Projets:Perso:2012:StickArcade
Revision as of 22:27, 2 March 2012 by Jnat (Talk | contribs)
Stick Arcade 2 Players (For Mame)
Auteur Jnat
Date de proposition 20/02/2012
Tags du projet Arcade;mame;usbhid;arduino;shift register;
Lieu d'utilisation final @Work/Home
Utilisateur final Gamers!
Projet personnel de Jnat
Projet Stick Arcade 2 Players (For Mame)
  • Stick Arcade USB for 2 players
  • 2 sticks + 8 buttons for each player (30+ buttons total)
  • USBHID / Arduino / Woodworking
Overview
This project is about making a working, robust but "cheap" arcade stick. The stick is to be plugged in USB to a computer in order to play Mame arcade emulator or other games.
This project is made of 3 parts:
  • Input multiplexing modules : making it possible for a simple arduino or Atmega chip to hold 30+ almost simultaneous inputs from players
  • USB HID Module : The device will create 2 gamepad HID and a keyboard HID on host computer
  • Stick body : mainly wood/metalworking in order to get a sturdy case (the arcade stick has to be strong and durable)
Input Multiplexing
Since I am using an Arduino diecimila, there is not enough I/o pins to manage 30 input buttons. So multiplexing is needed to make it all fit in.
The multiplexing part is designed to be modular.
  • Each board is based on a 74hc165N PISO shift register.
  • These chips can be daisy chained giving a good opportunity to think about scalability.
  • A module handles 8 inputs and uses 4 wires of the arduino (+ power and ground).
Status : In Progress
The first module has been soldered and tested
Task Status
Prototype a working module Done
Make a "real" module Done
Test daisy chain-ability Done (proto+clean)
Connect at least 2 "clean" modules TODO
Improve stability when modules are chained TODO
Module is compact and routing is elegant TODO
Toggling an input on is made by connecting +5v to an input pin.
Components Placement
Module mask, made with hobbyist design rules
Schematic of the module
Proof of concept for the bottom of a module
the first shift Register module bottom pcb (need 5)
The same module, soldered and working
Connector Board
The connector board is designed to sit on top of the input module, making it easy for buttons to be connected via Faston connectors.
  • This board is powered by the +5v of the bottom board
  • It presents
    • 8 power connectors (faston)
    • 8 labelled input connectors (faston)
CAUTION : Spacing between header pins may not be consistent with the input module. I need to check this
USB HID
Todo
