Les protocoles :
Les filtres :
Signal Path
Alexandrie
Schéma
Principe de fonctionnement
Coté réception
Coté émission
BOM
Github/Gerber
Alexi2C
Schéma
BOM
Github/Gerber
Utilisations annexes
Alexiares_lpf
Schéma
BOM
On peut utiliser des condensateurs 500 V porcelaine (ATC) assez coûteux (environ 2 euros pièce), soit des condensateurs multicouche 1kV prévus pour travailler en HF, de la série Vishay "Quad HiFreq" (format 1111, disponibles chez Farnell).
Github/Gerber
To all lpf, hpf and Thémis users : Seb F4GRX pointed out to me that the output track to the SMA connectors was too close to the connector’s body. When soldered “flush” on the pcb, classic SMA angle connectors can pose some risks of short circuits or electrical arcing on the RF path (lpf filter and power measurement on Themis) It is therefore strongly recommended to insert a small 1 to 1.5mm caliper under the connector before soldering it (I have a little exaggerated the gap between pcb and connector for the need of illustration, but a spacing of 0.8mm is far enough)
The gap betwee the pcb and the SMA does not influence the impedance, the connection strength or the power handling of the connector. If you intend to solder an RF shield on LPF and HPF cards, you’ll have to cut and remove the center trace if you do not use an "Edge" connector.
If you have already soldered these connectors, don’t panic ... they are very easily un-soldered by putting a large blob of solder on the bottom side. The connector will fall by itself (thanks to the gravity), as the holes are wide enough. Following versions will fix these little details and the "Edge" connectors will all be removed
La précision de
Alimentez la carte en 12V
![](/images/thumb/7/7c/Lpf_complet.png/800px-Lpf_complet.png)
Alexiares_hpf
Schéma
BOM
Github/Gerber
Alexiares_Coax_Out
Schéma
BOM
Github/Gerber
Mentor
Schéma
BOM
Github/Gerber
Programmation :
Intégration :
Télémaque
Schéma
BOM
tbd
Github/Gerber
tbd
tbd
Aiôn
Schéma
Conseils de montage
BOM
Github/Gerber
Themis
Schéma
Schéma
BOM
Github/Gerber
![](/images/thumb/b/b6/Themis_photo.jpg/700px-Themis_photo.jpg)
Vérifications et mesures
- - Lancez un balayage.
La ligne de ROS (bleue) est plate et indique une quasi absence de réfléchi (1.02, 1.08)... normal, l'énergie est absorbée par la charge 50 Ohms. La courbe d’impédance (rouge) est un peu moins parfaite, de 46 à 49 Ohms (ce qui prouve que notre coupleur n’est pas parfaitement symétrique, un léger recentrage des « boucles » des transformateurs et une meilleur répartition des spires peut arranger les choses).
Themis V2.0
- Le relais a disparu
Hébé
Schéma tbd
BOM
Github/Gerber
