Projets:Perso:2013:CNC laser cutter/engraver
Revision as of 13:27, 17 May 2013 by Jmpoure (Talk | contribs)
CNC laser cutter/engraver, 40W
Auteur jmpoure, Julien, eloib
Date de proposition 15/05/2013
Tags du projet CNC, laser, cutter, engraver, CO2
Projet personnel de jmpoure, Julien, eloib
Projet CNC laser cutter/engraver, 40W
This projects aims to build a small 40W CNC laser cutter / engraver
This project is a personal project which aims to build a small laser CNC at the lowest possible cost for learning purpose.
We may also collaborate with Amiens hacker club on that project (Eloib, www.etolab.com).
There is a need for a small and versatile CNC laser cutter/engraver:
  • Cutting small wood / acrylic parts.
  • Engaving aluminium / metal parts.
The devices should not require too much space and should be cheap, around 1000 EUR maximum.
Buildlog.net laser
Buildlog.net 2.0 laser
Follow these links for a complete description:
Technical details
I would like to upgrade Buildlog 2.x laser to 60W and later 80-100W.
  • Working area: 12” x 20” x 4” = 304,8 mm x 508 mm x 101,6 mm. Could be extended to a larger area.
  • Laser: 60 watt co2 laser tube(later upgradeable to 80-100 watt)
  • Structure: Openrail or Makerslide.
  • Axes : X and Y axes.
  • Lift platform with motor (Z axe?).
  • Fume extraction.
  • Water cooling.
  • Red Dot Pointer.
  • Should run under MACH3 and LinuxCNC
More details: http://www.buildlog.net/blog/2011/02/buildlog-net-2-x-laser/
To obtain that, we must use Scalable Laser 2.x script.
Materials
Cutting:
  • Acrilyc (no PVC)
  • Dark plastic
  • Wood
Engraving:
  • Wood
  • Glass
  • Anodized Aluminum
  • Granite
Supply
We don't want to order from US based companies, as delivery costs are too high. So we are looking for european suppliers.
Laser tubes
It seems that 40W entry-level laser tubes are extremely cheap on eBay:
By comparision, 60W tubes are more expensive:
I am currently looking for a cheap 60W tube.
Phase 1: mechanics and rails
Phase 2: electronics and laser
Be the force with us :)
