Projets:Perso:2013:CNC laser cutter/engraver
Revision as of 09:32, 16 May 2013 by Jmpoure (Talk | contribs)
CNC laser cutter/engraver, 40W
Auteur jmpoure, Julien
Date de proposition 15/05/2013
Tags du projet CNC, laser, cutter, engraver, CO2
Projet personnel de jmpoure, Julien
Projet CNC laser cutter/engraver, 40W
This projects aims to build a small 40W CNC laser cutter / engraver
This project aims to build a small laser CNC at the lowest possible cost in order to learn how to build a laser.
There is a need for a small and versatile CNC laser cutter/engraver:
  • Cutting small wood / acrylic parts.
  • Engaving aluminium parts.
The devices should not require too much space and should be cheap, around 1000 EUR maximum.
Buildlog.net laser
While searching the Internet, I found this small 40W CO2 Buildlog.Net 40W CO2 laser.
Buildlog.Net laser by Barton Dring is licensed under a Creative Commons Attribution-ShareAlike 3.0.
Buildlog.net 2.0 laser
Follow these links for a complete description:
This laser seems to be a derivate from Shapeoko CNC.
Technical details
  • Working area: 12” x 20” x 4” = 304,8 mm x 508 mm x 101,6 mm
  • Laser: 40W CO2 lasers sealed gas laser.
  • Structure: Openrail or Makerslide.
  • Axes : X and Y axes. Z axes is modified manually.
More details: http://www.buildlog.net/blog/2011/02/buildlog-net-2-x-laser/
