Projets:Perso:2013:PlatineAvrUSB
Revision as of 10:04, 7 April 2013 by Jnat (Talk | contribs)
Platine de test AVRUSB
Auteur Jnat
Date de proposition 20/02/2012
Tags du projet usbhid;
Lieu d'utilisation final @Work/Home
Utilisateur final Tout le monde
Projet personnel de Jnat
Projet Platine de test AVRUSB
  • Emulation en BitBanging de périphériques USB
  • Basé sur chipset AVR
  • USBHID
Platine AVRUSB
Vue d'ensemble
Solution choisie
J'ai opté pour le montage qui utilise des diodes Zener a l'envers pour abaisser la tension du bus usb a 3.3v.
"Instead of reducing the AVR's power supply, we can limit the output voltage on D+ and D- with Zener diodes. We recommend 3.6 V low power types, those that look like 1N4148 (usually 500 mW or less). Low power types are required because they have less capacitance and thus cause less distortion on the data lines. And 3.6 V is better than 3.3 V because 3.3 V diodes yield only ca. 2.7 V in conjunction with an 1.5 kΩ (or more exactly 10 kΩ) pull-up resistor. With 3.3 V diodes, the device may not be detected reliably."
En gros il vous faut deux diodes zener 3.6v 0.5W
Schema du montage
PCB sous kicad
