Projets:Commande groupee:archives
- 1 Commandes groupées en cours
- 2 Commandes groupées passées (archives)
- 2.1 Cergy-Vis
- 2.2 Conrad Electronique France
- 2.3 DamenCNC
- 2.4 Digikey Corporation
- 2.5 Doga
- 2.6 Farnell
- 2.7 Gotronic
- 2.8 Mini-Circuits
- 2.9 Mouser Electronics
- 2.10 Motedis France
- 2.11 Nouvelle Plastique
- 2.12 Olimex
- 2.13 Otelo
- 2.14 Radiospares
- 2.15 Saint Quentin radio
- 2.16 Selectronic
- 2.17 SparkFun Electronics
Cergy-Vis
Naviguer vers la page des commandes en cours de Cergy-Vis
Naviguer vers la page des commandes en cours de Conrad Electronique France
COMMENTAIRE
| Limesle | LED verte 5 mm Hlmp Cm14-Z30Dd Avago Technologies HLMP-CM14-Z30DD | 181211 - 62 | 2 | 0,95€ | David | CO_001 | O | O | O | N |
| Limesle | LED blanche 5Mm 18000 Mcd | 180000 - 62 | 2 | 0,90€ | David | CO_001 | O | O | O | N |
| Patrick | Switch Dlink 1005D Gigabit | 973969 - 62 | 1 | 34,96€ | David | CO_001 | O | O | O | O |
| David | Troisième main Toolcraft ZD-10F | 588124 - 62 | 3 | 5,39 | David | CO_001 | O | O | O | N |
| David | Panne de rechange Toolcraft T-LB | 588240 - 62 | 1 | 5,59 | David | CO_001 | O | O | O | N |
| Thomas | Lot de pinces dauphin XDK 1033 | 100631 - 62 | 1 | 10,95 | David | CO_001 | N | O | O | N |
| Thomas | Fiche Banane de Securite rouge 4 mm MultiContact 22.3007-22 | 741502 - 62 | 1 | 6,79 | David | CO_001 | N | O | O | N |
| Thomas | Fiche Banane de Securite 4 mm MultiContact 22.3007-21 | 741489 - 62 | 1 | 6,79 | David | CO_001 | N | O | O | N |
| Thomas | Cordon de mesure 50 cm bleu MultiContact XVS-4075 66.9562-05023 | 106035 - 62 | 1 | 5,69 | David | CO_001 | N | O | O | N |
| Thomas | Cordon de mesure 50 cm noir MultiContact XVS-4075 66.9562-05023 | 126033 - 62 | 1 | 5,69 | David | CO_001 | N | O | O | N |
| Thomas | Cordon de mesure 50 cm rouge MultiContact XVS-4075 66.9562-05023 | 106034 - 62 | 1 | 5,69 | David | CO_001 | N | O | O | N |
| Patrick | Elément chauffant 12V 50/100/150W | 532894 - 62 | 2 | 10.95 | <Patrick> | CO_002 | O | O | O | O |
| Patrick | POMPE A AIR MEMBRANE | 530476-62 | 21 | 34.95 | <Patrick> | CO_002 | O | O | O | O |
| Patrick | Livre Arduino applications avancées | 095064-62 | 1 | 25.65 | <Patrick> | CO_002 | O | O | O | O |
| Alexander | CI Bus I2C PCF 8573P Philips | 064235 - 62 | 5 | 0.05 | <Patrick> | CO_002 | N | N article abandonné | N | N |
| Eric | Aérosol 200 ml CRC Kontakt Chemie Kontakt 60 | 813516 - 62 | 1 | 7.95 | <Patrick> | CO_002 | N | O | O | O |
| Eric | Nettoyeur de circuits imprimés 400 ml CRC Kontakt LR | 822812 - 62 | 1 | 11.95 | <Patrick> | CO_002 | N | O | O | O |
| Eric | Douille Ø 4 mm type PKI100 vert/jaune SKS Hirschmann ref 930757188 | 733928 - 62 | 6 | 3.00 | <Patrick> | CO_002 | N | O | O | O |
| Eric | Varistance 510 V Epcos S20K320E3K1 B72220P3321K101 | 531595 - 62 | 5 | 1.40 | <Patrick> | CO_002 | N | O | O | O |
| Lab | Coffret plastique 18 compartiments | 078156 - 11 | 1 | 14.90 | <Patrick> | CO_002 | N | O | O | O |
| David | Panne de rechange Toolcraft T-3.2D | 588228 - 62 | 1 | 6.99 | Patrick | CO_003 | N | O | O | O |
| Patrick | Entretoise laiton M/F 10mm vis 3mm | 526630 - 62 | 10 | 0,23 | Patrick | CO_003 | N | O | O | O |
| Patrick | Aérosol désodorisant bio Melon | 095485-62 | 1 | 10.95 | Patrick | CO_003 | N | O | O | O |
| Patrick | Set de 200 colliers naturels (lg. 100, 150, 200 et 250mm) | 541665 - 62 | 1 | 3,30 | <acheteur> | CO_003 | N | O | O | O |
| Patrick | Eponge pour fer à souder | 812374-62 | 1 | 2,07 | Patrick | CO_003 | N | O | O | O |
| Lab | Eponge pour fer à souder | 812374-62 | 9 | 2,07 | Patrick | CO_003 | N | O | O | O |
| Lab | Gants de protection Camatex en latex naturel/Coton Taille 10 KCL 450 | 893626 - 62 | 2 | 6,99 | <acheteur> | CO_003 | N | O | O | O |
| Lab | Régulateur 7915 | 179310 - 62 | 1 | 1,10 | Patrick | CO_003 | N | O | O | O |
| Lab | Lot de 100 Colliers 100 X 2,5 Naturel Marque HellermannTyton ref: 138-00001 | 617849 - 62 | 1 | 1,50 | Patrick | CO_003 | N | O | O | O |
| Lab | Set de 200 colliers naturels (lg. 100, 150, 200 et 250mm) | 541665 - 62 | 1 | 3,30 | Patrick | CO_003 | N | O | O | O |
| Eric | Spray air comprimé 400 ml Dataflash | 995809 - 62 | 2 | 6,99 | Patrick | CO_003 | N | O | O | O |
| Eric | Collier de serrage de tuyau acier fin 10 à 16 mm SUBHC000 serrage papillon | 541837 - 62 | 5 | 1,00 | Patrick | CO_003 | N | O | O | O |
| Eric | Collier de serrage inox Ø 9 à 13 mm | 544906 - 62 | 5 | 0,60 | Patrick | CO_003 | N | O | O | O |
| Lab | DOUILLE DE SECURITE 4mm ECROU NOIR , ref3265-I-0 | 326500 | 4 | 1.35 | Patrick | CO_003 | N | O | O | O |
| Lab | DOUILLE DE SECURITE 4mm ECROU VERT, ref3265-I-5 | 326505 | 3 | 1.35 | Patrick | CO_003 | N | O | O | O |
| Lab | DOUILLE DE SECURITE 4mm ECROU BLEU, ref3265-I-6 | 326506 | 1 | 1.35 | Patrick | CO_003 | N | O | O | O |
| 3dsman | Capteur de couleur RVB KPS-5130PD7C | 180381 - 62 | 5 | 1.70 | Patrick | CO_004 | N | o | O | O |
| Florent, 2 pour Patrick | Lames de fusible 80A | 535265-62 | 27 | 0,32 | Patrick | CO_004 | N | o | O | o |
| David | Fer à souder de rechange 100 W | 588281 - 62 | 1 | 37,95 | Patrick | CO_004 | N | o | o | o |
| David | Câble Ftp Cat5 Vert 10 M Bulk | 972081 - 62 | 1 | 11,95 | Patrick | CO_004 | N | o | o | o |
| Eric | Lot de 100 Colliers 245 X 4,5 Transparent Marque HellermannTyton ref: UB250C-N-PA66-NA-C1 13 | 617873 - 62 | 1 | 7.09 | <Patrick> | CO_004 | N | o | O | O |
| Eric | Lot de 100 Colliers 200 X 4,6 Transparent Marque HellermannTyton ref: UB200C-N-PA66-NA-C1 13 | 617865 - 62 | 1 | 4.50 | <acheteur> | CO_004 | N | o | O | O |
| Eric | Testeur de capteurs Marque : Contrinex | 155946 - 62 | 1 | 40.95 | <Patrick> | CO_004 | N | o | O | O |
| Eric +1 Patrick | Fiche allume-cigares femelle standard pour câble | 062857 - 62 | 2 | 1,99 | <Patrick> | CO_004 | N | o | O | O |
| FICHF | LM317LD | 155584 - 62 | 10 | 0,2 | Patrick | CO_004 | N | o | O | O |
| Patrick | support lame de fusible ESKA max 500A | 535222-62 | 2 | 2,7 | Patrick | CO_004 | N | o | O | O |
| Yann | brasure étain 0.5mm 100g | 812803 - 62 | 1 | 7.99€ | <Patrick> | CO_004 | N | o | O | O |
| Yann | brasure étain 1mm 100g | 812811 - 62 | 1 | 4.09€ | <Patrick> | CO_004 | N | o | O | O |
| Yann | fil à wrapper 0.20mm2 | 606075 - 62 | 1 | 5.49€ | <Patrick> | CO_004 | N | o | O | O |
| Lab | gaine spiralée 4-50mm | 546146 - 62 | 1 | 3.10€ | <Patrick> | CO_004 | N | o | O | O |
| Patrick | porte fusible 5X20 chassi | 533769-62 | 1 | 0.80€ | <Patrick> | CO_004 | N | o | O | O |
| Patrick | Fiche allume-cigares male standard pour câble | 062856-62 | 1 | 1.99€ | <Patrick> | CO_004 | N | o | O | O |
| Lab | 100 Embouts à collerette 9mm fil 4mm² | 617878 - 62 | 1 | 2.59€ HT | <Patrick> | CO_005 | N | O | o | o |
| Eric | Gants de protection Camatex en latex naturel/Coton Taille 10 KCL 450 | 893626 - 62 | 2 | 6,99 | <Patrick> | CO_005 | N | O | O | O |
| Léonard | Set de 4 prises avec télécommande | 099994 - 62 | 1 | 20,82 HT | <Patrick> | CO_005 | N | O | O | O |
| Léonard | Module émetteur AM 433,92 MHz kit monté alim 5 V puissance 10 mW Aurel TX-SAW MID/5 V | 191525 - 62 | 1 | 9,16 HT | <Patrick> | CO_005 | N | O | O | O |
| Léonard | Module récepteur 433 MHz Aurel Ac-Rx | 190276 - 62 | 1 | 6,68 HT | <Patrick> | CO_005 | N | O | O | O |
| Iggy | Module capteur PIR | 506177 - 62 | 1 | 10,83 HT | <Patrick> | CO_005 | 50 | O | o | o |
| Iggy | Module électronique pour modules capteurs IR | 506178 - 62 | 1 | 12,50 HT | <Patrick> | CO_005 | 50 | O | o | o |
| Iggy | Capteur Pir CMS 5V Hygrosens | 172526 - 62 | 1 | 26,71 HT | <Patrick> | CO_005 | 50 | O | o | o |
| Patrick | Condensateur 4700µF 16V radial | 421939-62 | 2 | 1,75€HT | Pitrak | CO_007 | N | O | O | O |
| Patrick | Condensateur 4700µF 6,3V radial | 441534-62 | 1 | 1€HT | Pitrak | CO_007 | N | O | O | O |
| Patrick | Condensateur 330µF/50V radial | 422057-62 | 5 | 0,33€HT | Pitrak | CO_007 | N | O | O | O |
| Lab | Col de cygne 48cm (urgent) | 301671 - 62 | 3 | 16.95€TTC | Pitrak | CO_007 | N | O | O | O |
| Lab | Dispositif de serrage (urgent) | 304767 - 62 | 2 | 7.49€TTC | Pitrak | CO_007 | N | O | O | O |
| Eric | Saccoche FLIR (une de plus) | 658006 - 62 | 1 | 21,00€HT | Pitrak | CO_007 | N | O | O | O |
| Thomas | Boîte 1 CMS | 157619 - 62 | 16 | 0,58€HT | <Patrick> | CO_008 | N | O | O | O |
| Thomas | Boîte 3 CMS | 157635 - 62 | 4 | 1.69€HT | <Patrick> | CO_008 | N | O | O | O |
| Patrick | Micro Ventilateur 12v 25x25X6,5 mm | 189344 - 62 | 1 | 15,79€HT | <Patrick> | CO_008 | N | O | O | O |
| papy F1CHF | transformateur moulé 2X9V 1,5VA | 556946-62 | 1 | 2.5€HT | Patrick | CO_008 | N | O | O | O |
| Pierre | 588417 - 62 | 1 | 11,63€HT | <Patrick> | CO_008 | N | O | O | O | |
| Jean Seb | Interrupteur à levier 230V 10A | 701192 - 62 | 2 | 2,83€HT | <Patrick> | CO_008 | N | O | O | O |
| Jean Seb | Borne chassi 4mm + fil - V/J 35A | 732379 - 69 | 1 | 3,17€HT | <Patrick> | CO_008 | N | O | O | O |
| Jean Seb | Borne chassi 4mm + fil - blanc 35A | 430333 - 62 | 5 | 2,25€HT | <Patrick> | CO_008 | N | O | O | O |
| Jean Seb | Borne chassi 4mm + fil - noir 35A | 737740 - 62 | 5 | 3,08€HT | <Patrick> | CO_008 | N | O | O | O |
| Jean Seb | Galvanomètre 5A AC | 077808 - 62 | 1 | 5,79€HT | <Patrick> | CO_008 | N | O | O | O |
| Jean Seb | support LED 5 mm chassi | 185914 - 62 | 10 | 0,3€HT | <Patrick> | CO_008 | N | O | O | O |
| Jean Seb | pied caoutchouc autocollant 9,5X3,8mm | 185914 - 62 | 6 | 0,08€HT | <Patrick> | CO_008 | N | O | O | O |
| Patrick | boite de rangement ronde 5 compartiments | 526047 - 62 | 1 | 1,46€HT | <Patrick> | CO_008 | N | O | O | O |
| Patrick | boite de rangement 24 cases 340X230X55 | 067919 - 62 | 1 | 5,79€HT | <Patrick> | CO_008 | N | O | O | O |
| Eric | Aérosol 200 ml CRC Kontakt Chemie PLASTIK 70 50.1.530 | 884197 - 62 | 1 | 6.99€TTC | <Acheteur> | CO_009 | N | PLUS DE BESOIN | N | O |
| Eric | Support pince universel MM2 Bosch; Référence: 0603692200 | 816603 - 62 | 1 | 19.99€TTC | <Patrick> | CO_009 | N | O | O | O |
| Pierre G | Piles bouton CR2450; Référence: 638014 | 651090 - 62 | 2 | 3.99€TTC | <Patrick> | CO_009 | N | O | O | O |
| Pierre G | 24 Piles alcalines AA Référence: 650640 | 650640 - 62 | 1 | 5.83€TTC | <Patrick> | CO_009 | N | O | O | O |
| Pierre G | 24 Piles alcalines AAA Référence: 650638 | 650638 - 62 | 1 | 5.83€TTC | <Patrick> | CO_009 | N | O | O | O |
| Pierre G | 4 accus AAA Référence: 251111 | 251111 - 62 | 2 | 4.16€TTC | <Patrick> | CO_009 | N | O | O | O |
| Pierre G | Fiche Micro Usb 5Br. Trapézoïdale | 730794 - 62 | 2 | 1.9 ttc | <Patrick> | CO_009 | N | O | O | O |
| Pierre G | Connecteur Micro USB type B à visser | 595240 - 62 | 1 | 3.80 ttc | <Patrick> | CO_009 | N | O | O | O |
| Pierre G | Chauffage à quartz | 551392 - 62 | 2 | 21.66 ht | <Patrick> | CO_009 | N | O | O | O |
| Pierre G | Thermostat d'ambiance | 610700 - 62 | 1 | 19.99 ht | <Patrick> | CO_009 | N | O | O | O |
| Pierre G | Câble audio SpeaKa 1m mf | 986736 - 62 | 2 | 8.24 ht | <Patrick> | CO_009 | N | O | O | O |
| Pierre G | Câble audio SpeaKa 5m mf | 989198 - 62 | 1 | 13.33 ht | <Patrick> | CO_009 | N | O | O | O |
| Pierre G | Câble audio SpeaKa 0.3m mf coudé | 325234 - 62 | 1 | 5.99 ht | <Patrick> | CO_009 | N | O | O | O |
| Antoine J | Quartz 20 MHz HC-18U/49U | 168769-62 | 1 | 0.50€TTC | <Patrick> | CO_009 | N | O | O | O |
| Lab (Ellyan) | Embout pour clé à douille 1/4" 13 mm Toolcraft | 820753-62 | 1 | 2.60€TTC | <Patrick> | CO_009 | N | O | O | O |
| Eric | Set slimVario VDE starter 16 pcs Wiha ref 36068 | 826465-62 | 1 | 69.16HT | <Patrick> | CO_009 | N | O | O | O |
| Moala | Haut-parleur à large bande Visaton FR 10 HM/4 ohms | 303654 - 62 | 1 | 9.39TTC | <Patrick> | CO_009 | N | O | O | O |
| Moala | Circuit intégré linéaire TL081CP IC OPAMP JFET 3MHZ SGL 8DIP Texas Instruments | 1011528 - 62 | 10 | 0.58TTC | <Patrick> | CO_009 | N | O | O | O |
| Moala | Raspberry Pi® 2 Model B 1 Go RAM - sans système d'exploitation | 1316978 - 62 | 1 | 43,95TTC | <Patrick> | CO_009 | N | O | O | O |
| Patrick | Connecteur Micro USB type B à visser | 595240 - 62 | 1 | 3.80 ttc | <Patrick> | CO_009 | O | O | O | O |
| Patrick | fils câblage rasberry | 1182193-62 | 1 | 8,59 ttc | <Patrick> | CO_009 | O | O | O | O |
| Sylvia Lam | Chageur pile bouton CR2032 | 200520-62 | 1 | 8,99 ttc | <Patrick> | CO_009 | O | O | O | O |
| Sylvia Lam | Accu bouton CR2032 3V | 200520-62 | 2 | 6,19 ttc | <Patrick> | CO_009 | O | O | O | O |
| Sylvia Lam | Accu bouton LIR2032 3,6V | 200520-62 | 2 | 4,99 ttc | <Patrick> | CO_009 | O | O | O | O |
| Oleska Olga | plaque époxy simpla fac 160X100 | 523630-62 | 1 | 3,80 ttc | <Patrick> | CO_009 | N | O | O | O |
| Gérard Meunier | Micro process MSP430G2553IN20 PDIP-20 | 1010487-62 | 2 | .99 ttc | <Patrick> | CO_009 | O | O | O | O |
| Eric | Alia 382 | 076731 - 62 | 1 | 29,99€TTC | <Patrick> | CO_010 | N | O | O | O |
| Eric | Gaine thermorétractable 2:1 transparente pour accus longueur 100 cm largeur 44mm | 542044 - 32 | 2 | 2,90€TTC | <Patrick> | CO_010 | N | O | O | O |
| Eric | Régulateur de tension LDO STM LD1117V33C TO-220 | 1184974 - 62 | 1 | 0.66€TTC | <Patrick> | CO_010 | N | O | O | O |
| Eric | Régulateur de tension LDO STM L78L33ACZ TO-92 | 1185775 - 62 | 2 | 0.61€TTC | <Patrick> | CO_010 | N | O | O | O |
| Eric | référence de tension Texas TL431BILPR TO-92 | 1014551 - 62 | 2 | 0.95€TTC | <Patrick> | CO_010 | N | O | O | O |
| Eric | Calage pour L-BOXX 136 ref 2608438029 | 493599 - 62 | 1 | 8.59€TTC | <Acheteur> | CO_010 | N | Epuisé | N | N |
| FredericD | Relais reed Comus 3570-1210-121 1 contact à fermeture 12 V/DC 0.5 A 10 W DIP-14 | 1300084 - 62 | 1 | 3,10€ TTC | <Patrick> | CO_010 | N | O | O | O |
| Lab (Ellyan) | Cliquet réversible de 6,3 mm (1/4"), longueur 138 mm, TOOLCRAFT | 816188-62 | 1 | 19.90€TTC | <Patrick> | CO_010 | N | O | O | O |
| Lab (Ellyan) | Rallonge 1/4' 150 mm Toolcraft | 820755-62 | 1 | 4.30€TTC | <Patrick> | CO_009 | N | O | O | O |
| Lab (Ellyan) | Adaptateur d'embouts 1/4' Toolcraft | 815298-62 | 1 | 4.80€TTC | <Patrick> | CO_010 | N | O | O | O |
| Lab (Eric) | Douille de sécurité 4 mm noir marque: Electro PJP ref#3265-C-N | 064596 - 62 | 2 | 1.60€TTC | <Patrick> | CO_010 | N | O | O | O |
| FredericD | Circuit intégré linéaire TL071CP DIL-8 Texas Instruments | 181447 - 62 | 4 | 0.27€ TTC | <Patrick> | CO_010 | N | O | O | O |
| FredericD | Condensateur électrolytique Nichicon UVY1V331MPD sortie radiale 5 mm 330 µF 35 V 20 % (Ø x L) 10 mm x 12.5 mm 1 pc(s) | 444888 - 62 | 1 | 0.50€ TTC | <Patrick> | CO_010 | N | O | O | O |
| FredericD | Condensateur électrolytique sortie radiale 2 mm 10 µF 35 V 2 | 1328840 - 62 | 2 | 0.10€ TTC | <Patrick> | CO_010 | N | rupture | N | N |
| FredericD | Condensateur électrolytique Yageo SJ050M0120C5SL-0815 sortie radiale 5 mm 120 µF 50 V 20 % (Ø x h) 8 mm x 15 mm 1 pc(s) | 442601 - 622 | 2 | 0.20€ TTC | <Patrick> | CO_010 | N | O | O | O |
| FredericD | Condensateur électrolytique Yageo SY035M0560B5S-1025 sortie radiale 5 mm 560 µF 35 V 20 % (Ø x h) 10 mm x 25 mm 1 pc(s) | 442612 - 62 | 1 | 0.40€ TTC | <Patrick> | CO_010 | N | O | O | O |
| Gerard94 | Microcontrôleur intégré Texas Instruments MSP430G2553IN20 PDIP-20 | 1010488 - 62 | 2 | 2,86€ TTC | Patrick | CO_010 | N | O | o | o |
| Gerard94 | PMIC - régulateur de tension - linéaire (LDO) Texas Instruments LM1086IT-3.3/NOPB TO-220-3 | 1013617 - 62 | 1 | 3,04€ TTC | Patrick | CO_010 | N | O | o | o |
| <Patrick> | CO_011 | N | o | o | o | |||||
| Eric | µP Texas MSP430G2553IN20 PDIP-20 | 1010488 - 62 | 2 | 2,86€ TTC | <Patrick> | CO_011 | O | O | O | O |
| Eric | Clé Knipex 86 03 400 | 1008234-62 | 1 | 110€ttc | <Patrick> | CO_011 | O | O | O | O |
| Eric | kit KEMO B172 | 191520 - 62 | 1 | 11,99€ttc | <Patrick> | CO_011 | O | O | O | O |
| Eric | Adaptateur SMB BKL Electronic ref 0411043 SMB mâle - SMA femelle droit | 1082765 - 62 | 4 | 3,70€TTC | <Patrick> | CO_011 | O | O | O | O |
| Eric | Adaptateur SMB BKL Electronic ref 0411047 SMB mâle - BNC femelle | 1082768 - 62 | 2 | 3,30€TTC | <Patrick> | CO_011 | O | O | O | O |
| Eric | Lampe halogène x2 Osram H4 12V P43t | 759337 - 62 | 1 | 24,99€TTC | <Patrick> | CO_011 | O | O | O | O |
| Eric | Lampe halogène Osram H4 12V P43t | 759344 - 62 | 1 | 12,99€TTC | <Patrick> | CO_011 | O | O | O | O |
| Patrick | 2 piles LR44 | 650455 - 62 | 2 | 1,49€TTC | <Patrick> | CO_011 | O | O | O | O |
| Eric | Résistance de puissance 0.27 Ω 5 W sortie axiale | 401706 - 62 | 1 | 1.10€TTC | <Patrick> | CO_011 | O | O | O | O |
| Eric | Quartz 32.7680 kHz boîtier TC 38 (Ø x h) 3 mm x 6 mm | 168467 - 62 | 2 | 0.60€TTC | <Patrick> | CO_011 | O | O | O | O |
| Eric | Testo 405 | 101107 - 62 | 1 | 115.20€HT | Patrick | CO_012 | N | O | O | O |
| papy F1CHF | boitiers | 534346 - 62 | 2 | 2,4€ | <Patrick> | CO_012 | N | O | O | O |
| papy F1CHF | regul 1 volt | 1014366 - 62 | 5 | 4.45€ | <Patrick> | CO_012 | o | O | O | O |
| papy F1CHF | self 3.3 nH | 709519 - 62 | 100 | 0.34€ | <Patrick> | CO_012 | N | O | O | O |
| papy F1CHF | self 8.2 nH | 709589 - 62 | 100 | 0.38€ | <Patrick> | CO_012 | O | O | O | O |
| papy F1CHF | self 22 nH | 709594 - 62 | 100 | 0.38€ | <Patrick> | CO_012 | O | O | O | O |
| Gilles | Connecteur USB mâle type A | 774866 - 62 | 5 | 1,90€ (TTC) | Patrick | CO_012 | O | O | O | O |
| Gilles | Connecteur USB femelle type A | 774932 - 62 | 5 | 1,80€ (TTC) | Patrick | CO_012 | O | O | O | O |
| Gilles | diode au germanium 1N60 | 162205 - 62 | 2 | 1,00€ (TTC) | Patrick | CO_012 | O | O | O | O |
| Gilles | mousse antistatique | 172367 - 62 | 1 | 2,99€ (TTC) | Patrick | CO_012 | O | O | O | O |
| Patrick | Element chauffant céramique 12V 150W | 532894 - 62 | 1 | 10,83€ HT | <Patrick> | CO_012 | O | O | O | O |
| Laurent(C) | Condensateur électrolytique Würth Elektronik 860010275016 sortie radiale 5 mm 1000 µF 10 V 20 % (Ø x h) 10 mm x 12.5 mm | 1278751 - 62 | 27 | 0,36€ TTC | Patrick | CO_012 | O | O | O | O |
| Pierre G | Film chauffant Thermo auto-adhésif 12 V/DC, 12 V/AC 3 W | 189204 - 62 | 1 | € 5,29 TTC | Patrick | CO_012 | N | O | O | O |
| Pierre G | Thermostat bimétallique ESKA 261-Ö30-S20-H 250 V 10 A | 419088 - 62 | 1 | € 4,30 TTC | Patrick | CO_012 | N | O | O | O |
| gerard94 | Mini-PC BeagleBone Black BB-BBLK-000 Rev C | 1227430 - 62 | 1 | € 68,99 TTC | Patrick | CO_012 | N | O | O | O |
DamenCNC
Naviguer vers la page des commandes DamenCNC en cours
Digikey Corporation
Naviguer vers la page des commandes Digikey Corporation en cours
| Eric | Support de relais undecal (11 broches) pour rail DIN Marque : TE Connectivity Modèle MT78750 | PB872-ND | 2 | 6.67USD | <acheteur> | DI_004 | N | O | O | O |
| <acheteur> | DI_004 | N | N | N | O | |||||
| Eric | LTC6101HV IC CURR SENSE 8MSOP Linear Technology | LTC6101HVAIMS8#PBF-ND | 2 | 4.22USD | <acheteur> | DI_004 | N | O | O | O |
| Eric | LTC4444 IC HV MOSFET DRIVER N-CH 8-MSOP Linear Technology | LTC4444EMS8E#PBF-ND | 2 | 3.39USD | <acheteur> | DI_004 | N | O | O | O |
| Lab | CONN RECPT SATA VERT SMT 22POS | 3M5557-ND | 16 | 2.021€ | <acheteur> | DI_004 | N | O | 0 | 0 |
| Lab | CONN HEADER 7POS VERT SMD 15GOLD | WM19104-ND | 16 | 0.643€ | <acheteur> | DI_004 | N | O | 0 | 0 |
| Lab | CONN HEADER 4POS .200 VERT | WM9132-ND | 5 | 0.66€ | <acheteur> | DI_004 | N | O | 0 | 0 |
| Lab (Com Kit) | LED 5MM RED CLEAR 30DEG | C503B-RCN-CW0Z0AA1-ND | 400 | 0.12€ | <acheteur> | DI_004 | N | O | 0 | 0 |
| Guillaume | CONN HEADER 2POS 1.25MM | WM1742-ND | 25 | 0.2636€ | <acheteur> | DI_004 | N | O | 0 | 0 |
| Eric | CONN female horizonal mount double row 12 pos. ref Tyco#5-532956-1 | A34301-ND | 3 | 3.10USD | <acheteur> | DI_004 | N | O | O | O |
| Eric | CONN male header straight post double row 12 pos. ref :Tyco#5-102692-1 | A115216-ND | 3 | 3.61USD | <acheteur> | DI_004 | N | O | O | O |
| Eric | CONN Male Header, Right-Angle Post double row 12. pos (plating B) ref Tyco#5-102589-8 | A115215-ND | 3 | 5.95USD | <acheteur> | DI_004 | N | O | O | O |
| Laurent | CONN PWR PLUG DC 2.1X5.5 8A MOD | CP3-002AH-ND | 15 | 1.292€ | <acheteur> | DI_004 | N | O | 0 | 0 |
| Vincent | CHOKE COMM MODE 90 OHM SMD | 445-9335-1-ND | 3 | 0.70$ | <acheteur> | DI_004 | N | O | 0 | 0 |
| MAZ24 | CONN HEADER 4 POS | WM4302-ND | 25 | 0.516€ | <acheteur> | DI_004 | N | O | 0 | |
| MAZ24 | IC MCU 8 BITS | PIC16F690-I/P-ND | 10 | 1.656€ | <acheteur> | DI_004 | N | O | 0 | 0 |
| Claire | IC TOUCH SENSOR 1KEY SOT23-6 | AT42QT1010-TSHRCT-ND | 6 | 1,16€ | <Acheteur> | DI_004 | N | O | 0 | 0 |
| Claire | PROTO-BOARD ADAPTER FOR SOT-23-6 | 33206CA-ND | 6 | 1,67€ | <Acheteur> | DI_004 | N | O | 0 | 0 |
Doga
Naviguer vers la page des commandes Doga en cours
Farnell
| Demandeur | Description | Ref Farnell | Quantité | Prix unitaire | Acheteur | Commande n° | Payé d'avance (O/N) | Commandé (O/N) | Distribué (O/N) | Remboursé/Archive (O/N) |
| Clem(pcb) | forets hss 0.8mm | 377650 | 1 (pack de 10) | a vérifier (de l'ordre de 10€ | ? | ? | N (boite a pcb) | O | O | O |
| Lab | Batterie 12V YUASA NP1.2-12 | 147472 | 1 | 15,90HT | Destynova | FA_001 | O | O | O | O |
| Eric | Batterie 12V YUASA NP1.2-12 | 147472 | 1 | 15,90HT | Destynova | FA_001 | O | O | O | O |
| Lab | Pile CR2450 LITHIUM 3V, 600MAH | 2065173 | 1 | 1,14HT | Destynova | FA_001 | O | O | O | O |
| Eric | Pile CR2450 LITHIUM 3V, 600MAH | 2065173 | 1 | 1,14HT | Destynova | FA_001 | O | O | O | O |
| Lab | Graphit 33 (spray) | 832959 | 1 | 9,35HT | Destynova | FA_001 | O | O | O | O |
| Lab | ROULEAU POUR DYMO N/B 9MM ref 40913 pour Labelmanager 450 | 667006 | 1 | 13,65HT | Destynova | FA_001 | O | O | O | O |
| Crafty | LINEAR TECHNOLOGY - LTC3105EMS#PBF - BOOST 400MA MPPC 12MSOP | 1898601 | 10 | 5,06 EHT | Destynova | FA_001 | O | O | O | O |
| Crafty | BOURNS - SRR0603-100ML - INDUCTANCE 10UH PUISSANCE BLINDE CMS | 2212495 | 10 | 0,48 EHT | Destynova | FA_001 | O | O | O | O |
| Crafty | SUNON - EB40200S2-0000-999 - VENTILATEUR. 40X40X20MM. 5VDC | 1924832 | 2 | 9,78 EHT | Destynova | FA_001 | O | O | O | O |
| Crafty | MULTICOMP - MCTE1-12715L-S - DISSIPATEUR PELTIER 130W | 1639728 | 1 | 31,93 EHT | Destynova | FA_001 | O | O | O | O |
| Crafty | MULTICOMP - MCPE1-07107AC-S - DISSIPATEUR PELTIER 31.1W | 1639723 | 1 | 28,81 EHT | Destynova | FA_001 | O | O | O | O |
| Crafty | MULTICOMP - MCPE1-03108NC-S - DISSIPATEUR PELTIER 18.8W | 1639720 | 1 | 19,40 EHT | Destynova | FA_001 | O | O | O | O |
| the_nihilant | ATMEL - ATMEGA48A-AU - MCU, 8BIT, AVR, 4K FLASH, 32TQFP | 1841612 | 4 | 2,07 HT | Destynova | FA_001 | O | O | O | O |
| the_nihilant | ATMEL - ATMEGA88A-AU - MCU, 8BIT, AVR, 8K FLASH, 32TQFP | 1841614 | 2 | 2,33 HT | Destynova | FA_001 | O | O | O | O |
| the_nihilant | ATMEL - ATMEGA324A-PU - MCU, 8BIT, AVR, 32K FLASH, 40PDIP | 1841611 | 3 | 4,28 HT | Destynova | FA_001 | O | O | O | O |
| the_nihilant | TEXAS INSTRUMENTS - SN74HC595DR - IC, SM, LOGIC, 74HC, REGISTER | 1607849 | 24 | 0,20 HT | Destynova | FA_001 | O | O | O | O |
| raoul(Robotique) | TEXAS INSTRUMENTS - TPS40210DGQ - IC, CTRLR CUR MODE BOOST 10MSOP | 1755634 | 2 | 3.28 HT | Destynova | FA_001 | O | O | O | O |
| raoul(Robotique) | TEXAS INSTRUMENTS - ADS7830IPWTG4 - CONVERTISSEUR A/N 8 BITS 8 CH CMS | 1180129 | 4 | 3.57 HT | Destynova | FA_001 | O | O | O | O |
| raoul(Robotique) | TEXAS INSTRUMENTS - TPS76333DBVT - REG DE TENSION LDO 0.15A 3.3V CMS 76333 | 8461376 | 2 | 1.14 HT | Destynova | FA_001 | O | O | O | O |
| Matthieu | KONTAKT WL | 837970 | 1 | 8.26 ht | David | FA_002 | N | O | O | N |
| Matthieu | KONTAKT 60 400ML | 2142395 | 1 | 10,93 ht | David | FA_002 | N | O | O | N |
| the_nihilant | YAGEO (PHYCOMP) - YC164-JR-071KL - RESEAU DE RESISTANCES ARV241 1206 1K | 9234519 | 10 | 0,096 HT | David | FA_002 | N | O | O | O |
| the_nihilant | ABRACON - ABL-20.000MHZ-B2 - CRYSTAL, 20M, 18PF CL, HC49/4H | 1611779 | 10 | 0,25 HT | David | FA_002 | N | O | O | 0 |
| the_nihilant | RALTRON - AS-16.000-18 - CRYSTAL, 16M, 18PF CL, HC49/4H | 1611761 | 10 | 0,25 HT | David | FA_002 | N | O | O | O |
| the_nihilant | TEXAS INSTRUMENTS - CD74HC164E - LOGIC, SHIFT REGISTER 8BIT HS, 14DIP | 1740095 | 16 | 0,30 HT | David | FA_002 | N | O | O | O |
| the_nihilant | MULTICOMP - 703-0100 - LED ROUGE 5MM STANDARD | 2112111 | 25 | 0,182 HT | David | FA_002 | N | O | O | O |
| the_nihilant | KEYSTONE - 2463 - SUPPORT POUR BATTERIE | 1702631 | 6 | 1,05 HT | David | FA_002 | N | O | O | O |
| the_nihilant | MICRO COMMERCIAL COMPONENTS - 2N3906-AP - BJT, PNP, 40VDC, TO-92 | 1924641 | 100 | 0,028 HT | David | FA_002 | N | O | O | O |
| the_nihilant | STMICROELECTRONICS - ULN2803A - RESEAU DE TRANSISTOR DARLINGTON 8NPN | 1094428 | 10 | 0,84 HT | David | FA_002 | N | O | O | O |
| Eric | KONTAKT WL 200ML | 800946 | 1 | 5,56 HT | David | FA_002 | N | O | O | O |
| Eric | KONTAKT IPA 200ML | 2142406 | 1 | 6,78 HT | David | FA_002 | N | O | O | O |
| Eric | NXP - BYC10D-600 - DIODE HYPERFAST 10A 600V TO220AC | 2075013 | 4 | 1,23 HT | David | FA_002 | N | O | O | O |
| Lab | VISHAY DALE RESISTOR, METAL FILM, 1KOHM, 3W, 1% ref CPF31K0000FKE14 | 1218226 | 1 | 1,51 HT | David | FA_002 | N | O | O | O |
| MAZ24 | ATAVRISP2 | 1135517 | 1 | 28,13 | David | FA_002 | N | O | O | O |
| MAZ24 | ARDUINO A000048 | 1848694 | 2 | 4,41 | David | FA_002 | N | O | O | O |
| MAZ24 | ARDUINO UNO A000073 | 2285200 | 1 | 26,97 | David | FA_002 | N | O | O | O |
| MAZ24 | ULN2003ADR | 1470513 | 10 | 0,31 | David | FA_002 | N | O | O | O |
| Crafty | LTC3122EMSE#PBF BOOST SYNCH 15V 2.5A 3MHZ 12MSOP | 2148749 | 10 | 3,51 | David | FA_002 | N | O | O | N |
| Crafty | NXP - 2N7002P - MOSFET CANAL N 60V 0.36A SOT23 | 1859848RL | 30 | 0,115 | David | FA_002 | N | O | O | N |
| Crafty | KINGBRIGHT - KPTD-3216ZGC-01 - LED 1206 DOME REV.RUBAND TRUE-GRE | 2290350 | 40 | 0,40 | David | FA_002 | N | O | O | N |
| Crafty | TEXAS INSTRUMENTS - TLC59116IPWR - LED DRIVER, 16CH, I2C BUS, TSSOP28 | 1647815 | 4 | 4,24 | David | FA_002 | N | O | O | N |
| Crafty | TEXAS INSTRUMENTS - TLC5941PWPG4 - DRIVER DE LED 16 VOIES CMS | 1226308 | 4 | 2,28 | David | FA_002 | N | O | O | N |
| Crafty | NXP - PCA9634PW - DRIVER DE LED RGBA 20-TSSOP | 1854071 | 4 | 1,65 | David | FA_002 | N | O | O | N |
| Crafty | NXP - PCA9622DR - DRIVER DE LED RGBA 32-TSSOP | 1854075RL | 4 | 1,89 | David | FA_002 | N | O | O | N |
| Crafty | LINEAR TECHNOLOGY - LTC3109IUF#PBF - BOOST PMU 20QFN | 1839119 | 4 | 5,31 | David | FA_002 | N | O | O | N |
| Crafty | PANASONIC - EECF5R5U155 - CONDENSATEUR 1.5F 5.5V | 1305065 | 2 | 4,21 | David | FA_002 | N | O | O | N |
| Crafty | PANASONIC - EECS5R5H105 - CONDENSATEUR 1F 5.5V | 9697497 | 2 | 4,17 | David | FA_002 | N | O | O | N |
| MrPozor | CONNECTEUR 90142 C GRID 26 VOIES | 3291662 | 5 | 1,19 | David | FA_002 | N | O | O | O |
| MrPozor | CONTACT FEMELLE 26-28AWG | 9733280 | 40 | 0,23 | David | FA_002 | N | O | O | O |
| MrPozor | CONNECTEUR 90142 C GRID 14 VOIES | 3291601 | 5 | 0,99 | David | FA_002 | N | O | O | O |
| MrPozor | EMBASE F HE10 DROIT 14V.+S. CABLE | 1099237 | 1 | 0,59 | David | FA_002 | N | O | O | O |
| CydGy | CONTACT FEMELLE 26-28AWG | 1308868 | 5 | 1,97 € | David | FA_002 | N | O | O | O |
| CydGy | CONNECTEUR RCA/PHONO FEMELLE 3 VOIES | 2293877 | 1 | 2,73 € | David | FA_002 | N | O | O | O |
| CydGy | FICHE FEMELLE JACK 3.5MM STEREO | 1280747 | 1 | 0,86 € | David | FA_002 | N | O | O | O |
| CydGy | TRANSFORMATEUR COURANT E5 3000UH | 1579334 | 1 | 2,53 € | David | FA_002 | N | O | O | O |
| CydGy | DIODE LASER 655NM | 1272658 | 1 | 6,84 € | David | FA_002 | N | O | O | O |
| Eric | AVAGO HDSP-4832 RESEAUX DE LED MULTICOL. | 1003271 | 1 | 5.29 €HT | David | FA_003 | N | O | O | N |
| Crafty | WURTH ELEKTRONIK - 74488540070 - INDUCTANCE RECUPERATION D'ENERGIE 7.5UH | 2249879 | 8 | 3,55 | David | FA_003 | N | O | O | N |
| David | VITELEC - VB1094/L-75 - EMBASE PANNEAU FEMELLE BNC DROITE | 2254719 | 4 | 3,36 | David | FA_003 | N | O | O | N |
| Raoul | FRDM-KL25Z - CARTE KINETIS L SERIES KL25Z | 2191861 | 1 | 11,75€HT | <acheteur> | FA_003 | O | O | O | N |
| Pilou | FRDM-KL25Z - CARTE KINETIS L SERIES KL25Z | 2191861 | 1 | 11,75€HT | David | FA_003 | N | O | O | N |
| Pilou | TL082ACP - AMPLI OP DOUBLE BIFET | 1103189 | 4 | 0,64€HT | David | FA_003 | N | O | O | N |
| Pilou | VT935G - PHOTO RESISTANCE SERIE VT901 | 1652638 | 5 | 0,40€HT | David | FA_003 | N | O | O | N |
| 3dsman | FRDM-KL25Z - CARTE KINETIS L SERIES KL25Z | 2191861 | 1 | 11,75€HT | David | FA_003 | N | O | O | N |
| 3dsman | VEMD2020X01 - PHOT. DIODE SMD GULLWING FILT. | 1779705 | 10 | 0,3€HT | David | FA_003 | N | O | O | N |
| 3dsman | TSAL6200.. - IR EMITT. HI POWR 940NM 5MM 17DEG | 1779662 | 10 | 0,26€HT | David | FA_003 | N | O | O | N |
| Nicolas | MULTICOMP 2226TG | 1593529 | 100 | 0,083€HT | David | FA_003 | N | O | N | N |
| Nicolas | MULTICOMP 2226A-22 | 1593518 | 10 | 0,076€HT | David | FA_003 | N | O | N | N |
| Nicolas | MULTICOMP 2226B-22 | 1593527 | 10 | 0,077€HT | David | FA_003 | N | O | N | N |
| Eric | Double diode 1,2kV 11A ref: DSP8-12A fabricant : IXYS TO220AB | 1080104 | 4 | 1,54€HT | David | FA_003 | N | O | O | N |
| Antoine | MICRO 8 BITS AVR 32K FLASH 28PDIP | 1715487 | 2 | 3,86€HT | David | FA_003 | N | O | O | N |
| Antoine | REGULATEUR DE TENSION 5V | 1467758 | 4 | 0,49€HT | David | FA_003 | N | O | O | N |
| Antoine | CONDENSATEUR 22UF 50V | 8766835 | 2 | 0,137€HT | David | FA_003 | N | O | O | N |
| Antoine | CONDENSATEUR 0.01UF 50V | 2112749 | 2 | 0,27€HT | David | FA_003 | N | O | O | N |
| Antoine | RESISTANCE CARBONE 1/4W 1K0 | 1265072 | 5 | 0,13€HT | David | FA_003 | N | O | O | N |
| Thomas | INDUCTANCE | 2061655 | 5 | 0.36€HT | David | FA_003 | N | O | N | N |
| Raoul | C0805C105K4RACTU | 9227792 | 10 | 0.053 | David | FA_003 | O | O | O | N |
| Raoul | TMK212B7473KD-T | 1759031 | 100 | 0.008 | David | FA_003 | O | O | O | N |
| Raoul | CC0805KRX7R9BB391 | 3019846 | 10 | 0.054 | David | FA_003 | O | O | O | N |
| Raoul | CC0805KRX7R9BB222 | 3019895 | 10 | 0.044 | David | FA_003 | O | O | O | N |
| Raoul | APXA160ARA331MJC0G | 1580614 | 5 | 1.45 | David | FA_003 | O | O | O | N |
| Raoul | CC0805JRNP09BN101 | 3606028 | 10 | 0.086 | David | FA_003 | O | O | O | N |
| Raoul | GRM155R61A274KE15D | 1759111 | 100 | 0.008 | David | FA_003 | O | O | O | N |
| Raoul | 30CTQ060STRLPBF | 1611297 | 1 | 2.07 | David | FA_003 | O | O | O | N |
| Raoul | SER2915L-103KL | 2288908 | 1 | 2.85 | David | FA_003 | O | O | O | N |
| Raoul | CSD16415Q5 | 1710776 | 1 | 2.01 | David | FA_003 | O | O | O | N |
| Raoul | CRCW080517K8FKEA | 1652927 | 1 | 0.076 | David | FA_003 | O | O | O | N |
| Raoul | CRCW04025R11FKED | 1469821 | 50 | 0.009 | David | FA_003 | O | O | O | N |
| Raoul | CRCW08051K00FKEA | 1469847 | 50 | 0.022 | David | FA_003 | O | O | O | N |
| Raoul | CRCW08055M36FKEA | 2139208 | 50 | 0.008 | David | FA_003 | O | O | O | N |
| Raoul | CSNL1206FT3L00 | 2079419 | 5 | 0.194 | David | FA_003 | O | O | O | N |
| Raoul | CRCW08053K16FKEA | 1469910 | 50 | 0.023 | David | FA_003 | O | O | O | N |
| Raoul | CRCW080551K1FKEA | 1469943 | 50 | 0.023 | David | FA_003 | O | O | O | N |
| MAZ24 | ATMEL ATTINY85-20PU | 1455162 | 10 | 1.09 | Damien H | FA_004 | N | O | N | N |
| NAZ24 | ATMEL ATTINY4313-PU | 1841620 | 10 | 1.14 | Damien H | FA_004 | N | O | N | N |
| 3dsman | MULTICOMP-703-1028-LED RGB 3528 PLCC | 2112143 | 5 | 0,42€HT | Damien H | FA_004 | N | O | N | N |
| 3dsman | EXCELITAS TECH-VT935G-PHOTO RESISTANCE SERIE VT901 | 1652638 | 5 | 0,40€HT | Damien H | FA_004 | N | O | N | N |
| 3dsman | BTB04-600SL - TRIAC 4A 600V TO-220AB | 9910522 | 10 | 0,47€HT | Damien H | FA_004 | N | O | N | N |
| 3dsman | OPTOCOUPLEUR SORTIE DARLINGTON DIP-4 | 1852745 | 10 | 0,072€HT | Damien H | FA_004 | N | O | N | N |
| 3dsman | ATMEGA88A-AU - MCU, 8BIT, AVR, 8K FLASH, 32TQFP | 1841614 | 10 | 1,72€HT | Damien H | FA_004 | N | O | N | N |
| 3dsman | FOX ELECTRONICS - FXO-HC536R-20 - OSC, 3.2X5MM, SMD, CER, 20.000MHZ | 1641035 | 2 | 1,65€HT | Damien H | FA_004 | N | O | N | N |
| 3dsman | AMS - AS5035-ASSU - ENCODER, MAGNETIC, ROTARY, 8BIT, 16SSOP | 1630798 | 1 | 4,64€HT | Damien H | FA_004 | N | O | N | N |
| the_nihilant | ATMEL - ATMEGA48A-AU - MCU, 8BIT, AVR, 4K FLASH, 32TQFP | 1841612 | 5 | 1,92 HT | Damien H | FA_004 | N | O | N | N |
| the_nihilant | KEYSTONE - 2463 - SUPPORT POUR BATTERIE | 1702631 | 3 | 1,05 HT | Damien H | FA_004 | N | O | N | N |
| the_nihilant | TE CONNECTIVITY / AMP - 0-0881545-2 - STRAP D'INTERCONNEXION AVEC LANGUETTE | 4218176 | 50 | 0,115 HT | Damien H | FA_004 | N | O | N | N |
| PapyCHeF | Résistance chauffante (pour quartz) | 1515897 | 5 | 1,02 (HT) | Damien H | FA_004 | N | O | N | N |
| Yann | Cable FPC 16pin 20cm inversé | 1908499 | 1 | 4,92 (HT) | Damien H | FA_004 | N | O | N | N |
| Raoul | MC33926 | 2102575 | 2 | 4.01 HT | Damien H | FA_004 | N | O | N | N |
| Damien H | A4988SETTR-T MOTOR DRIVER | 2057418 | 1 | 4,00 (HT) | Damien H | FA_004 | N | O | N | N |
| MAZ24 | capteur hall effect | 1811311 | 10 | 0,79 (HT) | Damien H | FA_004 | N | O | N | N |
| MAZ24 | ATtiny13A-PU | 1704566 | 10 | 1,12 (HT) | Damien H | FA_004 | N | O | N | N |
| MAZ24 | Hall switch | 1825248 | 20 | 0,36(HT) | Damien H | FA_004 | N | O | N | N |
| Pilou | STP13NM60N | 1737870 | 1 | 4,23(HT) | Damien H | FA_004 | N | O | N | N |
| Pilou |
| Lab | LUBRICANT KONTAFLON 85 200ML KONTAKT CHEMIE | 2142404 | 1 | 9.20(HT) | 3dsman | FA_005 | N | O | O | O |
| CDR2014 | B41142A7476M | 1735339 | 10 | 0.132(HT) | 3dsman | FA_005 | N | O | O | O |
| CDR2014 | MC0805N220J500CT | 1759195 | 10 | 0.021(HT) | 3dsman | FA_005 | N | O | O | O |
| CDR2014 | MC0805B105K160CT | 2320853 | 30 | 0.027(HT) | 3dsman | FA_005 | N | O | O | O |
| CDR2014 | KP-2012QBC-D | 2217974 | 10 | 0.155(HT) | 3dsman | FA_005 | N | O | O | O |
| CDR2014 | KPT-2012SGC | 2099239 | 50 | 0.073(HT) | 3dsman | FA_005 | N | O | O | O |
| CDR2014 | KPT-2012SURCK | 2099241 | 50 | 0,097(HT) | 3dsman | FA_005 | N | O | O | O |
| CDR2014 | DMS3016SSSA | 2061527 | 2 | 0.28(HT) | 3dsman | FA_005 | N | O | O | O |
| CDR2014 | HC49SM-20-30-50-60-16-ATF | 1667018 | 1 | 0.40(HT) | 3dsman | FA_005 | N | O | O | O |
| CDR2014 | MC0805X106K160CT | 2320856 | 30 | 0.084(HT) | 3dsman | FA_005 | N | O | O | O |
| CDR2014 | MCCA000282 | 1759151RL | 100 | 0.027(HT) | 3dsman | FA_005 | N | O | O | O |
| CDR2014 | MCSR08X2700FTL | 2074422 | 100 | 0.014(HT) | 3dsman | FA_005 | N | O | O | O |
| CDR2014 | MCSR08X4701FTL | 2074469 | 100 | 0.011(HT) | 3dsman | FA_005 | N | O | O | O |
| CDR2014 | MCSR08X1003FTL | 2074335 | 100 | 0.014(HT) | 3dsman | FA_005 | N | O | O | O |
| F6ITU | régul CMS LDO +1.8V XC6201P182PRN | 1106655 | 4 | 0,49 €(HT) | 3dsman | FA_005 | N | O | O | O |
| F6ITU | régul CMS LDO +3.3V XC6201P332PR | 3605711 | 2 | 0,41 €(HT) | 3dsman | FA_005 | N | O | O | O |
| F6ITU | régul CMS LDO +1,5V LP5951MF-1.5 | 1312652 | 2 | 0,68 €(HT) | 3dsman | FA_005 | N | O | O | O |
| F6ITU | Ref tension +2,5V LM4132CMF | 1312757 | 2 | 2,85 €(HT) | 3dsman | FA_005 | N | O | O | O |
| F6ITU | schottky | 1651114RL | 5 | 0,53 €(HT) | 3dsman | FA_005 | N | O | O | O |
| F6ITU | tank coil | 2062736 | 1 | 0,83 €(HT) | 3dsman | FA_005 | N | O | O | O |
| Axone | LM35CAZ | 9494529 | 2 | 4.65 €(HT) | 3dsman | FA_005 | N | O | O | O |
| N-i-c-o | STP6NK60ZFP (MOSFET N 600V 6A) | 9803289 | 2 | 1.61 €(HT) | 3dsman | FA_005 | N | O | O | O |
| N-i-c-o | Tresse à dessouder 2,5mm | 876847 | 1 | 3.03 €(HT) | 3dsman | FA_005 | N | O | O | O |
| N-i-c-o | Jack mâle stéréo 3,5mm | 1280662 | 5 | 0.75 €(HT) | 3dsman | FA_005 | N | O | O | O |
| MAZ24 | Microchip 16F753-I/P | 2360788 | 10 | 1,47 | 3dsman | FA_005 | N | O | O | O |
| MAZ24 | Capteur effet hall SS341RT | 1784727 | 10 | 0.85 | 3dsman | FA_005 | N | O | O | O |
| Thomas | IRLH5030TRPBF | 1831085 | 14 | 1.24 | 3dsman | FA_005 | N | O | O | O |
| Limesle | QRE1113GR - OPTO COMMUTATEUR REFLECTIF | 1471020 | 6 | 1.14 | 3dsman | FA_005 | N | O | O | O |
| Limesle | RESISTANCE METAL 10 OHM | 2329993 | 10 | 0.04 | 3dsman | FA_005 | N | O | O | O |
| Limesle | RESISTOR, METAL 20 OHM | 2330062 | 10 | 0.04 | 3dsman | FA_005 | N | O | O | O |
| Limesle | RESISTANCE METAL 51 OHM | 2330176 | 10 | 0.04 | 3dsman | FA_005 | N | O | O | O |
| Limesle | RESISTOR, METAL 30 KOHM | 2330102 | 10 | 0.04 | 3dsman | FA_005 | N | O | O | O |
| Limesle | RESISTOR, METAL 51 KOHM | 2330175 | 10 | 0.04 | 3dsman | FA_005 | N | O | O | O |
| Limesle | RESISTOR, METAL 100 KOHM | 1563073 | 10 | 0,048 | 3dsman | FA_005 | N | O | O | O |
| PAPY F1CHF | ECLATEUR A GAS 300V 15KA | 2148133 | 10 | 0.39 | 3dsman | FA_005 | N | O | O | O |
| Victor | DS18B20 THERMOMETER | 1187948 | 2 | 4,89€ (HT) | 3dsman | FA_005 | N | O | O | O |
| Goldo | ANALOG DEVICES - ADUM3223BRZ - DRIVER GATE 1MHZ 4A 4.5V 16SOIC | 2127170 | 2 | 4,07€ (HT) | 3dsman | FA_005 | N | O | O | O |
| Goldo | PANASONIC - ERJP14J3R9U - RESISTANCE SURGE 1210 5% 3R9 | 1750886 | 25 | 0,06€ (HT) | 3dsman | FA_005 | N | O | O | O |
| Goldo | ATMEL - ATMEGA1284P-PU - MICRO 8 BITS AVR 128K FLASH 40PDIP | 1715481 | 1 | 6,40€ (HT) | 3dsman | FA_005 | N | O | O | O |
| MAZ24 | contacts molex 08-55-110 | 2313553 | 200 | 0,075 | 3dsman | FA_005 | N | O | O | O |
| MAZ24 | boitier molex 22-01-2025 | 143126 | 30 | 0,224 | 3dsman | FA_005 | N | O | O | O |
| MAZ24 | boitier molex 22-01-2035 | 143127 | 20 | 0,26 | 3dsman | FA_005 | N | O | O | O |
| MAZ24 | Embase coudée 6voies AMP | 2215288 | 10 | 0,39 | 3dsman | FA_006 | N | O | N | N |
| MAZ24 | Femelle IDC 6voies AMP | 2215245 | 10 | 0,37 | 3dsman | FA_006 | N | O | N | N |
| MAZ24 | HEADER, 2.54MM, PIN, R/A, 10WAY | 1841228 | 10 | 1,24 | 3dsman | FA_006 | N | O | N | N |
| MAZ24 | EMBASE MALE 3 VOIES MOLEX | 1462932 | 20 | 0,45 | 3dsman | FA_006 | N | O | N | N |
| Maz24 | Cordon 6 voies F/F 150 mm | 2217605 | 5 | 1,82 | 3dsman | FA_006 | N | O | N | N |
| Jnat | DEV BRD, NUCLEO STM32F0, STM32F030R8 | 2394225 | 2 | 11.18 | 3dsman | FA_006 | N | O | N | N |
| Jnat | DEV BRD, NUCLEO STM32F4, STM32F401RE | 2394223 | 2 | 11.18 | 3dsman | FA_006 | N | O | N | N |
| Jnat | DEV BRD, NUCLEO STM32L1, STM32L152RE | 2394227 | 2 | 11.18 | 3dsman | FA_006 | N | O | N | N |
| Burnyfighter 'Pierre' | MC34152PG - DRIVER MOS RAPIDE | 9664424 | 10 | 1.18HT | 3dsman | FA_006 | N | O | N | N |
| Eric | lot de 5 pcs SAMTEC - SMS-115-01-S-S - SOCKET, 1.27 X 2.54MM, 1X15WAY Réf: SMS-115-01-S-S (header femelle droit) | 1804970 | 1 | 4,66EURHT | MrPozor | FA_007 | N | O | O | O |
| Eric | lot de 5 pcs SAMTEC HEADER, 1.27MM, THT, R/A, 15WAY Réf: TMS-115-01-L-S-RA (header male coudé) | 2055131 | 1 | 3,33EURHT | MrPozor | FA_007 | N | O | O | O |
| MrPozor | CONDENSATEUR 68UF 400V 18X25MM | 1673496 | 1 | 2.07 | MrPozor | FA_007 | N | O | O | O |
| MrPozor | CAP, ALU ELEC, 1000UF, 10V, RAD | 2346253 | 2 | 0.34 | MrPozor | FA_007 | N | O | O | O |
| MrPozor | CONDENSATEUR 470UF 25V | 8126461 | 2 | 1.03 | MrPozor | FA_007 | N | O | O | O |
| MrPozor | CAP, ALU ELEC, 47UF, 50V, RAD | 2346604 | 1 | 0.174 | MrPozor | FA_007 | N | O | O | O |
| MrPozor | CAPACITOR RADIAL 50V 0.68UF | 1902067 | 5 | 0.199 | MrPozor | FA_007 | N | O | O | O |
| MrPozor | CONDENSATEUR 1UF 50V | 8126933 | 1 | 0.27 | MrPozor | FA_007 | N | O | O | O |
| MrPozor | CAPACITOR RADIAL 50V 4.7UF | 1902072 | 5 | 0.083 | MrPozor | FA_007 | N | O | O | O |
| Goldo | EMBASE VERTICAL 2.54MM 40VOIES | 2215314 | 4 | 0.82 | MrPozor | FA_007 | N | O | O | O |
| Goldo | BOUTON D'URGENCE | 1606956 | 1 | 21.31 | MrPozor | FA_007 | N | O | O | O |
| Thomas | Diode | 1456535 | 10 | 0.097 | MrPozor | FA_007 | N | O | O | O |
| Thomas | Diode | 1621821 | 20 | 0.05 | MrPozor | FA_007 | N | O | O | O |
| Thomas | connecteur | 1278365 | 6 | 0.84 | MrPozor | FA_007 | N | O | O | O |
| Thomas | stm32f303 micro | 2215110 | 2 | 8.62 | MrPozor | FA_007 | N | O | O | O |
| Lab | TEXAS INSTRUMENTS - TLC555CP | 1103036 | 400 | 0.239 | MrPozor | FA_007 | N | O | O | O |
| Lab | CAP MLCC X7R 100NF 50V RAD | 2309020 | 1000 | 0.022 | MrPozor | FA_007 | N | O | O | O |
| Lab | RESISTANCE CARBON 1M0 0.25W 5% CFR16J1M0 | 2329490 | 1000 | 0.008 | MrPozor | FA_007 | N | O | O | O |
| F4GRX | BS250FTA MOSFETCANAL P45V0.09ASOT23-3 | 1843731 | 25 | 0.47 | MrPozor | FA_007 | N | O | O | O |
| F4GRX | BS170 TRANSISTOR MOSFET N TO-92 | 1017687 | 25 | 0.206 | MrPozor | FA_007 | N | O | O | O |
| F4GRX | BS170F TRANSISTOR MOSFET CANAL N SOT-23 | 9526005 | 25 | 0.40 | MrPozor | FA_007 | N | O | O | O
| Clément | bobine fil AWG24 gris 250m | 1199049 | 1 | 28,43 € | the_nihilant | FA_008 | N | o | N | N |
| the_nihilant | ATMEGA48-20AU - 8BIT 4K FLASH MCU CMS TQFP32 | 9171312 | 3 | 1,58 € HT | the_nihilant | FA_008 | N | o | N | N |
| the_nihilant | ATMEGA328-PU - MICRO 8 BITS AVR 32K FLASH 28PDIP | 1972087 | 4 | 2,26 € HT | the_nihilant | FA_008 | N | o | N | N |
| the_nihilant | TE CONNECTIVITY / AMP - 5177984-1 - CONNECTEUR MALE CMS VERTICALEE 40P | 1098335 | 4 | 2,02 € HT | the_nihilant | FA_008 | N | o | N | N |
| the_nihilant | TE CONNECTIVITY / AMP - 5177983-1 - CONNECTEUR 40 VOIES 5MM | 1098345 | 1 | 1,68 € HT | the_nihilant | FA_008 | N | o | N | N |
| the_nihilant | EPCOS - B57863S103F040 - CAPTEUR CTN MINIATURE 10K | 1299930 | 3 | 2,78 € HT | the_nihilant | FA_008 | N | o | N | N |
| the_nihilant | ATMEL - ATTINY13A-PU - MCU 8 BITS AVR 1K FLASH 8PDIP | 1704566 | 6 | 0,785 € HT | the_nihilant | FA_008 | N | o | N | N |
| the_nihilant | RALTRON - AS-10.000-18 - QUARZ, 10MHZ, 18PF, HC49/S | 1611856 | 10 | 0,26 € HT | the_nihilant | FA_008 | N | o | N | N |
| Jérôme | BOURNS - PTA4543-2015DP-B103 - POTENTIOMETRE RECTILIGNE 10K 45MM | 1688415 | 1 | 1,22 € HT | the_nihilant | FA_008 | N | o | N | N |
| Jérôme | BOURNS - PTA4543-2015DP-A103 - POTENTIOMETRE RECTILIGNE 10K 45MM | 1688414 | 1 | 1,31 € HT | the_nihilant | FA_008 | N | o | N | N |
| Lab (Eric) | MULTICOMP - 038-0016 - MOUSSE HD COND. 305X305X6MM | 1687855 | 2,64 € HT | Laurent (C) | FA_009 | N | O | N | N | |
| Nicolas M. | Condensateur Snap-In 4700µF 63V | 1839289 | 6 | 2,52 € HT | Laurent (C) | FA_009 | O | O | O | O |
| Nicolas M. | Résistance 0,15 ohm 2W traversante | 1219188 | 2 | 0,312 € HT | Laurent (C) | FA_009 | O | O | O | O |
| Nicolas M. | Condensateur alu CMS 100µF 16V | 1870603 | 2 | 0,239 € HT | Laurent (C) | FA_009 | O | O | O | O |
| Nicolas M. | Ampli op NE5534 SO8 | 9589872 | 2 | 0,945 € HT | Laurent (C) | FA_009 | O | O | O | O |
| Nicolas M. | Condensateur alu CMS 4,7µF 16V | 2326125 | 1 | 0,369 € HT | Laurent (C) | FA_009 | O | O | O | O |
| Nicolas M. | Transistor NPN BC848B SOT-23 | 1773620 | 5 | 0,0377 € HT | Laurent (C) | FA_009 | O | O | O | O |
| Nicolas M. | Transistor PNP BC858B SOT-23 | 1773610 | 1 | 0,0978 € HT | Laurent (C) | FA_009 | O | O | O | O |
| Nicolas M. | Transistor NPN FZT653 SOT-223 | 9525017 | 1 | 0,669 € HT | Laurent (C) | FA_009 | O | O | O | O |
| Nicolas M. | Transistor PNP FZT753 SOT-223 | 9525033 | 2 | 0,919 € HT | Laurent (C) | FA_009 | O | O | O | O |
| Nicolas M. | Trimmer CMS 2k | 3531478 | 1 | 0,372 € HT | Laurent (C) | FA_009 | O | O | O | O |
| Laurent C | 74ACT244SC | 1014150 | 10 | 0,608 € HT | Laurent (C) | FA_009 | O | O | O | O |
| Steve | MULTICOMP COND 1UF 50V GLR | 1902991 | 10 | 0,0613 € HT | Laurent (C) | FA_009 | O | O | O | O |
| Steve | PANASONIC COND 47UF 50V NHG | 9692959 | 5 | 0,199 € HT | Laurent (C) | FA_009 | O | O | O | O |
| Steve | MULTICOMP COND 470UF 10V GLR | 1902954 | 5 | 0,1612 € HT | Laurent (C) | FA_009 | O | O | O | O |
| Eric | Casque anti-bruit OPTIME III Fabricant : AEARO | 1373086 | 1 | 45.57 €HT | Laurent (C) | FA_009 | O | O | O | O |
| Eric | EPCOS B64290L40X830 Ferrite Core R58, Toroid, 60.1 x 39.2 x 18.8mm AL5400 Mat: N30 ] | 1792070 | 1 | 14.15 €HT | Laurent (C) | FA_009 | O | N (réservé entreprises) |
N | O |
| Eric | EPCOS B64290L82X830 Ferrite Core R50, Toroid, 50 Dia. x 30mm AL8700 Mat: N30 | 2396140 | 1 | 13.01 €HT | Laurent (C) | FA_009 | O | O | O | O |
| Eric | EPCOS B64290L659X830 Ferrite Core R40 Toroid 41.8 Dia. x 17.2mm AL7000 Mat:N30 | 2396139 | 1 | 7.61 €HT | Laurent (C) | FA_009 | O | O | O | O |
| Eric | STM Dual Diode STTH60W02CW 200 V, 2x30 A, 1.35 V, 30 ns | 2325967 | 2 | 3.88 €HT | Laurent (C) | FA_009 | O | O | O | O |
| Eric | STM Diode STTH2002DI 200 V, 20 A, 1.1 V, 16 ns, 175 A | 1295249 | 2 | 2.86 €HT | Laurent (C) | FA_009 | O | O | O | O |
| Eric | LT1677IS8#PBF Single Opamp 7.2 MHz, 2.5 V/µs, ± 1.7V à ± 18V, SOIC8 | 2115807 | 4 | 5.96 €HT | Laurent (C) | FA_009 | O | O | O | O |
| Eric | EPCOS B64290L0699X087 Ferrite Core Toroid, 65 Dia. x 36mm AL5000 Mat:N87 | 2355022 | 1 | 15.69 €HT | Flax | FA_010 | O | O | O | O |
| lab (PierreG) | OHMITE WHD1R0FET WIREWOUND RESISTOR, 1 OHM, 3W, 1% | 2099538 | 5 | 1,38 € | Flax | FA_010 | N | O | N | N |
| Steve | STM NUCLEO-L476RG | 2493816 | 1 | 9,05 € HT | Flax | FA_010 | O | O | O | O |
| Steve | FTDI UMFT220XB-WE | 2498923 | 1 | 7,44 € HT | Flax | FA_010 | O | O | O | O |
| Raoul | Banana étoupe noire | 844019 | 2 | 1,81 € HT | Flax | FA_010 | N | O | N | N |
| Raoul | Banana étoupe orange | 844007 | 2 | 1,59 € HT | Flax | FA_010 | N | O | N | N |
| Goldo | STM LSM9DS0 Module MEMS | 2433079 | 1 | 10,91 € HT | Flax | FA_010 | O | O | O | O |
| papy F1CHF | rivets plastiques | 7235112 | 1 | 6 € HT | papy F1CHF | FA_011 | o | o | O | O |
| le grx | bav99w | 1081212 | 10 | 0.163 | papy F1CHF | FA_011 | o | o | O | O |
| le grx | cap avx 0402YC104KAT2A | 1833861 | 50 | 0,162 | papy F1CHF | FA_011 | o | o | O | O |
| le grx | cap avx TPSB107K006R0400 | 1432579 | 5 | 0,951 | papy F1CHF | FA_011 | o | o | O | O |
| le grx | cap avx 1206YC106KAT2A | 1657943 | 10 | 0,456 | papy F1CHF | FA_011 | o | o | O | O |
| le grx | cap avx TPSB475K035R0700 | 1658970 | 5 | 1,31 | papy F1CHF | FA_011 | o | o | O | O |
| le grx | res multicomp MCWR04X1002FTL | 2447096 | 500 | 0,0064 | papy F1CHF | FA_011 | o | o | O | O |
| le grx | res multicomp MCWR06X1002FTL | 2447230 | 500 | 0,0067 | papy F1CHF | FA_011 | o | o | O | O |
| le grx | res multicomp MCWR06X3302FTL | 2447342 | 100 | 0,0068 | papy F1CHF | FA_011 | o | o | O | O |
| le grx | res multicomp MCMR04X6800FTL | 2073200 | 100 | 0,0141 | papy F1CHF | FA_011 | o | o | O | O |
| le grx | diode NTS260SFT1G | 2473419 | 40 | 0.11 | papy F1CHF | FA_011 | o | o | O | O |
| le grx | led TLMS1000-GS08 | 2473419 | 20 | 0.247 | papy F1CHF | FA_011 | o | o | O | O |
| Eric | Foret HSS 6,35mm marque DORMER ref A0021/4 | 2290515 | 2 | 3.02€ HT | Damien H | FA_012 | N | O | O | O |
| Eric | Foret HSS TIN 6,7mm marque DORMER ref A0026.7 | 2290532 | 2 | 3.62€ HT | Damien H | FA_012 | N | O | O | O |
| Eric | Foret HSS TIN 6,8mm marque DORMER ref A0026.8 | 1389522 | 2 | 5.37€ HT | Damien H | FA_012 | N | O | O | O |
| Eric | Stylo Oil Loctite ref 2105021 | 537147 | 2 | 8.37€ HT | Damien H | FA_012 | N | O | O | O |
| Eric | CMS LDO +3.3V TOREX XC6201P332PR SOT-89-3 | 3605711 | 2 | 0,698 €HT | Damien H | FA_012 | N | O | O | O |
| Lab (Eric) | Batterie 12V YUASA NP1.2-12 | 147472 | 1 | 19,47 €HT | Damien H | FA_012 | N | O | O | O |
| Lab (Eric) | CR2450 LITHIUM 3V, 600MAH | 2065173 | 1 | 1,29€HT | Damien H | FA_012 | N | O | O | O |
| Nicolas M. | Transistor NPN FZT653 SOT-223 | 9525017 | 2 | 0,669 € HT | Damien H | FA_012 | N | O | O | O |
| Nicolas M. | Transistor PNP FZT753 SOT-223 | 9525033 | 3 | 1,41 € HT | Damien H | FA_012 | N | O | O | O |
| Nicolas M. | Pince croco 2mm rouge | 1699016 | 2 | 1,52 € HT | Damien H | FA_012 | N | O | O | O |
| Nicolas M. | Pince croco 2mm noire | 1699017 | 2 | 1,38 € HT | Damien H | FA_012 | N | O | O | O |
| Nicolas M. | Préampli audio SSM2019 | 2102509 | 4 | 3,97 € HT | Damien H | FA_012 | N | O | O | O |
| Nicolas M. | Embase XLR + Jack Neutrik NCJ9FI-H | 5008372 | 2 | 3,577€ HT | Damien H | FA_012 | N | O | O | O |
| Nicolas M. | Câble DVI-D -> HDMI 2m | 1277667 | 1 | 4,873€ HT | Damien H | FA_012 | N | O | O | O |
| Damien H. | Potard 1Mohm | 2321780 | 2 | 3,18€ HT | Damien H | FA_012 | O | O | O | O |
| Damien H. | Diode Zener BZX79C4V7 | 1651557 | 5 | 0,125€ HT | Damien H | FA_012 | O | O | O | O |
| Goldo | ANALOG DEVICES ADXRS453BRGZ Gyroscope MEMS | 2377130 | 1 | 63,38€ HT | Damien H | FA_012 | O | O | O | O |
Gotronic
| CDR2014 | connecteurs miniatures nsk254 male coudé 4cts | 48712 | 10 | 0.12€ | GO_001 | N | O | N | N | |
| CDR2014 | connecteurs miniatures nsk254 male droit 4cts | 48717 | 10 | 0.12€ | GO_001 | N | O | N | N | |
| CDR2014 | connecteurs miniatures nsk254 femelle 4cts | 48722 | 10 | 0.08€ | GO_001 | N | O | N | N | |
| CDR2014 | connecteurs miniatures nsk254 contacts | 48722 | 5 | 0.20€ | GO_001 | N | O | N | N | |
| CDR2014 | connecteurs miniatures nsk396 male coudé 3cts | 48691 | 10 | 0.15€ | GO_001 | N | O | N | N | |
| CDR2014 | connecteurs miniatures nsk396 male droit 3cts | 48694 | 10 | 0.15€ | GO_001 | N | O | N | N | |
| CDR2014 | connecteurs miniatures nsk396 femelle 3cts | 48697 | 10 | 0.10€ | GO_001 | N | O | N | N | |
| CDR2014 | connecteurs miniatures nsk396 contacts | 48698 | 4 | 0.55€ | GO_001 | N | O | N | N | |
| CDR2014 | pince a sertir les cosses de petites section | 13169 | 1 | 24.50€ | GO_001 | N | O | N | N | |
| CDR2014 | 300 colliers a sertir | 11357 | 1 | 5.50€ | GO_001 | N | O | N | N | |
| CDR2014 | Roue métallique OW006 | 25894 | 4 | 2.50€ | GO_001 | N | O | N | N | |
| 3dsman | 300 colliers a sertir | 11357 | 1 | 5.50€ | GO_001 | N | O | N | N | |
| 3dsman | gaine thermoretractable 1.6mm | 08840 | 1 | 1.00€ | GO_001 | N | O | N | N | |
| 3dsman | gaine thermoretractable 2.4mm | 08851 | 1 | 1.10€ | GO_001 | N | O | N | N | |
| 3dsman | gaine thermoretractable 3.2mm | 08841 | 1 | 1.20€ | GO_001 | N | O | N | N | |
| 3dsman | pack de 65 cables de conection m/m bbj2 | 12309 | 1 | 5.50€ | GO_001 | N | O | N | N | |
| Axone | BP rond | 07116 | 2 | 1.10€ | GO_001 | N | O | N | N | |
| Pilou | Paire de motoréducteurs DG01D | 31076 | 1 | 6.6€ | GO_001 | N | O | N | N | |
| Pilou | Adaptateur roue - moteur WMA | 31728 | 1 | 0.6€ | GO_001 | N | O | N | N | |
Mini-Circuits
Naviguer vers la page des commandes Mini-Circuits en cours
Mouser Electronics
Naviguer vers la page des commandes Mouser Electronics en cours
| Demandeur | Description | Ref Mouser | Quantité | Prix unitaire | Acheteur | Commande n° | Payé d'avance (O/N) | Commandé (O/N) | Distribué (O/N) | Remboursé/Archive (O/N) |
| Clem | alim 12v | SE-100-12 | 1 | 21.60€ | Goldo | MO_010 | Y | Y | Y | Y |
| fredericD | Diodes - 1N4148-T | 583-1N4148-T | 25 | 0,022€ | Goldo | MO_010 | Y | Y | Y | Y |
| fredericD | NPN Transistor BC547B A1 | 821-BC547B-A1 | 10 | 0,122€ | Goldo | MO_010 | Y | Y | Y | Y |
| fredericD | Zener Diodes 5.1 Volts | 821-BZX55C5V1 | 10 | 0,122€ | Goldo | MO_010 | Y | Y | Y | Y |
| fredericD | Zener Diodes 12 Volts | 821-BZX79B12 | 10 | 0,149€ | Goldo | MO_010 | Y | Y | Y | Y |
| fredericD | Crystals 20MHz 20pF | 73-XT49S2000-20 | 10 | 0,37€ | Goldo | MO_010 | Y | Y | Y | Y |
| fredericD | Ceramic Disc Capacitors 50V 15pF NPO 5% Tol | 140-50N2-150J-RC | 20 | 0,086€ | Goldo | MO_010 | Y | Y | Y | Y |
| fredericD | Ceramic Disc Capacitors 470pF 100V 10% | 594-D471K20Y5PH6UJ5R | 50 | 0,04€ | Goldo | MO_010 | Y | Y | Y | Y |
| fredericD | Ceramic Disc Capacitors 2200pF X760 Y500VAC 20% Y5U | 72-VY1222M43Y5UC63V0 | 20 | 0,29€ | Goldo | MO_010 | Y | Y | Y | Y |
| fredericD | Aluminium Electrolytic Capacitors - Leaded 10volts 470uF | 647-UVY1A471MED | 10 | 0,128€ | Goldo | MO_010 | Y | Y | Y | Y |
| fredericD | Aluminium Electrolytic Capacitors - Leaded 16volts 100uF | 80-ESH107M016AE3AA | 20 | 0,117€ | Goldo | MO_010 | Y | Y | Y | Y |
| fredericD | Aluminium Electrolytic Capacitors - 1µF-100V | 667-EEU-FC2A1R0H | 10 | 0,129€ | Goldo | MO_010 | Y | Y | N | Y |
| fredericD | Aluminium Electrolytic Capacitors - 100µF-63V | 667-EEU-EB1J101B | 10 | 0,254€ | Goldo | MO_010 | Y | Y | Y | Y |
| fredericD | Aluminium Electrolytic Capacitors - 35V 10uF | 140-RGA100M1VBK0511G | 100 | 0,06€ | Goldo | MO_010 | Y | Y | Y | Y |
| Eric | Tactile Switches RND 6.0x4.3mm 100gf ref#SKRGAAD010 Brand :ALPS | 688-SKRGAAD010 | 10 | 0,281€ | Goldo | MO_010 | Y | Y | Y? | Y |
| Goldo | DE0-Nano-SoC Kit | 993-P0286 | 1 | 104,37€ | Goldo | MO_010 | Y | Y | Y | Y |
| Goldo | Ethernet ICs 3 Port Ethernet Switch | 886-LAN9303-ABZJ | 1 | 5,76€ | Goldo | MO_010 | Y | Y | Y | Y |
| Goldo | Ethernet ICs Controller IEEE 10/ 100/1000 Mbps QFN64 | 607-WGI211ATSLJXZ | 1 | 2,95€ | Goldo | MO_010 | Y | Y | Y | Y |
| Goldo | RS-485 Interface IC Differential Bus | 595-SN65176BD | 2 | 0,805€ | Goldo | MO_010 | Y | Y | Y | Y |
| Goldo | RS-485 Interface IC Differential Bus | 595-SN65176BP | 2 | 0,742€ | Goldo | MO_010 | Y | Y | Y | Y |
| Goldo | RS-485 Interface IC Full-Duplex, 35kV ESD-Protected | 700-MAX14789EGSA+ | 2 | 5,21€ | Goldo | MO_010 | Y | Y | Y | Y |
| Goldo | RS-485 Interface IC Txrx RS-485 0.5Mbps Half | 700-MAX13430EEUB | 2 | 2,50€ | Goldo | MO_010 | Y | Y | Y | Y |
| Goldo | ARM Microcontrollers - MCU K60-1M | 841-MK63FN1M0VLQ12 | 1 | 11,53€ | Goldo | MO_010 | Y | Y | Y | Y |
| Goldo | Transformers Audio & Signal ISO MOD SMD GullWing Single 10/100BASE-TX | 493-TG110-S050N2LF | 1 | 4,81€ | Goldo | MO_010 | Y | Y | Y | Y |
| Goldo | Modular Connectors / Ethernet Connectors 10/100 FastJack RA TAB DOWN | 493-HFJ11-2450EL21RL | 2 | 9,67€ | Goldo | MO_010 | Y | Y | Y | Y |
| Clem | teensy | 485-199 | 0 | 0€ | Clem | MO_009 | O | O | O | O |
| Clem | eval brd alim bras robot | 595-TPS54531EVM-530 | 0 | 0€ | Clem | MO_009 | O | O | O | O |
| Raoul | carte de dev de goret | 511-NUCLEO-F446RE | 0 | 0€ | Clem | MO_009 | O | O | O | O |
| fredericD | Transistors bipolaires - BJT NPN Ampl/Switch | 610-2N1711 | 2 | 1,75 € | Clem | MO_009 | O | O | O | O |
| Eric | Quartz 153.6 KHz 12.5pF Cylinder shape Mfg ECSInc. ref ECS-1.536-12.5-13X | 520-ECS-153-12.5-13X | 2 | 0,695€ | Clem | MO_009 | O | O | O | O |
| Eric | Triax Jack Chassis coaxial connector 3 lugs Mfg : Pomona, ref 5219 ( 5 semaines de délai mais commander quand même la pièce, merci) | 565-5219 | 1 | 23,49€ | Clem | MO_009 | O | O | O | O |
| Eric | Precision Foil Resistor 0.1M Ohms 0.01% 2 PPM /°C Through hole Mfg : Vishay , ref Y0785100K000T9L | 71-S102JT-100K-L | 1 | 24,31€ | Clem | MO_009 | O | O | O | O |
| Eric | MOSFET Trans MOSFET P-CH 30V 3.5A Vgsth: 2.5 50mOhms ref " RRL035P03TR" Mfg : ROHM | 755-RRL035P03TR | 4 | 0,512€ | Clem | MO_009 | O | O | O | O |
| Eric | MOSFET Med Pwr, Sw MOSFET P Chan, 12V, 3A Vgsth: 1.5 144mOhms ref "RZF030P01TL" Mfg : ROHM | 755-RZF030P01TL | 2 | 0,64€ | Clem | MO_009 | O | O | O | O |
| Clem | condo cms low esr shield GSM | 74-592D228X96R3X2T | 1 | 6,92 € | <Acheteur> | DI_XXX | N | O | O | O |
| F6ITU+F1APY+F4HDA+F4GRX | transfo 1:1 4,5MHz-3GHz M/A Com | 937-ETC1-1-13TR | 4x10 | 1,55€ | <f6itu par défaut> | Mou002 | N | O | O | O |
| Jnat | Divers | Multiple | - | - | Jnat | [Mouser20121113] | N | O | O | O |
| Thomas | Carte dev MachXO2 | 1 | 25,34 | Thomas | panier http://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=902be54002 | N | O | O | O | |
| CydGy | transfo courant 1:1000 | 911-CT05-1000 | 1 | 4,02 € | Thomas | MO_002 | N | O | N | O |
| CydGy | transfo courant 1:500 | 553-CSE187LP | 1 | 3,74 € | Thomas | MO_002 | N | O | N | O |
| CydGy | transfo audio 1.2k:8 | 42TM003-RC | 1 | 2,30 € | Thomas | MO_002 | N | O | N | O |
| CydGy | microphone | 665-AOM6545PR | 1 | 0,726 € | Thomas | MO_002 | N | O | N | O |
| CydGy | microphone | 254-ECM96-RO | 1 | 1,66 € | Thomas | MO_002 | N | O | N | O |
| CydGy | HP speaker | 665-AST-03208MR-R | 1 | 2,17 € | Thomas | MO_002 | N | O | N | O |
| CydGy | HP speaker | 665-AST1732MR-R | 1 | 2,80 € | Thomas | MO_002 | N | O | N | O |
| CydGy | res 10m | 660-RK1/4DC1005F | 2 | 0,413 € | Thomas | MO_002 | N | O | N | O |
| Guillaume | CER RESONATOR 16.0MHZ SMD | [490-1198-1-ND] | 5 | 0,41 € | Thomas | MO_002 | N | O | O | O |
| Guillaume | Regulateur CMS 3.3V | [579-MCP1824T-3302EOT] | 5 | 0,43€ | Thomas | MO_002 | N | O | O | O |
| Axone | Supports CI et composants 28P | 571-1-390261-9 | 2 | 0.31€ | Thomas | MO_002 | N | O | O | O |
| Axone | Quartz 16MHz 20pF | 73-XT49S1600-20 | 2 | 0.404€ | Thomas | MO_002 | N | O | O | O |
| Axone | Capteur température LM35 | 926-LM335AZ/NOPB | 3 | 1.24€ | Thomas | MO_002 | N | O | O | O |
| Yann | Cable FFC/FPC 16p 1mm 20cm | 538-21039-0325 | 1 | 4.49€ | Thomas | MO_002 | N | O | O | O |
| Yann | Socket USB-A SMT | 649-87583-2010BLF | 1 | 0.58€ | Thomas | MO_002 | N | O | O | O |
| Yann | Cable USB | 538-88732-8702 | 2 | 1.69€ | Thomas | MO_002 | N | O | O | O |
| Yann | Kit de dev EXP430F5529 | 595-MSPEXP430F5529LP | 1 | 12.57€ | Thomas | MO_002 | N | O | O | O |
| Lab | Circuit Intégré BTS3408GXUMA2 SOT8 marque : Infineon | 726-BTS3408GXUMA2 | 2 | 1,73€ | Ellyan | MO_003 | N | O | N | N |
| Clem/lab | switch glissiere smd spdt cms | 688-SSSS810701 | 25 | 0,128 € | Ellyan | MO_003 | O | O | O | O |
| Eric | Circuit Intégré BTS3408GXUMA2 SOT8 marque : Infineon | 726-BTS3408GXUMA2 | 2 | 1,73€ | Ellyan | MO_003 | N | O | O | O |
| Guillaume | Connecteurs HDMI FCI | [649-10029449-002TLF] | 1 | 0.899€ | Ellyan | MO_003 | N | O | N | N |
| CDR2014 | Résistances détection de courant - CMS 0.010ohms 1% | 652-CRA2512FZR010ELF | 1 | 0,48€ | Ellyan | MO_003 | N | O | N | N |
| Eric | CI PI TNY254PN DIP8 | 869-TNY254PN | 3 | 1,36 | Ellyan | MO_003 | N | O | O | O |
| Ellyan | Convertisseur 48V=12V CC3-4812SF-E | 967-CC3-4812SF-E | 1 | 8,97€ | Ellyan | MO_003 | O | O | O | N |
| Ellyan | Alimentation Mean Well SP240-48 | 709-SP240-48 | 1 | 65,08€ | Ellyan | MO_003 | O | O | O | N |
| Julien Len | NXP Semiconductors SC18IS602BIPW,128 | 771-SC18IS602BIPW128 | 10 | 18 | Clement | MO_004 | N | O | N | N |
| Goldo | Convertisseur 24V=12V CC10-2412SF-E | 967-CC10-2412SF-E | 1 | 21,01€ | Clement | MO_004 | O | O | O | O |
| Tom Magnier | ?? | 941-CLM3AWKWCWAXA153 | 6 | ?€ | Clement | MO_004 | O | O | O | O |
| Tom Magnier | ?? | 941-XQBAWT020000L051 | 6 | ?€ | Clement | MO_004 | O | O | O | O |
| Théotime | ?? | 692-Z84C0006PEG | 1 | 3.31€ | Clement | MO_004 | O | O | O | O |
| Clement | module bluetooth audio/data | 765-RN52-I/RM | 2 | 18,64€ | Clement | MO_004 | X | O | O | O |
| Clement | Ecran 1.44" | 971-LCD-144-G2 | 1 | 27.10€ | Clement | MO_004 | X | O | O | O |
| Laurent | Ampli Op instrumentation | 584-AD623ANZ | 4 | 3.79€ | 3dsman | MO_005 | N | O | N | N |
| Laurent | Diodes | 512-1N4004 | 10 | 0,097€ | 3dsman | MO_005 | N | O | N | N |
| Dom | Jack Switchcraft S12B / Connecteurs téléphoniques 3 CONDUCTOR .210"ID | 502-S-12B | 4 | 2,95 € | 3dsman | MO_005 | N | O | N | N |
| Raoul&3dsman | STM32F0 nucleo board | 511-NUCLEO-F030R8 | 2 | 8,26 € | 3dsman | MO_005 | O | O | N | N |
| Thomas | connecteur mezzanine | 649-61083-102402LF | 2 | 4.69 € | 3dsman | MO_005 | O | O | N | N |
| Thomas | quartz 16MHz | 732-TX325-16F18X-AC3 | 10 | 0.40 € | 3dsman | MO_005 | O | O | N | N |
| Thomas | logement molex | 538-22-01-2035 | 20 | 0.148 € | 3dsman | MO_005 | O | O | N | N |
| Thomas | pin à sertir molex | 538-08-50-0136 | 100 | 0.045 € | 3dsman | MO_005 | O | O | N | N |
| Thomas | capteur de couleur | 856-TCS34717FN | 1 | 2.04 € | 3dsman | MO_005 | O | O | N | N |
| Thomas | IMU 9 axes | 511-LSM9DS0TR | 1 | 7.65 € | 3dsman | MO_005 | O | O | O | O |
| Thomas | capteur de pression | 262-BMP183 | 1 | 2.34 € | 3dsman | MO_005 | O | O | O | O |
| Thomas | capteur de pression | 511-LPS25HTR | 1 | 3.78 € | 3dsman | MO_005 | O | O | O | O |
| Thomas | connecteur hermaphrodite | 649-10106813034112LF | 3 | 1.10 € | 3dsman | MO_005 | O | O | O | O |
| Théotime | EEPROM 64Kbit | 556-AT28C64B15PU | 1 | 3,73 € | 3dsman | MO_005 | O | O | O | O |
| Théotime | SRAM 256 Kbit | 913-AS6C62256-55PCN | 1 | 1,43 € | 3dsman | MO_005 | O | O | O | O |
| Théotime | Clock Oscillator 4MHz | 815-ACO-4-EK | 1 | 1,61 € | 3dsman | MO_005 | O | O | O | O |
| Théotime | Clock Oscillator 6MHz | 520-TCF600-X | 1 | 1,50 € | 3dsman | MO_005 | O | O | O | O |
| Théotime | z80 CPU | 692-Z84C0006PEG | 1 | 3,31 € | 3dsman | MO_005 | O | O | O | O |
| Raoul | Shunt mirror | 522-ZXCT1009FTA | 5 | 0,82 € | 3dsman | MO_005 | N | 0 | N | N |
| Raoul | Temp sensor | 579-MCP9701AT-E/TT | 5 | 0,27 € | 3dsman | MO_005 | N | O | N | N |
| Raoul | STM32F030K6T6 | 511-STM32F030K6T6 | 10 | 1,00 € | 3dsman | MO_005 | N | O | N | N |
| Raoul | STM32F030C8T6 | 511-STM32F030C8T6 | 2 | 1,70 € | 3dsman | MO_005 | N | O | N | N |
| Théotime | SMD Clock Oscillator | 815-ASV-50-EJ-T | 1 | 2,01 € | 3dsman | MO_005 | N | O | N | N |
| Clement | module wifi cc3000 | 741-450-0067 | 1 | 22,29€ | <acheteur> | MO_006 | N | N | N | N |
| Clement | module Ecran nokia 3310 84x84 pixel B&W | 909-MOD-LCD3310 | 1 | 7,63€ | <acheteur> | MO_006 | N | N | N | N |
| Clement | cable prog 4D systems | 971-4D-PROGM-CABLE | 1 | 17,03 € | <acheteur> | MO_006 | N | N | N | N |
| Clement | atmega32u4 tqfp-44 | 556-ATMEGA32U4-AU | 25 | 3,14 € | <acheteur> | MO_006 | N | N | N | N |
| Clément | Cypress Semiconductor Cartes et kits de développement - ARM PSoC 4200 Prototyping Kit | 727-CY8CKIT-049-42XX | 1 | 3,20 € | <acheteur> | MO_006 | N | N | N | N |
| Clément | Cypress Semiconductor Cartes et kits de développement - ARM PSoC 4100 Prototyping Kit | 727-CY8CKIT-049-41XX | 1 | 3,20 € | <acheteur> | MO_006 | N | N | N | N |
| Clément | Connecteur audio 1/8" vertical 5 point | 523-ACJS-MV35-5 | 10 | 1.06 € | <acheteur> | MO_006 | N | N | N | N |
| Clément | ampli audio casque | 595-TPA6112A2DGQR | 10 | 1,31 € | <acheteur> | MO_006 | N | N | N | N |
| Thomas & Raoul | capteur de couleur | 985-TCS34725FN | 3 | 2.18 € | <acheteur> | MO_006 | N | N | N | N |
| Karol Alexander | XP2 Brevia Dev Kit | 842-LFXP2-5E-B2-EVN | 1 | 34,40 € | Goldo | MO_007 | O | O | O | O |
| Marc | Flip Flop UHF | 998-SY10EP52VZG | 2 | 4,08 € | Goldo | MO_007 | N | O | N | N |
| Goldo | Modules Zigbee / 802.15.4 2.4Ghz Xbee 256000 BAUD | 888-XB24-AWI-001 | 2 | 15,20 € | Goldo | MO_007 | O | O | O | O |
| Goldo | Prises et adaptateurs XBEE Adapter Board | 619-32403 | 2 | 3,19 € | Goldo | MO_007 | O | O | O | O |
| Thomas | Eeprom i2c | 579-24LC08BT-I/OT | 2 | 0,232 € | Goldo | MO_007 | O | O | O | O |
| Thomas | Capteur de distance | 511-VL6180XV0NR/1 | 2 | 5 € | Goldo | MO_007 | O | O | O | O |
| Thomas | connecteur carte sim | 649-7111S2015X02LF | 2 | 1.09 € | Goldo | MO_007 | O | O | O | O |
| Thomas | Pin de connection | 575-0577043802127100 | 20 | 0,274 € | Goldo | MO_007 | O | O | O | O |
| Thomas | condensateur 4,7uF | 963-EMK212B7475KG-T | 100 | 0,055 € | Goldo | MO_007 | O | O | O | O |
| Dom | Connecteurs téléphoniques 1/4" OPEN FRAME JACK MONO NICKEL | 568-NYS229-U | 4 | 0,712 € | Goldo | MO_007 | O | O | O | N |
| Dom | Connecteurs téléphoniques 3 CONDUCTOR .210"ID | 502-S-12B | 4 | 2.95 € | Goldo | MO_007 | O | O | O | N |
| Théotime | ATtiny85 | 556-ATTINY85-20PU | 27 | 0,882 € | Pilou | MO_008 | O | O | O | O |
| Théotime | 6502 | 955-W65C02S6TPG-14 | 2 | 6,01 € | Pilou | MO_008 | O | O | O | O |
| Clem | ATtiny85 | 556-ATTINY85-20PU | 25 | 0,882 € | Pilou | MO_008 | O | O | O | O |
| Clem | HV833MG-G Display Drivers & Controllers HVCMOS | 689-HV833MG-G | 25 | 0,995 € | Pilou | MO_008 | O | O | O | O |
| Clem | Murata Fixed Inductors 220uH 10% | 81-LQH43MN221K03L | 25 | 0,317 € | Pilou | MO_008 | O | O | O | O |
| Clem | Fixed Inductors 560uH 10% | 81-LQH43MN561K03L | 10 | 0,317 € | Pilou | MO_008 | O | O | O | O |
| Clem | Fixed Inductors 100uH 10% | 81-LQH43MN101K03L | 10 | 0,317 € | Pilou | MO_008 | O | O | O | O |
| Thomas | capteur de pression | 262-BMP280 | 1 | 2.45 € | Pilou | MO_008 | O | O | O | O |
| Thomas | capteur de pression | 511-LPS331APTR | 1 | 3.56 € | Pilou | MO_008 | O | O | O | O |
| Thomas | IMU 9 axes | 511-LSM9DS0TR | 1 | 8.27 € | Pilou | MO_008 | O | O | O | O |
| Thomas | IMU 9 axes | 262-BMX055 | 1 | 5.86 € | Pilou | MO_008 | O | O | O | O |
| Thomas | accelerometre 3 axes 400g | 511-H3LIS331DLTR | 1 | 9.0 € | Pilou | MO_008 | O | O | O | O |
| Thomas | gyro 3 axes automotive | 511-A3G4250DTR | 1 | 11.97 € | Pilou | MO_008 | O | O | O | O |
| Thomas | condensateur 4.7uF | 810-C1005X5R0J475M | 10 | 0.242 € | Pilou | MO_008 | O | O | O | O |
| Thomas | condensateur 4.7uF | GRM188R60J475KE19D | 100 | 0.025 € | Pilou | MO_008 | O | O | O | O |
| Thomas | condensateur 0.22uF | CGA3E2X7R1C224K080AA | 100 | 0.059 € | Pilou | MO_008 | O | O | O | O |
| Thomas | resistance 100k | 660-RK73H1ETTP1003F | 100 | 0.005 € | Pilou | MO_008 | O | O | O | O |
| Thomas | resistance 49.9k | 660-RK73H1ETTP4992F | 100 | 0.005 € | Pilou | MO_008 | O | O | O | O |
| Pilou | Fer à souder Weller Chisel Tip RT3 | 578-RT3 | 1 | 29.58 € | Pilou | MO_008 | O | O | O | O |
| Pierre Grommit | Philips Lumileds L235-3580AHLCBAAC0 | 997-35-3580AHLCBAAC0 | 1 | 11.77 € | Pilou | MO_008 | O | O | O | O |
Motedis France
Naviguer vers la page des commandes Motedis France en cours
| Demandeur | Description | Ref Motedis | Quantité | Prix unitaire | Acheteur | Commande n° | Payé d'avance (O/N) | Commandé (O/N) | Distribué (O/N) | Remboursé/Archive (O/N) |
| <demandeur_archive> | <description_archive> | <ref motedis_archive> | <quantité_archive> | <prix_archive> | <acheteur_archive> | MS_001 | N | N | N | N |
Nouvelle Plastique
Naviguer vers la page des commandes Nouvelle Plastique en cours
Olimex
Naviguer vers la page des commandes Olimex en cours
Otelo
Naviguer vers la page des commandes Otelo en cours
Radiospares
| Demandeur | Description | Ref RS | Quantité | Prix unitaire | Acheteur | Commande n° | Payé d'avance (O/N) | Commandé (O/N) | Distribué (O/N) | Remboursé/Archive (O/N) |
| Pilou | Lot de 10 RESSORTS 28MM | 751-528 | 1 | 2,99€ | RS_001 | N | O | O | O | |
| Eric | Clé réglable à mâchoires extra fines 8" marque Bahco ref 9031-T | 710-8798 | 1 | 31,23€HT | RS_001 | N | O | O | O | |
| Lab | Lot de 5 résistance 1% 1W 10R SFERNICE | 123-162 | 2 | 2.784€HT | Yannick | RS_001 | N | O | O | ? |
| Lab | lot de 4 filtres ref T0058711718 pour station à dessouder Weller | 358-9483 | 1 | 24,10€HT | <Yannick> | RS_002 | N | O | O | ? |
| Eric | lot de 4 filtres ref T0058711718 pour station à dessouder Weller | 358-9483 | 1 | 24,10€HT | <Patrick> | RS_003 | N | O | O | O |
| Gérard | Lot de 100 contacts à sertir Connecteur Molex 3,96mm AWG 22-28 | [1] 245-4718 | 1 | 7,50€HT | <Patrick> | RS_003 | N | O | O | O |
| Michel | contacts a sertir Molex 2,54mm AWG 22-28 | 720-6646 | 300 | 0,052 | <Patrick> | RS_003 | N | O | O | O |
| Michel | Embases Molex droites 2b 2,54 | 679-5515 | 30 | 0,31 | <Patrick> | RS_003 | N | O | O | O |
| Michel | Embases Molex coudées 2b 2,54 | 173-2916 | 20 | 0,726 | <Patrick> | RS_003 | N | O | O | O |
| Michel | Embases Molex coudées 4b 2,54 | 173-2944 | 10 | 1,02 | <Patrick> | RS_003 | N | O | O | O |
| Michel | Boitiers Molex 2b 2,54 | 687-7890 | 100 | 0,044 | <Patrick> | RS_003 | N | O | O | O |
| Michel | Boitiers Molex 4b 2,54 | 687-7900 | 20 | 0,233 | <Patrick> | RS_003 | N | O | O | O |
| Patrick | Pile CR2016 | 457-4735 | 2 | 2,19 | <Patrick> | RS_003 | N | O | O | O |
| Patrick | Pile CR2032 | 457-4757 | 2 | 2,19 | <Patrick> | RS_003 | N | O | O | O |
| Patrick | 5 Piles montre SR66 | 514-7766 | 1 | 2,29 | <Patrick> | RS_003 | N | O | O | O |
| Patrick | 5 Piles montre SR59 | 514-7744 | 1 | 4,40 | <Patrick> | RS_003 | N | O | O | O |
| Patrick | 5 Piles montre SR41 | 593-401 | 2 | 10,51 | <Patrick> | RS_003 | N | O | O | O |
| Eric | CI STM L4981B | 189-1144 | 2 | 2,15 | <Patrick> | RS_003 | N | O | O | O |
| Eric | Condensateur alu Nichicon 50V 1uF radial ESR:2Ohms ref UBT1H010MPD8 | 762-1727 | 10 (UDV) | 0,384 | <Patrick> | RS_003 | N | O | O | O |
| Eric | Condensateur alu Nichicon 25V 220uF radial ESR:0,1Ohms ref UBT1E221MPD8 | 762-1682 | 5 (UDV) | 0,85 | <Patrick> | RS_003 | N | O | O | O |
| Eric | Condensateur alu Nichicon 50V 2,2uF radial ESR:1,8Ohms ref UBT1H2R2MPD8 | 762-1720 | 5 (UDV) | 0,518 | <Patrick> | RS_003 | N | O | O | O |
| Eric | Condensateur alu Panasonic 450V 10uF radial Ref EEUEE2W100 | 699-7569 | 5 (UDV) | 0,786 | <Patrick> | RS_003 | N | O | O | O |
| Lab | Condensateur MKT Vishay 0.1uF 275VCA "X2" ref F1772-410-2200-E3 | 148-474 | 20 (UDV) | 0,657 | <Patrick> | RS_003 | N | O | O | O |
| Lab | Condensateur PET Kemet 10nF 220 V c.a., 630 V c.c. 4 x 9 x 13mm ref R60PF2100AA30J | 824-351 | 5(UDV) | 0,418 | <Patrick> | RS_003 | N | O | O | O |
| Patrick | Axial AL cap, 4700uF, 25V | 707-6708 | 2(UDV) | 2,42 | <Patrick> | RS_003 | N | O | O | O |
| Patrick | Perchlorure de fer en granulé (delai 14 jours mini 50€ H.T.) | 2550514751 | 1(UDV) | 4,2 | <Patrick> | RS_004 | N | O | O | O |
| Patrick | lot 2 piles 12V A23 Duracel | 717-4029 | 6 | 3,21 | <Patrick> | RS_003 | N | O | O | O |
| Lab | lot 5 languettes Kapton fer dessouder Weller ref T0051361699 | 176-1829 | 1 | 10,70 | <Patrick> | RS_003 | N | O | O | O |
| Lab | DS114 buse de dessoudage 3, 3 - 1,8mm Weller ref T0051351499 | 517-621 | 2 | 9,80 | <Patrick> | RS_003 | N | O | O | O |
| Eric | DS114 buse de dessoudage 3, 3 - 1,8mm Weller ref T0051351499 | 517-621 | 1 | 9,80 | <Patrick> | RS_003 | N | O | O | O |
| Lab | CI MOC3020 | 761-3388 | 10 (UDV) | 0,616 | <Patrick> | RS_004 | N | O | O | N |
| Eric | DS119 aiguille d'aspiration Weller ref T0051352700 | 2550520811 | 1 | 9,00 | <Patrick> | RS_004 | N | O | O | O |
| Eric | DS BUSE DE CALIBRAGE Weller ref T0052474999 | 2550520910 | 1 | 6,10 | <Patrick> | RS_004 | N | O | O | O |
| Lab | lot de 5 ressorts pour filtres ref T0058711720 pour station à dessouder Weller | 2550521588 (delai 21 jours mini 50€ H.T.) | 1 | 5,50€HT | <Patrick> | RS_004 | N | O | O | O |
| Eric | Bouchon fileté de filtre ref T0058711719 pour station à dessouder Weller | 2550521587 (delai 21 jours mini 50€ H.T.) | 1 | 4€HT | <Patrick> | RS_004 | N | O | O | O |
| Eric | Lot de 5 joints pour bouchon fileté de filtre ref T0051344499 pour station à dessouder Weller | 2550520804 (delai 21 jours mini 50€ H.T.) | 1 | 4,20€HT | <Patrick> | RS_004 | N | O | O | O |
| Lab | FORETS DE RECHANGE STANDARD 0,6 mm / 0,9 mm / 1,4 mm / 1,9 mm pour outil de nettoyage Weller ref T0051350199 | 2550520805 (delai 21 jours mini 50€ H.T.) | 1 | 15,10 | <Patrick> | RS_004 | N | O | O | N |
| Eric | Fusible cartouche 6.3mm x 32 mm 12A FF | 420-224 | 10 | 1,502 | Raoul | RS_005 | N | O | O | O |
| Eric | Fusible cartouche 6.3mm x 32 mm 15A T | 668-6095 | 10 | 0.248 | Raoul | RS_005 | N | O | O | O |
| Eric | Thermocouple type K en fibre de verre lg : 2m -50°C +1100°C | 621-2170 | 1 | 7.16 | Raoul | RS_005 | N | O | O | O |
| Eric | CI BQ2954 | 662-2319 | 2 | 3,88 | Raoul | RS_005 | N | O | O | O |
| Lab | GAINE THERMO 2.4MM recharge 10m | 170-6030 | 1 | 17.00 | Raoul | RS_005 | N | O | O | N |
| Lab | GAINE THERMO 1.6MM recharge 10m | 170-6024 | 1 | 17.00 | Raoul | RS_005 | N | O | O | N |
| Lab | GAINE THERMO 6,4MM recharge 8m | 170-6074 | 1 | 17.00 | Raoul | RS_005 | N | O | O | N |
| Patrick | DS1307 | 761-9759 | 2 | 2.92 | Raoul | RS_005 | N | O | O | O |
| Patrick | 74LS132 | 663-2401 | 5 | 0.526 | Raoul | RS_005 | N | O | O | O |
| Patrick | 74HC125 | 113-0528 | 5 | 0.20 | Raoul | RS_005 | N | O | O | O |
| Florent | Cosse à sertir robuste M6, fil 10mm² | 531-021 | 50 | 0.248 | Raoul | RS_006 | N | O | N | N |
| Thomas | Seringue pate à braser | 551-693 | 1 | 22,13 | RS_006 | N | N | N | N | |
| Thomas | Convertisseur CC/CC, 9-36V entrée, 5V | 733-1878 | 1 | 42.90 | Raoul | RS_006 | N | O | N | N |
| Goldo | Crochets Velcro Autoagrippants noirs 5m | 549-921 | 1 | 10.34 | Raoul | RS_006 | N | O | N | N |
| Goldo | Boucles Velcro Autoagrippants noirs 5m | 549-937 | 1 | 10.34 | Raoul | RS_006 | N | O | N | N |
| MAZ24 | boitiers Molex | 687-7890 | 30 | 0,04 | Raoul | RS_006 | N | O | N | N |
| MAZ24 | contacts Molex | 720-6643 | 300 | 0,02 | Raoul | RS_006 | N | O | N | N |
| MAZ24 | Embase 2 contacts Molex | 687-7269 | 30 | 0,326 | Raoul | RS_006 | N | O | N | N |
| Raoul | Alim dc/dc 12V 25W | 183-893 | 1 | 43.20 | Raoul | RS_006 | N | O | N | N |
| Lab | lot 5 languettes Kapton fer dessouder Weller ref T0051361699 [Eric en prend 3/5] | 176-1829 | 1 | 12,30€HT | Dom | RS_007 | N | O | O | N |
| Lab | lot 4 tubes verre fer dessouder Weller ref T0051360599 [Eric en prend 2/4] | 517-671 | 1 | 16.70€HT | Dom | RS_007 | N | O | O | N |
| Lab | TEXAS SG3524 PDIP16 | 428-521 | 10 | 0.62€HT | Dom | RS_007 | N | O | O | N |
| Eric | TEXAS SG3524 PDIP16 | 428-521 | 4 | 0.62€HT | Dom | RS_007 | N | O | O | O |
| Pat | Thermistance 10k +-5% -55/150°C -4,6%/°C | 697-4465 | 20 | 0,126 HT | Dom | RS_007 | N | O | O | O |
| Pat | Thermistance 10k +-0,9% -80/150°C -4,5%/°C | 151-237 | 10 | 1,91 HT | Dom | RS_007 | N | O | O | O |
| Pat | Thermistance 10k +-3% -55/150°C -4,5%/°C | 697-4562 | 10 | 0,95 HT | Dom | RS_007 | N | O | O | O |
| Goldo | Blindage digi international xbee zigbee | 696-1670 | 2 | 13,07 HT | Dom | RS_007 | N | O | O | O |
| Goldo | Module zigbee XB24-Z7SIT-004 | 667-3008 | 1 | 21,78 HT | Dom | RS_007 | N | O | O | O |
| FredericD | Positiv 20 | 173-886 | 1 | 17.82 HT | Dom | RS_007 | N | O | O | O |
| Eric | Boite de 200 bouchons d'oreille Marque 3M modèle 1100 | 190-5877 | 1 | 27.00€HT | Dom | RS_008 | N | O | O | O |
| Eric | Réfrigérant RS Aérosol 400 ml, -50°C | 846-682 | 1 | 11.53€HT | Dom | RS_008 | N | O | O | O |
| Eric | Curtis 701PR0512D0512A | 188-4411 | 1 | 34.57€HT | Dom | RS_008 | N | O | O | O |
| Eric | Douille, Bi-Hexagone, 13mm Carré 1/4" STAHLVILLE Ref# 01030013 (17,8/17,8mm) | 778-2364 | 1 | 7.20€HT | Dom | RS_008 | N | O | O | O |
| Antoine | MCP2515-I/P PDIP | 628-3532 | 1 | 1.63€ HT | Dom | RS_008 | N | O | O | O |
| Antoine | MCP2551-I/P PDIP | 402-920 | 5 | 0.924€ HT | Dom | RS_008 | N | O | O | O |
| Léo | Relais Statique CI | 476-652 | 1 | 9.61€ HT | Dom | RS_008 | N | O | O | O |
| Lab (Eric) | Réfrigérant RS Aérosol 400 ml, -50°C à faible charge statique | 132-520 | 2 | 16.09€ HT | Dom | RS_009 | N | O | O | O |
| Eric | Broche pour clés 91A - 92A - 97 ref fabricant #160A.1 | 2550366899 | 1 | 12.98€ HT | Dom | RS_009 | N | O | N | N |
| Eric | Tore R58 EPCOS 60.1 x 39.2 x 18.8mm AL5400 Mat:N30 ref B64290L40X830 | 212-0803 | 1 | 9.28€ HT | Dom | RS_009 | N | O | O | O |
| Eric | connector RF coaxial N crimp plug for RG316 double braid,50ohm Amphenol Réf 172171 | 2508406399 | 2 | 10.15€ HT | Dom | RS_009 | N | O | O | O |
| Dom | RS_009 | N | O | O | O | |||||
| Eric | CCO LTC1799CS5#TRMPBF SOT-5 | 506-1410 | 2 | 3.61€ HT | Dom | RS_009 | N | O | O | O |
| MrPozor | Support DIL ASSMANN WSW 8 contacts | 674-2435 | 20 | 0.059€ HT | Dom | RS_009 | N | O | O | O |
| MrPozor | Support DIL ASSMANN WSW 16 contacts | 674-2432 | 20 | 0.099€ HT | Dom | RS_009 | N | O | O | O |
| MrPozor | Support DIL ASSMANN WSW 18 contacts | 674-2441 | 20 | 0.107€ HT | Dom | RS_009 | N | O | O | O |
| MrPozor | Support DIL ASSMANN WSW 20 contacts | 674-2444 | 20 | 0.129€ HT | Dom | RS_009 | N | O | O | O |
| MrPozor | Support DIL ASSMANN WSW 24 contacts | 674-2448 | 20 | 0.14€ HT | Dom | RS_009 | N | O | O | O |
| Nicolas M. | Transistor MOSFET FQPF5N50CYDTU | 862-8779 | 10 | 0.807€ HT | Dom | RS_009 | N | O | O | O |
| Nicolas M. | Fusible CMS 0,5A | 852-7247 | 1 | 0.35€ HT | Dom | RS_009 | N | O | O | O |
| Lab (Eric) | Gaine tressée, RS, Diam 10mm, en Fibre de verre Naturel, 5m | 668-1242 | 1 | 13.76€HT | Dom | RS_009 | N | O | O | O |
| Lab (Eric) | Gaine tressée, RS, Diam 8mm, en Fibre de verre Naturel, 5m | 668-1248 | 1 | 8.04€HT | Dom | RS_009 | N | O | O | O |
| Lab (Eric) | Gaine tressée, RS, Diam 6mm, en Fibre de verre Naturel, 5m | 668-1245 | 1 | 7.31€HT | Dom | RS_009 | N | O | O | O |
| Lab (Eric) | Gaine de câble, FAVIER, Diam 4mm, en Fibre de verre Rouge | 137-2362 | 6 | 0,64€HT | Dom | RS_009 | N | O | O | O |
| Steve | Module USB-UART UMFT230XB-01 | 757-0067 | 1 | 9.10€ HT | Dom | RS_009 | N | O | O | O |
| Steve | HP Visaton 8ohm 2W | 431-8658 | 2 | 2.81€ HT | Dom | RS_009 | N | O | O | O |
| MrPozor | Support DIL ASSMANN WSW 14 contacts | 674-2438 | 20 | 0.099€ HT | Dom | RS_010 | N | O | O | O |
| Eric | Clé à molette, Ouverture 46.5mm, Long. 270 mm Alliage d'acier, marque BAHCO | 763-0863 | 1 | 32,96€ HT | Dom | RS_010 | N | O | O | O |
| Eric | Moteur CC Como Drills, 6 → 15 V ref 719RE385 | 238-9737 | 2 | 6.79€ HT | Dom | RS_010 | N | O | O | O |
| Axone | Antennes 868MHz SMA | 542-563 | 2 | 4.42€ HT | Dom | RS_010 | N | O | O | O |
| Axone | LM317 | 516-6240 | 10 | 0.41€ HT | Dom | RS_010 | N | O | O | O |
| Axone | Cartes à matrice | 206-8648 | 2 | 4.90€ HT | Dom | RS_010 | N | O | O | O |
| Lab | Vis de verouillage | 673-4945 | 40 | 14.16€ HT | Dom | RS_010 | N | O | O | O |
| Nico R. p4r4d0x86 | Condensateur électrolytique aluminium 4,7μF | 751-1134 | 1 lot de 5 | 0,36 * 5 € HT | Dom | RS_010 | N | O | O | O |
| Nico R. p4r4d0x86 | Résistance à film mince 4,7Ω | 267-1698 | 1 lot de 10 | 0,113 * 10 € HT | Dom | RS_010 | N | O | O | O |
| Nico R. p4r4d0x86 | Diode traversante, 1A, 800V, UF4006-E3/73 | 628-9990 | 1 lot de 10 | 0,306 * 10 € HT | Dom | RS_010 | N | O | O | O |
| papy F1CHF | LM2576CT | 533-8108 | 1 | 2,55€ | Dom | RS_010 | N | O | O | O |
| Nicolas M. | Condensateurs 680µF 35V 105°C | 840-4911 | 5 | 0,57€ HT | Dom | RS_010 | N | O | O | O |
| Nicolas M. | Câble HDMI 2m | 616-2362 | 2 | 2,82€ HT | Dom | RS_010 | N | O | O | O |
Saint Quentin radio
Selectronic
| Lab | foret Hss-Co 3,2 mm | 9773-1 | 1 | 2,70€TTC | F4GRX | SE_001 | N | O | O | O |
| Lab | lot de 10 forets Hss 1 mm | 12.1820-10 | 1 | 8,50€TTC | F4GRX | SE_001 | N | O | O | O |
| Lab | lot 2 tournevis pour borniers | 12.9706 | 1 | 24,90€TTC | F4GRX | SE_001 | N | O | O | O |
| Eric | Embout TORX T8x25mm - Lot de 2 | 7075-23 | 1 | 2,90€TTC | F4GRX | SE_001 | O | O | O | O |
| Eric | Embout TORX T9x25mm - Lot de 2 | 7075-24 | 1 | 2,90€TTC | F4GRX | SE_001 | O | O | O | O |
| Eric | Condensateur électrochimique polarisé sortie radiale - 2,2µF 400V | 6495 | 3 | 0,80€TTC | F4GRX | SE_001 | O | O | O | O |
| Eric | Condensateur électrochimique polarisé sortie radiale - 10µF 400V | 1792-1 | 2 | 1,35€TTC | F4GRX | SE_001 | O | O | O | O |
| Eric | Condensateur électrochimique polarisé sortie radiale - 22µF 400V | 1792-3 | 1 | 2,70€TTC | F4GRX | SE_001 | O | O | O | O |
| Eric | Condensateur électrochimique polarisé sortie radiale - 47µF 400V | 1792-4 | 1 | 3,30€TTC | F4GRX | SE_001 | O | O | O | O |
| Lab | Condensateur électrochimique polarisé sortie radiale - 22µF - 50V - Lot de 2 | 9296-2 | 1 | 0,70€TTC | F4GRX | SE_001 | N | O | O | O |
| Lab | Lot de 10 fusibles 200mAT | 13.9795-10 | 1 | 2.20€TTC | Ellyan | SE_002 | N | O | O | O |
| Lab | Lot de 10 fusibles 2AT | 13.9705-10 | 1 | 1.70€TTC | Ellyan | SE_002 | N | O | O | O |
| Lab | Résistance couche métal 1% 40,2 ohm 0,6 W traversante | 4764 | 6 | 0,35€TTC | Pilou | SE_003 | N | O | O | O |
| Lab | Résistance de précision 1% à couche métallique de 10,00 ohm 0,6 W traversante | 4705 | 3 | 0,35€TTC | Pilou | SE_003 | N | O | O | O |
| Lab | Bouton 10mm Gris/grise | 13.0006 | 15 | 2.00€TTC | Pilou | SE_003 | N | O | O | O |
| Eric | Résistance cémentée - 10W - 39Ω | 1499-20 | 1 | 1,35€TTC | Pilou | SE_003 | N | O | O | O |
| Ellyan | Borne de service | 13.0902-12 | 1 | 2.00€TTC | Pilou | SE_003 | N | O | O | O |
| Ellyan | convertisseur SATA | 13.0669-9 | 2 | 8.50€TTC | Pilou | SE_003 | N | O | O | O |
| Lab | Pince à sertir (scrounches) | 13.5546.3 | 1 | Pilou | <plus vendu par selectronic> | N | N | N | O | |
| Lab | Bouchons/capuchons SEULS pour Bouton 10mm Gris/grise REF 13.0006 | <pas vendu par selectronic> | 6 | Pilou | N | O | N | O | ||
| Lab | voir aussi ce produit (bouton gris, bouchon bleu) qui convient mieux aux Hameg | 0004 ? ou 13.0004 <pas disponible> | 20 | 2.00€TTC | <acheteur> | SE_004 | N | N | N | O |
| Lab | SELECTRONIC ZD - Fer de rechange 24V 48W | 2130-5 | 2 | 13,90€TTC | Eric | SE_005 | N | O( | O | N |
| Lab | Bouton 10mm Gris/grise | 13.0006 | 7 | 2.00€TTC | Eric | SE_005 | N | O | O | N |
| Lab | Bouton alu. axe 6mm Diam. 29x14mm argent | 6087-4 | 1 | 1.84€TTC promo | Eric | SE_005 | N | O | O | N |
| Eric | Ajustable horizontal 10mm piste Cermet 2,2 kohm PIHER monotour | 3140 | 2 | 1.15€TTC | Eric | SE_005 | N | O | O | O |
| Eric | Ajustable horizontal 10mm piste Cermet 10 kohm PIHER monotour | 3136 | 2 | 1.15€TTC | Eric | SE_005 | N | O | O | O |
| Eric | Transformateur TOKO 707 VX -A043YUK compatible LM1893 | 7294 | 5 | 1.14€TTC promo | Eric | SE_005 | N | O | O | O |
| Eric | Thermistance CTN 4,7 kohm | 5276 | 4 | 0.90€TTC | Pilou | SE_006 | N | O | O | O |
| Eric | Varistance 275VRMS / 4000A 275 LA 40 diam 24mm | 9091 | 4 | 1.25€TTC | Pilou | SE_006 | N | O | O | O |
| Eric | Résistance cémentée - 20W - 47Ω | 1498-21 | 4 | 1.60€TTC | Eric | SE_007 | O | O | O | O |
SparkFun Electronics
