<?xml version="1.0"?> <api> <error code="unknown_action" info="Unrecognized value for parameter 'action': https://blog-affakgley.gifthub.news/post/7509864213" xml:space="preserve"> ********************************************************************************************************** ** ** ** This is an auto-generated MediaWiki API documentation page ** ** ** ** Documentation and Examples: ** ** https://www.mediawiki.org/wiki/API ** ** ** ********************************************************************************************************** Status: All features shown on this page should be working, but the API is still in active development, and may change at any time. Make sure to monitor our mailing list for any updates Erroneous requests: When erroneous requests are sent to the API, a HTTP header will be sent with the key "MediaWiki-API-Error" and then both the value of the header and the error code sent back will be set to the same value In the case of an invalid action being passed, these will have a value of "unknown_action" For more information see https://www.mediawiki.org/wiki/API:Errors_and_warnings Documentation: https://www.mediawiki.org/wiki/API:Main_page FAQ https://www.mediawiki.org/wiki/API:FAQ Mailing list: https://lists.wikimedia.org/mailman/listinfo/mediawiki-api Api Announcements: https://lists.wikimedia.org/mailman/listinfo/mediawiki-api-announce Bugs & Requests: https://bugzilla.wikimedia.org/buglist.cgi?component=API&bug_status=NEW&bug_status=ASSIGNED&bug_status=REOPENED&order=bugs.delta_ts Parameters: format - The format of the output One value: json, jsonfm, php, phpfm, wddx, wddxfm, xml, xmlfm, yaml, yamlfm, rawfm, txt, txtfm, dbg, dbgfm, dump, dumpfm, none Default: xmlfm action - What action you would like to perform. See below for module help One value: login, logout, createaccount, query, expandtemplates, parse, opensearch, feedcontributions, feedwatchlist, help, paraminfo, rsd, compare, tokens, purge, setnotificationtimestamp, rollback, delete, undelete, protect, block, unblock, move, edit, upload, filerevert, emailuser, watch, patrol, import, userrights, options, imagerotate, sfautocomplete, sfautoedit, smwinfo, ask, askargs, browsebysubject Default: help maxlag - Maximum lag can be used when MediaWiki is installed on a database replicated cluster. To save actions causing any more site replication lag, this parameter can make the client wait until the replication lag is less than the specified value. In case of a replag error, error code "maxlag" is returned, with the message like "Waiting for $host: $lag seconds lagged\n". See https://www.mediawiki.org/wiki/Manual:Maxlag_parameter for more information smaxage - Set the s-maxage header to this many seconds. Errors are never cached Default: 0 maxage - Set the max-age header to this many seconds. Errors are never cached Default: 0 requestid - Request ID to distinguish requests. This will just be output back to you servedby - Include the hostname that served the request in the results. Unconditionally shown on error origin - When accessing the API using a cross-domain AJAX request (CORS), set this to the originating domain. This must be included in any pre-flight request, and therefore must be part of the request URI (not the POST body). This must match one of the origins in the Origin: header exactly, so it has to be set to something like http://en.wikipedia.org or https://meta.wikimedia.org . If this parameter does not match the Origin: header, a 403 response will be returned. If this parameter matches the Origin: header and the origin is whitelisted, an Access-Control-Allow-Origin header will be set. *** *** *** *** *** *** *** *** *** *** *** *** *** *** Modules *** *** *** *** *** *** *** *** *** *** *** *** *** *** * action=login (lg) * Log in and get the authentication tokens. In the event of a successful log-in, a cookie will be attached to your session. In the event of a failed log-in, you will not be able to attempt another log-in through this method for 5 seconds. This is to prevent password guessing by automated password crackers https://www.mediawiki.org/wiki/API:Login This module only accepts POST requests Parameters: lgname - User Name lgpassword - Password lgdomain - Domain (optional) lgtoken - Login token obtained in first request Example: api.php?action=login&lgname=user&lgpassword=password * action=logout * Log out and clear session data https://www.mediawiki.org/wiki/API:Logout Example: Log the current user out: api.php?action=logout * action=createaccount * Create a new user account. https://www.mediawiki.org/wiki/API:Account_creation This module requires write rights This module only accepts POST requests Parameters: name - Username This parameter is required password - Password (ignored if mailpassword is set) domain - Domain for external authentication (optional) token - Account creation token obtained in first request email - Email address of user (optional) This parameter is required realname - Real name of user (optional) mailpassword - If set to any value, a random password will be emailed to the user reason - Optional reason for creating the account to be put in the logs language - Language code to set as default for the user (optional, defaults to content language) Examples: api.php?action=createaccount&name=testuser&password=test123 api.php?action=createaccount&name=testmailuser&mailpassword=true&reason=MyReason * action=query * Query API module allows applications to get needed pieces of data from the MediaWiki databases, and is loosely based on the old query.php interface. All data modifications will first have to use query to acquire a token to prevent abuse from malicious sites https://www.mediawiki.org/wiki/API:Query https://www.mediawiki.org/wiki/API:Meta https://www.mediawiki.org/wiki/API:Properties https://www.mediawiki.org/wiki/API:Lists This module requires read rights Parameters: prop - Which properties to get for the titles/revisions/pageids. Module help is available below Values (separate with '|'): categories, categoryinfo, duplicatefiles, extlinks, images, imageinfo, info, links, iwlinks, langlinks, pageprops, revisions, stashimageinfo, templates list - Which lists to get. Module help is available below Values (separate with '|'): allcategories, allfileusages, allimages, alllinks, allpages, alltransclusions, allusers, backlinks, blocks, categorymembers, deletedrevs, embeddedin, exturlusage, filearchive, imageusage, iwbacklinks, langbacklinks, logevents, pageswithprop, pagepropnames, protectedtitles, querypage, random, recentchanges, search, tags, usercontribs, users, watchlist, watchlistraw meta - Which metadata to get about the site. Module help is available below Values (separate with '|'): allmessages, siteinfo, userinfo, filerepoinfo indexpageids - Include an additional pageids section listing all returned page IDs export - Export the current revisions of all given or generated pages exportnowrap - Return the export XML without wrapping it in an XML result (same format as Special:Export). Can only be used with export iwurl - Whether to get the full URL if the title is an interwiki link continue - When present, formats query-continue as key-value pairs that should simply be merged into the original request. This parameter must be set to an empty string in the initial query. This parameter is recommended for all new development, and will be made default in the next API version. titles - A list of titles to work on Separate values with '|' Maximum number of values 50 (500 for bots) pageids - A list of page IDs to work on Separate values with '|' Maximum number of values 50 (500 for bots) revids - A list of revision IDs to work on Separate values with '|' Maximum number of values 50 (500 for bots) redirects - Automatically resolve redirects converttitles - Convert titles to other variants if necessary. Only works if the wiki's content language supports variant conversion. Languages that support variant conversion include gan, iu, kk, ku, shi, sr, tg, uz, zh generator - Get the list of pages to work on by executing the specified query module. NOTE: generator parameter names must be prefixed with a 'g', see examples One value: allcategories, allfileusages, allimages, alllinks, allpages, alltransclusions, backlinks, categories, categorymembers, duplicatefiles, embeddedin, exturlusage, images, imageusage, iwbacklinks, langbacklinks, links, pageswithprop, protectedtitles, querypage, random, recentchanges, search, templates, watchlist, watchlistraw Examples: api.php?action=query&prop=revisions&meta=siteinfo&titles=Main%20Page&rvprop=user|comment&continue= api.php?action=query&generator=allpages&gapprefix=API/&prop=revisions&continue= --- --- --- --- --- --- --- --- --- --- --- --- Query: Prop --- --- --- --- --- --- --- --- --- --- --- --- * prop=categories (cl) * List all categories the page(s) belong to https://www.mediawiki.org/wiki/API:Properties#categories_.2F_cl This module requires read rights Parameters: clprop - Which additional properties to get for each category sortkey - Adds the sortkey (hexadecimal string) and sortkey prefix (human-readable part) for the category timestamp - Adds timestamp of when the category was added hidden - Tags categories that are hidden with __HIDDENCAT__ Values (separate with '|'): sortkey, timestamp, hidden clshow - Which kind of categories to show Values (separate with '|'): hidden, !hidden cllimit - How many categories to return No more than 500 (5000 for bots) allowed Default: 10 clcontinue - When more results are available, use this to continue clcategories - Only list these categories. Useful for checking whether a certain page is in a certain category Separate values with '|' Maximum number of values 50 (500 for bots) cldir - The direction in which to list One value: ascending, descending Default: ascending Examples: Get a list of categories [[Albert Einstein]] belongs to: api.php?action=query&prop=categories&titles=Albert%20Einstein Get information about all categories used in the [[Albert Einstein]]: api.php?action=query&generator=categories&titles=Albert%20Einstein&prop=info Generator: This module may be used as a generator * prop=categoryinfo (ci) * Returns information about the given categories https://www.mediawiki.org/wiki/API:Properties#categoryinfo_.2F_ci This module requires read rights Parameters: cicontinue - When more results are available, use this to continue Example: api.php?action=query&prop=categoryinfo&titles=Category:Foo|Category:Bar * prop=duplicatefiles (df) * List all files that are duplicates of the given file(s) based on hash values https://www.mediawiki.org/wiki/API:Properties#duplicatefiles_.2F_df This module requires read rights Parameters: dflimit - How many duplicate files to return No more than 500 (5000 for bots) allowed Default: 10 dfcontinue - When more results are available, use this to continue dfdir - The direction in which to list One value: ascending, descending Default: ascending dflocalonly - Look only for files in the local repository Examples: api.php?action=query&titles=File:Albert_Einstein_Head.jpg&prop=duplicatefiles api.php?action=query&generator=allimages&prop=duplicatefiles Generator: This module may be used as a generator * prop=extlinks (el) * Returns all external URLs (not interwikis) from the given page(s) https://www.mediawiki.org/wiki/API:Properties#extlinks_.2F_el This module requires read rights Parameters: ellimit - How many links to return No more than 500 (5000 for bots) allowed Default: 10 eloffset - When more results are available, use this to continue elprotocol - Protocol of the URL. If empty and elquery set, the protocol is http. Leave both this and elquery empty to list all external links Can be empty, or One value: http, https, ftp, ftps, ssh, sftp, irc, ircs, xmpp, sip, sips, gopher, telnet, nntp, worldwind, mailto, tel, sms, news, svn, git, mms, bitcoin, magnet, urn, geo Default: elquery - Search string without protocol. Useful for checking whether a certain page contains a certain external url elexpandurl - Expand protocol-relative URLs with the canonical protocol Example: Get a list of external links on the [[Main Page]]: api.php?action=query&prop=extlinks&titles=Main%20Page * prop=imageinfo (ii) * Returns image information and upload history https://www.mediawiki.org/wiki/API:Properties#imageinfo_.2F_ii This module requires read rights Parameters: iiprop - What image information to get: timestamp - Adds timestamp for the uploaded version user - Adds the user who uploaded the image version userid - Add the user ID that uploaded the image version comment - Comment on the version parsedcomment - Parse the comment on the version url - Gives URL to the image and the description page size - Adds the size of the image in bytes and the height, width and page count (if applicable) dimensions - Alias for size sha1 - Adds SHA-1 hash for the image mime - Adds MIME type of the image thumbmime - Adds MIME type of the image thumbnail (requires url and param iiurlwidth) mediatype - Adds the media type of the image metadata - Lists Exif metadata for the version of the image archivename - Adds the file name of the archive version for non-latest versions bitdepth - Adds the bit depth of the version uploadwarning - Used by the Special:Upload page to get information about an existing file. Not intended for use outside MediaWiki core Values (separate with '|'): timestamp, user, userid, comment, parsedcomment, url, size, dimensions, sha1, mime, thumbmime, mediatype, metadata, archivename, bitdepth, uploadwarning Default: timestamp|user iilimit - How many image revisions to return per image No more than 500 (5000 for bots) allowed Default: 1 iistart - Timestamp to start listing from iiend - Timestamp to stop listing at iiurlwidth - If iiprop=url is set, a URL to an image scaled to this width will be returned. For performance reasons if this option is used, no more than 50 scaled images will be returned. Default: -1 iiurlheight - Similar to iiurlwidth. Default: -1 iimetadataversion - Version of metadata to use. if 'latest' is specified, use latest version. Defaults to '1' for backwards compatibility Default: 1 iiurlparam - A handler specific parameter string. For example, pdf's might use 'page15-100px'. iiurlwidth must be used and be consistent with iiurlparam Default: iicontinue - If the query response includes a continue value, use it here to get another page of results iilocalonly - Look only for files in the local repository Examples: api.php?action=query&titles=File:Albert%20Einstein%20Head.jpg&prop=imageinfo api.php?action=query&titles=File:Test.jpg&prop=imageinfo&iilimit=50&iiend=20071231235959&iiprop=timestamp|user|url * prop=images (im) * Returns all images contained on the given page(s) https://www.mediawiki.org/wiki/API:Properties#images_.2F_im This module requires read rights Parameters: imlimit - How many images to return No more than 500 (5000 for bots) allowed Default: 10 imcontinue - When more results are available, use this to continue imimages - Only list these images. Useful for checking whether a certain page has a certain Image. Separate values with '|' Maximum number of values 50 (500 for bots) imdir - The direction in which to list One value: ascending, descending Default: ascending Examples: Get a list of images used in the [[Main Page]]: api.php?action=query&prop=images&titles=Main%20Page Get information about all images used in the [[Main Page]]: api.php?action=query&generator=images&titles=Main%20Page&prop=info Generator: This module may be used as a generator * prop=info (in) * Get basic page information such as namespace, title, last touched date, ... https://www.mediawiki.org/wiki/API:Properties#info_.2F_in This module requires read rights Parameters: inprop - Which additional properties to get: protection - List the protection level of each page talkid - The page ID of the talk page for each non-talk page watched - List the watched status of each page watchers - The number of watchers, if allowed notificationtimestamp - The watchlist notification timestamp of each page subjectid - The page ID of the parent page for each talk page url - Gives a full URL to the page, and also an edit URL readable - Whether the user can read this page preload - Gives the text returned by EditFormPreloadText displaytitle - Gives the way the page title is actually displayed Values (separate with '|'): protection, talkid, watched, watchers, notificationtimestamp, subjectid, url, readable, preload, displaytitle intoken - Request a token to perform a data-modifying action on a page Values (separate with '|'): edit, delete, protect, move, block, unblock, email, import, watch incontinue - When more results are available, use this to continue Examples: api.php?action=query&prop=info&titles=Main%20Page api.php?action=query&prop=info&inprop=protection&titles=Main%20Page * prop=iwlinks (iw) * Returns all interwiki links from the given page(s) https://www.mediawiki.org/wiki/API:Iwlinks This module requires read rights Parameters: iwurl - Whether to get the full URL iwlimit - How many interwiki links to return No more than 500 (5000 for bots) allowed Default: 10 iwcontinue - When more results are available, use this to continue iwprefix - Prefix for the interwiki iwtitle - Interwiki link to search for. Must be used with iwprefix iwdir - The direction in which to list One value: ascending, descending Default: ascending Example: Get interwiki links from the [[Main Page]]: api.php?action=query&prop=iwlinks&titles=Main%20Page * prop=langlinks (ll) * Returns all interlanguage links from the given page(s) https://www.mediawiki.org/wiki/API:Properties#langlinks_.2F_ll This module requires read rights Parameters: lllimit - How many langlinks to return No more than 500 (5000 for bots) allowed Default: 10 llcontinue - When more results are available, use this to continue llurl - Whether to get the full URL lllang - Language code lltitle - Link to search for. Must be used with lllang lldir - The direction in which to list One value: ascending, descending Default: ascending Example: Get interlanguage links from the [[Main Page]]: api.php?action=query&prop=langlinks&titles=Main%20Page&redirects= * prop=links (pl) * Returns all links from the given page(s) https://www.mediawiki.org/wiki/API:Properties#links_.2F_pl This module requires read rights Parameters: plnamespace - Show links in this namespace(s) only Values (separate with '|'): 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 102, 103, 108, 109, 106, 107, 104, 105 Maximum number of values 50 (500 for bots) pllimit - How many links to return No more than 500 (5000 for bots) allowed Default: 10 plcontinue - When more results are available, use this to continue pltitles - Only list links to these titles. Useful for checking whether a certain page links to a certain title. Separate values with '|' Maximum number of values 50 (500 for bots) pldir - The direction in which to list One value: ascending, descending Default: ascending Examples: Get links from the [[Main Page]]: api.php?action=query&prop=links&titles=Main%20Page Get information about the link pages in the [[Main Page]]: api.php?action=query&generator=links&titles=Main%20Page&prop=info Get links from the Main Page in the User and Template namespaces: api.php?action=query&prop=links&titles=Main%20Page&plnamespace=2|10 Generator: This module may be used as a generator * prop=pageprops (pp) * Get various properties defined in the page content https://www.mediawiki.org/wiki/API:Properties#pageprops_.2F_pp This module requires read rights Parameters: ppcontinue - When more results are available, use this to continue ppprop - Only list these props. Useful for checking whether a certain page uses a certain page prop Separate values with '|' Maximum number of values 50 (500 for bots) Example: api.php?action=query&prop=pageprops&titles=Category:Foo * prop=revisions (rv) * Get revision information May be used in several ways: 1) Get data about a set of pages (last revision), by setting titles or pageids parameter 2) Get revisions for one given page, by using titles/pageids with start/end/limit params 3) Get data about a set of revisions by setting their IDs with revids parameter All parameters marked as (enum) may only be used with a single page (#2) https://www.mediawiki.org/wiki/API:Properties#revisions_.2F_rv This module requires read rights Parameters: rvprop - Which properties to get for each revision: ids - The ID of the revision flags - Revision flags (minor) timestamp - The timestamp of the revision user - User that made the revision userid - User id of revision creator size - Length (bytes) of the revision sha1 - SHA-1 (base 16) of the revision contentmodel - Content model id comment - Comment by the user for revision parsedcomment - Parsed comment by the user for the revision content - Text of the revision tags - Tags for the revision Values (separate with '|'): ids, flags, timestamp, user, userid, size, sha1, contentmodel, comment, parsedcomment, content, tags Default: ids|timestamp|flags|comment|user rvlimit - Limit how many revisions will be returned (enum) No more than 500 (5000 for bots) allowed rvstartid - From which revision id to start enumeration (enum) rvendid - Stop revision enumeration on this revid (enum) rvstart - From which revision timestamp to start enumeration (enum) rvend - Enumerate up to this timestamp (enum) rvdir - In which direction to enumerate (enum) newer - List oldest first. Note: rvstart has to be before rvend. older - List newest first (default). Note: rvstart has to be later than rvend. One value: newer, older Default: older rvuser - Only include revisions made by user (enum) rvexcludeuser - Exclude revisions made by user (enum) rvtag - Only list revisions tagged with this tag rvexpandtemplates - Expand templates in revision content (requires rvprop=content) rvgeneratexml - Generate XML parse tree for revision content (requires rvprop=content) rvparse - Parse revision content (requires rvprop=content). For performance reasons if this option is used, rvlimit is enforced to 1. rvsection - Only retrieve the content of this section number rvtoken - Which tokens to obtain for each revision Values (separate with '|'): rollback rvcontinue - When more results are available, use this to continue rvdiffto - Revision ID to diff each revision to. Use "prev", "next" and "cur" for the previous, next and current revision respectively rvdifftotext - Text to diff each revision to. Only diffs a limited number of revisions. Overrides rvdiffto. If rvsection is set, only that section will be diffed against this text rvcontentformat - Serialization format used for difftotext and expected for output of content One value: text/x-wiki, text/javascript, text/css, text/plain Examples: Get data with content for the last revision of titles "API" and "Main Page" api.php?action=query&prop=revisions&titles=API|Main%20Page&rvprop=timestamp|user|comment|content Get last 5 revisions of the "Main Page" api.php?action=query&prop=revisions&titles=Main%20Page&rvlimit=5&rvprop=timestamp|user|comment Get first 5 revisions of the "Main Page" api.php?action=query&prop=revisions&titles=Main%20Page&rvlimit=5&rvprop=timestamp|user|comment&rvdir=newer Get first 5 revisions of the "Main Page" made after 2006-05-01 api.php?action=query&prop=revisions&titles=Main%20Page&rvlimit=5&rvprop=timestamp|user|comment&rvdir=newer&rvstart=20060501000000 Get first 5 revisions of the "Main Page" that were not made made by anonymous user "127.0.0.1" api.php?action=query&prop=revisions&titles=Main%20Page&rvlimit=5&rvprop=timestamp|user|comment&rvexcludeuser=127.0.0.1 Get first 5 revisions of the "Main Page" that were made by the user "MediaWiki default" api.php?action=query&prop=revisions&titles=Main%20Page&rvlimit=5&rvprop=timestamp|user|comment&rvuser=MediaWiki%20default * prop=stashimageinfo (sii) * Returns image information for stashed images https://www.mediawiki.org/wiki/API:Properties#imageinfo_.2F_ii This module requires read rights Parameters: siifilekey - Key that identifies a previous upload that was stashed temporarily. Separate values with '|' Maximum number of values 50 (500 for bots) siisessionkey - DEPRECATED! Alias for filekey, for backward compatibility. Separate values with '|' Maximum number of values 50 (500 for bots) siiprop - What image information to get: timestamp - Adds timestamp for the uploaded version url - Gives URL to the image and the description page size - Adds the size of the image in bytes and the height, width and page count (if applicable) dimensions - Alias for size sha1 - Adds SHA-1 hash for the image mime - Adds MIME type of the image thumbmime - Adds MIME type of the image thumbnail (requires url and param siiurlwidth) metadata - Lists Exif metadata for the version of the image bitdepth - Adds the bit depth of the version uploadwarning - Used by the Special:Upload page to get information about an existing file. Not intended for use outside MediaWiki core Values (separate with '|'): timestamp, url, size, dimensions, sha1, mime, thumbmime, metadata, bitdepth, uploadwarning Default: timestamp|url siiurlwidth - If siiprop=url is set, a URL to an image scaled to this width will be returned. Default: -1 siiurlheight - Similar to siiurlwidth. Cannot be used without siiurlwidth Default: -1 siiurlparam - A handler specific parameter string. For example, pdf's might use 'page15-100px'. siiurlwidth must be used and be consistent with siiurlparam Default: Examples: api.php?action=query&prop=stashimageinfo&siifilekey=124sd34rsdf567 api.php?action=query&prop=stashimageinfo&siifilekey=b34edoe3|bceffd4&siiurlwidth=120&siiprop=url * prop=templates (tl) * Returns all templates from the given page(s) https://www.mediawiki.org/wiki/API:Properties#templates_.2F_tl This module requires read rights Parameters: tlnamespace - Show templates in this namespace(s) only Values (separate with '|'): 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 102, 103, 108, 109, 106, 107, 104, 105 Maximum number of values 50 (500 for bots) tllimit - How many templates to return No more than 500 (5000 for bots) allowed Default: 10 tlcontinue - When more results are available, use this to continue tltemplates - Only list these templates. Useful for checking whether a certain page uses a certain template. Separate values with '|' Maximum number of values 50 (500 for bots) tldir - The direction in which to list One value: ascending, descending Default: ascending Examples: Get templates from the [[Main Page]]: api.php?action=query&prop=templates&titles=Main%20Page Get information about the template pages in the [[Main Page]]: api.php?action=query&generator=templates&titles=Main%20Page&prop=info Get templates from the Main Page in the User and Template namespaces: api.php?action=query&prop=templates&titles=Main%20Page&tlnamespace=2|10 Generator: This module may be used as a generator --- --- --- --- --- --- --- --- --- --- --- --- Query: List --- --- --- --- --- --- --- --- --- --- --- --- * list=allcategories (ac) * Enumerate all categories https://www.mediawiki.org/wiki/API:Allcategories This module requires read rights Parameters: acfrom - The category to start enumerating from accontinue - When more results are available, use this to continue acto - The category to stop enumerating at acprefix - Search for all category titles that begin with this value acdir - Direction to sort in One value: ascending, descending Default: ascending acmin - Minimum number of category members acmax - Maximum number of category members aclimit - How many categories to return No more than 500 (5000 for bots) allowed Default: 10 acprop - Which properties to get size - Adds number of pages in the category hidden - Tags categories that are hidden with __HIDDENCAT__ Values (separate with '|'): size, hidden Default: Examples: api.php?action=query&list=allcategories&acprop=size api.php?action=query&generator=allcategories&gacprefix=List&prop=info Generator: This module may be used as a generator * list=allfileusages (af) * List all file usages, including non-existing https://www.mediawiki.org/wiki/API:Allfileusages This module requires read rights Parameters: afcontinue - When more results are available, use this to continue affrom - The title of the file to start enumerating from afto - The title of the file to stop enumerating at afprefix - Search for all file titles that begin with this value afunique - Only show distinct file titles. Cannot be used with afprop=ids. When used as a generator, yields target pages instead of source pages. afprop - What pieces of information to include ids - Adds the pageid of the using page (Cannot be used with afunique) title - Adds the title of the file Values (separate with '|'): ids, title Default: title aflimit - How many total items to return No more than 500 (5000 for bots) allowed Default: 10 afdir - The direction in which to list One value: ascending, descending Default: ascending Examples: List file titles with page ids they are from, including missing ones. Start at B: api.php?action=query&list=allfileusages&affrom=B&afprop=ids|title List unique file titles: api.php?action=query&list=allfileusages&afunique=&affrom=B Gets all file titles, marking the missing ones: api.php?action=query&generator=allfileusages&gafunique=&gaffrom=B Gets pages containing the files: api.php?action=query&generator=allfileusages&gaffrom=B Generator: This module may be used as a generator * list=allimages (ai) * Enumerate all images sequentially https://www.mediawiki.org/wiki/API:Allimages This module requires read rights Parameters: aisort - Property to sort by One value: name, timestamp Default: name aidir - The direction in which to list One value: ascending, descending, newer, older Default: ascending aifrom - The image title to start enumerating from. Can only be used with aisort=name aito - The image title to stop enumerating at. Can only be used with aisort=name aicontinue - When more results are available, use this to continue aistart - The timestamp to start enumerating from. Can only be used with aisort=timestamp aiend - The timestamp to end enumerating. Can only be used with aisort=timestamp aiprop - What image information to get: timestamp - Adds timestamp for the uploaded version user - Adds the user who uploaded the image version userid - Add the user ID that uploaded the image version comment - Comment on the version parsedcomment - Parse the comment on the version url - Gives URL to the image and the description page size - Adds the size of the image in bytes and the height, width and page count (if applicable) dimensions - Alias for size sha1 - Adds SHA-1 hash for the image mime - Adds MIME type of the image mediatype - Adds the media type of the image metadata - Lists Exif metadata for the version of the image bitdepth - Adds the bit depth of the version uploadwarning - Used by the Special:Upload page to get information about an existing file. Not intended for use outside MediaWiki core Values (separate with '|'): timestamp, user, userid, comment, parsedcomment, url, size, dimensions, sha1, mime, mediatype, metadata, bitdepth, uploadwarning Default: timestamp|url aiprefix - Search for all image titles that begin with this value. Can only be used with aisort=name aiminsize - Limit to images with at least this many bytes aimaxsize - Limit to images with at most this many bytes aisha1 - SHA1 hash of image. Overrides aisha1base36 aisha1base36 - SHA1 hash of image in base 36 (used in MediaWiki) aiuser - Only return files uploaded by this user. Can only be used with aisort=timestamp. Cannot be used together with aifilterbots aifilterbots - How to filter files uploaded by bots. Can only be used with aisort=timestamp. Cannot be used together with aiuser One value: all, bots, nobots Default: all aimime - What MIME type to search for. e.g. image/jpeg. Disabled in Miser Mode ailimit - How many images in total to return No more than 500 (5000 for bots) allowed Default: 10 Examples: Simple Use Show a list of files starting at the letter "B": api.php?action=query&list=allimages&aifrom=B Simple Use Show a list of recently uploaded files similar to Special:NewFiles: api.php?action=query&list=allimages&aiprop=user|timestamp|url&aisort=timestamp&aidir=older Using as Generator Show info about 4 files starting at the letter "T": api.php?action=query&generator=allimages&gailimit=4&gaifrom=T&prop=imageinfo Generator: This module may be used as a generator * list=alllinks (al) * Enumerate all links that point to a given namespace https://www.mediawiki.org/wiki/API:Alllinks This module requires read rights Parameters: alcontinue - When more results are available, use this to continue alfrom - The title of the link to start enumerating from alto - The title of the link to stop enumerating at alprefix - Search for all linked titles that begin with this value alunique - Only show distinct linked titles. Cannot be used with alprop=ids. When used as a generator, yields target pages instead of source pages. alprop - What pieces of information to include ids - Adds the pageid of the linking page (Cannot be used with alunique) title - Adds the title of the link Values (separate with '|'): ids, title Default: title alnamespace - The namespace to enumerate One value: 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 102, 103, 108, 109, 106, 107, 104, 105 Default: 0 allimit - How many total items to return No more than 500 (5000 for bots) allowed Default: 10 aldir - The direction in which to list One value: ascending, descending Default: ascending Examples: List linked titles with page ids they are from, including missing ones. Start at B: api.php?action=query&list=alllinks&alfrom=B&alprop=ids|title List unique linked titles: api.php?action=query&list=alllinks&alunique=&alfrom=B Gets all linked titles, marking the missing ones: api.php?action=query&generator=alllinks&galunique=&galfrom=B Gets pages containing the links: api.php?action=query&generator=alllinks&galfrom=B Generator: This module may be used as a generator * list=allpages (ap) * Enumerate all pages sequentially in a given namespace https://www.mediawiki.org/wiki/API:Allpages This module requires read rights Parameters: apfrom - The page title to start enumerating from apcontinue - When more results are available, use this to continue apto - The page title to stop enumerating at apprefix - Search for all page titles that begin with this value apnamespace - The namespace to enumerate One value: 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 102, 103, 108, 109, 106, 107, 104, 105 Default: 0 apfilterredir - Which pages to list One value: all, redirects, nonredirects Default: all apminsize - Limit to pages with at least this many bytes apmaxsize - Limit to pages with at most this many bytes apprtype - Limit to protected pages only Values (separate with '|'): edit, move, upload apprlevel - The protection level (must be used with apprtype= parameter) Can be empty, or Values (separate with '|'): autoconfirmed, sysop apprfiltercascade - Filter protections based on cascadingness (ignored when apprtype isn't set) One value: cascading, noncascading, all Default: all aplimit - How many total pages to return. No more than 500 (5000 for bots) allowed Default: 10 apdir - The direction in which to list One value: ascending, descending Default: ascending apfilterlanglinks - Filter based on whether a page has langlinks Note that this may not consider langlinks added by extensions. One value: withlanglinks, withoutlanglinks, all Default: all apprexpiry - Which protection expiry to filter the page on indefinite - Get only pages with indefinite protection expiry definite - Get only pages with a definite (specific) protection expiry all - Get pages with any protections expiry One value: indefinite, definite, all Default: all Examples: Simple Use Show a list of pages starting at the letter "B": api.php?action=query&list=allpages&apfrom=B Using as Generator Show info about 4 pages starting at the letter "T": api.php?action=query&generator=allpages&gaplimit=4&gapfrom=T&prop=info Show content of first 2 non-redirect pages beginning at "Re": api.php?action=query&generator=allpages&gaplimit=2&gapfilterredir=nonredirects&gapfrom=Re&prop=revisions&rvprop=content Generator: This module may be used as a generator * list=alltransclusions (at) * List all transclusions (pages embedded using {{x}}), including non-existing https://www.mediawiki.org/wiki/API:Alltransclusions This module requires read rights Parameters: atcontinue - When more results are available, use this to continue atfrom - The title of the transclusion to start enumerating from atto - The title of the transclusion to stop enumerating at atprefix - Search for all transcluded titles that begin with this value atunique - Only show distinct transcluded titles. Cannot be used with atprop=ids. When used as a generator, yields target pages instead of source pages. atprop - What pieces of information to include ids - Adds the pageid of the transcluding page (Cannot be used with atunique) title - Adds the title of the transclusion Values (separate with '|'): ids, title Default: title atnamespace - The namespace to enumerate One value: 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 102, 103, 108, 109, 106, 107, 104, 105 Default: 10 atlimit - How many total items to return No more than 500 (5000 for bots) allowed Default: 10 atdir - The direction in which to list One value: ascending, descending Default: ascending Examples: List transcluded titles with page ids they are from, including missing ones. Start at B: api.php?action=query&list=alltransclusions&atfrom=B&atprop=ids|title List unique transcluded titles: api.php?action=query&list=alltransclusions&atunique=&atfrom=B Gets all transcluded titles, marking the missing ones: api.php?action=query&generator=alltransclusions&gatunique=&gatfrom=B Gets pages containing the transclusions: api.php?action=query&generator=alltransclusions&gatfrom=B Generator: This module may be used as a generator * list=allusers (au) * Enumerate all registered users https://www.mediawiki.org/wiki/API:Allusers This module requires read rights Parameters: aufrom - The user name to start enumerating from auto - The user name to stop enumerating at auprefix - Search for all users that begin with this value audir - Direction to sort in One value: ascending, descending Default: ascending augroup - Limit users to given group name(s) Values (separate with '|'): bot, sysop, bureaucrat, smwadministrator auexcludegroup - Exclude users in given group name(s) Values (separate with '|'): bot, sysop, bureaucrat, smwadministrator aurights - Limit users to given right(s) (does not include rights granted by implicit or auto-promoted groups like *, user, or autoconfirmed) Values (separate with '|'): apihighlimits, autoconfirmed, autopatrol, bigdelete, block, blockemail, bot, browsearchive, createaccount, createpage, createtalk, delete, deletedhistory, deletedtext, deletelogentry, deleterevision, edit, editinterface, editprotected, editmyoptions, editmyprivateinfo, editmyusercss, editmyuserjs, editmywatchlist, editsemiprotected, editusercssjs, editusercss, edituserjs, hideuser, import, importupload, ipblock-exempt, markbotedits, mergehistory, minoredit, move, movefile, move-rootuserpages, move-subpages, nominornewtalk, noratelimit, override-export-depth, passwordreset, patrol, patrolmarks, protect, proxyunbannable, purge, read, reupload, reupload-own, reupload-shared, rollback, sendemail, siteadmin, suppressionlog, suppressredirect, suppressrevision, unblockself, undelete, unwatchedpages, upload, upload_by_url, userrights, userrights-interwiki, viewmyprivateinfo, viewmywatchlist, writeapi, viewedittab, editrestrictedfields, createclass, skipcaptcha, smw-admin Maximum number of values 50 (500 for bots) auprop - What pieces of information to include. blockinfo - Adds the information about a current block on the user groups - Lists groups that the user is in. This uses more server resources and may return fewer results than the limit implicitgroups - Lists all the groups the user is automatically in rights - Lists rights that the user has editcount - Adds the edit count of the user registration - Adds the timestamp of when the user registered if available (may be blank) Values (separate with '|'): blockinfo, groups, implicitgroups, rights, editcount, registration aulimit - How many total user names to return No more than 500 (5000 for bots) allowed Default: 10 auwitheditsonly - Only list users who have made edits auactiveusers - Only list users active in the last 30 days(s) Example: api.php?action=query&list=allusers&aufrom=Y * list=backlinks (bl) * Find all pages that link to the given page https://www.mediawiki.org/wiki/API:Backlinks This module requires read rights Parameters: bltitle - Title to search. Cannot be used together with blpageid blpageid - Pageid to search. Cannot be used together with bltitle blcontinue - When more results are available, use this to continue blnamespace - The namespace to enumerate Values (separate with '|'): 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 102, 103, 108, 109, 106, 107, 104, 105 Maximum number of values 50 (500 for bots) bldir - The direction in which to list One value: ascending, descending Default: ascending blfilterredir - How to filter for redirects. If set to nonredirects when blredirect is enabled, this is only applied to the second level One value: all, redirects, nonredirects Default: all bllimit - How many total pages to return. If blredirect is enabled, limit applies to each level separately (which means you may get up to 2 * limit results). No more than 500 (5000 for bots) allowed Default: 10 blredirect - If linking page is a redirect, find all pages that link to that redirect as well. Maximum limit is halved. Examples: api.php?action=query&list=backlinks&bltitle=Main%20Page api.php?action=query&generator=backlinks&gbltitle=Main%20Page&prop=info Generator: This module may be used as a generator * list=blocks (bk) * List all blocked users and IP addresses https://www.mediawiki.org/wiki/API:Blocks This module requires read rights Parameters: bkstart - The timestamp to start enumerating from bkend - The timestamp to stop enumerating at bkdir - In which direction to enumerate newer - List oldest first. Note: bkstart has to be before bkend. older - List newest first (default). Note: bkstart has to be later than bkend. One value: newer, older Default: older bkids - List of block IDs to list (optional) Separate values with '|' Maximum number of values 50 (500 for bots) bkusers - List of users to search for (optional) Separate values with '|' Maximum number of values 50 (500 for bots) bkip - Get all blocks applying to this IP or CIDR range, including range blocks. Cannot be used together with bkusers. CIDR ranges broader than IPv4/16 or IPv6/19 are not accepted bklimit - The maximum amount of blocks to list No more than 500 (5000 for bots) allowed Default: 10 bkprop - Which properties to get id - Adds the ID of the block user - Adds the username of the blocked user userid - Adds the user ID of the blocked user by - Adds the username of the blocking user byid - Adds the user ID of the blocking user timestamp - Adds the timestamp of when the block was given expiry - Adds the timestamp of when the block expires reason - Adds the reason given for the block range - Adds the range of IPs affected by the block flags - Tags the ban with (autoblock, anononly, etc) Values (separate with '|'): id, user, userid, by, byid, timestamp, expiry, reason, range, flags Default: id|user|by|timestamp|expiry|reason|flags bkshow - Show only items that meet this criteria. For example, to see only indefinite blocks on IPs, set bkshow=ip|!temp Values (separate with '|'): account, !account, temp, !temp, ip, !ip, range, !range Examples: api.php?action=query&list=blocks api.php?action=query&list=blocks&bkusers=Alice|Bob * list=categorymembers (cm) * List all pages in a given category https://www.mediawiki.org/wiki/API:Categorymembers This module requires read rights Parameters: cmtitle - Which category to enumerate (required). Must include Category: prefix. Cannot be used together with cmpageid cmpageid - Page ID of the category to enumerate. Cannot be used together with cmtitle cmprop - What pieces of information to include ids - Adds the page ID title - Adds the title and namespace ID of the page sortkey - Adds the sortkey used for sorting in the category (hexadecimal string) sortkeyprefix - Adds the sortkey prefix used for sorting in the category (human-readable part of the sortkey) type - Adds the type that the page has been categorised as (page, subcat or file) timestamp - Adds the timestamp of when the page was included Values (separate with '|'): ids, title, sortkey, sortkeyprefix, type, timestamp Default: ids|title cmnamespace - Only include pages in these namespaces Values (separate with '|'): 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 102, 103, 108, 109, 106, 107, 104, 105 Maximum number of values 50 (500 for bots) cmtype - What type of category members to include. Ignored when cmsort=timestamp is set Values (separate with '|'): page, subcat, file Default: page|subcat|file cmcontinue - For large categories, give the value returned from previous query cmlimit - The maximum number of pages to return. No more than 500 (5000 for bots) allowed Default: 10 cmsort - Property to sort by One value: sortkey, timestamp Default: sortkey cmdir - In which direction to sort One value: asc, desc, ascending, descending, newer, older Default: ascending cmstart - Timestamp to start listing from. Can only be used with cmsort=timestamp cmend - Timestamp to end listing at. Can only be used with cmsort=timestamp cmstartsortkey - Sortkey to start listing from. Must be given in binary format. Can only be used with cmsort=sortkey cmendsortkey - Sortkey to end listing at. Must be given in binary format. Can only be used with cmsort=sortkey cmstartsortkeyprefix - Sortkey prefix to start listing from. Can only be used with cmsort=sortkey. Overrides cmstartsortkey cmendsortkeyprefix - Sortkey prefix to end listing BEFORE (not at, if this value occurs it will not be included!). Can only be used with cmsort=sortkey. Overrides cmendsortkey Examples: Get first 10 pages in [[Category:Physics]]: api.php?action=query&list=categorymembers&cmtitle=Category:Physics Get page info about first 10 pages in [[Category:Physics]]: api.php?action=query&generator=categorymembers&gcmtitle=Category:Physics&prop=info Generator: This module may be used as a generator * list=deletedrevs (dr) * List deleted revisions. Operates in three modes: 1) List deleted revisions for the given title(s), sorted by timestamp 2) List deleted contributions for the given user, sorted by timestamp (no titles specified) 3) List all deleted revisions in the given namespace, sorted by title and timestamp (no titles specified, druser not set) Certain parameters only apply to some modes and are ignored in others. For instance, a parameter marked (1) only applies to mode 1 and is ignored in modes 2 and 3 https://www.mediawiki.org/wiki/API:Deletedrevs This module requires read rights Parameters: drstart - The timestamp to start enumerating from (1, 2) drend - The timestamp to stop enumerating at (1, 2) drdir - In which direction to enumerate (1, 3) newer - List oldest first. Note: drstart has to be before drend. older - List newest first (default). Note: drstart has to be later than drend. One value: newer, older Default: older drfrom - Start listing at this title (3) drto - Stop listing at this title (3) drprefix - Search for all page titles that begin with this value (3) drcontinue - When more results are available, use this to continue (1, 3) drunique - List only one revision for each page (3) druser - Only list revisions by this user drexcludeuser - Don't list revisions by this user drnamespace - Only list pages in this namespace (3) One value: 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 102, 103, 108, 109, 106, 107, 104, 105 Default: 0 drlimit - The maximum amount of revisions to list No more than 500 (5000 for bots) allowed Default: 10 drprop - Which properties to get revid - Adds the revision ID of the deleted revision parentid - Adds the revision ID of the previous revision to the page user - Adds the user who made the revision userid - Adds the user ID whom made the revision comment - Adds the comment of the revision parsedcomment - Adds the parsed comment of the revision minor - Tags if the revision is minor len - Adds the length (bytes) of the revision sha1 - Adds the SHA-1 (base 16) of the revision content - Adds the content of the revision token - Gives the edit token Values (separate with '|'): revid, parentid, user, userid, comment, parsedcomment, minor, len, sha1, content, token Default: user|comment Examples: List the last deleted revisions of Main Page and Talk:Main Page, with content (mode 1): api.php?action=query&list=deletedrevs&titles=Main%20Page|Talk:Main%20Page&drprop=user|comment|content List the last 50 deleted contributions by Bob (mode 2): api.php?action=query&list=deletedrevs&druser=Bob&drlimit=50 List the first 50 deleted revisions in the main namespace (mode 3): api.php?action=query&list=deletedrevs&drdir=newer&drlimit=50 List the first 50 deleted pages in the Talk namespace (mode 3):: api.php?action=query&list=deletedrevs&drdir=newer&drlimit=50&drnamespace=1&drunique= * list=embeddedin (ei) * Find all pages that embed (transclude) the given title https://www.mediawiki.org/wiki/API:Embeddedin This module requires read rights Parameters: eititle - Title to search. Cannot be used together with eipageid eipageid - Pageid to search. Cannot be used together with eititle eicontinue - When more results are available, use this to continue einamespace - The namespace to enumerate Values (separate with '|'): 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 102, 103, 108, 109, 106, 107, 104, 105 Maximum number of values 50 (500 for bots) eidir - The direction in which to list One value: ascending, descending Default: ascending eifilterredir - How to filter for redirects One value: all, redirects, nonredirects Default: all eilimit - How many total pages to return No more than 500 (5000 for bots) allowed Default: 10 Examples: api.php?action=query&list=embeddedin&eititle=Template:Stub api.php?action=query&generator=embeddedin&geititle=Template:Stub&prop=info Generator: This module may be used as a generator * list=exturlusage (eu) * Enumerate pages that contain a given URL https://www.mediawiki.org/wiki/API:Exturlusage This module requires read rights Parameters: euprop - What pieces of information to include ids - Adds the ID of page title - Adds the title and namespace ID of the page url - Adds the URL used in the page Values (separate with '|'): ids, title, url Default: ids|title|url euoffset - Used for paging. Use the value returned for "continue" euprotocol - Protocol of the URL. If empty and euquery set, the protocol is http. Leave both this and euquery empty to list all external links Can be empty, or One value: http, https, ftp, ftps, ssh, sftp, irc, ircs, xmpp, sip, sips, gopher, telnet, nntp, worldwind, mailto, tel, sms, news, svn, git, mms, bitcoin, magnet, urn, geo Default: euquery - Search string without protocol. See [[Special:LinkSearch]]. Leave empty to list all external links eunamespace - The page namespace(s) to enumerate. Values (separate with '|'): 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 102, 103, 108, 109, 106, 107, 104, 105 Maximum number of values 50 (500 for bots) eulimit - How many pages to return. No more than 500 (5000 for bots) allowed Default: 10 euexpandurl - Expand protocol-relative URLs with the canonical protocol Example: api.php?action=query&list=exturlusage&euquery=www.mediawiki.org Generator: This module may be used as a generator * list=filearchive (fa) * Enumerate all deleted files sequentially https://www.mediawiki.org/wiki/API:Filearchive This module requires read rights Parameters: fafrom - The image title to start enumerating from facontinue - When more results are available, use this to continue fato - The image title to stop enumerating at faprefix - Search for all image titles that begin with this value falimit - How many images to return in total No more than 500 (5000 for bots) allowed Default: 10 fadir - The direction in which to list One value: ascending, descending Default: ascending fasha1 - SHA1 hash of image. Overrides fasha1base36 fasha1base36 - SHA1 hash of image in base 36 (used in MediaWiki) faprop - What image information to get: sha1 - Adds SHA-1 hash for the image timestamp - Adds timestamp for the uploaded version user - Adds user who uploaded the image version size - Adds the size of the image in bytes and the height, width and page count (if applicable) dimensions - Alias for size description - Adds description the image version parseddescription - Parse the description on the version mime - Adds MIME of the image mediatype - Adds the media type of the image metadata - Lists Exif metadata for the version of the image bitdepth - Adds the bit depth of the version archivename - Adds the file name of the archive version for non-latest versions Values (separate with '|'): sha1, timestamp, user, size, dimensions, description, parseddescription, mime, mediatype, metadata, bitdepth, archivename Default: timestamp Example: Simple Use Show a list of all deleted files: api.php?action=query&list=filearchive * list=imageusage (iu) * Find all pages that use the given image title. https://www.mediawiki.org/wiki/API:Imageusage This module requires read rights Parameters: iutitle - Title to search. Cannot be used together with iupageid iupageid - Pageid to search. Cannot be used together with iutitle iucontinue - When more results are available, use this to continue iunamespace - The namespace to enumerate Values (separate with '|'): 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 102, 103, 108, 109, 106, 107, 104, 105 Maximum number of values 50 (500 for bots) iudir - The direction in which to list One value: ascending, descending Default: ascending iufilterredir - How to filter for redirects. If set to nonredirects when iuredirect is enabled, this is only applied to the second level One value: all, redirects, nonredirects Default: all iulimit - How many total pages to return. If iuredirect is enabled, limit applies to each level separately (which means you may get up to 2 * limit results). No more than 500 (5000 for bots) allowed Default: 10 iuredirect - If linking page is a redirect, find all pages that link to that redirect as well. Maximum limit is halved. Examples: api.php?action=query&list=imageusage&iutitle=File:Albert%20Einstein%20Head.jpg api.php?action=query&generator=imageusage&giutitle=File:Albert%20Einstein%20Head.jpg&prop=info Generator: This module may be used as a generator * list=iwbacklinks (iwbl) * Find all pages that link to the given interwiki link. Can be used to find all links with a prefix, or all links to a title (with a given prefix). Using neither parameter is effectively "All IW Links" https://www.mediawiki.org/wiki/API:Iwbacklinks This module requires read rights Parameters: iwblprefix - Prefix for the interwiki iwbltitle - Interwiki link to search for. Must be used with iwblprefix iwblcontinue - When more results are available, use this to continue iwbllimit - How many total pages to return No more than 500 (5000 for bots) allowed Default: 10 iwblprop - Which properties to get iwprefix - Adds the prefix of the interwiki iwtitle - Adds the title of the interwiki Values (separate with '|'): iwprefix, iwtitle Default: iwbldir - The direction in which to list One value: ascending, descending Default: ascending Examples: api.php?action=query&list=iwbacklinks&iwbltitle=Test&iwblprefix=wikibooks api.php?action=query&generator=iwbacklinks&giwbltitle=Test&giwblprefix=wikibooks&prop=info Generator: This module may be used as a generator * list=langbacklinks (lbl) * Find all pages that link to the given language link. Can be used to find all links with a language code, or all links to a title (with a given language). Using neither parameter is effectively "All Language Links". Note that this may not consider language links added by extensions. https://www.mediawiki.org/wiki/API:Langbacklinks This module requires read rights Parameters: lbllang - Language for the language link lbltitle - Language link to search for. Must be used with lbllang lblcontinue - When more results are available, use this to continue lbllimit - How many total pages to return No more than 500 (5000 for bots) allowed Default: 10 lblprop - Which properties to get lllang - Adds the language code of the language link lltitle - Adds the title of the language link Values (separate with '|'): lllang, lltitle Default: lbldir - The direction in which to list One value: ascending, descending Default: ascending Examples: api.php?action=query&list=langbacklinks&lbltitle=Test&lbllang=fr api.php?action=query&generator=langbacklinks&glbltitle=Test&glbllang=fr&prop=info Generator: This module may be used as a generator * list=logevents (le) * Get events from logs https://www.mediawiki.org/wiki/API:Logevents This module requires read rights Parameters: leprop - Which properties to get ids - Adds the ID of the log event title - Adds the title of the page for the log event type - Adds the type of log event user - Adds the user responsible for the log event userid - Adds the user ID who was responsible for the log event timestamp - Adds the timestamp for the event comment - Adds the comment of the event parsedcomment - Adds the parsed comment of the event details - Lists additional details about the event tags - Lists tags for the event Values (separate with '|'): ids, title, type, user, userid, timestamp, comment, parsedcomment, details, tags Default: ids|title|type|user|timestamp|comment|details letype - Filter log entries to only this type Can be empty, or One value: block, protect, rights, delete, upload, move, import, patrol, merge, suppress, newusers leaction - Filter log actions to only this type. Overrides letype One value: block/block, block/unblock, block/reblock, protect/protect, protect/modify, protect/unprotect, protect/move_prot, upload/upload, upload/overwrite, upload/revert, import/upload, import/interwiki, merge/merge, suppress/block, suppress/reblock, move/move, move/move_redir, delete/delete, delete/restore, delete/revision, delete/event, suppress/revision, suppress/event, suppress/delete, patrol/patrol, rights/rights, rights/autopromote, newusers/newusers, newusers/create, newusers/create2, newusers/byemail, newusers/autocreate lestart - The timestamp to start enumerating from leend - The timestamp to end enumerating ledir - In which direction to enumerate newer - List oldest first. Note: lestart has to be before leend. older - List newest first (default). Note: lestart has to be later than leend. One value: newer, older Default: older leuser - Filter entries to those made by the given user letitle - Filter entries to those related to a page leprefix - Filter entries that start with this prefix. Disabled in Miser Mode letag - Only list event entries tagged with this tag lelimit - How many total event entries to return No more than 500 (5000 for bots) allowed Default: 10 Example: api.php?action=query&list=logevents * list=pagepropnames (ppn) * List all page prop names in use on the wiki https://www.mediawiki.org/wiki/API:Pagepropnames This module requires read rights Parameters: ppncontinue - When more results are available, use this to continue ppnlimit - The maximum number of pages to return No more than 500 (5000 for bots) allowed Default: 10 Example: Get first 10 prop names: api.php?action=query&list=pagepropnames * list=pageswithprop (pwp) * List all pages using a given page prop https://www.mediawiki.org/wiki/API:Pageswithprop This module requires read rights Parameters: pwppropname - Page prop for which to enumerate pages This parameter is required pwpprop - What pieces of information to include ids - Adds the page ID title - Adds the title and namespace ID of the page value - Adds the value of the page prop Values (separate with '|'): ids, title, value Default: ids|title pwpcontinue - When more results are available, use this to continue pwplimit - The maximum number of pages to return No more than 500 (5000 for bots) allowed Default: 10 pwpdir - In which direction to sort One value: ascending, descending Default: ascending Examples: Get first 10 pages using {{DISPLAYTITLE:}}: api.php?action=query&list=pageswithprop&pwppropname=displaytitle&pwpprop=ids|title|value Get page info about first 10 pages using __NOTOC__: api.php?action=query&generator=pageswithprop&gpwppropname=notoc&prop=info Generator: This module may be used as a generator * list=protectedtitles (pt) * List all titles protected from creation https://www.mediawiki.org/wiki/API:Protectedtitles This module requires read rights Parameters: ptnamespace - Only list titles in these namespaces Values (separate with '|'): 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 102, 103, 108, 109, 106, 107, 104, 105 Maximum number of values 50 (500 for bots) ptlevel - Only list titles with these protection levels Values (separate with '|'): autoconfirmed, sysop ptlimit - How many total pages to return No more than 500 (5000 for bots) allowed Default: 10 ptdir - In which direction to enumerate newer - List oldest first. Note: ptstart has to be before ptend. older - List newest first (default). Note: ptstart has to be later than ptend. One value: newer, older Default: older ptstart - Start listing at this protection timestamp ptend - Stop listing at this protection timestamp ptprop - Which properties to get timestamp - Adds the timestamp of when protection was added user - Adds the user that added the protection userid - Adds the user id that added the protection comment - Adds the comment for the protection parsedcomment - Adds the parsed comment for the protection expiry - Adds the timestamp of when the protection will be lifted level - Adds the protection level Values (separate with '|'): timestamp, user, userid, comment, parsedcomment, expiry, level Default: timestamp|level Example: api.php?action=query&list=protectedtitles Generator: This module may be used as a generator * list=querypage (qp) * Get a list provided by a QueryPage-based special page https://www.mediawiki.org/wiki/API:Querypage This module requires read rights Parameters: qppage - The name of the special page. Note, this is case sensitive This parameter is required One value: Ancientpages, BrokenRedirects, Deadendpages, DoubleRedirects, Listredirects, Lonelypages, Longpages, Mostcategories, Mostimages, Mostinterwikis, Mostlinkedcategories, Mostlinkedtemplates, Mostlinked, Mostrevisions, Fewestrevisions, Shortpages, Uncategorizedcategories, Uncategorizedpages, Uncategorizedimages, Uncategorizedtemplates, Unusedcategories, Unusedimages, Wantedcategories, Wantedfiles, Wantedpages, Wantedtemplates, Unwatchedpages, Unusedtemplates, Withoutinterwiki, Popularpages qpoffset - When more results are available, use this to continue Default: 0 qplimit - Number of results to return No more than 500 (5000 for bots) allowed Default: 10 Example: api.php?action=query&list=querypage&qppage=Ancientpages Generator: This module may be used as a generator * list=random (rn) * Get a set of random pages NOTE: Pages are listed in a fixed sequence, only the starting point is random. This means that if, for example, "Main Page" is the first random page on your list, "List of fictional monkeys" will *always* be second, "List of people on stamps of Vanuatu" third, etc NOTE: If the number of pages in the namespace is lower than rnlimit, you will get fewer pages. You will not get the same page twice https://www.mediawiki.org/wiki/API:Random This module requires read rights Parameters: rnnamespace - Return pages in these namespaces only Values (separate with '|'): 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 102, 103, 108, 109, 106, 107, 104, 105 Maximum number of values 50 (500 for bots) rnlimit - Limit how many random pages will be returned No more than 10 (20 for bots) allowed Default: 1 rnredirect - Load a random redirect instead of a random page Example: api.php?action=query&list=random&rnnamespace=0&rnlimit=2 Generator: This module may be used as a generator * list=recentchanges (rc) * Enumerate recent changes https://www.mediawiki.org/wiki/API:Recentchanges This module requires read rights Parameters: rcstart - The timestamp to start enumerating from rcend - The timestamp to end enumerating rcdir - In which direction to enumerate newer - List oldest first. Note: rcstart has to be before rcend. older - List newest first (default). Note: rcstart has to be later than rcend. One value: newer, older Default: older rcnamespace - Filter log entries to only this namespace(s) Values (separate with '|'): 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 102, 103, 108, 109, 106, 107, 104, 105 Maximum number of values 50 (500 for bots) rcuser - Only list changes by this user rcexcludeuser - Don't list changes by this user rctag - Only list changes tagged with this tag rcprop - Include additional pieces of information user - Adds the user responsible for the edit and tags if they are an IP userid - Adds the user id responsible for the edit comment - Adds the comment for the edit parsedcomment - Adds the parsed comment for the edit flags - Adds flags for the edit timestamp - Adds timestamp of the edit title - Adds the page title of the edit ids - Adds the page ID, recent changes ID and the new and old revision ID sizes - Adds the new and old page length in bytes redirect - Tags edit if page is a redirect patrolled - Tags edits that have been patrolled loginfo - Adds log information (logid, logtype, etc) to log entries tags - Lists tags for the entry sha1 - Adds the content checksum for entries associated with a revision Values (separate with '|'): user, userid, comment, parsedcomment, flags, timestamp, title, ids, sizes, redirect, patrolled, loginfo, tags, sha1 Default: title|timestamp|ids rctoken - Which tokens to obtain for each change Values (separate with '|'): patrol rcshow - Show only items that meet this criteria. For example, to see only minor edits done by logged-in users, set rcshow=minor|!anon Values (separate with '|'): minor, !minor, bot, !bot, anon, !anon, redirect, !redirect, patrolled, !patrolled rclimit - How many total changes to return No more than 500 (5000 for bots) allowed Default: 10 rctype - Which types of changes to show Values (separate with '|'): edit, external, new, log rctoponly - Only list changes which are the latest revision rccontinue - When more results are available, use this to continue Example: api.php?action=query&list=recentchanges Generator: This module may be used as a generator * list=search (sr) * Perform a full text search https://www.mediawiki.org/wiki/API:Search This module requires read rights Parameters: srsearch - Search for all page titles (or content) that has this value This parameter is required srnamespace - The namespace(s) to enumerate Values (separate with '|'): 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 102, 103, 108, 109, 106, 107, 104, 105 Maximum number of values 50 (500 for bots) Default: 0 srwhat - Search inside the text or titles One value: title, text, nearmatch srinfo - What metadata to return Values (separate with '|'): totalhits, suggestion Default: totalhits|suggestion srprop - What properties to return size - Adds the size of the page in bytes wordcount - Adds the word count of the page timestamp - Adds the timestamp of when the page was last edited score - Adds the score (if any) from the search engine snippet - Adds a parsed snippet of the page titlesnippet - Adds a parsed snippet of the page title redirectsnippet - Adds a parsed snippet of the redirect title redirecttitle - Adds the title of the matching redirect sectionsnippet - Adds a parsed snippet of the matching section title sectiontitle - Adds the title of the matching section hasrelated - Indicates whether a related search is available Values (separate with '|'): size, wordcount, timestamp, score, snippet, titlesnippet, redirecttitle, redirectsnippet, sectiontitle, sectionsnippet, hasrelated Default: size|wordcount|timestamp|snippet srredirects - Include redirect pages in the search sroffset - Use this value to continue paging (return by query) Default: 0 srlimit - How many total pages to return No more than 50 (500 for bots) allowed Default: 10 Examples: api.php?action=query&list=search&srsearch=meaning api.php?action=query&list=search&srwhat=text&srsearch=meaning api.php?action=query&generator=search&gsrsearch=meaning&prop=info Generator: This module may be used as a generator * list=tags (tg) * List change tags https://www.mediawiki.org/wiki/API:Tags This module requires read rights Parameters: tgcontinue - When more results are available, use this to continue tglimit - The maximum number of tags to list No more than 500 (5000 for bots) allowed Default: 10 tgprop - Which properties to get name - Adds name of tag displayname - Adds system message for the tag description - Adds description of the tag hitcount - Adds the amount of revisions that have this tag Values (separate with '|'): name, displayname, description, hitcount Default: name Example: api.php?action=query&list=tags&tgprop=displayname|description|hitcount * list=usercontribs (uc) * Get all edits by a user https://www.mediawiki.org/wiki/API:Usercontribs This module requires read rights Parameters: uclimit - The maximum number of contributions to return No more than 500 (5000 for bots) allowed Default: 10 ucstart - The start timestamp to return from ucend - The end timestamp to return to uccontinue - When more results are available, use this to continue ucuser - The users to retrieve contributions for Separate values with '|' Maximum number of values 50 (500 for bots) ucuserprefix - Retrieve contributions for all users whose names begin with this value. Overrides ucuser ucdir - In which direction to enumerate newer - List oldest first. Note: ucstart has to be before ucend. older - List newest first (default). Note: ucstart has to be later than ucend. One value: newer, older Default: older ucnamespace - Only list contributions in these namespaces Values (separate with '|'): 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 102, 103, 108, 109, 106, 107, 104, 105 Maximum number of values 50 (500 for bots) ucprop - Include additional pieces of information ids - Adds the page ID and revision ID title - Adds the title and namespace ID of the page timestamp - Adds the timestamp of the edit comment - Adds the comment of the edit parsedcomment - Adds the parsed comment of the edit size - Adds the new size of the edit sizediff - Adds the size delta of the edit against its parent flags - Adds flags of the edit patrolled - Tags patrolled edits tags - Lists tags for the edit Values (separate with '|'): ids, title, timestamp, comment, parsedcomment, size, sizediff, flags, patrolled, tags Default: ids|title|timestamp|comment|size|flags ucshow - Show only items that meet this criteria, e.g. non minor edits only: ucshow=!minor NOTE: if ucshow=patrolled or ucshow=!patrolled is set, revisions older than $wgRCMaxAge (7862400) won't be shown Values (separate with '|'): minor, !minor, patrolled, !patrolled uctag - Only list revisions tagged with this tag uctoponly - Only list changes which are the latest revision Examples: api.php?action=query&list=usercontribs&ucuser=YurikBot api.php?action=query&list=usercontribs&ucuserprefix=217.121.114. * list=users (us) * Get information about a list of users https://www.mediawiki.org/wiki/API:Users This module requires read rights Parameters: usprop - What pieces of information to include blockinfo - Tags if the user is blocked, by whom, and for what reason groups - Lists all the groups the user(s) belongs to implicitgroups - Lists all the groups a user is automatically a member of rights - Lists all the rights the user(s) has editcount - Adds the user's edit count registration - Adds the user's registration timestamp emailable - Tags if the user can and wants to receive email through [[Special:Emailuser]] gender - Tags the gender of the user. Returns "male", "female", or "unknown" Values (separate with '|'): blockinfo, groups, implicitgroups, rights, editcount, registration, emailable, gender ususers - A list of users to obtain the same information for Separate values with '|' Maximum number of values 50 (500 for bots) ustoken - Which tokens to obtain for each user Values (separate with '|'): userrights Example: api.php?action=query&list=users&ususers=brion|TimStarling&usprop=groups|editcount|gender * list=watchlist (wl) * Get all recent changes to pages in the logged in user's watchlist https://www.mediawiki.org/wiki/API:Watchlist This module requires read rights Parameters: wlallrev - Include multiple revisions of the same page within given timeframe wlstart - The timestamp to start enumerating from wlend - The timestamp to end enumerating wlnamespace - Filter changes to only the given namespace(s) Values (separate with '|'): 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 102, 103, 108, 109, 106, 107, 104, 105 Maximum number of values 50 (500 for bots) wluser - Only list changes by this user wlexcludeuser - Don't list changes by this user wldir - In which direction to enumerate newer - List oldest first. Note: wlstart has to be before wlend. older - List newest first (default). Note: wlstart has to be later than wlend. One value: newer, older Default: older wllimit - How many total results to return per request No more than 500 (5000 for bots) allowed Default: 10 wlprop - Which additional items to get (non-generator mode only). ids - Adds revision ids and page ids title - Adds title of the page flags - Adds flags for the edit user - Adds the user who made the edit userid - Adds user id of whom made the edit comment - Adds comment of the edit parsedcomment - Adds parsed comment of the edit timestamp - Adds timestamp of the edit patrol - Tags edits that are patrolled sizes - Adds the old and new lengths of the page notificationtimestamp - Adds timestamp of when the user was last notified about the edit loginfo - Adds log information where appropriate Values (separate with '|'): ids, title, flags, user, userid, comment, parsedcomment, timestamp, patrol, sizes, notificationtimestamp, loginfo Default: ids|title|flags wlshow - Show only items that meet this criteria. For example, to see only minor edits done by logged-in users, set wlshow=minor|!anon Values (separate with '|'): minor, !minor, bot, !bot, anon, !anon, patrolled, !patrolled wltype - Which types of changes to show edit - Regular page edits external - External changes new - Page creations log - Log entries Values (separate with '|'): edit, external, new, log wlowner - The name of the user whose watchlist you'd like to access wltoken - Give a security token (settable in preferences) to allow access to another user's watchlist Examples: api.php?action=query&list=watchlist api.php?action=query&list=watchlist&wlprop=ids|title|timestamp|user|comment api.php?action=query&list=watchlist&wlallrev=&wlprop=ids|title|timestamp|user|comment api.php?action=query&generator=watchlist&prop=info api.php?action=query&generator=watchlist&gwlallrev=&prop=revisions&rvprop=timestamp|user api.php?action=query&list=watchlist&wlowner=Bob_Smith&wltoken=123ABC Generator: This module may be used as a generator * list=watchlistraw (wr) * Get all pages on the logged in user's watchlist https://www.mediawiki.org/wiki/API:Watchlistraw This module requires read rights Parameters: wrcontinue - When more results are available, use this to continue wrnamespace - Only list pages in the given namespace(s) Values (separate with '|'): 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 102, 103, 108, 109, 106, 107, 104, 105 Maximum number of values 50 (500 for bots) wrlimit - How many total results to return per request No more than 500 (5000 for bots) allowed Default: 10 wrprop - Which additional properties to get (non-generator mode only) changed - Adds timestamp of when the user was last notified about the edit Values (separate with '|'): changed wrshow - Only list items that meet these criteria Values (separate with '|'): changed, !changed wrowner - The name of the user whose watchlist you'd like to access wrtoken - Give a security token (settable in preferences) to allow access to another user's watchlist wrdir - Direction to sort the titles and namespaces in One value: ascending, descending Default: ascending Examples: api.php?action=query&list=watchlistraw api.php?action=query&generator=watchlistraw&gwrshow=changed&prop=revisions Generator: This module may be used as a generator --- --- --- --- --- --- --- --- --- --- --- --- Query: Meta --- --- --- --- --- --- --- --- --- --- --- --- * meta=allmessages (am) * Return messages from this site https://www.mediawiki.org/wiki/API:Meta#allmessages_.2F_am This module requires read rights Parameters: ammessages - Which messages to output. "*" (default) means all messages Separate values with '|' Maximum number of values 50 (500 for bots) Default: * amprop - Which properties to get Values (separate with '|'): default amenableparser - Set to enable parser, will preprocess the wikitext of message Will substitute magic words, handle templates etc. amnocontent - If set, do not include the content of the messages in the output. amincludelocal - Also include local messages, i.e. messages that don't exist in the software but do exist as a MediaWiki: page. This lists all MediaWiki: pages, so it will also list those that aren't 'really' messages such as Common.js amargs - Arguments to be substituted into message Separate values with '|' Maximum number of values 50 (500 for bots) amfilter - Return only messages with names that contain this string amcustomised - Return only messages in this customisation state One value: all, modified, unmodified Default: all amlang - Return messages in this language amfrom - Return messages starting at this message amto - Return messages ending at this message amtitle - Page name to use as context when parsing message (for enableparser option) amprefix - Return messages with this prefix Examples: api.php?action=query&meta=allmessages&refix=ipb- api.php?action=query&meta=allmessages&ammessages=august|mainpage&amlang=de * meta=filerepoinfo (fri) * Return meta information about image repositories configured on the wiki. This module requires read rights Parameters: friprop - Which repository properties to get (there may be more available on some wikis): apiurl - URL to the repository API - helpful for getting image info from the host. name - The key of the repository - used in e.g. $wgForeignFileRepos and imageinfo return values. displayname - The human-readable name of the repository wiki. rooturl - Root URL for image paths. local - Whether that repository is the local one or not. Values (separate with '|'): name, displayname, rootUrl, local Default: name|displayname|rootUrl|local Example: api.php?action=query&meta=filerepoinfo&friprop=apiurl|name|displayname * meta=siteinfo (si) * Return general information about the site https://www.mediawiki.org/wiki/API:Meta#siteinfo_.2F_si This module requires read rights Parameters: siprop - Which sysinfo properties to get: general - Overall system information namespaces - List of registered namespaces and their canonical names namespacealiases - List of registered namespace aliases specialpagealiases - List of special page aliases magicwords - List of magic words and their aliases statistics - Returns site statistics interwikimap - Returns interwiki map (optionally filtered, (optionally localised by using siinlanguagecode)) dbrepllag - Returns database server with the highest replication lag usergroups - Returns user groups and the associated permissions extensions - Returns extensions installed on the wiki fileextensions - Returns list of file extensions allowed to be uploaded rightsinfo - Returns wiki rights (license) information if available languages - Returns a list of languages MediaWiki supports(optionally localised by using siinlanguagecode) skins - Returns a list of all enabled skins extensiontags - Returns a list of parser extension tags functionhooks - Returns a list of parser function hooks showhooks - Returns a list of all subscribed hooks (contents of $wgHooks) variables - Returns a list of variable IDs protocols - Returns a list of protocols that are allowed in external links. Values (separate with '|'): general, namespaces, namespacealiases, specialpagealiases, magicwords, interwikimap, dbrepllag, statistics, usergroups, extensions, fileextensions, rightsinfo, languages, skins, extensiontags, functionhooks, showhooks, variables, protocols Default: general sifilteriw - Return only local or only nonlocal entries of the interwiki map One value: local, !local sishowalldb - List all database servers, not just the one lagging the most sinumberingroup - Lists the number of users in user groups siinlanguagecode - Language code for localised language names (best effort, use CLDR extension) Examples: api.php?action=query&meta=siteinfo&siprop=general|namespaces|namespacealiases|statistics api.php?action=query&meta=siteinfo&siprop=interwikimap&sifilteriw=local api.php?action=query&meta=siteinfo&siprop=dbrepllag&sishowalldb= * meta=userinfo (ui) * Get information about the current user https://www.mediawiki.org/wiki/API:Meta#userinfo_.2F_ui This module requires read rights Parameters: uiprop - What pieces of information to include blockinfo - Tags if the current user is blocked, by whom, and for what reason hasmsg - Adds a tag "message" if the current user has pending messages groups - Lists all the groups the current user belongs to implicitgroups - Lists all the groups the current user is automatically a member of rights - Lists all the rights the current user has changeablegroups - Lists the groups the current user can add to and remove from options - Lists all preferences the current user has set preferencestoken - Get a token to change current user's preferences editcount - Adds the current user's edit count ratelimits - Lists all rate limits applying to the current user realname - Adds the user's real name email - Adds the user's email address and email authentication date acceptlang - Echoes the Accept-Language header sent by the client in a structured format registrationdate - Adds the user's registration date Values (separate with '|'): blockinfo, hasmsg, groups, implicitgroups, rights, changeablegroups, options, preferencestoken, editcount, ratelimits, email, realname, acceptlang, registrationdate Examples: api.php?action=query&meta=userinfo api.php?action=query&meta=userinfo&uiprop=blockinfo|groups|rights|hasmsg *** *** *** *** *** *** *** *** *** *** *** *** *** *** Modules: continuation *** *** *** *** *** *** *** *** *** *** *** *** *** *** * action=expandtemplates * Expands all templates in wikitext https://www.mediawiki.org/wiki/API:Parsing_wikitext#expandtemplates This module requires read rights Parameters: title - Title of page Default: API text - Wikitext to convert This parameter is required generatexml - Generate XML parse tree includecomments - Whether to include HTML comments in the output Example: api.php?action=expandtemplates&text={{Project:Sandbox}} * action=parse * Parses content and returns parser output See the various prop-Modules of action=query to get information from the current version of a page There are several ways to specify the text to parse: 1) Specify a page or revision, using page, pageid, or oldid. 2) Specify content explicitly, using text, title, and contentmodel. 3) Specify only a summary to parse. prop should be given an empty value. https://www.mediawiki.org/wiki/API:Parsing_wikitext#parse This module requires read rights Parameters: title - Title of page the text belongs to. If omitted, "API" is used as the title with content model wikitext text - Text to parse. Use title or contentmodel to control the content model summary - Summary to parse page - Parse the content of this page. Cannot be used together with text and title pageid - Parse the content of this page. Overrides page redirects - If the page or the pageid parameter is set to a redirect, resolve it oldid - Parse the content of this revision. Overrides page and pageid prop - Which pieces of information to get text - Gives the parsed text of the wikitext langlinks - Gives the language links in the parsed wikitext categories - Gives the categories in the parsed wikitext categorieshtml - Gives the HTML version of the categories languageshtml - Gives the HTML version of the language links links - Gives the internal links in the parsed wikitext templates - Gives the templates in the parsed wikitext images - Gives the images in the parsed wikitext externallinks - Gives the external links in the parsed wikitext sections - Gives the sections in the parsed wikitext revid - Adds the revision ID of the parsed page displaytitle - Adds the title of the parsed wikitext headitems - Gives items to put in the <head> of the page headhtml - Gives parsed <head> of the page iwlinks - Gives interwiki links in the parsed wikitext wikitext - Gives the original wikitext that was parsed properties - Gives various properties defined in the parsed wikitext Values (separate with '|'): text, langlinks, languageshtml, categories, categorieshtml, links, templates, images, externallinks, sections, revid, displaytitle, headitems, headhtml, iwlinks, wikitext, properties Default: text|langlinks|categories|links|templates|images|externallinks|sections|revid|displaytitle|iwlinks|properties pst - Do a pre-save transform on the input before parsing it Only valid when used with text onlypst - Do a pre-save transform (PST) on the input, but don't parse it Returns the same wikitext, after a PST has been applied. Only valid when used with text effectivelanglinks - Includes language links supplied by extensions (for use with prop=langlinks|languageshtml) uselang - Which language to parse the request in section - Only retrieve the content of this section number disablepp - Disable the PP Report from the parser output generatexml - Generate XML parse tree (requires contentmodel=wikitext) preview - Parse in preview mode sectionpreview - Parse in section preview mode (enables preview mode too) contentformat - Content serialization format used for the input text Only valid when used with text One value: text/x-wiki, text/javascript, text/css, text/plain contentmodel - Content model of the input text. Default is the model of the specified title, or wikitext if title is not specified Only valid when used with text One value: wikitext, javascript, css, text Examples: Parse a page: api.php?action=parse&page=Project:Sandbox Parse wikitext: api.php?action=parse&text={{Project:Sandbox}} Parse wikitext, specifying the page title: api.php?action=parse&text={{PAGENAME}}&title=Test Parse a summary: api.php?action=parse&summary=Some+[[link]]&prop= * action=opensearch * Search the wiki using the OpenSearch protocol https://www.mediawiki.org/wiki/API:Opensearch This module requires read rights Parameters: search - Search string limit - Maximum amount of results to return No more than 100 (100 for bots) allowed Default: 10 namespace - Namespaces to search Values (separate with '|'): 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 102, 103, 108, 109, 106, 107, 104, 105 Maximum number of values 50 (500 for bots) Default: 0 suggest - Do nothing if $wgEnableOpenSearchSuggest is false format - The format of the output One value: json, jsonfm Default: json Example: api.php?action=opensearch&search=Te * action=feedcontributions * Returns a user contributions feed This module requires read rights Parameters: feedformat - The format of the feed One value: rss, atom Default: rss user - What users to get the contributions for This parameter is required namespace - What namespace to filter the contributions by One value: 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 102, 103, 108, 109, 106, 107, 104, 105 year - From year (and earlier) month - From month (and earlier) tagfilter - Filter contributions that have these tags Values (separate with '|'): Default: deletedonly - Show only deleted contributions toponly - Only show edits that are latest revisions showsizediff - Show the size difference between revisions. Disabled in Miser Mode Example: api.php?action=feedcontributions&user=Reedy * action=feedwatchlist * Returns a watchlist feed https://www.mediawiki.org/wiki/API:Watchlist_feed This module requires read rights Parameters: feedformat - The format of the feed One value: rss, atom Default: rss hours - List pages modified within this many hours from now The value must be between 1 and 72 Default: 24 linktodiffs - Link to change differences instead of article pages linktosections - Link directly to changed sections if possible allrev - Include multiple revisions of the same page within given timeframe wlowner - The name of the user whose watchlist you'd like to access wltoken - Give a security token (settable in preferences) to allow access to another user's watchlist wlshow - Show only items that meet this criteria. For example, to see only minor edits done by logged-in users, set wlshow=minor|!anon Values (separate with '|'): minor, !minor, bot, !bot, anon, !anon, patrolled, !patrolled wltype - Which types of changes to show edit - Regular page edits external - External changes new - Page creations log - Log entries Values (separate with '|'): edit, external, new, log wlexcludeuser - Don't list changes by this user Examples: api.php?action=feedwatchlist api.php?action=feedwatchlist&allrev=&linktodiffs=&hours=6 * action=help * Display this help screen. Or the help screen for the specified module https://www.mediawiki.org/wiki/API:Main_page https://www.mediawiki.org/wiki/API:FAQ https://www.mediawiki.org/wiki/API:Quick_start_guide Parameters: modules - List of module names (value of the action= parameter). Can specify submodules with a '+' Separate values with '|' Maximum number of values 50 (500 for bots) querymodules - DEPRECATED! Use modules=query+value instead. List of query module names (value of prop=, meta= or list= parameter) Separate values with '|' Maximum number of values 50 (500 for bots) Examples: Whole help page: api.php?action=help Module (action) help page: api.php?action=help&modules=protect Help for the query/categorymembers module: api.php?action=help&modules=query+categorymembers Help for the login and query/info modules: api.php?action=help&modules=login|query+info * action=paraminfo * Obtain information about certain API parameters and errors https://www.mediawiki.org/wiki/API:Parameter_information Parameters: modules - List of module names (value of the action= parameter) Values (separate with '|'): ask, askargs, block, browsebysubject, compare, createaccount, delete, edit, emailuser, expandtemplates, feedcontributions, feedwatchlist, filerevert, help, imagerotate, import, login, logout, move, opensearch, options, paraminfo, parse, patrol, protect, purge, query, rollback, rsd, setnotificationtimestamp, sfautocomplete, sfautoedit, smwinfo, tokens, unblock, undelete, upload, userrights, watch querymodules - List of query module names (value of prop=, meta= or list= parameter) Values (separate with '|'): allcategories, allfileusages, allimages, alllinks, allmessages, allpages, alltransclusions, allusers, backlinks, blocks, categories, categoryinfo, categorymembers, deletedrevs, duplicatefiles, embeddedin, extlinks, exturlusage, filearchive, filerepoinfo, imageinfo, images, imageusage, info, iwbacklinks, iwlinks, langbacklinks, langlinks, links, logevents, pagepropnames, pageprops, pageswithprop, protectedtitles, querypage, random, recentchanges, revisions, search, siteinfo, stashimageinfo, tags, templates, usercontribs, userinfo, users, watchlist, watchlistraw mainmodule - Get information about the main (top-level) module as well pagesetmodule - Get information about the pageset module (providing titles= and friends) as well formatmodules - List of format module names (value of format= parameter) Values (separate with '|'): dbg, dbgfm, dump, dumpfm, json, jsonfm, none, php, phpfm, rawfm, txt, txtfm, wddx, wddxfm, xml, xmlfm, yaml, yamlfm Example: api.php?action=paraminfo&modules=parse&querymodules=allpages|siteinfo * action=rsd * Export an RSD (Really Simple Discovery) schema This module requires read rights Example: api.php?action=rsd * action=compare * Get the difference between 2 pages You must pass a revision number or a page title or a page ID id for each part (1 and 2) This module requires read rights Parameters: fromtitle - First title to compare fromid - First page ID to compare fromrev - First revision to compare totitle - Second title to compare toid - Second page ID to compare torev - Second revision to compare Example: Create a diff between revision 1 and 2: api.php?action=compare&fromrev=1&torev=2 * action=tokens * Gets tokens for data-modifying actions This module requires read rights Parameters: type - Type of token(s) to request Values (separate with '|'): block, delete, edit, email, import, move, options, patrol, protect, unblock, watch Default: edit Examples: Retrieve an edit token (the default): api.php?action=tokens Retrieve an email token and a move token: api.php?action=tokens&type=email|move * action=purge * Purge the cache for the given titles. Requires a POST request if the user is not logged in. https://www.mediawiki.org/wiki/API:Purge This module requires read rights This module requires write rights This module only accepts POST requests Parameters: forcelinkupdate - Update the links tables forcerecursivelinkupdate - Update the links table, and update the links tables for any page that uses this page as a template titles - A list of titles to work on Separate values with '|' Maximum number of values 50 (500 for bots) pageids - A list of page IDs to work on Separate values with '|' Maximum number of values 50 (500 for bots) revids - A list of revision IDs to work on Separate values with '|' Maximum number of values 50 (500 for bots) redirects - Automatically resolve redirects converttitles - Convert titles to other variants if necessary. Only works if the wiki's content language supports variant conversion. Languages that support variant conversion include gan, iu, kk, ku, shi, sr, tg, uz, zh generator - Get the list of pages to work on by executing the specified query module. NOTE: generator parameter names must be prefixed with a 'g', see examples One value: allcategories, allfileusages, allimages, alllinks, allpages, alltransclusions, backlinks, categories, categorymembers, duplicatefiles, embeddedin, exturlusage, images, imageusage, iwbacklinks, langbacklinks, links, pageswithprop, protectedtitles, querypage, random, recentchanges, search, templates, watchlist, watchlistraw Example: Purge the "Main Page" and the "API" page: api.php?action=purge&titles=Main_Page|API * action=setnotificationtimestamp * Update the notification timestamp for watched pages. This affects the highlighting of changed pages in the watchlist and history, and the sending of email when the "Email me when a page on my watchlist is changed" preference is enabled. https://www.mediawiki.org/wiki/API:SetNotificationTimestamp This module requires read rights This module requires write rights This module only accepts POST requests Parameters: entirewatchlist - Work on all watched pages token - A token previously acquired via prop=info timestamp - Timestamp to which to set the notification timestamp torevid - Revision to set the notification timestamp to (one page only) newerthanrevid - Revision to set the notification timestamp newer than (one page only) titles - A list of titles to work on Separate values with '|' Maximum number of values 50 (500 for bots) pageids - A list of page IDs to work on Separate values with '|' Maximum number of values 50 (500 for bots) revids - A list of revision IDs to work on Separate values with '|' Maximum number of values 50 (500 for bots) redirects - Automatically resolve redirects converttitles - Convert titles to other variants if necessary. Only works if the wiki's content language supports variant conversion. Languages that support variant conversion include gan, iu, kk, ku, shi, sr, tg, uz, zh generator - Get the list of pages to work on by executing the specified query module. NOTE: generator parameter names must be prefixed with a 'g', see examples One value: allcategories, allfileusages, allimages, alllinks, allpages, alltransclusions, backlinks, categories, categorymembers, duplicatefiles, embeddedin, exturlusage, images, imageusage, iwbacklinks, langbacklinks, links, pageswithprop, protectedtitles, querypage, random, recentchanges, search, templates, watchlist, watchlistraw Examples: Reset the notification status for the entire watchlist: api.php?action=setnotificationtimestamp&entirewatchlist=&token=123ABC Reset the notification status for "Main page": api.php?action=setnotificationtimestamp&titles=Main_page&token=123ABC Set the notification timestamp for "Main page" so all edits since 1 January 2012 are unviewed: api.php?action=setnotificationtimestamp&titles=Main_page×tamp=2012-01-01T00:00:00Z&token=123ABC * action=rollback * Undo the last edit to the page. If the last user who edited the page made multiple edits in a row, they will all be rolled back https://www.mediawiki.org/wiki/API:Rollback This module requires read rights This module requires write rights This module only accepts POST requests Parameters: title - Title of the page you want to rollback. This parameter is required user - Name of the user whose edits are to be rolled back. If set incorrectly, you'll get a badtoken error. This parameter is required token - A rollback token previously retrieved through prop=revisions This parameter is required summary - Custom edit summary. If empty, default summary will be used Default: markbot - Mark the reverted edits and the revert as bot edits watchlist - Unconditionally add or remove the page from your watchlist, use preferences or do not change watch One value: watch, unwatch, preferences, nochange Default: preferences Examples: api.php?action=rollback&title=Main%20Page&user=Catrope&token=123ABC api.php?action=rollback&title=Main%20Page&user=217.121.114.116&token=123ABC&summary=Reverting%20vandalism&markbot=1 * action=delete * Delete a page https://www.mediawiki.org/wiki/API:Delete This module requires read rights This module requires write rights This module only accepts POST requests Parameters: title - Title of the page you want to delete. Cannot be used together with pageid pageid - Page ID of the page you want to delete. Cannot be used together with title token - A delete token previously retrieved through prop=info This parameter is required reason - Reason for the deletion. If not set, an automatically generated reason will be used watch - DEPRECATED! Add the page to your watchlist watchlist - Unconditionally add or remove the page from your watchlist, use preferences or do not change watch One value: watch, unwatch, preferences, nochange Default: preferences unwatch - DEPRECATED! Remove the page from your watchlist oldimage - The name of the old image to delete as provided by iiprop=archivename Examples: Delete the Main Page: api.php?action=delete&title=Main%20Page&token=123ABC Delete the Main Page with the reason "Preparing for move": api.php?action=delete&title=Main%20Page&token=123ABC&reason=Preparing%20for%20move * action=undelete * Restore certain revisions of a deleted page. A list of deleted revisions (including timestamps) can be retrieved through list=deletedrevs https://www.mediawiki.org/wiki/API:Undelete This module requires read rights This module requires write rights This module only accepts POST requests Parameters: title - Title of the page you want to restore This parameter is required token - An undelete token previously retrieved through list=deletedrevs This parameter is required reason - Reason for restoring Default: timestamps - Timestamps of the revisions to restore. If not set, all revisions will be restored. Separate values with '|' Maximum number of values 50 (500 for bots) watchlist - Unconditionally add or remove the page from your watchlist, use preferences or do not change watch One value: watch, unwatch, preferences, nochange Default: preferences Examples: api.php?action=undelete&title=Main%20Page&token=123ABC&reason=Restoring%20main%20page api.php?action=undelete&title=Main%20Page&token=123ABC×tamps=20070703220045|20070702194856 * action=protect * Change the protection level of a page https://www.mediawiki.org/wiki/API:Protect This module requires read rights This module requires write rights This module only accepts POST requests Parameters: title - Title of the page you want to (un)protect. Cannot be used together with pageid pageid - ID of the page you want to (un)protect. Cannot be used together with title token - A protect token previously retrieved through prop=info This parameter is required protections - List of protection levels, formatted action=group (e.g. edit=sysop) This parameter is required Separate values with '|' Maximum number of values 50 (500 for bots) expiry - Expiry timestamps. If only one timestamp is set, it'll be used for all protections. Use 'infinite', 'indefinite' or 'never', for a never-expiring protection. Separate values with '|' Maximum number of values 50 (500 for bots) Default: infinite reason - Reason for (un)protecting Default: cascade - Enable cascading protection (i.e. protect pages included in this page) Ignored if not all protection levels are 'sysop' or 'protect' watch - DEPRECATED! If set, add the page being (un)protected to your watchlist watchlist - Unconditionally add or remove the page from your watchlist, use preferences or do not change watch One value: watch, unwatch, preferences, nochange Default: preferences Examples: api.php?action=protect&title=Main%20Page&token=123ABC&protections=edit=sysop|move=sysop&cascade=&expiry=20070901163000|never api.php?action=protect&title=Main%20Page&token=123ABC&protections=edit=all|move=all&reason=Lifting%20restrictions * action=block * Block a user https://www.mediawiki.org/wiki/API:Block This module requires read rights This module requires write rights This module only accepts POST requests Parameters: user - Username, IP address or IP range you want to block This parameter is required token - A block token previously obtained through prop=info expiry - Relative expiry time, e.g. '5 months' or '2 weeks'. If set to 'infinite', 'indefinite' or 'never', the block will never expire. Default: never reason - Reason for block Default: anononly - Block anonymous users only (i.e. disable anonymous edits for this IP) nocreate - Prevent account creation autoblock - Automatically block the last used IP address, and any subsequent IP addresses they try to login from noemail - Prevent user from sending email through the wiki. (Requires the "blockemail" right.) hidename - Hide the username from the block log. (Requires the "hideuser" right.) allowusertalk - Allow the user to edit their own talk page (depends on $wgBlockAllowsUTEdit) reblock - If the user is already blocked, overwrite the existing block watchuser - Watch the user/IP's user and talk pages Examples: api.php?action=block&user=123.5.5.12&expiry=3%20days&reason=First%20strike api.php?action=block&user=Vandal&expiry=never&reason=Vandalism&nocreate=&autoblock=&noemail= * action=unblock * Unblock a user https://www.mediawiki.org/wiki/API:Block This module requires read rights This module requires write rights This module only accepts POST requests Parameters: id - ID of the block you want to unblock (obtained through list=blocks). Cannot be used together with user user - Username, IP address or IP range you want to unblock. Cannot be used together with id token - An unblock token previously obtained through prop=info reason - Reason for unblock Default: Examples: api.php?action=unblock&id=105 api.php?action=unblock&user=Bob&reason=Sorry%20Bob * action=move * Move a page https://www.mediawiki.org/wiki/API:Move This module requires read rights This module requires write rights This module only accepts POST requests Parameters: from - Title of the page you want to move. Cannot be used together with fromid fromid - Page ID of the page you want to move. Cannot be used together with from to - Title you want to rename the page to This parameter is required token - A move token previously retrieved through prop=info This parameter is required reason - Reason for the move Default: movetalk - Move the talk page, if it exists movesubpages - Move subpages, if applicable noredirect - Don't create a redirect watch - DEPRECATED! Add the page and the redirect to your watchlist unwatch - DEPRECATED! Remove the page and the redirect from your watchlist watchlist - Unconditionally add or remove the page from your watchlist, use preferences or do not change watch One value: watch, unwatch, preferences, nochange Default: preferences ignorewarnings - Ignore any warnings Example: api.php?action=move&from=Badtitle&to=Goodtitle&token=123ABC&reason=Misspelled%20title&movetalk=&noredirect= * action=edit * Create and edit pages. https://www.mediawiki.org/wiki/API:Edit This module requires read rights This module requires write rights This module only accepts POST requests Parameters: title - Title of the page you want to edit. Cannot be used together with pageid pageid - Page ID of the page you want to edit. Cannot be used together with title section - Section number. 0 for the top section, 'new' for a new section sectiontitle - The title for a new section text - Page content token - Edit token. You can get one of these through prop=info. The token should always be sent as the last parameter, or at least, after the text parameter This parameter is required summary - Edit summary. Also section title when section=new and sectiontitle is not set minor - Minor edit notminor - Non-minor edit bot - Mark this edit as bot basetimestamp - Timestamp of the base revision (obtained through prop=revisions&rvprop=timestamp). Used to detect edit conflicts; leave unset to ignore conflicts starttimestamp - Timestamp when you obtained the edit token. Used to detect edit conflicts; leave unset to ignore conflicts recreate - Override any errors about the article having been deleted in the meantime createonly - Don't edit the page if it exists already nocreate - Throw an error if the page doesn't exist watch - DEPRECATED! Add the page to your watchlist unwatch - DEPRECATED! Remove the page from your watchlist watchlist - Unconditionally add or remove the page from your watchlist, use preferences or do not change watch One value: watch, unwatch, preferences, nochange Default: preferences md5 - The MD5 hash of the text parameter, or the prependtext and appendtext parameters concatenated. If set, the edit won't be done unless the hash is correct prependtext - Add this text to the beginning of the page. Overrides text appendtext - Add this text to the end of the page. Overrides text. Use section=new to append a new section undo - Undo this revision. Overrides text, prependtext and appendtext undoafter - Undo all revisions from undo to this one. If not set, just undo one revision redirect - Automatically resolve redirects contentformat - Content serialization format used for the input text One value: text/x-wiki, text/javascript, text/css, text/plain contentmodel - Content model of the new content One value: wikitext, javascript, css, text captchaword - Answer to the CAPTCHA captchaid - CAPTCHA ID from previous request Examples: Edit a page (anonymous user): api.php?action=edit&title=Test&summary=test%20summary&text=article%20content&basetimestamp=20070824123454&token=%2B\ Prepend __NOTOC__ to a page (anonymous user): api.php?action=edit&title=Test&summary=NOTOC&minor=&prependtext=__NOTOC__%0A&basetimestamp=20070824123454&token=%2B\ Undo r13579 through r13585 with autosummary (anonymous user): api.php?action=edit&title=Test&undo=13585&undoafter=13579&basetimestamp=20070824123454&token=%2B\ * action=upload * Upload a file, or get the status of pending uploads. Several methods are available: * Upload file contents directly, using the "file" parameter * Have the MediaWiki server fetch a file from a URL, using the "url" parameter * Complete an earlier upload that failed due to warnings, using the "filekey" parameter Note that the HTTP POST must be done as a file upload (i.e. using multipart/form-data) when sending the "file". Also you must get and send an edit token before doing any upload stuff https://www.mediawiki.org/wiki/API:Upload This module requires read rights This module requires write rights This module only accepts POST requests Parameters: filename - Target filename comment - Upload comment. Also used as the initial page text for new files if "text" is not specified Default: text - Initial page text for new files token - Edit token. You can get one of these through prop=info This parameter is required watch - DEPRECATED! Watch the page watchlist - Unconditionally add or remove the page from your watchlist, use preferences or do not change watch One value: watch, preferences, nochange Default: preferences ignorewarnings - Ignore any warnings file - File contents Must be posted as a file upload using multipart/form-data url - URL to fetch the file from filekey - Key that identifies a previous upload that was stashed temporarily. sessionkey - DEPRECATED! Same as filekey, maintained for backward compatibility. stash - If set, the server will not add the file to the repository and stash it temporarily. filesize - Filesize of entire upload offset - Offset of chunk in bytes chunk - Chunk contents Must be posted as a file upload using multipart/form-data async - Make potentially large file operations asynchronous when possible asyncdownload - Make fetching a URL asynchronous leavemessage - If asyncdownload is used, leave a message on the user talk page if finished statuskey - Fetch the upload status for this file key (upload by URL) checkstatus - Only fetch the upload status for the given file key Examples: Upload from a URL: api.php?action=upload&filename=Wiki.png&url=http%3A//upload.wikimedia.org/wikipedia/en/b/bc/Wiki.png Complete an upload that failed due to warnings: api.php?action=upload&filename=Wiki.png&filekey=filekey&ignorewarnings=1 * action=filerevert * Revert a file to an old version This module requires read rights This module requires write rights This module only accepts POST requests Parameters: filename - Target filename without the File: prefix This parameter is required comment - Upload comment Default: archivename - Archive name of the revision to revert to This parameter is required token - Edit token. You can get one of these through prop=info This parameter is required Example: Revert Wiki.png to the version of 20110305152740: api.php?action=filerevert&filename=Wiki.png&comment=Revert&archivename=20110305152740!Wiki.png&token=123ABC * action=emailuser * Email a user. https://www.mediawiki.org/wiki/API:Email This module requires read rights This module requires write rights This module only accepts POST requests Parameters: target - User to send email to This parameter is required subject - Subject header text - Mail body This parameter is required token - A token previously acquired via prop=info This parameter is required ccme - Send a copy of this mail to me Example: Send an email to the User "WikiSysop" with the text "Content": api.php?action=emailuser&target=WikiSysop&text=Content * action=watch * Add or remove a page from/to the current user's watchlist https://www.mediawiki.org/wiki/API:Watch This module requires read rights This module requires write rights This module only accepts POST requests Parameters: title - The page to (un)watch This parameter is required unwatch - If set the page will be unwatched rather than watched uselang - Language to show the message in token - A token previously acquired via prop=info This parameter is required Examples: Watch the page "Main Page": api.php?action=watch&title=Main_Page Unwatch the page "Main Page": api.php?action=watch&title=Main_Page&unwatch= * action=patrol * Patrol a page or revision https://www.mediawiki.org/wiki/API:Patrol This module requires read rights This module requires write rights This module only accepts POST requests Parameters: token - Patrol token obtained from list=recentchanges This parameter is required rcid - Recentchanges ID to patrol revid - Revision ID to patrol Examples: api.php?action=patrol&token=123abc&rcid=230672766 api.php?action=patrol&token=123abc&revid=230672766 * action=import * Import a page from another wiki, or an XML file. Note that the HTTP POST must be done as a file upload (i.e. using multipart/form-data) when sending a file for the "xml" parameter. https://www.mediawiki.org/wiki/API:Import This module requires read rights This module requires write rights This module only accepts POST requests Parameters: token - Import token obtained through prop=info This parameter is required summary - Import summary xml - Uploaded XML file Must be posted as a file upload using multipart/form-data interwikisource - For interwiki imports: wiki to import from One value: interwikipage - For interwiki imports: page to import fullhistory - For interwiki imports: import the full history, not just the current version templates - For interwiki imports: import all included templates as well namespace - For interwiki imports: import to this namespace One value: 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 102, 103, 108, 109, 106, 107, 104, 105 rootpage - Import as subpage of this page Example: Import [[meta:Help:Parserfunctions]] to namespace 100 with full history: api.php?action=import&interwikisource=meta&interwikipage=Help:ParserFunctions&namespace=100&fullhistory=&token=123ABC * action=userrights * Add/remove a user to/from groups https://www.mediawiki.org/wiki/API:User_group_membership This module requires read rights This module requires write rights This module only accepts POST requests Parameters: user - User name This parameter is required add - Add the user to these groups Values (separate with '|'): bot, sysop, bureaucrat, smwadministrator remove - Remove the user from these groups Values (separate with '|'): bot, sysop, bureaucrat, smwadministrator token - A userrights token previously retrieved through list=users This parameter is required reason - Reason for the change Default: Example: api.php?action=userrights&user=FooBot&add=bot&remove=sysop|bureaucrat&token=123ABC * action=options * Change preferences of the current user Only options which are registered in core or in one of installed extensions, or as options with keys prefixed with 'userjs-' (intended to be used by user scripts), can be set. https://www.mediawiki.org/wiki/API:Options This module requires read rights This module requires write rights This module only accepts POST requests Parameters: token - An options token previously obtained through the action=tokens This parameter is required reset - Resets preferences to the site defaults resetkinds - List of types of options to reset when the "reset" option is set Values (separate with '|'): registered, registered-multiselect, registered-checkmatrix, userjs, unused, all Default: all change - List of changes, formatted name=value (e.g. skin=vector), value cannot contain pipe characters. If no value is given (not even an equals sign), e.g., optionname|otheroption|..., the option will be reset to its default value Separate values with '|' Maximum number of values 50 (500 for bots) optionname - A name of a option which should have an optionvalue set optionvalue - A value of the option specified by the optionname, can contain pipe characters Examples: api.php?action=options&reset=&token=123ABC api.php?action=options&change=skin=vector|hideminor=1&token=123ABC api.php?action=options&reset=&change=skin=monobook&optionname=nickname&optionvalue=[[User:Beau|Beau]]%20([[User_talk:Beau|talk]])&token=123ABC * action=imagerotate * Rotate one or more images This module requires read rights This module requires write rights This module only accepts POST requests Parameters: rotation - Degrees to rotate image clockwise This parameter is required One value: 90, 180, 270 token - Edit token. You can get one of these through action=tokens This parameter is required titles - A list of titles to work on Separate values with '|' Maximum number of values 50 (500 for bots) pageids - A list of page IDs to work on Separate values with '|' Maximum number of values 50 (500 for bots) revids - A list of revision IDs to work on Separate values with '|' Maximum number of values 50 (500 for bots) redirects - Automatically resolve redirects converttitles - Convert titles to other variants if necessary. Only works if the wiki's content language supports variant conversion. Languages that support variant conversion include gan, iu, kk, ku, shi, sr, tg, uz, zh generator - Get the list of pages to work on by executing the specified query module. NOTE: generator parameter names must be prefixed with a 'g', see examples One value: allcategories, allfileusages, allimages, alllinks, allpages, alltransclusions, backlinks, categories, categorymembers, duplicatefiles, embeddedin, exturlusage, images, imageusage, iwbacklinks, langbacklinks, links, pageswithprop, protectedtitles, querypage, random, recentchanges, search, templates, watchlist, watchlistraw Example: api.php?action=imagerotate&titles=Example.jpg&rotation=90&token=123ABC * action=sfautocomplete * Autocompletion call used by the Semantic Forms extension (http://www.mediawiki.org/Extension:Semantic_Forms) This module requires read rights Parameters: limit - No more than 500 (5000 for bots) allowed Default: 10 substr - Search substring property - Semantic property for which to search values category - Category for which to search values concept - Concept for which to search values namespace - Namespace for which to search values external_url - Alias for external URL from which to get values baseprop - A previous property in the form to check against basevalue - The value to check for the previous property Examples: api.php?action=sfautocomplete&substr=te api.php?action=sfautocomplete&substr=te&property=Has_author api.php?action=sfautocomplete&substr=te&category=Authors * action=sfautoedit * This module is used to remotely create or edit pages using Semantic Forms. Add "template-name[field-name]=field-value" to the query string parameter, to set the value for a specific field. To set values for more than one field use "&", or rather its URL encoded version "%26": "template-name[field-name-1]=field-value-1%26template-name[field-name-2]=field-value-2". See the first example below. In addition to the query parameter, any parameter in the URL of the form "template-name[field-name]=field-value" will be treated as part of the query. See the second example. This module requires read rights This module requires write rights Parameters: form - The form to use. target - The target page. query - The query string. preload - The name of a page to preload Examples: With query parameter: api.php?action=sfautoedit&form=form-name&target=page-name&query=template-name[field-name-1]=field-value-1%26template-name[field-name-2]=field-value-2 Without query parameter: api.php?action=sfautoedit&form=form-name&target=page-name&template-name[field-name-1]=field-value-1&template-name[field-name-2]=field-value-2 * action=smwinfo * API module get info about this SMW install. This module requires read rights Parameters: info - The info to provide. Values (separate with '|'): propcount, usedpropcount, declaredpropcount, proppagecount, querycount, querysize, formatcount, conceptcount, subobjectcount Default: propcount|usedpropcount|declaredpropcount Example: api.php?action=smwinfo&info=proppagecount|propcount * action=ask * API module to query SMW by providing a query in the ask language. This module requires read rights Parameters: query - The query string in ask-language This parameter is required Example: api.php?action=ask&query=[[Modification%20date::%2B]]|%3FModification%20date|sort%3DModification%20date|order%3Ddesc * action=askargs * API module to query SMW by providing a query specified as a list of conditions, printouts and parameters. This module requires read rights Parameters: conditions - The query conditions, i.e. the requirements for a subject to be included This parameter is required Separate values with '|' Maximum number of values 50 (500 for bots) printouts - The query printouts, i.e. the properties to show per subject Separate values with '|' Maximum number of values 50 (500 for bots) Default: parameters - The query parameters, i.e. all non-condition and non-printout arguments Separate values with '|' Maximum number of values 50 (500 for bots) Default: Example: api.php?action=askargs&conditions=Modification%20date::%2B&printouts=Modification%20date¶meters=|sort%3DModification%20date|order%3Ddesc * action=browsebysubject * API module to query a subject. This module requires read rights Parameters: subject - The subject to be queried This parameter is required Example: api.php?action=browsebysubject&subject=Main_Page *** *** *** *** *** *** *** *** *** *** *** *** *** *** Permissions *** *** *** *** *** *** *** *** *** *** *** *** *** *** * writeapi * Use of the write API Granted to: all, user, bot * apihighlimits * Use higher limits in API queries (Slow queries: 500 results; Fast queries: 5000 results). The limits for slow queries also apply to multivalue parameters. Granted to: bot, sysop *** *** *** *** *** *** *** *** *** *** *** *** *** *** Formats *** *** *** *** *** *** *** *** *** *** *** *** *** *** * format=json * Output data in JSON format https://www.mediawiki.org/wiki/API:Data_formats This module requires read rights Parameters: callback - If specified, wraps the output into a given function call. For safety, all user-specific data will be restricted. utf8 - If specified, encodes most (but not all) non-ASCII characters as UTF-8 instead of replacing them with hexadecimal escape sequences. Example: Format the query result in the json format: api.php?action=query&meta=siteinfo&siprop=namespaces&format=json * format=jsonfm * Output data in JSON format (pretty-print in HTML) https://www.mediawiki.org/wiki/API:Data_formats This module requires read rights Parameters: callback - If specified, wraps the output into a given function call. For safety, all user-specific data will be restricted. utf8 - If specified, encodes most (but not all) non-ASCII characters as UTF-8 instead of replacing them with hexadecimal escape sequences. Example: Format the query result in the jsonfm format: api.php?action=query&meta=siteinfo&siprop=namespaces&format=jsonfm * format=php * Output data in serialized PHP format https://www.mediawiki.org/wiki/API:Data_formats This module requires read rights Example: Format the query result in the php format: api.php?action=query&meta=siteinfo&siprop=namespaces&format=php * format=phpfm * Output data in serialized PHP format (pretty-print in HTML) https://www.mediawiki.org/wiki/API:Data_formats This module requires read rights Example: Format the query result in the phpfm format: api.php?action=query&meta=siteinfo&siprop=namespaces&format=phpfm * format=wddx * Output data in WDDX format https://www.mediawiki.org/wiki/API:Data_formats This module requires read rights Example: Format the query result in the wddx format: api.php?action=query&meta=siteinfo&siprop=namespaces&format=wddx * format=wddxfm * Output data in WDDX format (pretty-print in HTML) https://www.mediawiki.org/wiki/API:Data_formats This module requires read rights Example: Format the query result in the wddxfm format: api.php?action=query&meta=siteinfo&siprop=namespaces&format=wddxfm * format=xml * Output data in XML format https://www.mediawiki.org/wiki/API:Data_formats This module requires read rights Parameters: xslt - If specified, adds <xslt> as stylesheet. This should be a wiki page in the MediaWiki namespace whose page name ends with ".xsl" includexmlnamespace - If specified, adds an XML namespace Example: Format the query result in the xml format: api.php?action=query&meta=siteinfo&siprop=namespaces&format=xml * format=xmlfm * Output data in XML format (pretty-print in HTML) https://www.mediawiki.org/wiki/API:Data_formats This module requires read rights Parameters: xslt - If specified, adds <xslt> as stylesheet. This should be a wiki page in the MediaWiki namespace whose page name ends with ".xsl" includexmlnamespace - If specified, adds an XML namespace Example: Format the query result in the xmlfm format: api.php?action=query&meta=siteinfo&siprop=namespaces&format=xmlfm * format=yaml * Output data in YAML format https://www.mediawiki.org/wiki/API:Data_formats This module requires read rights Parameters: callback - If specified, wraps the output into a given function call. For safety, all user-specific data will be restricted. utf8 - If specified, encodes most (but not all) non-ASCII characters as UTF-8 instead of replacing them with hexadecimal escape sequences. Example: Format the query result in the yaml format: api.php?action=query&meta=siteinfo&siprop=namespaces&format=yaml * format=yamlfm * Output data in YAML format (pretty-print in HTML) https://www.mediawiki.org/wiki/API:Data_formats This module requires read rights Parameters: callback - If specified, wraps the output into a given function call. For safety, all user-specific data will be restricted. utf8 - If specified, encodes most (but not all) non-ASCII characters as UTF-8 instead of replacing them with hexadecimal escape sequences. Example: Format the query result in the yamlfm format: api.php?action=query&meta=siteinfo&siprop=namespaces&format=yamlfm * format=rawfm * Output data with the debugging elements in JSON format (pretty-print in HTML) https://www.mediawiki.org/wiki/API:Data_formats This module requires read rights Parameters: callback - If specified, wraps the output into a given function call. For safety, all user-specific data will be restricted. utf8 - If specified, encodes most (but not all) non-ASCII characters as UTF-8 instead of replacing them with hexadecimal escape sequences. Example: Format the query result in the rawfm format: api.php?action=query&meta=siteinfo&siprop=namespaces&format=rawfm * format=txt * Output data in PHP's print_r() format https://www.mediawiki.org/wiki/API:Data_formats This module requires read rights Example: Format the query result in the txt format: api.php?action=query&meta=siteinfo&siprop=namespaces&format=txt * format=txtfm * Output data in PHP's print_r() format (pretty-print in HTML) https://www.mediawiki.org/wiki/API:Data_formats This module requires read rights Example: Format the query result in the txtfm format: api.php?action=query&meta=siteinfo&siprop=namespaces&format=txtfm * format=dbg * Output data in PHP's var_export() format https://www.mediawiki.org/wiki/API:Data_formats This module requires read rights Example: Format the query result in the dbg format: api.php?action=query&meta=siteinfo&siprop=namespaces&format=dbg * format=dbgfm * Output data in PHP's var_export() format (pretty-print in HTML) https://www.mediawiki.org/wiki/API:Data_formats This module requires read rights Example: Format the query result in the dbgfm format: api.php?action=query&meta=siteinfo&siprop=namespaces&format=dbgfm * format=dump * Output data in PHP's var_dump() format https://www.mediawiki.org/wiki/API:Data_formats This module requires read rights Example: Format the query result in the dump format: api.php?action=query&meta=siteinfo&siprop=namespaces&format=dump * format=dumpfm * Output data in PHP's var_dump() format (pretty-print in HTML) https://www.mediawiki.org/wiki/API:Data_formats This module requires read rights Example: Format the query result in the dumpfm format: api.php?action=query&meta=siteinfo&siprop=namespaces&format=dumpfm * format=none * Output nothing https://www.mediawiki.org/wiki/API:Data_formats This module requires read rights Example: Format the query result in the none format: api.php?action=query&meta=siteinfo&siprop=namespaces&format=none *** Credits: *** API developers: Roan Kattouw "<Firstname>.<Lastname>@gmail.com" (lead developer Sep 2007-2009) Victor Vasiliev - vasilvv @ gmail . com Bryan Tong Minh - bryan . tongminh @ gmail . com Sam Reed - sam @ reedyboy . net Yuri Astrakhan "<Firstname><Lastname>@gmail.com" (creator, lead developer Sep 2006-Sep 2007, 2012-present) Please send your comments, suggestions and questions to mediawiki-api@lists.wikimedia.org or file a bug report at https://bugzilla.wikimedia.org/ </error> </api>
