Projets:Perso:2013:RaspEink
Revision as of 20:00, 3 September 2013 by Mrpozor (Talk | contribs)
The aim of the RaspEink project is to drive a small e-Paper display with a Raspberry Pi. While such a display could serve many purposes (status reports, weather station etc.) it will be used in this project to complete an existing home automation system, namely to display current temperature in all rooms and the status of the heating system.
Hardware
Software Overview
  • Raspian linux from official source
  • FHEM home automation software
  • Perl, required to run FHEM
  • Python for extraction of data from logfile and generation of a bitmap
  • Modified version of the demo driver to send bitmap to display.
Software diagram:
The central piece of software is the Python program (piper.py). It processes the logfiles that are created by FHEM and extracts all required information (temperatures, valve positions, humidity and burner status). It then creates a bitmap from this information and launches the driver. The driver, written in C, loads the BMP and sends it to the display through SPI. Initially, the Python program was supposed to do both the image generation and hardware interfacing but the SPI implementation in Python turned out to be too buggy.
Hardware Setup and Test
The display is wired exactly as described in the excellent guide "Epaper_RaspberryPi.pdf" from Embedded Artists which can be downloaded from their website: http://www.embeddedartists.com/products/displays/lcd_27_epaper.php
The document also describes how to download, compile and run the demo software and driver. The demo software simply loops between two static logos.
Driver: Modifying Demo Code to Display Custom BMP
With the demo software working, it is time to modify the source code to make it load a BMP instead of the static logos. Please note that the modifications described below are only for educational purposes. Try them at your own risk. I assume no responsibility for any damage done by using these modifications.
The modifications were done in main.c.
First, the following variables and local function were introduced:
 * Local Functions
uint8_t buffer[176][33] = {};
void readfile(FILE *f) {
	int x,y;
    fseek(f, 62, SEEK_SET);
    fclose(f);
	for(x=0; x<=176; ++x) {
		for(y=0; y<=33; ++y) {
filebuffer will hold the BMP after it is loaded. buffer will hold the final image. With fseek we go to a specific postion in the file, more precisely to the start of the actual pixel data. This postion (62 in our case) depends on the version of BMP used. There are several version and which one is used largely depends on the image manipulation software. The Wikipedia article about the BMP file format gives a nice overview.
For the purpose of this software we are using monochrome BMP (i.e. with 1 bit per pixel). Such BMP can be created in GIMP for example by reducing the number of indexed colors to 2. After saving such a bitmap, it is a good idea to open it in a Hex editor and verify the offset of the pixel data. This value is stored in position 0x0Ah. If it is not 62 (0x3Eh), you need to adjust this value above. If you don't, the image might show a shift.
The for loops simply flip and invert the pixel data.
The main method can then be replaced completely by this one:
 * Main method
  uint8_t* pOldImg;
  char* path = "";
  FILE *f = NULL;
  if(argc == 1) {
	path = "testimage.bmp";
	f = fopen(path, "rb");
  if(argc == 2) {
	path = argv[1];
	printf("Loading %s\n", path);
	if(f == NULL) {
  bsp_init();
  readfile(f);
  memset((uint8_t*)&PreloadImage[0][0], 0xff, 176*33);
  pOldImg = (uint8_t*)&PreloadImage[0][0];
    printf("Sending Image...\n");
    epd_DisplayImg(DISPLAY_IN_USE, (uint8_t*)&buffer[0][0], pOldImg);
    pOldImg = (uint8_t*)&buffer[0][0];
  printf("Done.\n");
  return 1;
The functions above simply load the file after doing some basic error checks. If no file is mentioned as a parameter or the file is not found, a test bitmap is loaded (the bitmap can be downloaded here).
If all compiles well, you can use the software now to load your own bitmap:
sudo ./epaper yourbitmap.bmp
piper.py: Generating BMP
