Projets:Perso:2012:StickArcade
Stick Arcade 2 Players (For Mame) | |
Auteur | Jnat |
Date de proposition | 20/02/2012 |
Tags du projet | Arcade;mame;usbhid;arduino;shift register; |
Lieu d'utilisation final | @Work/Home |
Utilisateur final | Gamers! |
Projet personnel de Jnat |
Overview
This project is about making a working, robust but "cheap" arcade stick. The stick is to be plugged in USB to a computer in order to play Mame arcade emulator or other games.
This project is made of 3 parts:
- Input multiplexing modules : making it possible for a simple arduino or Atmega chip to hold 30+ almost simultaneous inputs from players
- USB HID Module : The device will create 2 gamepad HID and a keyboard HID on host computer
- Stick body : mainly wood/metalworking in order to get a sturdy case (the arcade stick has to be strong and durable)
Input Multiplexing
Status : In Progress The first module has been soldered and tested
- Module is working
- Modules are daisy chain-able
Toggling an input on is made by connecting +5v to an input pin.
The multiplexing part is designed to be modular.
- Each board is based on a 74hc165N PISO shift register.
- These chips can be daisy chained giving a good opportunity to think about scalability.
- A module handles 8 inputs and uses 4 wires of the arduino (+ power and ground).
USB HID
Todo
