Projets:Lab:2011:SA-Scotty
Revision as of 14:53, 1 December 2011 by Yannick (Talk | contribs)
  • Apprendre en faisant
Descriptif
Architecture
Fonctionnement du MSA
Analyse du système
Gain de conversion
Bilan des puissances :
  • MIXER1 : -6.5dB
  • Cavité coaxiale : -7dB
  • MIXER2 : -6.5dB
  • Ampli FI : +40dB
Total : +16dB
Sensibilité
  • Pour la mesure de phase :
Puissance d'entrée maximale
Dynamique
Niveau de bruit
Citation de Scotty Sprowls : "The Input Noise Floor of the MSA is determined by the self generated noise of all the circuits within the MSA. That is, it is assumed that there is no "real" signal entering the MSA to be measured by the Log Detector. This is a reality if the MSA is commanded to any frequency that does not create spurious signals. Spurs are explained near the end of this page. The devices, Mixer 1 and Mixer 2 do create noise, but their total level is below the physical noise floor of -174 dBm/sqrtHz (a 1 Hz bandwidth).
Validation
Description
Appro des composants
