais de livraisons: inconnu<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Taille !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!!Remboursé/Archive (O/N)<br />
|-<br />
<!-- Pour ajouter une ligne, copier les 2 lignes suivantes (celles qui commencent par | ) à la suite du tableau et remplacer le contenu des colonnes par ce qui semblera adéquat--><br />
| Steve|| Modèle haut Bleu et gris || Taille 44 || 1|| 15€ HT||Steve|| DET_001 || N || N || N || N<br />
|-<br />
| Steve|| Modèle haut Bleu et gris || Taille 45 || 1|| 15€ HT||Steve|| DET_001 || N || N || N || N<br />
|-<br />
| Laurent d. Lo^2 || Modèle haut orange et noir || Taille 44 || 1|| 15€ HT||Laurent|| DET_001 || N || N || N || N<br />
|-<br />
| Laurent d. Lo^2 || Modèle cuir noir || Taille 44 || 1|| 15€ HT||Laurent|| DET_001 || N || N || N || N<br />
|-<br />
| Beatrice/LK999 || Modèle cuir noir ou bas || Taille 45|| 1|| 15€ HT||XXX|| DET_001 || N || N || N || N<br />
|-<br />
| Le Xav || Modèle noir & orange haut || Taille 45|| 1|| 15€ HT||XXX|| DET_001 || N || N || N || N<br />
|-<br />
| Patrick|| 10m gaine VMC alu D80 M0|| HALUM0 82|| 2|| 13,78€ HT||XXX|| DET_002 || N || N || N || N<br />
|-<br />
| Patrick|| 10m gaine VMC alu D125 M0|| HALUM0 127|| 1|| 15,96€ HT||XXX|| DET_002 || N || N || N || N<br />
|-<br />
|}<br />
<br />
===[http://www.digikey.com/ Digikey Corporation]===<br />
<br />
La prochaine commande aura pour référence interne : DI_006<br />
<br />
<br />
Commande passée en attente de livraison : DI_005 <br />
<br />
Commande livrée en cours de distribution : NEANT <br />
<br />
Anciennes commandes Digikey Corporation archivées [[Projets:Commande_groupee:archives#Digikey Corporation|ici]]<br />
<br />
"PAS DE FRAIS POSTAUX sur toutes commandes avec une valeur de 65 Euro et plus.mais la DOUANE + frais"<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Digikey !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!!Remboursé/Archive (O/N)<br />
|-<br />
| Laurent(C) || Capa 470uF || 493-1493-ND || 24 || 0,229€||Laurent(C)|| DI_005 || || O || N || N<br />
|-<br />
| Laurent(C) || Carte NUCLEO-F303K8 || 497-15981-ND || 1|| 9,92€||Laurent(C)|| DI_005 || || O || N || N<br />
|-<br />
| Laurent(C) || Capa tantale 10uF || 478-8959-1-ND || 5|| 0.8€||Laurent(C)|| DI_005 || || O || N || N<br />
|-<br />
| Laurent(C) || PMIC 4V || MCP1702T-4002E/CBCT-ND|| 5|| 0.43€||Laurent(C)|| DI_005 || || O || N || N<br />
|-<br />
| Eric||[http://www.digikey.fr/product-search/fr?vendor=0&keywords=LT1677CS8%23PBF-ND LT1677 OPAMP S8 Package]|| LT1677CS8#PBF-ND || 4|| 3.95€||Laurent(C)|| DI_005 || O || O || N || N<br />
|-<br />
| Eric|| [http://www.digikey.com/product-detail/en/4664-6001/MPK64K-ND/138341 connecteur HE10 64 broches autodénudant mâle] || MPK64K-ND || 1|| 12.59€||Laurent(C)|| DI_005 || O || O || O || O<br />
|-<br />
| Eric|| [http://www.digikey.fr/product-detail/fr/DS2740U%2B/DS2740U%2B-ND/1197488 MAXIM coulombmetric counter DS2740U+ SMD]|| DS2740U+-ND || 1|| 3.90€||Laurent(C)|| DI_005 || O || O || O || O<br />
|-<br />
| Eric|| C190 case ||614-1102-ND||1||199,99USD||Laurent(C)|| DI_005 || O || N(export restriction!) || N || O<br />
|-<br />
| papy F1CHF || NB3N502 || NB3N502DGOS-ND ||4||2.99€||Laurent(C)|| DI_005 || N || O || O || O<br />
|-<br />
| Eric|| [http://www.digikey.com/product-detail/en/linear-technology/LT1763CS8-TRPBF/LT1763CS8-TRPBFCT-ND/4247570 LT1763CS8#TRPBF LT micropower low noise LDO ADJ regulator 500MA SO8]|| LT1763CS8#TRPBFCT-ND || 1|| 4.78USD||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| Eric|| [http://www.digikey.com/product-detail/en/linear-technology/LT1763CS8-3.3-TRPBF/LT1763CS8-3.3-TRPBFCT-ND/4247566 LT1763CS8-3.3#TRPBF LT micropower low noise LDO 3.3V regulator 500MA SO8]|| LT1763CS8-3.3#TRPBFCT-ND|| 2|| 4.78USD||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| Eric|| [http://www.digikey.fr/products/fr?keywords=BA5406 BA5406 Amplifier IC 2-Channel (Stereo) Class AB 12-SIP-M] ||BA5406-ND || 1|| 3.85 EUR||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| Eric|| [https://www.digikey.fr/products/fr?keywords=HR1732-ND HIROSE CONN PLUG 5POS W/PIN INSERT ref "RM12BPE-5PH(71)"] ||HR1732-ND || 1|| 11.19 EUR||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| Eric|| [https://www.digikey.fr/product-detail/fr/infineon-technologies/IRS2453DPBF/IRS2453DPBF-ND/1189713 INFINEON IC DRIVER FULL SELF OSC 14-DIP IRS2453DPBF] ||IRS2453DPBF-ND || 1|| 3.09 EUR||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| 3dsman|| US5881LUA Digital Switch Unipolar Switch Open Drain Hall Effect TO-92UA ||US5881LUA-AAA-000-BU-ND || 5|| 1.10 EUR||<acheteur>|| DI_006 || N || N || N || N<br />
|-<br />
| Debutant|| [https://www.digikey.fr/product-detail/fr/jst-sales-america-inc/SYF-001T-P0.6-LF-SN/455-2652-1-ND/2796952 JST Sales America Inc. SYF-001T-P0.6(LF)(SN) ] || 455-2652-1-ND || 100|| 0.05460 EUR|| Debutant || DI_006 || N || N || N || N<br />
|-<br />
| Lo2|| [https://www.digikey.fr/product-detail/en/molex-llc/0755860006/WM22014CT-ND/9095459 Molex Connecteur 50POS SMD] || WM22014CT-ND || 3|| 8.47 EUR|| Lo2 || DI_006 || N || N || N || N<br />
|-<br />
<br />
|}<br />
<br />
=== [http://www.doga.fr Doga] ===<br />
<br />
La prochaine commande aura pour référence interne : DO_004<br />
<br />
Prochaine date de commande : [inconnu]<br />
<br />
Commande passée en attente de livraison : [aucune]<br />
<br />
Commande livrée en cours de distribution : DO_003<br />
<br />
<br />
Minimum de commande : 50€ HT<br />
Franco : 100€ HT<br />
<br />
Merci de préciser le catalogue dans lequel se trouve l'article pour le retrouver plus aisément. <br />
<br />
Les principaux catalogues sont :<br />
* http://www.doga.fr/catalogue_pdf/ugv.pdf<br />
* http://www.doga.fr/catalogue_pdf/ugv-alliage-leger.pdf<br />
* [https://shop.precitool.de/bk/WKZ_2017-2018/#page_0.1 Precitool]<br />
<br />
Anciennes commandes Doga archivées [[Projets:Commande_groupee:archives#Doga|ici]]<br />
<br />
<br />
|-<br />
!Demandeur !! class="unsortable"| Description !!class="unsortable"| Ref Doga !! class="unsortable"| Catalogue !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!!Remboursé/Archive (O/N)<br />
<br />
<br />
|-<br />
| Eric||[http://shop.precitool.de/bk/HKL_2016-2017/#page_870 Ø 8mm Zylinderbürste mit Öse, Messingdraht gewellt marque : LESSMANN]|| 481772 || Precitool || 1 || 7 EURHT || <acheteur> || DO_002 || N || O || O || O<br />
|-<br />
| <s>Eric</s>||<s>[http://shop.precitool.de/bk/HKL_2015-2016/#page_1044 Kompakt-Bolzenscheider KNIPEX Mit Mehrkomponenten-Hülle, Öffnungsfeder, 20° abgewinkelt]</s>||<s> 559026</s> ||<s> Precitool </s>||<s> 1 </s>||<s> 40.45EURHT</s> ||<s> <acheteur> </s>||<s> DO_002 </s>||<s>N</s> ||<s>N</s>||<s> N </s>||<s> N</s><br />
|-<br />
| Eric||[http://shop.precitool.de/bk/HKL_2016-2017/#page_924 Strinlochschlüssel-Satz marque AMF]|| 506050|| Precitool || 1 || 31.05EURHT || <acheteur> || DO_002 || N || O || O || O<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1116 KNIPEX Montagezange Typ 4521 für Sprengringe auf Wellen (KNIPEX Ref 45 21 200)]||554175 /4521|| Precitool || 1 || 30,75EURHT || <acheteur> || DO_002 || N || O || O || O<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2016-2017/#page_1242 Schneidoel 500ml]||924055|| Precitool || 1 || 14,35EURHT || <acheteur> || DO_002 || N || O || O || O<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2016-2017/#page_1254 Luftweiche 3 Fach (4 x G3/8) Typ 0304]||925805/0304|| Precitool || 2 || 7.05EURHT || <acheteur> || DO_002 || N || O || O || O<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_35 Spiralbohrer HSS-Co Precitool D1897 INOX Dn 2,1mm]||100670/2,10|| Precitool || 5 || 1.91 EURHT || Lab || DO_003 || N || O || O (livré en 2.3mm, puis relivré gratuitement en 2,1mm) || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_815 Düsenlehre 0.45-1.5mm (0.05mm steigung)]||389850/20|| Precitool || 1 || 12.65 EURHT || Lab || DO_003 || N || O || O || N<br />
|-<br />
|Steve||[http://shop.precitool.de/bk/HKL_2017-2018/#page_987 Gelenk-Hakenschlüssel]||506350/22-35|| Precitool || 1 || 13.55 EURHT || Lab || DO_003 || N || N || N || N<br />
|-<br />
|Steve||[http://shop.precitool.de/bk/HKL_2017-2018/#page_987 Gelenk-Hakenschlüssel]||506350/35-60|| Precitool || 1 || 14.90 EURHT || Lab || DO_003 || N || N || N || N<br />
|-<br />
|Steve||[http://shop.precitool.de/bk/HKL_2017-2018/#page_987 Gelenk-Hakenschlüssel]||506350/60-90|| Precitool || 1 || 17.70 EURHT || Lab || DO_003 || N || N || N || N<br />
|-<br />
|Lab||[http://shop.precitool.de/bk/HKL_2017-2018/#page_985 Hakenschlüssel aus spezial Stahl Gehärtet und im Brunierton angelassen, pour Ø 95-100 mm, pour écrous DIN 1804 et DIN 981]||506200 95/100|| Precitool || 1 || 10,80 EURHT || Lab|| DO_003 || N || O || O (erreur de reference de commande) || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_985 Hakenschlüssel aus spezial Stahl Gehärtet und im Brunierton angelassen, pour Ø 95-100 mm, pour écrous DIN 1804 et DIN 981]||506200 95/100|| Precitool || 1 || 10,80 EURHT || Lab || DO_003 || N || O || O (erreur de reference de commande) || N<br />
<br />
|-<br />
|Lab||[http://shop.precitool.de/bk/HKL_2017-2018/#page_1153 Jeu de chasse-goupilles - Splintentreiber]|| 561110/6M || Precitool || 1 || 18.05 EURHT || Lab || DO_003 || N || N || N || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Linksausdreher Grosse 1 (für M3-M6)]||590950/1|| Precitool || 3 || 1,35 EURHT || Lab || DO_003 || N || O || O || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Linksausdreher Grosse 2 (für M6-M8)]||590950/2|| Precitool || 2 || 1,35 EURHT || Lab || DO_003 || N || O || O || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Linksausdreher Grosse 3 (für M8-M11)]||590950/3|| Precitool || 2 || 1,54 EURHT || Lab|| DO_003 || N || O || O || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Schaubenausdreher/Linksausdreher "Super Traktion" Grosse T1 (pour Ø 4-5 mm, perçage 2.1 mm)]||590970/T1|| Precitool || 3 || 4.47 EURHT || Lab || DO_003 || N || O || O || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Schaubenausdreher/Linksausdreher "Super Traktion" Grosse T2 (pour Ø 5-7 mm, perçage 3.2 mm )]||590970/T2|| Precitool || 3 || 4.58 EURHT || Lab || DO_003 || N || O || O || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Schaubenausdreher/Linksausdreher "Super Traktion" Grosse T3 (pour Ø 8-12 mm, perçage 4.5 mm )]||590970/T3|| Precitool || 3 || 5.70 EURHT || Lab || DO_003 || N || O || O || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_35 Spiralbohrer HSS-Co Precitool D1897 INOX Dn 8,6mm]||100670/8,60|| Precitool || 2 || 6.99 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_35 Spiralbohrer HSS-Co Precitool D1897 INOX Dn 8,7mm]||100670/8,70|| Precitool || 2 || 6.99 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_985 Gelenk-Hakenschlüssel verstellbar, mit Nase, gehärtet und im Brünierton angelassen; für AuBen Ø (Mutter) 20-35 mm]||506300/20-35|| Precitool || 1 || 11.10 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_985 Gelenk-Hakenschlüssel verstellbar, mit Nase, gehärtet und im Brünierton angelassen; für AuBen Ø (Mutter) 35-60 mm]||506300/35-60|| Precitool || 1 || 12.00 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[http://shop.precitool.de/bk/HKL_2017-2018/#page_985 Gelenk-Hakenschlüssel verstellbar, mit Nase, gehärtet und im Brünierton angelassen; für AuBen Ø (Mutter) 60-90 mm]||506300/60-90|| Precitool || 1 || 15.55 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Schaubenausdreher/Linksausdreher "Super Traktion" Grosse T4 (pour Ø 12-14 mm, perçage 6.5 mm )]||590970/T4|| Precitool || 3 || 6.59 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|-<br />
|Eric||[https://shop.precitool.de/bk/WKZ_2017-2018/#page_1208 Schaubenausdreher/Linksausdreher "Super Traktion" Grosse T5 (pour Ø 16-20 mm, perçage 8.5 mm )]||590970/T5|| Precitool || 3 || 9.00 EURHT || <acheteur> || DO_004 || N || N || N || N<br />
|}<br />
<br />
=== [http://fr.farnell.com Farnell] ===<br />
<br />
Livraison gratuite au dessus de 30€ HT<br />
<br />
La prochaine commande aura pour référence interne : FA_017<br />
<br />
<br />
Prochaine date de commande : <à définir><br />
<br />
Commande passée en attente de livraison : <aucune><br />
<br />
Anciennes commandes Farnell archivées [[Projets:Commande_groupee:archives#Farnell|ici]]<br />
<br />
|-<br />
| Demandeur || class="unsortable"| Description || Ref Farnell || class="unsortable"| Quantité || class="unsortable"| Prix unitaire || Acheteur || Commande<br/>n° || Payé<br/>d'avance<br/>(O/N)|| Commandé<br/>(O/N)|| Distribué<br/>(O/N)|| Remboursé/<br/>Archive<br/>(O/N)<br />
|-<br />
|-<br />
|-<br />
| Claire Poisson || CD4011BM96 || 2114002 || 15 || 0,313 TTC || 3dsman ||FA_015 ||N ||O ||N ||N<br />
|-<br />
|-<br />
| 3dsman || Câble multiconducteur blindé || 2425036 || 10 || 0,85 TTC || 3dsman ||FA_015 ||N ||O ||N ||N<br />
|-<br />
|-<br />
| Steve (Pour lab/smoothie) || NXP LPC 1769 || 2072199 || 1 || 8,68 TTC || 3dsman ||FA_015 ||N ||O ||O ||N<br />
|-<br />
|-<br />
| Dom (Rude ULM) || Connecteur d'alimentation DC, Mâle, 2 A, 9.5 mm, Montage sur câble, 1.7 mm || 1737255 || 2 || 2.87 TTC || 3dsman ||FA_015 ||N ||O ||N ||N<br />
|-<br />
|-<br />
| Steve || MCP1702T-5002E/MB - Régulateur LDO 5V SOT89-3 || 1605559 || 3 || 0.593 || 3dsman ||FA_015 ||N ||O ||O ||N<br />
|-<br />
|-<br />
| Steve || RELAY, SPDT, 250VAC, 12A || 1714771 || 2 || 2.27E|| 3dsman ||FA_015 ||N ||O ||O ||N<br />
|-<br />
|-<br />
|-<br />
| Steve (Pour lab/smoothie) || LDO LM1117 3.3V || 2323580 || 5 || 0.907 || Ph. Gras||FA_016 ||N ||O ||O ||N<br />
|-<br />
| Eric ||[http://fr.farnell.com/amphenol-sine-tuchel/t-3424-501/fiche-libre-6-voies/dp/1123507 Connecteur 6 broches Amphénol avec serrage baillionnette ref T 3424 501] || 1123507 || 1 || 5,12 || Ph. Gras ||FA_016 ||N ||O ||O ||N<br />
|-<br />
| Eric ||[http://fr.farnell.com/nkk-switches/b18jp/switch-toggle-spdt-0-1a-28vac/dp/2374722?ost=2374722&ddkey=http%3Afr-FR%2FElement14_France%2Fsearch Commutateur 3 positions miniature SPDT, 0.1A, 28VAC On-Off-On NKK Switch ref B18JP ] || 2374722|| 2 || 3,98 EUR || Ph. Gras ||FA_016 ||N ||O ||O ||N<br />
|-<br />
| Ph. Gras||[http://fr.farnell.com/jst-japan-solderless-terminals/phr-2/boitier-2-voies-2mm/dp/3616186 Boîtier de connecteur, Série PH, Embase, 2 Voies, 2 mm, Contacts à sertir Série BPH et SPH ] || 3616186|| 100 || 0,0324 EUR || Ph. Gras||FA_016 ||N ||O ||O ||O<br />
|-<br />
| Ph. Gras||[http://fr.farnell.com/jst-japan-solderless-terminals/sph-002t-p0-5s/contact-0-05-0-22mm-cut-reel/dp/1671245?st=SPH-002T-P0.5S Contact, Série PH, Femelle, Sertissage, 24 AWG, Contacts plaqués étain, Connecteurs PH ] || 1671245|| 250|| 0,0208 EUR || Ph. Gras ||FA_016 ||N ||O ||O ||O<br />
|-<br />
| Ph. Gras||[http://fr.farnell.com/on-semiconductor/lm317ahvt/regulateur-ldo-ajustable-1-5a/dp/1564497?st=lm317LM317AHVT Régulateur de tension positive ajustable 1.2V à 37V, 1.5A en boîtier TO-220-3 ] || 1564497|| 10|| 0,727 EUR || Ph. Gras ||FA_016 ||N ||O ||O ||O<br />
|-<br />
|-<br />
|-<br />
| <demandeur> ||[http://wiki.electrolab.fr/Projets:Commande_groupee#Glossaire <article>] || <fa_cde_nb> || <quantité> || <prix> || <acheteur> ||FA_017 ||N ||N ||N ||N<br />
|-<br />
|-<br />
|}<br />
<br />
=== [http://www.gotronic.fr Gotronic] ===<br />
<br />
la prochaine commande a la référence interne GO_003<br />
<br />
<br />
Commande passée en attente de livraison :GO_002 le 31/05/2017 par Ellyan<br />
<br />
<br />
Anciennes commandes Gotronic archivées [[Projets:Commande_groupee:archives#Gotronic|ici]]<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref gotronic!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||<Acheteur>|| GO_XXX || N || N || N || N<br />
|-<br />
--><br />
| Damien H || Solénoïde 12 Vcc || LS1110BD || 1 || 7,00€||Ellyan|| GO_002 || N || O || N || N<br />
|}<br />
<br />
=== HighVoltageShop ===<br />
<br />
La prochaine commande a pour référence interne : HV_002<br />
<br />
5 euros de réduction sur la prochaine commande<br />
<br />
Prochaine date de commande : Aucune<br />
<br />
Commande passée en attente de livraison : Aucune<br />
* frais de port 20 euros<br />
* Livraison mardi 7 janvier 2014 au lab<br />
<br />
Commande livrée en cours de distribution : HV_001 (08/12/2013) <br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref ebay!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||David|| DI_XXX || N || N || N || N<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| Thomas || Cable HV 120 kV || 271261265516 || 1 || 8,69€||David|| HV_001 || O || O || O || N<br />
|-<br />
|David||-30kV HV-Generator Modul 12VDC||281162933827||1||34,99€||David||HV_001||O||O||O||N<br />
|-<br />
|David||5 Stk. Zeilentrafo - Flyback Transformer - Zeilentrafos||281024817841||1||24,99€||David||HV_001||O||O||O||N<br />
|-<br />
|David||+30kV HV-Generator Modul 12VDC||281162933829||1|| 34,99€||David||HV_001||O||O||O||N<br />
|-<br />
|CitronVert||-30kV HV-Generator Modul 12VDC||281162933827||2||34,99€||David||HV_001||N||O||O||N<br />
|-<br />
| Goldo || Regelbares Hochspannungsnetzteil 50kV Strombegrenzung || 280941865340 || 1 || 119,99€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || +30kV HV-Generator Modul 12VDC || 281162933829 || 1 || 34,99€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Zenos || +30kV HV-Generator Modul 12VDC || 281162933829 || 1 || 34,99€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || Cable HV 120 kV || 271261265516 || 1 || 8,69€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || Hochspannungskabel 40kV 1m || 271261265512 || 1 || 4,61€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || Hochspannungswiderstand 20kV 1 GigaOhm Messwiderstand || 280941865344 || 1 || 6,34€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || Hochspannungswiderstand 20kV 100 MegaOhm || 271106455991 || 1 || 6,34€||David|| HV_001 || O || O || O || N<br />
|-<br />
| Goldo || Hochspannungswiderstand 20kV 1 MegaOhm || 281026497192 || 1 || 6,34€||David|| HV_001 || O || O || O || N<br />
|}<br />
<br />
=== [http://www.limpulsion.fr/web/index.php L'impulsion] ===<br />
<br />
[http://v1.limpulsion.fr/docpdf/2008_cat/bpoa_a.pdf Catalogue "accessoires de test"]<br />
<br />
La prochaine commande a la référence interne LI_002<br />
<br />
Prochaine date de commande : [à définir]<br />
<br />
<br />
Commande livrée en cours de distribution :[aucune]<br />
<br />
Anciennes commandes Limpulsion archivées [[Projets:Commande_groupee:archives|ici]]<br />
<br />
<br />
{|class="wikitable sortable" style="font-size:80%"<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref L'impulsion!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-<br />
|Lab||ADAPTATEUR D'AXE HM8001-2 HAMEG||760000500||1||2.30HT||Yannick||IL_001||N||N (plus livrable)||N||O<br />
|-<br />
|Lab||TRESSE A DESSOUDER NO CLEAN 2.8mm/3m||730.14||10||1.56HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||Entretoise plastique grise de montage en saillie marque "Electro-PJP" pour douilles 4mm type 3265, ref EPJP : 3282||<pas au catalogue: demander si livrable> ||16||? ||Yannick||IL_001||N||N (apparement pas dispo)||N||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou NOIR, ref3265-I-0 ||326500||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou MARRON, ref3265-I-1 ||326501||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou ROUGE, ref3265-I-2 ||326502||3||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou BLEU, ref3265-I-6 ||326506||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou VIOLET, ref3265-I-7 ||326507||3||1.48HT||Yannick||IL_001||O||O||N||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou GRIS, ref3265-I-8 ||326508||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou BLANC, ref3265-I-9 ||326509||3||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||DOUILLE DE SECURITE 4mm avec écrou JAUNE/VERT, ref 3265-I-J/V||326510||1||1.74HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Lab||[http://v1.limpulsion.fr/docpdf/2008_cat/bpoe_a.pdf#page=9 Passe fil classique intérieur :12mm, Perçage: 18mm, Epaisseur :10mm (lot de 10pcs)]||252.162||1||1,95EURHT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||Entretoise plastique grise de montage en saillie marque "Electro-PJP" pour douilles 4mm type 3265, ref EPJP : 3282||<pas au catalogue: demander si livrable> ||16||? ||Yannick||IL_001||N||N(apparement pas dispo)||N||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou NOIR, ref3265-I-0 ||326500||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou MARRON, ref3265-I-1 ||326501||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou ROUGE, ref3265-I-2 ||326502||3||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou BLEU, ref3265-I-6 ||326506||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou VIOLET, ref3265-I-7 ||326507||3||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou GRIS, ref3265-I-8 ||326508||1||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou BLANC, ref3265-I-9 ||32650||3||1.48HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||DOUILLE DE SECURITE 4mm avec écrou JAUNE/VERT, ref 3265-I-J/V||326510||2||1.74HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||CLE EXTERNE POUR DOUILLE DE SECURITE||3299||1||13.51HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||TRANSFO FERRITE POUR THT HM1005 HAMEG (plus livrable) ||THTHM1005||1||16.77HT||Yannick||IL_001||N||N (plus livable)||N||O<br />
|-<br />
|Eric||Lot de 100 douilles pour C.I diam4 Long 10mm à souder Electro-PJP ref 20054||20054||1||7,95 EUR HT||Yannick||LI_001||N||O||O||O<br />
|-<br />
<br />
|Eric||CI SN75492 (7 segm DRIVER) TEXAS DIP14||75492||13||1.29HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||CI 74LS164 TEXAS DIL||74LS164||2||0.76HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|Eric||IPROBER520||IPROBER520||1||594HT||Yannick||IL_001||N||O||O||O<br />
|-<br />
|}<br />
<br />
=== [https://shop.mchobby.be/ MCHobby] ===<br />
<br />
La prochaine commande a pour référence interne : MCH_001<br />
<br />
Prochaine date de commande : <Mardi 20 ou mercredi 21 au plus tard ><br />
<br />
Livraison gratuite en Mondial Relay à partir de 75 euros.<br />
<br />
Commande passée en attente de livraison :[aucune]<br />
<br />
<br />
Anciennes commandes MCHobby archivées [[Projets:Commande_groupee:archives#MCHobby|ici]]<br />
<br />
Site WEB de MCHobby : https://shop.mchobby.be/<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Mon Droguiste !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||<Acheteur>|| MC_XXX || N || N || N || N<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| LienRag|| Divers ||Divers || ++|| 75€||<acheteur>|| MHC_001 || N|| N || N || N<br />
|}<br />
<br />
<br />
=== [http://217.34.103.131/homepage/homepage.html Mini-Circuits] ===<br />
<br />
La prochaine commande a pour référence interne : MC_001<br />
<br />
<br />
<br />
<br />
Anciennes commandes Mini-Circuits archivées [[Projets:Commande_groupee:archives#Mini-Circuits|ici]]<br />
<br />
Site WEB de minicircuits : http://www.minicircuits.com/homepage/homepage.html<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Mini-circuits !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| F1CHF || ERA-3 || AMPL || 20 || 1.43€||F1CHF|| MC_001 || N || N || N || N<br />
|-<br />
|-<br />
| F1CHF || ADCH-80+ || coil || 20 || 2.88€||F1CHF|| MC_001 || N || N || N || N<br />
|-<br />
|}<br />
<br />
=== [http://www.mon-droguiste.com/index.cfm Mon Droguiste] ===<br />
<br />
La prochaine commande a pour référence interne : MD_001<br />
<br />
<br />
<br />
<br />
Anciennes commandes Mon Droguiste archivées [[Projets:Commande_groupee:archives#Mon-droguiste|ici]]<br />
<br />
Site WEB de Mon Droguiste : http://www.mon-droguiste.com/index.cfm<br />
<br />
|-<br />
|-l<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| Eric|| Ethylene Diamino Tetraacetic Acide 500g ||Ethylene Diamino Tetraacetic Acide Sac 500g || 1|| 16.95€||<acheteur>|| MD_001 || N|| N || N || N<br />
|-class="sortbottom"<br />
|}<br />
<br />
=== [http://www.mouser.fr Mouser Electronics]===<br />
<br />
La prochaine commande aura pour référence interne MO_014<br />
<br />
Prochaine date de commande : ?<br />
<br />
<br />
Commande livrée en cours de distribution : MO_013 le 31/05/2017 par Ellyan<br />
<br />
Anciennes commandes Mouser Electronics archivées [[Projets:Commande_groupee:archives#Mouser Electronics|ici]]<br />
<br />
Livraison gratuite (FedEx ou UPS) au delà de 50€ de commande<br />
<br />
<br />
<br />
<br />
{|class="wikitable sortable" style="font-size:85%"<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Mouser !! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||<Acheteur>|| DI_XXX || N || N || N || N<br />
|-<br />
--><br />
<br />
|-<br />
|Frederic.D.||[http://www.mouser.fr/ProductDetail/TE-Connectivity/1-826632-0/ Headers & Wire Housings 2X10P DUAL ROW]||571-1-826632-0 ||3 ||1.95 |||| MO_013||O ||O ||O ||N<br />
|-<br />
|Frederic.D.||[http://www.mouser.fr/ProductDetail/Bourns/3306P-1-103/ Trimmer Resistors - Through Hole 10K 25% 6mm Single Turn]||652-3306P-1-103 ||3 ||0.407 |||| MO_013||O ||O ||O ||N<br />
|-<br />
|Frederic.D.||[http://www.mouser.fr/ProductDetail/Schurter/13019302/?qs=%2fha2pyFadugAVCtehZ6ro0we%252bFlHwInvMJ3iEORyekx9pnGrLimsvA%3d%3d Pushbutton Switches SHORT TRAVEL SWITCH 6X6, 5.0MM]||693-1301.9302 ||9 ||0.251 |||| MO_013||O ||O ||O ||N<br />
|-<br />
|Frederic.D.||[http://www.mouser.fr/ProductDetail/Bourns/MF-USMF075-2/ Resettable Fuses - PPTC 0.75A 6V 0.18ohm Hold .75A Trip 1.5A]||652-MF-USMF075-2 ||3 ||0.275 |||| MO_013 ||O ||O||O ||N<br />
|-<br />
|Frederic.D.||[http://www.mouser.fr/ProductDetail/STMicroelectronics/SMA6J50A-TR/?qs=%2fha2pyFadujqXhcCRI4%2fO5BEn9p7pkr6EX0dAQtUlws3JpN%2fE2p9DQ%3d%3d TVS Diodes - Transient Voltage Suppressors HJ Temp Transil]||511-SMA6J5.0A-TR ||3 ||0.38 |||| MO_013 ||O||O||O ||N<br />
|-<br />
|-<br />
|Sylvain V.||[http://www.mouser.fr/ProductDetail/Cirrus-Logic/CS4398-CZZ/?qs=sGAEpiMZZMv%252bLKsN4bqzyhXScoHWAp%252boAQFEBwyfAGo%3d DAC Cirrus Logic]||777-CS4398-CZZ ||1 || 10.46 || Sylvain V. || MO_013 ||O||O||O ||N<br />
|-<br />
|Eric||[https://eu.mouser.com/ProductDetail/Amphenol-Tuchel/T-3427-100?qs=%2fha2pyFaduhPv3s%2fjYa9sAYm3fflPgRKEDSdRTPyUvP7YbNcd%2fVs5g%3d%3d Circular DIN Connectors FEMALE RECEPTACLE 6 WAY, Amphenol series C091B]|| 523-T3427-100 ||1 || 10.29|| <<acheteur>> || MO_014 ||N||N||N ||N<br />
|-<br />
|Eric||[https://www.mouser.fr/ProductDetail/EPCOS-TDK/B32926A4685M?qs=sGAEpiMZZMv1cc3ydrPrF3kXVSi%252b9fyL4PImBI83UxcgTMvwb1977w== Condensateurs à film 6.8uF 20% 350Vac LS 37.5MM Fabricant : EPCOS /TDK ref : B32926A4685M ]|| 871-B32926A4685M ||1 || 10.67|| <<acheteur>> || MO_014 ||N||N||N ||N<br />
|-<br />
|Eric||[https://www.mouser.fr/ProductDetail/Texas-Instruments/OPA2227U-2K5?qs=sGAEpiMZZMtCHixnSjNA6Mrdwin7F8A2DB4TJmgUI0w%3d OPA2227U SOIC8 dual opamp low noise Texas ]|| 595-OPA2227U/2K5 ||2 || 8.07|| <<acheteur>> || MO_014 ||N||N||N ||N<br />
|-<br />
|Eric||[https://eu.mouser.com/ProductDetail/Molex/53253-0570?qs=sGAEpiMZZMvlX3nhDDO4AD1CBCqS4WJ3BaSa47NubxE%3d Shrouded header 5 pins 2mm male through hole board connnector vertical mounting Molex ref. 53253-0570 Cross ref to JST PH "B5B-PH-K-S"]|| 538-53253-0570||20 || 0,164 €|| <<acheteur>> || MO_014 ||N||N||N ||N<br />
|-<br />
|Eric||[https://eu.mouser.com/ProductDetail/Central-Semiconductor/TIP42B?qs=sGAEpiMZZMshyDBzk1%2fWi0MKeUdJDRlz1TXFEdLineJjytqjBdqtHg%3d%3d Bipolar Transistor PNP 10A 80V TIP42B]|| 610-TIP42B ||2 || 0,969 €|| <<acheteur>> || MO_014 ||N||N||N ||N<br />
|-<br />
| Eric|| [https://www.mouser.fr/ProductDetail/Hirose-Connector/RM12BPE-5PH71?qs=sGAEpiMZZMvG94qpybaIZaiKjo18NgShhh8FQGCnH4c%3d HIROSE CONN PLUG Cbl Mount 5 Terminals ref "RM12BPE-5PH(71)"] ||798-RM12BPE-5PH71 || 1|| 11.47 EUR||<acheteur>|| MO_014 || N || N || N || N<br />
|-<br />
| Eric|| [https://www.mouser.fr/ProductDetail/Mueller-Electr/BU-75K?qs=sGAEpiMZZMs4AFwHyzhTm%2f3wHG8LpAJAx37I4fl4y%2fU%3d Kelvin clip 10A Mueller Electric ref. BU-75K] ||548-BU-75K|| 4|| 10.20 EUR||<acheteur>|| MO_014 || N || N || N || N<br />
|-<br />
| Marc|| [https://www.mouser.fr/ProductDetail/Laird/28B0570-000?qs=%2fha2pyFaduia8iLa7KZn%252b9ZwN9PPwsI6zauOY7uXjr3NGQmgjfyUfg%3d%3d Tores Laird] ||875-28B0570-000|| 25|| 0,139 €||<acheteur>|| MO_014 || N || N || N || N<br />
|-<br />
| Marc|| [https://www.mouser.fr/ProductDetail/Laird/28B0562-100?qs=%2fha2pyFadugPna2jpgDGpEerG08QF%2feuzZA0nW3WCHO2J%2fL24jvrtw%3d%3d Tube ferrite Laird] ||875-28B0562-100|| 25||0,236 €||<acheteur>|| MO_014 || N || N || N || N<br />
|-<br />
|}<br />
<br />
<br />
=== [http://www.motedis.fr/shop/ Motedis France] ===<br />
<br />
<br />
La prochaine commande aura pour référence interne : MS_001<br />
<br />
<br />
<br />
<br />
Anciennes commandes Motedis France archivées [[Projets:Commande_groupee:archives#Motedis France|ici]]<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Motedis!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-<br />
|Eric||Plaquette aluminium 15mm d'épaisseur Largeur: 100mm ||<ref motedis>||L:1000mm|| 24.15EURHT || <acheteur> || MS_001 || N|| N || N || N<br />
|-<br />
|<demandeur>||<description>||<ref motedis>|| <quantité> || <prix>|| <acheteur> || MS_001 || N|| N || N || N<br />
|-<br />
|}<br />
<br />
<br />
===[http://www.nouvelleplastique.it/f/setf.html Nouvelle Plastique]===<br />
La prochaine commande a pour référence interne : NP_001<br />
<br />
Prochaine date de commande : Q3/2014<br />
<br />
<br />
<br />
Anciennes commandes Nouvelle Plastique archivées [[Projets:Commande_groupee:archives#Nouvelle Plastique|ici]]<br />
<br />
La société "[http://www.nouvelleplastique.it/f/setf.html Nouvelle Plastique]" fabrique des systèmes de rangements portables et modulaires en plastique.<br />
Les produits sont souvent bien pensés (parfois mieux que RAACO ou Stanley) et de bonne solidité.<br />
<br />
Malheureusement, ses produits ne sont que rarement distribués par les circuits classiques et pour le moment aucun revendeur de détail en France n'a été identifié. De même, on ne connait pas les prix des produits.<br />
La démarche envisagée est de collecter via le tableau ci-dessous une liste de souhaits afin de pouvoir demander un devis global directement au fabricant d'ici quelques mois (probablement en Q3/2014). En fonction de ses proposition de prix, chacun pourra finalement accepter ou refuser que ses souhaits soient inclus dans la commande définitive. Le coût du port sera partagé au prorata du prix des marchandises achetées (plus il y a de demaneurs, plus le coût individuel du port sera faible).<br />
Pour chaque article, il y a indication d'une UDV (Unité De Vente), c'est à dire de lot indivisible.<br />
Au terme des sélections de vos besoins, il faudra que le nombre de pièces commandées pour chaque article soit un multiple de son UDV.<br />
Le tableau ci-dessous dispose d'une structure adaptée à la gestion des souhaits des demandeurs, du nombre d'article et des UDV.<br />
Tous les demandeurs intéressés par un même article s'inscrivent dans une seule ligne (ce qui conduit au fait qu'il y ait une ligne par référence d'article).<br />
Le champ "PUHT" sera complété une fois le devis obtenu.<br />
<br />
====Légende du tableau ====<br />
<br />
UDV = correspond au nombre d'articles par UDV. = nombre d'articles dans un lot indivisible, cette information est indiquée par le fabricant dans son catalogue. <br />
Reste à affecter = mod(Nombre d'UDV; Nombre d'articles) <br />
<br />
<br />
Si vous éditez une ligne existante pour vous inclure comme demandeur de l'article considéré, modifiez les champs suivants :<br />
*''UDV' *''Nombre d'UDV'' (valeur cumulée d'UDV entre tous les demandeurs) <br />
*''Quantités (nombre d'articles)'' (valeur cumulées en nombre d'articles individuels entre tous les demandeurs) <br />
*''Reste à affecter'' (valeur calculée globalement pour tout les demandeurs) <br />
*''Liste de demandeurs avec (unités)'' Unités = nombre d'articles demandéz<br />
<br />
<br />
{|class="wikitable sortable" style="font-size:99%"<br />
|-<br />
! Ref article!! class="unsortable"| Désignation!! UDV (= nombre d'articles dans un lot indivisible) !! class="unsortable"| Nombre d'UDV!! class="unsortable"| Quantité souhaitée(nombre d'articles) !! Reste à affecter!! PUHT !! Liste de demandeurs avec (unités) !! N° de commande <br />
|-l<br />
|00366|| Tyger maxi double|| 6 || 1 ||6 ||0|| <PU> || Eric (6) || NP_001 <br />
|-<br />
|00361|| Tyger maxi|| 12 || 1 ||6 ||6|| <PU> || Eric (6) || NP_001 <br />
|-<br />
<br />
|}<br />
<br />
=== [https://www.olimex.com/ Olimex]===<br />
<br />
La prochaine commande a pour référence interne : OL_001<br />
<br />
<br />
<br />
<br />
Anciennes commandes Olimex archivées [[Projets:Commande_groupee:archives#Olimex|ici]]<br />
<br />
<br />
Achat par l'intermédiaire de leur site internet: https://www.olimex.com/<br />
<br />
Produits identifiés comme potentiellement intéressants:<br />
* https://www.olimex.com/Products/ARM/TI/TMS570-CAN/ un pti devkit pour un micro bien patator, prévu au départ pour des applications safety mais qui a des périphériques & capacités pas dégueulasses...<br />
* https://www.olimex.com/Products/Modules/Adapters/ pour utiliser leurs modules d'extension avec un launchpad ou un rpi<br />
* https://www.olimex.com/Products/Modules/LCD/ (divers modules LCD)<br />
* https://www.olimex.com/Products/Modules/LCD/MOD-LCD4.3%27%27/ module LCD "complet" avec pti micro sympatoche intégré<br />
* https://www.olimex.com/Products/OLinuXino/ gamme de nanocomputers intégrés & pas chers (type rpi mais en open)<br />
* https://www.olimex.com/Products/Components/Misc/TC-K-TYPE/ thermocouple K <br />
etc...<br />
<br />
<br />
Commande prévue courant mars 2013 par Clem.<br />
Attention, prix HT a priori, et prévoir également frais de port "importants" (environ 20€) à répartir entre les participants à la CG.<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Olimex!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||<Acheteur>|| OL_XXX || N || N || N || N<br />
|-<br />
--><br />
| || || || || || || || || || || <br />
|-<br />
| XXX|| XXX || - || - || XXX€||XXX|| OL_001 || N || N || N || N<br />
|-<br />
|-<br />
|}<br />
<br />
=== [http://www.otelo.fr/fr/index.html Otelo] ===<br />
<br />
Outillage bois-métal <br />
<br />
Ports gratuits au delà de 230 € H.T. ou code promo<br />
<br />
La prochaine commande a pour référence interne : OT_004<br />
<br />
Prochaine date de commande : < non définie ><br />
<br />
Commande passée en attente de livraison [AUCUNE]<br />
<br />
<br />
Anciennes commandes Otelo archivées [[Projets:Commande_groupee:archives#Otelo|ici]]<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Otelo!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
|-<br />
--><br />
|-<br />
|lab||TARAUD à main diamètre 14X200 Acier/alu||14104142N1||1|| 14,51€ HT|| <Patrick> || OT_002|| N || O|| O || O<br />
|-<br />
|lab||100 rondelles plates diamètre 8X16 ||36211008||5|| 3,23€ HT|| <Patrick> || OT_002|| N || O|| O || O<br />
|-<br />
|Patrick||Disque à poncer bombé axe 22mm D125 grain 80||54426280||2|| 3,42€ HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|Patrick||boites de rangement 18 sep 375X310X60||PY 69720030||3|| 9,55€ HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|Patrick||jeu d'outils ébavurage||PY 58500009||1|| 7,35€ HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|Patrick||BOMBE GALVA FLASH||PY 73006003||1|| 8,40€ HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|Eric||Tablier de soudeur 90 x 60 cm||PW 75 150 001||1|| 10,90€HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|MAZ24||meule blanche touret||5473014F||1|| 11,40€HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|MAZ24||Meule verte de touret||54571150||1|| 42,40€HT|| <Patrick> || OT_002|| O || O|| O || O<br />
|-<br />
|MAZ24||Bagues adaptation||54703320||4|| 1,09€HT|| <Patrick> || OT_002|| O || O|| O|| O<br />
|-<br />
|Patrick||Mandrin à clef 3-16mm CM2/B18||30140413||1|| 27,25€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Mandrin à clef 1-13mm CM2/B16||30140409||1|| 23,20€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Arbre pour mandrin CM2/B16||30199116||1|| 6,80€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Arbre pour mandrin CM2/B18||30199118||1|| 7,00€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Ecouvillon manche bois 15mm||57169015||1|| 7,70€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Ecouvillon manche bois 25mm||57169025||1|| 8,15€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Ecouvillon à fil 6mm||57169006||1|| 5,24€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Patrick||Ecouvillon à fil 25mm||57151025||1|| 6,38€ HT|| <Patrick> || OT_003|| O|| O|| O|| O<br />
|-<br />
|Sylvia||Support articulé ||43130110||1|| 23,77€ HT|| <Patrick> || OT_003|| N || O|| O|| O<br />
|-<br />
|}<br />
<br />
===[http://www.outiz.fr/ Outiz]===<br />
<br />
<br />
Comptoir Guilleraies (Nanterre)<br />
<br />
Du lundi au vendredi 7h - 17h Samedi 8h - 12h<br />
<br />
Téléphone : 01 40 35 77 77<br />
<br />
La prochaine commande aura pour référence interne : OU_001 <br />
<br />
Prochaine date de commande : <non définie><br />
<br />
<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Outiz!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!!Remboursé/Archive (O/N)<br />
|-<br />
| Eric ||[http://www.outiz.fr/sferaco-vanne-a-sphere-laiton-pn25-batiment-ff-3-4-poignee-acier-plate-rouge-580005/p/3806984/ Vanne à poignée plate rouge Genre : FF Ø : 3/4" ] ||3806984 || 1|| 4,54 €HT||<acheteur>|| OU_001 || N || N || N || N<br />
|-<br />
|}<br />
<br />
=== [http://fr.rs-online.com/web/ Radiospares (RS Composants)] ===<br />
<br />
La prochaine commande aura pour référénce interne : RS_012<br />
<br />
<br />
<br />
Commande livrée en cours de distribution : <aucune><br />
<br />
Anciennes commandes Radiospares archivées [[Projets:Commande_groupee:archives#Radiospares|ici]]<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref RS!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
| Tartanschmurtz || Zibulateur à impédance || DS-666-1664 || 42 || 9,81€||Acheteur|| DI_XXX || N || N || N || N<br />
--><br />
|-<br />
| papy F1CHF||régulateur || 686-9007 || 10 || 0,27€|| <>|| RS_012 || N || N || N || N<br />
|FredericD||[http://fr.rs-online.com/web/p/ldr/9146710/ Silonex, NSL-19M51, CdS, Traversant, TO-18, 20 kΩ → 100 kΩ]||914-6710|| 10 || 1.074€HT ||<>||RS_012||N||N||N||N <br />
|-<br />
|FredericD||[http://fr.rs-online.com/web/p/relais-reed/2562055/ Relais Reed 1NO 12V dc 1 A]||256-2055|| 1 || 5.17€HT ||<>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[http://fr.rs-online.com/web/p/refrigerants/1115853/ Réfrigérant aérosol Cramolin Aérosol 400 ml, -50°C]||111-5853|| 2 || 11.12€HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/accessoires-pour-capteur-de-temperature/0286771/ Presse-étoupe pour Thermocouple]||286-771|| 2 || 9,68€HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/pinces-kelvin/7148263/ Pince Kelvin BU-75K, 10A, noir, fabricant : Mueller]||714-8263|| 2 || 19,61€HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/condensateurs-aluminium/8396258 Condensateur électrolytique aluminium radial 10µF, -20%, 50V dc, Traversant, +105°C, WURTH série WCAP-AT1H, 5 (Dia.) x 11mm 5000h 97mA Référence fabricant : 860240672002]||839-6258|| 25 (1 sachet) || 3,90 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/condensateurs-aluminium/8399011 Condensateur électrolytique aluminium radial 47µF, -20%, 63V dc, Traversant, +105°C, WURTH série WCAP-ATUL, 8 (Dia.) x 11.5mm 7000h 360mA ESR: 0.66 Ohms Référence fabricant : 860040774002]||839-9011|| 20 (2 paquets) || 3,12 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/condensateurs-aluminium/8399033 Condensateur électrolytique aluminium 120µF, -20%, 63V dc, Traversant, +105°C, série WCAP-ATUL, 10 (Dia.) x 16mm 7000h 760mA ESR: 0.3 Ohms Référence fabricant : 860040775008]||839-9033|| 20 (4 paquets) || 3,43 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/connecteur-xlr/7259543/ Connecteur XLR femelle plastique pour chassis soudage pour CI 3 broches coudé + blindage avec louet métal, NEUTRIK NC3FAH2]||725-9543|| 2 || 1,97 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/connecteur-xlr/7259549 Connecteur XLR mâle plastique pour chassis soudage pour CI 3 broches coudé + blindage, NEUTRIK NC3MAH ]||725-9549|| 2 || 1,43 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Eric||[https://fr.rs-online.com/web/p/fusibles-cms-rearmables/5177054/ Fusible CMS réarmable, Littelfuse, 2.2A - 1.1A Référence fabricant : SMD100F-2 MK : 100F]|| 517-7054|| 10 || 0,497 €HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|3ds||[https://fr.rs-online.com/web/p/potentiometres/0387896/ Potentiomètre carbone série 23 montage panneau 4K7 B avec interrupteur DPST, axe 6,35mm TE Connectivity ref 23ESB472MMF50AF]||387-896|| 1 || 4,14€HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|Louis||[https://fr.rs-online.com/web/p/passe-fils/1366806/ Passe-fils,SES en PVC, Diamètre maximum de câble 3mm Noir ref 01070005010 ]||136-6806|| 1 sachet de 100|| 5,38€HT ||<acheteur>||RS_012||N||N||N||N <br />
|-<br />
|}<br />
<br />
<br />
<br />
=== [http://www.stquentin-radio.com/ Saint Quentin radio]===<br />
<br />
La prochaine commande a pour référence interne SQ_002<br />
<br />
Prochaine date de commande : <non défini><br />
<br />
<br />
<br />
Anciennes commandes Saint Quentin Radio archivées [[Projets:Commande_groupee: Saint Quentin radio|ici]]<br />
<br />
Paiement cash par avance à l'acheteur : payez le montant exact, car il n'y a pas de frais annexes<br />
<br />
Frais de port : 0€ (sauf objets lourds) Gare du Nord<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref St Quentin!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
|-<br />
--><br />
|Lab||DOUILLE DE SECURITE 4mm ECROU BLANC, ref3265-I-9 ||326509 ||3||1.80€||<Patrick>||SQ_001||N||O||O||O<br />
|-<br />
|Lab||Fiche DIN 5BR MALE PLASTIQUE 360°||I076||2||1.00€||<acheteur>||SQ_002||N||N||N||N<br />
|-<br />
|Lab||Fiche DIN 5BR CHASSIS METAL 360°||I088||1||1.20€||<acheteur>||SQ_002||N||N||N||N<br />
|}<br />
<br />
=== [http://www.selectronic.fr Selectronic] ===<br />
<br />
La prochaine commande a pour référence interne : SE_010 <br />
<br />
<br />
<br />
<br />
Anciennes commandes Sélectronic archivées [[Projets:Commande_groupee:archives#Selectronic|ici]]<br />
<br />
Frais de port : 0€ (sauf objets lourds)<br />
<br />
Certains produits sont pas en stock à Paris et requièrent d'être livrés de Lille d'où un délai de quelques jours. Le mieux est d'aller au mag à Nation le mardi pour passer la commande et dans ce cas c'est en principe dispo jeudi sur place.<br />
<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description || Ref Sélectronic!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-<br />
|Eric||Résistance CTN 10kOhms 10% format goutte traversant||5277|| 1 || 0.95€TTC|| Eric|| SE_008 || O || O || O || O<br />
|- <br />
|lab||Résistance CTN 10kOhms 10% format goutte traversant||5277|| 1 || 0.95€TTC|| Zenos|| SE_009 || N || O || O || N<br />
|-<br />
|Zenos||triac BT139-600||4024|| 3 || 1,90€TTC|| Zenos|| SE_009 || O || O || O || O<br />
|-<br />
|Lab||TIC106D Thyristor||4018|||1||1,52||<acheteur>|| SE_009 || N || O || N (pas dispo) || N <br />
|-<br />
|Eric||IR IRF9540 MOS canal P -100V -19A||08015|||1||2,50EUR||Zenos|| SE_009 || O || O || O || O<br />
|- <br />
|Eric||Mosfet N IRF640N TO220 200V 0.150Ω - 18A||HD75-940|||2||1,94||<acheteur>|| SE_010 || N || N || N || N<br />
|-<br />
|Marc f6itu||pointes de scope||2447|||4||1,02||<acheteur>|| SE_010 || N || N || N || N<br />
|-<br />
|Lab (Eric)||[http://www.selectronic.fr/joints-adhesif-pour-enceintes.html bande mousse autocollante de largeur 5mm, hauteur 2mm]||2300|||2||5.50||<acheteur>|| SE_010 || N || N || N || N<br />
|-<br />
|}<br />
<br />
=== [http://www.sparkfun.com/ SparkFun Electronics]===<br />
<br />
La prochaine commande a pour référence interne SF_002<br />
<br />
Prochaine date de commande : N/A<br />
<br />
<br />
Commande livrée en cours de distribution : SF_001<br />
<br />
<br />
TVA, frais de port et droits de douane + frais pour dossier de dédouanement : selon taille totale de la commande finale, seront ventilés au pro-rata du montant commandé par chacun.<br />
<br />
Anciennes commandes SparkFun Electronics archivées [[Projets:Commande_groupee:archives#SparkFun Electronics|ici]]<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref SparkFun!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Remboursé/Archive (O/N)<br />
|-l<br />
<!-- Pour ajouter une ligne, copier les 2 lignes suivantes (celles qui commencent par | ) à la suite du tableau et remplacer le contenu des colonnes par ce qui semblera adéquat<br />
|-<br />
--><br />
|Damien H||Spark Gap Igniter - 4.8V||COM-11218||3||$14,95||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Pilou||MIDI Shield||DEV-09595||1||$19,90||<Damien H>||SF_001||N||O||O||O<br />
|-<br />
|Pilou||OpenServo||ROB-09014||2||$14,95||<Damien H>||SF_001||N||O||O||O<br />
|-<br />
|Pilou||Breakout Board for PCF8575 I2C Expander||BOB-08130||1||$11,95||<Damien H>||SF_001||N||O||O||O<br />
|-<br />
|MAZ24||wire stripper||TOL-08696||1||$4,95||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|MAZ24||flush cutter||TOL-11952||1||$6,95||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Eric||Optical Dust Sensor - GP2Y1010AU0F||COM-09689||1||$11,95||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Eric||Mating Connector Housing for Dust Sensor (JST ref#: ZHR-6)||PRT-09690||2||$0,35||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Eric||Crimp Pins for Dust Sensor Connector (JST ref#: SZH-002T-P0.5)||PRT-09728||16||$0,09||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Eric||Copper Tape - 2" (50ft)||PRT-11081||1||$14,95||<Damien H>||SF_001||O||O||O||O<br />
|-<br />
|Olga||RaspiRobot Board||KIT-11561||1||$29,95||<Damien H>||SF_001||N||O||N||O<br />
|-<br />
|Dom||Copper Tape - 2" (50ft)||PRT-11081||1||$14,95||||SF_002||N||N||N||N<br />
|-<br />
|Jean-Marc (PdM) || Polymer Lithium Ion Battery - 400mAh || PRT-10718 || 1 || $6.95 || || SF_002 || N || N || N ||N<br />
|-<br />
|Jean-Marc (PdM) || SparkFun USB LiPoly Charger - Single Cell || PRT-12711 || 1 || $14.95 || || SF_002 || N || N || N ||N<br />
|-<br />
|Jean-Marc (PdM) || Precision Disc Wheel - 5" (Yellow, 2 Pack) || ROB-12469 || 1 || $6.29 || || SF_002 || N || N || N ||N<br />
|-<br />
|Jean-Marc (PdM) || Set Screw Hub - 3mm Bore || ROB-12512 || 2 || $4.99 || || SF_002 || N || N || N ||N<br />
|-<br />
|Jean-Marc (PdM) || ProtoBoard - Square 2" || PRT-08811 || 1 || $2.95 || || SF_002 || N || N || N ||N<br />
|-<br />
|Jean-Marc (PdM) || Micro Gearmotor - 90 RPM (6-12V) || ROB-12285 || 2 || $12.95 || || SF_002 || N || N || N ||N<br />
|- <br />
|Jean-Marc (PdM) || SparkFun Solderable Breadboard - Mini || PRT-12702 || 1 || $2.95 || || SF_002 || N || N || N ||N<br />
|- <br />
|}<br />
<br />
=== Subtel.fr ===<br />
<br />
Pas de frais de port, prix TVA comprise<br />
<br />
<br />
<br />
Commande livrée en cours de distribution : [aucune] <br />
<br />
Anciennes commandes Subtel.fr archivées [[Projets:Commande_groupee:archives|ici]]<br />
<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Description !! Ref Subtel!! class="unsortable"| Quantité !! class="unsortable"| Prix unitaire !! Acheteur !! Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Archive (O/N)<br />
|-l<br />
|-<br />
! !! !! !! !! !! !! !! !! !! !!<br />
|}<br />
<br />
=== raspberry-pi-zero ===<br />
Une opportunité dégotée par Francis: une version du raspberry-pi, un peu spartiate, pour 5 euros!<br />
https://www.raspberrypi.org/blog/raspberry-pi-zero/<br />
<br />
On peut également acheter le kit: http://swag.raspberrypi.org/collections/pi-kits/products/pi-zero-cables<br />
C'est le cordon midi-hdmi/hdmi, PLUSSE la barrette gpio.<br />
<br />
Cette entrée est mise en place alors que tout n'est pas défini pour cet achat: ni le fournisseur (fournisseur initial en rupture de stock), ni le prix.<br />
Mais ce sera le support pour rassembler les commandes. Je tiendrai ce paragraphe à jour selon les infos.<br />
<br />
Le kit comprend l'adaptateur micro-hdmi/hdmi (1 cordon + 1 petit adaptateur?), et la barette 2x20, à souder, pour les gpio. Le raspberry n'est pas dans le kit!<br />
<br />
Le prix: 5 euros le kit, idem le raspberry, et quelques pourcent pour les frais de transport. <br />
<br />
(ce soir: site http://swag.raspberrypi.org/ down; ??)<br />
<br />
<br />
On peut aussi attendre 3 semaines le temps que cela soit livré directement chez vous et avoir<br />
<br />
- l'adaptateur micro hdmi mâle- hdmi femelle : http://www.banggood.com/Gold-Plated-Micro-HDMI-Type-D-Male-To-HDMI-Female-Adapter-p-974265.html<br />
<br />
- un adaptateur micro-hdmi vers VGA femelle sans le son : http://www.banggood.com/1080P-HDMI-Male-To-VGA-Female-Adapter-Video-Converter-Cable-p-937626.html<br />
<br />
- un adaptateur micro-hdmi vers VGA femelle avec le son : http://www.banggood.com/Sin-Hon-SH-MH2V02-Micro-HDMI-to-VGA-Cable-Adapter-with-Audio-p-907524.html<br />
<br />
- un adaptateur micro usb coudé(pratique pour ranger sur le côté : http://www.banggood.com/Micro-USB-Host-OTG-Cable-For-Samsung-HTC-p-79909.html<br />
<br />
- pour se faire une prise alim micro usb, on déboîte le capot et on soude : http://www.banggood.com/USB-2_0-Micro-B-Male-to-Mini-B-Female-5-Pins-Adapter-p-956044.html<br />
<br />
- toutes sortes d'alim : http://www.banggood.com/search/usb-2a-charger.html<br />
<br />
- de quoi s'amuser avec les GPIO : http://www.banggood.com/search/gpio-raspberry/1091-0-0-0-0-0-0-price-0-0_p-1.html<br />
<br />
Et si vous avez le temps de chercher c'est encore moins cher sur http://fr.aliexpress.com/<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| raspberry ou kit !! class="unsortable"| Quantité !! class="unsortable"| Commande n° !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Archive (O/N)<br />
|-l<br />
|-<br />
!Pierre Grommit !!raspb !! 2 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!Pierre Grommit !!kit !! 1 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!Francis Roussel !!rasp !! 2 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!papy F1CHF !!kit !! 4 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!PDA !!rasp !! 3 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!yvs Accard !!rasp !! 3 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!yvs Accard !!Kit !! 1 !! 1 !! n!! n !!n !! n!!<br />
|-<br />
!Malek H. !!3 rasp + 2 vga son + 1 gpio + 1 otg !! 1 !! 1 !! n!! n !!n !! n!!<br />
<br />
<br />
|}<br />
<br />
<br />
=== Starterkit FPGA Altera Max10 ===<br />
'''COMMANDE CLOSE'''<br />
<br />
[https://www.arrow.com/en/products/bemicromax10/arrow-development-tools#page-1 Carte de démarrage FPGA] qui sera parfait pour les [[Formations#Initiation_.C3.A9lectronique_num.C3.A9rique_et_FPGA|formation initiation à venir]].<br />
<br />
Cette carte utilise un FPGA entrée de gamme MAX 10 de chez Altera. Elle contient tout un tas de périphériques sympa pour débuter.<br />
<br />
A noter que la board intègre une sonde JTAG Altera Blaster II (>200€ dans le commerce, 20€ pour un clone).<br />
<br />
Le prix: $30 le kit, disons donc 30€ (à réajuster à la baisse post commande). <br />
<br />
Date butoir pour la commande: mercredi 6 avril 2016<br />
<br />
Chip principal: MAX® 10 FPGA (10M08DAF484C8G):<br />
* 8,000 LEs (largement de quoi mettre le soft core 32bit Altera & des périphériques confortables)<br />
* 414 Kbit (Kb) M9K memory<br />
* 256 Kbit (Kb) user flash memory<br />
* 2 phase locked loops (PLLs)<br />
* 24 18x18-bit multipliers<br />
* 1 ADC block – 1 MSa/sec, 12-bit, 18-channels<br />
* 17 analog inputs<br />
* 1 temperature sense diode<br />
* 250 general purpose input/output (GPIO)<br />
* Non-volatile self-configuration with dual-boot support<br />
* Clocking circuitry: 50 MHz oscillator and 24 MHz oscillator<br />
* achetable à l'unité (moins cher de la gamme: 3€, celui ci, 30€)<br />
<br />
External peripherals<br />
* 8MB SDRAM (4Mb x 16) (ISSI IS42S16400)<br />
* Accelerometer, 3-Axis, SPI interface (Analog Devices ADXL362)<br />
* DAC, 12-bit, SPI interface (Analog Devices AD5681)<br />
* Temperature sensor, I2C interface (Analog Devices ADT7420)<br />
* Thermal resistor<br />
* Photo resistor<br />
* 8 user LEDs<br />
* 2 user Pushbuttons<br />
<br />
Prototyping<br />
* Two 6-pin PMOD expansion headers<br />
* Two 40-pin prototyping headers which provide access to 64 digital I/O<br />
* 6 analog inputs<br />
* One 80-pin BeMicro card edge connector<br />
<br />
<br />
Merci d'ajouter votre nom et votre rapport à l'éventualité de formations au lab:<br />
* débutant, intermédiaire, expert: sous entendu je veux assister à une formation & j'ai ce niveau<br />
* formateur: je suis volontaire pour participer à l'élaboration de formations<br />
* pas intéressé: ni en participant ni en formateur<br />
<br />
Merci d'indiquer:<br />
* combien vous en achetez à titre perso (30€ pièce, à revoir selon le change & port)<br />
* si vous voulez en prendre une à offrir aux formations du lab (vous payez 20€, moi 10€ ; il nous faut 10 cartes)<br />
<br />
<br />
'''MISE A JOUR RECEPTION'''<br />
Prix total 40€/carte. 25€ par carte offerte au lab. Merci de vous mettre à jour, et venez récupérer vos cartes auprès de Coline :)<br />
<br />
|-<br />
! Demandeur !! class="unsortable"| Formation? !! class="unsortable"| Quantité !! class="unsortable"| cadeau au lab !! Payé d'avance (O/N)!! Commandé (O/N)!! Distribué (O/N)!! Archive (O/N)<br />
|-l<br />
|-<br />
|-<br />
!flax !!formateur!! 1 !! non !! O!! n !!n !! n!!<br />
|-<br />
!flax !!formateur!! 1 !! oui !! O!! n !!n !! n!!<br />
|-<br />
!Clem !!formateur!! 1 !! N/A !! O!! n !!n !! n!!<br />
|-<br />
!3dsman!!débutant !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
!3dsman!!débutant !! 1 !! oui !! n!! n !!n !! n!!<br />
|-<br />
!Yann D!!débutant !! 2 !! non !! n!! n !!n !! n!!<br />
|-<br />
!Yannick A.!!formateur !! 1 !! oui !! n!! n !!n !! n!!<br />
|-<br />
!Yannick A.!!formateur !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
!F1HSU!!débutant !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
!Roul!!formateur? !! 1 !! oui !! n!! n !!n !! n!!<br />
|-<br />
!Roul!!formateur? !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
!Jojo du VoLAB !!intermédiaire !! 2 !! non !! n!! n !!n !! n!!<br />
|-<br />
!Jojo du VoLAB !!intermédiaire !! 1 !! oui !! n!! n !!n !! n!!<br />
|-<br />
!MrPozor !!débutant !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
!Julien Len!!débutant !! 1 !! oui? !! n!! n !!n !! n!!<br />
|-<br />
!Julien Len!!débutant !! 1 !! non!! n!! n !!n !! n!!<br />
|-<br />
!Jérôme Loï!! débutant !! 1? !! oui !! O(payé 30)!! n !!n !! n!!<br />
|-<br />
!Jérôme Loï!! débutant !! 1 !! non!! O!! n !!n !! n!!<br />
|-<br />
!Moala!!débutant !! 1 !! non !! O!! n !!n !! n!!<br />
|-<br />
!Desty!!debutant !! 1 !! oui !! n!! n !!n !! n!!<br />
|-<br />
!Desty!!debutant !! 1 !! non !! n!! n !!n !! n!!<br />
|-<br />
<br />
!Votre nom!!type !! nombre !! oui/non !! n!! n !!n !! n!!<br />
<br />
<br />
<br />
|}<br />
Nombre de cartes total: 23 dont lab: 8 (total à mettre à jour !)</div>Erichttps://wiki.electrolab.fr/Projets:Perso:2018:KAPEX_KS120_DadoCutFunctionEnhancementProjets:Perso:2018:KAPEX KS120 DadoCutFunctionEnhancement2018-09-12T09:09:54Z<p>Eric: </p>
<hr />
<div><br />
{{Project<br />
|name=: Modify / enhance the dado cut adjustment span of the FESTOOL Kapex KS120 miter saw<br />
|author= Eric<br />
|proposal_date=August 2018<br />
|abstract1=Mod for FESTOOL KAPEX KS120 MITER SAW <br />
|abstract3=Augmentation de la plage de réglage de la fonction de découpe de rainure de la scie à onglet FESTOOL KAPEX KS120<br />
|tags=FESTOOL KAPEX KS120,dado cut,rainure,modding,enhancement<br />
|where=<br />
|for_who=my Kapex<br />
|official_electrolab_project=<br />
|elecrolab_project_manager= N/A<br />
|budget= 15€<br />
|number_of_members= N/A<br />
|estimated_time= 1/2 day<br />
}}<br />
<br />
<br />
=Dado cuts height adjustement feature=<br />
<br />
The Kapex KS120 height adjustement for dado cuts is limited to about 40 mm, which avoids using this feature for high workpieces.<br />
This limitation [http://festoolownersgroup.com/festool-how-to/kapex-ks-120-cutting-depth-limiter-limitation-of-cutting-higher-workpieces/ seems to annoy other Kapex users.]<br />
<br />
[[File:FESTOOL_KAPEX_dado_cut_mod_50411.JPG|800px|thumb|center|Dado cuts are limited to about 40 mm]]<br />
<br />
<br />
Ron Paulk recorded a [https://www.youtube.com/watch?v=YynWuNeGuQY small video] to show how to perform dado cuts using the Kapex KS120. Many thanks to him !<br />
<br />
=User's manuals=<br />
The cutting depth limit lever is referenced at position "1.4" on page 4 of the [https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=2ahUKEwj4ycjQi_TcAhVInRoKHQw1DRAQFjABegQIBhAC&url=https%3A%2F%2Fwww.festoolusa.com%2F-%2Fmedia%2Ftts%2Ffestool%2Ffestool-usa%2Fdownloads%2Fmanuals%2F472068_005_ks_120_usa.pdf PDF user manual.]<br />
<br />
The cutting depth limit lever is referenced at position "U" on page 7 of this [https://service.festoolusa.com/media/pdf/Kapex-KS120-Supplemental-Manual.pdf very nice official Kapex KS120 supplemental user's manual.] <br />
<br />
=Enhancement=<br />
<br />
I updated my Kapex KS120 to allow a cutting depth limit adustement from 0 to ...93 mm<br />
<br />
==How to ?==<br />
<br />
To unmount the existing 1.4 lever, remove the mains cable strain relief and the machine back panel/plate.<br />
[[File:FESTOOL KAPEX dado cut mod 50412 ann.jpg|800px|thumb|center|The cutting depth limiter lever is easy to replace]]<br />
<br />
<br />
<br />
On a lathe, process a [https://www.rc-machines.com/en/materials/silver-steel/silversteel/silver-steel-o-6-mm-length-330-mm?action_ms=1 6 mm silver steel rod] to make a modified copy of the lever 1.4 using the dimensions shown in the picture below (scale = mm). The shape of the thinner side of the rod does not need to match exactly with the original part.<br />
<br />
[[File:FESTOOL KAPEX dado cut mod 50409 ann.jpg|800px|thumb|center|Original and custom made cutting depth limiter levers]]<br />
<br />
<br />
<br />
Use an M6 x 1 mm (right hand) HSS die to machine the thread.<br />
<br />
e.g ref. SDEMM06B [http://www.tap-die.com/contents/en-uk/p637_6x1mm_dies_1od.html here.]<br />
<br />
<br />
<br />
Use an angle grinder to create the flats on the opposite side of the rod.<br />
<br />
<br />
<br />
Mount the barrel nut on the threaded side of lever<br />
<br />
As you can observe on the original lever, the lowest possible position of the barrel nut is 12 mm.<br />
<br />
Use a small chisel to break the thread on 3 or 4 locations on your custom made lever to limit the barrel nut lowest position to 12 mm (same value as on the original Festool part).<br />
<br />
[[File:FESTOOL_KAPEX_dado_cut_mod_50417.JPG|800px|thumb|center|Limit the barrel nut lowest position to 12 mm]]<br />
<br />
<br />
<br />
Check if the custom made lever has enough room to move near the motor enclosure.<br />
<br />
[[File:FESTOOL_KAPEX_dado_cut_mod_50420.JPG|800px|thumb|center|Take care of the motor enclosure]]<br />
<br />
==Mounting hints==<br />
Replace the original lever with your custom made lever.<br />
<br />
Keep a look on the tall miter latch parts to be sure they are in their correct position.<br />
[[File:FESTOOL_KAPEX_dado_cut_mod_50421.JPG|800px|thumb|center|Tall miter latch parts mounting]]<br />
<br />
<br />
While positionning the plastic back panel, take care to put the tall miter locking lever spring into it's groove.<br />
[[File:FESTOOL KAPEX dado cut mod 50424 ann.jpg|800px|thumb|center|Spring and groove for the tall miter feature]]<br />
<br />
==Results==<br />
With this modding, we now obtain a gorgeous adjustement span from 0 to 93 mm.<br />
The dado cut feature of the Kapex becomes now far more versatile.<br />
[[File:FESTOOL_KAPEX_dado_cut_mod_50435.JPG|800px|thumb|center|Great! We now have more than twice the span of the unmodified machine]]<br />
<br />
=Last hints/limitations=<br />
==Barrel nut==<br />
You may use the M6 x 1 barrel nut from the existing lever assembly or buy a [https://www.fastenright.com/general-fixings/cross-dowel-barrel-nut/ff04 new part] <br />
The original part has a 10 mm diameter and 14 mm lenght.<br />
<br />
==The height adjustment lever has now 3 positions==<br />
For adjustement limit above 50 mm, the 1.4 lever has to be set into an intermediate position.<br />
<br />
[[File:FESTOOL_KAPEX_dado_cut_mod_50436.JPG|300px|thumb|left|Depth limit lever in engaged position for dado cuts from 0 to 40 mm]]<br />
[[File:FESTOOL_KAPEX_dado_cut_mod_50442.JPG|300px|thumb|right|Depth limit lever in disengaged position]][[File:FESTOOL_KAPEX_dado_cut_mod_50428.JPG|300px|thumb|center|Lever in intermediate position for dado cuts from 40 to 93 mm]]<br />
<br />
<br />
<br />
==Cutting witdh==<br />
Another limitation (that already exists on an unmodified Kapex saw) : you won't be able to perform the dado cut in one pass on the full nominal machine width of 305 mm, but 220 mm seems to be reachable. To process wider dado cuts, you need to reverse your workpiece.</div>Erichttps://wiki.electrolab.fr/Projets:Perso:2018:KAPEX_KS120_DadoCutFunctionEnhancementProjets:Perso:2018:KAPEX KS120 DadoCutFunctionEnhancement2018-09-07T14:48:54Z<p>Eric: /* Mounting hint */</p>
<hr />
<div><br />
{{Project<br />
|author= Eric<br />
|where=<br />
|budget= 15€<br />
}}<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
=Enhancement=<br />
<br />
<br />
==How to ?==<br />
<br />
[[File:FESTOOL KAPEX dado cut mod 50412 ann.jpg|800px|thumb|center|The height adjustement lever is easy to replace]]<br />
<br />
<br />
<br />
<br />
[[File:FESTOOL KAPEX dado cut mod 50409 ann.jpg|800px|thumb|center|Original and custom made height adjustement lever]]<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
[[File:FESTOOL_KAPEX_dado_cut_mod_50421.JPG|800px|thumb|center|]]<br />
<br />
<br />
<br />
==Results==<br />
[[File:FESTOOL_KAPEX_dado_cut_mod_50435.JPG|800px|thumb|center|Great! More than twice the span of the unmodified machine]]<br />
<br />
<br />
<br />
<br />
<br />
<br />
Another limitation (that already exists on an unmodified Kapex saw) : you won't be able to perform the dado cut in one pass on the full nominal machine width of 305 mm, but 220 mm seems to be reachable. To process wider dado cuts, you need to reverse your workpiece.</div>Erichttps://wiki.electrolab.fr/Projets:Perso:2018:KAPEX_KS120_DadoCutFunctionEnhancementProjets:Perso:2018:KAPEX KS120 DadoCutFunctionEnhancement2018-09-07T14:46:54Z<p>Eric: /* How to ? */</p>
<hr />
<div><br />
{{Project<br />
|author= Eric<br />
|where=<br />
|budget= 15€<br />
}}<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
=Enhancement=<br />
<br />
<br />
==How to ?==<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
==Mounting hint==<br />
<br />
<br />
<br />
==Results==<br />
<br />
<br />
<br />
<br />
<br />
<br />
Another limitation (that already exists on an unmodified Kapex saw) : you won't be able to perform the dado cut in one pass on the full nominal machine width of 305 mm, but 220 mm seems to be reachable. To process wider dado cuts, you need to reverse your workpiece.</div>Erichttps://wiki.electrolab.fr/Projets:Perso:2018:KAPEX_KS120_DadoCutFunctionEnhancementProjets:Perso:2018:KAPEX KS120 DadoCutFunctionEnhancement2018-09-07T14:46:19Z<p>Eric: /* How to ? */</p>
<hr />
<div><br />
{{Project<br />
|author= Eric<br />
|where=<br />
|budget= 15€<br />
}}<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
=Enhancement=<br />
<br />
<br />
==How to ?==<br />
<br />
<br />
<br />
<br />
On a lathe, process a [https://www.rc-machines.com/en/materials/silver-steel/silversteel/silver-steel-o-6-mm-length-330-mm?action_ms=1 6 mm silver steel rod] to make a modified copy of the lever 1.4 using the dimensions shown in the picture below (scale = mm). The shape of the thinner side of the rod does not need to match exactely with the original part.<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
==Results==<br />
<br />
<br />
<br />
<br />
<br />
<br />
Another limitation (that already exists on an unmodified Kapex saw) : you won't be able to perform the dado cut in one pass on the full nominal machine width of 305 mm, but 220 mm seems to be reachable. To process wider dado cuts, you need to reverse your workpiece.</div>Erichttps://wiki.electrolab.fr/Projets:Perso:2018:KAPEX_KS120_DadoCutFunctionEnhancementProjets:Perso:2018:KAPEX KS120 DadoCutFunctionEnhancement2018-09-07T14:45:26Z<p>Eric: /* Dado cuts height adjustement feature */</p>
<hr />
<div><br />
{{Project<br />
|author= Eric<br />
|where=<br />
|budget= 15€<br />
}}<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
=Enhancement=<br />
<br />
<br />
==How to ?==<br />
<br />
<br />
<br />
<br />
On a lathe, process a [https://www.rc-machines.com/en/materials/silver-steel/silversteel/silver-steel-o-6-mm-length-330-mm?action_ms=1 6 mm silver steel rod] to make a modified copy of the lever 1.4 using the dimensions shown in the picture below (scale = mm). The shape of the thinner side of th rod does not need to match exactely with the original part.<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
==Results==<br />
<br />
<br />
<br />
<br />
<br />
<br />
Another limitation (that already exists on an unmodified Kapex saw) : you won't be able to perform the dado cut in one pass on the full nominal machine width of 305 mm, but 220 mm seems to be reachable. To process wider dado cuts, you need to reverse your workpiece.</div>Erichttps://wiki.electrolab.fr/Projets:Perso:2018:KAPEX_KS120_DadoCutFunctionEnhancementProjets:Perso:2018:KAPEX KS120 DadoCutFunctionEnhancement2018-09-07T14:33:48Z<p>Eric: /* How to ? */</p>
<hr />
<div><br />
{{Project<br />
|author= Eric<br />
|where=<br />
|budget= 15€<br />
}}<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
=Enhancement=<br />
<br />
<br />
==How to ?==<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
==Results==<br />
<br />
<br />
<br />
<br />
<br />
<br />
Another limitation (that already exists on an unmodified Kapex saw) : you won't be able to perform the dado cut in one pass on the full nominal machine width of 305 mm, but 220 mm seems to be reachable. To process wider dado cuts, you need to reverse your workpiece.</div>Erichttps://wiki.electrolab.fr/Projets:Perso:2018:KAPEX_KS120_DadoCutFunctionEnhancementProjets:Perso:2018:KAPEX KS120 DadoCutFunctionEnhancement2018-09-07T14:28:49Z<p>Eric: /* Cutting witdh */</p>
<hr />
<div><br />
{{Project<br />
|author= Eric<br />
|where=<br />
|budget= 15€<br />
}}<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
=Enhancement=<br />
<br />
<br />
==How to ?==<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
Use an angle grinder to create the flats on the opposite side of the rod<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
==Results==<br />
<br />
<br />
<br />
<br />
<br />
<br />
Another limitation (that already exists on an unmodified Kapex saw) : you won't be able to perform the dado cut in one pass on the full nominal machine width of 305 mm, but 220 mm seems to be reachable. To process wider dado cuts, you need to reverse your workpiece.</div>Erichttps://wiki.electrolab.fr/Projets:Perso:2018:KAPEX_KS120_DadoCutFunctionEnhancementProjets:Perso:2018:KAPEX KS120 DadoCutFunctionEnhancement2018-09-07T14:27:24Z<p>Eric: /* Barrel nut */</p>
<hr />
<div><br />
{{Project<br />
|author= Eric<br />
|where=<br />
|budget= 15€<br />
}}<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
=Enhancement=<br />
<br />
<br />
==How to ?==<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
==Results==<br />
<br />
<br />
<br />
<br />
<br />
<br />
Another limitation (that already exists on an unmodified Kapex saw) : you won't be able to perform the dado cut in one pass on the full nominal machine width of 305 mm, but 220 mm seems to be reachable. To use the full 305 mm width, you need to reverse your workpiece.</div>Erichttps://wiki.electrolab.fr/Projets:Perso:2018:KAPEX_KS120_DadoCutFunctionEnhancementProjets:Perso:2018:KAPEX KS120 DadoCutFunctionEnhancement2018-09-07T14:25:39Z<p>Eric: /* How to ? */</p>
<hr />
<div><br />
{{Project<br />
|author= Eric<br />
|where=<br />
|budget= 15€<br />
}}<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
=Enhancement=<br />
<br />
<br />
==How to ?==<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
==Results==<br />
<br />
You may use the M6 x 1 barrel nut from the existing lever assembly or buy a new part https://www.fastenright.com/general-fixings/cross-dowel-barrel-nut/ff04<br />
<br />
<br />
<br />
<br />
<br />
<br />
Another limitation (that already exists on an unmodified Kapex saw) : you won't be able to perform the dado cut in one pass on the full nominal machine width of 305 mm, but 220 mm seems to be reachable. To use the full 305 mm width, you need to reverse your workpiece.</div>Erichttps://wiki.electrolab.fr/Projets:Perso:2018:KAPEX_KS120_DadoCutFunctionEnhancementProjets:Perso:2018:KAPEX KS120 DadoCutFunctionEnhancement2018-09-07T14:24:40Z<p>Eric: /* Mounting hint */</p>
<hr />
<div><br />
{{Project<br />
|author= Eric<br />
|where=<br />
|budget= 15€<br />
}}<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
=Enhancement=<br />
<br />
<br />
==How to ?==<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
Use a small chisel to break the thread on 3 or 4 locations on your custom made lever to limit the barrel nut lowest position to 12 mm (same value as on the original part).<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
==Results==<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
