Projets:Perso:2013:CNC laser cutter/engraver
Revision as of 09:20, 16 May 2013 by Jmpoure (Talk | contribs)
CNC laser cutter/engraver, 40W
Auteur jmpoure, Julien
Date de proposition 15/05/2013
Tags du projet CNC, laser, cutter, engraver, CO2
Projet personnel de jmpoure, Julien
Projet CNC laser cutter/engraver, 40W
This projects aims to build a small 40W CNC laser cutter / engraver
This project aims to build a small laser CNC at the lowest possible cost in order to learn how to build a laser.
There is a need for a small and versatile CNC laser cutter/engraver:
  • Cutting small wood / acrylic parts.
  • Engaving aluminium parts.
The devices should not require too much space and should be cheap, around 1000 EUR maximum.
Buildlog.net laser
While searching the Internet, I found this small 40W CO2 Buildlog.net 40W CO2 laser, using famous makerslide/openrail and arduino.
Buildlog.net 2.0 laser
Follow these links for a complete description:
This laser seems to be a derivate from Shapeoko CNC.
Shape and structure
The structure could be made of Openrail or Makerslide.
