Projets:Perso:2013:CNC laser cutter/engraver
Revision as of 14:02, 16 May 2013 by Jmpoure (Talk | contribs)
CNC laser cutter/engraver, 40W
Auteur jmpoure, Julien
Date de proposition 15/05/2013
Tags du projet CNC, laser, cutter, engraver, CO2
Projet personnel de jmpoure, Julien
Projet CNC laser cutter/engraver, 40W
This projects aims to build a small 40W CNC laser cutter / engraver
This project is a personal project which aims to build a small laser CNC at the lowest possible cost for learning purpose.
There is a need for a small and versatile CNC laser cutter/engraver:
  • Cutting small wood / acrylic parts.
  • Engaving aluminium / metal parts.
The devices should not require too much space and should be cheap, around 1000 EUR maximum.
Buildlog.net laser
Buildlog.net 2.0 laser
Follow these links for a complete description:
Technical details
  • Working area: 12” x 20” x 4” = 304,8 mm x 508 mm x 101,6 mm. Could be extended to a larger area.
  • Laser: 40W CO2 lasers sealed gas laser.
  • Structure: Openrail or Makerslide.
  • Axes : X and Y axes.
  • Lift platform with motor (Z axe?).
  • Fume extraction.
  • Water cooling.
  • Red Dot Pointer.
  • Should run under MACH3 and LinuxCNC
More details: http://www.buildlog.net/blog/2011/02/buildlog-net-2-x-laser/
Materials
Cutting:
  • Acrilyc (no PVC)
  • Dark plastic
  • Wood
Engraving:
  • Wood
  • Glass
  • Anodized Aluminum
  • Granite
Supply
We don't want to order from US based companies, as delivery costs are too high. So we are looking for european suppliers.
Phase 1: mechanics and rails
Phase 2: electronics and laser
Be the force with us :)
