Projets:Commande groupee:archives
Commandes groupées en cours
Cergy-Vis
Naviguer vers la page des commandes en cours de Cergy-Vis
Conrad Electronique France
Naviguer vers la page des commandes en cours de Conrad Electronique France
COMMENTAIRE
| Limesle | LED verte 5 mm Hlmp Cm14-Z30Dd Avago Technologies HLMP-CM14-Z30DD | 181211 - 62 | 2 | 0,95€ | David | CO_001 | O | O | O | N |
| Limesle | LED blanche 5Mm 18000 Mcd | 180000 - 62 | 2 | 0,90€ | David | CO_001 | O | O | O | N |
| Patrick | Switch Dlink 1005D Gigabit | 973969 - 62 | 1 | 34,96€ | David | CO_001 | O | O | O | O |
| David | Troisième main Toolcraft ZD-10F | 588124 - 62 | 3 | 5,39 | David | CO_001 | O | O | O | N |
| David | Panne de rechange Toolcraft T-LB | 588240 - 62 | 1 | 5,59 | David | CO_001 | O | O | O | N |
| Thomas | Lot de pinces dauphin XDK 1033 | 100631 - 62 | 1 | 10,95 | David | CO_001 | N | O | O | N |
| Thomas | Fiche Banane de Securite rouge 4 mm MultiContact 22.3007-22 | 741502 - 62 | 1 | 6,79 | David | CO_001 | N | O | O | N |
| Thomas | Fiche Banane de Securite 4 mm MultiContact 22.3007-21 | 741489 - 62 | 1 | 6,79 | David | CO_001 | N | O | O | N |
| Thomas | Cordon de mesure 50 cm bleu MultiContact XVS-4075 66.9562-05023 | 106035 - 62 | 1 | 5,69 | David | CO_001 | N | O | O | N |
| Thomas | Cordon de mesure 50 cm noir MultiContact XVS-4075 66.9562-05023 | 126033 - 62 | 1 | 5,69 | David | CO_001 | N | O | O | N |
| Thomas | Cordon de mesure 50 cm rouge MultiContact XVS-4075 66.9562-05023 | 106034 - 62 | 1 | 5,69 | David | CO_001 | N | O | O | N |
| Patrick | Elément chauffant 12V 50/100/150W | 532894 - 62 | 2 | 10.95 | <Patrick> | CO_002 | O | O | O | O |
| Patrick | POMPE A AIR MEMBRANE | 530476-62 | 21 | 34.95 | <Patrick> | CO_002 | O | O | O | O |
| Patrick | Livre Arduino applications avancées | 095064-62 | 1 | 25.65 | <Patrick> | CO_002 | O | O | O | O |
| Alexander | CI Bus I2C PCF 8573P Philips | 064235 - 62 | 5 | 0.05 | <Patrick> | CO_002 | N | N article abandonné | N | N |
| Eric | Aérosol 200 ml CRC Kontakt Chemie Kontakt 60 | 813516 - 62 | 1 | 7.95 | <Patrick> | CO_002 | N | O | O | O |
| Eric | Nettoyeur de circuits imprimés 400 ml CRC Kontakt LR | 822812 - 62 | 1 | 11.95 | <Patrick> | CO_002 | N | O | O | O |
| Eric | Douille Ø 4 mm type PKI100 vert/jaune SKS Hirschmann ref 930757188 | 733928 - 62 | 6 | 3.00 | <Patrick> | CO_002 | N | O | O | O |
| Eric | Varistance 510 V Epcos S20K320E3K1 B72220P3321K101 | 531595 - 62 | 5 | 1.40 | <Patrick> | CO_002 | N | O | O | O |
| Lab | Coffret plastique 18 compartiments | 078156 - 11 | 1 | 14.90 | <Patrick> | CO_002 | N | O | O | O |
| David | Panne de rechange Toolcraft T-3.2D | 588228 - 62 | 1 | 6.99 | Patrick | CO_003 | N | O | O | O |
| Patrick | Entretoise laiton M/F 10mm vis 3mm | 526630 - 62 | 10 | 0,23 | Patrick | CO_003 | N | O | O | O |
| Patrick | Aérosol désodorisant bio Melon | 095485-62 | 1 | 10.95 | Patrick | CO_003 | N | O | O | O |
| Patrick | Set de 200 colliers naturels (lg. 100, 150, 200 et 250mm) | 541665 - 62 | 1 | 3,30 | <acheteur> | CO_003 | N | O | O | O |
| Patrick | Eponge pour fer à souder | 812374-62 | 1 | 2,07 | Patrick | CO_003 | N | O | O | O |
| Lab | Eponge pour fer à souder | 812374-62 | 9 | 2,07 | Patrick | CO_003 | N | O | O | O |
| Lab | Gants de protection Camatex en latex naturel/Coton Taille 10 KCL 450 | 893626 - 62 | 2 | 6,99 | <acheteur> | CO_003 | N | O | O | O |
| Lab | Régulateur 7915 | 179310 - 62 | 1 | 1,10 | Patrick | CO_003 | N | O | O | O |
| Lab | Lot de 100 Colliers 100 X 2,5 Naturel Marque HellermannTyton ref: 138-00001 | 617849 - 62 | 1 | 1,50 | Patrick | CO_003 | N | O | O | O |
| Lab | Set de 200 colliers naturels (lg. 100, 150, 200 et 250mm) | 541665 - 62 | 1 | 3,30 | Patrick | CO_003 | N | O | O | O |
| Eric | Spray air comprimé 400 ml Dataflash | 995809 - 62 | 2 | 6,99 | Patrick | CO_003 | N | O | O | O |
| Eric | Collier de serrage de tuyau acier fin 10 à 16 mm SUBHC000 serrage papillon | 541837 - 62 | 5 | 1,00 | Patrick | CO_003 | N | O | O | O |
| Eric | Collier de serrage inox Ø 9 à 13 mm | 544906 - 62 | 5 | 0,60 | Patrick | CO_003 | N | O | O | O |
| Lab | DOUILLE DE SECURITE 4mm ECROU NOIR , ref3265-I-0 | 326500 | 4 | 1.35 | Patrick | CO_003 | N | O | O | O |
| Lab | DOUILLE DE SECURITE 4mm ECROU VERT, ref3265-I-5 | 326505 | 3 | 1.35 | Patrick | CO_003 | N | O | O | O |
| Lab | DOUILLE DE SECURITE 4mm ECROU BLEU, ref3265-I-6 | 326506 | 1 | 1.35 | Patrick | CO_003 | N | O | O | O |
| 3dsman | Capteur de couleur RVB KPS-5130PD7C | 180381 - 62 | 5 | 1.70 | Patrick | CO_004 | N | o | O | O |
| Florent, 2 pour Patrick | Lames de fusible 80A | 535265-62 | 27 | 0,32 | Patrick | CO_004 | N | o | O | o |
| David | Fer à souder de rechange 100 W | 588281 - 62 | 1 | 37,95 | Patrick | CO_004 | N | o | o | o |
| David | Câble Ftp Cat5 Vert 10 M Bulk | 972081 - 62 | 1 | 11,95 | Patrick | CO_004 | N | o | o | o |
| Eric | Lot de 100 Colliers 245 X 4,5 Transparent Marque HellermannTyton ref: UB250C-N-PA66-NA-C1 13 | 617873 - 62 | 1 | 7.09 | <Patrick> | CO_004 | N | o | O | O |
| Eric | Lot de 100 Colliers 200 X 4,6 Transparent Marque HellermannTyton ref: UB200C-N-PA66-NA-C1 13 | 617865 - 62 | 1 | 4.50 | <acheteur> | CO_004 | N | o | O | O |
| Eric | Testeur de capteurs Marque : Contrinex | 155946 - 62 | 1 | 40.95 | <Patrick> | CO_004 | N | o | O | O |
| Eric +1 Patrick | Fiche allume-cigares femelle standard pour câble | 062857 - 62 | 2 | 1,99 | <Patrick> | CO_004 | N | o | O | O |
| FICHF | LM317LD | 155584 - 62 | 10 | 0,2 | Patrick | CO_004 | N | o | O | O |
| Patrick | support lame de fusible ESKA max 500A | 535222-62 | 2 | 2,7 | Patrick | CO_004 | N | o | O | O |
| Yann | brasure étain 0.5mm 100g | 812803 - 62 | 1 | 7.99€ | <Patrick> | CO_004 | N | o | O | O |
| Yann | brasure étain 1mm 100g | 812811 - 62 | 1 | 4.09€ | <Patrick> | CO_004 | N | o | O | O |
| Yann | fil à wrapper 0.20mm2 | 606075 - 62 | 1 | 5.49€ | <Patrick> | CO_004 | N | o | O | O |
| Lab | gaine spiralée 4-50mm | 546146 - 62 | 1 | 3.10€ | <Patrick> | CO_004 | N | o | O | O |
| Patrick | porte fusible 5X20 chassi | 533769-62 | 1 | 0.80€ | <Patrick> | CO_004 | N | o | O | O |
| Patrick | Fiche allume-cigares male standard pour câble | 062856-62 | 1 | 1.99€ | <Patrick> | CO_004 | N | o | O | O |
| Lab | 100 Embouts à collerette 9mm fil 4mm² | 617878 - 62 | 1 | 2.59€ HT | <Patrick> | CO_005 | N | O | o | o |
| Eric | Gants de protection Camatex en latex naturel/Coton Taille 10 KCL 450 | 893626 - 62 | 2 | 6,99 | <Patrick> | CO_005 | N | O | O | O |
| Léonard | Set de 4 prises avec télécommande | 099994 - 62 | 1 | 20,82 HT | <Patrick> | CO_005 | N | O | O | O |
| Léonard | Module émetteur AM 433,92 MHz kit monté alim 5 V puissance 10 mW Aurel TX-SAW MID/5 V | 191525 - 62 | 1 | 9,16 HT | <Patrick> | CO_005 | N | O | O | O |
| Léonard | Module récepteur 433 MHz Aurel Ac-Rx | 190276 - 62 | 1 | 6,68 HT | <Patrick> | CO_005 | N | O | O | O |
| Iggy | Module capteur PIR | 506177 - 62 | 1 | 10,83 HT | <Patrick> | CO_005 | 50 | O | o | o |
| Iggy | Module électronique pour modules capteurs IR | 506178 - 62 | 1 | 12,50 HT | <Patrick> | CO_005 | 50 | O | o | o |
| Iggy | Capteur Pir CMS 5V Hygrosens | 172526 - 62 | 1 | 26,71 HT | <Patrick> | CO_005 | 50 | O | o | o |
DamenCNC
Naviguer vers la page des commandes DamenCNC en cours
Digikey Corporation
Naviguer vers la page des commandes Digikey Corporation en cours
| Yann/Matthieu | SWITCH TACTILE SPST-NO 0.05A 24V | SW796-ND | 70 | 0.29580€ | Destynova | DI_002 | O | O | O | O |
| David | CONN PC VERT 9V SNAP-ON | 968K-ND | 100 | 0.57410€ | Destynova | DI_002 | O | O | O | O |
| Robotique(lab) | PCA9685 (i2c pwm) | 568-5931-1-ND | 2 | 2.17€ | Destynova | DI_002 | O | O | O | O |
| Robotique(lab) | MCP23017-E/SO (i2c io) | MCP23017-E/SO-ND | 2 | 1.22€ | Destynova | DI_002 | O | O | O | O |
| Robotique(lab) | ADS1015IDGST ADC 12BIT I2C W/REF | 296-25227-1-ND | 2 | 2.64€ | Destynova | DI_002 | O | O | O | O |
| Eric | DIODE ARRAY BYC10-600CT 600V 10A TO220AB | 568-1781-5-ND | 2 | 1,26 | 3dsman | DI_003 | N | O | O | O |
| Eric | OPAMP LT1637 PDIP8 | LT1637CN8#PBF-ND | 6 | 2.89 USD | 3dsman | DI_003 | N | O | O | O |
| 3dsman | ENCODER PROG 16RES SW TTL RADIAL | 102-1307-ND | 2 | 23.63 USD | 3dsman | DI_003 | O | O | O | O |
| 3dsman | SN65HVD3082EDR | 296-31719-1-ND | 5 | 2.42USD | 3dsman | DI_003 | O | O | O | O |
| 3dsman | ATMEGA48A-PU | ATMEGA48A-PU-ND | 1 | 2.04USD | 3dsman | DI_003 | O | O | O | O |
| 3dsman | ATMEGA88PA-PU | ATMEGA88PA-PU-ND | 1 | 2.45USD | 3dsman | DI_003 | O | O | O | O |
| 3dsman | ATMEGA88A-AU | ATMEGA88A-AU-ND | 2 | 2.13USD | 3dsman | DI_003 | O | O | O | O |
| 3dsman | TCS3104FN | TCS3104FNCT-ND | 1 | 1.8USD | 3dsman | DI_003 | O | O | O | O |
| 3dsman | CLA1B-WKW-XD0F0E13 | CLA1B-WKW-XD0F0E13CT-ND | 3 | 0.29USD | 3dsman | DI_003 | O | O | O | O |
| f6itu | xtal 12 MHz | 644-1047-1-ND | 2 | 0.87000 | 3dsman | DI_003 | N | O | N | N |
| thomas | ACS711EEXLT-15AB-T | 620-1481-1-ND | 10 | 1.158USD | 3dsman | DI_003 | N | O | N | N |
| Audran | EEU-FR1V471B | P15391CT-ND | 3 | 0.77€ | 3dsman | DI_003 | N | O | O | O |
| Audran | EEU-HD1E221B | P15737CT-ND | 1 | 0.88€ | 3dsman | DI_003 | N | O | O | O |
| Audran | 50PX47MEFCTA6.3X11 | 1189-1649-1-ND | 2 | 0.28€ | 3dsman | DI_003 | N | O | O | O |
| Audran | UPB1H3R3MDD1TD | 493-4941-1-ND | 1 | 0.36€ | 3dsman | DI_003 | N | O | O | O |
| Audran | EEU-FR1C102B | P15331CT-ND | 2 | 0.77€ | 3dsman | DI_003 | N | O | O | O |
| Audran | UPJ1A331MPD1TD | 493-5000-1-ND | 1 | 0.4€ | 3dsman | DI_003 | N | O | O | O |
| Audran | EEU-FR1E821B | P15368CT-ND | 4 | 0.87€ | 3dsman | DI_003 | N | O | O | O |
| Audran | 51761-10002406AALF | 609-3636-ND | 2 | 4.72€ | 3dsman | DI_003 | N | O | O | O |
Farnell
| Demandeur | Description | Ref Farnell | Quantité | Prix unitaire | Acheteur | Commande n° | Payé d'avance (O/N) | Commandé (O/N) | Distribué (O/N) | Remboursé/Archive (O/N) |
| Clem(pcb) | forets hss 0.8mm | 377650 | 1 (pack de 10) | a vérifier (de l'ordre de 10€ | ? | ? | N (boite a pcb) | O | O | O |
| Lab | Batterie 12V YUASA NP1.2-12 | 147472 | 1 | 15,90HT | Destynova | FA_001 | O | O | O | O |
| Eric | Batterie 12V YUASA NP1.2-12 | 147472 | 1 | 15,90HT | Destynova | FA_001 | O | O | O | O |
| Lab | Pile CR2450 LITHIUM 3V, 600MAH | 2065173 | 1 | 1,14HT | Destynova | FA_001 | O | O | O | O |
| Eric | Pile CR2450 LITHIUM 3V, 600MAH | 2065173 | 1 | 1,14HT | Destynova | FA_001 | O | O | O | O |
| Lab | Graphit 33 (spray) | 832959 | 1 | 9,35HT | Destynova | FA_001 | O | O | O | O |
| Lab | ROULEAU POUR DYMO N/B 9MM ref 40913 pour Labelmanager 450 | 667006 | 1 | 13,65HT | Destynova | FA_001 | O | O | O | O |
| Crafty | LINEAR TECHNOLOGY - LTC3105EMS#PBF - BOOST 400MA MPPC 12MSOP | 1898601 | 10 | 5,06 EHT | Destynova | FA_001 | O | O | O | O |
| Crafty | BOURNS - SRR0603-100ML - INDUCTANCE 10UH PUISSANCE BLINDE CMS | 2212495 | 10 | 0,48 EHT | Destynova | FA_001 | O | O | O | O |
| Crafty | SUNON - EB40200S2-0000-999 - VENTILATEUR. 40X40X20MM. 5VDC | 1924832 | 2 | 9,78 EHT | Destynova | FA_001 | O | O | O | O |
| Crafty | MULTICOMP - MCTE1-12715L-S - DISSIPATEUR PELTIER 130W | 1639728 | 1 | 31,93 EHT | Destynova | FA_001 | O | O | O | O |
| Crafty | MULTICOMP - MCPE1-07107AC-S - DISSIPATEUR PELTIER 31.1W | 1639723 | 1 | 28,81 EHT | Destynova | FA_001 | O | O | O | O |
| Crafty | MULTICOMP - MCPE1-03108NC-S - DISSIPATEUR PELTIER 18.8W | 1639720 | 1 | 19,40 EHT | Destynova | FA_001 | O | O | O | O |
| the_nihilant | ATMEL - ATMEGA48A-AU - MCU, 8BIT, AVR, 4K FLASH, 32TQFP | 1841612 | 4 | 2,07 HT | Destynova | FA_001 | O | O | O | O |
| the_nihilant | ATMEL - ATMEGA88A-AU - MCU, 8BIT, AVR, 8K FLASH, 32TQFP | 1841614 | 2 | 2,33 HT | Destynova | FA_001 | O | O | O | O |
| the_nihilant | ATMEL - ATMEGA324A-PU - MCU, 8BIT, AVR, 32K FLASH, 40PDIP | 1841611 | 3 | 4,28 HT | Destynova | FA_001 | O | O | O | O |
| the_nihilant | TEXAS INSTRUMENTS - SN74HC595DR - IC, SM, LOGIC, 74HC, REGISTER | 1607849 | 24 | 0,20 HT | Destynova | FA_001 | O | O | O | O |
| raoul(Robotique) | TEXAS INSTRUMENTS - TPS40210DGQ - IC, CTRLR CUR MODE BOOST 10MSOP | 1755634 | 2 | 3.28 HT | Destynova | FA_001 | O | O | O | O |
| raoul(Robotique) | TEXAS INSTRUMENTS - ADS7830IPWTG4 - CONVERTISSEUR A/N 8 BITS 8 CH CMS | 1180129 | 4 | 3.57 HT | Destynova | FA_001 | O | O | O | O |
| raoul(Robotique) | TEXAS INSTRUMENTS - TPS76333DBVT - REG DE TENSION LDO 0.15A 3.3V CMS 76333 | 8461376 | 2 | 1.14 HT | Destynova | FA_001 | O | O | O | O |
| Matthieu | KONTAKT WL | 837970 | 1 | 8.26 ht | David | FA_002 | N | O | O | N |
| Matthieu | KONTAKT 60 400ML | 2142395 | 1 | 10,93 ht | David | FA_002 | N | O | O | N |
| the_nihilant | YAGEO (PHYCOMP) - YC164-JR-071KL - RESEAU DE RESISTANCES ARV241 1206 1K | 9234519 | 10 | 0,096 HT | David | FA_002 | N | O | O | O |
| the_nihilant | ABRACON - ABL-20.000MHZ-B2 - CRYSTAL, 20M, 18PF CL, HC49/4H | 1611779 | 10 | 0,25 HT | David | FA_002 | N | O | O | 0 |
| the_nihilant | RALTRON - AS-16.000-18 - CRYSTAL, 16M, 18PF CL, HC49/4H | 1611761 | 10 | 0,25 HT | David | FA_002 | N | O | O | O |
| the_nihilant | TEXAS INSTRUMENTS - CD74HC164E - LOGIC, SHIFT REGISTER 8BIT HS, 14DIP | 1740095 | 16 | 0,30 HT | David | FA_002 | N | O | O | O |
| the_nihilant | MULTICOMP - 703-0100 - LED ROUGE 5MM STANDARD | 2112111 | 25 | 0,182 HT | David | FA_002 | N | O | O | O |
| the_nihilant | KEYSTONE - 2463 - SUPPORT POUR BATTERIE | 1702631 | 6 | 1,05 HT | David | FA_002 | N | O | O | O |
| the_nihilant | MICRO COMMERCIAL COMPONENTS - 2N3906-AP - BJT, PNP, 40VDC, TO-92 | 1924641 | 100 | 0,028 HT | David | FA_002 | N | O | O | O |
| the_nihilant | STMICROELECTRONICS - ULN2803A - RESEAU DE TRANSISTOR DARLINGTON 8NPN | 1094428 | 10 | 0,84 HT | David | FA_002 | N | O | O | O |
| Eric | KONTAKT WL 200ML | 800946 | 1 | 5,56 HT | David | FA_002 | N | O | O | O |
| Eric | KONTAKT IPA 200ML | 2142406 | 1 | 6,78 HT | David | FA_002 | N | O | O | O |
| Eric | NXP - BYC10D-600 - DIODE HYPERFAST 10A 600V TO220AC | 2075013 | 4 | 1,23 HT | David | FA_002 | N | O | O | O |
| Lab | VISHAY DALE RESISTOR, METAL FILM, 1KOHM, 3W, 1% ref CPF31K0000FKE14 | 1218226 | 1 | 1,51 HT | David | FA_002 | N | O | O | O |
| MAZ24 | ATAVRISP2 | 1135517 | 1 | 28,13 | David | FA_002 | N | O | O | O |
| MAZ24 | ARDUINO A000048 | 1848694 | 2 | 4,41 | David | FA_002 | N | O | O | O |
| MAZ24 | ARDUINO UNO A000073 | 2285200 | 1 | 26,97 | David | FA_002 | N | O | O | O |
| MAZ24 | ULN2003ADR | 1470513 | 10 | 0,31 | David | FA_002 | N | O | O | O |
| Crafty | LTC3122EMSE#PBF BOOST SYNCH 15V 2.5A 3MHZ 12MSOP | 2148749 | 10 | 3,51 | David | FA_002 | N | O | O | N |
| Crafty | NXP - 2N7002P - MOSFET CANAL N 60V 0.36A SOT23 | 1859848RL | 30 | 0,115 | David | FA_002 | N | O | O | N |
| Crafty | KINGBRIGHT - KPTD-3216ZGC-01 - LED 1206 DOME REV.RUBAND TRUE-GRE | 2290350 | 40 | 0,40 | David | FA_002 | N | O | O | N |
| Crafty | TEXAS INSTRUMENTS - TLC59116IPWR - LED DRIVER, 16CH, I2C BUS, TSSOP28 | 1647815 | 4 | 4,24 | David | FA_002 | N | O | O | N |
| Crafty | TEXAS INSTRUMENTS - TLC5941PWPG4 - DRIVER DE LED 16 VOIES CMS | 1226308 | 4 | 2,28 | David | FA_002 | N | O | O | N |
| Crafty | NXP - PCA9634PW - DRIVER DE LED RGBA 20-TSSOP | 1854071 | 4 | 1,65 | David | FA_002 | N | O | O | N |
| Crafty | NXP - PCA9622DR - DRIVER DE LED RGBA 32-TSSOP | 1854075RL | 4 | 1,89 | David | FA_002 | N | O | O | N |
| Crafty | LINEAR TECHNOLOGY - LTC3109IUF#PBF - BOOST PMU 20QFN | 1839119 | 4 | 5,31 | David | FA_002 | N | O | O | N |
| Crafty | PANASONIC - EECF5R5U155 - CONDENSATEUR 1.5F 5.5V | 1305065 | 2 | 4,21 | David | FA_002 | N | O | O | N |
| Crafty | PANASONIC - EECS5R5H105 - CONDENSATEUR 1F 5.5V | 9697497 | 2 | 4,17 | David | FA_002 | N | O | O | N |
| MrPozor | CONNECTEUR 90142 C GRID 26 VOIES | 3291662 | 5 | 1,19 | David | FA_002 | N | O | O | O |
| MrPozor | CONTACT FEMELLE 26-28AWG | 9733280 | 40 | 0,23 | David | FA_002 | N | O | O | O |
| MrPozor | CONNECTEUR 90142 C GRID 14 VOIES | 3291601 | 5 | 0,99 | David | FA_002 | N | O | O | O |
| MrPozor | EMBASE F HE10 DROIT 14V.+S. CABLE | 1099237 | 1 | 0,59 | David | FA_002 | N | O | O | O |
| CydGy | CONTACT FEMELLE 26-28AWG | 1308868 | 5 | 1,97 € | David | FA_002 | N | O | O | O |
| CydGy | CONNECTEUR RCA/PHONO FEMELLE 3 VOIES | 2293877 | 1 | 2,73 € | David | FA_002 | N | O | O | O |
| CydGy | FICHE FEMELLE JACK 3.5MM STEREO | 1280747 | 1 | 0,86 € | David | FA_002 | N | O | O | O |
| CydGy | TRANSFORMATEUR COURANT E5 3000UH | 1579334 | 1 | 2,53 € | David | FA_002 | N | O | O | O |
| CydGy | DIODE LASER 655NM | 1272658 | 1 | 6,84 € | David | FA_002 | N | O | O | O |
| Eric | AVAGO HDSP-4832 RESEAUX DE LED MULTICOL. | 1003271 | 1 | 5.29 €HT | David | FA_003 | N | O | O | N |
| Crafty | WURTH ELEKTRONIK - 74488540070 - INDUCTANCE RECUPERATION D'ENERGIE 7.5UH | 2249879 | 8 | 3,55 | David | FA_003 | N | O | O | N |
| David | VITELEC - VB1094/L-75 - EMBASE PANNEAU FEMELLE BNC DROITE | 2254719 | 4 | 3,36 | David | FA_003 | N | O | O | N |
| Raoul | FRDM-KL25Z - CARTE KINETIS L SERIES KL25Z | 2191861 | 1 | 11,75€HT | <acheteur> | FA_003 | O | O | O | N |
| Pilou | FRDM-KL25Z - CARTE KINETIS L SERIES KL25Z | 2191861 | 1 | 11,75€HT | David | FA_003 | N | O | O | N |
| Pilou | TL082ACP - AMPLI OP DOUBLE BIFET | 1103189 | 4 | 0,64€HT | David | FA_003 | N | O | O | N |
| Pilou | VT935G - PHOTO RESISTANCE SERIE VT901 | 1652638 | 5 | 0,40€HT | David | FA_003 | N | O | O | N |
| 3dsman | FRDM-KL25Z - CARTE KINETIS L SERIES KL25Z | 2191861 | 1 | 11,75€HT | David | FA_003 | N | O | O | N |
| 3dsman | VEMD2020X01 - PHOT. DIODE SMD GULLWING FILT. | 1779705 | 10 | 0,3€HT | David | FA_003 | N | O | O | N |
| 3dsman | TSAL6200.. - IR EMITT. HI POWR 940NM 5MM 17DEG | 1779662 | 10 | 0,26€HT | David | FA_003 | N | O | O | N |
| Nicolas | MULTICOMP 2226TG | 1593529 | 100 | 0,083€HT | David | FA_003 | N | O | N | N |
| Nicolas | MULTICOMP 2226A-22 | 1593518 | 10 | 0,076€HT | David | FA_003 | N | O | N | N |
| Nicolas | MULTICOMP 2226B-22 | 1593527 | 10 | 0,077€HT | David | FA_003 | N | O | N | N |
| Eric | Double diode 1,2kV 11A ref: DSP8-12A fabricant : IXYS TO220AB | 1080104 | 4 | 1,54€HT | David | FA_003 | N | O | O | N |
| Antoine | MICRO 8 BITS AVR 32K FLASH 28PDIP | 1715487 | 2 | 3,86€HT | David | FA_003 | N | O | O | N |
| Antoine | REGULATEUR DE TENSION 5V | 1467758 | 4 | 0,49€HT | David | FA_003 | N | O | O | N |
| Antoine | CONDENSATEUR 22UF 50V | 8766835 | 2 | 0,137€HT | David | FA_003 | N | O | O | N |
| Antoine | CONDENSATEUR 0.01UF 50V | 2112749 | 2 | 0,27€HT | David | FA_003 | N | O | O | N |
| Antoine | RESISTANCE CARBONE 1/4W 1K0 | 1265072 | 5 | 0,13€HT | David | FA_003 | N | O | O | N |
| Thomas | INDUCTANCE | 2061655 | 5 | 0.36€HT | David | FA_003 | N | O | N | N |
| Raoul | C0805C105K4RACTU | 9227792 | 10 | 0.053 | David | FA_003 | O | O | O | N |
| Raoul | TMK212B7473KD-T | 1759031 | 100 | 0.008 | David | FA_003 | O | O | O | N |
| Raoul | CC0805KRX7R9BB391 | 3019846 | 10 | 0.054 | David | FA_003 | O | O | O | N |
| Raoul | CC0805KRX7R9BB222 | 3019895 | 10 | 0.044 | David | FA_003 | O | O | O | N |
| Raoul | APXA160ARA331MJC0G | 1580614 | 5 | 1.45 | David | FA_003 | O | O | O | N |
| Raoul | CC0805JRNP09BN101 | 3606028 | 10 | 0.086 | David | FA_003 | O | O | O | N |
| Raoul | GRM155R61A274KE15D | 1759111 | 100 | 0.008 | David | FA_003 | O | O | O | N |
| Raoul | 30CTQ060STRLPBF | 1611297 | 1 | 2.07 | David | FA_003 | O | O | O | N |
| Raoul | SER2915L-103KL | 2288908 | 1 | 2.85 | David | FA_003 | O | O | O | N |
| Raoul | CSD16415Q5 | 1710776 | 1 | 2.01 | David | FA_003 | O | O | O | N |
| Raoul | CRCW080517K8FKEA | 1652927 | 1 | 0.076 | David | FA_003 | O | O | O | N |
| Raoul | CRCW04025R11FKED | 1469821 | 50 | 0.009 | David | FA_003 | O | O | O | N |
| Raoul | CRCW08051K00FKEA | 1469847 | 50 | 0.022 | David | FA_003 | O | O | O | N |
| Raoul | CRCW08055M36FKEA | 2139208 | 50 | 0.008 | David | FA_003 | O | O | O | N |
| Raoul | CSNL1206FT3L00 | 2079419 | 5 | 0.194 | David | FA_003 | O | O | O | N |
| Raoul | CRCW08053K16FKEA | 1469910 | 50 | 0.023 | David | FA_003 | O | O | O | N |
| Raoul | CRCW080551K1FKEA | 1469943 | 50 | 0.023 | David | FA_003 | O | O | O | N |
| MAZ24 | ATMEL ATTINY85-20PU | 1455162 | 10 | 1.09 | Damien H | FA_004 | N | O | N | N |
| NAZ24 | ATMEL ATTINY4313-PU | 1841620 | 10 | 1.14 | Damien H | FA_004 | N | O | N | N |
| 3dsman | MULTICOMP-703-1028-LED RGB 3528 PLCC | 2112143 | 5 | 0,42€HT | Damien H | FA_004 | N | O | N | N |
| 3dsman | EXCELITAS TECH-VT935G-PHOTO RESISTANCE SERIE VT901 | 1652638 | 5 | 0,40€HT | Damien H | FA_004 | N | O | N | N |
| 3dsman | BTB04-600SL - TRIAC 4A 600V TO-220AB | 9910522 | 10 | 0,47€HT | Damien H | FA_004 | N | O | N | N |
| 3dsman | OPTOCOUPLEUR SORTIE DARLINGTON DIP-4 | 1852745 | 10 | 0,072€HT | Damien H | FA_004 | N | O | N | N |
| 3dsman | ATMEGA88A-AU - MCU, 8BIT, AVR, 8K FLASH, 32TQFP | 1841614 | 10 | 1,72€HT | Damien H | FA_004 | N | O | N | N |
| 3dsman | FOX ELECTRONICS - FXO-HC536R-20 - OSC, 3.2X5MM, SMD, CER, 20.000MHZ | 1641035 | 2 | 1,65€HT | Damien H | FA_004 | N | O | N | N |
| 3dsman | AMS - AS5035-ASSU - ENCODER, MAGNETIC, ROTARY, 8BIT, 16SSOP | 1630798 | 1 | 4,64€HT | Damien H | FA_004 | N | O | N | N |
| the_nihilant | ATMEL - ATMEGA48A-AU - MCU, 8BIT, AVR, 4K FLASH, 32TQFP | 1841612 | 5 | 1,92 HT | Damien H | FA_004 | N | O | N | N |
| the_nihilant | KEYSTONE - 2463 - SUPPORT POUR BATTERIE | 1702631 | 3 | 1,05 HT | Damien H | FA_004 | N | O | N | N |
| the_nihilant | TE CONNECTIVITY / AMP - 0-0881545-2 - STRAP D'INTERCONNEXION AVEC LANGUETTE | 4218176 | 50 | 0,115 HT | Damien H | FA_004 | N | O | N | N |
| PapyCHeF | Résistance chauffante (pour quartz) | 1515897 | 5 | 1,02 (HT) | Damien H | FA_004 | N | O | N | N |
| Yann | Cable FPC 16pin 20cm inversé | 1908499 | 1 | 4,92 (HT) | Damien H | FA_004 | N | O | N | N |
| Raoul | MC33926 | 2102575 | 2 | 4.01 HT | Damien H | FA_004 | N | O | N | N |
| Damien H | A4988SETTR-T MOTOR DRIVER | 2057418 | 1 | 4,00 (HT) | Damien H | FA_004 | N | O | N | N |
| MAZ24 | capteur hall effect | 1811311 | 10 | 0,79 (HT) | Damien H | FA_004 | N | O | N | N |
| MAZ24 | ATtiny13A-PU | 1704566 | 10 | 1,12 (HT) | Damien H | FA_004 | N | O | N | N |
| MAZ24 | Hall switch | 1825248 | 20 | 0,36(HT) | Damien H | FA_004 | N | O | N | N |
| Pilou | STP13NM60N | 1737870 | 1 | 4,23(HT) | Damien H | FA_004 | N | O | N | N |
| Pilou |
| Lab | LUBRICANT KONTAFLON 85 200ML KONTAKT CHEMIE | 2142404 | 1 | 9.20(HT) | 3dsman | FA_005 | N | O | O | O |
| CDR2014 | B41142A7476M | 1735339 | 10 | 0.132(HT) | 3dsman | FA_005 | N | O | O | O |
| CDR2014 | MC0805N220J500CT | 1759195 | 10 | 0.021(HT) | 3dsman | FA_005 | N | O | O | O |
| CDR2014 | MC0805B105K160CT | 2320853 | 30 | 0.027(HT) | 3dsman | FA_005 | N | O | O | O |
| CDR2014 | KP-2012QBC-D | 2217974 | 10 | 0.155(HT) | 3dsman | FA_005 | N | O | O | O |
| CDR2014 | KPT-2012SGC | 2099239 | 50 | 0.073(HT) | 3dsman | FA_005 | N | O | O | O |
| CDR2014 | KPT-2012SURCK | 2099241 | 50 | 0,097(HT) | 3dsman | FA_005 | N | O | O | O |
| CDR2014 | DMS3016SSSA | 2061527 | 2 | 0.28(HT) | 3dsman | FA_005 | N | O | O | O |
| CDR2014 | HC49SM-20-30-50-60-16-ATF | 1667018 | 1 | 0.40(HT) | 3dsman | FA_005 | N | O | O | O |
| CDR2014 | MC0805X106K160CT | 2320856 | 30 | 0.084(HT) | 3dsman | FA_005 | N | O | O | O |
| CDR2014 | MCCA000282 | 1759151RL | 100 | 0.027(HT) | 3dsman | FA_005 | N | O | O | O |
| CDR2014 | MCSR08X2700FTL | 2074422 | 100 | 0.014(HT) | 3dsman | FA_005 | N | O | O | O |
| CDR2014 | MCSR08X4701FTL | 2074469 | 100 | 0.011(HT) | 3dsman | FA_005 | N | O | O | O |
| CDR2014 | MCSR08X1003FTL | 2074335 | 100 | 0.014(HT) | 3dsman | FA_005 | N | O | O | O |
| F6ITU | régul CMS LDO +1.8V XC6201P182PRN | 1106655 | 4 | 0,49 €(HT) | 3dsman | FA_005 | N | O | O | O |
| F6ITU | régul CMS LDO +3.3V XC6201P332PR | 3605711 | 2 | 0,41 €(HT) | 3dsman | FA_005 | N | O | O | O |
| F6ITU | régul CMS LDO +1,5V LP5951MF-1.5 | 1312652 | 2 | 0,68 €(HT) | 3dsman | FA_005 | N | O | O | O |
| F6ITU | Ref tension +2,5V LM4132CMF | 1312757 | 2 | 2,85 €(HT) | 3dsman | FA_005 | N | O | O | O |
| F6ITU | schottky | 1651114RL | 5 | 0,53 €(HT) | 3dsman | FA_005 | N | O | O | O |
| F6ITU | tank coil | 2062736 | 1 | 0,83 €(HT) | 3dsman | FA_005 | N | O | O | O |
| Axone | LM35CAZ | 9494529 | 2 | 4.65 €(HT) | 3dsman | FA_005 | N | O | O | O |
| N-i-c-o | STP6NK60ZFP (MOSFET N 600V 6A) | 9803289 | 2 | 1.61 €(HT) | 3dsman | FA_005 | N | O | O | O |
| N-i-c-o | Tresse à dessouder 2,5mm | 876847 | 1 | 3.03 €(HT) | 3dsman | FA_005 | N | O | O | O |
| N-i-c-o | Jack mâle stéréo 3,5mm | 1280662 | 5 | 0.75 €(HT) | 3dsman | FA_005 | N | O | O | O |
| MAZ24 | Microchip 16F753-I/P | 2360788 | 10 | 1,47 | 3dsman | FA_005 | N | O | O | O |
| MAZ24 | Capteur effet hall SS341RT | 1784727 | 10 | 0.85 | 3dsman | FA_005 | N | O | O | O |
| Thomas | IRLH5030TRPBF | 1831085 | 14 | 1.24 | 3dsman | FA_005 | N | O | O | O |
| Limesle | QRE1113GR - OPTO COMMUTATEUR REFLECTIF | 1471020 | 6 | 1.14 | 3dsman | FA_005 | N | O | O | O |
| Limesle | RESISTANCE METAL 10 OHM | 2329993 | 10 | 0.04 | 3dsman | FA_005 | N | O | O | O |
| Limesle | RESISTOR, METAL 20 OHM | 2330062 | 10 | 0.04 | 3dsman | FA_005 | N | O | O | O |
| Limesle | RESISTANCE METAL 51 OHM | 2330176 | 10 | 0.04 | 3dsman | FA_005 | N | O | O | O |
| Limesle | RESISTOR, METAL 30 KOHM | 2330102 | 10 | 0.04 | 3dsman | FA_005 | N | O | O | O |
| Limesle | RESISTOR, METAL 51 KOHM | 2330175 | 10 | 0.04 | 3dsman | FA_005 | N | O | O | O |
| Limesle | RESISTOR, METAL 100 KOHM | 1563073 | 10 | 0,048 | 3dsman | FA_005 | N | O | O | O |
| PAPY F1CHF | ECLATEUR A GAS 300V 15KA | 2148133 | 10 | 0.39 | 3dsman | FA_005 | N | O | O | O |
| Victor | DS18B20 THERMOMETER | 1187948 | 2 | 4,89€ (HT) | 3dsman | FA_005 | N | O | O | O |
| Goldo | ANALOG DEVICES - ADUM3223BRZ - DRIVER GATE 1MHZ 4A 4.5V 16SOIC | 2127170 | 2 | 4,07€ (HT) | 3dsman | FA_005 | N | O | O | O |
| Goldo | PANASONIC - ERJP14J3R9U - RESISTANCE SURGE 1210 5% 3R9 | 1750886 | 25 | 0,06€ (HT) | 3dsman | FA_005 | N | O | O | O |
| Goldo | ATMEL - ATMEGA1284P-PU - MICRO 8 BITS AVR 128K FLASH 40PDIP | 1715481 | 1 | 6,40€ (HT) | 3dsman | FA_005 | N | O | O | O |
| MAZ24 | contacts molex 08-55-110 | 2313553 | 200 | 0,075 | 3dsman | FA_005 | N | O | O | O |
| MAZ24 | boitier molex 22-01-2025 | 143126 | 30 | 0,224 | 3dsman | FA_005 | N | O | O | O |
| MAZ24 | boitier molex 22-01-2035 | 143127 | 20 | 0,26 | 3dsman | FA_005 | N | O | O | O |
| MAZ24 | Embase coudée 6voies AMP | 2215288 | 10 | 0,39 | 3dsman | FA_006 | N | O | N | N |
| MAZ24 | Femelle IDC 6voies AMP | 2215245 | 10 | 0,37 | 3dsman | FA_006 | N | O | N | N |
| MAZ24 | HEADER, 2.54MM, PIN, R/A, 10WAY | 1841228 | 10 | 1,24 | 3dsman | FA_006 | N | O | N | N |
| MAZ24 | EMBASE MALE 3 VOIES MOLEX | 1462932 | 20 | 0,45 | 3dsman | FA_006 | N | O | N | N |
| Maz24 | Cordon 6 voies F/F 150 mm | 2217605 | 5 | 1,82 | 3dsman | FA_006 | N | O | N | N |
| Jnat | DEV BRD, NUCLEO STM32F0, STM32F030R8 | 2394225 | 2 | 11.18 | 3dsman | FA_006 | N | O | N | N |
| Jnat | DEV BRD, NUCLEO STM32F4, STM32F401RE | 2394223 | 2 | 11.18 | 3dsman | FA_006 | N | O | N | N |
| Jnat | DEV BRD, NUCLEO STM32L1, STM32L152RE | 2394227 | 2 | 11.18 | 3dsman | FA_006 | N | O | N | N |
| Burnyfighter 'Pierre' | MC34152PG - DRIVER MOS RAPIDE | 9664424 | 10 | 1.18HT | 3dsman | FA_006 | N | O | N | N |
| Eric | lot de 5 pcs SAMTEC - SMS-115-01-S-S - SOCKET, 1.27 X 2.54MM, 1X15WAY Réf: SMS-115-01-S-S (header femelle droit) | 1804970 | 1 | 4,66EURHT | MrPozor | FA_007 | N | O | O | O |
| Eric | lot de 5 pcs SAMTEC HEADER, 1.27MM, THT, R/A, 15WAY Réf: TMS-115-01-L-S-RA (header male coudé) | 2055131 | 1 | 3,33EURHT | MrPozor | FA_007 | N | O | O | O |
| MrPozor | CONDENSATEUR 68UF 400V 18X25MM | 1673496 | 1 | 2.07 | MrPozor | FA_007 | N | O | O | O |
| MrPozor | CAP, ALU ELEC, 1000UF, 10V, RAD | 2346253 | 2 | 0.34 | MrPozor | FA_007 | N | O | O | O |
| MrPozor | CONDENSATEUR 470UF 25V | 8126461 | 2 | 1.03 | MrPozor | FA_007 | N | O | O | O |
| MrPozor | CAP, ALU ELEC, 47UF, 50V, RAD | 2346604 | 1 | 0.174 | MrPozor | FA_007 | N | O | O | O |
| MrPozor | CAPACITOR RADIAL 50V 0.68UF | 1902067 | 5 | 0.199 | MrPozor | FA_007 | N | O | O | O |
| MrPozor | CONDENSATEUR 1UF 50V | 8126933 | 1 | 0.27 | MrPozor | FA_007 | N | O | O | O |
| MrPozor | CAPACITOR RADIAL 50V 4.7UF | 1902072 | 5 | 0.083 | MrPozor | FA_007 | N | O | O | O |
| Goldo | EMBASE VERTICAL 2.54MM 40VOIES | 2215314 | 4 | 0.82 | MrPozor | FA_007 | N | O | O | O |
| Goldo | BOUTON D'URGENCE | 1606956 | 1 | 21.31 | MrPozor | FA_007 | N | O | O | O |
| Thomas | Diode | 1456535 | 10 | 0.097 | MrPozor | FA_007 | N | O | O | O |
| Thomas | Diode | 1621821 | 20 | 0.05 | MrPozor | FA_007 | N | O | O | O |
| Thomas | connecteur | 1278365 | 6 | 0.84 | MrPozor | FA_007 | N | O | O | O |
| Thomas | stm32f303 micro | 2215110 | 2 | 8.62 | MrPozor | FA_007 | N | O | O | O |
| Lab | TEXAS INSTRUMENTS - TLC555CP | 1103036 | 400 | 0.239 | MrPozor | FA_007 | N | O | O | O |
| Lab | CAP MLCC X7R 100NF 50V RAD | 2309020 | 1000 | 0.022 | MrPozor | FA_007 | N | O | O | O |
| Lab | RESISTANCE CARBON 1M0 0.25W 5% CFR16J1M0 | 2329490 | 1000 | 0.008 | MrPozor | FA_007 | N | O | O | O |
| F4GRX | BS250FTA MOSFETCANAL P45V0.09ASOT23-3 | 1843731 | 25 | 0.47 | MrPozor | FA_007 | N | O | O | O |
| F4GRX | BS170 TRANSISTOR MOSFET N TO-92 | 1017687 | 25 | 0.206 | MrPozor | FA_007 | N | O | O | O |
| F4GRX | BS170F TRANSISTOR MOSFET CANAL N SOT-23 | 9526005 | 25 | 0.40 | MrPozor | FA_007 | N | O | O | O |
Gotronic
| CDR2014 | connecteurs miniatures nsk254 male coudé 4cts | 48712 | 10 | 0.12€ | GO_001 | N | O | N | N | |
| CDR2014 | connecteurs miniatures nsk254 male droit 4cts | 48717 | 10 | 0.12€ | GO_001 | N | O | N | N | |
| CDR2014 | connecteurs miniatures nsk254 femelle 4cts | 48722 | 10 | 0.08€ | GO_001 | N | O | N | N | |
| CDR2014 | connecteurs miniatures nsk254 contacts | 48722 | 5 | 0.20€ | GO_001 | N | O | N | N | |
| CDR2014 | connecteurs miniatures nsk396 male coudé 3cts | 48691 | 10 | 0.15€ | GO_001 | N | O | N | N | |
| CDR2014 | connecteurs miniatures nsk396 male droit 3cts | 48694 | 10 | 0.15€ | GO_001 | N | O | N | N | |
| CDR2014 | connecteurs miniatures nsk396 femelle 3cts | 48697 | 10 | 0.10€ | GO_001 | N | O | N | N | |
| CDR2014 | connecteurs miniatures nsk396 contacts | 48698 | 4 | 0.55€ | GO_001 | N | O | N | N | |
| CDR2014 | pince a sertir les cosses de petites section | 13169 | 1 | 24.50€ | GO_001 | N | O | N | N | |
| CDR2014 | 300 colliers a sertir | 11357 | 1 | 5.50€ | GO_001 | N | O | N | N | |
| CDR2014 | Roue métallique OW006 | 25894 | 4 | 2.50€ | GO_001 | N | O | N | N | |
| 3dsman | 300 colliers a sertir | 11357 | 1 | 5.50€ | GO_001 | N | O | N | N | |
| 3dsman | gaine thermoretractable 1.6mm | 08840 | 1 | 1.00€ | GO_001 | N | O | N | N | |
| 3dsman | gaine thermoretractable 2.4mm | 08851 | 1 | 1.10€ | GO_001 | N | O | N | N | |
| 3dsman | gaine thermoretractable 3.2mm | 08841 | 1 | 1.20€ | GO_001 | N | O | N | N | |
| 3dsman | pack de 65 cables de conection m/m bbj2 | 12309 | 1 | 5.50€ | GO_001 | N | O | N | N | |
| Axone | BP rond | 07116 | 2 | 1.10€ | GO_001 | N | O | N | N | |
| Pilou | Paire de motoréducteurs DG01D | 31076 | 1 | 6.6€ | GO_001 | N | O | N | N | |
| Pilou | Adaptateur roue - moteur WMA | 31728 | 1 | 0.6€ | GO_001 | N | O | N | N | |
Mini-Circuits
Naviguer vers la page des commandes Mini-Circuits en cours
Mouser Electronics
Naviguer vers la page des commandes Mouser Electronics en cours
| Demandeur | Description | Ref Mouser | Quantité | Prix unitaire | Acheteur | Commande n° | Payé d'avance (O/N) | Commandé (O/N) | Distribué (O/N) | Remboursé/Archive (O/N) | |||||||||||
| Clem | condo cms low esr shield GSM | 74-592D228X96R3X2T | 1 | 6,92 € | <Acheteur> | DI_XXX | N | O | O | O | |||||||||||
| F6ITU+F1APY+F4HDA+F4GRX | transfo 1:1 4,5MHz-3GHz M/A Com | 937-ETC1-1-13TR | 4x10 | 1,55€ | <f6itu par défaut> | Mou002 | N | O | O | O | |||||||||||
| Jnat | Divers | Multiple | - | - | Jnat | [Mouser20121113] | N | O | O | O | |||||||||||
| Thomas | Carte dev MachXO2 | 1 | 25,34 | Thomas | panier http://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=902be54002 | N | O | O | O | ||||||||||||
| CydGy | transfo courant 1:1000 | 911-CT05-1000 | 1 | 4,02 € | Thomas | MO_002 | N | O | N | O | |||||||||||
| CydGy | transfo courant 1:500 | 553-CSE187LP | 1 | 3,74 € | Thomas | MO_002 | N | O | N | O | |||||||||||
| CydGy | transfo audio 1.2k:8 | 42TM003-RC | 1 | 2,30 € | Thomas | MO_002 | N | O | N | O | |||||||||||
| CydGy | microphone | 665-AOM6545PR | 1 | 0,726 € | Thomas | MO_002 | N | O | N | O | |||||||||||
| CydGy | microphone | 254-ECM96-RO | 1 | 1,66 € | Thomas | MO_002 | N | O | N | O | |||||||||||
| CydGy | HP speaker | 665-AST-03208MR-R | 1 | 2,17 € | Thomas | MO_002 | N | O | N | O | |||||||||||
| CydGy | HP speaker | 665-AST1732MR-R | 1 | 2,80 € | Thomas | MO_002 | N | O | N | O | |||||||||||
| CydGy | res 10m | 660-RK1/4DC1005F | 2 | 0,413 € | Thomas | MO_002 | N | O | N | O | |||||||||||
| Guillaume | CER RESONATOR 16.0MHZ SMD | [490-1198-1-ND] | 5 | 0,41 € | Thomas | MO_002 | N | O | O | O | |||||||||||
| Guillaume | Regulateur CMS 3.3V | [579-MCP1824T-3302EOT] | 5 | 0,43€ | Thomas | MO_002 | N | O | O | O | |||||||||||
| Axone | Supports CI et composants 28P | 571-1-390261-9 | 2 | 0.31€ | Thomas | MO_002 | N | O | O | O | |||||||||||
| Axone | Quartz 16MHz 20pF | 73-XT49S1600-20 | 2 | 0.404€ | Thomas | MO_002 | N | O | O | O | |||||||||||
| Axone | Capteur température LM35 | 926-LM335AZ/NOPB | 3 | 1.24€ | Thomas | MO_002 | N | O | O | O | |||||||||||
| Yann | Cable FFC/FPC 16p 1mm 20cm | 538-21039-0325 | 1 | 4.49€ | Thomas | MO_002 | N | O | O | O | |||||||||||
| Yann | Socket USB-A SMT | 649-87583-2010BLF | 1 | 0.58€ | Thomas | MO_002 | N | O | O | O | |||||||||||
| Yann | Cable USB | 538-88732-8702 | 2 | 1.69€ | Thomas | MO_002 | N | O | O | O | |||||||||||
| Yann | Kit de dev EXP430F5529 | 595-MSPEXP430F5529LP | 1 | 12.57€ | Thomas | MO_002 | N | O | O | O | |||||||||||
| Lab | Circuit Intégré BTS3408GXUMA2 SOT8 marque : Infineon | 726-BTS3408GXUMA2 | 2 | 1,73€ | Ellyan | MO_003 | N | O | N | N | |||||||||||
| Clem/lab | switch glissiere smd spdt cms | 688-SSSS810701 | 25 | 0,128 € | Ellyan | MO_003 | O | O | O | O | |||||||||||
| Eric | Circuit Intégré BTS3408GXUMA2 SOT8 marque : Infineon | 726-BTS3408GXUMA2 | 2 | 1,73€ | Ellyan | MO_003 | N | O | O | O | |||||||||||
| Guillaume | Connecteurs HDMI FCI | [649-10029449-002TLF] | 1 | 0.899€ | Ellyan | MO_003 | N | O | N | N | |||||||||||
| CDR2014 | Résistances détection de courant - CMS 0.010ohms 1% | 652-CRA2512FZR010ELF | 1 | 0,48€ | Ellyan | MO_003 | N | O | N | N | |||||||||||
| Eric | CI PI TNY254PN DIP8 | 869-TNY254PN | 3 | 1,36 | Ellyan | MO_003 | N | O | O | O | |||||||||||
| Ellyan | Convertisseur 48V=12V CC3-4812SF-E | 967-CC3-4812SF-E | 1 | 8,97€ | Ellyan | MO_003 | O | O | O | N | |||||||||||
| Ellyan | Alimentation Mean Well SP240-48 | 709-SP240-48 | 1 | 65,08€ | Ellyan | MO_003 | O | O | O | N | |||||||||||
| Julien Len | NXP Semiconductors SC18IS602BIPW,128 | 771-SC18IS602BIPW128 | 10 | 18 | Clement | MO_004 | N | O | N | N | |||||||||||
| Goldo | Convertisseur 24V=12V CC10-2412SF-E | 967-CC10-2412SF-E | 1 | 21,01€ | Clement | MO_004 | O | O | O | O | |||||||||||
| Tom Magnier | ?? | 941-CLM3AWKWCWAXA153 | 6 | ?€ | Clement | MO_004 | O | O | O | O | |||||||||||
| Tom Magnier | ?? | 941-XQBAWT020000L051 | 6 | ?€ | Clement | MO_004 | O | O | O | O | |||||||||||
| Théotime | ?? | 692-Z84C0006PEG | 1 | 3.31€ | Clement | MO_004 | O | O | O | O | |||||||||||
| Clement | module bluetooth audio/data | 765-RN52-I/RM | 2 | 18,64€ | Clement | MO_004 | X | O | O | O | |||||||||||
| Clement | Ecran 1.44" | 971-LCD-144-G2 | 1 | 27.10€ | Clement | MO_004 | X | O | O | O | |||||||||||
| Laurent | Ampli Op instrumentation | 584-AD623ANZ | 4 | 3.79€ | 3dsman | MO_005 | N | O | N | N | |||||||||||
| Laurent | Diodes | 512-1N4004 | 10 | 0,097€ | 3dsman | MO_005 | N | O | N | N | |||||||||||
| Dom | Jack Switchcraft S12B / Connecteurs téléphoniques 3 CONDUCTOR .210"ID | 502-S-12B | 4 | 2,95 € | 3dsman | MO_005 | N | O | N | N | |||||||||||
| Raoul&3dsman | STM32F0 nucleo board | 511-NUCLEO-F030R8 | 2 | 8,26 € | 3dsman | MO_005 | O | O | N | N | |||||||||||
| Thomas | connecteur mezzanine | 649-61083-102402LF | 2 | 4.69 € | 3dsman | MO_005 | O | O | N | N | |||||||||||
| Thomas | quartz 16MHz | 732-TX325-16F18X-AC3 | 10 | 0.40 € | 3dsman | MO_005 | O | O | N | N | |||||||||||
| Thomas | logement molex | 538-22-01-2035 | 20 | 0.148 € | 3dsman | MO_005 | O | O | N | N | |||||||||||
| Thomas | pin à sertir molex | 538-08-50-0136 | 100 | 0.045 € | 3dsman | MO_005 | O | O | N | N | |||||||||||
| Thomas | capteur de couleur | 856-TCS34717FN | 1 | 2.04 € | 3dsman | MO_005 | O | O | N | N | |||||||||||
| Thomas | IMU 9 axes | 511-LSM9DS0TR | 1 | 7.65 € | 3dsman | MO_005 | O | O | O | O | |||||||||||
| Thomas | capteur de pression | 262-BMP183 | 1 | 2.34 € | 3dsman | MO_005 | O | O | O | O | |||||||||||
| Thomas | capteur de pression | 511-LPS25HTR | 1 | 3.78 € | 3dsman | MO_005 | O | O | O | O | |||||||||||
| Thomas | connecteur hermaphrodite | 649-10106813034112LF | 3 | 1.10 € | 3dsman | MO_005 | O | O | O | O | |||||||||||
| Théotime | EEPROM 64Kbit | 556-AT28C64B15PU | 1 | 3,73 € | 3dsman | MO_005 | O | O | O | O | |||||||||||
| Théotime | SRAM 256 Kbit | 913-AS6C62256-55PCN | 1 | 1,43 € | 3dsman | MO_005 | O | O | O | O | |||||||||||
| Théotime | Clock Oscillator 4MHz | 815-ACO-4-EK | 1 | 1,61 € | 3dsman | MO_005 | O | O | O | O | |||||||||||
| Théotime | Clock Oscillator 6MHz | 520-TCF600-X | 1 | 1,50 € | 3dsman | MO_005 | O | O | O | O | |||||||||||
| Théotime | z80 CPU | 692-Z84C0006PEG | 1 | 3,31 € | 3dsman | MO_005 | O | O | O | O | |||||||||||
| Raoul | Shunt mirror | 522-ZXCT1009FTA | 5 | 0,82 € | 3dsman | MO_005 | N | 0 | N | N | |||||||||||
| Raoul | Temp sensor | 579-MCP9701AT-E/TT | 5 | 0,27 € | 3dsman | MO_005 | N | O | N | N | |||||||||||
| Raoul | STM32F030K6T6 | 511-STM32F030K6T6 | 10 | 1,00 € | 3dsman | MO_005 | N | O | N | N | |||||||||||
| Raoul | STM32F030C8T6 | 511-STM32F030C8T6 | 2 | 1,70 € | 3dsman | MO_005 | N | O | N | N | |||||||||||
| Théotime | SMD Clock Oscillator | 815-ASV-50-EJ-T | 1 | 2,01 € | 3dsman | MO_005 | N | O | N | N
Clement | module wifi cc3000 | 741-450-0067 | 1 | 22,29€ | <acheteur> | MO_006 | N | N | N | N |
| Clement | module Ecran nokia 3310 84x84 pixel B&W | 909-MOD-LCD3310 | 1 | 7,63€ | <acheteur> | MO_006 | N | N | N | N | |||||||||||
| Clement | cable prog 4D systems | 971-4D-PROGM-CABLE | 1 | 17,03 € | <acheteur> | MO_006 | N | N | N | N | |||||||||||
| Clement | atmega32u4 tqfp-44 | 556-ATMEGA32U4-AU | 25 | 3,14 € | <acheteur> | MO_006 | N | N | N | N | |||||||||||
| Clément | Cypress Semiconductor Cartes et kits de développement - ARM PSoC 4200 Prototyping Kit | 727-CY8CKIT-049-42XX | 1 | 3,20 € | <acheteur> | MO_006 | N | N | N | N | |||||||||||
| Clément | Cypress Semiconductor Cartes et kits de développement - ARM PSoC 4100 Prototyping Kit | 727-CY8CKIT-049-41XX | 1 | 3,20 € | <acheteur> | MO_006 | N | N | N | N | |||||||||||
| Clément | Connecteur audio 1/8" vertical 5 point | 523-ACJS-MV35-5 | 10 | 1.06 € | <acheteur> | MO_006 | N | N | N | N | |||||||||||
| Clément | ampli audio casque | 595-TPA6112A2DGQR | 10 | 1,31 € | <acheteur> | MO_006 | N | N | N | N | |||||||||||
| Thomas & Raoul | capteur de couleur | 985-TCS34725FN | 3 | 2.18 € | <acheteur> | MO_006 | N | N | N | N | |||||||||||
Nouvelle Plastique
Naviguer vers la page des commandes Nouvelle Plastique en cours
Olimex
Naviguer vers la page des commandes Olimex en cours
Otelo
Naviguer vers la page des commandes Otelo en cours
Radiospares
| Demandeur | Description | Ref RS | Quantité | Prix unitaire | Acheteur | Commande n° | Payé d'avance (O/N) | Commandé (O/N) | Distribué (O/N) | Remboursé/Archive (O/N) |
| Pilou | Lot de 10 RESSORTS 28MM | 751-528 | 1 | 2,99€ | RS_001 | N | O | O | O | |
| Eric | Clé réglable à mâchoires extra fines 8" marque Bahco ref 9031-T | 710-8798 | 1 | 31,23€HT | RS_001 | N | O | O | O | |
| Lab | Lot de 5 résistance 1% 1W 10R SFERNICE | 123-162 | 2 | 2.784€HT | Yannick | RS_001 | N | O | O | ? |
| Lab | lot de 4 filtres ref T0058711718 pour station à dessouder Weller | 358-9483 | 1 | 24,10€HT | <Yannick> | RS_002 | N | O | O | ? |
| Eric | lot de 4 filtres ref T0058711718 pour station à dessouder Weller | 358-9483 | 1 | 24,10€HT | <Patrick> | RS_003 | N | O | O | O |
| Gérard | Lot de 100 contacts à sertir Connecteur Molex 3,96mm AWG 22-28 | [1] 245-4718 | 1 | 7,50€HT | <Patrick> | RS_003 | N | O | O | O |
| Michel | contacts a sertir Molex 2,54mm AWG 22-28 | 720-6646 | 300 | 0,052 | <Patrick> | RS_003 | N | O | O | O |
| Michel | Embases Molex droites 2b 2,54 | 679-5515 | 30 | 0,31 | <Patrick> | RS_003 | N | O | O | O |
| Michel | Embases Molex coudées 2b 2,54 | 173-2916 | 20 | 0,726 | <Patrick> | RS_003 | N | O | O | O |
| Michel | Embases Molex coudées 4b 2,54 | 173-2944 | 10 | 1,02 | <Patrick> | RS_003 | N | O | O | O |
| Michel | Boitiers Molex 2b 2,54 | 687-7890 | 100 | 0,044 | <Patrick> | RS_003 | N | O | O | O |
| Michel | Boitiers Molex 4b 2,54 | 687-7900 | 20 | 0,233 | <Patrick> | RS_003 | N | O | O | O |
| Patrick | Pile CR2016 | 457-4735 | 2 | 2,19 | <Patrick> | RS_003 | N | O | O | O |
| Patrick | Pile CR2032 | 457-4757 | 2 | 2,19 | <Patrick> | RS_003 | N | O | O | O |
| Patrick | 5 Piles montre SR66 | 514-7766 | 1 | 2,29 | <Patrick> | RS_003 | N | O | O | O |
| Patrick | 5 Piles montre SR59 | 514-7744 | 1 | 4,40 | <Patrick> | RS_003 | N | O | O | O |
| Patrick | 5 Piles montre SR41 | 593-401 | 2 | 10,51 | <Patrick> | RS_003 | N | O | O | O |
| Eric | CI STM L4981B | 189-1144 | 2 | 2,15 | <Patrick> | RS_003 | N | O | O | O |
| Eric | Condensateur alu Nichicon 50V 1uF radial ESR:2Ohms ref UBT1H010MPD8 | 762-1727 | 10 (UDV) | 0,384 | <Patrick> | RS_003 | N | O | O | O |
| Eric | Condensateur alu Nichicon 25V 220uF radial ESR:0,1Ohms ref UBT1E221MPD8 | 762-1682 | 5 (UDV) | 0,85 | <Patrick> | RS_003 | N | O | O | O |
| Eric | Condensateur alu Nichicon 50V 2,2uF radial ESR:1,8Ohms ref UBT1H2R2MPD8 | 762-1720 | 5 (UDV) | 0,518 | <Patrick> | RS_003 | N | O | O | O |
| Eric | Condensateur alu Panasonic 450V 10uF radial Ref EEUEE2W100 | 699-7569 | 5 (UDV) | 0,786 | <Patrick> | RS_003 | N | O | O | O |
| Lab | Condensateur MKT Vishay 0.1uF 275VCA "X2" ref F1772-410-2200-E3 | 148-474 | 20 (UDV) | 0,657 | <Patrick> | RS_003 | N | O | O | O |
| Lab | Condensateur PET Kemet 10nF 220 V c.a., 630 V c.c. 4 x 9 x 13mm ref R60PF2100AA30J | 824-351 | 5(UDV) | 0,418 | <Patrick> | RS_003 | N | O | O | O |
| Patrick | Axial AL cap, 4700uF, 25V | 707-6708 | 2(UDV) | 2,42 | <Patrick> | RS_003 | N | O | O | O |
| Patrick | Perchlorure de fer en granulé (delai 14 jours mini 50€ H.T.) | 2550514751 | 1(UDV) | 4,2 | <Patrick> | RS_004 | N | O | O | O |
| Patrick | lot 2 piles 12V A23 Duracel | 717-4029 | 6 | 3,21 | <Patrick> | RS_003 | N | O | O | O |
| Lab | lot 5 languettes Kapton fer dessouder Weller ref T0051361699 | 176-1829 | 1 | 10,70 | <Patrick> | RS_003 | N | O | O | O |
| Lab | DS114 buse de dessoudage 3, 3 - 1,8mm Weller ref T0051351499 | 517-621 | 2 | 9,80 | <Patrick> | RS_003 | N | O | O | O |
| Eric | DS114 buse de dessoudage 3, 3 - 1,8mm Weller ref T0051351499 | 517-621 | 1 | 9,80 | <Patrick> | RS_003 | N | O | O | O |
| Lab | CI MOC3020 | 761-3388 | 10 (UDV) | 0,616 | <Patrick> | RS_004 | N | O | O | N |
| Eric | DS119 aiguille d'aspiration Weller ref T0051352700 | 2550520811 | 1 | 9,00 | <Patrick> | RS_004 | N | O | O | O |
| Eric | DS BUSE DE CALIBRAGE Weller ref T0052474999 | 2550520910 | 1 | 6,10 | <Patrick> | RS_004 | N | O | O | O |
| Lab | lot de 5 ressorts pour filtres ref T0058711720 pour station à dessouder Weller | 2550521588 (delai 21 jours mini 50€ H.T.) | 1 | 5,50€HT | <Patrick> | RS_004 | N | O | O | O |
| Eric | Bouchon fileté de filtre ref T0058711719 pour station à dessouder Weller | 2550521587 (delai 21 jours mini 50€ H.T.) | 1 | 4€HT | <Patrick> | RS_004 | N | O | O | O |
| Eric | Lot de 5 joints pour bouchon fileté de filtre ref T0051344499 pour station à dessouder Weller | 2550520804 (delai 21 jours mini 50€ H.T.) | 1 | 4,20€HT | <Patrick> | RS_004 | N | O | O | O |
| Lab | FORETS DE RECHANGE STANDARD 0,6 mm / 0,9 mm / 1,4 mm / 1,9 mm pour outil de nettoyage Weller ref T0051350199 | 2550520805 (delai 21 jours mini 50€ H.T.) | 1 | 15,10 | <Patrick> | RS_004 | N | O | O | N |
| Eric | Fusible cartouche 6.3mm x 32 mm 12A FF | 420-224 | 10 | 1,502 | Raoul | RS_005 | N | O | O | O |
| Eric | Fusible cartouche 6.3mm x 32 mm 15A T | 668-6095 | 10 | 0.248 | Raoul | RS_005 | N | O | O | O |
| Eric | Thermocouple type K en fibre de verre lg : 2m -50°C +1100°C | 621-2170 | 1 | 7.16 | Raoul | RS_005 | N | O | O | O |
| Eric | CI BQ2954 | 662-2319 | 2 | 3,88 | Raoul | RS_005 | N | O | O | O |
| Lab | GAINE THERMO 2.4MM recharge 10m | 170-6030 | 1 | 17.00 | Raoul | RS_005 | N | O | O | N |
| Lab | GAINE THERMO 1.6MM recharge 10m | 170-6024 | 1 | 17.00 | Raoul | RS_005 | N | O | O | N |
| Lab | GAINE THERMO 6,4MM recharge 8m | 170-6074 | 1 | 17.00 | Raoul | RS_005 | N | O | O | N |
| Patrick | DS1307 | 761-9759 | 2 | 2.92 | Raoul | RS_005 | N | O | O | O |
| Patrick | 74LS132 | 663-2401 | 5 | 0.526 | Raoul | RS_005 | N | O | O | O |
| Patrick | 74HC125 | 113-0528 | 5 | 0.20 | Raoul | RS_005 | N | O | O | O |
| Florent | Cosse à sertir robuste M6, fil 10mm² | 531-021 | 50 | 0.248 | Raoul | RS_006 | N | O | N | N |
| Thomas | Seringue pate à braser | 551-693 | 1 | 22,13 | RS_006 | N | N | N | N | |
| Thomas | Convertisseur CC/CC, 9-36V entrée, 5V | 733-1878 | 1 | 42.90 | Raoul | RS_006 | N | O | N | N |
| Goldo | Crochets Velcro Autoagrippants noirs 5m | 549-921 | 1 | 10.34 | Raoul | RS_006 | N | O | N | N |
| Goldo | Boucles Velcro Autoagrippants noirs 5m | 549-937 | 1 | 10.34 | Raoul | RS_006 | N | O | N | N |
| MAZ24 | boitiers Molex | 687-7890 | 30 | 0,04 | Raoul | RS_006 | N | O | N | N |
| MAZ24 | contacts Molex | 720-6643 | 300 | 0,02 | Raoul | RS_006 | N | O | N | N |
| MAZ24 | Embase 2 contacts Molex | 687-7269 | 30 | 0,326 | Raoul | RS_006 | N | O | N | N |
| Raoul | Alim dc/dc 12V 25W | 183-893 | 1 | 43.20 | Raoul | RS_006 | N | O | N | N |
Saint Quentin radio
Selectronic
| Lab | foret Hss-Co 3,2 mm | 9773-1 | 1 | 2,70€TTC | F4GRX | SE_001 | N | O | O | O |
| Lab | lot de 10 forets Hss 1 mm | 12.1820-10 | 1 | 8,50€TTC | F4GRX | SE_001 | N | O | O | O |
| Lab | lot 2 tournevis pour borniers | 12.9706 | 1 | 24,90€TTC | F4GRX | SE_001 | N | O | O | O |
| Eric | Embout TORX T8x25mm - Lot de 2 | 7075-23 | 1 | 2,90€TTC | F4GRX | SE_001 | O | O | O | O |
| Eric | Embout TORX T9x25mm - Lot de 2 | 7075-24 | 1 | 2,90€TTC | F4GRX | SE_001 | O | O | O | O |
| Eric | Condensateur électrochimique polarisé sortie radiale - 2,2µF 400V | 6495 | 3 | 0,80€TTC | F4GRX | SE_001 | O | O | O | O |
| Eric | Condensateur électrochimique polarisé sortie radiale - 10µF 400V | 1792-1 | 2 | 1,35€TTC | F4GRX | SE_001 | O | O | O | O |
| Eric | Condensateur électrochimique polarisé sortie radiale - 22µF 400V | 1792-3 | 1 | 2,70€TTC | F4GRX | SE_001 | O | O | O | O |
| Eric | Condensateur électrochimique polarisé sortie radiale - 47µF 400V | 1792-4 | 1 | 3,30€TTC | F4GRX | SE_001 | O | O | O | O |
| Lab | Condensateur électrochimique polarisé sortie radiale - 22µF - 50V - Lot de 2 | 9296-2 | 1 | 0,70€TTC | F4GRX | SE_001 | N | O | O | O |
| Lab | Lot de 10 fusibles 200mAT | 13.9795-10 | 1 | 2.20€TTC | Ellyan | SE_002 | N | O | O | O |
| Lab | Lot de 10 fusibles 2AT | 13.9705-10 | 1 | 1.70€TTC | Ellyan | SE_002 | N | O | O | O |
| Lab | Résistance couche métal 1% 40,2 ohm 0,6 W traversante | 4764 | 6 | 0,35€TTC | Pilou | SE_003 | N | O | O | O |
| Lab | Résistance de précision 1% à couche métallique de 10,00 ohm 0,6 W traversante | 4705 | 3 | 0,35€TTC | Pilou | SE_003 | N | O | O | O |
| Lab | Bouton 10mm Gris/grise | 13.0006 | 15 | 2.00€TTC | Pilou | SE_003 | N | O | O | O |
| Eric | Résistance cémentée - 10W - 39Ω | 1499-20 | 1 | 1,35€TTC | Pilou | SE_003 | N | O | O | O |
| Ellyan | Borne de service | 13.0902-12 | 1 | 2.00€TTC | Pilou | SE_003 | N | O | O | O |
| Ellyan | convertisseur SATA | 13.0669-9 | 2 | 8.50€TTC | Pilou | SE_003 | N | O | O | O |
| Lab | Pince à sertir (scrounches) | 13.5546.3 | 1 | Pilou | <plus vendu par selectronic> | N | N | N | O | |
| Lab | Bouchons/capuchons SEULS pour Bouton 10mm Gris/grise REF 13.0006 | <pas vendu par selectronic> | 6 | Pilou | N | O | N | O | ||
| Lab | voir aussi ce produit (bouton gris, bouchon bleu) qui convient mieux aux Hameg | 0004 ? ou 13.0004 <pas disponible> | 20 | 2.00€TTC | <acheteur> | SE_004 | N | N | N | O |
| Lab | SELECTRONIC ZD - Fer de rechange 24V 48W | 2130-5 | 2 | 13,90€TTC | Eric | SE_005 | N | O( | O | N |
| Lab | Bouton 10mm Gris/grise | 13.0006 | 7 | 2.00€TTC | Eric | SE_005 | N | O | O | N |
| Lab | Bouton alu. axe 6mm Diam. 29x14mm argent | 6087-4 | 1 | 1.84€TTC promo | Eric | SE_005 | N | O | O | N |
| Eric | Ajustable horizontal 10mm piste Cermet 2,2 kohm PIHER monotour | 3140 | 2 | 1.15€TTC | Eric | SE_005 | N | O | O | O |
| Eric | Ajustable horizontal 10mm piste Cermet 10 kohm PIHER monotour | 3136 | 2 | 1.15€TTC | Eric | SE_005 | N | O | O | O |
| Eric | Transformateur TOKO 707 VX -A043YUK compatible LM1893 | 7294 | 5 | 1.14€TTC promo | Eric | SE_005 | N | O | O | O |
| Eric | Thermistance CTN 4,7 kohm | 5276 | 4 | 0.90€TTC | Pilou | SE_006 | N | O | O | O |
| Eric | Varistance 275VRMS / 4000A 275 LA 40 diam 24mm | 9091 | 4 | 1.25€TTC | Pilou | SE_006 | N | O | O | O |
| Eric | Résistance cémentée - 20W - 47Ω | 1498-21 | 4 | 1.60€TTC | Eric | SE_007 | O | O | O | O |
SparkFun Electronics
