Projets:Perso:2011:RepRap:Mendel n1:PiecesDetachees
Revision as of 17:22, 17 April 2011 by Lcdvasrm (Talk | contribs)
Reprap Mendel
Bill of Material : cf http://reprap.org/wiki/Mendel_assembly_data_sheet
On a
Electronique Generation 3
  • 1 RepRap Motherboard (mendel/electronics/motherboard): v1.2 (david)
  • 3 RepRap Stepper drivers (mendel/electronics/stepper-motor-driver) : v2.3 (david)
  • 1 RepRap extruder controller: v2.2 (david)
  • 1 kit extrudeur complet (david)
Connectique
  • 1 Mendel USB and power connector (no Eagle design - it's a simple piece of stripboard) ?
Meca
  • les 3 courroies crantées (commande yannick)
  • Les plaques de support de l'electronique (découpées au laser), ce qu'ils appellent Thick Sheets (commande yannick)
  • le kit complet de roulements à billes (48+2) (commande yannick)
On a pas
Contacteurs
Opto Endstop v2.1
Source	Cost per board	Total
Makerbot DIY KIT	$3 	$18
Makerbot Fully Assembled	*	*
Self Source Total	#NOM ?	$18,36
Total Boards needed for Build	6
	Cheapest				Alternate
Part	Type	Seller	Part #	Cost $	Seller	Part #	Cost	Board Quantity	Board Total	Project Quantity	Project Total
1K ohm resistor	EC	Mouser	291-1k-RC	$0,10				1	$0,10	6	$0,60
220 ohm resistor	EC	Mouser	291-220-RC	$0,10		R220R14W	$0,10	1	$0,10	6	$0,60
3mm green LED	EC	Mouser	859-LTL-4231N-1	$0,10		LED3G	$0,10	1	$0,10	6	$0,60
H21LOB	EC	Mouser	512-H21LOB	$1,02	Digikey	H21LOB-ND	$1,77	1	$1,02	6	$6,12
RJ45 Jack	EC	Mouser	571-5555164-1	$0,74				1	$0,74	6	$4,44
Opto Endstop v2.1 PCB	PCB	Makerbot	Opto Endstop v2.1 PCB	$1,00				1	$1,00	6	$6,00
								Total:	#NOM ?		$18,36
Ecrous
BZP == Bright Zinc Plated est suffisant comme qualité
Nut = écrou / Washer = rondelle / Cap Screw = vis à tête / Mudguard = gared boue ?
Nyloc = http://en.wikipedia.org/wiki/Nyloc_nut, écrou avec un insert en nylon
  • M3 Cap Screw 20mm 54
http://img-europe.electrocomponents.com/images/C209955-63.jpg
  • M3 Nut 14
http://img-europe.electrocomponents.com/images/R525919-22.jpg
  • M3 Nyloc 38
http://img-europe.electrocomponents.com/images/C524281-63.jpg
  • M3 Washer 102
http://img-europe.electrocomponents.com/images/R275051-51.jpg
  • M4 Nut 25
  • M4 Nyloc 129
  • M4 Washer 449
  • M4 Cap Screw 16mm 39
  • M4 Cap Screw 40mm (Mild Only) 115
  • M4 ou M5 Mudguard 20mm washer 15
http://img-europe.electrocomponents.com/images/C275844-63.jpg
  • M8 Nut 104
  • M8 Washer 104
Barres
  • 8x1m de barres M8 filletées
  • 3x1m de barres non filletées 8mm diam. pour les barres x-y-z
Affaire : lot de 25 tiges filetées M8 en acier zingué de longueur 1m : 17,90 EUR chez leroy merlin.
Je vais y faire un tour ce week end.
Modifs de connectique à faire : http://reprap.org/wiki/PCB_adaptions_for_Mendel
