Projets:Commande groupee:archives
Commandes groupées en cours
Conrad Electronique France
COMMENTAIRE
| Limesle | LED verte 5 mm Hlmp Cm14-Z30Dd Avago Technologies HLMP-CM14-Z30DD | 181211 - 62 | 2 | 0,95€ | David | CO_001 | O | O | O | N |
| Limesle | LED blanche 5Mm 18000 Mcd | 180000 - 62 | 2 | 0,90€ | David | CO_001 | O | O | O | N |
| Patrick | Switch Dlink 1005D Gigabit | 973969 - 62 | 1 | 34,96€ | David | CO_001 | O | O | O | O |
| David | Troisième main Toolcraft ZD-10F | 588124 - 62 | 3 | 5,39 | David | CO_001 | O | O | O | N |
| David | Panne de rechange Toolcraft T-LB | 588240 - 62 | 1 | 5,59 | David | CO_001 | O | O | O | N |
| Thomas | Lot de pinces dauphin XDK 1033 | 100631 - 62 | 1 | 10,95 | David | CO_001 | N | O | O | N |
| Thomas | Fiche Banane de Securite rouge 4 mm MultiContact 22.3007-22 | 741502 - 62 | 1 | 6,79 | David | CO_001 | N | O | O | N |
| Thomas | Fiche Banane de Securite 4 mm MultiContact 22.3007-21 | 741489 - 62 | 1 | 6,79 | David | CO_001 | N | O | O | N |
| Thomas | Cordon de mesure 50 cm bleu MultiContact XVS-4075 66.9562-05023 | 106035 - 62 | 1 | 5,69 | David | CO_001 | N | O | O | N |
| Thomas | Cordon de mesure 50 cm noir MultiContact XVS-4075 66.9562-05023 | 126033 - 62 | 1 | 5,69 | David | CO_001 | N | O | O | N |
| Thomas | Cordon de mesure 50 cm rouge MultiContact XVS-4075 66.9562-05023 | 106034 - 62 | 1 | 5,69 | David | CO_001 | N | O | O | N |
| Patrick | Elément chauffant 12V 50/100/150W | 532894 - 62 | 2 | 10.95 | <Patrick> | CO_002 | O | O | O | O |
| Patrick | POMPE A AIR MEMBRANE | 530476-62 | 21 | 34.95 | <Patrick> | CO_002 | O | O | O | O |
| Patrick | Livre Arduino applications avancées | 095064-62 | 1 | 25.65 | <Patrick> | CO_002 | O | O | O | O |
| Alexander | CI Bus I2C PCF 8573P Philips | 064235 - 62 | 5 | 0.05 | <Patrick> | CO_002 | N | N article abandonné | N | N |
| Eric | Aérosol 200 ml CRC Kontakt Chemie Kontakt 60 | 813516 - 62 | 1 | 7.95 | <Patrick> | CO_002 | N | O | O | O |
| Eric | Nettoyeur de circuits imprimés 400 ml CRC Kontakt LR | 822812 - 62 | 1 | 11.95 | <Patrick> | CO_002 | N | O | O | O |
| Eric | Douille Ø 4 mm type PKI100 vert/jaune SKS Hirschmann ref 930757188 | 733928 - 62 | 6 | 3.00 | <Patrick> | CO_002 | N | O | O | O |
| Eric | Varistance 510 V Epcos S20K320E3K1 B72220P3321K101 | 531595 - 62 | 5 | 1.40 | <Patrick> | CO_002 | N | O | O | O |
| Lab | Coffret plastique 18 compartiments | 078156 - 11 | 1 | 14.90 | <Patrick> | CO_002 | N | O | O | O |
| David | Panne de rechange Toolcraft T-3.2D | 588228 - 62 | 1 | 6.99 | Patrick | CO_003 | N | O | O | O |
| Patrick | Entretoise laiton M/F 10mm vis 3mm | 526630 - 62 | 10 | 0,23 | Patrick | CO_003 | N | O | O | O |
| Patrick | Aérosol désodorisant bio Melon | 095485-62 | 1 | 10.95 | Patrick | CO_003 | N | O | O | O |
| Patrick | Set de 200 colliers naturels (lg. 100, 150, 200 et 250mm) | 541665 - 62 | 1 | 3,30 | <acheteur> | CO_003 | N | O | O | O |
| Patrick | Eponge pour fer à souder | 812374-62 | 1 | 2,07 | Patrick | CO_003 | N | O | O | O |
| Lab | Eponge pour fer à souder | 812374-62 | 9 | 2,07 | Patrick | CO_003 | N | O | O | O |
| Lab | Gants de protection Camatex en latex naturel/Coton Taille 10 KCL 450 | 893626 - 62 | 2 | 6,99 | <acheteur> | CO_003 | N | O | O | O |
| Lab | Régulateur 7915 | 179310 - 62 | 1 | 1,10 | Patrick | CO_003 | N | O | O | O |
| Lab | Lot de 100 Colliers 100 X 2,5 Naturel Marque HellermannTyton ref: 138-00001 | 617849 - 62 | 1 | 1,50 | Patrick | CO_003 | N | O | O | O |
| Lab | Set de 200 colliers naturels (lg. 100, 150, 200 et 250mm) | 541665 - 62 | 1 | 3,30 | Patrick | CO_003 | N | O | O | O |
| Eric | Spray air comprimé 400 ml Dataflash | 995809 - 62 | 2 | 6,99 | Patrick | CO_003 | N | O | O | O |
| Eric | Collier de serrage de tuyau acier fin 10 à 16 mm SUBHC000 serrage papillon | 541837 - 62 | 5 | 1,00 | Patrick | CO_003 | N | O | O | O |
| Eric | Collier de serrage inox Ø 9 à 13 mm | 544906 - 62 | 5 | 0,60 | Patrick | CO_003 | N | O | O | O |
| Lab | DOUILLE DE SECURITE 4mm ECROU NOIR , ref3265-I-0 | 326500 | 4 | 1.35 | Patrick | CO_003 | N | O | O | O |
| Lab | DOUILLE DE SECURITE 4mm ECROU VERT, ref3265-I-5 | 326505 | 3 | 1.35 | Patrick | CO_003 | N | O | O | O |
| Lab | DOUILLE DE SECURITE 4mm ECROU BLEU, ref3265-I-6 | 326506 | 1 | 1.35 | Patrick | CO_003 | N | O | O | O |
| 3dsman | Capteur de couleur RVB KPS-5130PD7C | 180381 - 62 | 5 | 1.70 | Patrick | CO_004 | N | o | O | O |
| Florent, 2 pour Patrick | Lames de fusible 80A | 535265-62 | 27 | 0,32 | Patrick | CO_004 | N | o | N | N |
| David | Fer à souder de rechange 100 W | 588281 - 62 | 1 | 37,95 | Patrick | CO_004 | N | o | N | N |
| David | Câble Ftp Cat5 Vert 10 M Bulk | 972081 - 62 | 1 | 11,95 | Patrick | CO_004 | N | o | N | N |
| Eric | Lot de 100 Colliers 245 X 4,5 Transparent Marque HellermannTyton ref: UB250C-N-PA66-NA-C1 13 | 617873 - 62 | 1 | 7.09 | <Patrick> | CO_004 | N | o | O | O |
| Eric | Lot de 100 Colliers 200 X 4,6 Transparent Marque HellermannTyton ref: UB200C-N-PA66-NA-C1 13 | 617865 - 62 | 1 | 4.50 | <acheteur> | CO_004 | N | o | O | O |
| Eric | Testeur de capteurs Marque : Contrinex | 155946 - 62 | 1 | 40.95 | <Patrick> | CO_004 | N | o | O | O |
| Eric +1 Patrick | Fiche allume-cigares femelle standard pour câble | 062857 - 62 | 2 | 1,99 | <Patrick> | CO_004 | N | o | O | O |
| FICHF | LM317LD | 155584 - 62 | 10 | 0,2 | Patrick | CO_004 | N | o | O | O |
| Patrick | support lame de fusible ESKA max 500A | 535222-62 | 2 | 2,7 | Patrick | CO_004 | N | o | O | O |
| Yann | brasure étain 0.5mm 100g | 812803 - 62 | 1 | 7.99€ | <Patrick> | CO_004 | N | o | O | O |
| Yann | brasure étain 1mm 100g | 812811 - 62 | 1 | 4.09€ | <Patrick> | CO_004 | N | o | O | O |
| Yann | fil à wrapper 0.20mm2 | 606075 - 62 | 1 | 5.49€ | <Patrick> | CO_004 | N | o | O | O |
| Lab | gaine spiralée 4-50mm | 546146 - 62 | 1 | 3.10€ | <Patrick> | CO_004 | N | o | O | O |
| Patrick | porte fusible 5X20 chassi | 533769-62 | 1 | 0.80€ | <Patrick> | CO_004 | N | o | O | O |
| Patrick | Fiche allume-cigares male standard pour câble | 062856-62 | 1 | 1.99€ | <Patrick> | CO_004 | N | o | O | O |
| Lab | 100 Embouts à collerette 9mm fil 4mm² | 617878 - 62 | 1 | 2.59€ HT | <Patrick> | CO_005 | N | O | N | N |
| Eric | Gants de protection Camatex en latex naturel/Coton Taille 10 KCL 450 | 893626 - 62 | 2 | 6,99 | <Patrick> | CO_005 | N | O | O | O |
| Léonard | Set de 4 prises avec télécommande | 099994 - 62 | 1 | 20,82 HT | <Patrick> | CO_005 | N | O | O | O |
| Léonard | Module émetteur AM 433,92 MHz kit monté alim 5 V puissance 10 mW Aurel TX-SAW MID/5 V | 191525 - 62 | 1 | 9,16 HT | <Patrick> | CO_005 | N | O | O | O |
| Léonard | Module récepteur 433 MHz Aurel Ac-Rx | 190276 - 62 | 1 | 6,68 HT | <Patrick> | CO_005 | N | O | O | O |
| Iggy | Module capteur PIR | 506177 - 62 | 1 | 10,83 HT | <Patrick> | CO_005 | 50 | O | N | N |
| Iggy | Module électronique pour modules capteurs IR | 506178 - 62 | 1 | 12,50 HT | <Patrick> | CO_005 | 50 | O | N | N |
| Iggy | Capteur Pir CMS 5V Hygrosens | 172526 - 62 | 1 | 26,71 HT | <Patrick> | CO_005 | 50 | O | N | N |
Naviguer vers la page des commandes en cours
Digikey
| Yann/Matthieu | SWITCH TACTILE SPST-NO 0.05A 24V | SW796-ND | 70 | 0.29580€ | Destynova | DI_002 | O | O | O | O |
| David | CONN PC VERT 9V SNAP-ON | 968K-ND | 100 | 0.57410€ | Destynova | DI_002 | O | O | O | O |
| Robotique(lab) | PCA9685 (i2c pwm) | 568-5931-1-ND | 2 | 2.17€ | Destynova | DI_002 | O | O | O | O |
| Robotique(lab) | MCP23017-E/SO (i2c io) | MCP23017-E/SO-ND | 2 | 1.22€ | Destynova | DI_002 | O | O | O | O |
| Robotique(lab) | ADS1015IDGST ADC 12BIT I2C W/REF | 296-25227-1-ND | 2 | 2.64€ | Destynova | DI_002 | O | O | O | O |
| Eric | DIODE ARRAY BYC10-600CT 600V 10A TO220AB | 568-1781-5-ND | 2 | 1,26 | 3dsman | DI_003 | N | O | O | O |
| Eric | OPAMP LT1637 PDIP8 | LT1637CN8#PBF-ND | 6 | 2.89 USD | 3dsman | DI_003 | N | O | O | O |
| 3dsman | ENCODER PROG 16RES SW TTL RADIAL | 102-1307-ND | 2 | 23.63 USD | 3dsman | DI_003 | O | O | O | O |
| 3dsman | SN65HVD3082EDR | 296-31719-1-ND | 5 | 2.42USD | 3dsman | DI_003 | O | O | O | O |
| 3dsman | ATMEGA48A-PU | ATMEGA48A-PU-ND | 1 | 2.04USD | 3dsman | DI_003 | O | O | O | O |
| 3dsman | ATMEGA88PA-PU | ATMEGA88PA-PU-ND | 1 | 2.45USD | 3dsman | DI_003 | O | O | O | O |
| 3dsman | ATMEGA88A-AU | ATMEGA88A-AU-ND | 2 | 2.13USD | 3dsman | DI_003 | O | O | O | O |
| 3dsman | TCS3104FN | TCS3104FNCT-ND | 1 | 1.8USD | 3dsman | DI_003 | O | O | O | O |
| 3dsman | CLA1B-WKW-XD0F0E13 | CLA1B-WKW-XD0F0E13CT-ND | 3 | 0.29USD | 3dsman | DI_003 | O | O | O | O |
| f6itu | xtal 12 MHz | 644-1047-1-ND | 2 | 0.87000 | 3dsman | DI_003 | N | O | N | N |
| thomas | ACS711EEXLT-15AB-T | 620-1481-1-ND | 10 | 1.158USD | 3dsman | DI_003 | N | O | N | N |
| Audran | EEU-FR1V471B | P15391CT-ND | 3 | 0.77€ | 3dsman | DI_003 | N | O | O | O |
| Audran | EEU-HD1E221B | P15737CT-ND | 1 | 0.88€ | 3dsman | DI_003 | N | O | O | O |
| Audran | 50PX47MEFCTA6.3X11 | 1189-1649-1-ND | 2 | 0.28€ | 3dsman | DI_003 | N | O | O | O |
| Audran | UPB1H3R3MDD1TD | 493-4941-1-ND | 1 | 0.36€ | 3dsman | DI_003 | N | O | O | O |
| Audran | EEU-FR1C102B | P15331CT-ND | 2 | 0.77€ | 3dsman | DI_003 | N | O | O | O |
| Audran | UPJ1A331MPD1TD | 493-5000-1-ND | 1 | 0.4€ | 3dsman | DI_003 | N | O | O | O |
| Audran | EEU-FR1E821B | P15368CT-ND | 4 | 0.87€ | 3dsman | DI_003 | N | O | O | O |
| Audran | 51761-10002406AALF | 609-3636-ND | 2 | 4.72€ | 3dsman | DI_003 | N | O | O | O |
Farnell
| Demandeur | Description | Ref Farnell | Quantité | Prix unitaire | Acheteur | Commande n° | Payé d'avance (O/N) | Commandé (O/N) | Distribué (O/N) | Remboursé/Archive (O/N) |
| Clem(pcb) | forets hss 0.8mm | 377650 | 1 (pack de 10) | a vérifier (de l'ordre de 10€ | ? | ? | N (boite a pcb) | O | O | O |
| Lab | Batterie 12V YUASA NP1.2-12 | 147472 | 1 | 15,90HT | Destynova | FA_001 | O | O | O | O |
| Eric | Batterie 12V YUASA NP1.2-12 | 147472 | 1 | 15,90HT | Destynova | FA_001 | O | O | O | O |
| Lab | Pile CR2450 LITHIUM 3V, 600MAH | 2065173 | 1 | 1,14HT | Destynova | FA_001 | O | O | O | O |
| Eric | Pile CR2450 LITHIUM 3V, 600MAH | 2065173 | 1 | 1,14HT | Destynova | FA_001 | O | O | O | O |
| Lab | Graphit 33 (spray) | 832959 | 1 | 9,35HT | Destynova | FA_001 | O | O | O | O |
| Lab | ROULEAU POUR DYMO N/B 9MM ref 40913 pour Labelmanager 450 | 667006 | 1 | 13,65HT | Destynova | FA_001 | O | O | O | O |
| Crafty | LINEAR TECHNOLOGY - LTC3105EMS#PBF - BOOST 400MA MPPC 12MSOP | 1898601 | 10 | 5,06 EHT | Destynova | FA_001 | O | O | O | O |
| Crafty | BOURNS - SRR0603-100ML - INDUCTANCE 10UH PUISSANCE BLINDE CMS | 2212495 | 10 | 0,48 EHT | Destynova | FA_001 | O | O | O | O |
| Crafty | SUNON - EB40200S2-0000-999 - VENTILATEUR. 40X40X20MM. 5VDC | 1924832 | 2 | 9,78 EHT | Destynova | FA_001 | O | O | O | O |
| Crafty | MULTICOMP - MCTE1-12715L-S - DISSIPATEUR PELTIER 130W | 1639728 | 1 | 31,93 EHT | Destynova | FA_001 | O | O | O | O |
| Crafty | MULTICOMP - MCPE1-07107AC-S - DISSIPATEUR PELTIER 31.1W | 1639723 | 1 | 28,81 EHT | Destynova | FA_001 | O | O | O | O |
| Crafty | MULTICOMP - MCPE1-03108NC-S - DISSIPATEUR PELTIER 18.8W | 1639720 | 1 | 19,40 EHT | Destynova | FA_001 | O | O | O | O |
| the_nihilant | ATMEL - ATMEGA48A-AU - MCU, 8BIT, AVR, 4K FLASH, 32TQFP | 1841612 | 4 | 2,07 HT | Destynova | FA_001 | O | O | O | O |
| the_nihilant | ATMEL - ATMEGA88A-AU - MCU, 8BIT, AVR, 8K FLASH, 32TQFP | 1841614 | 2 | 2,33 HT | Destynova | FA_001 | O | O | O | O |
| the_nihilant | ATMEL - ATMEGA324A-PU - MCU, 8BIT, AVR, 32K FLASH, 40PDIP | 1841611 | 3 | 4,28 HT | Destynova | FA_001 | O | O | O | O |
| the_nihilant | TEXAS INSTRUMENTS - SN74HC595DR - IC, SM, LOGIC, 74HC, REGISTER | 1607849 | 24 | 0,20 HT | Destynova | FA_001 | O | O | O | O |
| raoul(Robotique) | TEXAS INSTRUMENTS - TPS40210DGQ - IC, CTRLR CUR MODE BOOST 10MSOP | 1755634 | 2 | 3.28 HT | Destynova | FA_001 | O | O | O | O |
| raoul(Robotique) | TEXAS INSTRUMENTS - ADS7830IPWTG4 - CONVERTISSEUR A/N 8 BITS 8 CH CMS | 1180129 | 4 | 3.57 HT | Destynova | FA_001 | O | O | O | O |
| raoul(Robotique) | TEXAS INSTRUMENTS - TPS76333DBVT - REG DE TENSION LDO 0.15A 3.3V CMS 76333 | 8461376 | 2 | 1.14 HT | Destynova | FA_001 | O | O | O | O |
| Matthieu | KONTAKT WL | 837970 | 1 | 8.26 ht | David | FA_002 | N | O | O | N |
| Matthieu | KONTAKT 60 400ML | 2142395 | 1 | 10,93 ht | David | FA_002 | N | O | O | N |
| the_nihilant | YAGEO (PHYCOMP) - YC164-JR-071KL - RESEAU DE RESISTANCES ARV241 1206 1K | 9234519 | 10 | 0,096 HT | David | FA_002 | N | O | O | O |
| the_nihilant | ABRACON - ABL-20.000MHZ-B2 - CRYSTAL, 20M, 18PF CL, HC49/4H | 1611779 | 10 | 0,25 HT | David | FA_002 | N | O | O | 0 |
| the_nihilant | RALTRON - AS-16.000-18 - CRYSTAL, 16M, 18PF CL, HC49/4H | 1611761 | 10 | 0,25 HT | David | FA_002 | N | O | O | O |
| the_nihilant | TEXAS INSTRUMENTS - CD74HC164E - LOGIC, SHIFT REGISTER 8BIT HS, 14DIP | 1740095 | 16 | 0,30 HT | David | FA_002 | N | O | O | O |
| the_nihilant | MULTICOMP - 703-0100 - LED ROUGE 5MM STANDARD | 2112111 | 25 | 0,182 HT | David | FA_002 | N | O | O | O |
| the_nihilant | KEYSTONE - 2463 - SUPPORT POUR BATTERIE | 1702631 | 6 | 1,05 HT | David | FA_002 | N | O | O | O |
| the_nihilant | MICRO COMMERCIAL COMPONENTS - 2N3906-AP - BJT, PNP, 40VDC, TO-92 | 1924641 | 100 | 0,028 HT | David | FA_002 | N | O | O | O |
| the_nihilant | STMICROELECTRONICS - ULN2803A - RESEAU DE TRANSISTOR DARLINGTON 8NPN | 1094428 | 10 | 0,84 HT | David | FA_002 | N | O | O | O |
| Eric | KONTAKT WL 200ML | 800946 | 1 | 5,56 HT | David | FA_002 | N | O | O | O |
| Eric | KONTAKT IPA 200ML | 2142406 | 1 | 6,78 HT | David | FA_002 | N | O | O | O |
| Eric | NXP - BYC10D-600 - DIODE HYPERFAST 10A 600V TO220AC | 2075013 | 4 | 1,23 HT | David | FA_002 | N | O | O | O |
| Lab | VISHAY DALE RESISTOR, METAL FILM, 1KOHM, 3W, 1% ref CPF31K0000FKE14 | 1218226 | 1 | 1,51 HT | David | FA_002 | N | O | O | O |
| MAZ24 | ATAVRISP2 | 1135517 | 1 | 28,13 | David | FA_002 | N | O | O | O |
| MAZ24 | ARDUINO A000048 | 1848694 | 2 | 4,41 | David | FA_002 | N | O | O | O |
| MAZ24 | ARDUINO UNO A000073 | 2285200 | 1 | 26,97 | David | FA_002 | N | O | O | O |
| MAZ24 | ULN2003ADR | 1470513 | 10 | 0,31 | David | FA_002 | N | O | O | O |
| Crafty | LTC3122EMSE#PBF BOOST SYNCH 15V 2.5A 3MHZ 12MSOP | 2148749 | 10 | 3,51 | David | FA_002 | N | O | O | N |
| Crafty | NXP - 2N7002P - MOSFET CANAL N 60V 0.36A SOT23 | 1859848RL | 30 | 0,115 | David | FA_002 | N | O | O | N |
| Crafty | KINGBRIGHT - KPTD-3216ZGC-01 - LED 1206 DOME REV.RUBAND TRUE-GRE | 2290350 | 40 | 0,40 | David | FA_002 | N | O | O | N |
| Crafty | TEXAS INSTRUMENTS - TLC59116IPWR - LED DRIVER, 16CH, I2C BUS, TSSOP28 | 1647815 | 4 | 4,24 | David | FA_002 | N | O | O | N |
| Crafty | TEXAS INSTRUMENTS - TLC5941PWPG4 - DRIVER DE LED 16 VOIES CMS | 1226308 | 4 | 2,28 | David | FA_002 | N | O | O | N |
| Crafty | NXP - PCA9634PW - DRIVER DE LED RGBA 20-TSSOP | 1854071 | 4 | 1,65 | David | FA_002 | N | O | O | N |
| Crafty | NXP - PCA9622DR - DRIVER DE LED RGBA 32-TSSOP | 1854075RL | 4 | 1,89 | David | FA_002 | N | O | O | N |
| Crafty | LINEAR TECHNOLOGY - LTC3109IUF#PBF - BOOST PMU 20QFN | 1839119 | 4 | 5,31 | David | FA_002 | N | O | O | N |
| Crafty | PANASONIC - EECF5R5U155 - CONDENSATEUR 1.5F 5.5V | 1305065 | 2 | 4,21 | David | FA_002 | N | O | O | N |
| Crafty | PANASONIC - EECS5R5H105 - CONDENSATEUR 1F 5.5V | 9697497 | 2 | 4,17 | David | FA_002 | N | O | O | N |
| MrPozor | CONNECTEUR 90142 C GRID 26 VOIES | 3291662 | 5 | 1,19 | David | FA_002 | N | O | O | O |
| MrPozor | CONTACT FEMELLE 26-28AWG | 9733280 | 40 | 0,23 | David | FA_002 | N | O | O | O |
| MrPozor | CONNECTEUR 90142 C GRID 14 VOIES | 3291601 | 5 | 0,99 | David | FA_002 | N | O | O | O |
| MrPozor | EMBASE F HE10 DROIT 14V.+S. CABLE | 1099237 | 1 | 0,59 | David | FA_002 | N | O | O | O |
| CydGy | CONTACT FEMELLE 26-28AWG | 1308868 | 5 | 1,97 € | David | FA_002 | N | O | O | O |
| CydGy | CONNECTEUR RCA/PHONO FEMELLE 3 VOIES | 2293877 | 1 | 2,73 € | David | FA_002 | N | O | O | O |
| CydGy | FICHE FEMELLE JACK 3.5MM STEREO | 1280747 | 1 | 0,86 € | David | FA_002 | N | O | O | O |
| CydGy | TRANSFORMATEUR COURANT E5 3000UH | 1579334 | 1 | 2,53 € | David | FA_002 | N | O | O | O |
| CydGy | DIODE LASER 655NM | 1272658 | 1 | 6,84 € | David | FA_002 | N | O | O | O |
| Eric | AVAGO HDSP-4832 RESEAUX DE LED MULTICOL. | 1003271 | 1 | 5.29 €HT | David | FA_003 | N | O | O | N |
| Crafty | WURTH ELEKTRONIK - 74488540070 - INDUCTANCE RECUPERATION D'ENERGIE 7.5UH | 2249879 | 8 | 3,55 | David | FA_003 | N | O | O | N |
| David | VITELEC - VB1094/L-75 - EMBASE PANNEAU FEMELLE BNC DROITE | 2254719 | 4 | 3,36 | David | FA_003 | N | O | O | N |
| Raoul | FRDM-KL25Z - CARTE KINETIS L SERIES KL25Z | 2191861 | 1 | 11,75€HT | <acheteur> | FA_003 | O | O | O | N |
| Pilou | FRDM-KL25Z - CARTE KINETIS L SERIES KL25Z | 2191861 | 1 | 11,75€HT | David | FA_003 | N | O | O | N |
| Pilou | TL082ACP - AMPLI OP DOUBLE BIFET | 1103189 | 4 | 0,64€HT | David | FA_003 | N | O | O | N |
| Pilou | VT935G - PHOTO RESISTANCE SERIE VT901 | 1652638 | 5 | 0,40€HT | David | FA_003 | N | O | O | N |
| 3dsman | FRDM-KL25Z - CARTE KINETIS L SERIES KL25Z | 2191861 | 1 | 11,75€HT | David | FA_003 | N | O | O | N |
| 3dsman | VEMD2020X01 - PHOT. DIODE SMD GULLWING FILT. | 1779705 | 10 | 0,3€HT | David | FA_003 | N | O | O | N |
| 3dsman | TSAL6200.. - IR EMITT. HI POWR 940NM 5MM 17DEG | 1779662 | 10 | 0,26€HT | David | FA_003 | N | O | O | N |
| Nicolas | MULTICOMP 2226TG | 1593529 | 100 | 0,083€HT | David | FA_003 | N | O | N | N |
| Nicolas | MULTICOMP 2226A-22 | 1593518 | 10 | 0,076€HT | David | FA_003 | N | O | N | N |
| Nicolas | MULTICOMP 2226B-22 | 1593527 | 10 | 0,077€HT | David | FA_003 | N | O | N | N |
| Eric | Double diode 1,2kV 11A ref: DSP8-12A fabricant : IXYS TO220AB | 1080104 | 4 | 1,54€HT | David | FA_003 | N | O | O | N |
| Antoine | MICRO 8 BITS AVR 32K FLASH 28PDIP | 1715487 | 2 | 3,86€HT | David | FA_003 | N | O | O | N |
| Antoine | REGULATEUR DE TENSION 5V | 1467758 | 4 | 0,49€HT | David | FA_003 | N | O | O | N |
| Antoine | CONDENSATEUR 22UF 50V | 8766835 | 2 | 0,137€HT | David | FA_003 | N | O | O | N |
| Antoine | CONDENSATEUR 0.01UF 50V | 2112749 | 2 | 0,27€HT | David | FA_003 | N | O | O | N |
| Antoine | RESISTANCE CARBONE 1/4W 1K0 | 1265072 | 5 | 0,13€HT | David | FA_003 | N | O | O | N |
| Thomas | INDUCTANCE | 2061655 | 5 | 0.36€HT | David | FA_003 | N | O | N | N |
| Raoul | C0805C105K4RACTU | 9227792 | 10 | 0.053 | David | FA_003 | O | O | O | N |
| Raoul | TMK212B7473KD-T | 1759031 | 100 | 0.008 | David | FA_003 | O | O | O | N |
| Raoul | CC0805KRX7R9BB391 | 3019846 | 10 | 0.054 | David | FA_003 | O | O | O | N |
| Raoul | CC0805KRX7R9BB222 | 3019895 | 10 | 0.044 | David | FA_003 | O | O | O | N |
| Raoul | APXA160ARA331MJC0G | 1580614 | 5 | 1.45 | David | FA_003 | O | O | O | N |
| Raoul | CC0805JRNP09BN101 | 3606028 | 10 | 0.086 | David | FA_003 | O | O | O | N |
| Raoul | GRM155R61A274KE15D | 1759111 | 100 | 0.008 | David | FA_003 | O | O | O | N |
| Raoul | 30CTQ060STRLPBF | 1611297 | 1 | 2.07 | David | FA_003 | O | O | O | N |
| Raoul | SER2915L-103KL | 2288908 | 1 | 2.85 | David | FA_003 | O | O | O | N |
| Raoul | CSD16415Q5 | 1710776 | 1 | 2.01 | David | FA_003 | O | O | O | N |
| Raoul | CRCW080517K8FKEA | 1652927 | 1 | 0.076 | David | FA_003 | O | O | O | N |
| Raoul | CRCW04025R11FKED | 1469821 | 50 | 0.009 | David | FA_003 | O | O | O | N |
| Raoul | CRCW08051K00FKEA | 1469847 | 50 | 0.022 | David | FA_003 | O | O | O | N |
| Raoul | CRCW08055M36FKEA | 2139208 | 50 | 0.008 | David | FA_003 | O | O | O | N |
| Raoul | CSNL1206FT3L00 | 2079419 | 5 | 0.194 | David | FA_003 | O | O | O | N |
| Raoul | CRCW08053K16FKEA | 1469910 | 50 | 0.023 | David | FA_003 | O | O | O | N |
| Raoul | CRCW080551K1FKEA | 1469943 | 50 | 0.023 | David | FA_003 | O | O | O | N |
| MAZ24 | ATMEL ATTINY85-20PU | 1455162 | 10 | 1.09 | Damien H | FA_004 | N | O | N | N |
| NAZ24 | ATMEL ATTINY4313-PU | 1841620 | 10 | 1.14 | Damien H | FA_004 | N | O | N | N |
| 3dsman | MULTICOMP-703-1028-LED RGB 3528 PLCC | 2112143 | 5 | 0,42€HT | Damien H | FA_004 | N | O | N | N |
| 3dsman | EXCELITAS TECH-VT935G-PHOTO RESISTANCE SERIE VT901 | 1652638 | 5 | 0,40€HT | Damien H | FA_004 | N | O | N | N |
| 3dsman | BTB04-600SL - TRIAC 4A 600V TO-220AB | 9910522 | 10 | 0,47€HT | Damien H | FA_004 | N | O | N | N |
| 3dsman | OPTOCOUPLEUR SORTIE DARLINGTON DIP-4 | 1852745 | 10 | 0,072€HT | Damien H | FA_004 | N | O | N | N |
| 3dsman | ATMEGA88A-AU - MCU, 8BIT, AVR, 8K FLASH, 32TQFP | 1841614 | 10 | 1,72€HT | Damien H | FA_004 | N | O | N | N |
| 3dsman | FOX ELECTRONICS - FXO-HC536R-20 - OSC, 3.2X5MM, SMD, CER, 20.000MHZ | 1641035 | 2 | 1,65€HT | Damien H | FA_004 | N | O | N | N |
| 3dsman | AMS - AS5035-ASSU - ENCODER, MAGNETIC, ROTARY, 8BIT, 16SSOP | 1630798 | 1 | 4,64€HT | Damien H | FA_004 | N | O | N | N |
| the_nihilant | ATMEL - ATMEGA48A-AU - MCU, 8BIT, AVR, 4K FLASH, 32TQFP | 1841612 | 5 | 1,92 HT | Damien H | FA_004 | N | O | N | N |
| the_nihilant | KEYSTONE - 2463 - SUPPORT POUR BATTERIE | 1702631 | 3 | 1,05 HT | Damien H | FA_004 | N | O | N | N |
| the_nihilant | TE CONNECTIVITY / AMP - 0-0881545-2 - STRAP D'INTERCONNEXION AVEC LANGUETTE | 4218176 | 50 | 0,115 HT | Damien H | FA_004 | N | O | N | N |
| PapyCHeF | Résistance chauffante (pour quartz) | 1515897 | 5 | 1,02 (HT) | Damien H | FA_004 | N | O | N | N |
| Yann | Cable FPC 16pin 20cm inversé | 1908499 | 1 | 4,92 (HT) | Damien H | FA_004 | N | O | N | N |
| Raoul | MC33926 | 2102575 | 2 | 4.01 HT | Damien H | FA_004 | N | O | N | N |
| Damien H | A4988SETTR-T MOTOR DRIVER | 2057418 | 1 | 4,00 (HT) | Damien H | FA_004 | N | O | N | N |
| MAZ24 | capteur hall effect | 1811311 | 10 | 0,79 (HT) | Damien H | FA_004 | N | O | N | N |
| MAZ24 | ATtiny13A-PU | 1704566 | 10 | 1,12 (HT) | Damien H | FA_004 | N | O | N | N |
| MAZ24 | Hall switch | 1825248 | 20 | 0,36(HT) | Damien H | FA_004 | N | O | N | N |
| Pilou | STP13NM60N | 1737870 | 1 | 4,23(HT) | Damien H | FA_004 | N | O | N | N |
| Pilou |
Gotronic
| CDR2014 | connecteurs miniatures nsk254 male coudé 4cts | 48712 | 10 | 0.12€ | GO_001 | N | N | N | N | |
| CDR2014 | connecteurs miniatures nsk254 male droit 4cts | 48717 | 10 | 0.12€ | GO_001 | N | N | N | N | |
| CDR2014 | connecteurs miniatures nsk254 femelle 4cts | 48722 | 10 | 0.08€ | GO_001 | N | N | N | N | |
| CDR2014 | connecteurs miniatures nsk254 contacts | 48722 | 5 | 0.20€ | GO_001 | N | N | N | N | |
| CDR2014 | connecteurs miniatures nsk396 male coudé 3cts | 48691 | 10 | 0.15€ | GO_001 | N | N | N | N | |
| CDR2014 | connecteurs miniatures nsk396 male droit 3cts | 48694 | 10 | 0.15€ | GO_001 | N | N | N | N | |
| CDR2014 | connecteurs miniatures nsk396 femelle 3cts | 48697 | 10 | 0.10€ | GO_001 | N | N | N | N | |
| CDR2014 | connecteurs miniatures nsk396 contacts | 48698 | 4 | 0.55€ | GO_001 | N | N | N | N | |
| CDR2014 | pince a sertir les cosses de petites section | 13169 | 1 | 24.50€ | GO_001 | N | N | N | N | |
| CDR2014 | 300 colliers a sertir | 11357 | 1 | 5.50€ | GO_001 | N | N | N | N | |
| CDR2014 | Roue métallique OW006 | 25894 | 4 | 2.50€ | GO_001 | N | N | N | N | |
| 3dsman | 300 colliers a sertir | 11357 | 1 | 5.50€ | GO_001 | N | N | N | N | |
| 3dsman | gaine thermoretractable 1.6mm | 08840 | 1 | 1.00€ | GO_001 | N | N | N | N | |
| 3dsman | gaine thermoretractable 2.4mm | 08851 | 1 | 1.10€ | GO_001 | N | N | N | N | |
| 3dsman | gaine thermoretractable 3.2mm | 08841 | 1 | 1.20€ | GO_001 | N | N | N | N | |
| 3dsman | pack de 65 cables de conection m/m bbj2 | 12309 | 1 | 5.50€ | GO_001 | N | N | N | N | |
| Axone | BP rond | 07116 | 2 | 1.10€ | GO_001 | N | N | N | N | |
| Pilou | Paire de motoréducteurs DG01D | 31076 | 1 | 6.6€ | GO_001 | N | N | N | N | |
| Pilou | Adaptateur roue - moteur WMA | 31728 | 1 | 0.6€ | GO_001 | N | N | N | N | |
Radiospares
| Demandeur | Description | Ref RS | Quantité | Prix unitaire | Acheteur | Commande n° | Payé d'avance (O/N) | Commandé (O/N) | Distribué (O/N) | Remboursé/Archive (O/N) |
| Pilou | Lot de 10 RESSORTS 28MM | 751-528 | 1 | 2,99€ | RS_001 | N | O | O | O | |
| Eric | Clé réglable à mâchoires extra fines 8" marque Bahco ref 9031-T | 710-8798 | 1 | 31,23€HT | RS_001 | N | O | O | O | |
| Lab | Lot de 5 résistance 1% 1W 10R SFERNICE | 123-162 | 2 | 2.784€HT | Yannick | RS_001 | N | O | O | ? |
| Lab | lot de 4 filtres ref T0058711718 pour station à dessouder Weller | 358-9483 | 1 | 24,10€HT | <Yannick> | RS_002 | N | O | O | ? |
| Eric | lot de 4 filtres ref T0058711718 pour station à dessouder Weller | 358-9483 | 1 | 24,10€HT | <Patrick> | RS_003 | N | O | O | O |
| Gérard | Lot de 100 contacts à sertir Connecteur Molex 3,96mm AWG 22-28 | [1] 245-4718 | 1 | 7,50€HT | <Patrick> | RS_003 | N | O | O | O |
| Michel | contacts a sertir Molex 2,54mm AWG 22-28 | 720-6646 | 300 | 0,052 | <Patrick> | RS_003 | N | O | O | O |
| Michel | Embases Molex droites 2b 2,54 | 679-5515 | 30 | 0,31 | <Patrick> | RS_003 | N | O | O | O |
| Michel | Embases Molex coudées 2b 2,54 | 173-2916 | 20 | 0,726 | <Patrick> | RS_003 | N | O | O | O |
| Michel | Embases Molex coudées 4b 2,54 | 173-2944 | 10 | 1,02 | <Patrick> | RS_003 | N | O | O | O |
| Michel | Boitiers Molex 2b 2,54 | 687-7890 | 100 | 0,044 | <Patrick> | RS_003 | N | O | O | O |
| Michel | Boitiers Molex 4b 2,54 | 687-7900 | 20 | 0,233 | <Patrick> | RS_003 | N | O | O | O |
| Patrick | Pile CR2016 | 457-4735 | 2 | 2,19 | <Patrick> | RS_003 | N | O | O | O |
| Patrick | Pile CR2032 | 457-4757 | 2 | 2,19 | <Patrick> | RS_003 | N | O | O | O |
| Patrick | 5 Piles montre SR66 | 514-7766 | 1 | 2,29 | <Patrick> | RS_003 | N | O | O | O |
| Patrick | 5 Piles montre SR59 | 514-7744 | 1 | 4,40 | <Patrick> | RS_003 | N | O | O | O |
| Patrick | 5 Piles montre SR41 | 593-401 | 2 | 10,51 | <Patrick> | RS_003 | N | O | O | O |
| Eric | CI STM L4981B | 189-1144 | 2 | 2,15 | <Patrick> | RS_003 | N | O | O | O |
| Eric | Condensateur alu Nichicon 50V 1uF radial ESR:2Ohms ref UBT1H010MPD8 | 762-1727 | 10 (UDV) | 0,384 | <Patrick> | RS_003 | N | O | O | O |
| Eric | Condensateur alu Nichicon 25V 220uF radial ESR:0,1Ohms ref UBT1E221MPD8 | 762-1682 | 5 (UDV) | 0,85 | <Patrick> | RS_003 | N | O | O | O |
| Eric | Condensateur alu Nichicon 50V 2,2uF radial ESR:1,8Ohms ref UBT1H2R2MPD8 | 762-1720 | 5 (UDV) | 0,518 | <Patrick> | RS_003 | N | O | O | O |
| Eric | Condensateur alu Panasonic 450V 10uF radial Ref EEUEE2W100 | 699-7569 | 5 (UDV) | 0,786 | <Patrick> | RS_003 | N | O | O | O |
| Lab | Condensateur MKT Vishay 0.1uF 275VCA "X2" ref F1772-410-2200-E3 | 148-474 | 20 (UDV) | 0,657 | <Patrick> | RS_003 | N | O | O | O |
| Lab | Condensateur PET Kemet 10nF 220 V c.a., 630 V c.c. 4 x 9 x 13mm ref R60PF2100AA30J | 824-351 | 5(UDV) | 0,418 | <Patrick> | RS_003 | N | O | O | O |
| Patrick | Axial AL cap, 4700uF, 25V | 707-6708 | 2(UDV) | 2,42 | <Patrick> | RS_003 | N | O | O | O |
| Patrick | Perchlorure de fer en granulé (delai 14 jours mini 50€ H.T.) | 2550514751 | 1(UDV) | 4,2 | <Patrick> | RS_004 | N | O | O | O |
| Patrick | lot 2 piles 12V A23 Duracel | 717-4029 | 6 | 3,21 | <Patrick> | RS_003 | N | O | O | O |
| Lab | lot 5 languettes Kapton fer dessouder Weller ref T0051361699 | 176-1829 | 1 | 10,70 | <Patrick> | RS_003 | N | O | O | O |
| Lab | DS114 buse de dessoudage 3, 3 - 1,8mm Weller ref T0051351499 | 517-621 | 2 | 9,80 | <Patrick> | RS_003 | N | O | O | O |
| Eric | DS114 buse de dessoudage 3, 3 - 1,8mm Weller ref T0051351499 | 517-621 | 1 | 9,80 | <Patrick> | RS_003 | N | O | O | O |
| Lab | CI MOC3020 | 761-3388 | 10 (UDV) | 0,616 | <Patrick> | RS_004 | N | O | O | N |
| Eric | DS119 aiguille d'aspiration Weller ref T0051352700 | 2550520811 | 1 | 9,00 | <Patrick> | RS_004 | N | O | O | O |
| Eric | DS BUSE DE CALIBRAGE Weller ref T0052474999 | 2550520910 | 1 | 6,10 | <Patrick> | RS_004 | N | O | O | O |
| Lab | lot de 5 ressorts pour filtres ref T0058711720 pour station à dessouder Weller | 2550521588 (delai 21 jours mini 50€ H.T.) | 1 | 5,50€HT | <Patrick> | RS_004 | N | O | O | O |
| Eric | Bouchon fileté de filtre ref T0058711719 pour station à dessouder Weller | 2550521587 (delai 21 jours mini 50€ H.T.) | 1 | 4€HT | <Patrick> | RS_004 | N | O | O | O |
| Eric | Lot de 5 joints pour bouchon fileté de filtre ref T0051344499 pour station à dessouder Weller | 2550520804 (delai 21 jours mini 50€ H.T.) | 1 | 4,20€HT | <Patrick> | RS_004 | N | O | O | O |
| Lab | FORETS DE RECHANGE STANDARD 0,6 mm / 0,9 mm / 1,4 mm / 1,9 mm pour outil de nettoyage Weller ref T0051350199 | 2550520805 (delai 21 jours mini 50€ H.T.) | 1 | 15,10 | <Patrick> | RS_004 | N | O | O | N |
Selectronic
La prochaine commande a pour référence interne : SE_008
Frais de port : 0€ (sauf objets lourds)
Certains produits sont pas en stock à Paris et requièrent d'être livrés de Lille d'où un délai d'une semaine sur certaines pièces.
Le mieux est d'aller au mag le mardi et dans ce cas c'est dispo jeudi.
| Lab | foret Hss-Co 3,2 mm | 9773-1 | 1 | 2,70€TTC | F4GRX | SE_001 | N | O | O | O |
| Lab | lot de 10 forets Hss 1 mm | 12.1820-10 | 1 | 8,50€TTC | F4GRX | SE_001 | N | O | O | O |
| Lab | lot 2 tournevis pour borniers | 12.9706 | 1 | 24,90€TTC | F4GRX | SE_001 | N | O | O | O |
| Eric | Embout TORX T8x25mm - Lot de 2 | 7075-23 | 1 | 2,90€TTC | F4GRX | SE_001 | O | O | O | O |
| Eric | Embout TORX T9x25mm - Lot de 2 | 7075-24 | 1 | 2,90€TTC | F4GRX | SE_001 | O | O | O | O |
| Eric | Condensateur électrochimique polarisé sortie radiale - 2,2µF 400V | 6495 | 3 | 0,80€TTC | F4GRX | SE_001 | O | O | O | O |
| Eric | Condensateur électrochimique polarisé sortie radiale - 10µF 400V | 1792-1 | 2 | 1,35€TTC | F4GRX | SE_001 | O | O | O | O |
| Eric | Condensateur électrochimique polarisé sortie radiale - 22µF 400V | 1792-3 | 1 | 2,70€TTC | F4GRX | SE_001 | O | O | O | O |
| Eric | Condensateur électrochimique polarisé sortie radiale - 47µF 400V | 1792-4 | 1 | 3,30€TTC | F4GRX | SE_001 | O | O | O | O |
| Lab | Condensateur électrochimique polarisé sortie radiale - 22µF - 50V - Lot de 2 | 9296-2 | 1 | 0,70€TTC | F4GRX | SE_001 | N | O | O | O |
| Lab | Lot de 10 fusibles 200mAT | 13.9795-10 | 1 | 2.20€TTC | Ellyan | SE_002 | N | O | O | O |
| Lab | Lot de 10 fusibles 2AT | 13.9705-10 | 1 | 1.70€TTC | Ellyan | SE_002 | N | O | O | O |
| Lab | Résistance couche métal 1% 40,2 ohm 0,6 W traversante | 4764 | 6 | 0,35€TTC | Pilou | SE_003 | N | O | O | O |
| Lab | Résistance de précision 1% à couche métallique de 10,00 ohm 0,6 W traversante | 4705 | 3 | 0,35€TTC | Pilou | SE_003 | N | O | O | O |
| Lab | Bouton 10mm Gris/grise | 13.0006 | 15 | 2.00€TTC | Pilou | SE_003 | N | O | O | O |
| Eric | Résistance cémentée - 10W - 39Ω | 1499-20 | 1 | 1,35€TTC | Pilou | SE_003 | N | O | O | O |
| Ellyan | Borne de service | 13.0902-12 | 1 | 2.00€TTC | Pilou | SE_003 | N | O | O | O |
| Ellyan | convertisseur SATA | 13.0669-9 | 2 | 8.50€TTC | Pilou | SE_003 | N | O | O | O |
| Lab | Pince à sertir (scrounches) | 13.5546.3 | 1 | Pilou | <plus vendu par selectronic> | N | N | N | O | |
| Lab | Bouchons/capuchons SEULS pour Bouton 10mm Gris/grise REF 13.0006 | <pas vendu par selectronic> | 6 | Pilou | N | O | N | O | ||
| Lab | voir aussi ce produit (bouton gris, bouchon bleu) qui convient mieux aux Hameg | 0004 ? ou 13.0004 <pas disponible> | 20 | 2.00€TTC | <acheteur> | SE_004 | N | N | N | O |
| Lab | SELECTRONIC ZD - Fer de rechange 24V 48W | 2130-5 | 2 | 13,90€TTC | Eric | SE_005 | N | O( | O | N |
| Lab | Bouton 10mm Gris/grise | 13.0006 | 7 | 2.00€TTC | Eric | SE_005 | N | O | O | N |
| Lab | Bouton alu. axe 6mm Diam. 29x14mm argent | 6087-4 | 1 | 1.84€TTC promo | Eric | SE_005 | N | O | O | N |
| Eric | Ajustable horizontal 10mm piste Cermet 2,2 kohm PIHER monotour | 3140 | 2 | 1.15€TTC | Eric | SE_005 | N | O | O | O |
| Eric | Ajustable horizontal 10mm piste Cermet 10 kohm PIHER monotour | 3136 | 2 | 1.15€TTC | Eric | SE_005 | N | O | O | O |
| Eric | Transformateur TOKO 707 VX -A043YUK compatible LM1893 | 7294 | 5 | 1.14€TTC promo | Eric | SE_005 | N | O | O | O |
| Eric | Thermistance CTN 4,7 kohm | 5276 | 4 | 0.90€TTC | Pilou | SE_006 | N | O | O | O |
| Eric | Varistance 275VRMS / 4000A 275 LA 40 diam 24mm | 9091 | 4 | 1.25€TTC | Pilou | SE_006 | N | O | O | O |
| Eric | Résistance cémentée - 20W - 47Ω | 1498-21 | 4 | 1.60€TTC | Eric | SE_007 | O | O | O | O |
