Projets:Perso:2013:CNC laser cutter/engraver
CNC laser cutter/engraver, 40W | |
Auteur | jmpoure, Julien, eloib |
Date de proposition | 15/05/2013 |
Tags du projet | CNC, laser, cutter, engraver, CO2 |
Projet personnel de jmpoure, Julien, eloib |
This projects aims to build a small 40W CNC laser cutter / engraver
This project is a personal project which aims to build a small laser CNC at the lowest possible cost for learning purpose.
We may also collaborate with Amiens hacker club on that project (Eloib, www.etolab.com).
There is a need for a small and versatile CNC laser cutter/engraver:
- Cutting small wood / acrylic parts.
- Engaving aluminium / metal parts.
The devices should not require too much space and should be cheap, around 1000 EUR maximum.
Buildlog.net laser
Follow these links for a complete description:
- Buildlog.net
- Buildlog.net forum and new member intro
- Buildlog.net wiki
- Scalable Laser 2.x - Gantry, Frame, Skins and Drive Mods
- Parts in STEP format.
- Drawings.
- Bill of materials. Warning: does not include laser and AC/DC.
- Laser Optics Calculator and research documents.
Technical details
I would like to upgrade Buildlog 2.x laser to 60W and later 80-100W.
- Working area: 12” x 20” x 4” = 304,8 mm x 508 mm x 101,6 mm. Could be extended to a larger area.
- Laser: 60 watt co2 laser tube(later upgradeable to 80-100 watt)
- Structure: Openrail or Makerslide.
- Axes : X and Y axes.
- Lift platform with motor (Z axe?).
- Fume extraction.
- Water cooling.
- Red Dot Pointer.
- Should run under MACH3 and LinuxCNC
More details: http://www.buildlog.net/blog/2011/02/buildlog-net-2-x-laser/
To obtain that, we must use Scalable Laser 2.x script.
Materials
Cutting:
- Acrilyc (no PVC)
- Dark plastic
- Wood
Engraving:
- Wood
- Glass
- Anodized Aluminum
- Granite
Supply
We don't want to order from US based companies, as delivery costs are too high. So we are looking for european suppliers.
Phase 1: mechanics and rails
Phase 2: electronics and laser
Be the force with us :)
