Projets:Lab:2011:SA-Scotty
Revision as of 15:20, 30 November 2011 by Yannick (Talk | contribs)
  • Apprendre en faisant
Descriptif
Architecture
[schéma]
Fonctionnement du MSA
Il y a donc deux oscillateurs locaux (LO1 et LO2), pilotant les deux mélangeurs (Mixer 1 et Mixer 2). LO1 est un synthétiseur hybride (verrouillage de phase -PLO 1- et DDS -DDS 1-). LO2 dispose simplement d'un verrouillage de phase et génère une fréquence fixe de 1024MHz. Un oscillateur maître à 64MHz est utilisé comme référence.
The MSA frequency range is from 0 to 1000 MHz and the input is J2 of Mixer 1. PLO 1 is variable, from 1013.3 MHz to 2013.3 MHz, and will high-side mix with the input frequency. The converted output at J3 of Mixer 1 is 1013.3 MHz, and is passed to the Coaxial Cavity Filter for image rejection. Its output is mixed with PLO 2, a fixed frequency of 1024 MHz. to produce the Final I.F. of 10.7 MHz. The final I.F. is low pass filtered within Mixer 2 and is present at J2. The final IF is passed to J3 of the I.F. Amplifier, amplified, and passed to a user selected, Final Xtal Filter. This filter determines the Resolution Bandwidth of the MSA. The magnitude of the signal is converted to a relative voltage by the Log Detector and processed by the Analog to Digital Converter. The digital signal is passed through the Control Board to the home computer for software processing.
The MSA frequency range is from 2000 to 3000 MHz and the input is J2 of Mixer 1. PLO 1 is variable, from 986.7 MHz to 1986.7 MHz, and will low-side mix with the input frequency. The converted output at J3 of Mixer 1 is 1013.3 MHz, and is passed to the Coaxial Cavity Filter for image rejection. Its output is mixed with PLO 2, a fixed frequency of 1024 MHz. to produce the Final I.F. of 10.7 MHz.
The J2 input port of Mixer 1 has degraded performance for input frequencies above 1000 MHz. Although the 3G Band of the MSA is responsive with this configuration, it is better to reverse the input/outport ports of Mixer 1. The MSA input would become J3 of Mixer 1 and the 1st I.F. would exit J2.
The MSA frequency range is from 1000 to 2000 MHz. With a physical change to the path topology, the MSA is changed to a single conversion topology. PLO 1 is variable, from 1010.7 MHz to 2010.7 MHz, and will high-side mix with the input frequency. The converted output at J3 of Mixer 1 is 10.7 MHz, and is passed to the 2G Low Pass Filter. Its output is passed to J3 of the I.F. Amplifier, amplified, and passed to a user selected, Final Xtal Filter. The Coaxial Cavity Filter and Mixer 2 are not used for 2G Band operation.
   Again, the J2 input port of Mixer 1 has degraded performance for input frequencies above 1000 MHz. Although the 2G Band is responsive with this configuration, it is better to reverse the input/outport ports of Mixer 1. The MSA input would become J3 of Mixer 1 and the Final I.F. would exit J2.
   This single conversion scheme has no image rejection. That is, Mixer 1 will act as a low-side mixer and will produce the same 10.7 MHz conversion frequency for input frequencies of 1021.4 MHz to 2021.4 MHz.  This is because input signals can be either 10.7 MHz above LO 1 or 10.7 MHz below LO 1.
Analyse du système
Gain
Sensibilité
Puissance d'entrée maximale
Dynamique
Niveau de bruit
Validation
