Projets:Perso:2013:CNC laser cutter/engraver
CNC laser cutter/engraver, 40W | |
Auteur | jmpoure, Julien |
Date de proposition | 15/05/2013 |
Tags du projet | CNC, laser, cutter, engraver, CO2 |
Projet personnel de jmpoure, Julien |
This projects aims to build a small 40W CNC laser cutter / engraver
This project aims to build a small laser CNC at the lowest possible cost in order to learn how to build a laser.
There is a need for a small and versatile CNC laser cutter/engraver:
- Cutting small wood / acrylic parts.
- Engaving aluminium parts.
The devices should not require too much space and should be cheap, around 1000 EUR maximum.
Buildlog.net laser
While searching the Internet, I found this small 40W CO2 Buildlog.Net 40W CO2 laser.
Buildlog.Net laser by Barton Dring is licensed under a Creative Commons Attribution-ShareAlike 3.0.
Follow these links for a complete description:
This laser seems to be a derivate from Shapeoko CNC.
Technical details
- Working area: 12” x 20” x 4” = 304,8 mm x 508 mm x 101,6 mm
- Structure: Openrail or Makerslide.
- Axes : X and Y axes. Z axes is modified manually.
