Projets:Perso:2013:AutomaticCatFeeder
Revision as of 13:37, 24 May 2013 by Pilou (Talk | contribs)
Automatic cat feeder with scale
Auteur Pilou
Date de proposition 15/04/2013
Tags du projet arduino;
Lieu d'utilisation final @Home
Utilisateur final Crazy cat lady
Projet personnel de Pilou
Projet Automatic cat feeder with scale
  • Dry food
  • Rotary cylinder for stocking and dispense to the scale
  • Scale
This automatic cat feeder have to precisely weigh the food (1 gram precision).
Brainstorming:
  • a turning cylinder with a trap for filing and a hole for emptying.
    • on a side just a hole
    • on the other side the filing trap
  • a bowl fixed to a scale with a servomotor receive the food.
  • when the desired weight is reached, the bowl is poured to a dish.
  • Battery and wall-plug powered.(In case of power breakdown)
  • Detect when the food level is low in the cylinder (IR barrier)
Preliminary:
  • find a scale who can be easily read by an arduino
  • find the size of the hole in the cylinder
Electronic/Hardware/Software:
  • Arduino with SDcard/RTC
  • Serial to bluetooth module
Power:
  • USB battery charger connected to a 5V wall-plug.
    • Provide 5V even if the power is down.
Ideas:
Progress
23/05/2013
Extraction of a Strain gauge from an electronic scales (about 8€ on ebay). The scale is build for a maximum of 1kg, after 1kg the voltage continue to raise
TODO
  • Add gain to the strain gauge to have 5V when 1kg is reached.
  • Prototyping of the tube feeder.
  • Find a transparent tube (for prototype grey pvc tube)
Feel free to correct my english!
